USD composer crash during launch on Windows
I am unable to launch the USD Composer. When I try launching the app, splash screen appears and after that the app crashes. The first time I installed the app (last evening) it worked well, but since then I cannot run it.
I tried multiple releases and using the recommended drivers listed on the website.
I attached the log files as well if that might get me somewhere. Any help is appreciated, thanks!
launcher.log (270 Bytes)
kit_20231216_170140.log (440.6 KB)
omni.kit.internal.log (15.9 KB)
omni.kit.sysinfo.log (4.5 KB)
@n.cvetkovic i am just another user - so Composer launched fine the first time but it stopped working overnight? mind mentioning your hardware spec?
Thank you so much for taking the time to respond to this issue.
Spec list:
NVIDIA GeForce RTX 3060
OS: Windows, Version: 10.0, Build: 19045
Processor: 13th Gen Intel(R) Core™ i5-13600KF
Total Memory (MB): 32577
Try deleting your user preferences file at c:/users/USER/appdata/local/ov/data/kit/Composer and then restart your computer and try again.
Thank you for the response! Unfortunately that did not help.
In the meantime I also tried using cleanup tool on multiple occasions, in addition to which tried to uninstall and delete all remaining files myself, trying multiple GPU driver versions, tried different builds of the composer and it’s always the same.
The only change I got so far was that the Blender USD branch stopped working properly as well, or to be more precise “Omniverse: Nucleus Connector” add-on is throwing an error while enabling.
So in conclusion I am suspecting that it might be something wrong with the omniverse app itself on my end, but am not sure what could it be.
Can you please do a complete uninstall of all OV apps and launcher, run the cleanup tool, and then just install Composer latest ONLY. Then try that. In your logs, it does not seem to identify your GPU correctly. Are you sure you have good drivers ? Is this a laptop with a second system card ?
Thank you for your reply, honestly I took a break from trying to make it work and tried installing everything again and it somehow worked! I am not sure what was the issue but I hope it will stay functional.
Now the last issue I have is with Blender (omniverse navigator addon) but I guess something went wrong while re-installing everything a countless times.
Thank you for your time everyone, I would be happy to write what was the actual issue and what helped at the end but I am honestly clueless.
