Add noise to Odometry
Hello, how can I add noise to odom in ActionGraph in the form of a GUI in isaac (2023.1.1). Thank you for your reply.
Hi @liuqiran1997 Have you successfully added it ? I am looking for the same.
Hi @liuqiran1997,
There are 2 ways:
  1. Drag in relevant Noise nodes and combine them with Math nodes to add noise to the outputs of the Isaac Compute Odometry node. The full library of nodes are here . You can add them to your action graph by using the search bar in the action graph tab.
  2. You can add in a script node to the graph, setup up inputs/outputs and apply any logic to your input data. The script node comes with examples.
