The Isaac version I’m using now is 2023.1.1. I want to add noise to the lidar in ActionGraph. I found the Noise node in ActionGraph, is it using the Noise node? I can’t find the documentation, can you explain how to connect?
Thank you for your reply.
I am moving your topic to the Isaac SIim category for better visibility.
Raffaello
@liuqiran1997
Maybe this is helpful: 7.1.17. Add Noise to Camera — Omniverse IsaacSim latest documentation
Thank you very much for your reply, I have seen this description you posted above on the official documentation before, but I see that the noise is added to the camera through the code, and I now want to add noise to the sensor in the form of a GUI through ActionGraph, and at the same time I retrieved the Noise node, and I want to ask if the noise is added through this or other nodes.
