I have a robot with a Lidar and RGB-D camera. I want to introduce some noise into the readings, and I could not find an option in the property window of the sensors to do so. I have used Gazebo previously, and there the option to add noise could directly be added in the xacro files while defining the robot. How do I add noise to my sensor readings in Isaac Sim? Thank you for your reply!
Regards,
Vivek Varma
Hi @vivekvarma98 ,
Unfortunately we don’t have a shortcut for adding noise to your sensor in the current version, but will be added soon.
You could write a python script to do this, although is not the best way but should work.
Kindly,
Liila
Hi @vivekvarma98,
I have the same problem as you. Have you been able to find a solution?
Kind regards,
Chris
Yes, we will have a solution for this by using the omnigraph, coming out spring 2022
It is spring now. =D Is there any directions to add some noise to lidar data?
We will Omnigraph in our next release, which is the tool for adding noise and other post processing to sensors
Thank you~!
The Isaac version I’m using now is 2023.1.1. I want to add noise to the lidar in ActionGraph, and I see you say it’s supported. I found the Noise node in ActionGraph, is it using the Noise node? I can’t find the documentation, can you explain how to use it if you connect? Thank you for your reply.
Hi
Is there any example in python script ?
