hello everyone, I configured my jetson AGX Orin devkit with normal configuration, and updated cuda but when i reboot it doesn’t show anything on the screen.
Can anyone help.
Welcome to the NVIDIA Developer forums! Your topic will be best served in the Jetson category.
I will move this post over for visibility.
Cheers,
Tom
No sure what you have done, suggest to reflash you device via SDK manager.
DevKit/custom board?
L4T/JetPack version?
DevKit : JETPACK 5.1.2
L4T 35.41
Can i flash it using the UART port because the flashing port doesnt show when i plug it with computer ?
You use the USB-C port above the 40-pin header for flashing, and the micro USB port for dumping debug messages.
The USB-C port above the 40 pin doesn’t show, only the USB type B port that work.
What is doesn't show
when i plug the jetson using USB C(flashing port) on pc host, the port number doesn’t show, it seems that the port is not working, i can only use uart port using minicom or putty.
I really have no idea what you are doing.
What does your port number
mean?
You don’t use the USB-C port with minicom/putty.
I can’t connect to the devkit using USB port C, i have same issue as in this post. The monitor doesnt display anything , so i tried to connect the dev kit with the host pc using the USB C to check if the problem comes from the monitor, so its not working.
Sorry if i don’t explain well.
I still have no idea what you are doing.
Just tell me if you are able to re-flash the device or not.
Hello, i re-flashed the device.
Thank you for you assistance
