AGX Xavier Dev Kit will not power on
AGX Xavier Dev Kit will not power up. Plugged into original power brick. White LED flashes, and then goes out and the system does not start up. Does this sound like my unit is dead? I suppose NVidia doesn’t have a repair option, does it?
hello qbit9,
may I know what’s the modification you’ve done? what’s the scenario to cause this failure. please setup the serial console via port J501 to gather the complete bootloader logs for reference,
besides,
are you able to enter forced-recovery mode to re-flash the target?
please refer to developer guide, To determine whether the developer kit is in Force Recovery mode as see-also,
thanks
