We want to inform you of some recent changes to the NGC Website.
New NGC Website UI
The https://ngc.nvidia.com/ site, where we publish DRIVE OS Dockers, recently underwent a user interface (UI) refresh. While this update improves the overall user experience, it means that some of our existing installation guides may not perfectly match the current website layout. We have screenshots of the new UI and flow here.
How to sign in and access driveos-sdk:
- On the host system, sign into NGC (https://ngc.nvidia.com) using your NVIDIA Developer credentials.
- Once you have signed in, select your NGC Organization (for NVIDIA Developer Users, this will be drive). Then, select driveos-sdk under the drop-down menu.
- DRIVE OS Docker Containers are located under PRIVATE REGISTRY on the upper left dropdown menu.
- Once signed in, select Setup under the User menu in the top-right of the page to Generate an API Key to pull Docker images.
If you have any questions or need assistance, please don’t hesitate to post in the forums or contact your NVIDIA Representative(s).
