Hi all, apologies if this doesn’t belong here but I’m not sure where else to put it since the source of the issue is eluding me. I first posted to the ArduPilot boards but wonder if this is a TX2 hardware issue. Essentially, here’s what’s going on:
- I have an OcPoc flight control unit (similar to Pixhawk) running Capter 3.5 and communicating with a RaspberryPi3 via MAVLink at various baudrates with no issues. I can connect from the RasPi to the FCU directly via serial (/dev/serial0) using mavproxy.py to see status as well as run MAVROS to stream data via ROS. All working well.
- I also have an NVIDIA TX2 with a Auvidea J120 carrier board which I’ve set up the same way as the RasPi and connect to the FCU, however running mavproxy.py to connect directly via TX2 serial (/dev/ttyTHS1) at various baudrates always gives me output like:
Connect /dev/ttyTHS1 source_system=255 Log Directory: Telemetry log: mav.tlog Waiting for heartbeat from /dev/ttyTHS1 MAV> online system 1 STABILIZE> Mode STABILIZE STABILIZE> status STABILIZE> Counters: Slave:0 MasterIn:[20] FGearOut:0 FGearIn:0 MasterOut:5 MAV Errors: 17 None 17: BAD_DATA {Bad prefix, data:[‘9’]} 3: HEARTBEAT {type : 2, autopilot : 3, base_mode : 81, custom_mode : 0, system_status : 3, mavlink_version : 3} status STABILIZE> Counters: Slave:0 MasterIn:[26] FGearOut:0 FGearIn:0 MasterOut:11 MAV Errors: 17 None 17: BAD_DATA {Bad prefix, data:[‘9’]} 9: HEARTBEAT {type : 2, autopilot : 3, base_mode : 81, custom_mode : 0, system_status : 3, mavlink_version : 3} . . .I tried using the dev kit carrier board and connecting via UART and this works fine, so it must be somehow related to the J120 carrier board…
- HOWEVER, if I first connect to the FCU via mavproxy.py on the RasPi, then switch the cable to the TX2 and try mavproxy.py again, I can see the status with no issues! The same applies to MAVROS; I can only stream data via ROS if I first set the stream rate using the RasPi, then swap the cables.
Any ideas? I’m clueless here. I don’t understand what connecting to the RasPi first and then swapping to the TX2 is doing in this setup, but that’s the main clue.
Thank you!
