I’ve been trying to get Remote Desktop working with my newly flashed TX2. I’m on Ubuntu 18.04 and Jetpack 4.5.1.
This seems like a common problem.
I followed the “get Vino working” instructions found in the L4T-README file.
The “Desktop Sharing” options crash … in fact, Desktop Sharing just crashes with an internal error. I attempted to follow these instructions for getting that bit working but Desktop Sharing still doesn’t open.
I also tried getting remote access using XRDP. Link
It seems like I’m able to connect, but the remote session just sits there for a loooong time … almost like there’s a laggy connection.
Do you have any suggestions?
The eventual goal is to have this run headless and stream results of image classification from a webcam.
Thank you.
Other notes: I do have a monitor connected. I’m able to log in via the attached monitor and keyboard and mouse … things are otherwise working, I suppose.
I have hdmi, mouse and keyboard, use “Activities” search for remote, one result will be settings, and you will get to the Screen Sharing “active” set things up here.
it is dependent on the network,
I then first used linux Remmina and it connected and worked great.
The on a microsoft box I use Realvnc viewer and got into the can’t connect stuff. I found I had to use dconf to set the encription false, and then vnc viewer from microsoft and android would work. the web link give you the command line way of doing a bunch of things to get vino to work.
but even if it’s laggy … I should be able to still log in … which doesn’t seem to be happening here.
My RDP session just … doesn’t get past the login prompt.
I changed the default port in Remote Desktop on Windows (regedit, changed to port 5900).
That didn’t seem to have an effect.
I did add port 5900 to the firewall … ‘sudo ufw allow 5900’ on the TX2 and rebooted the TX2.
