Did you mean you cannot access aurix via minicom + uart? Did you erase the UCB section (where BMHD are located)?
Yes, I can’t acces aurix via minicom + uart.
Also I locked UCB_BMHD1 (or erased, i’m not sure) on PFLASH0, It’s all gray and I’m unable to change anything. But if I remember I was able to flash it after that and everything worked fine (with old image), I used UCB_BMHD0 for Internal start for Flash (that was few mnonths ago),
but maybe now I have problems with this new software because of that:
Are you still able to use Memtool + UART to connect to the chip?
No.
If it’s not able to connect, please contact your nvidia representative for following process for this issue on your system. Thanks!
