Hello, I need to download the 4.6 version of the SDK manager program for Jetson Nano, but I get an error while authorization: not allowed.
You can also download it here:
JetPack 4.6 comes with L4T 32.6.1.
Ok but I’m having trouble logging in.
I do not get any errors in the current SDK version, but I want to use the 4.6 version SDK manager for Jetson Nano.
I mean if SDK Manager does not work for you, then you can also download the L4T BSP and flash manually with the flashing script.
ok i will try
This document is confusing, can you help me with a more understandable guide?
I think it’s clear:
https://docs.nvidia.com/jetson/archives/l4t-archived/l4t-3261/index.html#page/Tegra%20Linux%20Driver%20Package%20Development%20Guide/quick_start.html#
OK, I just noticed that you are also the one who posted this:
Aren’t they the same?
Now I guess I couldn’t explain my problem to you. I bought my Jetson nano device from waveshare. I contacted them and they said the SD card slot might be defective. Now this is not important, I have a device that will convert SD card to USB, I want to install it and start my Jetson Nano from it. But then I decided to go back to Jetpack 4.6 because I couldn’t find the container version, but now it gives SDK manager authentication error. Am I missing something or do you not understand?
So you used 4.6.4 and now want to switch to 4.6?
Then I believe steps should be the same.
I want to ask you something
https://courses.nvidia.com/courses/course-v1:DLI+S-RX-02+V2/course/
Can you find me the 4.6.4 version of the Docker container used in this tutorial? I couldn’t find it, so I want to go back to 4.6.
If there is a docker container according to 4.6.4 there is no need to return
I think we haven’t updated it, so please use 4.6.
I was finally able to explain what I wanted to say
But the document you gave me is confusing, I don’t know where to start right now.
I don’t know what you are talking about.
What part of the document you cannot understand?
Didn’t you do the same thing with 4.6.4? Then you just replicate the process on 4.6.
For 4.6.4, I used the program called SDK manager. But for 4.6, the program gives an authorization error and I cannot do it from the program.
You should refer to this section: To flash Jetson Developer Kit operating software.
Then for the board config, you should use jetson-nano-devkit-emmc
Any other thing you feel unclear?
I’m going to download 4.6, but I can’t find where to download it or a section to download.
I don’t feel like you should take all these Jetson stuff if you don’t even know how to download the BSP.
https://developer.nvidia.com/embedded/l4t/r32_release_v6.1/t210/jetson-210_linux_r32.6.1_aarch64.tbz2
https://developer.nvidia.com/embedded/l4t/r32_release_v6.1/t210/tegra_linux_sample-root-filesystem_r32.6.1_aarch64.tbz2
Is it really that hard?
I am a normal user, so you had to make the SDK manager program accessible according to 4.6. Not everyone is professional like you
