Auto-Login when booting into CLI (command line) mode
Is it possible to configure the Jetson automatically login when it’s set to boot into CLI mode?
Auto-login works perfect when booting into GUI mode.
I would like to run my system headless, therefore there is no need for me to launch the Desktop (gdm3.service).
I managed to configure boot to CLI following this post and using this command:
sudo systemctl set-default multi-user.target
However the system prompts for a username an password right after booting.
I tried following this post but could not find the /etc/systemd/system/serial-getty@ttyS0.service.d/autologin.conf file on the Jetson Xavier NX.
What would be the right configuration to auto-login into a CLI session on the Jetson Xavier NX?
Hi yurikleb,
You can edit “/etc/gdm3/custom.conf” to enable auto login.
AutomaticLoginEnable=true
AutomaticLogin=[your username]
Hey @carolyuu
I already have those settings enabled in my “ /etc/gdm3/custom.conf ” file.
With one small difference:
AutomaticLogin=[my username]
And auto-login work well when booting into GIU mode.
However when I disable boot to GIU via sudo systemctl set-default multi-user.target and the system boots into CLI, it still asks for a username and password.
The CLI does not support auto login. Similar question was asked by other users too.
Only the GUI supports the auto login.
Sorry for my typo.
