Blender with the new workstation system
Isaac Sim Version
4.5.0
Operating System
Windows 11
Topic Description
With the omniverse launcher there was an option to download blender for omniverse. and that is the software i used for safely converting .blend files into .usd files.
Now, the omniverse launcher is not available any longer and I installed isaac sim with the new workstation system: Workstation Installation — Isaac Sim Documentation
if I use now the normal blender (none omniverse): Download — Blender
and select export as .usdz, then the conversion faulty:
results in:
I am not sure but I believe I found the new blender for omniverse plugin here: GitHub - NVIDIA-Omniverse/blender_omniverse_addons: Add-ons for Blender for working with NVIDIA Omniverse · GitHub
However i’m really not sure how to add teh plugin to my installation of blender. I mean, I downloaded blender, I also downlaoded the blender_omniverse_addons repo, now, how do i add the add on to blender so that I will have this menu:
and be able to convert .blend files to .usd?
Thank you
While I’m checking this with our team, please provide the log file generated by Isaac Sim when you attempt to import the USD file.
I confirmed that you just need to use the standard Blender now, so please share the log file, the .usdz file, and the command line used for our reproduction.
hi @VickNV thank you for looking into this.
How can I generate a .usdz file? the only option in blender is .usd.
also, is there a specific way to import the .usd file into omniverse? I simply open the file from the Content window. There are no errors whats so ever when I open the file (so there shouldnt be anything interesting in the logs). Blender simply doesnt export the material correctly. This was never an issue with the omniverse addon. I’m wondering why the omniverse add on was removed by omniverse…it is a needed tool, blender on its own does not export .usd files properly in alot of cases.
@danielle.sisserman a few notes i’d like to just chime in on:
i think you had meant to type .usd, so the mod was just trying to ask for the file with the file type you had mentioned. but to export out as .usdz, you just need to type out that format during Blender export.
now, regarding the faulty export - by looking at what you are trying to export, it looks like you have particles/hair on the plane mesh which might be what you are trying to get out of Blender, did you try to enable hair option during export?
the bigger concern of yours was the development of Blender addon - i think the connectors were always meant to be a temporary bridge before more software decides to implement OpenUSD. some are certainly slower than others on the up take, but as an user, it’s hard to see NVIDIA keeping up with every DCCs from dev to release version. so perhaps the end game has always been to push other software to support USD natively in each program. the trick here, however, is that each program might implement differently, and perhaps it’s just a matter of time before there is little to no discrepancies with export/import. but this is just my 2c 😊
@Simplychenable thank you for trying to help. you are right, the grass itself is part of the material. As of now, since the omniverse addon was removed, there is no way to correctly export this type of material into omniverse. after enabling hair in the export settings:
@Simplychenable I was able to install the dipreciated launcher and the blender app from the exchange tab:
after using it to export i can confirm that the export was successful:
It is way too soon to remove this much needed tool I hope the omniverse team will revert on some of it’s decisions with the new version/system
@danielle.sisserman nice! i have uninstalled my launcher from a while ago. i wonder if there’s a way to retain the plugin after launcher’s deprecated in october. perhaps try to locate the source code before it’s completely gone!
There are so many issues with the 4.5.0 version and no so much help here (maybe the version should not be marked stable?) I simply downloaded isaac sim 4.2.0 and am utilizing both versions. Hopefully the Omniverse team will be able to provide some answers soon
Sorry this wasn’t answered properly the first time – “just use standard Blender” is not correct for particle systems and geometry-node-based materials like the grass you showed. Standard Blender’s USD exporter doesn’t handle those the same way the Omniverse-flavored Blender did.
Here is the current migration path now that the Launcher is gone.
Option 1: Blender 4.2 Alpha USD Branch (recommended)
NVIDIA publishes an experimental Blender 4.2 build on NGC that includes the Omniverse connectors and add-ons bundled – this is the direct replacement for the Blender that was previously distributed through the Launcher Exchange tab:
Blender Alpha USD Branch with Omniverse Connector and Add-ons – NVIDIA NGC
This build includes the Omni Panel (particle/material conversions), MDL material support, Nucleus connector, Audio2Face panel, and Scene Optimizer – the same toolset you had before. It is also listed on the official NVIDIA Omniverse Legacy Tools page under “Blender 4.2 Alpha USD Branch.”
Option 2: Install the Omni Panel add-on into your existing Blender
If you want to keep using a standard Blender install, the Omni Panel source code is publicly available on GitHub:
To install it:
  1. Download the repository as a ZIP (Code > Download ZIP)
  2. In Blender: Edit > Preferences > Add-ons > Install…
  3. Select the ZIP file and enable the add-on
This gives you the particle conversion and material utilities panel, though for full MDL and USD export fidelity Option 1 is the more complete solution.
The workaround you found (reinstalling the deprecated Launcher) worked at the time, but the Launcher was officially retired on October 1, 2025, so Option 1 or 2 above are the supported paths going forward.
Closing this out – hope that helps clarify the migration path.
