Bluetooth Mouse Connects Does Not WOrk
I have an Jetson AGX Orin Developer kit and I simply hope to utilize my Logitech MX Master 3S mouse. I can connect to the device and I can see the battery percentage without any issues. However, this is all nothing else works. I have attempted this with several other mice with the same results.
I am attempting to connect directly with bluetooth and not through an universal adapter because I currently do not have one. So far I have attempted to see if following the advice for connecting bluetooth audio did the trick but alas it did not (https://developer.nvidia.com/embedded/learn/tutorials/connecting-bluetooth-audio)
Do you use AGX Orin developer kit? And please use latest Jetpack 5.1.3 or 5.1.2.
Yes, this is a 32gb Jetson AGX Orin Development Kit. I currently have the following jetpack loaded:
Package: nvidia-jetpack
Version: 6.0-b52
Priority: standard
Section: metapackages
Maintainer: NVIDIA Corporation
Installed-Size: 199 kB
Depends: nvidia-jetpack-runtime (= 6.0-b52), nvidia-jetpack-dev (= 6.0-b52)
Homepage: http://developer.nvidia.com/jetson
Download-Size: 29.3 kB
APT-Manual-Installed: yes
APT-Sources: https://repo.download.nvidia.com/jetson/common r36.2/main arm64 Packages
Description: NVIDIA Jetpack Meta Package
I will switch over to 5.1.3 and get back to you
From searching it does not appear to be the case, is there a way to downgrade to 5.1.3 without reflashing with sdk manager? I would assume not since it is ubuntu 20 based?
You are using 6.0 developer preview. We would suggest use production release such as 5.1.3 or 5.1.2. Please re-flash the system through SDKManager.
I am now dealing with a new issue trying to downgrade to 5.1.3 or 5.1.2
13:12:36 ERROR: Flash Jetson Linux - flash: [ 0.1783 ] ERROR: /misc/tsc_controls/tsc_locking_config is not supported
13:12:36 INFO: Flash Jetson Linux - flash: [ 0.1886 ] Assuming zero filled SBK key
13:12:36 INFO: Flash Jetson Linux - flash: [ 0.1915 ] adding BCH for mb1_bct_MB1_aligned.bct
13:12:36 INFO: Flash Jetson Linux - flash: [ 0.1975 ] Assuming zero filled SBK key
13:12:36 INFO: Flash Jetson Linux - flash: [ 0.2005 ] tegrarcm_v2 --new_session --chip 0x23 0 --uid --download bct_br br_bct_BR.bct --download mb1 mb1_t234_prod_aligned_sigheader.bin.encrypt --download psc_bl1 psc_bl1_t234_prod_aligned_sigheader.bin.encrypt --download bct_mb1 mb1_bct_MB1_sigheader.bct.encrypt
13:12:36 INFO: Flash Jetson Linux - flash: [ 0.2028 ] Sending mb1
13:12:36 INFO: Flash Jetson Linux - flash: [ 0.2035 ] Sending psc_bl1
13:12:36 INFO: Flash Jetson Linux - flash: [ 0.2150 ] Sending bct_mb1
13:12:36 INFO: Flash Jetson Linux - flash: [ 0.2253 ] adding BCH for applet_t234_aligned.bin
13:12:36 INFO: Flash Jetson Linux - flash: [ 0.2382 ] Assuming zero filled SBK key
13:12:37 INFO: Flash Jetson Linux - flash: [ 0.2379 ] tegrarcm_v2 --chip 0x23 0 --pollbl --download applet applet_t234_sigheader.bin.encrypt
13:12:37 INFO: Flash Jetson Linux - flash: [ 0.4264 ] Sending applet
13:12:37 ERROR: Flash Jetson Linux - flash: [ 0.4266 ] ERROR: might be timeout in USB write.
13:12:37 ERROR: Flash Jetson Linux - flash: command terminated with error
13:12:37 SUMMARY: Flash Jetson Linux - flash: First Error: Installation failed.
I am attempting to utilize WSL ubuntu 20.04 to run sdkmanager. I am able to see and connect to the board, however, when flashing the board I receive the USB error. I have seen this error on several other threads but nothing posted there has worked for me. Specifically downgrading from 6.0 to 5.1.3
I just saw the FAQ posted here: Jetson Orin devkit 64GB Flash Jetpack DP_6.0 Failed - ERROR: might be timeout in USB write trying this now
Switching from wsl utilizing ubuntu 20.04 to ubuntu 18.04
