We have several Drive Xavier platforms that came with Ubuntu Linux SDK pre-installed and they all work fine out of the box.
We tried to flash two of them with Nvidia QNX SDK and it worked fine.
Now we are trying to flash Linux SDK again and the system does not boot.
I downloaded Nvidia Linux SDK 5.0.10.3 for Drive AGX platform through SDK Manager.
I tried flashing the boards from SDK Manager (last step of the SDK installation) and also manually using command
./pdk_flash.sh -b e3550b01-t194a2b-es -o linux
or
./pdk_flash.sh -b e3550b01-t194a-es -o linux
./pdk_flash.sh -b e3550b01-t194b-es -o linux
The board does not boot. Both Tegra A and B show errors during boot in corresponding terminals.
Then I tried flashing with "linux_minimal" option. Not sure how "linux_minimal" is different from "linux"
./pdk_flash.sh -b e3550b01-t194a-es -o linux_minimal
./pdk_flash.sh -b e3550b01-t194b-es -o linux_minimal
After that, Tegra A can boot Ubuntu, but constantly prints "!!ComErr!!" message to the terminal.
Tegra B fails to boot.
Any ideas how to fix that problem?
I tried flashing two different boards multiple times.
Tegra B boot log:
[code]
\00ÿâ
[0000.024] I> MISCREG_HIDREV_0: 0x21917
[0000.028] I> MB1 (prd-version: 00.22.180704-t194-39702425-7fcf5198)
[0000.034] I> Boot-mode: L0 coldboot
[0000.037] I> chip revision : A02
[0000.040] I> Bootrom patch version : 3 (correctly patched)
[0000.045] I> ATE fuse revision : 0x200
[0000.049] I> Ram repair fuse : 0x0
[0000.052] I> rst_source : 0x0
[0000.054] I> rst_level : 0x0
[0000.057] E> Last boot error: 0x00000000
[0000.061] I> Soft fuse initialized
[0000.064] I> Boot WARS Applied
[0000.067] I> Boot-device: QSPI
[0000.070] I> qspi flash params source = brbct
[0000.074] I> Qspi using bpmp-dma
[0000.077] I> Qspi clock source : pllp
[0000.080] I> QSPI Flash: Spansion 64MB
[0000.084] I> QSPI Flash Size = 64 MB
[0000.089] I> QSPI Flash: Set 512B page size
[0000.093] I> Qspi initialized successfully
[0000.097] I> Loading MB1-BCT to SysRAM
[0000.100] I> Boot-device: QSPI
[0000.103] I> Binary@ device:3/0 block-1536 (partition size: 0x20000)
[0000.109] I> qspi flash params source = brbct
[0000.114] I> Binary mb1bct loaded successfully at 0x40000000
[0000.120] I> MB1-BCT relocated to 0xd48bc00 from 0x40000000
[0000.125] I> Loading MEM-BCT to SysRAM
[0000.128] I> Binary@ device:3/0 block-2048 (partition size: 0x40000)
[0000.134] I> qspi flash params source = mb1bct
[0000.138] I> Qspi using bpmp-dma
[0000.141] I> Qspi clock source : pllp
[0000.145] I> Qspi reinitialized
[0000.149] I> Binary membct loaded successfully at 0x40000000
[0000.155] I> SDRAM params relocated to 0xd493400 from 0x40000000
[0000.160] I> SDRAM pack relocated to 0xd495c00 from 0x40000000
[0000.166] E> No fuse-bypass data
[0000.171] I> temperature = 31500
[0000.174] W> Skipping boost for clk:aon_cpu_nic
[0000.178] W> Skipping boost for clk:aon_can0
[0000.182] W> Skipping boost for clk:aon_can1
[0000.186] E> MB1_PLATFORM_CONFIG: prod table is empty in MB1 BCT.
[0000.192] I> Boot-device: QSPI
[0000.195] I> Boot-device: QSPI
[0000.198] I> qspi flash params source = mb1bct
[0000.202] I> Binary@ device:3/0 block-2560 (partition size: 0x40000)
[0000.208] I> qspi flash params source = mb1bct
[0000.214] I> Binary spe-fw loaded successfully at 0x40000000
[0000.221] I> ECC region[0]: Start:0x0, End:0x0
[0000.226] I> ECC region[1]: Start:0x0, End:0x0
[0000.230] I> ECC region[2]: Start:0x0, End:0x0
[0000.234] I> ECC region[3]: Start:0x0, End:0x0
[0000.238] I> ECC region[4]: Start:0x0, End:0x0
[0000.242] I> ECC region[5]: Start:0x0, End:0x0
[0000.246] I> Non-ECC region[0]: Start:0x80000000, End:0x100000000
[0000.252] I> Non-ECC region[1]: Start:0x0, End:0x0
[0000.256] I> Non-ECC region[2]: Start:0x0, End:0x0
[0000.261] I> Non-ECC region[3]: Start:0x0, End:0x0
[0000.265] I> Non-ECC region[4]: Start:0x0, End:0x0
[0000.269] I> Non-ECC region[5]: Start:0x0, End:0x0
[0000.274] I> Added Block:1 Start:0x80000000 End:0x100000000
[0000.280] I> allocated(CO:32) base:0xf8000000 size:0x8000000 align: 0x8000000
[0000.287] I> allocated(CO:33) base:0xf0000000 size:0x8000000 align: 0x100000
[0000.294] I> allocated(CO:38) base:0x80000000 size:0x8000000 align: 0x200000
[0000.301] I> allocated(CO:39) base:0x88000000 size:0x8000000 align: 0x8000000
[0000.307] I> allocated(CO:36) base:0x95a00000 size:0x4000000 align: 0x200000
[0000.314] I> allocated(CO:24) base:0xee000000 size:0x2000000 align: 0x2000000
[0000.321] I> allocated(CO:28) base:0xecc00000 size:0x1400000 align: 0x200000
[0000.327] I> allocated(CO:34) base:0xebc00000 size:0x1000000 align: 0x0
[0000.334] I> allocated(CO:35) base:0x90000000 size:0x1000000 align: 0x1000000
[0000.340] I> allocated(CO:7) base:0xeb000000 size:0x800000 align: 0x800000
[0000.347] I> allocated(CO:10) base:0xea800000 size:0x800000 align: 0x800000
[0000.353] I> allocated(CO:37) base:0xea000000 size:0x800000 align: 0x800000
[0000.360] I> allocated(CO:19) base:0xe9a00000 size:0x600000 align: 0x200000
[0000.366] I> allocated(CO:6) base:0xeb800000 size:0x400000 align: 0x200000
[0000.373] I> allocated(CO:27) base:0xe9600000 size:0x400000 align: 0x200000
[0000.380] I> allocated(CO:29) base:0xe9200000 size:0x400000 align: 0x200000
[0000.386] I> allocated(CO:1) base:0xe9100000 size:0x100000 align: 0x100000
[0000.393] I> allocated(CO:2) base:0xe9000000 size:0x100000 align: 0x100000
[0000.399] I> allocated(CO:3) base:0xe8f00000 size:0x100000 align: 0x100000
[0000.406] I> allocated(CO:4) base:0xe8e00000 size:0x100000 align: 0x100000
[0000.412] I> allocated(CO:5) base:0xe8d00000 size:0x100000 align: 0x100000
[0000.419] I> allocated(CO:8) base:0xe8c00000 size:0x100000 align: 0x100000
[0000.425] I> allocated(CO:9) base:0xe8b00000 size:0x100000 align: 0x100000
[0000.431] I> allocated(CO:12) base:0xe8a00000 size:0x100000 align: 0x100000
[0000.438] I> allocated(CO:17) base:0xe8900000 size:0x100000 align: 0x100000
[0000.445] I> allocated(CO:21) base:0xe88f0000 size:0x10000 align: 0x0
[0000.451] > MB1_PLATFORM_CONFIG: Rail ID 9 not found in pmic rail config table.
[0000.458] E> FAILED: Thermal config
[0000.465] > MB1_PLATFORM_CONFIG: Rail ID 7 not found in pmic rail config table.
[0000.472] E> FAILED: MEMIO rail config
[0000.475] I> MSS code-drop: NvBootSdramInit
[0000.492] I> scrub mode: full dram
[0000.495] E> Error: ECID of check failed!!
[0000.499] E> MB1 BCT does not have SCR table
[0000.503] I> Binary@ device:3/0 block-4608 (partition size: 0x40000)
[0000.509] I> qspi flash params source = mb1bct
[0000.523] I> RSA PSS signature check: OK
[0000.527] I> Binary preboot loaded successfully at 0x40000040
[0000.534] I> Restrict GSC#31 access to DPMU only
[0000.538] I> WP-0 triggered
[0000.540] I> WP-0 ACK received :)
[0000.544] I> CPU reset vector: 0x40000000
[0000.547] I> MTS carveout BOM: 0xff000000
[0000.551] I> MC_MTS_CARVEOUT_SIZE_MB_0: 0x10
[0000.555] I> Loading MCE
[0000.557] I> Binary@ device:3/0 block-5120 (partition size: 0x80000)
[0000.563] I> qspi flash params source = mb1bct
[0000.578] I> RSA PSS signature check: OK
[0000.585] I> Binary MCE loaded successfully at 0xbf080000
[0000.594] I> Loading MTS
[0000.596] I> Binary@ device:3/0 block-6144 (partition size: 0x400000)
[0000.602] I> qspi flash params source = mb1bct
[0000.661] I> Binary MTS loaded successfully at 0xbfa00000
[0000.678] I> WP-1 triggered
[0000.683] I> WP-1 ACK received :)
[0000.686] I> MTS carveout BOM: 0xf8000000
[0000.690] I> WP1.5 triggered
[0000.693] I> WP1.5 ACK received :)
[0000.696] E> MB1_PLATFORM_CONFIG: Bootrom mmio i2c table is empty in MB1 BCT.
[0000.703] I> Loading MB2
[0000.705] I> Binary@ device:3/0 block-3072 (partition size: 0x40000)
[0000.711] I> qspi flash params source = mb1bct
[0000.718] I> Binary mb2 loaded successfully at 0x52000000
[0000.723] I> co:0 offset:0x70000000
[0000.726] I> MB2-params @ 0x70000000
[0000.730] I> co:4 offset:0x70010000
[0000.733] I> co:1 offset:0x70020000
[0000.737] I> CO:(35) safe offset:0x53000000
[0000.741] I> CO:(37) safe offset:0x70030000
[0000.745] > MB1_PLATFORM_CONFIG: Rail ID 8 not found in pmic rail config table.
[0000.752] I> MB1 done
\00ÿýÿàmain enter
SPE VERSION #: R01.00.07 Created: Mar 21 2018 @ 15:14:19
HW Function test
Start Scheduler.
in late init
ÿâ
I> Welcome to MB2(TBoot-BPMP)
I> mb2 Safe end :0x52700000 mb2 safe start :0x52032044
I> co:0 offset:0x52700000
I> DMA Heap @ [0x52700000 - 0x53000000]
I> Default Heap @ [0xd486400 - 0xd488400]
I> qspi flash-0 params source = boot args
I> bit @ 0xd480000
I> Found 20 partitions in 00030000 device
I> co:8 offset:0x70030000
I> GR Blob not found or corrupted. Skipping GR Dump for MB1 Stage
I> Binary@ device:3/0 block-20480 (partition size: 0x100000)
I> header load address is : 0x5202fdf0
I> header of binary bpmp-fw read from storage device 3(0)
I> oem authentication of bpmp-fw header done
I> component list is filled with contents from header
I> parsing oem signed section of bpmp-fw header done
I> updated handle with bpmp-fw info. from oem comp table
I> bpmp-fw binary read from storage
I> Binary@ device:3/0 block-22528 (partition size: 0x100000)
I> header of binary bpmp-fw-dtb read from storage device 3(0)
I> oem authentication of bpmp-fw-dtb header done
I> parsing oem signed section of bpmp-fw-dtb header done
I> updated handle with bpmp-fw-dtb info. from oem comp table
I> bpmp-fw-dtb binary read from storage
I> BPMP-FW load address = 0x50000000
I> BPMP-FW DTB load address = 0x503e43a0
I> Loading SCE-FW ...
I> Binary@ device:3/0 block-24576 (partition size: 0x80000)
I> header of binary sce read from storage device 3(0)
I> oem authentication of sce header done
I> parsing oem signed section of sce header done
I> updated handle with sce info. from oem comp table
I> sce binary read from storage
I> Loading RCE-FW ...
I> Binary@ device:3/0 block-25600 (partition size: 0x80000)
I> header of binary rce read from storage device 3(0)
I> oem authentication of rce header done
I> parsing oem signed section of rce header done
I> updated handle with rce info. from oem comp table
I> rce binary read from storage
I> Unpowergating APE
I> Unpowergate done
I> Loading APE-FW ...
I> Binary@ device:3/0 block-26624 (partition size: 0x200000)
I> header of binary ape read from storage device 3(0)
I> oem authentication of ape header done
I> parsing oem signed section of ape header done
I> updated handle with ape info. from oem comp table
I> ape binary read from storage
I> Copy BTCM section
I> Binary@ device:3/0 block-14336 (partition size: 0x80000)
I> header of binary cpubl read from storage device 3(0)
I> oem authentication of cpubl header done
I> parsing oem signed section of cpubl header done
I> updated handle with cpubl info. from oem comp table
I> cpubl binary read from storage
I> co:4 offset:0x70040000
I> CPUBL-params @ 0x70040000
I> co:5 offset:0x70050000
I> Relocating BR-BCT
I> co:6 offset:0x70060000
I> BRBCT @ 0x40066c00
I> BR-BCT relocated to 0x70060000
I> CPU-BL loaded at : 0x96000000
I> Loading TOS ...
I> Binary@ device:3/0 block-15360 (partition size: 0x280000)
I> header of binary tos read from storage device 3(0)
I> oem authentication of tos header done
I> parsing oem signed section of tos header done
I> updated handle with tos info. from oem comp table
I> tos binary read from storage
I> TOS params:@0x52d02410
I> TLK boot-params @ 0x52d02410
I> TLK params prepared
I> Loading EKS ...
I> Binary@ device:3/0 block-30720 (partition size: 0x40000)
I> header of binary eks read from storage device 3(0)
I> oem authentication of eks header done
I> parsing oem signed section of eks header done
I> updated handle with eks info. from oem comp table
I> eks binary read from storage
I> EKS (length: 0x5000) @ 0x52d07800
I> Copied encrypted keys
I> Copying Monitor (length: 0x17170) from 0x52702600 to 0x40000000
I> Erasing Monitor @ 0x52702600
I> tos-params: tzdram_size: 0x1000000
I> tos-params: tzdram_base: 0xebc00000
I> tos-params: uart_port_id: 254
I> Copying TOS (length: 0x13e1d0) from 0x52719770 to 0xabc40000
I> Waypoint2-ACK: 0x52014d64
I> SCR config list empty
I> Unhalting RCE
I> GR Blob not found or corrupted. Skipping GR Dump for MB2 Stage
ÿäNOTICE: BL31: v1.3(release):934cbe7
NOTICE: BL31: Built : 10:49:22, Sep 4 2018
ÿâ
welcome to lk
ÿäÿâbpmp: platform_init
dt initialized
mail initialized
chipid initialized
fuse initialized
sku initialized
speedo initialized
ec initialized
vmon_populate_monitors: found 1 monitors
vmon initialized
vmon_soc_self_check: vmon_vsoc: self-check passed
adc initialized
fmon_populate_monitors: found 73 monitors
vrefro_re_cal: VrefRO: adjusted 0x82=>0x86
fmon_soc_ops_init: re-start disabled FMON_OSCnFUSE_CK
fmon_soc_ops_init: re-start disabled FMON_PMC_CK
fmon initialized
reset initialized
nvhs initialized
warning: pllp_vic do not permit 'allow_fractional_divider' property
warning: pllp_vic do not permit 'allowed-parents' property
warning: mphy_core_pll_fixed do not permit 'allowed-parents' property
warning: ufsdev_ref do not permit 'allowed-parents' property
warning: slvsec do not permit 'allowed-parents' property
warning: pllp_aon do not permit 'allow_fractional_divider' property
warning: pllp_aon do not permit 'allowed-parents' property
warning: mphy_tx_1mhz_ref do not permit 'allowed-parents' property
warning: sdmmc4 do not permit 'allow_fractional_divider' property
warning: eqos_tx do not permit 'allowed-parents' property
386 clocks registered
clk_mrq_init: mrq handler registered
clk initialized
io_dpd initialized
thermal initialized
ti2c_dt_parse: error fetching tlow
ti2c_dt_parse: error fetching thigh
i2c5 controller initialized
initialized i2c mrq handling
i2c initialized
WARNING: at platform/drivers/regulator/regulator-dt.c:126
regulator_parse_dt: regulator-ramp-delay is deprecated. Use regulator-ramp-delay-linear instead.
regulator initialized
avfs_clk_platform initialized
soctherm initialized
aotag initialized
powergate initialized
dvs initialized
pm initialized
pg_late initialized
strap initialized
tag initialized
emc initialized
WARNING: at platform/drivers/vfmon/fmon.c:456
invalid clock 307 rate 0
invalid clock 113 rate 0
fmon_enable: FMON_NVLINK_SYS: s/w DC fault is detected
invalid clock 118 rate 0
warning: i2c2 do not permit parent clk_m
warning: i2c8 do not permit parent clk_m
clk_update_possible_parents: clk_m not in allowed parent table for sdmmc4
warning: sor0_out do not permit parent pll_d
warning: sor0_out do not permit parent pll_dp
clk_update_possible_parents: sor_safe not in allowed parent table for sor0_out
warning: sor1_out do not permit parent pll_d2
warning: sor1_out do not permit parent pll_dp
clk_update_possible_parents: sor_safe not in allowed parent table for sor1_out
warning: sor2_out do not permit parent pll_d3
warning: sor2_out do not permit parent pll_dp
clk_update_possible_parents: sor_safe not in allowed parent table for sor2_out
warning: sor3_out do not permit parent pll_d4
warning: sor3_out do not permit parent pll_dp
clk_update_possible_parents: sor_safe not in allowed parent table for sor3_out
clk_dt initialized
avfs_ccplex_platform initialized
pm_post initialized
tj_max: dt node not found
tj_init initialized
uphy_mrq_init: mrq handler registered
uphy_dt initialized
uphy initialized
mrq initialized
clk_dt_late initialized
carveout 6: size check failed (0x20)
AST0 misconfig for DRAM: slave 0x050000001 master 0x0eb800000 mask 0x3ff000 control 0x80001
AST1 misconfig for DRAM: slave 0x050000001 master 0x0eb800000 mask 0x3ff000 control 0x80001
machine_check initialized
fmon_post initialized
tag is fce7e7e850bd06c123a330c57f701fca
tag_lateinit initialized
avfs_clk_platform_post initialized
dmce initialized
cvc initialized
ÿãCombined UART initialized
Starting OS
ÿâavfs_clk_mach_post initialized
ÿãInitialization done!
ÿâgboost_init initialized
aotag_hsm initialized
regulator_post initialized
rm initialized
sc7_diag initialized
thermal_test initialized
serial_late initialized
clk_post initialized
clk_dt_post initialized
wake initialized
sku_debugfs initialized
speedo_debugfs initialized
adc_debugfs initialized
clk_debugfs initialized
emc_debugfs initialized
ÿáqb:[E]: Partition not found ramdisk
qb:[E]: Error PartitionNotExist (0x30018)
ÿâdvs_debugfs initialized
ÿáqb:[E]: Partition not found kernel-dtb
ÿâfmon_debugfs initialized
vmon_debugfs initialized
pg_debugfs initialized
profile_fs initialized
debugfs_cons initialized
mail_fs initialized
profile initialized
cvc_debugfs initialized
dmce_debugfs initialized
ec_debugfs initialized
soctherm_debug initialized
debugfs_mrq initialized
ÿáÿÿýÿÿþÿâstarting app shell
entering main console loop
] ÿáDRIVE Hypervisor
ÿÿNvGpcDmaLibInitÿÿ
iÿÿ:ÿÿ
vÿÿHÿÿ
cÿÿyÿÿ
_ÿÿpÿÿ
qÿÿeÿÿ
uÿÿrÿÿ
eÿÿvÿÿ
uÿÿiÿÿ
eÿÿsÿÿ
ÿÿoÿÿ
nÿÿrÿÿ
oÿÿ ÿÿ
dÿÿMÿÿ
eÿÿoÿÿ
ÿÿdÿÿ
nÿÿeÿÿ
oÿÿ
ÿÿ
tÿÿ
ÿÿ
present
ivc_queue node not present
ivc_queue node not pÿÿ sÿÿ
rÿÿ tÿÿ
eÿÿ aÿÿ
sÿÿ rÿÿ
eÿÿ tÿÿ
nÿÿ iÿÿ
tÿÿ nÿÿ
ÿÿ gÿÿ
ÿÿ app i2c_server
starting aÿÿ
sÿÿ pÿÿ
tÿÿ pÿÿ
aÿÿ ÿÿ
rÿÿ bÿÿ
tÿÿ pÿÿ
iÿÿ mÿÿ
nÿÿ pÿÿ
gÿÿ _iÿÿ
ÿÿ nÿÿ
aÿÿ cÿÿ
pÿÿ oÿÿ
p ÿÿ mÿÿ
gÿÿ iÿÿ
dÿÿ nÿÿ
bÿÿ gÿÿ
_ÿÿ
ÿÿ
aÿÿ
ÿÿ
gent
ÿÿvirt/servers/servers/apps/thermal/cooling_devs/cdev_balanced_throttle.c: cpufreq-virt_init failed
Registered governor: pid_thermal_govmax20024: No regulator node found in pmc node
ÿÿ
starting app debug_seÿÿstarting app bpmp_ping
starting app thermal
trip_update_worker: Failed to get current temperature for zone 1
starting app bpmp_server
starting app cpÿÿSÿÿufÿÿtÿÿreÿÿaÿÿq_ÿÿrÿÿhvÿÿtÿÿ
ÿÿing TrustZoneÿÿstarting app bpmp_incoming
trip_update_worker: Failed to get current temperature for zone 7
ÿÿ
rver
D-S> ÿÿ Sever...
ÿÿevent logginÿÿRÿÿgÿÿeÿÿ nÿÿsÿÿotÿÿeÿÿ ÿÿrÿÿavÿÿvÿÿaiÿÿeÿÿlaÿÿdÿÿbÿÿ ÿÿleÿÿIÿÿ
ÿÿVÿÿ
ÿÿC id 526
Reserved IVC iÿÿstÿÿdÿÿaÿÿ ÿÿrtÿÿ5ÿÿinÿÿ2ÿÿgÿÿ7ÿÿ apÿÿ
ÿÿpÿÿ
ÿÿ vÿÿRÿÿscÿÿeÿÿ
ÿÿserved IVC id 528
Reserved IVC id 529
Reserved IVC id 530
Resÿÿsÿÿeÿÿtaÿÿrÿÿrtÿÿvÿÿinÿÿeÿÿgÿÿdÿÿ aÿÿ ÿÿppÿÿIÿÿ ÿÿVÿÿbpÿÿCÿÿmpÿÿ ÿÿ_ÿÿiÿÿinÿÿdÿÿcoÿÿ ÿÿmiÿÿ5ÿÿngÿÿ3ÿÿ
ÿÿ1
Reserved IVC id 532
Reserved IVC id 533
Reserved IVC id 534
Reserved IVC id 535
Reserved IVC id 536
Reserved IVC id 537
Reserved IVC id 538
Reserved IVC id 539
ÿäplatform_guest_warm_boot: guest warm reboot
ÿástarting app tz_server
ÿÿaMMFLAGS=1
Starting RM server
Start nvpm server
Setting BOARD_SHUTDOWN_DLL to /proc/boot/libnvshutdown.so if not set already
Done...
ÿÿstarting app se_server
ÿÿpl:[Eÿÿþ 2628418|HV/c4: ÿÿÿÿþGAC : GID 0 unhandled access of size 4 for Read operation on trap address 3270000 with err 0!
ÿÿ]:ÿÿpÿÿÿÿþ 2630931|HV/c4: ÿÿÿÿþGAC : GID 0 unhandled access of size 4 for Read operation on trap address 0 with err 0!
ÿÿ ÿÿlÿÿNÿÿ:ÿÿvÿÿ[ÿÿGÿÿEÿÿuÿÿ]:ÿÿeÿÿ ÿÿsÿÿNvÿÿtÿÿGÿÿFÿÿuÿÿiÿÿeÿÿnÿÿsÿÿdÿÿtÿÿBÿÿFÿÿoÿÿiÿÿoÿÿnÿÿtÿÿdÿÿDÿÿBÿÿeÿÿoÿÿvÿÿoÿÿiÿÿtÿÿcÿÿDÿÿeÿÿpÿÿÿäplatform_guest_warm_boot: guest warm reboot
ÿáÿäplatform_guest_warm_boot: guest warm reboot
ÿáeÿÿIÿÿlÿÿvÿÿnÿÿ:ÿÿiÿÿfÿÿ[ÿÿ\00
ÿÿcÿÿ\00GID 0:ÿÿoÿÿ\00 UnÿÿEÿÿ\00hanÿÿeÿÿ\00dled acÿÿ:ÿÿ\00cesÿÿ]ÿÿ\00s oÿÿIÿÿ\00f sizeÿÿ1ÿÿ\00 4 foÿÿ:ÿÿ\00r read.ÿÿnÿÿ\00
Acceÿÿ5ÿÿ\00ss sÿÿ ÿÿfÿÿ\00izeÿÿ9ÿÿ\00: 0x4
Fault ÿÿNÿÿ\00Iÿÿoÿÿ\00PA: 0ÿÿ ÿÿ\00x32700ÿÿvÿÿ\0000ÿÿ:ÿÿ\00
ESR_EL2ÿÿNÿÿ\00: 0x9382ÿÿGÿÿ\000ÿÿ1ÿÿ\00007
ÿÿoÿÿ\00Fatal VMÿÿuÿÿ\00 ÿÿ5ÿÿ\00Fault: ÿÿ ÿÿ\00Faileÿÿeÿÿ\00d ÿÿ9ÿÿ\00to haÿÿBÿÿ\00ndlÿÿsÿÿ\00e dÿÿ ÿÿ\00ata aÿÿoÿÿ\00borÿÿtÿÿ\00t!
ÿÿNÿÿ\00
VM Stÿÿoÿÿ\00atÿÿFÿÿ\00e:
Vÿÿoÿÿ\00CPU ID: 0xÿÿtÿÿiÿÿ\000
PC:ÿÿ ÿÿ\00 0x21009750ÿÿ ÿÿ\00
ÿÿnÿÿ\00
SPSR_ELÿÿBÿÿ\002: 0x800003cÿÿDÿÿdÿÿ\005
FAR_ELÿÿoÿÿ\002: 0x327ÿÿeÿÿBÿÿ\000000
Sÿÿoÿÿ\00PSR_EL1: 0xÿÿvÿÿ\000
ÿÿoÿÿ\00
GPRÿÿtÿÿ\00s:
x0: ÿÿiÿÿ\000ÿÿoÿÿ\00x000000ÿÿ ÿÿ\000085a46cÿÿcÿÿ\004ÿÿtÿÿ\000 x1:ÿÿDÿÿ\00 0x0ÿÿDÿÿ\000ÿÿeÿÿ\00000ÿÿeÿÿ\0000085e89cÿÿeÿÿ ÿÿ\0038 xÿÿvÿÿ\002: 0x00000ÿÿfÿÿvÿÿ\0000000ÿÿiÿÿ\00000000
ÿÿiÿÿ\00
xÿÿoÿÿ\003: ÿÿcÿÿÿäplatform_guest_warm_boot: guest warm reboot
ÿá\000x00000ÿÿcÿÿ\0000ÿÿuÿÿ\0000327ÿÿeÿÿ\000000 x4: 0xÿÿeÿÿ\000ÿÿnÿÿ\0000000ÿÿ ÿÿ\000085e89e58 x5ÿÿIÿÿdÿÿ\00: 0x00ÿÿfÿÿ\00000000000ÿÿnÿÿ\000ÿÿ
ÿÿ\000000 ÿÿoÿÿ\00
x6: 0x000ÿÿfÿÿ
ÿÿ\00000ÿÿuÿÿ\000000000001 ÿÿoÿÿ\00x7:ÿÿpÿÿnÿÿ\00 0x0000000ÿÿ:ÿÿ\0000000ÿÿlÿÿdÿÿ\000001 x8: ÿÿ1ÿÿ\000x0ÿÿ
ÿÿ:ÿÿ\00000000000ÿÿ5ÿÿ\000000ÿÿ[ÿÿ\000ÿÿ
ÿÿ\001
x9: 0x00ÿÿ9ÿÿ\000000ÿÿEÿÿ\0000ÿÿpÿÿ\0000000004 x10: 0x0ÿÿ]ÿÿ\000ÿÿlÿÿ\0000000000000022 xÿÿ:ÿÿ\0011:ÿÿ:ÿÿ\00 ÿÿ[ÿÿ\000x0000000085a42698
ÿÿEÿÿ\00
x12: 0x000ÿÿ ÿÿ\00000000000ÿÿ]ÿÿ\000000 x13: 0x0ÿÿQÿÿ\000000ÿÿ:ÿÿ\000ÿÿbÿÿ\000000000018ÿÿ ÿÿ\00 x14: 0x0000ÿÿQÿÿ\000ÿÿDÿÿ\0000000000001ÿÿbÿÿ\00
x15: ÿÿaÿÿ\000x00ÿÿDÿÿ\000ÿÿtÿÿ\0000000000000ÿÿaÿÿ\0000 x16: 0x0000000000000ÿÿtÿÿ\0006ÿÿaÿÿ\000 x17: 0x00000000ÿÿaÿÿ\0000000ÿÿDÿÿ\00080
x18: 0x00000ÿÿDÿÿ\000008ÿÿrÿÿ\005e80000 xÿÿ ÿÿ\0019: 0x0000ÿÿrÿÿ\0000ÿÿiÿÿ\000085a46aaÿÿNÿÿ\000 x20:ÿÿiÿÿ\00 0x00ÿÿvÿÿ\00000000ÿÿoÿÿ\0000000000
ÿÿvÿÿ\00x21ÿÿeÿÿ\00: 0x0000ÿÿ ÿÿ\00000085a46c40ÿÿeÿÿ\00 ÿÿnÿÿ\00x22: 0xÿÿBÿÿ\0000000000ÿÿnÿÿ\0000ÿÿIÿÿ\0000000ÿÿoÿÿ\000 x23: 0x000000ÿÿnÿÿ\00008ÿÿIÿÿ\005a46ÿÿoÿÿ\00ac8
x24: 0x0000ÿÿiÿÿ\000ÿÿnÿÿ\00000ÿÿtÿÿ\00ffffffff x25ÿÿtÿÿiÿÿ\00: ÿÿ ÿÿ\000x0000000085a46ÿÿ(ÿÿ\00c3ÿÿtÿÿ\008ÿÿDÿÿ\00 x26: 0x0000ÿÿ)ÿÿ\000000ÿÿ(ÿÿ\0085ÿÿeÿÿ\00a46ac0
x27: 0x0ÿÿ ÿÿ\0000ÿÿ)ÿÿ\000000ÿÿvÿÿ\00085a46ac8 ÿÿfÿÿ\00x28:ÿÿ ÿÿ\00 0ÿÿiÿÿ\00x000000000000ÿÿaÿÿ\0000ÿÿfÿÿ\0002 xÿÿcÿÿ\0029: 0x000000ÿÿiÿÿ\0000ÿÿaÿÿ\0085e7eÿÿeÿÿ\00db0
x30: 0x00ÿÿlÿÿ\0000ÿÿiÿÿ\00000021ÿÿ ÿÿ\00009dd8
Vÿÿeÿÿ\00M ÿÿlÿÿ\00Stackÿÿfÿÿ\00 Trace:
0x21009ÿÿdÿÿ\00dd8ÿÿeÿÿ\00
ÿÿoÿÿ\000x2100bbÿÿ
ÿÿ\002c
ÿÿdÿÿuÿÿ\000x21002fb0
0xÿÿ
ÿÿ\0021003ÿÿ
ÿÿnÿÿ\00514
0x210ÿÿpÿÿ\000155ÿÿ
ÿÿ\000ÿÿdÿÿ\00
0x21000184
Sÿÿpÿÿ\00iÿÿ
ÿÿ\00dÿÿlÿÿ\00ekick Stack Tracÿÿlÿÿ\00eÿÿ
ÿÿ\00:
0x1766ÿÿ:ÿÿ\000
0x18350
ÿÿ:ÿÿ\000xÿÿpÿÿ\00183e8
0x12ÿÿ[ÿÿ\00070
ÿÿ[ÿÿlÿÿEÿÿEÿÿ:ÿÿ]ÿÿ]ÿÿ[ÿÿ:ÿÿ:ÿÿEÿÿ ÿÿ ÿÿ]ÿÿBÿÿ:ÿÿBÿÿUÿÿ ÿÿUÿÿGÿÿQÿÿGÿÿ ÿÿbÿÿ ÿÿdÿÿDÿÿdÿÿaÿÿaÿÿaÿÿtÿÿtÿÿtÿÿaÿÿaÿÿaÿÿDÿÿ_ÿÿ_ÿÿrÿÿdÿÿdÿÿiÿÿrÿÿrÿÿvÿÿiÿÿiÿÿeÿÿvÿÿvÿÿnÿÿeÿÿeÿÿIÿÿnÿÿnÿÿnÿÿ_ÿÿ_ÿÿiÿÿdÿÿdÿÿtÿÿtÿÿtÿÿ(ÿÿ.ÿÿ.ÿÿ)ÿÿcÿÿcÿÿ ÿÿ:ÿÿ:ÿÿfÿÿ9ÿÿ9ÿÿaÿÿ2ÿÿ2ÿÿiÿÿ2ÿÿ2ÿÿlÿÿ ÿÿ ÿÿeÿÿ(ÿÿ(ÿÿdÿÿQÿÿQÿÿ
ÿÿbÿÿbÿÿ
ÿÿDÿÿDÿÿpÿÿaÿÿaÿÿlÿÿtÿÿtÿÿ:ÿÿaÿÿaÿÿ[ÿÿDÿÿDÿÿEÿÿrÿÿrÿÿ]ÿÿiÿÿiÿÿ:ÿÿvÿÿvÿÿ ÿÿeÿÿeÿÿBÿÿnÿÿnÿÿUÿÿIÿÿIÿÿGÿÿnÿÿnÿÿ ÿÿiÿÿiÿÿdÿÿtÿÿtÿÿaÿÿ)ÿÿ)ÿÿtÿÿ
ÿÿ
ÿÿaÿÿ
ÿÿ
ÿÿ_ÿÿpÿÿpÿÿdÿÿlÿÿlÿÿrÿÿ:ÿÿ:ÿÿiÿÿ[ÿÿ[ÿÿvÿÿEÿÿEÿÿeÿÿ]ÿÿ]ÿÿnÿÿ:ÿÿ:ÿÿ_ÿÿ ÿÿ ÿÿdÿÿSÿÿSÿÿtÿÿtÿÿtÿÿ.ÿÿaÿÿaÿÿcÿÿcÿÿcÿÿ:ÿÿkÿÿkÿÿ9ÿÿ ÿÿ ÿÿ2ÿÿtÿÿtÿÿrÿÿrÿÿaÿÿ2ÿÿaÿÿcÿÿ ÿÿcÿÿeÿÿ(ÿÿeÿÿ:ÿÿQÿÿ:ÿÿ
ÿÿbÿÿ
ÿÿ
ÿÿDÿÿ
ÿÿaÿÿpÿÿpÿÿtÿÿlÿÿlÿÿaÿÿ:ÿÿ:ÿÿDÿÿ[ÿÿ[ÿÿrÿÿEÿÿE]ÿÿ]ÿÿiÿÿ:ÿÿ:ÿÿvÿÿ ÿÿ ÿÿeÿÿ<ÿÿ<ÿÿnÿÿ ÿÿ ÿÿIÿÿPÿÿPÿÿnÿÿCÿÿCÿÿiÿÿ ÿÿ ÿÿtÿÿ:ÿÿ:ÿÿ)ÿÿ2ÿÿ2ÿÿ
ÿÿ1ÿÿ
ÿÿ1ÿÿ0ÿÿ0ÿÿpÿÿ0ÿÿ0ÿÿlÿÿ3ÿÿ3ÿÿ:ÿÿ5ÿÿ5ÿÿ[ÿÿbÿÿbÿÿEÿÿ0ÿÿ0ÿÿ]ÿÿ ÿÿ ÿÿ:ÿÿ>ÿÿ>ÿÿ ÿÿ
ÿÿ
ÿÿSÿÿ
ÿÿ
ÿÿtÿÿpÿÿpÿÿaÿÿlÿÿlÿÿcÿÿ:ÿÿpÿÿ:ÿÿkÿÿ[ÿÿlÿÿ[ÿÿ ÿÿEÿÿEÿÿtÿÿ:ÿÿ]ÿÿ]ÿÿrÿÿ[ÿÿ:ÿÿ:ÿÿaÿÿEÿÿ ÿÿ ÿÿcÿÿ<ÿÿ]ÿÿ<ÿÿeÿÿ ÿÿ ÿÿ:ÿÿPÿÿ:ÿÿPÿÿ
ÿÿCÿÿ ÿÿCÿÿ
ÿÿ ÿÿNÿÿ ÿÿpÿÿ:ÿÿ:ÿÿvÿÿlÿÿ2ÿÿ2ÿÿGÿÿ:ÿÿ1ÿÿ1ÿÿuÿÿ[ÿÿ0ÿÿ0ÿÿEÿÿeÿÿ0ÿÿ0ÿÿ]ÿÿ1ÿÿ1ÿÿ:ÿÿ5ÿÿsÿÿ5ÿÿ ÿÿ4ÿÿtÿÿ4ÿÿ<ÿÿcÿÿcÿÿFÿÿ ÿÿ ÿÿ ÿÿiÿÿPÿÿ>ÿÿ>ÿÿCÿÿnÿÿ
ÿÿ
ÿÿ ÿÿdÿÿ
ÿÿ
ÿÿ:ÿÿpÿÿ2ÿÿpÿÿlÿÿBÿÿlÿÿ1ÿÿ:ÿÿoÿÿ:ÿÿ0ÿÿ[ÿÿoÿÿ[ÿÿ0ÿÿEÿÿtÿÿEÿÿ3ÿÿ]ÿÿDÿÿ]ÿÿ5ÿÿ:ÿÿeÿÿ:ÿÿbÿÿ ÿÿvÿÿ ÿÿ0ÿÿ<ÿÿ<ÿÿ ÿÿ ÿÿ ÿÿiÿÿPÿÿ>ÿÿcÿÿPÿÿCÿÿ
ÿÿCÿÿeÿÿ ÿÿ
ÿÿ ÿÿIÿÿ:ÿÿpÿÿ:ÿÿnÿÿ2ÿÿlÿÿ2ÿÿfÿÿ:ÿÿ1ÿÿ1ÿÿ0ÿÿ[ÿÿ0ÿÿoÿÿEÿÿ0ÿÿ0ÿÿ0ÿÿ:ÿÿ]ÿÿ0ÿÿ1ÿÿ:ÿÿ1ÿÿ1ÿÿ8ÿÿ ÿÿ5ÿÿ8ÿÿ0ÿÿ<ÿÿ9ÿÿ0ÿÿ ÿÿ ÿÿ ÿÿ ÿÿ>ÿÿPÿÿNÿÿ>ÿÿ
ÿÿCÿÿ
ÿÿ
ÿÿ ÿÿ
ÿÿoÿÿ:ÿÿ ÿÿ2ÿÿBÿÿ1ÿÿoÿÿ00ÿÿoÿÿ1ÿÿtÿÿ5ÿÿ ÿÿ4cÿÿDÿÿ ÿÿeÿÿ>ÿÿvÿÿ
ÿÿiÿÿ
ÿÿcÿÿpÿÿeÿÿlÿÿ ÿÿ:[ÿÿfÿÿE]ÿÿoÿÿ:ÿÿuÿÿ ÿÿnÿÿ<ÿÿdÿÿ ÿÿ
ÿÿPÿÿ
ÿÿCÿÿpÿÿ :ÿÿlÿÿ21ÿÿ:ÿÿ0ÿÿ[ÿÿ0ÿÿEÿÿ0ÿÿ]ÿÿ1ÿÿ:ÿÿ8ÿÿ ÿÿ0 ÿÿQÿÿ>ÿÿbÿÿ
ÿÿDÿÿ
ÿÿataDrivenInit() failed
pl:[E]: BUG data_driven_dt.c:922 (QbDataDrivenInit)
pl:[E]: Stack trace:
pÿÿpl:[E]: NvGuestFindBootDeviceInfo:159 No Boot Device found
pl:[E]: QbDataDrivenInit() failed
pl:[E]: < PC ÿÿl:[E]: < PC :210035b0 >
pl:[E]: < PC :2100154c >
pl:[E]: < PC :21000180 >
ÿÿ:210035b0 >
ÿãHSM ERROR 244, CRITICAL_ERR_NVL_CAR
\00
[/code]0ÿâ
[code]
\00ÿâ
\00ÿýÿàmain enter
HW Function test
Start Scheduler.
in late init
ÿâ
I> bit @ 0xd480000
I> Unpowergate done
I> Loading TOS ...
I> Loading EKS ...
I> Unhalting RCE
ÿâ
welcome to lk
dt initialized
mail initialized
chipid initialized
fuse initialized
sku initialized
speedo initialized
ec initialized
vmon initialized
adc initialized
fmon initialized
reset initialized
nvhs initialized
clk initialized
io_dpd initialized
thermal initialized
i2c initialized
aotag initialized
dvs initialized
pm initialized
pg_late initialized
strap initialized
tag initialized
emc initialized
clk_dt initialized
pm_post initialized
tj_init initialized
uphy_dt initialized
uphy initialized
mrq initialized
dmce initialized
cvc initialized
Starting OS
rm initialized
wake initialized
mail_fs initialized
profile initialized
ÿÿNvGpcDmaLibInitÿÿ
iÿÿ:ÿÿ
vÿÿHÿÿ
cÿÿyÿÿ
_ÿÿpÿÿ
qÿÿeÿÿ
uÿÿrÿÿ
eÿÿvÿÿ
uÿÿiÿÿ
eÿÿsÿÿ
ÿÿoÿÿ
nÿÿrÿÿ
oÿÿ ÿÿ
dÿÿMÿÿ
eÿÿoÿÿ
ÿÿdÿÿ
nÿÿeÿÿ
oÿÿ
ÿÿ
tÿÿ
ÿÿ
present
rÿÿ tÿÿ
eÿÿ aÿÿ
sÿÿ rÿÿ
eÿÿ tÿÿ
nÿÿ iÿÿ
tÿÿ nÿÿ
ÿÿ gÿÿ
ÿÿ app i2c_server
starting aÿÿ
sÿÿ pÿÿ
tÿÿ pÿÿ
aÿÿ ÿÿ
rÿÿ bÿÿ
tÿÿ pÿÿ
iÿÿ mÿÿ
nÿÿ pÿÿ
gÿÿ _iÿÿ
ÿÿ nÿÿ
aÿÿ cÿÿ
pÿÿ oÿÿ
p ÿÿ mÿÿ
gÿÿ iÿÿ
dÿÿ nÿÿ
bÿÿ gÿÿ
_ÿÿ
ÿÿ
aÿÿ
ÿÿ
gent
ÿÿ
ÿÿ
rver
D-S> ÿÿ Sever...
ÿÿVÿÿ
ÿÿC id 526
ÿÿpÿÿ
ÿÿ vÿÿRÿÿscÿÿeÿÿ
ÿÿserved IVC id 528
Reserved IVC id 529
Reserved IVC id 530
ÿÿ1
Reserved IVC id 532
Reserved IVC id 533
Reserved IVC id 534
Reserved IVC id 535
Reserved IVC id 536
Reserved IVC id 537
Reserved IVC id 538
Reserved IVC id 539
ÿÿaMMFLAGS=1
Starting RM server
Start nvpm server
Done...
ÿÿNÿÿ\00
ÿÿnÿÿ\00
ÿÿoÿÿ\00
GPRÿÿtÿÿ\00s:
ÿÿiÿÿ\00
ÿÿ\000000 ÿÿoÿÿ\00
x6: 0x000ÿÿfÿÿ
ÿÿ\001
ÿÿEÿÿ\00
ÿÿoÿÿ\000x2100bbÿÿ
ÿÿ\002c
0xÿÿ
ÿÿ\0021003ÿÿ
ÿÿnÿÿ\00514
0x210ÿÿpÿÿ\000155ÿÿ
ÿÿ\000ÿÿdÿÿ\00
0x21000184
Sÿÿpÿÿ\00iÿÿ
ÿÿ\00:
0x1766ÿÿ:ÿÿ\000
0x18350
0x12ÿÿ[ÿÿ\00070
ÿÿbÿÿbÿÿ
ÿÿ
ÿÿaÿÿ
ÿÿ
ÿÿbÿÿ
ÿÿ
ÿÿDÿÿ
ÿÿ1ÿÿ
ÿÿ
ÿÿSÿÿ
ÿÿ
ÿÿCÿÿ ÿÿCÿÿ
ÿÿ
ÿÿ ÿÿdÿÿ
ÿÿ
ÿÿCÿÿeÿÿ ÿÿ
ÿÿCÿÿ
ÿÿ
ÿÿ ÿÿ
ÿÿiÿÿ
ÿÿPÿÿ
ÿÿDÿÿ
ÿÿ:210035b0 >
\00
[/code]0ÿýÿàmain enter
HW Function test
Start Scheduler.
in late init
ÿâ
I> bit @ 0xd480000
I> Unpowergate done
I> Loading TOS ...
I> Loading EKS ...
I> Unhalting RCE
ÿâ
welcome to lk
dt initialized
mail initialized
chipid initialized
fuse initialized
sku initialized
speedo initialized
ec initialized
vmon initialized
adc initialized
fmon initialized
reset initialized
nvhs initialized
clk initialized
io_dpd initialized
thermal initialized
i2c initialized
aotag initialized
dvs initialized
pm initialized
pg_late initialized
strap initialized
tag initialized
emc initialized
clk_dt initialized
pm_post initialized
tj_init initialized
uphy_dt initialized
uphy initialized
mrq initialized
dmce initialized
cvc initialized
Starting OS
rm initialized
wake initialized
mail_fs initialized
profile initialized
ÿÿNvGpcDmaLibInitÿÿ
iÿÿ:ÿÿ
vÿÿHÿÿ
cÿÿyÿÿ
_ÿÿpÿÿ
qÿÿeÿÿ
uÿÿrÿÿ
eÿÿvÿÿ
uÿÿiÿÿ
eÿÿsÿÿ
ÿÿoÿÿ
nÿÿrÿÿ
oÿÿ ÿÿ
dÿÿMÿÿ
eÿÿoÿÿ
ÿÿdÿÿ
nÿÿeÿÿ
oÿÿ
ÿÿ
tÿÿ
ÿÿ
present
rÿÿ tÿÿ
eÿÿ aÿÿ
sÿÿ rÿÿ
eÿÿ tÿÿ
nÿÿ iÿÿ
tÿÿ nÿÿ
ÿÿ gÿÿ
ÿÿ app i2c_server
starting aÿÿ
sÿÿ pÿÿ
tÿÿ pÿÿ
aÿÿ ÿÿ
rÿÿ bÿÿ
tÿÿ pÿÿ
iÿÿ mÿÿ
nÿÿ pÿÿ
gÿÿ _iÿÿ
ÿÿ nÿÿ
aÿÿ cÿÿ
pÿÿ oÿÿ
p ÿÿ mÿÿ
gÿÿ iÿÿ
dÿÿ nÿÿ
bÿÿ gÿÿ
_ÿÿ
ÿÿ
aÿÿ
ÿÿ
gent
ÿÿ
ÿÿ
rver
D-S> ÿÿ Sever...
ÿÿVÿÿ
ÿÿC id 526
ÿÿpÿÿ
ÿÿ vÿÿRÿÿscÿÿeÿÿ
ÿÿserved IVC id 528
Reserved IVC id 529
Reserved IVC id 530
ÿÿ1
Reserved IVC id 532
Reserved IVC id 533
Reserved IVC id 534
Reserved IVC id 535
Reserved IVC id 536
Reserved IVC id 537
Reserved IVC id 538
Reserved IVC id 539
ÿÿaMMFLAGS=1
Starting RM server
Start nvpm server
Done...
ÿáeÿÿIÿÿlÿÿvÿÿnÿÿ:ÿÿiÿÿfÿÿ[ÿÿ[code]
\00ÿâ
\00ÿýÿàmain enter
HW Function test
Start Scheduler.
in late init
ÿâ
I> bit @ 0xd480000
I> Unpowergate done
I> Loading TOS ...
I> Loading EKS ...
I> Unhalting RCE
ÿâ
welcome to lk
dt initialized
mail initialized
chipid initialized
fuse initialized
sku initialized
speedo initialized
ec initialized
vmon initialized
adc initialized
fmon initialized
reset initialized
nvhs initialized
clk initialized
io_dpd initialized
thermal initialized
i2c initialized
aotag initialized
dvs initialized
pm initialized
pg_late initialized
strap initialized
tag initialized
emc initialized
clk_dt initialized
pm_post initialized
tj_init initialized
uphy_dt initialized
uphy initialized
mrq initialized
dmce initialized
cvc initialized
Starting OS
rm initialized
wake initialized
mail_fs initialized
profile initialized
ÿÿNvGpcDmaLibInitÿÿ
iÿÿ:ÿÿ
vÿÿHÿÿ
cÿÿyÿÿ
_ÿÿpÿÿ
qÿÿeÿÿ
uÿÿrÿÿ
eÿÿvÿÿ
uÿÿiÿÿ
eÿÿsÿÿ
ÿÿoÿÿ
nÿÿrÿÿ
oÿÿ ÿÿ
dÿÿMÿÿ
eÿÿoÿÿ
ÿÿdÿÿ
nÿÿeÿÿ
oÿÿ
ÿÿ
tÿÿ
ÿÿ
present
rÿÿ tÿÿ
eÿÿ aÿÿ
sÿÿ rÿÿ
eÿÿ tÿÿ
nÿÿ iÿÿ
tÿÿ nÿÿ
ÿÿ gÿÿ
ÿÿ app i2c_server
starting aÿÿ
sÿÿ pÿÿ
tÿÿ pÿÿ
aÿÿ ÿÿ
rÿÿ bÿÿ
tÿÿ pÿÿ
iÿÿ mÿÿ
nÿÿ pÿÿ
gÿÿ _iÿÿ
ÿÿ nÿÿ
aÿÿ cÿÿ
pÿÿ oÿÿ
p ÿÿ mÿÿ
gÿÿ iÿÿ
dÿÿ nÿÿ
bÿÿ gÿÿ
_ÿÿ
ÿÿ
aÿÿ
ÿÿ
gent
ÿÿ
ÿÿ
rver
D-S> ÿÿ Sever...
ÿÿVÿÿ
ÿÿC id 526
ÿÿpÿÿ
ÿÿ vÿÿRÿÿscÿÿeÿÿ
ÿÿserved IVC id 528
Reserved IVC id 529
Reserved IVC id 530
ÿÿ1
Reserved IVC id 532
Reserved IVC id 533
Reserved IVC id 534
Reserved IVC id 535
Reserved IVC id 536
Reserved IVC id 537
Reserved IVC id 538
Reserved IVC id 539
ÿÿaMMFLAGS=1
Starting RM server
Start nvpm server
Done...
ÿÿNÿÿ\00
ÿÿnÿÿ\00
ÿÿoÿÿ\00
GPRÿÿtÿÿ\00s:
ÿÿiÿÿ\00
ÿÿ\000000 ÿÿoÿÿ\00
x6: 0x000ÿÿfÿÿ
ÿÿ\001
ÿÿEÿÿ\00
ÿÿoÿÿ\000x2100bbÿÿ
ÿÿ\002c
0xÿÿ
ÿÿ\0021003ÿÿ
ÿÿnÿÿ\00514
0x210ÿÿpÿÿ\000155ÿÿ
ÿÿ\000ÿÿdÿÿ\00
0x21000184
Sÿÿpÿÿ\00iÿÿ
ÿÿ\00:
0x1766ÿÿ:ÿÿ\000
0x18350
0x12ÿÿ[ÿÿ\00070
ÿÿbÿÿbÿÿ
ÿÿ
ÿÿaÿÿ
ÿÿ
ÿÿbÿÿ
ÿÿ
ÿÿDÿÿ
ÿÿ1ÿÿ
ÿÿ
ÿÿSÿÿ
ÿÿ
ÿÿCÿÿ ÿÿCÿÿ
ÿÿ
ÿÿ ÿÿdÿÿ
ÿÿ
ÿÿCÿÿeÿÿ ÿÿ
ÿÿCÿÿ
ÿÿ
ÿÿ ÿÿ
ÿÿiÿÿ
ÿÿPÿÿ
ÿÿDÿÿ
ÿÿ:210035b0 >
\00
[/code]0
ÿÿcÿÿ[code]
\00ÿâ
\00ÿýÿàmain enter
HW Function test
Start Scheduler.
in late init
ÿâ
I> bit @ 0xd480000
I> Unpowergate done
I> Loading TOS ...
I> Loading EKS ...
I> Unhalting RCE
ÿâ
welcome to lk
dt initialized
mail initialized
chipid initialized
fuse initialized
sku initialized
speedo initialized
ec initialized
vmon initialized
adc initialized
fmon initialized
reset initialized
nvhs initialized
clk initialized
io_dpd initialized
thermal initialized
i2c initialized
aotag initialized
dvs initialized
pm initialized
pg_late initialized
strap initialized
tag initialized
emc initialized
clk_dt initialized
pm_post initialized
tj_init initialized
uphy_dt initialized
uphy initialized
mrq initialized
dmce initialized
cvc initialized
Starting OS
rm initialized
wake initialized
mail_fs initialized
profile initialized
ÿÿNvGpcDmaLibInitÿÿ
iÿÿ:ÿÿ
vÿÿHÿÿ
cÿÿyÿÿ
_ÿÿpÿÿ
qÿÿeÿÿ
uÿÿrÿÿ
eÿÿvÿÿ
uÿÿiÿÿ
eÿÿsÿÿ
ÿÿoÿÿ
nÿÿrÿÿ
oÿÿ ÿÿ
dÿÿMÿÿ
eÿÿoÿÿ
ÿÿdÿÿ
nÿÿeÿÿ
oÿÿ
ÿÿ
tÿÿ
ÿÿ
present
rÿÿ tÿÿ
eÿÿ aÿÿ
sÿÿ rÿÿ
eÿÿ tÿÿ
nÿÿ iÿÿ
tÿÿ nÿÿ
ÿÿ gÿÿ
ÿÿ app i2c_server
starting aÿÿ
sÿÿ pÿÿ
tÿÿ pÿÿ
aÿÿ ÿÿ
rÿÿ bÿÿ
tÿÿ pÿÿ
iÿÿ mÿÿ
nÿÿ pÿÿ
gÿÿ _iÿÿ
ÿÿ nÿÿ
aÿÿ cÿÿ
pÿÿ oÿÿ
p ÿÿ mÿÿ
gÿÿ iÿÿ
dÿÿ nÿÿ
bÿÿ gÿÿ
_ÿÿ
ÿÿ
aÿÿ
ÿÿ
gent
ÿÿ
ÿÿ
rver
D-S> ÿÿ Sever...
ÿÿVÿÿ
ÿÿC id 526
ÿÿpÿÿ
ÿÿ vÿÿRÿÿscÿÿeÿÿ
ÿÿserved IVC id 528
Reserved IVC id 529
Reserved IVC id 530
ÿÿ1
Reserved IVC id 532
Reserved IVC id 533
Reserved IVC id 534
Reserved IVC id 535
Reserved IVC id 536
Reserved IVC id 537
Reserved IVC id 538
Reserved IVC id 539
ÿÿaMMFLAGS=1
Starting RM server
Start nvpm server
Done...
ÿÿNÿÿ\00
ÿÿnÿÿ\00
ÿÿoÿÿ\00
GPRÿÿtÿÿ\00s:
ÿÿiÿÿ\00
ÿÿ\000000 ÿÿoÿÿ\00
x6: 0x000ÿÿfÿÿ
ÿÿ\001
ÿÿEÿÿ\00
ÿÿoÿÿ\000x2100bbÿÿ
ÿÿ\002c
0xÿÿ
ÿÿ\0021003ÿÿ
ÿÿnÿÿ\00514
0x210ÿÿpÿÿ\000155ÿÿ
ÿÿ\000ÿÿdÿÿ\00
0x21000184
Sÿÿpÿÿ\00iÿÿ
ÿÿ\00:
0x1766ÿÿ:ÿÿ\000
0x18350
0x12ÿÿ[ÿÿ\00070
ÿÿbÿÿbÿÿ
ÿÿ
ÿÿaÿÿ
ÿÿ
ÿÿbÿÿ
ÿÿ
ÿÿDÿÿ
ÿÿ1ÿÿ
ÿÿ
ÿÿSÿÿ
ÿÿ
ÿÿCÿÿ ÿÿCÿÿ
ÿÿ
ÿÿ ÿÿdÿÿ
ÿÿ
ÿÿCÿÿeÿÿ ÿÿ
ÿÿCÿÿ
ÿÿ
ÿÿ ÿÿ
ÿÿiÿÿ
ÿÿPÿÿ
ÿÿDÿÿ
ÿÿ:210035b0 >
\00
[/code]0GID 0:ÿÿoÿÿ[code]
\00ÿâ
\00ÿýÿàmain enter
HW Function test
Start Scheduler.
in late init
ÿâ
I> bit @ 0xd480000
I> Unpowergate done
I> Loading TOS ...
I> Loading EKS ...
I> Unhalting RCE
ÿâ
welcome to lk
dt initialized
mail initialized
chipid initialized
fuse initialized
sku initialized
speedo initialized
ec initialized
vmon initialized
adc initialized
fmon initialized
reset initialized
nvhs initialized
clk initialized
io_dpd initialized
thermal initialized
i2c initialized
aotag initialized
dvs initialized
pm initialized
pg_late initialized
strap initialized
tag initialized
emc initialized
clk_dt initialized
pm_post initialized
tj_init initialized
uphy_dt initialized
uphy initialized
mrq initialized
dmce initialized
cvc initialized
Starting OS
rm initialized
wake initialized
mail_fs initialized
profile initialized
ÿÿNvGpcDmaLibInitÿÿ
iÿÿ:ÿÿ
vÿÿHÿÿ
cÿÿyÿÿ
_ÿÿpÿÿ
qÿÿeÿÿ
uÿÿrÿÿ
eÿÿvÿÿ
uÿÿiÿÿ
eÿÿsÿÿ
ÿÿoÿÿ
nÿÿrÿÿ
oÿÿ ÿÿ
dÿÿMÿÿ
eÿÿoÿÿ
ÿÿdÿÿ
nÿÿeÿÿ
oÿÿ
ÿÿ
tÿÿ
ÿÿ
present
rÿÿ tÿÿ
eÿÿ aÿÿ
sÿÿ rÿÿ
eÿÿ tÿÿ
nÿÿ iÿÿ
tÿÿ nÿÿ
ÿÿ gÿÿ
ÿÿ app i2c_server
starting aÿÿ
sÿÿ pÿÿ
tÿÿ pÿÿ
aÿÿ ÿÿ
rÿÿ bÿÿ
tÿÿ pÿÿ
iÿÿ mÿÿ
nÿÿ pÿÿ
gÿÿ _iÿÿ
ÿÿ nÿÿ
aÿÿ cÿÿ
pÿÿ oÿÿ
p ÿÿ mÿÿ
gÿÿ iÿÿ
dÿÿ nÿÿ
bÿÿ gÿÿ
_ÿÿ
ÿÿ
aÿÿ
ÿÿ
gent
ÿÿ
ÿÿ
rver
D-S> ÿÿ Sever...
ÿÿVÿÿ
ÿÿC id 526
ÿÿpÿÿ
ÿÿ vÿÿRÿÿscÿÿeÿÿ
ÿÿserved IVC id 528
Reserved IVC id 529
Reserved IVC id 530
ÿÿ1
Reserved IVC id 532
Reserved IVC id 533
Reserved IVC id 534
Reserved IVC id 535
Reserved IVC id 536
Reserved IVC id 537
Reserved IVC id 538
Reserved IVC id 539
ÿÿaMMFLAGS=1
Starting RM server
Start nvpm server
Done...
ÿÿNÿÿ\00
ÿÿnÿÿ\00
ÿÿoÿÿ\00
GPRÿÿtÿÿ\00s:
ÿÿiÿÿ\00
ÿÿ\000000 ÿÿoÿÿ\00
x6: 0x000ÿÿfÿÿ
ÿÿ\001
ÿÿEÿÿ\00
ÿÿoÿÿ\000x2100bbÿÿ
ÿÿ\002c
0xÿÿ
ÿÿ\0021003ÿÿ
ÿÿnÿÿ\00514
0x210ÿÿpÿÿ\000155ÿÿ
ÿÿ\000ÿÿdÿÿ\00
0x21000184
Sÿÿpÿÿ\00iÿÿ
ÿÿ\00:
0x1766ÿÿ:ÿÿ\000
0x18350
0x12ÿÿ[ÿÿ\00070
ÿÿbÿÿbÿÿ
ÿÿ
ÿÿaÿÿ
ÿÿ
ÿÿbÿÿ
ÿÿ
ÿÿDÿÿ
ÿÿ1ÿÿ
ÿÿ
ÿÿSÿÿ
ÿÿ
ÿÿCÿÿ ÿÿCÿÿ
ÿÿ
ÿÿ ÿÿdÿÿ
ÿÿ
ÿÿCÿÿeÿÿ ÿÿ
ÿÿCÿÿ
ÿÿ
ÿÿ ÿÿ
ÿÿiÿÿ
ÿÿPÿÿ
ÿÿDÿÿ
ÿÿ:210035b0 >
\00
[/code]0 UnÿÿEÿÿ[code]
\00ÿâ
\00ÿýÿàmain enter
HW Function test
Start Scheduler.
in late init
ÿâ
I> bit @ 0xd480000
I> Unpowergate done
I> Loading TOS ...
I> Loading EKS ...
I> Unhalting RCE
ÿâ
welcome to lk
dt initialized
mail initialized
chipid initialized
fuse initialized
sku initialized
speedo initialized
ec initialized
vmon initialized
adc initialized
fmon initialized
reset initialized
nvhs initialized
clk initialized
io_dpd initialized
thermal initialized
i2c initialized
aotag initialized
dvs initialized
pm initialized
pg_late initialized
strap initialized
tag initialized
emc initialized
clk_dt initialized
pm_post initialized
tj_init initialized
uphy_dt initialized
uphy initialized
mrq initialized
dmce initialized
cvc initialized
Starting OS
rm initialized
wake initialized
mail_fs initialized
profile initialized
ÿÿNvGpcDmaLibInitÿÿ
iÿÿ:ÿÿ
vÿÿHÿÿ
cÿÿyÿÿ
_ÿÿpÿÿ
qÿÿeÿÿ
uÿÿrÿÿ
eÿÿvÿÿ
uÿÿiÿÿ
eÿÿsÿÿ
ÿÿoÿÿ
nÿÿrÿÿ
oÿÿ ÿÿ
dÿÿMÿÿ
eÿÿoÿÿ
ÿÿdÿÿ
nÿÿeÿÿ
oÿÿ
ÿÿ
tÿÿ
ÿÿ
present
rÿÿ tÿÿ
eÿÿ aÿÿ
sÿÿ rÿÿ
eÿÿ tÿÿ
nÿÿ iÿÿ
tÿÿ nÿÿ
ÿÿ gÿÿ
ÿÿ app i2c_server
starting aÿÿ
sÿÿ pÿÿ
tÿÿ pÿÿ
aÿÿ ÿÿ
rÿÿ bÿÿ
tÿÿ pÿÿ
iÿÿ mÿÿ
nÿÿ pÿÿ
gÿÿ _iÿÿ
ÿÿ nÿÿ
aÿÿ cÿÿ
pÿÿ oÿÿ
p ÿÿ mÿÿ
gÿÿ iÿÿ
dÿÿ nÿÿ
bÿÿ gÿÿ
_ÿÿ
ÿÿ
aÿÿ
ÿÿ
gent
ÿÿ
ÿÿ
rver
D-S> ÿÿ Sever...
ÿÿVÿÿ
ÿÿC id 526
ÿÿpÿÿ
ÿÿ vÿÿRÿÿscÿÿeÿÿ
ÿÿserved IVC id 528
Reserved IVC id 529
Reserved IVC id 530
ÿÿ1
Reserved IVC id 532
Reserved IVC id 533
Reserved IVC id 534
Reserved IVC id 535
Reserved IVC id 536
Reserved IVC id 537
Reserved IVC id 538
Reserved IVC id 539
ÿÿaMMFLAGS=1
Starting RM server
Start nvpm server
Done...
ÿÿNÿÿ\00
ÿÿnÿÿ\00
ÿÿoÿÿ\00
GPRÿÿtÿÿ\00s:
ÿÿiÿÿ\00
ÿÿ\000000 ÿÿoÿÿ\00
x6: 0x000ÿÿfÿÿ
ÿÿ\001
ÿÿEÿÿ\00
ÿÿoÿÿ\000x2100bbÿÿ
ÿÿ\002c
0xÿÿ
ÿÿ\0021003ÿÿ
ÿÿnÿÿ\00514
0x210ÿÿpÿÿ\000155ÿÿ
ÿÿ\000ÿÿdÿÿ\00
0x21000184
Sÿÿpÿÿ\00iÿÿ
ÿÿ\00:
0x1766ÿÿ:ÿÿ\000
0x18350
0x12ÿÿ[ÿÿ\00070
ÿÿbÿÿbÿÿ
ÿÿ
ÿÿaÿÿ
ÿÿ
ÿÿbÿÿ
ÿÿ
ÿÿDÿÿ
ÿÿ1ÿÿ
ÿÿ
ÿÿSÿÿ
ÿÿ
ÿÿCÿÿ ÿÿCÿÿ
ÿÿ
ÿÿ ÿÿdÿÿ
ÿÿ
ÿÿCÿÿeÿÿ ÿÿ
ÿÿCÿÿ
ÿÿ
ÿÿ ÿÿ
ÿÿiÿÿ
ÿÿPÿÿ
ÿÿDÿÿ
ÿÿ:210035b0 >
\00
[/code]0hanÿÿeÿÿ[code]
\00ÿâ
\00ÿýÿàmain enter
HW Function test
Start Scheduler.
in late init
ÿâ
I> bit @ 0xd480000
I> Unpowergate done
I> Loading TOS ...
I> Loading EKS ...
I> Unhalting RCE
ÿâ
welcome to lk
dt initialized
mail initialized
chipid initialized
fuse initialized
sku initialized
speedo initialized
ec initialized
vmon initialized
adc initialized
fmon initialized
reset initialized
nvhs initialized
clk initialized
io_dpd initialized
thermal initialized
i2c initialized
aotag initialized
dvs initialized
pm initialized
pg_late initialized
strap initialized
tag initialized
emc initialized
clk_dt initialized
pm_post initialized
tj_init initialized
uphy_dt initialized
uphy initialized
mrq initialized
dmce initialized
cvc initialized
Starting OS
rm initialized
wake initialized
mail_fs initialized
profile initialized
ÿÿNvGpcDmaLibInitÿÿ
iÿÿ:ÿÿ
vÿÿHÿÿ
cÿÿyÿÿ
_ÿÿpÿÿ
qÿÿeÿÿ
uÿÿrÿÿ
eÿÿvÿÿ
uÿÿiÿÿ
eÿÿsÿÿ
ÿÿoÿÿ
nÿÿrÿÿ
oÿÿ ÿÿ
dÿÿMÿÿ
eÿÿoÿÿ
ÿÿdÿÿ
nÿÿeÿÿ
oÿÿ
ÿÿ
tÿÿ
ÿÿ
present
rÿÿ tÿÿ
eÿÿ aÿÿ
sÿÿ rÿÿ
eÿÿ tÿÿ
nÿÿ iÿÿ
tÿÿ nÿÿ
ÿÿ gÿÿ
ÿÿ app i2c_server
starting aÿÿ
sÿÿ pÿÿ
tÿÿ pÿÿ
aÿÿ ÿÿ
rÿÿ bÿÿ
tÿÿ pÿÿ
iÿÿ mÿÿ
nÿÿ pÿÿ
gÿÿ _iÿÿ
ÿÿ nÿÿ
aÿÿ cÿÿ
pÿÿ oÿÿ
p ÿÿ mÿÿ
gÿÿ iÿÿ
dÿÿ nÿÿ
bÿÿ gÿÿ
_ÿÿ
ÿÿ
aÿÿ
ÿÿ
gent
ÿÿ
ÿÿ
rver
D-S> ÿÿ Sever...
ÿÿVÿÿ
ÿÿC id 526
ÿÿpÿÿ
ÿÿ vÿÿRÿÿscÿÿeÿÿ
ÿÿserved IVC id 528
Reserved IVC id 529
Reserved IVC id 530
ÿÿ1
Reserved IVC id 532
Reserved IVC id 533
Reserved IVC id 534
Reserved IVC id 535
Reserved IVC id 536
Reserved IVC id 537
Reserved IVC id 538
Reserved IVC id 539
ÿÿaMMFLAGS=1
Starting RM server
Start nvpm server
Done...
ÿÿNÿÿ\00
ÿÿnÿÿ\00
ÿÿoÿÿ\00
GPRÿÿtÿÿ\00s:
ÿÿiÿÿ\00
ÿÿ\000000 ÿÿoÿÿ\00
x6: 0x000ÿÿfÿÿ
ÿÿ\001
ÿÿEÿÿ\00
ÿÿoÿÿ\000x2100bbÿÿ
ÿÿ\002c
0xÿÿ
ÿÿ\0021003ÿÿ
ÿÿnÿÿ\00514
0x210ÿÿpÿÿ\000155ÿÿ
ÿÿ\000ÿÿdÿÿ\00
0x21000184
Sÿÿpÿÿ\00iÿÿ
ÿÿ\00:
0x1766ÿÿ:ÿÿ\000
0x18350
0x12ÿÿ[ÿÿ\00070
ÿÿbÿÿbÿÿ
ÿÿ
ÿÿaÿÿ
ÿÿ
ÿÿbÿÿ
ÿÿ
ÿÿDÿÿ
ÿÿ1ÿÿ
ÿÿ
ÿÿSÿÿ
ÿÿ
ÿÿCÿÿ ÿÿCÿÿ
ÿÿ
ÿÿ ÿÿdÿÿ
ÿÿ
ÿÿCÿÿeÿÿ ÿÿ
ÿÿCÿÿ
ÿÿ
ÿÿ ÿÿ
ÿÿiÿÿ
ÿÿPÿÿ
ÿÿDÿÿ
ÿÿ:210035b0 >
\00
[/code]0dled acÿÿ:ÿÿ[code]
\00ÿâ
\00ÿýÿàmain enter
HW Function test
Start Scheduler.
in late init
ÿâ
I> bit @ 0xd480000
I> Unpowergate done
I> Loading TOS ...
I> Loading EKS ...
I> Unhalting RCE
ÿâ
welcome to lk
dt initialized
mail initialized
chipid initialized
fuse initialized
sku initialized
speedo initialized
ec initialized
vmon initialized
adc initialized
fmon initialized
reset initialized
nvhs initialized
clk initialized
io_dpd initialized
thermal initialized
i2c initialized
aotag initialized
dvs initialized
pm initialized
pg_late initialized
strap initialized
tag initialized
emc initialized
clk_dt initialized
pm_post initialized
tj_init initialized
uphy_dt initialized
uphy initialized
mrq initialized
dmce initialized
cvc initialized
Starting OS
rm initialized
wake initialized
mail_fs initialized
profile initialized
ÿÿNvGpcDmaLibInitÿÿ
iÿÿ:ÿÿ
vÿÿHÿÿ
cÿÿyÿÿ
_ÿÿpÿÿ
qÿÿeÿÿ
uÿÿrÿÿ
eÿÿvÿÿ
uÿÿiÿÿ
eÿÿsÿÿ
ÿÿoÿÿ
nÿÿrÿÿ
oÿÿ ÿÿ
dÿÿMÿÿ
eÿÿoÿÿ
ÿÿdÿÿ
nÿÿeÿÿ
oÿÿ
ÿÿ
tÿÿ
ÿÿ
present
rÿÿ tÿÿ
eÿÿ aÿÿ
sÿÿ rÿÿ
eÿÿ tÿÿ
nÿÿ iÿÿ
tÿÿ nÿÿ
ÿÿ gÿÿ
ÿÿ app i2c_server
starting aÿÿ
sÿÿ pÿÿ
tÿÿ pÿÿ
aÿÿ ÿÿ
rÿÿ bÿÿ
tÿÿ pÿÿ
iÿÿ mÿÿ
nÿÿ pÿÿ
gÿÿ _iÿÿ
ÿÿ nÿÿ
aÿÿ cÿÿ
pÿÿ oÿÿ
p ÿÿ mÿÿ
gÿÿ iÿÿ
dÿÿ nÿÿ
bÿÿ gÿÿ
_ÿÿ
ÿÿ
aÿÿ
ÿÿ
gent
ÿÿ
ÿÿ
rver
D-S> ÿÿ Sever...
ÿÿVÿÿ
ÿÿC id 526
ÿÿpÿÿ
ÿÿ vÿÿRÿÿscÿÿeÿÿ
ÿÿserved IVC id 528
Reserved IVC id 529
Reserved IVC id 530
ÿÿ1
Reserved IVC id 532
Reserved IVC id 533
Reserved IVC id 534
Reserved IVC id 535
Reserved IVC id 536
Reserved IVC id 537
Reserved IVC id 538
Reserved IVC id 539
ÿÿaMMFLAGS=1
Starting RM server
Start nvpm server
Done...
ÿÿNÿÿ\00
ÿÿnÿÿ\00
ÿÿoÿÿ\00
GPRÿÿtÿÿ\00s:
ÿÿiÿÿ\00
ÿÿ\000000 ÿÿoÿÿ\00
x6: 0x000ÿÿfÿÿ
ÿÿ\001
ÿÿEÿÿ\00
ÿÿoÿÿ\000x2100bbÿÿ
ÿÿ\002c
0xÿÿ
ÿÿ\0021003ÿÿ
ÿÿnÿÿ\00514
0x210ÿÿpÿÿ\000155ÿÿ
ÿÿ\000ÿÿdÿÿ\00
0x21000184
Sÿÿpÿÿ\00iÿÿ
ÿÿ\00:
0x1766ÿÿ:ÿÿ\000
0x18350
0x12ÿÿ[ÿÿ\00070
ÿÿbÿÿbÿÿ
ÿÿ
ÿÿaÿÿ
ÿÿ
ÿÿbÿÿ
ÿÿ
ÿÿDÿÿ
ÿÿ1ÿÿ
ÿÿ
ÿÿSÿÿ
ÿÿ
ÿÿCÿÿ ÿÿCÿÿ
ÿÿ
ÿÿ ÿÿdÿÿ
ÿÿ
ÿÿCÿÿeÿÿ ÿÿ
ÿÿCÿÿ
ÿÿ
ÿÿ ÿÿ
ÿÿiÿÿ
ÿÿPÿÿ
ÿÿDÿÿ
ÿÿ:210035b0 >
\00
[/code]0cesÿÿ]ÿÿ[code]
\00ÿâ
\00ÿýÿàmain enter
HW Function test
Start Scheduler.
in late init
ÿâ
I> bit @ 0xd480000
I> Unpowergate done
I> Loading TOS ...
I> Loading EKS ...
I> Unhalting RCE
ÿâ
welcome to lk
dt initialized
mail initialized
chipid initialized
fuse initialized
sku initialized
speedo initialized
ec initialized
vmon initialized
adc initialized
fmon initialized
reset initialized
nvhs initialized
clk initialized
io_dpd initialized
thermal initialized
i2c initialized
aotag initialized
dvs initialized
pm initialized
pg_late initialized
strap initialized
tag initialized
emc initialized
clk_dt initialized
pm_post initialized
tj_init initialized
uphy_dt initialized
uphy initialized
mrq initialized
dmce initialized
cvc initialized
Starting OS
rm initialized
wake initialized
mail_fs initialized
profile initialized
ÿÿNvGpcDmaLibInitÿÿ
iÿÿ:ÿÿ
vÿÿHÿÿ
cÿÿyÿÿ
_ÿÿpÿÿ
qÿÿeÿÿ
uÿÿrÿÿ
eÿÿvÿÿ
uÿÿiÿÿ
eÿÿsÿÿ
ÿÿoÿÿ
nÿÿrÿÿ
oÿÿ ÿÿ
dÿÿMÿÿ
eÿÿoÿÿ
ÿÿdÿÿ
nÿÿeÿÿ
oÿÿ
ÿÿ
tÿÿ
ÿÿ
present
rÿÿ tÿÿ
eÿÿ aÿÿ
sÿÿ rÿÿ
eÿÿ tÿÿ
nÿÿ iÿÿ
tÿÿ nÿÿ
ÿÿ gÿÿ
ÿÿ app i2c_server
starting aÿÿ
sÿÿ pÿÿ
tÿÿ pÿÿ
aÿÿ ÿÿ
rÿÿ bÿÿ
tÿÿ pÿÿ
iÿÿ mÿÿ
nÿÿ pÿÿ
gÿÿ _iÿÿ
ÿÿ nÿÿ
aÿÿ cÿÿ
pÿÿ oÿÿ
p ÿÿ mÿÿ
gÿÿ iÿÿ
dÿÿ nÿÿ
bÿÿ gÿÿ
_ÿÿ
ÿÿ
aÿÿ
ÿÿ
gent
ÿÿ
ÿÿ
rver
D-S> ÿÿ Sever...
ÿÿVÿÿ
ÿÿC id 526
ÿÿpÿÿ
ÿÿ vÿÿRÿÿscÿÿeÿÿ
ÿÿserved IVC id 528
Reserved IVC id 529
Reserved IVC id 530
ÿÿ1
Reserved IVC id 532
Reserved IVC id 533
Reserved IVC id 534
Reserved IVC id 535
Reserved IVC id 536
Reserved IVC id 537
Reserved IVC id 538
Reserved IVC id 539
ÿÿaMMFLAGS=1
Starting RM server
Start nvpm server
Done...
ÿÿNÿÿ\00
ÿÿnÿÿ\00
ÿÿoÿÿ\00
GPRÿÿtÿÿ\00s:
ÿÿiÿÿ\00
ÿÿ\000000 ÿÿoÿÿ\00
x6: 0x000ÿÿfÿÿ
ÿÿ\001
ÿÿEÿÿ\00
ÿÿoÿÿ\000x2100bbÿÿ
ÿÿ\002c
0xÿÿ
ÿÿ\0021003ÿÿ
ÿÿnÿÿ\00514
0x210ÿÿpÿÿ\000155ÿÿ
ÿÿ\000ÿÿdÿÿ\00
0x21000184
Sÿÿpÿÿ\00iÿÿ
ÿÿ\00:
0x1766ÿÿ:ÿÿ\000
0x18350
0x12ÿÿ[ÿÿ\00070
ÿÿbÿÿbÿÿ
ÿÿ
ÿÿaÿÿ
ÿÿ
ÿÿbÿÿ
ÿÿ
ÿÿDÿÿ
ÿÿ1ÿÿ
ÿÿ
ÿÿSÿÿ
ÿÿ
ÿÿCÿÿ ÿÿCÿÿ
ÿÿ
ÿÿ ÿÿdÿÿ
ÿÿ
ÿÿCÿÿeÿÿ ÿÿ
ÿÿCÿÿ
ÿÿ
ÿÿ ÿÿ
ÿÿiÿÿ
ÿÿPÿÿ
ÿÿDÿÿ
ÿÿ:210035b0 >
\00
[/code]0s oÿÿIÿÿ[code]
\00ÿâ
\00ÿýÿàmain enter
HW Function test
Start Scheduler.
in late init
ÿâ
I> bit @ 0xd480000
I> Unpowergate done
I> Loading TOS ...
I> Loading EKS ...
I> Unhalting RCE
ÿâ
welcome to lk
dt initialized
mail initialized
chipid initialized
fuse initialized
sku initialized
speedo initialized
ec initialized
vmon initialized
adc initialized
fmon initialized
reset initialized
nvhs initialized
clk initialized
io_dpd initialized
thermal initialized
i2c initialized
aotag initialized
dvs initialized
pm initialized
pg_late initialized
strap initialized
tag initialized
emc initialized
clk_dt initialized
pm_post initialized
tj_init initialized
uphy_dt initialized
uphy initialized
mrq initialized
dmce initialized
cvc initialized
Starting OS
rm initialized
wake initialized
mail_fs initialized
profile initialized
ÿÿNvGpcDmaLibInitÿÿ
iÿÿ:ÿÿ
vÿÿHÿÿ
cÿÿyÿÿ
_ÿÿpÿÿ
qÿÿeÿÿ
uÿÿrÿÿ
eÿÿvÿÿ
uÿÿiÿÿ
eÿÿsÿÿ
ÿÿoÿÿ
nÿÿrÿÿ
oÿÿ ÿÿ
dÿÿMÿÿ
eÿÿoÿÿ
ÿÿdÿÿ
nÿÿeÿÿ
oÿÿ
ÿÿ
tÿÿ
ÿÿ
present
rÿÿ tÿÿ
eÿÿ aÿÿ
sÿÿ rÿÿ
eÿÿ tÿÿ
nÿÿ iÿÿ
tÿÿ nÿÿ
ÿÿ gÿÿ
ÿÿ app i2c_server
starting aÿÿ
sÿÿ pÿÿ
tÿÿ pÿÿ
aÿÿ ÿÿ
rÿÿ bÿÿ
tÿÿ pÿÿ
iÿÿ mÿÿ
nÿÿ pÿÿ
gÿÿ _iÿÿ
ÿÿ nÿÿ
aÿÿ cÿÿ
pÿÿ oÿÿ
p ÿÿ mÿÿ
gÿÿ iÿÿ
dÿÿ nÿÿ
bÿÿ gÿÿ
_ÿÿ
ÿÿ
aÿÿ
ÿÿ
gent
ÿÿ
ÿÿ
rver
D-S> ÿÿ Sever...
ÿÿVÿÿ
ÿÿC id 526
ÿÿpÿÿ
ÿÿ vÿÿRÿÿscÿÿeÿÿ
ÿÿserved IVC id 528
Reserved IVC id 529
Reserved IVC id 530
ÿÿ1
Reserved IVC id 532
Reserved IVC id 533
Reserved IVC id 534
Reserved IVC id 535
Reserved IVC id 536
Reserved IVC id 537
Reserved IVC id 538
Reserved IVC id 539
ÿÿaMMFLAGS=1
Starting RM server
Start nvpm server
Done...
ÿÿNÿÿ\00
ÿÿnÿÿ\00
ÿÿoÿÿ\00
GPRÿÿtÿÿ\00s:
ÿÿiÿÿ\00
ÿÿ\000000 ÿÿoÿÿ\00
x6: 0x000ÿÿfÿÿ
ÿÿ\001
ÿÿEÿÿ\00
ÿÿoÿÿ\000x2100bbÿÿ
ÿÿ\002c
0xÿÿ
ÿÿ\0021003ÿÿ
ÿÿnÿÿ\00514
0x210ÿÿpÿÿ\000155ÿÿ
ÿÿ\000ÿÿdÿÿ\00
0x21000184
Sÿÿpÿÿ\00iÿÿ
ÿÿ\00:
0x1766ÿÿ:ÿÿ\000
0x18350
0x12ÿÿ[ÿÿ\00070
ÿÿbÿÿbÿÿ
ÿÿ
ÿÿaÿÿ
ÿÿ
ÿÿbÿÿ
ÿÿ
ÿÿDÿÿ
ÿÿ1ÿÿ
ÿÿ
ÿÿSÿÿ
ÿÿ
ÿÿCÿÿ ÿÿCÿÿ
ÿÿ
ÿÿ ÿÿdÿÿ
ÿÿ
ÿÿCÿÿeÿÿ ÿÿ
ÿÿCÿÿ
ÿÿ
ÿÿ ÿÿ
ÿÿiÿÿ
ÿÿPÿÿ
ÿÿDÿÿ
ÿÿ:210035b0 >
\00
[/code]0f sizeÿÿ1ÿÿ[code]
\00ÿâ
\00ÿýÿàmain enter
HW Function test
Start Scheduler.
in late init
ÿâ
I> bit @ 0xd480000
I> Unpowergate done
I> Loading TOS ...
I> Loading EKS ...
I> Unhalting RCE
ÿâ
welcome to lk
dt initialized
mail initialized
chipid initialized
fuse initialized
sku initialized
speedo initialized
ec initialized
vmon initialized
adc initialized
fmon initialized
reset initialized
nvhs initialized
clk initialized
io_dpd initialized
thermal initialized
i2c initialized
aotag initialized
dvs initialized
pm initialized
pg_late initialized
strap initialized
tag initialized
emc initialized
clk_dt initialized
pm_post initialized
tj_init initialized
uphy_dt initialized
uphy initialized
mrq initialized
dmce initialized
cvc initialized
Starting OS
rm initialized
wake initialized
mail_fs initialized
profile initialized
ÿÿNvGpcDmaLibInitÿÿ
iÿÿ:ÿÿ
vÿÿHÿÿ
cÿÿyÿÿ
_ÿÿpÿÿ
qÿÿeÿÿ
uÿÿrÿÿ
eÿÿvÿÿ
uÿÿiÿÿ
eÿÿsÿÿ
ÿÿoÿÿ
nÿÿrÿÿ
oÿÿ ÿÿ
dÿÿMÿÿ
eÿÿoÿÿ
ÿÿdÿÿ
nÿÿeÿÿ
oÿÿ
ÿÿ
tÿÿ
ÿÿ
present
rÿÿ tÿÿ
eÿÿ aÿÿ
sÿÿ rÿÿ
eÿÿ tÿÿ
nÿÿ iÿÿ
tÿÿ nÿÿ
ÿÿ gÿÿ
ÿÿ app i2c_server
starting aÿÿ
sÿÿ pÿÿ
tÿÿ pÿÿ
aÿÿ ÿÿ
rÿÿ bÿÿ
tÿÿ pÿÿ
iÿÿ mÿÿ
nÿÿ pÿÿ
gÿÿ _iÿÿ
ÿÿ nÿÿ
aÿÿ cÿÿ
pÿÿ oÿÿ
p ÿÿ mÿÿ
gÿÿ iÿÿ
dÿÿ nÿÿ
bÿÿ gÿÿ
_ÿÿ
ÿÿ
aÿÿ
ÿÿ
gent
ÿÿ
ÿÿ
rver
D-S> ÿÿ Sever...
ÿÿVÿÿ
ÿÿC id 526
ÿÿpÿÿ
ÿÿ vÿÿRÿÿscÿÿeÿÿ
ÿÿserved IVC id 528
Reserved IVC id 529
Reserved IVC id 530
ÿÿ1
Reserved IVC id 532
Reserved IVC id 533
Reserved IVC id 534
Reserved IVC id 535
Reserved IVC id 536
Reserved IVC id 537
Reserved IVC id 538
Reserved IVC id 539
ÿÿaMMFLAGS=1
Starting RM server
Start nvpm server
Done...
ÿÿNÿÿ\00
ÿÿnÿÿ\00
ÿÿoÿÿ\00
GPRÿÿtÿÿ\00s:
ÿÿiÿÿ\00
ÿÿ\000000 ÿÿoÿÿ\00
x6: 0x000ÿÿfÿÿ
ÿÿ\001
ÿÿEÿÿ\00
ÿÿoÿÿ\000x2100bbÿÿ
ÿÿ\002c
0xÿÿ
ÿÿ\0021003ÿÿ
ÿÿnÿÿ\00514
0x210ÿÿpÿÿ\000155ÿÿ
ÿÿ\000ÿÿdÿÿ\00
0x21000184
Sÿÿpÿÿ\00iÿÿ
ÿÿ\00:
0x1766ÿÿ:ÿÿ\000
0x18350
0x12ÿÿ[ÿÿ\00070
ÿÿbÿÿbÿÿ
ÿÿ
ÿÿaÿÿ
ÿÿ
ÿÿbÿÿ
ÿÿ
ÿÿDÿÿ
ÿÿ1ÿÿ
ÿÿ
ÿÿSÿÿ
ÿÿ
ÿÿCÿÿ ÿÿCÿÿ
ÿÿ
ÿÿ ÿÿdÿÿ
ÿÿ
ÿÿCÿÿeÿÿ ÿÿ
ÿÿCÿÿ
ÿÿ
ÿÿ ÿÿ
ÿÿiÿÿ
ÿÿPÿÿ
ÿÿDÿÿ
ÿÿ:210035b0 >
\00
[/code]0 4 foÿÿ:ÿÿ[code]
\00ÿâ
\00ÿýÿàmain enter
HW Function test
Start Scheduler.
in late init
ÿâ
I> bit @ 0xd480000
I> Unpowergate done
I> Loading TOS ...
I> Loading EKS ...
I> Unhalting RCE
ÿâ
welcome to lk
dt initialized
mail initialized
chipid initialized
fuse initialized
sku initialized
speedo initialized
ec initialized
vmon initialized
adc initialized
fmon initialized
reset initialized
nvhs initialized
clk initialized
io_dpd initialized
thermal initialized
i2c initialized
aotag initialized
dvs initialized
pm initialized
pg_late initialized
strap initialized
tag initialized
emc initialized
clk_dt initialized
pm_post initialized
tj_init initialized
uphy_dt initialized
uphy initialized
mrq initialized
dmce initialized
cvc initialized
Starting OS
rm initialized
wake initialized
mail_fs initialized
profile initialized
ÿÿNvGpcDmaLibInitÿÿ
iÿÿ:ÿÿ
vÿÿHÿÿ
cÿÿyÿÿ
_ÿÿpÿÿ
qÿÿeÿÿ
uÿÿrÿÿ
eÿÿvÿÿ
uÿÿiÿÿ
eÿÿsÿÿ
ÿÿoÿÿ
nÿÿrÿÿ
oÿÿ ÿÿ
dÿÿMÿÿ
eÿÿoÿÿ
ÿÿdÿÿ
nÿÿeÿÿ
oÿÿ
ÿÿ
tÿÿ
ÿÿ
present
rÿÿ tÿÿ
eÿÿ aÿÿ
sÿÿ rÿÿ
eÿÿ tÿÿ
nÿÿ iÿÿ
tÿÿ nÿÿ
ÿÿ gÿÿ
ÿÿ app i2c_server
starting aÿÿ
sÿÿ pÿÿ
tÿÿ pÿÿ
aÿÿ ÿÿ
rÿÿ bÿÿ
tÿÿ pÿÿ
iÿÿ mÿÿ
nÿÿ pÿÿ
gÿÿ _iÿÿ
ÿÿ nÿÿ
aÿÿ cÿÿ
pÿÿ oÿÿ
p ÿÿ mÿÿ
gÿÿ iÿÿ
dÿÿ nÿÿ
bÿÿ gÿÿ
_ÿÿ
ÿÿ
aÿÿ
ÿÿ
gent
ÿÿ
ÿÿ
rver
D-S> ÿÿ Sever...
ÿÿVÿÿ
ÿÿC id 526
ÿÿpÿÿ
ÿÿ vÿÿRÿÿscÿÿeÿÿ
ÿÿserved IVC id 528
Reserved IVC id 529
Reserved IVC id 530
ÿÿ1
Reserved IVC id 532
Reserved IVC id 533
Reserved IVC id 534
Reserved IVC id 535
Reserved IVC id 536
Reserved IVC id 537
Reserved IVC id 538
Reserved IVC id 539
ÿÿaMMFLAGS=1
Starting RM server
Start nvpm server
Done...
ÿÿNÿÿ\00
ÿÿnÿÿ\00
ÿÿoÿÿ\00
GPRÿÿtÿÿ\00s:
ÿÿiÿÿ\00
ÿÿ\000000 ÿÿoÿÿ\00
x6: 0x000ÿÿfÿÿ
ÿÿ\001
ÿÿEÿÿ\00
ÿÿoÿÿ\000x2100bbÿÿ
ÿÿ\002c
0xÿÿ
ÿÿ\0021003ÿÿ
ÿÿnÿÿ\00514
0x210ÿÿpÿÿ\000155ÿÿ
ÿÿ\000ÿÿdÿÿ\00
0x21000184
Sÿÿpÿÿ\00iÿÿ
ÿÿ\00:
0x1766ÿÿ:ÿÿ\000
0x18350
0x12ÿÿ[ÿÿ\00070
ÿÿbÿÿbÿÿ
ÿÿ
ÿÿaÿÿ
ÿÿ
ÿÿbÿÿ
ÿÿ
ÿÿDÿÿ
ÿÿ1ÿÿ
ÿÿ
ÿÿSÿÿ
ÿÿ
ÿÿCÿÿ ÿÿCÿÿ
ÿÿ
ÿÿ ÿÿdÿÿ
ÿÿ
ÿÿCÿÿeÿÿ ÿÿ
ÿÿCÿÿ
ÿÿ
ÿÿ ÿÿ
ÿÿiÿÿ
ÿÿPÿÿ
ÿÿDÿÿ
ÿÿ:210035b0 >
\00
[/code]0r read.ÿÿnÿÿ[code]
\00ÿâ
\00ÿýÿàmain enter
HW Function test
Start Scheduler.
in late init
ÿâ
I> bit @ 0xd480000
I> Unpowergate done
I> Loading TOS ...
I> Loading EKS ...
I> Unhalting RCE
ÿâ
welcome to lk
dt initialized
mail initialized
chipid initialized
fuse initialized
sku initialized
speedo initialized
ec initialized
vmon initialized
adc initialized
fmon initialized
reset initialized
nvhs initialized
clk initialized
io_dpd initialized
thermal initialized
i2c initialized
aotag initialized
dvs initialized
pm initialized
pg_late initialized
strap initialized
tag initialized
emc initialized
clk_dt initialized
pm_post initialized
tj_init initialized
uphy_dt initialized
uphy initialized
mrq initialized
dmce initialized
cvc initialized
Starting OS
rm initialized
wake initialized
mail_fs initialized
profile initialized
ÿÿNvGpcDmaLibInitÿÿ
iÿÿ:ÿÿ
vÿÿHÿÿ
cÿÿyÿÿ
_ÿÿpÿÿ
qÿÿeÿÿ
uÿÿrÿÿ
eÿÿvÿÿ
uÿÿiÿÿ
eÿÿsÿÿ
ÿÿoÿÿ
nÿÿrÿÿ
oÿÿ ÿÿ
dÿÿMÿÿ
eÿÿoÿÿ
ÿÿdÿÿ
nÿÿeÿÿ
oÿÿ
ÿÿ
tÿÿ
ÿÿ
present
rÿÿ tÿÿ
eÿÿ aÿÿ
sÿÿ rÿÿ
eÿÿ tÿÿ
nÿÿ iÿÿ
tÿÿ nÿÿ
ÿÿ gÿÿ
ÿÿ app i2c_server
starting aÿÿ
sÿÿ pÿÿ
tÿÿ pÿÿ
aÿÿ ÿÿ
rÿÿ bÿÿ
tÿÿ pÿÿ
iÿÿ mÿÿ
nÿÿ pÿÿ
gÿÿ _iÿÿ
ÿÿ nÿÿ
aÿÿ cÿÿ
pÿÿ oÿÿ
p ÿÿ mÿÿ
gÿÿ iÿÿ
dÿÿ nÿÿ
bÿÿ gÿÿ
_ÿÿ
ÿÿ
aÿÿ
ÿÿ
gent
ÿÿ
ÿÿ
rver
D-S> ÿÿ Sever...
ÿÿVÿÿ
ÿÿC id 526
ÿÿpÿÿ
ÿÿ vÿÿRÿÿscÿÿeÿÿ
ÿÿserved IVC id 528
Reserved IVC id 529
Reserved IVC id 530
ÿÿ1
Reserved IVC id 532
Reserved IVC id 533
Reserved IVC id 534
Reserved IVC id 535
Reserved IVC id 536
Reserved IVC id 537
Reserved IVC id 538
Reserved IVC id 539
ÿÿaMMFLAGS=1
Starting RM server
Start nvpm server
Done...
ÿÿNÿÿ\00
ÿÿnÿÿ\00
ÿÿoÿÿ\00
GPRÿÿtÿÿ\00s:
ÿÿiÿÿ\00
ÿÿ\000000 ÿÿoÿÿ\00
x6: 0x000ÿÿfÿÿ
ÿÿ\001
ÿÿEÿÿ\00
ÿÿoÿÿ\000x2100bbÿÿ
ÿÿ\002c
0xÿÿ
ÿÿ\0021003ÿÿ
ÿÿnÿÿ\00514
0x210ÿÿpÿÿ\000155ÿÿ
ÿÿ\000ÿÿdÿÿ\00
0x21000184
Sÿÿpÿÿ\00iÿÿ
ÿÿ\00:
0x1766ÿÿ:ÿÿ\000
0x18350
0x12ÿÿ[ÿÿ\00070
ÿÿbÿÿbÿÿ
ÿÿ
ÿÿaÿÿ
ÿÿ
ÿÿbÿÿ
ÿÿ
ÿÿDÿÿ
ÿÿ1ÿÿ
ÿÿ
ÿÿSÿÿ
ÿÿ
ÿÿCÿÿ ÿÿCÿÿ
ÿÿ
ÿÿ ÿÿdÿÿ
ÿÿ
ÿÿCÿÿeÿÿ ÿÿ
ÿÿCÿÿ
ÿÿ
ÿÿ ÿÿ
ÿÿiÿÿ
ÿÿPÿÿ
ÿÿDÿÿ
ÿÿ:210035b0 >
\00
[/code]0
Acceÿÿ5ÿÿ[code]
\00ÿâ
\00ÿýÿàmain enter
HW Function test
Start Scheduler.
in late init
ÿâ
I> bit @ 0xd480000
I> Unpowergate done
I> Loading TOS ...
I> Loading EKS ...
I> Unhalting RCE
ÿâ
welcome to lk
dt initialized
mail initialized
chipid initialized
fuse initialized
sku initialized
speedo initialized
ec initialized
vmon initialized
adc initialized
fmon initialized
reset initialized
nvhs initialized
clk initialized
io_dpd initialized
thermal initialized
i2c initialized
aotag initialized
dvs initialized
pm initialized
pg_late initialized
strap initialized
tag initialized
emc initialized
clk_dt initialized
pm_post initialized
tj_init initialized
uphy_dt initialized
uphy initialized
mrq initialized
dmce initialized
cvc initialized
Starting OS
rm initialized
wake initialized
mail_fs initialized
profile initialized
ÿÿNvGpcDmaLibInitÿÿ
iÿÿ:ÿÿ
vÿÿHÿÿ
cÿÿyÿÿ
_ÿÿpÿÿ
qÿÿeÿÿ
uÿÿrÿÿ
eÿÿvÿÿ
uÿÿiÿÿ
eÿÿsÿÿ
ÿÿoÿÿ
nÿÿrÿÿ
oÿÿ ÿÿ
dÿÿMÿÿ
eÿÿoÿÿ
ÿÿdÿÿ
nÿÿeÿÿ
oÿÿ
ÿÿ
tÿÿ
ÿÿ
present
rÿÿ tÿÿ
eÿÿ aÿÿ
sÿÿ rÿÿ
eÿÿ tÿÿ
nÿÿ iÿÿ
tÿÿ nÿÿ
ÿÿ gÿÿ
ÿÿ app i2c_server
starting aÿÿ
sÿÿ pÿÿ
tÿÿ pÿÿ
aÿÿ ÿÿ
rÿÿ bÿÿ
tÿÿ pÿÿ
iÿÿ mÿÿ
nÿÿ pÿÿ
gÿÿ _iÿÿ
ÿÿ nÿÿ
aÿÿ cÿÿ
pÿÿ oÿÿ
p ÿÿ mÿÿ
gÿÿ iÿÿ
dÿÿ nÿÿ
bÿÿ gÿÿ
_ÿÿ
ÿÿ
aÿÿ
ÿÿ
gent
ÿÿ
ÿÿ
rver
D-S> ÿÿ Sever...
ÿÿVÿÿ
ÿÿC id 526
ÿÿpÿÿ
ÿÿ vÿÿRÿÿscÿÿeÿÿ
ÿÿserved IVC id 528
Reserved IVC id 529
Reserved IVC id 530
ÿÿ1
Reserved IVC id 532
Reserved IVC id 533
Reserved IVC id 534
Reserved IVC id 535
Reserved IVC id 536
Reserved IVC id 537
Reserved IVC id 538
Reserved IVC id 539
ÿÿaMMFLAGS=1
Starting RM server
Start nvpm server
Done...
ÿÿNÿÿ\00
ÿÿnÿÿ\00
ÿÿoÿÿ\00
GPRÿÿtÿÿ\00s:
ÿÿiÿÿ\00
ÿÿ\000000 ÿÿoÿÿ\00
x6: 0x000ÿÿfÿÿ
ÿÿ\001
ÿÿEÿÿ\00
ÿÿoÿÿ\000x2100bbÿÿ
ÿÿ\002c
0xÿÿ
ÿÿ\0021003ÿÿ
ÿÿnÿÿ\00514
0x210ÿÿpÿÿ\000155ÿÿ
ÿÿ\000ÿÿdÿÿ\00
0x21000184
Sÿÿpÿÿ\00iÿÿ
ÿÿ\00:
0x1766ÿÿ:ÿÿ\000
0x18350
0x12ÿÿ[ÿÿ\00070
ÿÿbÿÿbÿÿ
ÿÿ
ÿÿaÿÿ
ÿÿ
ÿÿbÿÿ
ÿÿ
ÿÿDÿÿ
ÿÿ1ÿÿ
ÿÿ
ÿÿSÿÿ
ÿÿ
ÿÿCÿÿ ÿÿCÿÿ
ÿÿ
ÿÿ ÿÿdÿÿ
ÿÿ
ÿÿCÿÿeÿÿ ÿÿ
ÿÿCÿÿ
ÿÿ
ÿÿ ÿÿ
ÿÿiÿÿ
ÿÿPÿÿ
ÿÿDÿÿ
ÿÿ:210035b0 >
\00
[/code]0ss sÿÿ ÿÿfÿÿ[code]
\00ÿâ
\00ÿýÿàmain enter
HW Function test
Start Scheduler.
in late init
ÿâ
I> bit @ 0xd480000
I> Unpowergate done
I> Loading TOS ...
I> Loading EKS ...
I> Unhalting RCE
ÿâ
welcome to lk
dt initialized
mail initialized
chipid initialized
fuse initialized
sku initialized
speedo initialized
ec initialized
vmon initialized
adc initialized
fmon initialized
reset initialized
nvhs initialized
clk initialized
io_dpd initialized
thermal initialized
i2c initialized
aotag initialized
dvs initialized
pm initialized
pg_late initialized
strap initialized
tag initialized
emc initialized
clk_dt initialized
pm_post initialized
tj_init initialized
uphy_dt initialized
uphy initialized
mrq initialized
dmce initialized
cvc initialized
Starting OS
rm initialized
wake initialized
mail_fs initialized
profile initialized
ÿÿNvGpcDmaLibInitÿÿ
iÿÿ:ÿÿ
vÿÿHÿÿ
cÿÿyÿÿ
_ÿÿpÿÿ
qÿÿeÿÿ
uÿÿrÿÿ
eÿÿvÿÿ
uÿÿiÿÿ
eÿÿsÿÿ
ÿÿoÿÿ
nÿÿrÿÿ
oÿÿ ÿÿ
dÿÿMÿÿ
eÿÿoÿÿ
ÿÿdÿÿ
nÿÿeÿÿ
oÿÿ
ÿÿ
tÿÿ
ÿÿ
present
rÿÿ tÿÿ
eÿÿ aÿÿ
sÿÿ rÿÿ
eÿÿ tÿÿ
nÿÿ iÿÿ
tÿÿ nÿÿ
ÿÿ gÿÿ
ÿÿ app i2c_server
starting aÿÿ
sÿÿ pÿÿ
tÿÿ pÿÿ
aÿÿ ÿÿ
rÿÿ bÿÿ
tÿÿ pÿÿ
iÿÿ mÿÿ
nÿÿ pÿÿ
gÿÿ _iÿÿ
ÿÿ nÿÿ
aÿÿ cÿÿ
pÿÿ oÿÿ
p ÿÿ mÿÿ
gÿÿ iÿÿ
dÿÿ nÿÿ
bÿÿ gÿÿ
_ÿÿ
ÿÿ
aÿÿ
ÿÿ
gent
ÿÿ
ÿÿ
rver
D-S> ÿÿ Sever...
ÿÿVÿÿ
ÿÿC id 526
ÿÿpÿÿ
ÿÿ vÿÿRÿÿscÿÿeÿÿ
ÿÿserved IVC id 528
Reserved IVC id 529
Reserved IVC id 530
ÿÿ1
Reserved IVC id 532
Reserved IVC id 533
Reserved IVC id 534
Reserved IVC id 535
Reserved IVC id 536
Reserved IVC id 537
Reserved IVC id 538
Reserved IVC id 539
ÿÿaMMFLAGS=1
Starting RM server
Start nvpm server
Done...
ÿÿNÿÿ\00
ÿÿnÿÿ\00
ÿÿoÿÿ\00
GPRÿÿtÿÿ\00s:
ÿÿiÿÿ\00
ÿÿ\000000 ÿÿoÿÿ\00
x6: 0x000ÿÿfÿÿ
ÿÿ\001
ÿÿEÿÿ\00
ÿÿoÿÿ\000x2100bbÿÿ
ÿÿ\002c
0xÿÿ
ÿÿ\0021003ÿÿ
ÿÿnÿÿ\00514
0x210ÿÿpÿÿ\000155ÿÿ
ÿÿ\000ÿÿdÿÿ\00
0x21000184
Sÿÿpÿÿ\00iÿÿ
ÿÿ\00:
0x1766ÿÿ:ÿÿ\000
0x18350
0x12ÿÿ[ÿÿ\00070
ÿÿbÿÿbÿÿ
ÿÿ
ÿÿaÿÿ
ÿÿ
ÿÿbÿÿ
ÿÿ
ÿÿDÿÿ
ÿÿ1ÿÿ
ÿÿ
ÿÿSÿÿ
ÿÿ
ÿÿCÿÿ ÿÿCÿÿ
ÿÿ
ÿÿ ÿÿdÿÿ
ÿÿ
ÿÿCÿÿeÿÿ ÿÿ
ÿÿCÿÿ
ÿÿ
ÿÿ ÿÿ
ÿÿiÿÿ
ÿÿPÿÿ
ÿÿDÿÿ
ÿÿ:210035b0 >
\00
[/code]0izeÿÿ9ÿÿ[code]
\00ÿâ
\00ÿýÿàmain enter
HW Function test
Start Scheduler.
in late init
ÿâ
I> bit @ 0xd480000
I> Unpowergate done
I> Loading TOS ...
I> Loading EKS ...
I> Unhalting RCE
ÿâ
welcome to lk
dt initialized
mail initialized
chipid initialized
fuse initialized
sku initialized
speedo initialized
ec initialized
vmon initialized
adc initialized
fmon initialized
reset initialized
nvhs initialized
clk initialized
io_dpd initialized
thermal initialized
i2c initialized
aotag initialized
dvs initialized
pm initialized
pg_late initialized
strap initialized
tag initialized
emc initialized
clk_dt initialized
pm_post initialized
tj_init initialized
uphy_dt initialized
uphy initialized
mrq initialized
dmce initialized
cvc initialized
Starting OS
rm initialized
wake initialized
mail_fs initialized
profile initialized
ÿÿNvGpcDmaLibInitÿÿ
iÿÿ:ÿÿ
vÿÿHÿÿ
cÿÿyÿÿ
_ÿÿpÿÿ
qÿÿeÿÿ
uÿÿrÿÿ
eÿÿvÿÿ
uÿÿiÿÿ
eÿÿsÿÿ
ÿÿoÿÿ
nÿÿrÿÿ
oÿÿ ÿÿ
dÿÿMÿÿ
eÿÿoÿÿ
ÿÿdÿÿ
nÿÿeÿÿ
oÿÿ
ÿÿ
tÿÿ
ÿÿ
present
rÿÿ tÿÿ
eÿÿ aÿÿ
sÿÿ rÿÿ
eÿÿ tÿÿ
nÿÿ iÿÿ
tÿÿ nÿÿ
ÿÿ gÿÿ
ÿÿ app i2c_server
starting aÿÿ
sÿÿ pÿÿ
tÿÿ pÿÿ
aÿÿ ÿÿ
rÿÿ bÿÿ
tÿÿ pÿÿ
iÿÿ mÿÿ
nÿÿ pÿÿ
gÿÿ _iÿÿ
ÿÿ nÿÿ
aÿÿ cÿÿ
pÿÿ oÿÿ
p ÿÿ mÿÿ
gÿÿ iÿÿ
dÿÿ nÿÿ
bÿÿ gÿÿ
_ÿÿ
ÿÿ
aÿÿ
ÿÿ
gent
ÿÿ
ÿÿ
rver
D-S> ÿÿ Sever...
ÿÿVÿÿ
ÿÿC id 526
ÿÿpÿÿ
ÿÿ vÿÿRÿÿscÿÿeÿÿ
ÿÿserved IVC id 528
Reserved IVC id 529
Reserved IVC id 530
ÿÿ1
Reserved IVC id 532
Reserved IVC id 533
Reserved IVC id 534
Reserved IVC id 535
Reserved IVC id 536
Reserved IVC id 537
Reserved IVC id 538
Reserved IVC id 539
ÿÿaMMFLAGS=1
Starting RM server
Start nvpm server
Done...
ÿÿNÿÿ\00
ÿÿnÿÿ\00
ÿÿoÿÿ\00
GPRÿÿtÿÿ\00s:
ÿÿiÿÿ\00
ÿÿ\000000 ÿÿoÿÿ\00
x6: 0x000ÿÿfÿÿ
ÿÿ\001
ÿÿEÿÿ\00
ÿÿoÿÿ\000x2100bbÿÿ
ÿÿ\002c
0xÿÿ
ÿÿ\0021003ÿÿ
ÿÿnÿÿ\00514
0x210ÿÿpÿÿ\000155ÿÿ
ÿÿ\000ÿÿdÿÿ\00
0x21000184
Sÿÿpÿÿ\00iÿÿ
ÿÿ\00:
0x1766ÿÿ:ÿÿ\000
0x18350
0x12ÿÿ[ÿÿ\00070
ÿÿbÿÿbÿÿ
ÿÿ
ÿÿaÿÿ
ÿÿ
ÿÿbÿÿ
ÿÿ
ÿÿDÿÿ
ÿÿ1ÿÿ
ÿÿ
ÿÿSÿÿ
ÿÿ
ÿÿCÿÿ ÿÿCÿÿ
ÿÿ
ÿÿ ÿÿdÿÿ
ÿÿ
ÿÿCÿÿeÿÿ ÿÿ
ÿÿCÿÿ
ÿÿ
ÿÿ ÿÿ
ÿÿiÿÿ
ÿÿPÿÿ
ÿÿDÿÿ
ÿÿ:210035b0 >
\00
[/code]0: 0x4
Fault ÿÿNÿÿ[code]
\00ÿâ
\00ÿýÿàmain enter
HW Function test
Start Scheduler.
in late init
ÿâ
I> bit @ 0xd480000
I> Unpowergate done
I> Loading TOS ...
I> Loading EKS ...
I> Unhalting RCE
ÿâ
welcome to lk
dt initialized
mail initialized
chipid initialized
fuse initialized
sku initialized
speedo initialized
ec initialized
vmon initialized
adc initialized
fmon initialized
reset initialized
nvhs initialized
clk initialized
io_dpd initialized
thermal initialized
i2c initialized
aotag initialized
dvs initialized
pm initialized
pg_late initialized
strap initialized
tag initialized
emc initialized
clk_dt initialized
pm_post initialized
tj_init initialized
uphy_dt initialized
uphy initialized
mrq initialized
dmce initialized
cvc initialized
Starting OS
rm initialized
wake initialized
mail_fs initialized
profile initialized
ÿÿNvGpcDmaLibInitÿÿ
iÿÿ:ÿÿ
vÿÿHÿÿ
cÿÿyÿÿ
_ÿÿpÿÿ
qÿÿeÿÿ
uÿÿrÿÿ
eÿÿvÿÿ
uÿÿiÿÿ
eÿÿsÿÿ
ÿÿoÿÿ
nÿÿrÿÿ
oÿÿ ÿÿ
dÿÿMÿÿ
eÿÿoÿÿ
ÿÿdÿÿ
nÿÿeÿÿ
oÿÿ
ÿÿ
tÿÿ
ÿÿ
present
rÿÿ tÿÿ
eÿÿ aÿÿ
sÿÿ rÿÿ
eÿÿ tÿÿ
nÿÿ iÿÿ
tÿÿ nÿÿ
ÿÿ gÿÿ
ÿÿ app i2c_server
starting aÿÿ
sÿÿ pÿÿ
tÿÿ pÿÿ
aÿÿ ÿÿ
rÿÿ bÿÿ
tÿÿ pÿÿ
iÿÿ mÿÿ
nÿÿ pÿÿ
gÿÿ _iÿÿ
ÿÿ nÿÿ
aÿÿ cÿÿ
pÿÿ oÿÿ
p ÿÿ mÿÿ
gÿÿ iÿÿ
dÿÿ nÿÿ
bÿÿ gÿÿ
_ÿÿ
ÿÿ
aÿÿ
ÿÿ
gent
ÿÿ
ÿÿ
rver
D-S> ÿÿ Sever...
ÿÿVÿÿ
ÿÿC id 526
ÿÿpÿÿ
ÿÿ vÿÿRÿÿscÿÿeÿÿ
ÿÿserved IVC id 528
Reserved IVC id 529
Reserved IVC id 530
ÿÿ1
Reserved IVC id 532
Reserved IVC id 533
Reserved IVC id 534
Reserved IVC id 535
Reserved IVC id 536
Reserved IVC id 537
Reserved IVC id 538
Reserved IVC id 539
ÿÿaMMFLAGS=1
Starting RM server
Start nvpm server
Done...
ÿÿNÿÿ\00
ÿÿnÿÿ\00
ÿÿoÿÿ\00
GPRÿÿtÿÿ\00s:
ÿÿiÿÿ\00
ÿÿ\000000 ÿÿoÿÿ\00
x6: 0x000ÿÿfÿÿ
ÿÿ\001
ÿÿEÿÿ\00
ÿÿoÿÿ\000x2100bbÿÿ
ÿÿ\002c
0xÿÿ
ÿÿ\0021003ÿÿ
ÿÿnÿÿ\00514
0x210ÿÿpÿÿ\000155ÿÿ
ÿÿ\000ÿÿdÿÿ\00
0x21000184
Sÿÿpÿÿ\00iÿÿ
ÿÿ\00:
0x1766ÿÿ:ÿÿ\000
0x18350
0x12ÿÿ[ÿÿ\00070
ÿÿbÿÿbÿÿ
ÿÿ
ÿÿaÿÿ
ÿÿ
ÿÿbÿÿ
ÿÿ
ÿÿDÿÿ
ÿÿ1ÿÿ
ÿÿ
ÿÿSÿÿ
ÿÿ
ÿÿCÿÿ ÿÿCÿÿ
ÿÿ
ÿÿ ÿÿdÿÿ
ÿÿ
ÿÿCÿÿeÿÿ ÿÿ
ÿÿCÿÿ
ÿÿ
ÿÿ ÿÿ
ÿÿiÿÿ
ÿÿPÿÿ
ÿÿDÿÿ
ÿÿ:210035b0 >
\00
[/code]0Iÿÿoÿÿ[code]
\00ÿâ
\00ÿýÿàmain enter
HW Function test
Start Scheduler.
in late init
ÿâ
I> bit @ 0xd480000
I> Unpowergate done
I> Loading TOS ...
I> Loading EKS ...
I> Unhalting RCE
ÿâ
welcome to lk
dt initialized
mail initialized
chipid initialized
fuse initialized
sku initialized
speedo initialized
ec initialized
vmon initialized
adc initialized
fmon initialized
reset initialized
nvhs initialized
clk initialized
io_dpd initialized
thermal initialized
i2c initialized
aotag initialized
dvs initialized
pm initialized
pg_late initialized
strap initialized
tag initialized
emc initialized
clk_dt initialized
pm_post initialized
tj_init initialized
uphy_dt initialized
uphy initialized
mrq initialized
dmce initialized
cvc initialized
Starting OS
rm initialized
wake initialized
mail_fs initialized
profile initialized
ÿÿNvGpcDmaLibInitÿÿ
iÿÿ:ÿÿ
vÿÿHÿÿ
cÿÿyÿÿ
_ÿÿpÿÿ
qÿÿeÿÿ
uÿÿrÿÿ
eÿÿvÿÿ
uÿÿiÿÿ
eÿÿsÿÿ
ÿÿoÿÿ
nÿÿrÿÿ
oÿÿ ÿÿ
dÿÿMÿÿ
eÿÿoÿÿ
ÿÿdÿÿ
nÿÿeÿÿ
oÿÿ
ÿÿ
tÿÿ
ÿÿ
present
rÿÿ tÿÿ
eÿÿ aÿÿ
sÿÿ rÿÿ
eÿÿ tÿÿ
nÿÿ iÿÿ
tÿÿ nÿÿ
ÿÿ gÿÿ
ÿÿ app i2c_server
starting aÿÿ
sÿÿ pÿÿ
tÿÿ pÿÿ
aÿÿ ÿÿ
rÿÿ bÿÿ
tÿÿ pÿÿ
iÿÿ mÿÿ
nÿÿ pÿÿ
gÿÿ _iÿÿ
ÿÿ nÿÿ
aÿÿ cÿÿ
pÿÿ oÿÿ
p ÿÿ mÿÿ
gÿÿ iÿÿ
dÿÿ nÿÿ
bÿÿ gÿÿ
_ÿÿ
ÿÿ
aÿÿ
ÿÿ
gent
ÿÿ
ÿÿ
rver
D-S> ÿÿ Sever...
ÿÿVÿÿ
ÿÿC id 526
ÿÿpÿÿ
ÿÿ vÿÿRÿÿscÿÿeÿÿ
ÿÿserved IVC id 528
Reserved IVC id 529
Reserved IVC id 530
ÿÿ1
Reserved IVC id 532
Reserved IVC id 533
Reserved IVC id 534
Reserved IVC id 535
Reserved IVC id 536
Reserved IVC id 537
Reserved IVC id 538
Reserved IVC id 539
ÿÿaMMFLAGS=1
Starting RM server
Start nvpm server
Done...
ÿÿNÿÿ\00
ÿÿnÿÿ\00
ÿÿoÿÿ\00
GPRÿÿtÿÿ\00s:
ÿÿiÿÿ\00
ÿÿ\000000 ÿÿoÿÿ\00
x6: 0x000ÿÿfÿÿ
ÿÿ\001
ÿÿEÿÿ\00
ÿÿoÿÿ\000x2100bbÿÿ
ÿÿ\002c
0xÿÿ
ÿÿ\0021003ÿÿ
ÿÿnÿÿ\00514
0x210ÿÿpÿÿ\000155ÿÿ
ÿÿ\000ÿÿdÿÿ\00
0x21000184
Sÿÿpÿÿ\00iÿÿ
ÿÿ\00:
0x1766ÿÿ:ÿÿ\000
0x18350
0x12ÿÿ[ÿÿ\00070
ÿÿbÿÿbÿÿ
ÿÿ
ÿÿaÿÿ
ÿÿ
ÿÿbÿÿ
ÿÿ
ÿÿDÿÿ
ÿÿ1ÿÿ
ÿÿ
ÿÿSÿÿ
ÿÿ
ÿÿCÿÿ ÿÿCÿÿ
ÿÿ
ÿÿ ÿÿdÿÿ
ÿÿ
ÿÿCÿÿeÿÿ ÿÿ
ÿÿCÿÿ
ÿÿ
ÿÿ ÿÿ
ÿÿiÿÿ
ÿÿPÿÿ
ÿÿDÿÿ
ÿÿ:210035b0 >
\00
[/code]0PA: 0ÿÿ ÿÿ[code]
\00ÿâ
\00ÿýÿàmain enter
HW Function test
Start Scheduler.
in late init
ÿâ
I> bit @ 0xd480000
I> Unpowergate done
I> Loading TOS ...
I> Loading EKS ...
I> Unhalting RCE
ÿâ
welcome to lk
dt initialized
mail initialized
chipid initialized
fuse initialized
sku initialized
speedo initialized
ec initialized
vmon initialized
adc initialized
fmon initialized
reset initialized
nvhs initialized
clk initialized
io_dpd initialized
thermal initialized
i2c initialized
aotag initialized
dvs initialized
pm initialized
pg_late initialized
strap initialized
tag initialized
emc initialized
clk_dt initialized
pm_post initialized
tj_init initialized
uphy_dt initialized
uphy initialized
mrq initialized
dmce initialized
cvc initialized
Starting OS
rm initialized
wake initialized
mail_fs initialized
profile initialized
ÿÿNvGpcDmaLibInitÿÿ
iÿÿ:ÿÿ
vÿÿHÿÿ
cÿÿyÿÿ
_ÿÿpÿÿ
qÿÿeÿÿ
uÿÿrÿÿ
eÿÿvÿÿ
uÿÿiÿÿ
eÿÿsÿÿ
ÿÿoÿÿ
nÿÿrÿÿ
oÿÿ ÿÿ
dÿÿMÿÿ
eÿÿoÿÿ
ÿÿdÿÿ
nÿÿeÿÿ
oÿÿ
ÿÿ
tÿÿ
ÿÿ
present
rÿÿ tÿÿ
eÿÿ aÿÿ
sÿÿ rÿÿ
eÿÿ tÿÿ
nÿÿ iÿÿ
tÿÿ nÿÿ
ÿÿ gÿÿ
ÿÿ app i2c_server
starting aÿÿ
sÿÿ pÿÿ
tÿÿ pÿÿ
aÿÿ ÿÿ
rÿÿ bÿÿ
tÿÿ pÿÿ
iÿÿ mÿÿ
nÿÿ pÿÿ
gÿÿ _iÿÿ
ÿÿ nÿÿ
aÿÿ cÿÿ
pÿÿ oÿÿ
p ÿÿ mÿÿ
gÿÿ iÿÿ
dÿÿ nÿÿ
bÿÿ gÿÿ
_ÿÿ
ÿÿ
aÿÿ
ÿÿ
gent
ÿÿ
ÿÿ
rver
D-S> ÿÿ Sever...
ÿÿVÿÿ
ÿÿC id 526
ÿÿpÿÿ
ÿÿ vÿÿRÿÿscÿÿeÿÿ
ÿÿserved IVC id 528
Reserved IVC id 529
Reserved IVC id 530
ÿÿ1
Reserved IVC id 532
Reserved IVC id 533
Reserved IVC id 534
Reserved IVC id 535
Reserved IVC id 536
Reserved IVC id 537
Reserved IVC id 538
Reserved IVC id 539
ÿÿaMMFLAGS=1
Starting RM server
Start nvpm server
Done...
ÿÿNÿÿ\00
ÿÿnÿÿ\00
ÿÿoÿÿ\00
GPRÿÿtÿÿ\00s:
ÿÿiÿÿ\00
ÿÿ\000000 ÿÿoÿÿ\00
x6: 0x000ÿÿfÿÿ
ÿÿ\001
ÿÿEÿÿ\00
ÿÿoÿÿ\000x2100bbÿÿ
ÿÿ\002c
0xÿÿ
ÿÿ\0021003ÿÿ
ÿÿnÿÿ\00514
0x210ÿÿpÿÿ\000155ÿÿ
ÿÿ\000ÿÿdÿÿ\00
0x21000184
Sÿÿpÿÿ\00iÿÿ
ÿÿ\00:
0x1766ÿÿ:ÿÿ\000
0x18350
0x12ÿÿ[ÿÿ\00070
ÿÿbÿÿbÿÿ
ÿÿ
ÿÿaÿÿ
ÿÿ
ÿÿbÿÿ
ÿÿ
ÿÿDÿÿ
ÿÿ1ÿÿ
ÿÿ
ÿÿSÿÿ
ÿÿ
ÿÿCÿÿ ÿÿCÿÿ
ÿÿ
ÿÿ ÿÿdÿÿ
ÿÿ
ÿÿCÿÿeÿÿ ÿÿ
ÿÿCÿÿ
ÿÿ
ÿÿ ÿÿ
ÿÿiÿÿ
ÿÿPÿÿ
ÿÿDÿÿ
ÿÿ:210035b0 >
\00
[/code]0x32700ÿÿvÿÿ[code]
\00ÿâ
\00ÿýÿàmain enter
HW Function test
Start Scheduler.
in late init
ÿâ
I> bit @ 0xd480000
I> Unpowergate done
I> Loading TOS ...
I> Loading EKS ...
I> Unhalting RCE
ÿâ
welcome to lk
dt initialized
mail initialized
chipid initialized
fuse initialized
sku initialized
speedo initialized
ec initialized
vmon initialized
adc initialized
fmon initialized
reset initialized
nvhs initialized
clk initialized
io_dpd initialized
thermal initialized
i2c initialized
aotag initialized
dvs initialized
pm initialized
pg_late initialized
strap initialized
tag initialized
emc initialized
clk_dt initialized
pm_post initialized
tj_init initialized
uphy_dt initialized
uphy initialized
mrq initialized
dmce initialized
cvc initialized
Starting OS
rm initialized
wake initialized
mail_fs initialized
profile initialized
ÿÿNvGpcDmaLibInitÿÿ
iÿÿ:ÿÿ
vÿÿHÿÿ
cÿÿyÿÿ
_ÿÿpÿÿ
qÿÿeÿÿ
uÿÿrÿÿ
eÿÿvÿÿ
uÿÿiÿÿ
eÿÿsÿÿ
ÿÿoÿÿ
nÿÿrÿÿ
oÿÿ ÿÿ
dÿÿMÿÿ
eÿÿoÿÿ
ÿÿdÿÿ
nÿÿeÿÿ
oÿÿ
ÿÿ
tÿÿ
ÿÿ
present
rÿÿ tÿÿ
eÿÿ aÿÿ
sÿÿ rÿÿ
eÿÿ tÿÿ
nÿÿ iÿÿ
tÿÿ nÿÿ
ÿÿ gÿÿ
ÿÿ app i2c_server
starting aÿÿ
sÿÿ pÿÿ
tÿÿ pÿÿ
aÿÿ ÿÿ
rÿÿ bÿÿ
tÿÿ pÿÿ
iÿÿ mÿÿ
nÿÿ pÿÿ
gÿÿ _iÿÿ
ÿÿ nÿÿ
aÿÿ cÿÿ
pÿÿ oÿÿ
p ÿÿ mÿÿ
gÿÿ iÿÿ
dÿÿ nÿÿ
bÿÿ gÿÿ
_ÿÿ
ÿÿ
aÿÿ
ÿÿ
gent
ÿÿ
ÿÿ
rver
D-S> ÿÿ Sever...
ÿÿVÿÿ
ÿÿC id 526
ÿÿpÿÿ
ÿÿ vÿÿRÿÿscÿÿeÿÿ
ÿÿserved IVC id 528
Reserved IVC id 529
Reserved IVC id 530
ÿÿ1
Reserved IVC id 532
Reserved IVC id 533
Reserved IVC id 534
Reserved IVC id 535
Reserved IVC id 536
Reserved IVC id 537
Reserved IVC id 538
Reserved IVC id 539
ÿÿaMMFLAGS=1
Starting RM server
Start nvpm server
Done...
ÿÿNÿÿ\00
ÿÿnÿÿ\00
ÿÿoÿÿ\00
GPRÿÿtÿÿ\00s:
ÿÿiÿÿ\00
ÿÿ\000000 ÿÿoÿÿ\00
x6: 0x000ÿÿfÿÿ
ÿÿ\001
ÿÿEÿÿ\00
ÿÿoÿÿ\000x2100bbÿÿ
ÿÿ\002c
0xÿÿ
ÿÿ\0021003ÿÿ
ÿÿnÿÿ\00514
0x210ÿÿpÿÿ\000155ÿÿ
ÿÿ\000ÿÿdÿÿ\00
0x21000184
Sÿÿpÿÿ\00iÿÿ
ÿÿ\00:
0x1766ÿÿ:ÿÿ\000
0x18350
0x12ÿÿ[ÿÿ\00070
ÿÿbÿÿbÿÿ
ÿÿ
ÿÿaÿÿ
ÿÿ
ÿÿbÿÿ
ÿÿ
ÿÿDÿÿ
ÿÿ1ÿÿ
ÿÿ
ÿÿSÿÿ
ÿÿ
ÿÿCÿÿ ÿÿCÿÿ
ÿÿ
ÿÿ ÿÿdÿÿ
ÿÿ
ÿÿCÿÿeÿÿ ÿÿ
ÿÿCÿÿ
ÿÿ
ÿÿ ÿÿ
ÿÿiÿÿ
ÿÿPÿÿ
ÿÿDÿÿ
ÿÿ:210035b0 >
\00
[/code]000ÿÿ:ÿÿ[code]
\00ÿâ
[0000.024] I> MISCREG_HIDREV_0: 0x21917
[0000.028] I> MB1 (prd-version: 00.22.180704-t194-39702425-7fcf5198)
[0000.034] I> Boot-mode: L0 coldboot
[0000.037] I> chip revision : A02
[0000.040] I> Bootrom patch version : 3 (correctly patched)
[0000.045] I> ATE fuse revision : 0x200
[0000.049] I> Ram repair fuse : 0x0
[0000.052] I> rst_source : 0x0
[0000.054] I> rst_level : 0x0
[0000.057] E> Last boot error: 0x00000000
[0000.061] I> Soft fuse initialized
[0000.064] I> Boot WARS Applied
[0000.067] I> Boot-device: QSPI
[0000.070] I> qspi flash params source = brbct
[0000.074] I> Qspi using bpmp-dma
[0000.077] I> Qspi clock source : pllp
[0000.080] I> QSPI Flash: Spansion 64MB
[0000.084] I> QSPI Flash Size = 64 MB
[0000.089] I> QSPI Flash: Set 512B page size
[0000.093] I> Qspi initialized successfully
[0000.097] I> Loading MB1-BCT to SysRAM
[0000.100] I> Boot-device: QSPI
[0000.103] I> Binary@ device:3/0 block-1536 (partition size: 0x20000)
[0000.109] I> qspi flash params source = brbct
[0000.114] I> Binary mb1bct loaded successfully at 0x40000000
[0000.120] I> MB1-BCT relocated to 0xd48bc00 from 0x40000000
[0000.125] I> Loading MEM-BCT to SysRAM
[0000.128] I> Binary@ device:3/0 block-2048 (partition size: 0x40000)
[0000.134] I> qspi flash params source = mb1bct
[0000.138] I> Qspi using bpmp-dma
[0000.141] I> Qspi clock source : pllp
[0000.145] I> Qspi reinitialized
[0000.149] I> Binary membct loaded successfully at 0x40000000
[0000.155] I> SDRAM params relocated to 0xd493400 from 0x40000000
[0000.160] I> SDRAM pack relocated to 0xd495c00 from 0x40000000
[0000.166] E> No fuse-bypass data
[0000.171] I> temperature = 31500
[0000.174] W> Skipping boost for clk:aon_cpu_nic
[0000.178] W> Skipping boost for clk:aon_can0
[0000.182] W> Skipping boost for clk:aon_can1
[0000.186] E> MB1_PLATFORM_CONFIG: prod table is empty in MB1 BCT.
[0000.192] I> Boot-device: QSPI
[0000.195] I> Boot-device: QSPI
[0000.198] I> qspi flash params source = mb1bct
[0000.202] I> Binary@ device:3/0 block-2560 (partition size: 0x40000)
[0000.208] I> qspi flash params source = mb1bct
[0000.214] I> Binary spe-fw loaded successfully at 0x40000000
[0000.221] I> ECC region[0]: Start:0x0, End:0x0
[0000.226] I> ECC region[1]: Start:0x0, End:0x0
[0000.230] I> ECC region[2]: Start:0x0, End:0x0
[0000.234] I> ECC region[3]: Start:0x0, End:0x0
[0000.238] I> ECC region[4]: Start:0x0, End:0x0
[0000.242] I> ECC region[5]: Start:0x0, End:0x0
[0000.246] I> Non-ECC region[0]: Start:0x80000000, End:0x100000000
[0000.252] I> Non-ECC region[1]: Start:0x0, End:0x0
[0000.256] I> Non-ECC region[2]: Start:0x0, End:0x0
[0000.261] I> Non-ECC region[3]: Start:0x0, End:0x0
[0000.265] I> Non-ECC region[4]: Start:0x0, End:0x0
[0000.269] I> Non-ECC region[5]: Start:0x0, End:0x0
[0000.274] I> Added Block:1 Start:0x80000000 End:0x100000000
[0000.280] I> allocated(CO:32) base:0xf8000000 size:0x8000000 align: 0x8000000
[0000.287] I> allocated(CO:33) base:0xf0000000 size:0x8000000 align: 0x100000
[0000.294] I> allocated(CO:38) base:0x80000000 size:0x8000000 align: 0x200000
[0000.301] I> allocated(CO:39) base:0x88000000 size:0x8000000 align: 0x8000000
[0000.307] I> allocated(CO:36) base:0x95a00000 size:0x4000000 align: 0x200000
[0000.314] I> allocated(CO:24) base:0xee000000 size:0x2000000 align: 0x2000000
[0000.321] I> allocated(CO:28) base:0xecc00000 size:0x1400000 align: 0x200000
[0000.327] I> allocated(CO:34) base:0xebc00000 size:0x1000000 align: 0x0
[0000.334] I> allocated(CO:35) base:0x90000000 size:0x1000000 align: 0x1000000
[0000.340] I> allocated(CO:7) base:0xeb000000 size:0x800000 align: 0x800000
[0000.347] I> allocated(CO:10) base:0xea800000 size:0x800000 align: 0x800000
[0000.353] I> allocated(CO:37) base:0xea000000 size:0x800000 align: 0x800000
[0000.360] I> allocated(CO:19) base:0xe9a00000 size:0x600000 align: 0x200000
[0000.366] I> allocated(CO:6) base:0xeb800000 size:0x400000 align: 0x200000
[0000.373] I> allocated(CO:27) base:0xe9600000 size:0x400000 align: 0x200000
[0000.380] I> allocated(CO:29) base:0xe9200000 size:0x400000 align: 0x200000
[0000.386] I> allocated(CO:1) base:0xe9100000 size:0x100000 align: 0x100000
[0000.393] I> allocated(CO:2) base:0xe9000000 size:0x100000 align: 0x100000
[0000.399] I> allocated(CO:3) base:0xe8f00000 size:0x100000 align: 0x100000
[0000.406] I> allocated(CO:4) base:0xe8e00000 size:0x100000 align: 0x100000
[0000.412] I> allocated(CO:5) base:0xe8d00000 size:0x100000 align: 0x100000
[0000.419] I> allocated(CO:8) base:0xe8c00000 size:0x100000 align: 0x100000
[0000.425] I> allocated(CO:9) base:0xe8b00000 size:0x100000 align: 0x100000
[0000.431] I> allocated(CO:12) base:0xe8a00000 size:0x100000 align: 0x100000
[0000.438] I> allocated(CO:17) base:0xe8900000 size:0x100000 align: 0x100000
[0000.445] I> allocated(CO:21) base:0xe88f0000 size:0x10000 align: 0x0
[0000.451] > MB1_PLATFORM_CONFIG: Rail ID 9 not found in pmic rail config table.
[0000.458] E> FAILED: Thermal config
[0000.465] > MB1_PLATFORM_CONFIG: Rail ID 7 not found in pmic rail config table.
[0000.472] E> FAILED: MEMIO rail config
[0000.475] I> MSS code-drop: NvBootSdramInit
[0000.492] I> scrub mode: full dram
[0000.495] E> Error: ECID of check failed!!
[0000.499] E> MB1 BCT does not have SCR table
[0000.503] I> Binary@ device:3/0 block-4608 (partition size: 0x40000)
[0000.509] I> qspi flash params source = mb1bct
[0000.523] I> RSA PSS signature check: OK
[0000.527] I> Binary preboot loaded successfully at 0x40000040
[0000.534] I> Restrict GSC#31 access to DPMU only
[0000.538] I> WP-0 triggered
[0000.540] I> WP-0 ACK received :)
[0000.544] I> CPU reset vector: 0x40000000
[0000.547] I> MTS carveout BOM: 0xff000000
[0000.551] I> MC_MTS_CARVEOUT_SIZE_MB_0: 0x10
[0000.555] I> Loading MCE
[0000.557] I> Binary@ device:3/0 block-5120 (partition size: 0x80000)
[0000.563] I> qspi flash params source = mb1bct
[0000.578] I> RSA PSS signature check: OK
[0000.585] I> Binary MCE loaded successfully at 0xbf080000
[0000.594] I> Loading MTS
[0000.596] I> Binary@ device:3/0 block-6144 (partition size: 0x400000)
[0000.602] I> qspi flash params source = mb1bct
[0000.661] I> Binary MTS loaded successfully at 0xbfa00000
[0000.678] I> WP-1 triggered
[0000.683] I> WP-1 ACK received :)
[0000.686] I> MTS carveout BOM: 0xf8000000
[0000.690] I> WP1.5 triggered
[0000.693] I> WP1.5 ACK received :)
[0000.696] E> MB1_PLATFORM_CONFIG: Bootrom mmio i2c table is empty in MB1 BCT.
[0000.703] I> Loading MB2
[0000.705] I> Binary@ device:3/0 block-3072 (partition size: 0x40000)
[0000.711] I> qspi flash params source = mb1bct
[0000.718] I> Binary mb2 loaded successfully at 0x52000000
[0000.723] I> co:0 offset:0x70000000
[0000.726] I> MB2-params @ 0x70000000
[0000.730] I> co:4 offset:0x70010000
[0000.733] I> co:1 offset:0x70020000
[0000.737] I> CO:(35) safe offset:0x53000000
[0000.741] I> CO:(37) safe offset:0x70030000
[0000.745] > MB1_PLATFORM_CONFIG: Rail ID 8 not found in pmic rail config table.
[0000.752] I> MB1 done
\00ÿýÿàmain enter
SPE VERSION #: R01.00.07 Created: Mar 21 2018 @ 15:14:19
HW Function test
Start Scheduler.
in late init
ÿâ
I> Welcome to MB2(TBoot-BPMP)
I> mb2 Safe end :0x52700000 mb2 safe start :0x52032044
I> co:0 offset:0x52700000
I> DMA Heap @ [0x52700000 - 0x53000000]
I> Default Heap @ [0xd486400 - 0xd488400]
I> qspi flash-0 params source = boot args
I> bit @ 0xd480000
I> Found 20 partitions in 00030000 device
I> co:8 offset:0x70030000
I> GR Blob not found or corrupted. Skipping GR Dump for MB1 Stage
I> Binary@ device:3/0 block-20480 (partition size: 0x100000)
I> header load address is : 0x5202fdf0
I> header of binary bpmp-fw read from storage device 3(0)
I> oem authentication of bpmp-fw header done
I> component list is filled with contents from header
I> parsing oem signed section of bpmp-fw header done
I> updated handle with bpmp-fw info. from oem comp table
I> bpmp-fw binary read from storage
I> Binary@ device:3/0 block-22528 (partition size: 0x100000)
I> header of binary bpmp-fw-dtb read from storage device 3(0)
I> oem authentication of bpmp-fw-dtb header done
I> parsing oem signed section of bpmp-fw-dtb header done
I> updated handle with bpmp-fw-dtb info. from oem comp table
I> bpmp-fw-dtb binary read from storage
I> BPMP-FW load address = 0x50000000
I> BPMP-FW DTB load address = 0x503e43a0
I> Loading SCE-FW ...
I> Binary@ device:3/0 block-24576 (partition size: 0x80000)
I> header of binary sce read from storage device 3(0)
I> oem authentication of sce header done
I> parsing oem signed section of sce header done
I> updated handle with sce info. from oem comp table
I> sce binary read from storage
I> Loading RCE-FW ...
I> Binary@ device:3/0 block-25600 (partition size: 0x80000)
I> header of binary rce read from storage device 3(0)
I> oem authentication of rce header done
I> parsing oem signed section of rce header done
I> updated handle with rce info. from oem comp table
I> rce binary read from storage
I> Unpowergating APE
I> Unpowergate done
I> Loading APE-FW ...
I> Binary@ device:3/0 block-26624 (partition size: 0x200000)
I> header of binary ape read from storage device 3(0)
I> oem authentication of ape header done
I> parsing oem signed section of ape header done
I> updated handle with ape info. from oem comp table
I> ape binary read from storage
I> Copy BTCM section
I> Binary@ device:3/0 block-14336 (partition size: 0x80000)
I> header of binary cpubl read from storage device 3(0)
I> oem authentication of cpubl header done
I> parsing oem signed section of cpubl header done
I> updated handle with cpubl info. from oem comp table
I> cpubl binary read from storage
I> co:4 offset:0x70040000
I> CPUBL-params @ 0x70040000
I> co:5 offset:0x70050000
I> Relocating BR-BCT
I> co:6 offset:0x70060000
I> BRBCT @ 0x40066c00
I> BR-BCT relocated to 0x70060000
I> CPU-BL loaded at : 0x96000000
I> Loading TOS ...
I> Binary@ device:3/0 block-15360 (partition size: 0x280000)
I> header of binary tos read from storage device 3(0)
I> oem authentication of tos header done
I> parsing oem signed section of tos header done
I> updated handle with tos info. from oem comp table
I> tos binary read from storage
I> TOS params:@0x52d02410
I> TLK boot-params @ 0x52d02410
I> TLK params prepared
I> Loading EKS ...
I> Binary@ device:3/0 block-30720 (partition size: 0x40000)
I> header of binary eks read from storage device 3(0)
I> oem authentication of eks header done
I> parsing oem signed section of eks header done
I> updated handle with eks info. from oem comp table
I> eks binary read from storage
I> EKS (length: 0x5000) @ 0x52d07800
I> Copied encrypted keys
I> Copying Monitor (length: 0x17170) from 0x52702600 to 0x40000000
I> Erasing Monitor @ 0x52702600
I> tos-params: tzdram_size: 0x1000000
I> tos-params: tzdram_base: 0xebc00000
I> tos-params: uart_port_id: 254
I> Copying TOS (length: 0x13e1d0) from 0x52719770 to 0xabc40000
I> Waypoint2-ACK: 0x52014d64
I> SCR config list empty
I> Unhalting RCE
I> GR Blob not found or corrupted. Skipping GR Dump for MB2 Stage
ÿäNOTICE: BL31: v1.3(release):934cbe7
NOTICE: BL31: Built : 10:49:22, Sep 4 2018
ÿâ
welcome to lk
ÿäÿâbpmp: platform_init
dt initialized
mail initialized
chipid initialized
fuse initialized
sku initialized
speedo initialized
ec initialized
vmon_populate_monitors: found 1 monitors
vmon initialized
vmon_soc_self_check: vmon_vsoc: self-check passed
adc initialized
fmon_populate_monitors: found 73 monitors
vrefro_re_cal: VrefRO: adjusted 0x82=>0x86
fmon_soc_ops_init: re-start disabled FMON_OSCnFUSE_CK
fmon_soc_ops_init: re-start disabled FMON_PMC_CK
fmon initialized
reset initialized
nvhs initialized
warning: pllp_vic do not permit 'allow_fractional_divider' property
warning: pllp_vic do not permit 'allowed-parents' property
warning: mphy_core_pll_fixed do not permit 'allowed-parents' property
warning: ufsdev_ref do not permit 'allowed-parents' property
warning: slvsec do not permit 'allowed-parents' property
warning: pllp_aon do not permit 'allow_fractional_divider' property
warning: pllp_aon do not permit 'allowed-parents' property
warning: mphy_tx_1mhz_ref do not permit 'allowed-parents' property
warning: sdmmc4 do not permit 'allow_fractional_divider' property
warning: eqos_tx do not permit 'allowed-parents' property
386 clocks registered
clk_mrq_init: mrq handler registered
clk initialized
io_dpd initialized
thermal initialized
ti2c_dt_parse: error fetching tlow
ti2c_dt_parse: error fetching thigh
i2c5 controller initialized
initialized i2c mrq handling
i2c initialized
WARNING: at platform/drivers/regulator/regulator-dt.c:126
regulator_parse_dt: regulator-ramp-delay is deprecated. Use regulator-ramp-delay-linear instead.
regulator initialized
avfs_clk_platform initialized
soctherm initialized
aotag initialized
powergate initialized
dvs initialized
pm initialized
pg_late initialized
strap initialized
tag initialized
emc initialized
WARNING: at platform/drivers/vfmon/fmon.c:456
invalid clock 307 rate 0
invalid clock 113 rate 0
fmon_enable: FMON_NVLINK_SYS: s/w DC fault is detected
invalid clock 118 rate 0
warning: i2c2 do not permit parent clk_m
warning: i2c8 do not permit parent clk_m
clk_update_possible_parents: clk_m not in allowed parent table for sdmmc4
warning: sor0_out do not permit parent pll_d
warning: sor0_out do not permit parent pll_dp
clk_update_possible_parents: sor_safe not in allowed parent table for sor0_out
warning: sor1_out do not permit parent pll_d2
warning: sor1_out do not permit parent pll_dp
clk_update_possible_parents: sor_safe not in allowed parent table for sor1_out
warning: sor2_out do not permit parent pll_d3
warning: sor2_out do not permit parent pll_dp
clk_update_possible_parents: sor_safe not in allowed parent table for sor2_out
warning: sor3_out do not permit parent pll_d4
warning: sor3_out do not permit parent pll_dp
clk_update_possible_parents: sor_safe not in allowed parent table for sor3_out
clk_dt initialized
avfs_ccplex_platform initialized
pm_post initialized
tj_max: dt node not found
tj_init initialized
uphy_mrq_init: mrq handler registered
uphy_dt initialized
uphy initialized
mrq initialized
clk_dt_late initialized
carveout 6: size check failed (0x20)
AST0 misconfig for DRAM: slave 0x050000001 master 0x0eb800000 mask 0x3ff000 control 0x80001
AST1 misconfig for DRAM: slave 0x050000001 master 0x0eb800000 mask 0x3ff000 control 0x80001
machine_check initialized
fmon_post initialized
tag is fce7e7e850bd06c123a330c57f701fca
tag_lateinit initialized
avfs_clk_platform_post initialized
dmce initialized
cvc initialized
ÿãCombined UART initialized
Starting OS
ÿâavfs_clk_mach_post initialized
ÿãInitialization done!
ÿâgboost_init initialized
aotag_hsm initialized
regulator_post initialized
rm initialized
sc7_diag initialized
thermal_test initialized
serial_late initialized
clk_post initialized
clk_dt_post initialized
wake initialized
sku_debugfs initialized
speedo_debugfs initialized
adc_debugfs initialized
clk_debugfs initialized
emc_debugfs initialized
ÿáqb:[E]: Partition not found ramdisk
qb:[E]: Error PartitionNotExist (0x30018)
ÿâdvs_debugfs initialized
ÿáqb:[E]: Partition not found kernel-dtb
ÿâfmon_debugfs initialized
vmon_debugfs initialized
pg_debugfs initialized
profile_fs initialized
debugfs_cons initialized
mail_fs initialized
profile initialized
cvc_debugfs initialized
dmce_debugfs initialized
ec_debugfs initialized
soctherm_debug initialized
debugfs_mrq initialized
ÿáÿÿýÿÿþÿâstarting app shell
entering main console loop
] ÿáDRIVE Hypervisor
ÿÿNvGpcDmaLibInitÿÿ
iÿÿ:ÿÿ
vÿÿHÿÿ
cÿÿyÿÿ
_ÿÿpÿÿ
qÿÿeÿÿ
uÿÿrÿÿ
eÿÿvÿÿ
uÿÿiÿÿ
eÿÿsÿÿ
ÿÿoÿÿ
nÿÿrÿÿ
oÿÿ ÿÿ
dÿÿMÿÿ
eÿÿoÿÿ
ÿÿdÿÿ
nÿÿeÿÿ
oÿÿ
ÿÿ
tÿÿ
ÿÿ
present
ivc_queue node not present
ivc_queue node not pÿÿ sÿÿ
rÿÿ tÿÿ
eÿÿ aÿÿ
sÿÿ rÿÿ
eÿÿ tÿÿ
nÿÿ iÿÿ
tÿÿ nÿÿ
ÿÿ gÿÿ
ÿÿ app i2c_server
starting aÿÿ
sÿÿ pÿÿ
tÿÿ pÿÿ
aÿÿ ÿÿ
rÿÿ bÿÿ
tÿÿ pÿÿ
iÿÿ mÿÿ
nÿÿ pÿÿ
gÿÿ _iÿÿ
ÿÿ nÿÿ
aÿÿ cÿÿ
pÿÿ oÿÿ
p ÿÿ mÿÿ
gÿÿ iÿÿ
dÿÿ nÿÿ
bÿÿ gÿÿ
_ÿÿ
ÿÿ
aÿÿ
ÿÿ
gent
ÿÿvirt/servers/servers/apps/thermal/cooling_devs/cdev_balanced_throttle.c: cpufreq-virt_init failed
Registered governor: pid_thermal_govmax20024: No regulator node found in pmc node
ÿÿ
starting app debug_seÿÿstarting app bpmp_ping
starting app thermal
trip_update_worker: Failed to get current temperature for zone 1
starting app bpmp_server
starting app cpÿÿSÿÿufÿÿtÿÿreÿÿaÿÿq_ÿÿrÿÿhvÿÿtÿÿ
ÿÿing TrustZoneÿÿstarting app bpmp_incoming
trip_update_worker: Failed to get current temperature for zone 7
ÿÿ
rver
D-S> ÿÿ Sever...
ÿÿevent logginÿÿRÿÿgÿÿeÿÿ nÿÿsÿÿotÿÿeÿÿ ÿÿrÿÿavÿÿvÿÿaiÿÿeÿÿlaÿÿdÿÿbÿÿ ÿÿleÿÿIÿÿ
ÿÿVÿÿ
ÿÿC id 526
Reserved IVC iÿÿstÿÿdÿÿaÿÿ ÿÿrtÿÿ5ÿÿinÿÿ2ÿÿgÿÿ7ÿÿ apÿÿ
ÿÿpÿÿ
ÿÿ vÿÿRÿÿscÿÿeÿÿ
ÿÿserved IVC id 528
Reserved IVC id 529
Reserved IVC id 530
Resÿÿsÿÿeÿÿtaÿÿrÿÿrtÿÿvÿÿinÿÿeÿÿgÿÿdÿÿ aÿÿ ÿÿppÿÿIÿÿ ÿÿVÿÿbpÿÿCÿÿmpÿÿ ÿÿ_ÿÿiÿÿinÿÿdÿÿcoÿÿ ÿÿmiÿÿ5ÿÿngÿÿ3ÿÿ
ÿÿ1
Reserved IVC id 532
Reserved IVC id 533
Reserved IVC id 534
Reserved IVC id 535
Reserved IVC id 536
Reserved IVC id 537
Reserved IVC id 538
Reserved IVC id 539
ÿástarting app tz_server
ÿÿaMMFLAGS=1
Starting RM server
Start nvpm server
Setting BOARD_SHUTDOWN_DLL to /proc/boot/libnvshutdown.so if not set already
Done...
ÿÿstarting app se_server
ÿÿpl:[Eÿÿþ 2628418|HV/c4: ÿÿÿÿþGAC : GID 0 unhandled access of size 4 for Read operation on trap address 3270000 with err 0!
ÿÿ]:ÿÿpÿÿÿÿþ 2630931|HV/c4: ÿÿÿÿþGAC : GID 0 unhandled access of size 4 for Read operation on trap address 0 with err 0!
ÿÿ ÿÿlÿÿNÿÿ:ÿÿvÿÿ[ÿÿGÿÿEÿÿuÿÿ]:ÿÿeÿÿ ÿÿsÿÿNvÿÿtÿÿGÿÿFÿÿuÿÿiÿÿeÿÿnÿÿsÿÿdÿÿtÿÿBÿÿFÿÿoÿÿiÿÿoÿÿnÿÿtÿÿdÿÿDÿÿBÿÿeÿÿoÿÿvÿÿoÿÿiÿÿtÿÿcÿÿDÿÿeÿÿpÿÿÿäplatform_guest_warm_boot: guest warm reboot
ÿáÿäplatform_guest_warm_boot: guest warm reboot
ÿáeÿÿIÿÿlÿÿvÿÿnÿÿ:ÿÿiÿÿfÿÿ[ÿÿ\00
ÿÿcÿÿ\00GID 0:ÿÿoÿÿ\00 UnÿÿEÿÿ\00hanÿÿeÿÿ\00dled acÿÿ:ÿÿ\00cesÿÿ]ÿÿ\00s oÿÿIÿÿ\00f sizeÿÿ1ÿÿ\00 4 foÿÿ:ÿÿ\00r read.ÿÿnÿÿ\00
Acceÿÿ5ÿÿ\00ss sÿÿ ÿÿfÿÿ\00izeÿÿ9ÿÿ\00: 0x4
Fault ÿÿNÿÿ\00Iÿÿoÿÿ\00PA: 0ÿÿ ÿÿ\00x32700ÿÿvÿÿ\0000ÿÿ:ÿÿ\00
ESR_EL2ÿÿNÿÿ\00: 0x9382ÿÿGÿÿ\000ÿÿ1ÿÿ\00007
ÿÿoÿÿ\00Fatal VMÿÿuÿÿ\00 ÿÿ5ÿÿ\00Fault: ÿÿ ÿÿ\00Faileÿÿeÿÿ\00d ÿÿ9ÿÿ\00to haÿÿBÿÿ\00ndlÿÿsÿÿ\00e dÿÿ ÿÿ\00ata aÿÿoÿÿ\00borÿÿtÿÿ\00t!
ÿÿNÿÿ\00
VM Stÿÿoÿÿ\00atÿÿFÿÿ\00e:
Vÿÿoÿÿ\00CPU ID: 0xÿÿtÿÿiÿÿ\000
PC:ÿÿ ÿÿ\00 0x21009750ÿÿ ÿÿ\00
ÿÿnÿÿ\00
SPSR_ELÿÿBÿÿ\002: 0x800003cÿÿDÿÿdÿÿ\005
FAR_ELÿÿoÿÿ\002: 0x327ÿÿeÿÿBÿÿ\000000
Sÿÿoÿÿ\00PSR_EL1: 0xÿÿvÿÿ\000
ÿÿoÿÿ\00
GPRÿÿtÿÿ\00s:
x0: ÿÿiÿÿ\000ÿÿoÿÿ\00x000000ÿÿ ÿÿ\000085a46cÿÿcÿÿ\004ÿÿtÿÿ\000 x1:ÿÿDÿÿ\00 0x0ÿÿDÿÿ\000ÿÿeÿÿ\00000ÿÿeÿÿ\0000085e89cÿÿeÿÿ ÿÿ\0038 xÿÿvÿÿ\002: 0x00000ÿÿfÿÿvÿÿ\0000000ÿÿiÿÿ\00000000
ÿÿiÿÿ\00
xÿÿoÿÿ\003: ÿÿcÿÿÿäplatform_guest_warm_boot: guest warm reboot
ÿá\000x00000ÿÿcÿÿ\0000ÿÿuÿÿ\0000327ÿÿeÿÿ\000000 x4: 0xÿÿeÿÿ\000ÿÿnÿÿ\0000000ÿÿ ÿÿ\000085e89e58 x5ÿÿIÿÿdÿÿ\00: 0x00ÿÿfÿÿ\00000000000ÿÿnÿÿ\000ÿÿ
ÿÿ\000000 ÿÿoÿÿ\00
x6: 0x000ÿÿfÿÿ
ÿÿ\00000ÿÿuÿÿ\000000000001 ÿÿoÿÿ\00x7:ÿÿpÿÿnÿÿ\00 0x0000000ÿÿ:ÿÿ\0000000ÿÿlÿÿdÿÿ\000001 x8: ÿÿ1ÿÿ\000x0ÿÿ
ÿÿ:ÿÿ\00000000000ÿÿ5ÿÿ\000000ÿÿ[ÿÿ\000ÿÿ
ÿÿ\001
x9: 0x00ÿÿ9ÿÿ\000000ÿÿEÿÿ\0000ÿÿpÿÿ\0000000004 x10: 0x0ÿÿ]ÿÿ\000ÿÿlÿÿ\0000000000000022 xÿÿ:ÿÿ\0011:ÿÿ:ÿÿ\00 ÿÿ[ÿÿ\000x0000000085a42698
ÿÿEÿÿ\00
x12: 0x000ÿÿ ÿÿ\00000000000ÿÿ]ÿÿ\000000 x13: 0x0ÿÿQÿÿ\000000ÿÿ:ÿÿ\000ÿÿbÿÿ\000000000018ÿÿ ÿÿ\00 x14: 0x0000ÿÿQÿÿ\000ÿÿDÿÿ\0000000000001ÿÿbÿÿ\00
x15: ÿÿaÿÿ\000x00ÿÿDÿÿ\000ÿÿtÿÿ\0000000000000ÿÿaÿÿ\0000 x16: 0x0000000000000ÿÿtÿÿ\0006ÿÿaÿÿ\000 x17: 0x00000000ÿÿaÿÿ\0000000ÿÿDÿÿ\00080
x18: 0x00000ÿÿDÿÿ\000008ÿÿrÿÿ\005e80000 xÿÿ ÿÿ\0019: 0x0000ÿÿrÿÿ\0000ÿÿiÿÿ\000085a46aaÿÿNÿÿ\000 x20:ÿÿiÿÿ\00 0x00ÿÿvÿÿ\00000000ÿÿoÿÿ\0000000000
ÿÿvÿÿ\00x21ÿÿeÿÿ\00: 0x0000ÿÿ ÿÿ\00000085a46c40ÿÿeÿÿ\00 ÿÿnÿÿ\00x22: 0xÿÿBÿÿ\0000000000ÿÿnÿÿ\0000ÿÿIÿÿ\0000000ÿÿoÿÿ\000 x23: 0x000000ÿÿnÿÿ\00008ÿÿIÿÿ\005a46ÿÿoÿÿ\00ac8
x24: 0x0000ÿÿiÿÿ\000ÿÿnÿÿ\00000ÿÿtÿÿ\00ffffffff x25ÿÿtÿÿiÿÿ\00: ÿÿ ÿÿ\000x0000000085a46ÿÿ(ÿÿ\00c3ÿÿtÿÿ\008ÿÿDÿÿ\00 x26: 0x0000ÿÿ)ÿÿ\000000ÿÿ(ÿÿ\0085ÿÿeÿÿ\00a46ac0
x27: 0x0ÿÿ ÿÿ\0000ÿÿ)ÿÿ\000000ÿÿvÿÿ\00085a46ac8 ÿÿfÿÿ\00x28:ÿÿ ÿÿ\00 0ÿÿiÿÿ\00x000000000000ÿÿaÿÿ\0000ÿÿfÿÿ\0002 xÿÿcÿÿ\0029: 0x000000ÿÿiÿÿ\0000ÿÿaÿÿ\0085e7eÿÿeÿÿ\00db0
x30: 0x00ÿÿlÿÿ\0000ÿÿiÿÿ\00000021ÿÿ ÿÿ\00009dd8
Vÿÿeÿÿ\00M ÿÿlÿÿ\00Stackÿÿfÿÿ\00 Trace:
0x21009ÿÿdÿÿ\00dd8ÿÿeÿÿ\00
ÿÿoÿÿ\000x2100bbÿÿ
ÿÿ\002c
ÿÿdÿÿuÿÿ\000x21002fb0
0xÿÿ
ÿÿ\0021003ÿÿ
ÿÿnÿÿ\00514
0x210ÿÿpÿÿ\000155ÿÿ
ÿÿ\000ÿÿdÿÿ\00
0x21000184
Sÿÿpÿÿ\00iÿÿ
ÿÿ\00dÿÿlÿÿ\00ekick Stack Tracÿÿlÿÿ\00eÿÿ
ÿÿ\00:
0x1766ÿÿ:ÿÿ\000
0x18350
ÿÿ:ÿÿ\000xÿÿpÿÿ\00183e8
0x12ÿÿ[ÿÿ\00070
ÿÿ[ÿÿlÿÿEÿÿEÿÿ:ÿÿ]ÿÿ]ÿÿ[ÿÿ:ÿÿ:ÿÿEÿÿ ÿÿ ÿÿ]ÿÿBÿÿ:ÿÿBÿÿUÿÿ ÿÿUÿÿGÿÿQÿÿGÿÿ ÿÿbÿÿ ÿÿdÿÿDÿÿdÿÿaÿÿaÿÿaÿÿtÿÿtÿÿtÿÿaÿÿaÿÿaÿÿDÿÿ_ÿÿ_ÿÿrÿÿdÿÿdÿÿiÿÿrÿÿrÿÿvÿÿiÿÿiÿÿeÿÿvÿÿvÿÿnÿÿeÿÿeÿÿIÿÿnÿÿnÿÿnÿÿ_ÿÿ_ÿÿiÿÿdÿÿdÿÿtÿÿtÿÿtÿÿ(ÿÿ.ÿÿ.ÿÿ)ÿÿcÿÿcÿÿ ÿÿ:ÿÿ:ÿÿfÿÿ9ÿÿ9ÿÿaÿÿ2ÿÿ2ÿÿiÿÿ2ÿÿ2ÿÿlÿÿ ÿÿ ÿÿeÿÿ(ÿÿ(ÿÿdÿÿQÿÿQÿÿ
ÿÿbÿÿbÿÿ
ÿÿDÿÿDÿÿpÿÿaÿÿaÿÿlÿÿtÿÿtÿÿ:ÿÿaÿÿaÿÿ[ÿÿDÿÿDÿÿEÿÿrÿÿrÿÿ]ÿÿiÿÿiÿÿ:ÿÿvÿÿvÿÿ ÿÿeÿÿeÿÿBÿÿnÿÿnÿÿUÿÿIÿÿIÿÿGÿÿnÿÿnÿÿ ÿÿiÿÿiÿÿdÿÿtÿÿtÿÿaÿÿ)ÿÿ)ÿÿtÿÿ
ÿÿ
ÿÿaÿÿ
ÿÿ
ÿÿ_ÿÿpÿÿpÿÿdÿÿlÿÿlÿÿrÿÿ:ÿÿ:ÿÿiÿÿ[ÿÿ[ÿÿvÿÿEÿÿEÿÿeÿÿ]ÿÿ]ÿÿnÿÿ:ÿÿ:ÿÿ_ÿÿ ÿÿ ÿÿdÿÿSÿÿSÿÿtÿÿtÿÿtÿÿ.ÿÿaÿÿaÿÿcÿÿcÿÿcÿÿ:ÿÿkÿÿkÿÿ9ÿÿ ÿÿ ÿÿ2ÿÿtÿÿtÿÿrÿÿrÿÿaÿÿ2ÿÿaÿÿcÿÿ ÿÿcÿÿeÿÿ(ÿÿeÿÿ:ÿÿQÿÿ:ÿÿ
ÿÿbÿÿ
ÿÿ
ÿÿDÿÿ
ÿÿaÿÿpÿÿpÿÿtÿÿlÿÿlÿÿaÿÿ:ÿÿ:ÿÿDÿÿ[ÿÿ[ÿÿrÿÿEÿÿE]ÿÿ]ÿÿiÿÿ:ÿÿ:ÿÿvÿÿ ÿÿ ÿÿeÿÿ<ÿÿ<ÿÿnÿÿ ÿÿ ÿÿIÿÿPÿÿPÿÿnÿÿCÿÿCÿÿiÿÿ ÿÿ ÿÿtÿÿ:ÿÿ:ÿÿ)ÿÿ2ÿÿ2ÿÿ
ÿÿ1ÿÿ
ÿÿ1ÿÿ0ÿÿ0ÿÿpÿÿ0ÿÿ0ÿÿlÿÿ3ÿÿ3ÿÿ:ÿÿ5ÿÿ5ÿÿ[ÿÿbÿÿbÿÿEÿÿ0ÿÿ0ÿÿ]ÿÿ ÿÿ ÿÿ:ÿÿ>ÿÿ>ÿÿ ÿÿ
ÿÿ
ÿÿSÿÿ
ÿÿ
ÿÿtÿÿpÿÿpÿÿaÿÿlÿÿlÿÿcÿÿ:ÿÿpÿÿ:ÿÿkÿÿ[ÿÿlÿÿ[ÿÿ ÿÿEÿÿEÿÿtÿÿ:ÿÿ]ÿÿ]ÿÿrÿÿ[ÿÿ:ÿÿ:ÿÿaÿÿEÿÿ ÿÿ ÿÿcÿÿ<ÿÿ]ÿÿ<ÿÿeÿÿ ÿÿ ÿÿ:ÿÿPÿÿ:ÿÿPÿÿ
ÿÿCÿÿ ÿÿCÿÿ
ÿÿ ÿÿNÿÿ ÿÿpÿÿ:ÿÿ:ÿÿvÿÿlÿÿ2ÿÿ2ÿÿGÿÿ:ÿÿ1ÿÿ1ÿÿuÿÿ[ÿÿ0ÿÿ0ÿÿEÿÿeÿÿ0ÿÿ0ÿÿ]ÿÿ1ÿÿ1ÿÿ:ÿÿ5ÿÿsÿÿ5ÿÿ ÿÿ4ÿÿtÿÿ4ÿÿ<ÿÿcÿÿcÿÿFÿÿ ÿÿ ÿÿ ÿÿiÿÿPÿÿ>ÿÿ>ÿÿCÿÿnÿÿ
ÿÿ
ÿÿ ÿÿdÿÿ
ÿÿ
ÿÿ:ÿÿpÿÿ2ÿÿpÿÿlÿÿBÿÿlÿÿ1ÿÿ:ÿÿoÿÿ:ÿÿ0ÿÿ[ÿÿoÿÿ[ÿÿ0ÿÿEÿÿtÿÿEÿÿ3ÿÿ]ÿÿDÿÿ]ÿÿ5ÿÿ:ÿÿeÿÿ:ÿÿbÿÿ ÿÿvÿÿ ÿÿ0ÿÿ<ÿÿ<ÿÿ ÿÿ ÿÿ ÿÿiÿÿPÿÿ>ÿÿcÿÿPÿÿCÿÿ
ÿÿCÿÿeÿÿ ÿÿ
ÿÿ ÿÿIÿÿ:ÿÿpÿÿ:ÿÿnÿÿ2ÿÿlÿÿ2ÿÿfÿÿ:ÿÿ1ÿÿ1ÿÿ0ÿÿ[ÿÿ0ÿÿoÿÿEÿÿ0ÿÿ0ÿÿ0ÿÿ:ÿÿ]ÿÿ0ÿÿ1ÿÿ:ÿÿ1ÿÿ1ÿÿ8ÿÿ ÿÿ5ÿÿ8ÿÿ0ÿÿ<ÿÿ9ÿÿ0ÿÿ ÿÿ ÿÿ ÿÿ ÿÿ>ÿÿPÿÿNÿÿ>ÿÿ
ÿÿCÿÿ
ÿÿ
ÿÿ ÿÿ
ÿÿoÿÿ:ÿÿ ÿÿ2ÿÿBÿÿ1ÿÿoÿÿ00ÿÿoÿÿ1ÿÿtÿÿ5ÿÿ ÿÿ4cÿÿDÿÿ ÿÿeÿÿ>ÿÿvÿÿ
ÿÿiÿÿ
ÿÿcÿÿpÿÿeÿÿlÿÿ ÿÿ:[ÿÿfÿÿE]ÿÿoÿÿ:ÿÿuÿÿ ÿÿnÿÿ<ÿÿdÿÿ ÿÿ
ÿÿPÿÿ
ÿÿCÿÿpÿÿ :ÿÿlÿÿ21ÿÿ:ÿÿ0ÿÿ[ÿÿ0ÿÿEÿÿ0ÿÿ]ÿÿ1ÿÿ:ÿÿ8ÿÿ ÿÿ0 ÿÿQÿÿ>ÿÿbÿÿ
ÿÿDÿÿ
ÿÿataDrivenInit() failed
pl:[E]: BUG data_driven_dt.c:922 (QbDataDrivenInit)
pl:[E]: Stack trace:
pÿÿpl:[E]: NvGuestFindBootDeviceInfo:159 No Boot Device found
pl:[E]: QbDataDrivenInit() failed
pl:[E]: < PC ÿÿl:[E]: < PC :210035b0 >
pl:[E]: < PC :2100154c >
pl:[E]: < PC :21000180 >
ÿÿ:210035b0 >
ÿãHSM ERROR 244, CRITICAL_ERR_NVL_CAR
\00
[/code]0
ESR_EL2ÿÿNÿÿ[code]
\00ÿâ
\00ÿýÿàmain enter
HW Function test
Start Scheduler.
in late init
ÿâ
I> bit @ 0xd480000
I> Unpowergate done
I> Loading TOS ...
I> Loading EKS ...
I> Unhalting RCE
ÿâ
welcome to lk
dt initialized
mail initialized
chipid initialized
fuse initialized
sku initialized
speedo initialized
ec initialized
vmon initialized
adc initialized
fmon initialized
reset initialized
nvhs initialized
clk initialized
io_dpd initialized
thermal initialized
i2c initialized
aotag initialized
dvs initialized
pm initialized
pg_late initialized
strap initialized
tag initialized
emc initialized
clk_dt initialized
pm_post initialized
tj_init initialized
uphy_dt initialized
uphy initialized
mrq initialized
dmce initialized
cvc initialized
Starting OS
rm initialized
wake initialized
mail_fs initialized
profile initialized
ÿÿNvGpcDmaLibInitÿÿ
iÿÿ:ÿÿ
vÿÿHÿÿ
cÿÿyÿÿ
_ÿÿpÿÿ
qÿÿeÿÿ
uÿÿrÿÿ
eÿÿvÿÿ
uÿÿiÿÿ
eÿÿsÿÿ
ÿÿoÿÿ
nÿÿrÿÿ
oÿÿ ÿÿ
dÿÿMÿÿ
eÿÿoÿÿ
ÿÿdÿÿ
nÿÿeÿÿ
oÿÿ
ÿÿ
tÿÿ
ÿÿ
present
rÿÿ tÿÿ
eÿÿ aÿÿ
sÿÿ rÿÿ
eÿÿ tÿÿ
nÿÿ iÿÿ
tÿÿ nÿÿ
ÿÿ gÿÿ
ÿÿ app i2c_server
starting aÿÿ
sÿÿ pÿÿ
tÿÿ pÿÿ
aÿÿ ÿÿ
rÿÿ bÿÿ
tÿÿ pÿÿ
iÿÿ mÿÿ
nÿÿ pÿÿ
gÿÿ _iÿÿ
ÿÿ nÿÿ
aÿÿ cÿÿ
pÿÿ oÿÿ
p ÿÿ mÿÿ
gÿÿ iÿÿ
dÿÿ nÿÿ
bÿÿ gÿÿ
_ÿÿ
ÿÿ
aÿÿ
ÿÿ
gent
ÿÿ
ÿÿ
rver
D-S> ÿÿ Sever...
ÿÿVÿÿ
ÿÿC id 526
ÿÿpÿÿ
ÿÿ vÿÿRÿÿscÿÿeÿÿ
ÿÿserved IVC id 528
Reserved IVC id 529
Reserved IVC id 530
ÿÿ1
Reserved IVC id 532
Reserved IVC id 533
Reserved IVC id 534
Reserved IVC id 535
Reserved IVC id 536
Reserved IVC id 537
Reserved IVC id 538
Reserved IVC id 539
ÿÿaMMFLAGS=1
Starting RM server
Start nvpm server
Done...
ÿÿNÿÿ\00
ÿÿnÿÿ\00
ÿÿoÿÿ\00
GPRÿÿtÿÿ\00s:
ÿÿiÿÿ\00
ÿÿ\000000 ÿÿoÿÿ\00
x6: 0x000ÿÿfÿÿ
ÿÿ\001
ÿÿEÿÿ\00
ÿÿoÿÿ\000x2100bbÿÿ
ÿÿ\002c
0xÿÿ
ÿÿ\0021003ÿÿ
ÿÿnÿÿ\00514
0x210ÿÿpÿÿ\000155ÿÿ
ÿÿ\000ÿÿdÿÿ\00
0x21000184
Sÿÿpÿÿ\00iÿÿ
ÿÿ\00:
0x1766ÿÿ:ÿÿ\000
0x18350
0x12ÿÿ[ÿÿ\00070
ÿÿbÿÿbÿÿ
ÿÿ
ÿÿaÿÿ
ÿÿ
ÿÿbÿÿ
ÿÿ
ÿÿDÿÿ
ÿÿ1ÿÿ
ÿÿ
ÿÿSÿÿ
ÿÿ
ÿÿCÿÿ ÿÿCÿÿ
ÿÿ
ÿÿ ÿÿdÿÿ
ÿÿ
ÿÿCÿÿeÿÿ ÿÿ
ÿÿCÿÿ
ÿÿ
ÿÿ ÿÿ
ÿÿiÿÿ
ÿÿPÿÿ
ÿÿDÿÿ
ÿÿ:210035b0 >
\00
[/code]0: 0x9382ÿÿGÿÿ[code]
\00ÿâ
\00ÿýÿàmain enter
HW Function test
Start Scheduler.
in late init
ÿâ
I> bit @ 0xd480000
I> Unpowergate done
I> Loading TOS ...
I> Loading EKS ...
I> Unhalting RCE
ÿâ
welcome to lk
dt initialized
mail initialized
chipid initialized
fuse initialized
sku initialized
speedo initialized
ec initialized
vmon initialized
adc initialized
fmon initialized
reset initialized
nvhs initialized
clk initialized
io_dpd initialized
thermal initialized
i2c initialized
aotag initialized
dvs initialized
pm initialized
pg_late initialized
strap initialized
tag initialized
emc initialized
clk_dt initialized
pm_post initialized
tj_init initialized
uphy_dt initialized
uphy initialized
mrq initialized
dmce initialized
cvc initialized
Starting OS
rm initialized
wake initialized
mail_fs initialized
profile initialized
ÿÿNvGpcDmaLibInitÿÿ
iÿÿ:ÿÿ
vÿÿHÿÿ
cÿÿyÿÿ
_ÿÿpÿÿ
qÿÿeÿÿ
uÿÿrÿÿ
eÿÿvÿÿ
uÿÿiÿÿ
eÿÿsÿÿ
ÿÿoÿÿ
nÿÿrÿÿ
oÿÿ ÿÿ
dÿÿMÿÿ
eÿÿoÿÿ
ÿÿdÿÿ
nÿÿeÿÿ
oÿÿ
ÿÿ
tÿÿ
ÿÿ
present
rÿÿ tÿÿ
eÿÿ aÿÿ
sÿÿ rÿÿ
eÿÿ tÿÿ
nÿÿ iÿÿ
tÿÿ nÿÿ
ÿÿ gÿÿ
ÿÿ app i2c_server
starting aÿÿ
sÿÿ pÿÿ
tÿÿ pÿÿ
aÿÿ ÿÿ
rÿÿ bÿÿ
tÿÿ pÿÿ
iÿÿ mÿÿ
nÿÿ pÿÿ
gÿÿ _iÿÿ
ÿÿ nÿÿ
aÿÿ cÿÿ
pÿÿ oÿÿ
p ÿÿ mÿÿ
gÿÿ iÿÿ
dÿÿ nÿÿ
bÿÿ gÿÿ
_ÿÿ
ÿÿ
aÿÿ
ÿÿ
gent
ÿÿ
ÿÿ
rver
D-S> ÿÿ Sever...
ÿÿVÿÿ
ÿÿC id 526
ÿÿpÿÿ
ÿÿ vÿÿRÿÿscÿÿeÿÿ
ÿÿserved IVC id 528
Reserved IVC id 529
Reserved IVC id 530
ÿÿ1
Reserved IVC id 532
Reserved IVC id 533
Reserved IVC id 534
Reserved IVC id 535
Reserved IVC id 536
Reserved IVC id 537
Reserved IVC id 538
Reserved IVC id 539
ÿÿaMMFLAGS=1
Starting RM server
Start nvpm server
Done...
ÿÿNÿÿ\00
ÿÿnÿÿ\00
ÿÿoÿÿ\00
GPRÿÿtÿÿ\00s:
ÿÿiÿÿ\00
ÿÿ\000000 ÿÿoÿÿ\00
x6: 0x000ÿÿfÿÿ
ÿÿ\001
ÿÿEÿÿ\00
ÿÿoÿÿ\000x2100bbÿÿ
ÿÿ\002c
0xÿÿ
ÿÿ\0021003ÿÿ
ÿÿnÿÿ\00514
0x210ÿÿpÿÿ\000155ÿÿ
ÿÿ\000ÿÿdÿÿ\00
0x21000184
Sÿÿpÿÿ\00iÿÿ
ÿÿ\00:
0x1766ÿÿ:ÿÿ\000
0x18350
0x12ÿÿ[ÿÿ\00070
ÿÿbÿÿbÿÿ
ÿÿ
ÿÿaÿÿ
ÿÿ
ÿÿbÿÿ
ÿÿ
ÿÿDÿÿ
ÿÿ1ÿÿ
ÿÿ
ÿÿSÿÿ
ÿÿ
ÿÿCÿÿ ÿÿCÿÿ
ÿÿ
ÿÿ ÿÿdÿÿ
ÿÿ
ÿÿCÿÿeÿÿ ÿÿ
ÿÿCÿÿ
ÿÿ
ÿÿ ÿÿ
ÿÿiÿÿ
ÿÿPÿÿ
ÿÿDÿÿ
ÿÿ:210035b0 >
\00
[/code]00ÿÿ1ÿÿ[code]
\00ÿâ
\00ÿýÿàmain enter
HW Function test
Start Scheduler.
in late init
ÿâ
I> bit @ 0xd480000
I> Unpowergate done
I> Loading TOS ...
I> Loading EKS ...
I> Unhalting RCE
ÿâ
welcome to lk
dt initialized
mail initialized
chipid initialized
fuse initialized
sku initialized
speedo initialized
ec initialized
vmon initialized
adc initialized
fmon initialized
reset initialized
nvhs initialized
clk initialized
io_dpd initialized
thermal initialized
i2c initialized
aotag initialized
dvs initialized
pm initialized
pg_late initialized
strap initialized
tag initialized
emc initialized
clk_dt initialized
pm_post initialized
tj_init initialized
uphy_dt initialized
uphy initialized
mrq initialized
dmce initialized
cvc initialized
Starting OS
rm initialized
wake initialized
mail_fs initialized
profile initialized
ÿÿNvGpcDmaLibInitÿÿ
iÿÿ:ÿÿ
vÿÿHÿÿ
cÿÿyÿÿ
_ÿÿpÿÿ
qÿÿeÿÿ
uÿÿrÿÿ
eÿÿvÿÿ
uÿÿiÿÿ
eÿÿsÿÿ
ÿÿoÿÿ
nÿÿrÿÿ
oÿÿ ÿÿ
dÿÿMÿÿ
eÿÿoÿÿ
ÿÿdÿÿ
nÿÿeÿÿ
oÿÿ
ÿÿ
tÿÿ
ÿÿ
present
rÿÿ tÿÿ
eÿÿ aÿÿ
sÿÿ rÿÿ
eÿÿ tÿÿ
nÿÿ iÿÿ
tÿÿ nÿÿ
ÿÿ gÿÿ
ÿÿ app i2c_server
starting aÿÿ
sÿÿ pÿÿ
tÿÿ pÿÿ
aÿÿ ÿÿ
rÿÿ bÿÿ
tÿÿ pÿÿ
iÿÿ mÿÿ
nÿÿ pÿÿ
gÿÿ _iÿÿ
ÿÿ nÿÿ
aÿÿ cÿÿ
pÿÿ oÿÿ
p ÿÿ mÿÿ
gÿÿ iÿÿ
dÿÿ nÿÿ
bÿÿ gÿÿ
_ÿÿ
ÿÿ
aÿÿ
ÿÿ
gent
ÿÿ
ÿÿ
rver
D-S> ÿÿ Sever...
ÿÿVÿÿ
ÿÿC id 526
ÿÿpÿÿ
ÿÿ vÿÿRÿÿscÿÿeÿÿ
ÿÿserved IVC id 528
Reserved IVC id 529
Reserved IVC id 530
ÿÿ1
Reserved IVC id 532
Reserved IVC id 533
Reserved IVC id 534
Reserved IVC id 535
Reserved IVC id 536
Reserved IVC id 537
Reserved IVC id 538
Reserved IVC id 539
ÿÿaMMFLAGS=1
Starting RM server
Start nvpm server
Done...
ÿÿNÿÿ\00
ÿÿnÿÿ\00
ÿÿoÿÿ\00
GPRÿÿtÿÿ\00s:
ÿÿiÿÿ\00
ÿÿ\000000 ÿÿoÿÿ\00
x6: 0x000ÿÿfÿÿ
ÿÿ\001
ÿÿEÿÿ\00
ÿÿoÿÿ\000x2100bbÿÿ
ÿÿ\002c
0xÿÿ
ÿÿ\0021003ÿÿ
ÿÿnÿÿ\00514
0x210ÿÿpÿÿ\000155ÿÿ
ÿÿ\000ÿÿdÿÿ\00
0x21000184
Sÿÿpÿÿ\00iÿÿ
ÿÿ\00:
0x1766ÿÿ:ÿÿ\000
0x18350
0x12ÿÿ[ÿÿ\00070
ÿÿbÿÿbÿÿ
ÿÿ
ÿÿaÿÿ
ÿÿ
ÿÿbÿÿ
ÿÿ
ÿÿDÿÿ
ÿÿ1ÿÿ
ÿÿ
ÿÿSÿÿ
ÿÿ
ÿÿCÿÿ ÿÿCÿÿ
ÿÿ
ÿÿ ÿÿdÿÿ
ÿÿ
ÿÿCÿÿeÿÿ ÿÿ
ÿÿCÿÿ
ÿÿ
ÿÿ ÿÿ
ÿÿiÿÿ
ÿÿPÿÿ
ÿÿDÿÿ
ÿÿ:210035b0 >
\00
[/code]0007
ÿÿoÿÿ[code]
\00ÿâ
\00ÿýÿàmain enter
HW Function test
Start Scheduler.
in late init
ÿâ
I> bit @ 0xd480000
I> Unpowergate done
I> Loading TOS ...
I> Loading EKS ...
I> Unhalting RCE
ÿâ
welcome to lk
dt initialized
mail initialized
chipid initialized
fuse initialized
sku initialized
speedo initialized
ec initialized
vmon initialized
adc initialized
fmon initialized
reset initialized
nvhs initialized
clk initialized
io_dpd initialized
thermal initialized
i2c initialized
aotag initialized
dvs initialized
pm initialized
pg_late initialized
strap initialized
tag initialized
emc initialized
clk_dt initialized
pm_post initialized
tj_init initialized
uphy_dt initialized
uphy initialized
mrq initialized
dmce initialized
cvc initialized
Starting OS
rm initialized
wake initialized
mail_fs initialized
profile initialized
ÿÿNvGpcDmaLibInitÿÿ
iÿÿ:ÿÿ
vÿÿHÿÿ
cÿÿyÿÿ
_ÿÿpÿÿ
qÿÿeÿÿ
uÿÿrÿÿ
eÿÿvÿÿ
uÿÿiÿÿ
eÿÿsÿÿ
ÿÿoÿÿ
nÿÿrÿÿ
oÿÿ ÿÿ
dÿÿMÿÿ
eÿÿoÿÿ
ÿÿdÿÿ
nÿÿeÿÿ
oÿÿ
ÿÿ
tÿÿ
ÿÿ
present
rÿÿ tÿÿ
eÿÿ aÿÿ
sÿÿ rÿÿ
eÿÿ tÿÿ
nÿÿ iÿÿ
tÿÿ nÿÿ
ÿÿ gÿÿ
ÿÿ app i2c_server
starting aÿÿ
sÿÿ pÿÿ
tÿÿ pÿÿ
aÿÿ ÿÿ
rÿÿ bÿÿ
tÿÿ pÿÿ
iÿÿ mÿÿ
nÿÿ pÿÿ
gÿÿ _iÿÿ
ÿÿ nÿÿ
aÿÿ cÿÿ
pÿÿ oÿÿ
p ÿÿ mÿÿ
gÿÿ iÿÿ
dÿÿ nÿÿ
bÿÿ gÿÿ
_ÿÿ
ÿÿ
aÿÿ
ÿÿ
gent
ÿÿ
ÿÿ
rver
D-S> ÿÿ Sever...
ÿÿVÿÿ
ÿÿC id 526
ÿÿpÿÿ
ÿÿ vÿÿRÿÿscÿÿeÿÿ
ÿÿserved IVC id 528
Reserved IVC id 529
Reserved IVC id 530
ÿÿ1
Reserved IVC id 532
Reserved IVC id 533
Reserved IVC id 534
Reserved IVC id 535
Reserved IVC id 536
Reserved IVC id 537
Reserved IVC id 538
Reserved IVC id 539
ÿÿaMMFLAGS=1
Starting RM server
Start nvpm server
Done...
ÿÿNÿÿ\00
ÿÿnÿÿ\00
ÿÿoÿÿ\00
GPRÿÿtÿÿ\00s:
ÿÿiÿÿ\00
ÿÿ\000000 ÿÿoÿÿ\00
x6: 0x000ÿÿfÿÿ
ÿÿ\001
ÿÿEÿÿ\00
ÿÿoÿÿ\000x2100bbÿÿ
ÿÿ\002c
0xÿÿ
ÿÿ\0021003ÿÿ
ÿÿnÿÿ\00514
0x210ÿÿpÿÿ\000155ÿÿ
ÿÿ\000ÿÿdÿÿ\00
0x21000184
Sÿÿpÿÿ\00iÿÿ
ÿÿ\00:
0x1766ÿÿ:ÿÿ\000
0x18350
0x12ÿÿ[ÿÿ\00070
ÿÿbÿÿbÿÿ
ÿÿ
ÿÿaÿÿ
ÿÿ
ÿÿbÿÿ
ÿÿ
ÿÿDÿÿ
ÿÿ1ÿÿ
ÿÿ
ÿÿSÿÿ
ÿÿ
ÿÿCÿÿ ÿÿCÿÿ
ÿÿ
ÿÿ ÿÿdÿÿ
ÿÿ
ÿÿCÿÿeÿÿ ÿÿ
ÿÿCÿÿ
ÿÿ
ÿÿ ÿÿ
ÿÿiÿÿ
ÿÿPÿÿ
ÿÿDÿÿ
ÿÿ:210035b0 >
\00
[/code]0Fatal VMÿÿuÿÿ[code]
\00ÿâ
\00ÿýÿàmain enter
HW Function test
Start Scheduler.
in late init
ÿâ
I> bit @ 0xd480000
I> Unpowergate done
I> Loading TOS ...
I> Loading EKS ...
I> Unhalting RCE
ÿâ
welcome to lk
dt initialized
mail initialized
chipid initialized
fuse initialized
sku initialized
speedo initialized
ec initialized
vmon initialized
adc initialized
fmon initialized
reset initialized
nvhs initialized
clk initialized
io_dpd initialized
thermal initialized
i2c initialized
aotag initialized
dvs initialized
pm initialized
pg_late initialized
strap initialized
tag initialized
emc initialized
clk_dt initialized
pm_post initialized
tj_init initialized
uphy_dt initialized
uphy initialized
mrq initialized
dmce initialized
cvc initialized
Starting OS
rm initialized
wake initialized
mail_fs initialized
profile initialized
ÿÿNvGpcDmaLibInitÿÿ
iÿÿ:ÿÿ
vÿÿHÿÿ
cÿÿyÿÿ
_ÿÿpÿÿ
qÿÿeÿÿ
uÿÿrÿÿ
eÿÿvÿÿ
uÿÿiÿÿ
eÿÿsÿÿ
ÿÿoÿÿ
nÿÿrÿÿ
oÿÿ ÿÿ
dÿÿMÿÿ
eÿÿoÿÿ
ÿÿdÿÿ
nÿÿeÿÿ
oÿÿ
ÿÿ
tÿÿ
ÿÿ
present
rÿÿ tÿÿ
eÿÿ aÿÿ
sÿÿ rÿÿ
eÿÿ tÿÿ
nÿÿ iÿÿ
tÿÿ nÿÿ
ÿÿ gÿÿ
ÿÿ app i2c_server
starting aÿÿ
sÿÿ pÿÿ
tÿÿ pÿÿ
aÿÿ ÿÿ
rÿÿ bÿÿ
tÿÿ pÿÿ
iÿÿ mÿÿ
nÿÿ pÿÿ
gÿÿ _iÿÿ
ÿÿ nÿÿ
aÿÿ cÿÿ
pÿÿ oÿÿ
p ÿÿ mÿÿ
gÿÿ iÿÿ
dÿÿ nÿÿ
bÿÿ gÿÿ
_ÿÿ
ÿÿ
aÿÿ
ÿÿ
gent
ÿÿ
ÿÿ
rver
D-S> ÿÿ Sever...
ÿÿVÿÿ
ÿÿC id 526
ÿÿpÿÿ
ÿÿ vÿÿRÿÿscÿÿeÿÿ
ÿÿserved IVC id 528
Reserved IVC id 529
Reserved IVC id 530
ÿÿ1
Reserved IVC id 532
Reserved IVC id 533
Reserved IVC id 534
Reserved IVC id 535
Reserved IVC id 536
Reserved IVC id 537
Reserved IVC id 538
Reserved IVC id 539
ÿÿaMMFLAGS=1
Starting RM server
Start nvpm server
Done...
ÿÿNÿÿ\00
ÿÿnÿÿ\00
ÿÿoÿÿ\00
GPRÿÿtÿÿ\00s:
ÿÿiÿÿ\00
ÿÿ\000000 ÿÿoÿÿ\00
x6: 0x000ÿÿfÿÿ
ÿÿ\001
ÿÿEÿÿ\00
ÿÿoÿÿ\000x2100bbÿÿ
ÿÿ\002c
0xÿÿ
ÿÿ\0021003ÿÿ
ÿÿnÿÿ\00514
0x210ÿÿpÿÿ\000155ÿÿ
ÿÿ\000ÿÿdÿÿ\00
0x21000184
Sÿÿpÿÿ\00iÿÿ
ÿÿ\00:
0x1766ÿÿ:ÿÿ\000
0x18350
0x12ÿÿ[ÿÿ\00070
ÿÿbÿÿbÿÿ
ÿÿ
ÿÿaÿÿ
ÿÿ
ÿÿbÿÿ
ÿÿ
ÿÿDÿÿ
ÿÿ1ÿÿ
ÿÿ
ÿÿSÿÿ
ÿÿ
ÿÿCÿÿ ÿÿCÿÿ
ÿÿ
ÿÿ ÿÿdÿÿ
ÿÿ
ÿÿCÿÿeÿÿ ÿÿ
ÿÿCÿÿ
ÿÿ
ÿÿ ÿÿ
ÿÿiÿÿ
ÿÿPÿÿ
ÿÿDÿÿ
ÿÿ:210035b0 >
\00
[/code]0 ÿÿ5ÿÿ[code]
\00ÿâ
\00ÿýÿàmain enter
HW Function test
Start Scheduler.
in late init
ÿâ
I> bit @ 0xd480000
I> Unpowergate done
I> Loading TOS ...
I> Loading EKS ...
I> Unhalting RCE
ÿâ
welcome to lk
dt initialized
mail initialized
chipid initialized
fuse initialized
sku initialized
speedo initialized
ec initialized
vmon initialized
adc initialized
fmon initialized
reset initialized
nvhs initialized
clk initialized
io_dpd initialized
thermal initialized
i2c initialized
aotag initialized
dvs initialized
pm initialized
pg_late initialized
strap initialized
tag initialized
emc initialized
clk_dt initialized
pm_post initialized
tj_init initialized
uphy_dt initialized
uphy initialized
mrq initialized
dmce initialized
cvc initialized
Starting OS
rm initialized
wake initialized
mail_fs initialized
profile initialized
ÿÿNvGpcDmaLibInitÿÿ
iÿÿ:ÿÿ
vÿÿHÿÿ
cÿÿyÿÿ
_ÿÿpÿÿ
qÿÿeÿÿ
uÿÿrÿÿ
eÿÿvÿÿ
uÿÿiÿÿ
eÿÿsÿÿ
ÿÿoÿÿ
nÿÿrÿÿ
oÿÿ ÿÿ
dÿÿMÿÿ
eÿÿoÿÿ
ÿÿdÿÿ
nÿÿeÿÿ
oÿÿ
ÿÿ
tÿÿ
ÿÿ
present
rÿÿ tÿÿ
eÿÿ aÿÿ
sÿÿ rÿÿ
eÿÿ tÿÿ
nÿÿ iÿÿ
tÿÿ nÿÿ
ÿÿ gÿÿ
ÿÿ app i2c_server
starting aÿÿ
sÿÿ pÿÿ
tÿÿ pÿÿ
aÿÿ ÿÿ
rÿÿ bÿÿ
tÿÿ pÿÿ
iÿÿ mÿÿ
nÿÿ pÿÿ
gÿÿ _iÿÿ
ÿÿ nÿÿ
aÿÿ cÿÿ
pÿÿ oÿÿ
p ÿÿ mÿÿ
gÿÿ iÿÿ
dÿÿ nÿÿ
bÿÿ gÿÿ
_ÿÿ
ÿÿ
aÿÿ
ÿÿ
gent
ÿÿ
ÿÿ
rver
D-S> ÿÿ Sever...
ÿÿVÿÿ
ÿÿC id 526
ÿÿpÿÿ
ÿÿ vÿÿRÿÿscÿÿeÿÿ
ÿÿserved IVC id 528
Reserved IVC id 529
Reserved IVC id 530
ÿÿ1
Reserved IVC id 532
Reserved IVC id 533
Reserved IVC id 534
Reserved IVC id 535
Reserved IVC id 536
Reserved IVC id 537
Reserved IVC id 538
Reserved IVC id 539
ÿÿaMMFLAGS=1
Starting RM server
Start nvpm server
Done...
ÿÿNÿÿ\00
ÿÿnÿÿ\00
ÿÿoÿÿ\00
GPRÿÿtÿÿ\00s:
ÿÿiÿÿ\00
ÿÿ\000000 ÿÿoÿÿ\00
x6: 0x000ÿÿfÿÿ
ÿÿ\001
ÿÿEÿÿ\00
ÿÿoÿÿ\000x2100bbÿÿ
ÿÿ\002c
0xÿÿ
ÿÿ\0021003ÿÿ
ÿÿnÿÿ\00514
0x210ÿÿpÿÿ\000155ÿÿ
ÿÿ\000ÿÿdÿÿ\00
0x21000184
Sÿÿpÿÿ\00iÿÿ
ÿÿ\00:
0x1766ÿÿ:ÿÿ\000
0x18350
0x12ÿÿ[ÿÿ\00070
ÿÿbÿÿbÿÿ
ÿÿ
ÿÿaÿÿ
ÿÿ
ÿÿbÿÿ
ÿÿ
ÿÿDÿÿ
ÿÿ1ÿÿ
ÿÿ
ÿÿSÿÿ
ÿÿ
ÿÿCÿÿ ÿÿCÿÿ
ÿÿ
ÿÿ ÿÿdÿÿ
ÿÿ
ÿÿCÿÿeÿÿ ÿÿ
ÿÿCÿÿ
ÿÿ
ÿÿ ÿÿ
ÿÿiÿÿ
ÿÿPÿÿ
ÿÿDÿÿ
ÿÿ:210035b0 >
\00
[/code]0Fault: ÿÿ ÿÿ[code]
\00ÿâ
\00ÿýÿàmain enter
HW Function test
Start Scheduler.
in late init
ÿâ
I> bit @ 0xd480000
I> Unpowergate done
I> Loading TOS ...
I> Loading EKS ...
I> Unhalting RCE
ÿâ
welcome to lk
dt initialized
mail initialized
chipid initialized
fuse initialized
sku initialized
speedo initialized
ec initialized
vmon initialized
adc initialized
fmon initialized
reset initialized
nvhs initialized
clk initialized
io_dpd initialized
thermal initialized
i2c initialized
aotag initialized
dvs initialized
pm initialized
pg_late initialized
strap initialized
tag initialized
emc initialized
clk_dt initialized
pm_post initialized
tj_init initialized
uphy_dt initialized
uphy initialized
mrq initialized
dmce initialized
cvc initialized
Starting OS
rm initialized
wake initialized
mail_fs initialized
profile initialized
ÿÿNvGpcDmaLibInitÿÿ
iÿÿ:ÿÿ
vÿÿHÿÿ
cÿÿyÿÿ
_ÿÿpÿÿ
qÿÿeÿÿ
uÿÿrÿÿ
eÿÿvÿÿ
uÿÿiÿÿ
eÿÿsÿÿ
ÿÿoÿÿ
nÿÿrÿÿ
oÿÿ ÿÿ
dÿÿMÿÿ
eÿÿoÿÿ
ÿÿdÿÿ
nÿÿeÿÿ
oÿÿ
ÿÿ
tÿÿ
ÿÿ
present
rÿÿ tÿÿ
eÿÿ aÿÿ
sÿÿ rÿÿ
eÿÿ tÿÿ
nÿÿ iÿÿ
tÿÿ nÿÿ
ÿÿ gÿÿ
ÿÿ app i2c_server
starting aÿÿ
sÿÿ pÿÿ
tÿÿ pÿÿ
aÿÿ ÿÿ
rÿÿ bÿÿ
tÿÿ pÿÿ
iÿÿ mÿÿ
nÿÿ pÿÿ
gÿÿ _iÿÿ
ÿÿ nÿÿ
aÿÿ cÿÿ
pÿÿ oÿÿ
p ÿÿ mÿÿ
gÿÿ iÿÿ
dÿÿ nÿÿ
bÿÿ gÿÿ
_ÿÿ
ÿÿ
aÿÿ
ÿÿ
gent
ÿÿ
ÿÿ
rver
D-S> ÿÿ Sever...
ÿÿVÿÿ
ÿÿC id 526
ÿÿpÿÿ
ÿÿ vÿÿRÿÿscÿÿeÿÿ
ÿÿserved IVC id 528
Reserved IVC id 529
Reserved IVC id 530
ÿÿ1
Reserved IVC id 532
Reserved IVC id 533
Reserved IVC id 534
Reserved IVC id 535
Reserved IVC id 536
Reserved IVC id 537
Reserved IVC id 538
Reserved IVC id 539
ÿÿaMMFLAGS=1
Starting RM server
Start nvpm server
Done...
ÿÿNÿÿ\00
ÿÿnÿÿ\00
ÿÿoÿÿ\00
GPRÿÿtÿÿ\00s:
ÿÿiÿÿ\00
ÿÿ\000000 ÿÿoÿÿ\00
x6: 0x000ÿÿfÿÿ
ÿÿ\001
ÿÿEÿÿ\00
ÿÿoÿÿ\000x2100bbÿÿ
ÿÿ\002c
0xÿÿ
ÿÿ\0021003ÿÿ
ÿÿnÿÿ\00514
0x210ÿÿpÿÿ\000155ÿÿ
ÿÿ\000ÿÿdÿÿ\00
0x21000184
Sÿÿpÿÿ\00iÿÿ
ÿÿ\00:
0x1766ÿÿ:ÿÿ\000
0x18350
0x12ÿÿ[ÿÿ\00070
ÿÿbÿÿbÿÿ
ÿÿ
ÿÿaÿÿ
ÿÿ
ÿÿbÿÿ
ÿÿ
ÿÿDÿÿ
ÿÿ1ÿÿ
ÿÿ
ÿÿSÿÿ
ÿÿ
ÿÿCÿÿ ÿÿCÿÿ
ÿÿ
ÿÿ ÿÿdÿÿ
ÿÿ
ÿÿCÿÿeÿÿ ÿÿ
ÿÿCÿÿ
ÿÿ
ÿÿ ÿÿ
ÿÿiÿÿ
ÿÿPÿÿ
ÿÿDÿÿ
ÿÿ:210035b0 >
\00
[/code]0Faileÿÿeÿÿ[code]
\00ÿâ
\00ÿýÿàmain enter
HW Function test
Start Scheduler.
in late init
ÿâ
I> bit @ 0xd480000
I> Unpowergate done
I> Loading TOS ...
I> Loading EKS ...
I> Unhalting RCE
ÿâ
welcome to lk
dt initialized
mail initialized
chipid initialized
fuse initialized
sku initialized
speedo initialized
ec initialized
vmon initialized
adc initialized
fmon initialized
reset initialized
nvhs initialized
clk initialized
io_dpd initialized
thermal initialized
i2c initialized
aotag initialized
dvs initialized
pm initialized
pg_late initialized
strap initialized
tag initialized
emc initialized
clk_dt initialized
pm_post initialized
tj_init initialized
uphy_dt initialized
uphy initialized
mrq initialized
dmce initialized
cvc initialized
Starting OS
rm initialized
wake initialized
mail_fs initialized
profile initialized
ÿÿNvGpcDmaLibInitÿÿ
iÿÿ:ÿÿ
vÿÿHÿÿ
cÿÿyÿÿ
_ÿÿpÿÿ
qÿÿeÿÿ
uÿÿrÿÿ
eÿÿvÿÿ
uÿÿiÿÿ
eÿÿsÿÿ
ÿÿoÿÿ
nÿÿrÿÿ
oÿÿ ÿÿ
dÿÿMÿÿ
eÿÿoÿÿ
ÿÿdÿÿ
nÿÿeÿÿ
oÿÿ
ÿÿ
tÿÿ
ÿÿ
present
rÿÿ tÿÿ
eÿÿ aÿÿ
sÿÿ rÿÿ
eÿÿ tÿÿ
nÿÿ iÿÿ
tÿÿ nÿÿ
ÿÿ gÿÿ
ÿÿ app i2c_server
starting aÿÿ
sÿÿ pÿÿ
tÿÿ pÿÿ
aÿÿ ÿÿ
rÿÿ bÿÿ
tÿÿ pÿÿ
iÿÿ mÿÿ
nÿÿ pÿÿ
gÿÿ _iÿÿ
ÿÿ nÿÿ
aÿÿ cÿÿ
pÿÿ oÿÿ
p ÿÿ mÿÿ
gÿÿ iÿÿ
dÿÿ nÿÿ
bÿÿ gÿÿ
_ÿÿ
ÿÿ
aÿÿ
ÿÿ
gent
ÿÿ
ÿÿ
rver
D-S> ÿÿ Sever...
ÿÿVÿÿ
ÿÿC id 526
ÿÿpÿÿ
ÿÿ vÿÿRÿÿscÿÿeÿÿ
ÿÿserved IVC id 528
Reserved IVC id 529
Reserved IVC id 530
ÿÿ1
Reserved IVC id 532
Reserved IVC id 533
Reserved IVC id 534
Reserved IVC id 535
Reserved IVC id 536
Reserved IVC id 537
Reserved IVC id 538
Reserved IVC id 539
ÿÿaMMFLAGS=1
Starting RM server
Start nvpm server
Done...
ÿÿNÿÿ\00
ÿÿnÿÿ\00
ÿÿoÿÿ\00
GPRÿÿtÿÿ\00s:
ÿÿiÿÿ\00
ÿÿ\000000 ÿÿoÿÿ\00
x6: 0x000ÿÿfÿÿ
ÿÿ\001
ÿÿEÿÿ\00
ÿÿoÿÿ\000x2100bbÿÿ
ÿÿ\002c
0xÿÿ
ÿÿ\0021003ÿÿ
ÿÿnÿÿ\00514
0x210ÿÿpÿÿ\000155ÿÿ
ÿÿ\000ÿÿdÿÿ\00
0x21000184
Sÿÿpÿÿ\00iÿÿ
ÿÿ\00:
0x1766ÿÿ:ÿÿ\000
0x18350
0x12ÿÿ[ÿÿ\00070
ÿÿbÿÿbÿÿ
ÿÿ
ÿÿaÿÿ
ÿÿ
ÿÿbÿÿ
ÿÿ
ÿÿDÿÿ
ÿÿ1ÿÿ
ÿÿ
ÿÿSÿÿ
ÿÿ
ÿÿCÿÿ ÿÿCÿÿ
ÿÿ
ÿÿ ÿÿdÿÿ
ÿÿ
ÿÿCÿÿeÿÿ ÿÿ
ÿÿCÿÿ
ÿÿ
ÿÿ ÿÿ
ÿÿiÿÿ
ÿÿPÿÿ
ÿÿDÿÿ
ÿÿ:210035b0 >
\00
[/code]0d ÿÿ9ÿÿ[code]
\00ÿâ
\00ÿýÿàmain enter
HW Function test
Start Scheduler.
in late init
ÿâ
I> bit @ 0xd480000
I> Unpowergate done
I> Loading TOS ...
I> Loading EKS ...
I> Unhalting RCE
ÿâ
welcome to lk
dt initialized
mail initialized
chipid initialized
fuse initialized
sku initialized
speedo initialized
ec initialized
vmon initialized
adc initialized
fmon initialized
reset initialized
nvhs initialized
clk initialized
io_dpd initialized
thermal initialized
i2c initialized
aotag initialized
dvs initialized
pm initialized
pg_late initialized
strap initialized
tag initialized
emc initialized
clk_dt initialized
pm_post initialized
tj_init initialized
uphy_dt initialized
uphy initialized
mrq initialized
dmce initialized
cvc initialized
Starting OS
rm initialized
wake initialized
mail_fs initialized
profile initialized
ÿÿNvGpcDmaLibInitÿÿ
iÿÿ:ÿÿ
vÿÿHÿÿ
cÿÿyÿÿ
_ÿÿpÿÿ
qÿÿeÿÿ
uÿÿrÿÿ
eÿÿvÿÿ
uÿÿiÿÿ
eÿÿsÿÿ
ÿÿoÿÿ
nÿÿrÿÿ
oÿÿ ÿÿ
dÿÿMÿÿ
eÿÿoÿÿ
ÿÿdÿÿ
nÿÿeÿÿ
oÿÿ
ÿÿ
tÿÿ
ÿÿ
present
rÿÿ tÿÿ
eÿÿ aÿÿ
sÿÿ rÿÿ
eÿÿ tÿÿ
nÿÿ iÿÿ
tÿÿ nÿÿ
ÿÿ gÿÿ
ÿÿ app i2c_server
starting aÿÿ
sÿÿ pÿÿ
tÿÿ pÿÿ
aÿÿ ÿÿ
rÿÿ bÿÿ
tÿÿ pÿÿ
iÿÿ mÿÿ
nÿÿ pÿÿ
gÿÿ _iÿÿ
ÿÿ nÿÿ
aÿÿ cÿÿ
pÿÿ oÿÿ
p ÿÿ mÿÿ
gÿÿ iÿÿ
dÿÿ nÿÿ
bÿÿ gÿÿ
_ÿÿ
ÿÿ
aÿÿ
ÿÿ
gent
ÿÿ
ÿÿ
rver
D-S> ÿÿ Sever...
ÿÿVÿÿ
ÿÿC id 526
ÿÿpÿÿ
ÿÿ vÿÿRÿÿscÿÿeÿÿ
ÿÿserved IVC id 528
Reserved IVC id 529
Reserved IVC id 530
ÿÿ1
Reserved IVC id 532
Reserved IVC id 533
Reserved IVC id 534
Reserved IVC id 535
Reserved IVC id 536
Reserved IVC id 537
Reserved IVC id 538
Reserved IVC id 539
ÿÿaMMFLAGS=1
Starting RM server
Start nvpm server
Done...
ÿÿNÿÿ\00
ÿÿnÿÿ\00
ÿÿoÿÿ\00
GPRÿÿtÿÿ\00s:
ÿÿiÿÿ\00
ÿÿ\000000 ÿÿoÿÿ\00
x6: 0x000ÿÿfÿÿ
ÿÿ\001
ÿÿEÿÿ\00
ÿÿoÿÿ\000x2100bbÿÿ
ÿÿ\002c
0xÿÿ
ÿÿ\0021003ÿÿ
ÿÿnÿÿ\00514
0x210ÿÿpÿÿ\000155ÿÿ
ÿÿ\000ÿÿdÿÿ\00
0x21000184
Sÿÿpÿÿ\00iÿÿ
ÿÿ\00:
0x1766ÿÿ:ÿÿ\000
0x18350
0x12ÿÿ[ÿÿ\00070
ÿÿbÿÿbÿÿ
ÿÿ
ÿÿaÿÿ
ÿÿ
ÿÿbÿÿ
ÿÿ
ÿÿDÿÿ
ÿÿ1ÿÿ
ÿÿ
ÿÿSÿÿ
ÿÿ
ÿÿCÿÿ ÿÿCÿÿ
ÿÿ
ÿÿ ÿÿdÿÿ
ÿÿ
ÿÿCÿÿeÿÿ ÿÿ
ÿÿCÿÿ
ÿÿ
ÿÿ ÿÿ
ÿÿiÿÿ
ÿÿPÿÿ
ÿÿDÿÿ
ÿÿ:210035b0 >
\00
[/code]0to haÿÿBÿÿ[code]
\00ÿâ
\00ÿýÿàmain enter
HW Function test
Start Scheduler.
in late init
ÿâ
I> bit @ 0xd480000
I> Unpowergate done
I> Loading TOS ...
I> Loading EKS ...
I> Unhalting RCE
ÿâ
welcome to lk
dt initialized
mail initialized
chipid initialized
fuse initialized
sku initialized
speedo initialized
ec initialized
vmon initialized
adc initialized
fmon initialized
reset initialized
nvhs initialized
clk initialized
io_dpd initialized
thermal initialized
i2c initialized
aotag initialized
dvs initialized
pm initialized
pg_late initialized
strap initialized
tag initialized
emc initialized
clk_dt initialized
pm_post initialized
tj_init initialized
uphy_dt initialized
uphy initialized
mrq initialized
dmce initialized
cvc initialized
Starting OS
rm initialized
wake initialized
mail_fs initialized
profile initialized
ÿÿNvGpcDmaLibInitÿÿ
iÿÿ:ÿÿ
vÿÿHÿÿ
cÿÿyÿÿ
_ÿÿpÿÿ
qÿÿeÿÿ
uÿÿrÿÿ
eÿÿvÿÿ
uÿÿiÿÿ
eÿÿsÿÿ
ÿÿoÿÿ
nÿÿrÿÿ
oÿÿ ÿÿ
dÿÿMÿÿ
eÿÿoÿÿ
ÿÿdÿÿ
nÿÿeÿÿ
oÿÿ
ÿÿ
tÿÿ
ÿÿ
present
rÿÿ tÿÿ
eÿÿ aÿÿ
sÿÿ rÿÿ
eÿÿ tÿÿ
nÿÿ iÿÿ
tÿÿ nÿÿ
ÿÿ gÿÿ
ÿÿ app i2c_server
starting aÿÿ
sÿÿ pÿÿ
tÿÿ pÿÿ
aÿÿ ÿÿ
rÿÿ bÿÿ
tÿÿ pÿÿ
iÿÿ mÿÿ
nÿÿ pÿÿ
gÿÿ _iÿÿ
ÿÿ nÿÿ
aÿÿ cÿÿ
pÿÿ oÿÿ
p ÿÿ mÿÿ
gÿÿ iÿÿ
dÿÿ nÿÿ
bÿÿ gÿÿ
_ÿÿ
ÿÿ
aÿÿ
ÿÿ
gent
ÿÿ
ÿÿ
rver
D-S> ÿÿ Sever...
ÿÿVÿÿ
ÿÿC id 526
ÿÿpÿÿ
ÿÿ vÿÿRÿÿscÿÿeÿÿ
ÿÿserved IVC id 528
Reserved IVC id 529
Reserved IVC id 530
ÿÿ1
Reserved IVC id 532
Reserved IVC id 533
Reserved IVC id 534
Reserved IVC id 535
Reserved IVC id 536
Reserved IVC id 537
Reserved IVC id 538
Reserved IVC id 539
ÿÿaMMFLAGS=1
Starting RM server
Start nvpm server
Done...
ÿÿNÿÿ\00
ÿÿnÿÿ\00
ÿÿoÿÿ\00
GPRÿÿtÿÿ\00s:
ÿÿiÿÿ\00
ÿÿ\000000 ÿÿoÿÿ\00
x6: 0x000ÿÿfÿÿ
ÿÿ\001
ÿÿEÿÿ\00
ÿÿoÿÿ\000x2100bbÿÿ
ÿÿ\002c
0xÿÿ
ÿÿ\0021003ÿÿ
ÿÿnÿÿ\00514
0x210ÿÿpÿÿ\000155ÿÿ
ÿÿ\000ÿÿdÿÿ\00
0x21000184
Sÿÿpÿÿ\00iÿÿ
ÿÿ\00:
0x1766ÿÿ:ÿÿ\000
0x18350
0x12ÿÿ[ÿÿ\00070
ÿÿbÿÿbÿÿ
ÿÿ
ÿÿaÿÿ
ÿÿ
ÿÿbÿÿ
ÿÿ
ÿÿDÿÿ
ÿÿ1ÿÿ
ÿÿ
ÿÿSÿÿ
ÿÿ
ÿÿCÿÿ ÿÿCÿÿ
ÿÿ
ÿÿ ÿÿdÿÿ
ÿÿ
ÿÿCÿÿeÿÿ ÿÿ
ÿÿCÿÿ
ÿÿ
ÿÿ ÿÿ
ÿÿiÿÿ
ÿÿPÿÿ
ÿÿDÿÿ
ÿÿ:210035b0 >
\00
[/code]0ndlÿÿsÿÿ[code]
\00ÿâ
\00ÿýÿàmain enter
HW Function test
Start Scheduler.
in late init
ÿâ
I> bit @ 0xd480000
I> Unpowergate done
I> Loading TOS ...
I> Loading EKS ...
I> Unhalting RCE
ÿâ
welcome to lk
dt initialized
mail initialized
chipid initialized
fuse initialized
sku initialized
speedo initialized
ec initialized
vmon initialized
adc initialized
fmon initialized
reset initialized
nvhs initialized
clk initialized
io_dpd initialized
thermal initialized
i2c initialized
aotag initialized
dvs initialized
pm initialized
pg_late initialized
strap initialized
tag initialized
emc initialized
clk_dt initialized
pm_post initialized
tj_init initialized
uphy_dt initialized
uphy initialized
mrq initialized
dmce initialized
cvc initialized
Starting OS
rm initialized
wake initialized
mail_fs initialized
profile initialized
ÿÿNvGpcDmaLibInitÿÿ
iÿÿ:ÿÿ
vÿÿHÿÿ
cÿÿyÿÿ
_ÿÿpÿÿ
qÿÿeÿÿ
uÿÿrÿÿ
eÿÿvÿÿ
uÿÿiÿÿ
eÿÿsÿÿ
ÿÿoÿÿ
nÿÿrÿÿ
oÿÿ ÿÿ
dÿÿMÿÿ
eÿÿoÿÿ
ÿÿdÿÿ
nÿÿeÿÿ
oÿÿ
ÿÿ
tÿÿ
ÿÿ
present
rÿÿ tÿÿ
eÿÿ aÿÿ
sÿÿ rÿÿ
eÿÿ tÿÿ
nÿÿ iÿÿ
tÿÿ nÿÿ
ÿÿ gÿÿ
ÿÿ app i2c_server
starting aÿÿ
sÿÿ pÿÿ
tÿÿ pÿÿ
aÿÿ ÿÿ
rÿÿ bÿÿ
tÿÿ pÿÿ
iÿÿ mÿÿ
nÿÿ pÿÿ
gÿÿ _iÿÿ
ÿÿ nÿÿ
aÿÿ cÿÿ
pÿÿ oÿÿ
p ÿÿ mÿÿ
gÿÿ iÿÿ
dÿÿ nÿÿ
bÿÿ gÿÿ
_ÿÿ
ÿÿ
aÿÿ
ÿÿ
gent
ÿÿ
ÿÿ
rver
D-S> ÿÿ Sever...
ÿÿVÿÿ
ÿÿC id 526
ÿÿpÿÿ
ÿÿ vÿÿRÿÿscÿÿeÿÿ
ÿÿserved IVC id 528
Reserved IVC id 529
Reserved IVC id 530
ÿÿ1
Reserved IVC id 532
Reserved IVC id 533
Reserved IVC id 534
Reserved IVC id 535
Reserved IVC id 536
Reserved IVC id 537
Reserved IVC id 538
Reserved IVC id 539
ÿÿaMMFLAGS=1
Starting RM server
Start nvpm server
Done...
ÿÿNÿÿ\00
ÿÿnÿÿ\00
ÿÿoÿÿ\00
GPRÿÿtÿÿ\00s:
ÿÿiÿÿ\00
ÿÿ\000000 ÿÿoÿÿ\00
x6: 0x000ÿÿfÿÿ
ÿÿ\001
ÿÿEÿÿ\00
ÿÿoÿÿ\000x2100bbÿÿ
ÿÿ\002c
0xÿÿ
ÿÿ\0021003ÿÿ
ÿÿnÿÿ\00514
0x210ÿÿpÿÿ\000155ÿÿ
ÿÿ\000ÿÿdÿÿ\00
0x21000184
Sÿÿpÿÿ\00iÿÿ
ÿÿ\00:
0x1766ÿÿ:ÿÿ\000
0x18350
0x12ÿÿ[ÿÿ\00070
ÿÿbÿÿbÿÿ
ÿÿ
ÿÿaÿÿ
ÿÿ
ÿÿbÿÿ
ÿÿ
ÿÿDÿÿ
ÿÿ1ÿÿ
ÿÿ
ÿÿSÿÿ
ÿÿ
ÿÿCÿÿ ÿÿCÿÿ
ÿÿ
ÿÿ ÿÿdÿÿ
ÿÿ
ÿÿCÿÿeÿÿ ÿÿ
ÿÿCÿÿ
ÿÿ
ÿÿ ÿÿ
ÿÿiÿÿ
ÿÿPÿÿ
ÿÿDÿÿ
ÿÿ:210035b0 >
\00
[/code]0e dÿÿ ÿÿ[code]
\00ÿâ
\00ÿýÿàmain enter
HW Function test
Start Scheduler.
in late init
ÿâ
I> bit @ 0xd480000
I> Unpowergate done
I> Loading TOS ...
I> Loading EKS ...
I> Unhalting RCE
ÿâ
welcome to lk
dt initialized
mail initialized
chipid initialized
fuse initialized
sku initialized
speedo initialized
ec initialized
vmon initialized
adc initialized
fmon initialized
reset initialized
nvhs initialized
clk initialized
io_dpd initialized
thermal initialized
i2c initialized
aotag initialized
dvs initialized
pm initialized
pg_late initialized
strap initialized
tag initialized
emc initialized
clk_dt initialized
pm_post initialized
tj_init initialized
uphy_dt initialized
uphy initialized
mrq initialized
dmce initialized
cvc initialized
Starting OS
rm initialized
wake initialized
mail_fs initialized
profile initialized
ÿÿNvGpcDmaLibInitÿÿ
iÿÿ:ÿÿ
vÿÿHÿÿ
cÿÿyÿÿ
_ÿÿpÿÿ
qÿÿeÿÿ
uÿÿrÿÿ
eÿÿvÿÿ
uÿÿiÿÿ
eÿÿsÿÿ
ÿÿoÿÿ
nÿÿrÿÿ
oÿÿ ÿÿ
dÿÿMÿÿ
eÿÿoÿÿ
ÿÿdÿÿ
nÿÿeÿÿ
oÿÿ
ÿÿ
tÿÿ
ÿÿ
present
rÿÿ tÿÿ
eÿÿ aÿÿ
sÿÿ rÿÿ
eÿÿ tÿÿ
nÿÿ iÿÿ
tÿÿ nÿÿ
ÿÿ gÿÿ
ÿÿ app i2c_server
starting aÿÿ
sÿÿ pÿÿ
tÿÿ pÿÿ
aÿÿ ÿÿ
rÿÿ bÿÿ
tÿÿ pÿÿ
iÿÿ mÿÿ
nÿÿ pÿÿ
gÿÿ _iÿÿ
ÿÿ nÿÿ
aÿÿ cÿÿ
pÿÿ oÿÿ
p ÿÿ mÿÿ
gÿÿ iÿÿ
dÿÿ nÿÿ
bÿÿ gÿÿ
_ÿÿ
ÿÿ
aÿÿ
ÿÿ
gent
ÿÿ
ÿÿ
rver
D-S> ÿÿ Sever...
ÿÿVÿÿ
ÿÿC id 526
ÿÿpÿÿ
ÿÿ vÿÿRÿÿscÿÿeÿÿ
ÿÿserved IVC id 528
Reserved IVC id 529
Reserved IVC id 530
ÿÿ1
Reserved IVC id 532
Reserved IVC id 533
Reserved IVC id 534
Reserved IVC id 535
Reserved IVC id 536
Reserved IVC id 537
Reserved IVC id 538
Reserved IVC id 539
ÿÿaMMFLAGS=1
Starting RM server
Start nvpm server
Done...
ÿÿNÿÿ\00
ÿÿnÿÿ\00
ÿÿoÿÿ\00
GPRÿÿtÿÿ\00s:
ÿÿiÿÿ\00
ÿÿ\000000 ÿÿoÿÿ\00
x6: 0x000ÿÿfÿÿ
ÿÿ\001
ÿÿEÿÿ\00
ÿÿoÿÿ\000x2100bbÿÿ
ÿÿ\002c
0xÿÿ
ÿÿ\0021003ÿÿ
ÿÿnÿÿ\00514
0x210ÿÿpÿÿ\000155ÿÿ
ÿÿ\000ÿÿdÿÿ\00
0x21000184
Sÿÿpÿÿ\00iÿÿ
ÿÿ\00:
0x1766ÿÿ:ÿÿ\000
0x18350
0x12ÿÿ[ÿÿ\00070
ÿÿbÿÿbÿÿ
ÿÿ
ÿÿaÿÿ
ÿÿ
ÿÿbÿÿ
ÿÿ
ÿÿDÿÿ
ÿÿ1ÿÿ
ÿÿ
ÿÿSÿÿ
ÿÿ
ÿÿCÿÿ ÿÿCÿÿ
ÿÿ
ÿÿ ÿÿdÿÿ
ÿÿ
ÿÿCÿÿeÿÿ ÿÿ
ÿÿCÿÿ
ÿÿ
ÿÿ ÿÿ
ÿÿiÿÿ
ÿÿPÿÿ
ÿÿDÿÿ
ÿÿ:210035b0 >
\00
[/code]0ata aÿÿoÿÿ[code]
\00ÿâ
\00ÿýÿàmain enter
HW Function test
Start Scheduler.
in late init
ÿâ
I> bit @ 0xd480000
I> Unpowergate done
I> Loading TOS ...
I> Loading EKS ...
I> Unhalting RCE
ÿâ
welcome to lk
dt initialized
mail initialized
chipid initialized
fuse initialized
sku initialized
speedo initialized
ec initialized
vmon initialized
adc initialized
fmon initialized
reset initialized
nvhs initialized
clk initialized
io_dpd initialized
thermal initialized
i2c initialized
aotag initialized
dvs initialized
pm initialized
pg_late initialized
strap initialized
tag initialized
emc initialized
clk_dt initialized
pm_post initialized
tj_init initialized
uphy_dt initialized
uphy initialized
mrq initialized
dmce initialized
cvc initialized
Starting OS
rm initialized
wake initialized
mail_fs initialized
profile initialized
ÿÿNvGpcDmaLibInitÿÿ
iÿÿ:ÿÿ
vÿÿHÿÿ
cÿÿyÿÿ
_ÿÿpÿÿ
qÿÿeÿÿ
uÿÿrÿÿ
eÿÿvÿÿ
uÿÿiÿÿ
eÿÿsÿÿ
ÿÿoÿÿ
nÿÿrÿÿ
oÿÿ ÿÿ
dÿÿMÿÿ
eÿÿoÿÿ
ÿÿdÿÿ
nÿÿeÿÿ
oÿÿ
ÿÿ
tÿÿ
ÿÿ
present
rÿÿ tÿÿ
eÿÿ aÿÿ
sÿÿ rÿÿ
eÿÿ tÿÿ
nÿÿ iÿÿ
tÿÿ nÿÿ
ÿÿ gÿÿ
ÿÿ app i2c_server
starting aÿÿ
sÿÿ pÿÿ
tÿÿ pÿÿ
aÿÿ ÿÿ
rÿÿ bÿÿ
tÿÿ pÿÿ
iÿÿ mÿÿ
nÿÿ pÿÿ
gÿÿ _iÿÿ
ÿÿ nÿÿ
aÿÿ cÿÿ
pÿÿ oÿÿ
p ÿÿ mÿÿ
gÿÿ iÿÿ
dÿÿ nÿÿ
bÿÿ gÿÿ
_ÿÿ
ÿÿ
aÿÿ
ÿÿ
gent
ÿÿ
ÿÿ
rver
D-S> ÿÿ Sever...
ÿÿVÿÿ
ÿÿC id 526
ÿÿpÿÿ
ÿÿ vÿÿRÿÿscÿÿeÿÿ
ÿÿserved IVC id 528
Reserved IVC id 529
Reserved IVC id 530
ÿÿ1
Reserved IVC id 532
Reserved IVC id 533
Reserved IVC id 534
Reserved IVC id 535
Reserved IVC id 536
Reserved IVC id 537
Reserved IVC id 538
Reserved IVC id 539
ÿÿaMMFLAGS=1
Starting RM server
Start nvpm server
Done...
ÿÿNÿÿ\00
ÿÿnÿÿ\00
ÿÿoÿÿ\00
GPRÿÿtÿÿ\00s:
ÿÿiÿÿ\00
ÿÿ\000000 ÿÿoÿÿ\00
x6: 0x000ÿÿfÿÿ
ÿÿ\001
ÿÿEÿÿ\00
ÿÿoÿÿ\000x2100bbÿÿ
ÿÿ\002c
0xÿÿ
ÿÿ\0021003ÿÿ
ÿÿnÿÿ\00514
0x210ÿÿpÿÿ\000155ÿÿ
ÿÿ\000ÿÿdÿÿ\00
0x21000184
Sÿÿpÿÿ\00iÿÿ
ÿÿ\00:
0x1766ÿÿ:ÿÿ\000
0x18350
0x12ÿÿ[ÿÿ\00070
ÿÿbÿÿbÿÿ
ÿÿ
ÿÿaÿÿ
ÿÿ
ÿÿbÿÿ
ÿÿ
ÿÿDÿÿ
ÿÿ1ÿÿ
ÿÿ
ÿÿSÿÿ
ÿÿ
ÿÿCÿÿ ÿÿCÿÿ
ÿÿ
ÿÿ ÿÿdÿÿ
ÿÿ
ÿÿCÿÿeÿÿ ÿÿ
ÿÿCÿÿ
ÿÿ
ÿÿ ÿÿ
ÿÿiÿÿ
ÿÿPÿÿ
ÿÿDÿÿ
ÿÿ:210035b0 >
\00
[/code]0borÿÿtÿÿ[code]
\00ÿâ
\00ÿýÿàmain enter
HW Function test
Start Scheduler.
in late init
ÿâ
I> bit @ 0xd480000
I> Unpowergate done
I> Loading TOS ...
I> Loading EKS ...
I> Unhalting RCE
ÿâ
welcome to lk
dt initialized
mail initialized
chipid initialized
fuse initialized
sku initialized
speedo initialized
ec initialized
vmon initialized
adc initialized
fmon initialized
reset initialized
nvhs initialized
clk initialized
io_dpd initialized
thermal initialized
i2c initialized
aotag initialized
dvs initialized
pm initialized
pg_late initialized
strap initialized
tag initialized
emc initialized
clk_dt initialized
pm_post initialized
tj_init initialized
uphy_dt initialized
uphy initialized
mrq initialized
dmce initialized
cvc initialized
Starting OS
rm initialized
wake initialized
mail_fs initialized
profile initialized
ÿÿNvGpcDmaLibInitÿÿ
iÿÿ:ÿÿ
vÿÿHÿÿ
cÿÿyÿÿ
_ÿÿpÿÿ
qÿÿeÿÿ
uÿÿrÿÿ
eÿÿvÿÿ
uÿÿiÿÿ
eÿÿsÿÿ
ÿÿoÿÿ
nÿÿrÿÿ
oÿÿ ÿÿ
dÿÿMÿÿ
eÿÿoÿÿ
ÿÿdÿÿ
nÿÿeÿÿ
oÿÿ
ÿÿ
tÿÿ
ÿÿ
present
rÿÿ tÿÿ
eÿÿ aÿÿ
sÿÿ rÿÿ
eÿÿ tÿÿ
nÿÿ iÿÿ
tÿÿ nÿÿ
ÿÿ gÿÿ
ÿÿ app i2c_server
starting aÿÿ
sÿÿ pÿÿ
tÿÿ pÿÿ
aÿÿ ÿÿ
rÿÿ bÿÿ
tÿÿ pÿÿ
iÿÿ mÿÿ
nÿÿ pÿÿ
gÿÿ _iÿÿ
ÿÿ nÿÿ
aÿÿ cÿÿ
pÿÿ oÿÿ
p ÿÿ mÿÿ
gÿÿ iÿÿ
dÿÿ nÿÿ
bÿÿ gÿÿ
_ÿÿ
ÿÿ
aÿÿ
ÿÿ
gent
ÿÿ
ÿÿ
rver
D-S> ÿÿ Sever...
ÿÿVÿÿ
ÿÿC id 526
ÿÿpÿÿ
ÿÿ vÿÿRÿÿscÿÿeÿÿ
ÿÿserved IVC id 528
Reserved IVC id 529
Reserved IVC id 530
ÿÿ1
Reserved IVC id 532
Reserved IVC id 533
Reserved IVC id 534
Reserved IVC id 535
Reserved IVC id 536
Reserved IVC id 537
Reserved IVC id 538
Reserved IVC id 539
ÿÿaMMFLAGS=1
Starting RM server
Start nvpm server
Done...
ÿÿNÿÿ\00
ÿÿnÿÿ\00
ÿÿoÿÿ\00
GPRÿÿtÿÿ\00s:
ÿÿiÿÿ\00
ÿÿ\000000 ÿÿoÿÿ\00
x6: 0x000ÿÿfÿÿ
ÿÿ\001
ÿÿEÿÿ\00
ÿÿoÿÿ\000x2100bbÿÿ
ÿÿ\002c
0xÿÿ
ÿÿ\0021003ÿÿ
ÿÿnÿÿ\00514
0x210ÿÿpÿÿ\000155ÿÿ
ÿÿ\000ÿÿdÿÿ\00
0x21000184
Sÿÿpÿÿ\00iÿÿ
ÿÿ\00:
0x1766ÿÿ:ÿÿ\000
0x18350
0x12ÿÿ[ÿÿ\00070
ÿÿbÿÿbÿÿ
ÿÿ
ÿÿaÿÿ
ÿÿ
ÿÿbÿÿ
ÿÿ
ÿÿDÿÿ
ÿÿ1ÿÿ
ÿÿ
ÿÿSÿÿ
ÿÿ
ÿÿCÿÿ ÿÿCÿÿ
ÿÿ
ÿÿ ÿÿdÿÿ
ÿÿ
ÿÿCÿÿeÿÿ ÿÿ
ÿÿCÿÿ
ÿÿ
ÿÿ ÿÿ
ÿÿiÿÿ
ÿÿPÿÿ
ÿÿDÿÿ
ÿÿ:210035b0 >
\00
[/code]0t!
ÿÿNÿÿ[code]
\00ÿâ
\00ÿýÿàmain enter
HW Function test
Start Scheduler.
in late init
ÿâ
I> bit @ 0xd480000
I> Unpowergate done
I> Loading TOS ...
I> Loading EKS ...
I> Unhalting RCE
ÿâ
welcome to lk
dt initialized
mail initialized
chipid initialized
fuse initialized
sku initialized
speedo initialized
ec initialized
vmon initialized
adc initialized
fmon initialized
reset initialized
nvhs initialized
clk initialized
io_dpd initialized
thermal initialized
i2c initialized
aotag initialized
dvs initialized
pm initialized
pg_late initialized
strap initialized
tag initialized
emc initialized
clk_dt initialized
pm_post initialized
tj_init initialized
uphy_dt initialized
uphy initialized
mrq initialized
dmce initialized
cvc initialized
Starting OS
rm initialized
wake initialized
mail_fs initialized
profile initialized
ÿÿNvGpcDmaLibInitÿÿ
iÿÿ:ÿÿ
vÿÿHÿÿ
cÿÿyÿÿ
_ÿÿpÿÿ
qÿÿeÿÿ
uÿÿrÿÿ
eÿÿvÿÿ
uÿÿiÿÿ
eÿÿsÿÿ
ÿÿoÿÿ
nÿÿrÿÿ
oÿÿ ÿÿ
dÿÿMÿÿ
eÿÿoÿÿ
ÿÿdÿÿ
nÿÿeÿÿ
oÿÿ
ÿÿ
tÿÿ
ÿÿ
present
rÿÿ tÿÿ
eÿÿ aÿÿ
sÿÿ rÿÿ
eÿÿ tÿÿ
nÿÿ iÿÿ
tÿÿ nÿÿ
ÿÿ gÿÿ
ÿÿ app i2c_server
starting aÿÿ
sÿÿ pÿÿ
tÿÿ pÿÿ
aÿÿ ÿÿ
rÿÿ bÿÿ
tÿÿ pÿÿ
iÿÿ mÿÿ
nÿÿ pÿÿ
gÿÿ _iÿÿ
ÿÿ nÿÿ
aÿÿ cÿÿ
pÿÿ oÿÿ
p ÿÿ mÿÿ
gÿÿ iÿÿ
dÿÿ nÿÿ
bÿÿ gÿÿ
_ÿÿ
ÿÿ
aÿÿ
ÿÿ
gent
ÿÿ
ÿÿ
rver
D-S> ÿÿ Sever...
ÿÿVÿÿ
ÿÿC id 526
ÿÿpÿÿ
ÿÿ vÿÿRÿÿscÿÿeÿÿ
ÿÿserved IVC id 528
Reserved IVC id 529
Reserved IVC id 530
ÿÿ1
Reserved IVC id 532
Reserved IVC id 533
Reserved IVC id 534
Reserved IVC id 535
Reserved IVC id 536
Reserved IVC id 537
Reserved IVC id 538
Reserved IVC id 539
ÿÿaMMFLAGS=1
Starting RM server
Start nvpm server
Done...
ÿÿNÿÿ\00
ÿÿnÿÿ\00
ÿÿoÿÿ\00
GPRÿÿtÿÿ\00s:
ÿÿiÿÿ\00
ÿÿ\000000 ÿÿoÿÿ\00
x6: 0x000ÿÿfÿÿ
ÿÿ\001
ÿÿEÿÿ\00
ÿÿoÿÿ\000x2100bbÿÿ
ÿÿ\002c
0xÿÿ
ÿÿ\0021003ÿÿ
ÿÿnÿÿ\00514
0x210ÿÿpÿÿ\000155ÿÿ
ÿÿ\000ÿÿdÿÿ\00
0x21000184
Sÿÿpÿÿ\00iÿÿ
ÿÿ\00:
0x1766ÿÿ:ÿÿ\000
0x18350
0x12ÿÿ[ÿÿ\00070
ÿÿbÿÿbÿÿ
ÿÿ
ÿÿaÿÿ
ÿÿ
ÿÿbÿÿ
ÿÿ
ÿÿDÿÿ
ÿÿ1ÿÿ
ÿÿ
ÿÿSÿÿ
ÿÿ
ÿÿCÿÿ ÿÿCÿÿ
ÿÿ
ÿÿ ÿÿdÿÿ
ÿÿ
ÿÿCÿÿeÿÿ ÿÿ
ÿÿCÿÿ
ÿÿ
ÿÿ ÿÿ
ÿÿiÿÿ
ÿÿPÿÿ
ÿÿDÿÿ
ÿÿ:210035b0 >
\00
[/code]0
VM Stÿÿoÿÿ[code]
\00ÿâ
\00ÿýÿàmain enter
HW Function test
Start Scheduler.
in late init
ÿâ
I> bit @ 0xd480000
I> Unpowergate done
I> Loading TOS ...
I> Loading EKS ...
I> Unhalting RCE
ÿâ
welcome to lk
dt initialized
mail initialized
chipid initialized
fuse initialized
sku initialized
speedo initialized
ec initialized
vmon initialized
adc initialized
fmon initialized
reset initialized
nvhs initialized
clk initialized
io_dpd initialized
thermal initialized
i2c initialized
aotag initialized
dvs initialized
pm initialized
pg_late initialized
strap initialized
tag initialized
emc initialized
clk_dt initialized
pm_post initialized
tj_init initialized
uphy_dt initialized
uphy initialized
mrq initialized
dmce initialized
cvc initialized
Starting OS
rm initialized
wake initialized
mail_fs initialized
profile initialized
ÿÿNvGpcDmaLibInitÿÿ
iÿÿ:ÿÿ
vÿÿHÿÿ
cÿÿyÿÿ
_ÿÿpÿÿ
qÿÿeÿÿ
uÿÿrÿÿ
eÿÿvÿÿ
uÿÿiÿÿ
eÿÿsÿÿ
ÿÿoÿÿ
nÿÿrÿÿ
oÿÿ ÿÿ
dÿÿMÿÿ
eÿÿoÿÿ
ÿÿdÿÿ
nÿÿeÿÿ
oÿÿ
ÿÿ
tÿÿ
ÿÿ
present
rÿÿ tÿÿ
eÿÿ aÿÿ
sÿÿ rÿÿ
eÿÿ tÿÿ
nÿÿ iÿÿ
tÿÿ nÿÿ
ÿÿ gÿÿ
ÿÿ app i2c_server
starting aÿÿ
sÿÿ pÿÿ
tÿÿ pÿÿ
aÿÿ ÿÿ
rÿÿ bÿÿ
tÿÿ pÿÿ
iÿÿ mÿÿ
nÿÿ pÿÿ
gÿÿ _iÿÿ
ÿÿ nÿÿ
aÿÿ cÿÿ
pÿÿ oÿÿ
p ÿÿ mÿÿ
gÿÿ iÿÿ
dÿÿ nÿÿ
bÿÿ gÿÿ
_ÿÿ
ÿÿ
aÿÿ
ÿÿ
gent
ÿÿ
ÿÿ
rver
D-S> ÿÿ Sever...
ÿÿVÿÿ
ÿÿC id 526
ÿÿpÿÿ
ÿÿ vÿÿRÿÿscÿÿeÿÿ
ÿÿserved IVC id 528
Reserved IVC id 529
Reserved IVC id 530
ÿÿ1
Reserved IVC id 532
Reserved IVC id 533
Reserved IVC id 534
Reserved IVC id 535
Reserved IVC id 536
Reserved IVC id 537
Reserved IVC id 538
Reserved IVC id 539
ÿÿaMMFLAGS=1
Starting RM server
Start nvpm server
Done...
ÿÿNÿÿ\00
ÿÿnÿÿ\00
ÿÿoÿÿ\00
GPRÿÿtÿÿ\00s:
ÿÿiÿÿ\00
ÿÿ\000000 ÿÿoÿÿ\00
x6: 0x000ÿÿfÿÿ
ÿÿ\001
ÿÿEÿÿ\00
ÿÿoÿÿ\000x2100bbÿÿ
ÿÿ\002c
0xÿÿ
ÿÿ\0021003ÿÿ
ÿÿnÿÿ\00514
0x210ÿÿpÿÿ\000155ÿÿ
ÿÿ\000ÿÿdÿÿ\00
0x21000184
Sÿÿpÿÿ\00iÿÿ
ÿÿ\00:
0x1766ÿÿ:ÿÿ\000
0x18350
0x12ÿÿ[ÿÿ\00070
ÿÿbÿÿbÿÿ
ÿÿ
ÿÿaÿÿ
ÿÿ
ÿÿbÿÿ
ÿÿ
ÿÿDÿÿ
ÿÿ1ÿÿ
ÿÿ
ÿÿSÿÿ
ÿÿ
ÿÿCÿÿ ÿÿCÿÿ
ÿÿ
ÿÿ ÿÿdÿÿ
ÿÿ
ÿÿCÿÿeÿÿ ÿÿ
ÿÿCÿÿ
ÿÿ
ÿÿ ÿÿ
ÿÿiÿÿ
ÿÿPÿÿ
ÿÿDÿÿ
ÿÿ:210035b0 >
\00
[/code]0atÿÿFÿÿ[code]
\00ÿâ
\00ÿýÿàmain enter
HW Function test
Start Scheduler.
in late init
ÿâ
I> bit @ 0xd480000
I> Unpowergate done
I> Loading TOS ...
I> Loading EKS ...
I> Unhalting RCE
ÿâ
welcome to lk
dt initialized
mail initialized
chipid initialized
fuse initialized
sku initialized
speedo initialized
ec initialized
vmon initialized
adc initialized
fmon initialized
reset initialized
nvhs initialized
clk initialized
io_dpd initialized
thermal initialized
i2c initialized
aotag initialized
dvs initialized
pm initialized
pg_late initialized
strap initialized
tag initialized
emc initialized
clk_dt initialized
pm_post initialized
tj_init initialized
uphy_dt initialized
uphy initialized
mrq initialized
dmce initialized
cvc initialized
Starting OS
rm initialized
wake initialized
mail_fs initialized
profile initialized
ÿÿNvGpcDmaLibInitÿÿ
iÿÿ:ÿÿ
vÿÿHÿÿ
cÿÿyÿÿ
_ÿÿpÿÿ
qÿÿeÿÿ
uÿÿrÿÿ
eÿÿvÿÿ
uÿÿiÿÿ
eÿÿsÿÿ
ÿÿoÿÿ
nÿÿrÿÿ
oÿÿ ÿÿ
dÿÿMÿÿ
eÿÿoÿÿ
ÿÿdÿÿ
nÿÿeÿÿ
oÿÿ
ÿÿ
tÿÿ
ÿÿ
present
rÿÿ tÿÿ
eÿÿ aÿÿ
sÿÿ rÿÿ
eÿÿ tÿÿ
nÿÿ iÿÿ
tÿÿ nÿÿ
ÿÿ gÿÿ
ÿÿ app i2c_server
starting aÿÿ
sÿÿ pÿÿ
tÿÿ pÿÿ
aÿÿ ÿÿ
rÿÿ bÿÿ
tÿÿ pÿÿ
iÿÿ mÿÿ
nÿÿ pÿÿ
gÿÿ _iÿÿ
ÿÿ nÿÿ
aÿÿ cÿÿ
pÿÿ oÿÿ
p ÿÿ mÿÿ
gÿÿ iÿÿ
dÿÿ nÿÿ
bÿÿ gÿÿ
_ÿÿ
ÿÿ
aÿÿ
ÿÿ
gent
ÿÿ
ÿÿ
rver
D-S> ÿÿ Sever...
ÿÿVÿÿ
ÿÿC id 526
ÿÿpÿÿ
ÿÿ vÿÿRÿÿscÿÿeÿÿ
ÿÿserved IVC id 528
Reserved IVC id 529
Reserved IVC id 530
ÿÿ1
Reserved IVC id 532
Reserved IVC id 533
Reserved IVC id 534
Reserved IVC id 535
Reserved IVC id 536
Reserved IVC id 537
Reserved IVC id 538
Reserved IVC id 539
ÿÿaMMFLAGS=1
Starting RM server
Start nvpm server
Done...
ÿÿNÿÿ\00
ÿÿnÿÿ\00
ÿÿoÿÿ\00
GPRÿÿtÿÿ\00s:
ÿÿiÿÿ\00
ÿÿ\000000 ÿÿoÿÿ\00
x6: 0x000ÿÿfÿÿ
ÿÿ\001
ÿÿEÿÿ\00
ÿÿoÿÿ\000x2100bbÿÿ
ÿÿ\002c
0xÿÿ
ÿÿ\0021003ÿÿ
ÿÿnÿÿ\00514
0x210ÿÿpÿÿ\000155ÿÿ
ÿÿ\000ÿÿdÿÿ\00
0x21000184
Sÿÿpÿÿ\00iÿÿ
ÿÿ\00:
0x1766ÿÿ:ÿÿ\000
0x18350
0x12ÿÿ[ÿÿ\00070
ÿÿbÿÿbÿÿ
ÿÿ
ÿÿaÿÿ
ÿÿ
ÿÿbÿÿ
ÿÿ
ÿÿDÿÿ
ÿÿ1ÿÿ
ÿÿ
ÿÿSÿÿ
ÿÿ
ÿÿCÿÿ ÿÿCÿÿ
ÿÿ
ÿÿ ÿÿdÿÿ
ÿÿ
ÿÿCÿÿeÿÿ ÿÿ
ÿÿCÿÿ
ÿÿ
ÿÿ ÿÿ
ÿÿiÿÿ
ÿÿPÿÿ
ÿÿDÿÿ
ÿÿ:210035b0 >
\00
[/code]0e:
Vÿÿoÿÿ[code]
\00ÿâ
\00ÿýÿàmain enter
HW Function test
Start Scheduler.
in late init
ÿâ
I> bit @ 0xd480000
I> Unpowergate done
I> Loading TOS ...
I> Loading EKS ...
I> Unhalting RCE
ÿâ
welcome to lk
dt initialized
mail initialized
chipid initialized
fuse initialized
sku initialized
speedo initialized
ec initialized
vmon initialized
adc initialized
fmon initialized
reset initialized
nvhs initialized
clk initialized
io_dpd initialized
thermal initialized
i2c initialized
aotag initialized
dvs initialized
pm initialized
pg_late initialized
strap initialized
tag initialized
emc initialized
clk_dt initialized
pm_post initialized
tj_init initialized
uphy_dt initialized
uphy initialized
mrq initialized
dmce initialized
cvc initialized
Starting OS
rm initialized
wake initialized
mail_fs initialized
profile initialized
ÿÿNvGpcDmaLibInitÿÿ
iÿÿ:ÿÿ
vÿÿHÿÿ
cÿÿyÿÿ
_ÿÿpÿÿ
qÿÿeÿÿ
uÿÿrÿÿ
eÿÿvÿÿ
uÿÿiÿÿ
eÿÿsÿÿ
ÿÿoÿÿ
nÿÿrÿÿ
oÿÿ ÿÿ
dÿÿMÿÿ
eÿÿoÿÿ
ÿÿdÿÿ
nÿÿeÿÿ
oÿÿ
ÿÿ
tÿÿ
ÿÿ
present
rÿÿ tÿÿ
eÿÿ aÿÿ
sÿÿ rÿÿ
eÿÿ tÿÿ
nÿÿ iÿÿ
tÿÿ nÿÿ
ÿÿ gÿÿ
ÿÿ app i2c_server
starting aÿÿ
sÿÿ pÿÿ
tÿÿ pÿÿ
aÿÿ ÿÿ
rÿÿ bÿÿ
tÿÿ pÿÿ
iÿÿ mÿÿ
nÿÿ pÿÿ
gÿÿ _iÿÿ
ÿÿ nÿÿ
aÿÿ cÿÿ
pÿÿ oÿÿ
p ÿÿ mÿÿ
gÿÿ iÿÿ
dÿÿ nÿÿ
bÿÿ gÿÿ
_ÿÿ
ÿÿ
aÿÿ
ÿÿ
gent
ÿÿ
ÿÿ
rver
D-S> ÿÿ Sever...
ÿÿVÿÿ
ÿÿC id 526
ÿÿpÿÿ
ÿÿ vÿÿRÿÿscÿÿeÿÿ
ÿÿserved IVC id 528
Reserved IVC id 529
Reserved IVC id 530
ÿÿ1
Reserved IVC id 532
Reserved IVC id 533
Reserved IVC id 534
Reserved IVC id 535
Reserved IVC id 536
Reserved IVC id 537
Reserved IVC id 538
Reserved IVC id 539
ÿÿaMMFLAGS=1
Starting RM server
Start nvpm server
Done...
ÿÿNÿÿ\00
ÿÿnÿÿ\00
ÿÿoÿÿ\00
GPRÿÿtÿÿ\00s:
ÿÿiÿÿ\00
ÿÿ\000000 ÿÿoÿÿ\00
x6: 0x000ÿÿfÿÿ
ÿÿ\001
ÿÿEÿÿ\00
ÿÿoÿÿ\000x2100bbÿÿ
ÿÿ\002c
0xÿÿ
ÿÿ\0021003ÿÿ
ÿÿnÿÿ\00514
0x210ÿÿpÿÿ\000155ÿÿ
ÿÿ\000ÿÿdÿÿ\00
0x21000184
Sÿÿpÿÿ\00iÿÿ
ÿÿ\00:
0x1766ÿÿ:ÿÿ\000
0x18350
0x12ÿÿ[ÿÿ\00070
ÿÿbÿÿbÿÿ
ÿÿ
ÿÿaÿÿ
ÿÿ
ÿÿbÿÿ
ÿÿ
ÿÿDÿÿ
ÿÿ1ÿÿ
ÿÿ
ÿÿSÿÿ
ÿÿ
ÿÿCÿÿ ÿÿCÿÿ
ÿÿ
ÿÿ ÿÿdÿÿ
ÿÿ
ÿÿCÿÿeÿÿ ÿÿ
ÿÿCÿÿ
ÿÿ
ÿÿ ÿÿ
ÿÿiÿÿ
ÿÿPÿÿ
ÿÿDÿÿ
ÿÿ:210035b0 >
\00
[/code]0CPU ID: 0xÿÿtÿÿiÿÿ[code]
\00ÿâ
\00ÿýÿàmain enter
HW Function test
Start Scheduler.
in late init
ÿâ
I> bit @ 0xd480000
I> Unpowergate done
I> Loading TOS ...
I> Loading EKS ...
I> Unhalting RCE
ÿâ
welcome to lk
dt initialized
mail initialized
chipid initialized
fuse initialized
sku initialized
speedo initialized
ec initialized
vmon initialized
adc initialized
fmon initialized
reset initialized
nvhs initialized
clk initialized
io_dpd initialized
thermal initialized
i2c initialized
aotag initialized
dvs initialized
pm initialized
pg_late initialized
strap initialized
tag initialized
emc initialized
clk_dt initialized
pm_post initialized
tj_init initialized
uphy_dt initialized
uphy initialized
mrq initialized
dmce initialized
cvc initialized
Starting OS
rm initialized
wake initialized
mail_fs initialized
profile initialized
ÿÿNvGpcDmaLibInitÿÿ
iÿÿ:ÿÿ
vÿÿHÿÿ
cÿÿyÿÿ
_ÿÿpÿÿ
qÿÿeÿÿ
uÿÿrÿÿ
eÿÿvÿÿ
uÿÿiÿÿ
eÿÿsÿÿ
ÿÿoÿÿ
nÿÿrÿÿ
oÿÿ ÿÿ
dÿÿMÿÿ
eÿÿoÿÿ
ÿÿdÿÿ
nÿÿeÿÿ
oÿÿ
ÿÿ
tÿÿ
ÿÿ
present
rÿÿ tÿÿ
eÿÿ aÿÿ
sÿÿ rÿÿ
eÿÿ tÿÿ
nÿÿ iÿÿ
tÿÿ nÿÿ
ÿÿ gÿÿ
ÿÿ app i2c_server
starting aÿÿ
sÿÿ pÿÿ
tÿÿ pÿÿ
aÿÿ ÿÿ
rÿÿ bÿÿ
tÿÿ pÿÿ
iÿÿ mÿÿ
nÿÿ pÿÿ
gÿÿ _iÿÿ
ÿÿ nÿÿ
aÿÿ cÿÿ
pÿÿ oÿÿ
p ÿÿ mÿÿ
gÿÿ iÿÿ
dÿÿ nÿÿ
bÿÿ gÿÿ
_ÿÿ
ÿÿ
aÿÿ
ÿÿ
gent
ÿÿ
ÿÿ
rver
D-S> ÿÿ Sever...
ÿÿVÿÿ
ÿÿC id 526
ÿÿpÿÿ
ÿÿ vÿÿRÿÿscÿÿeÿÿ
ÿÿserved IVC id 528
Reserved IVC id 529
Reserved IVC id 530
ÿÿ1
Reserved IVC id 532
Reserved IVC id 533
Reserved IVC id 534
Reserved IVC id 535
Reserved IVC id 536
Reserved IVC id 537
Reserved IVC id 538
Reserved IVC id 539
ÿÿaMMFLAGS=1
Starting RM server
Start nvpm server
Done...
ÿÿNÿÿ\00
ÿÿnÿÿ\00
ÿÿoÿÿ\00
GPRÿÿtÿÿ\00s:
ÿÿiÿÿ\00
ÿÿ\000000 ÿÿoÿÿ\00
x6: 0x000ÿÿfÿÿ
ÿÿ\001
ÿÿEÿÿ\00
ÿÿoÿÿ\000x2100bbÿÿ
ÿÿ\002c
0xÿÿ
ÿÿ\0021003ÿÿ
ÿÿnÿÿ\00514
0x210ÿÿpÿÿ\000155ÿÿ
ÿÿ\000ÿÿdÿÿ\00
0x21000184
Sÿÿpÿÿ\00iÿÿ
ÿÿ\00:
0x1766ÿÿ:ÿÿ\000
0x18350
0x12ÿÿ[ÿÿ\00070
ÿÿbÿÿbÿÿ
ÿÿ
ÿÿaÿÿ
ÿÿ
ÿÿbÿÿ
ÿÿ
ÿÿDÿÿ
ÿÿ1ÿÿ
ÿÿ
ÿÿSÿÿ
ÿÿ
ÿÿCÿÿ ÿÿCÿÿ
ÿÿ
ÿÿ ÿÿdÿÿ
ÿÿ
ÿÿCÿÿeÿÿ ÿÿ
ÿÿCÿÿ
ÿÿ
ÿÿ ÿÿ
ÿÿiÿÿ
ÿÿPÿÿ
ÿÿDÿÿ
ÿÿ:210035b0 >
\00
[/code]00
PC:ÿÿ ÿÿ[code]
\00ÿâ
\00ÿýÿàmain enter
HW Function test
Start Scheduler.
in late init
ÿâ
I> bit @ 0xd480000
I> Unpowergate done
I> Loading TOS ...
I> Loading EKS ...
I> Unhalting RCE
ÿâ
welcome to lk
dt initialized
mail initialized
chipid initialized
fuse initialized
sku initialized
speedo initialized
ec initialized
vmon initialized
adc initialized
fmon initialized
reset initialized
nvhs initialized
clk initialized
io_dpd initialized
thermal initialized
i2c initialized
aotag initialized
dvs initialized
pm initialized
pg_late initialized
strap initialized
tag initialized
emc initialized
clk_dt initialized
pm_post initialized
tj_init initialized
uphy_dt initialized
uphy initialized
mrq initialized
dmce initialized
cvc initialized
Starting OS
rm initialized
wake initialized
mail_fs initialized
profile initialized
ÿÿNvGpcDmaLibInitÿÿ
iÿÿ:ÿÿ
vÿÿHÿÿ
cÿÿyÿÿ
_ÿÿpÿÿ
qÿÿeÿÿ
uÿÿrÿÿ
eÿÿvÿÿ
uÿÿiÿÿ
eÿÿsÿÿ
ÿÿoÿÿ
nÿÿrÿÿ
oÿÿ ÿÿ
dÿÿMÿÿ
eÿÿoÿÿ
ÿÿdÿÿ
nÿÿeÿÿ
oÿÿ
ÿÿ
tÿÿ
ÿÿ
present
rÿÿ tÿÿ
eÿÿ aÿÿ
sÿÿ rÿÿ
eÿÿ tÿÿ
nÿÿ iÿÿ
tÿÿ nÿÿ
ÿÿ gÿÿ
ÿÿ app i2c_server
starting aÿÿ
sÿÿ pÿÿ
tÿÿ pÿÿ
aÿÿ ÿÿ
rÿÿ bÿÿ
tÿÿ pÿÿ
iÿÿ mÿÿ
nÿÿ pÿÿ
gÿÿ _iÿÿ
ÿÿ nÿÿ
aÿÿ cÿÿ
pÿÿ oÿÿ
p ÿÿ mÿÿ
gÿÿ iÿÿ
dÿÿ nÿÿ
bÿÿ gÿÿ
_ÿÿ
ÿÿ
aÿÿ
ÿÿ
gent
ÿÿ
ÿÿ
rver
D-S> ÿÿ Sever...
ÿÿVÿÿ
ÿÿC id 526
ÿÿpÿÿ
ÿÿ vÿÿRÿÿscÿÿeÿÿ
ÿÿserved IVC id 528
Reserved IVC id 529
Reserved IVC id 530
ÿÿ1
Reserved IVC id 532
Reserved IVC id 533
Reserved IVC id 534
Reserved IVC id 535
Reserved IVC id 536
Reserved IVC id 537
Reserved IVC id 538
Reserved IVC id 539
ÿÿaMMFLAGS=1
Starting RM server
Start nvpm server
Done...
ÿÿNÿÿ\00
ÿÿnÿÿ\00
ÿÿoÿÿ\00
GPRÿÿtÿÿ\00s:
ÿÿiÿÿ\00
ÿÿ\000000 ÿÿoÿÿ\00
x6: 0x000ÿÿfÿÿ
ÿÿ\001
ÿÿEÿÿ\00
ÿÿoÿÿ\000x2100bbÿÿ
ÿÿ\002c
0xÿÿ
ÿÿ\0021003ÿÿ
ÿÿnÿÿ\00514
0x210ÿÿpÿÿ\000155ÿÿ
ÿÿ\000ÿÿdÿÿ\00
0x21000184
Sÿÿpÿÿ\00iÿÿ
ÿÿ\00:
0x1766ÿÿ:ÿÿ\000
0x18350
0x12ÿÿ[ÿÿ\00070
ÿÿbÿÿbÿÿ
ÿÿ
ÿÿaÿÿ
ÿÿ
ÿÿbÿÿ
ÿÿ
ÿÿDÿÿ
ÿÿ1ÿÿ
ÿÿ
ÿÿSÿÿ
ÿÿ
ÿÿCÿÿ ÿÿCÿÿ
ÿÿ
ÿÿ ÿÿdÿÿ
ÿÿ
ÿÿCÿÿeÿÿ ÿÿ
ÿÿCÿÿ
ÿÿ
ÿÿ ÿÿ
ÿÿiÿÿ
ÿÿPÿÿ
ÿÿDÿÿ
ÿÿ:210035b0 >
\00
[/code]0 0x21009750ÿÿ ÿÿ[code]
\00ÿâ
[0000.024] I> MISCREG_HIDREV_0: 0x21917
[0000.028] I> MB1 (prd-version: 00.22.180704-t194-39702425-7fcf5198)
[0000.034] I> Boot-mode: L0 coldboot
[0000.037] I> chip revision : A02
[0000.040] I> Bootrom patch version : 3 (correctly patched)
[0000.045] I> ATE fuse revision : 0x200
[0000.049] I> Ram repair fuse : 0x0
[0000.052] I> rst_source : 0x0
[0000.054] I> rst_level : 0x0
[0000.057] E> Last boot error: 0x00000000
[0000.061] I> Soft fuse initialized
[0000.064] I> Boot WARS Applied
[0000.067] I> Boot-device: QSPI
[0000.070] I> qspi flash params source = brbct
[0000.074] I> Qspi using bpmp-dma
[0000.077] I> Qspi clock source : pllp
[0000.080] I> QSPI Flash: Spansion 64MB
[0000.084] I> QSPI Flash Size = 64 MB
[0000.089] I> QSPI Flash: Set 512B page size
[0000.093] I> Qspi initialized successfully
[0000.097] I> Loading MB1-BCT to SysRAM
[0000.100] I> Boot-device: QSPI
[0000.103] I> Binary@ device:3/0 block-1536 (partition size: 0x20000)
[0000.109] I> qspi flash params source = brbct
[0000.114] I> Binary mb1bct loaded successfully at 0x40000000
[0000.120] I> MB1-BCT relocated to 0xd48bc00 from 0x40000000
[0000.125] I> Loading MEM-BCT to SysRAM
[0000.128] I> Binary@ device:3/0 block-2048 (partition size: 0x40000)
[0000.134] I> qspi flash params source = mb1bct
[0000.138] I> Qspi using bpmp-dma
[0000.141] I> Qspi clock source : pllp
[0000.145] I> Qspi reinitialized
[0000.149] I> Binary membct loaded successfully at 0x40000000
[0000.155] I> SDRAM params relocated to 0xd493400 from 0x40000000
[0000.160] I> SDRAM pack relocated to 0xd495c00 from 0x40000000
[0000.166] E> No fuse-bypass data
[0000.171] I> temperature = 31500
[0000.174] W> Skipping boost for clk:aon_cpu_nic
[0000.178] W> Skipping boost for clk:aon_can0
[0000.182] W> Skipping boost for clk:aon_can1
[0000.186] E> MB1_PLATFORM_CONFIG: prod table is empty in MB1 BCT.
[0000.192] I> Boot-device: QSPI
[0000.195] I> Boot-device: QSPI
[0000.198] I> qspi flash params source = mb1bct
[0000.202] I> Binary@ device:3/0 block-2560 (partition size: 0x40000)
[0000.208] I> qspi flash params source = mb1bct
[0000.214] I> Binary spe-fw loaded successfully at 0x40000000
[0000.221] I> ECC region[0]: Start:0x0, End:0x0
[0000.226] I> ECC region[1]: Start:0x0, End:0x0
[0000.230] I> ECC region[2]: Start:0x0, End:0x0
[0000.234] I> ECC region[3]: Start:0x0, End:0x0
[0000.238] I> ECC region[4]: Start:0x0, End:0x0
[0000.242] I> ECC region[5]: Start:0x0, End:0x0
[0000.246] I> Non-ECC region[0]: Start:0x80000000, End:0x100000000
[0000.252] I> Non-ECC region[1]: Start:0x0, End:0x0
[0000.256] I> Non-ECC region[2]: Start:0x0, End:0x0
[0000.261] I> Non-ECC region[3]: Start:0x0, End:0x0
[0000.265] I> Non-ECC region[4]: Start:0x0, End:0x0
[0000.269] I> Non-ECC region[5]: Start:0x0, End:0x0
[0000.274] I> Added Block:1 Start:0x80000000 End:0x100000000
[0000.280] I> allocated(CO:32) base:0xf8000000 size:0x8000000 align: 0x8000000
[0000.287] I> allocated(CO:33) base:0xf0000000 size:0x8000000 align: 0x100000
[0000.294] I> allocated(CO:38) base:0x80000000 size:0x8000000 align: 0x200000
[0000.301] I> allocated(CO:39) base:0x88000000 size:0x8000000 align: 0x8000000
[0000.307] I> allocated(CO:36) base:0x95a00000 size:0x4000000 align: 0x200000
[0000.314] I> allocated(CO:24) base:0xee000000 size:0x2000000 align: 0x2000000
[0000.321] I> allocated(CO:28) base:0xecc00000 size:0x1400000 align: 0x200000
[0000.327] I> allocated(CO:34) base:0xebc00000 size:0x1000000 align: 0x0
[0000.334] I> allocated(CO:35) base:0x90000000 size:0x1000000 align: 0x1000000
[0000.340] I> allocated(CO:7) base:0xeb000000 size:0x800000 align: 0x800000
[0000.347] I> allocated(CO:10) base:0xea800000 size:0x800000 align: 0x800000
[0000.353] I> allocated(CO:37) base:0xea000000 size:0x800000 align: 0x800000
[0000.360] I> allocated(CO:19) base:0xe9a00000 size:0x600000 align: 0x200000
[0000.366] I> allocated(CO:6) base:0xeb800000 size:0x400000 align: 0x200000
[0000.373] I> allocated(CO:27) base:0xe9600000 size:0x400000 align: 0x200000
[0000.380] I> allocated(CO:29) base:0xe9200000 size:0x400000 align: 0x200000
[0000.386] I> allocated(CO:1) base:0xe9100000 size:0x100000 align: 0x100000
[0000.393] I> allocated(CO:2) base:0xe9000000 size:0x100000 align: 0x100000
[0000.399] I> allocated(CO:3) base:0xe8f00000 size:0x100000 align: 0x100000
[0000.406] I> allocated(CO:4) base:0xe8e00000 size:0x100000 align: 0x100000
[0000.412] I> allocated(CO:5) base:0xe8d00000 size:0x100000 align: 0x100000
[0000.419] I> allocated(CO:8) base:0xe8c00000 size:0x100000 align: 0x100000
[0000.425] I> allocated(CO:9) base:0xe8b00000 size:0x100000 align: 0x100000
[0000.431] I> allocated(CO:12) base:0xe8a00000 size:0x100000 align: 0x100000
[0000.438] I> allocated(CO:17) base:0xe8900000 size:0x100000 align: 0x100000
[0000.445] I> allocated(CO:21) base:0xe88f0000 size:0x10000 align: 0x0
[0000.451] > MB1_PLATFORM_CONFIG: Rail ID 9 not found in pmic rail config table.
[0000.458] E> FAILED: Thermal config
[0000.465] > MB1_PLATFORM_CONFIG: Rail ID 7 not found in pmic rail config table.
[0000.472] E> FAILED: MEMIO rail config
[0000.475] I> MSS code-drop: NvBootSdramInit
[0000.492] I> scrub mode: full dram
[0000.495] E> Error: ECID of check failed!!
[0000.499] E> MB1 BCT does not have SCR table
[0000.503] I> Binary@ device:3/0 block-4608 (partition size: 0x40000)
[0000.509] I> qspi flash params source = mb1bct
[0000.523] I> RSA PSS signature check: OK
[0000.527] I> Binary preboot loaded successfully at 0x40000040
[0000.534] I> Restrict GSC#31 access to DPMU only
[0000.538] I> WP-0 triggered
[0000.540] I> WP-0 ACK received :)
[0000.544] I> CPU reset vector: 0x40000000
[0000.547] I> MTS carveout BOM: 0xff000000
[0000.551] I> MC_MTS_CARVEOUT_SIZE_MB_0: 0x10
[0000.555] I> Loading MCE
[0000.557] I> Binary@ device:3/0 block-5120 (partition size: 0x80000)
[0000.563] I> qspi flash params source = mb1bct
[0000.578] I> RSA PSS signature check: OK
[0000.585] I> Binary MCE loaded successfully at 0xbf080000
[0000.594] I> Loading MTS
[0000.596] I> Binary@ device:3/0 block-6144 (partition size: 0x400000)
[0000.602] I> qspi flash params source = mb1bct
[0000.661] I> Binary MTS loaded successfully at 0xbfa00000
[0000.678] I> WP-1 triggered
[0000.683] I> WP-1 ACK received :)
[0000.686] I> MTS carveout BOM: 0xf8000000
[0000.690] I> WP1.5 triggered
[0000.693] I> WP1.5 ACK received :)
[0000.696] E> MB1_PLATFORM_CONFIG: Bootrom mmio i2c table is empty in MB1 BCT.
[0000.703] I> Loading MB2
[0000.705] I> Binary@ device:3/0 block-3072 (partition size: 0x40000)
[0000.711] I> qspi flash params source = mb1bct
[0000.718] I> Binary mb2 loaded successfully at 0x52000000
[0000.723] I> co:0 offset:0x70000000
[0000.726] I> MB2-params @ 0x70000000
[0000.730] I> co:4 offset:0x70010000
[0000.733] I> co:1 offset:0x70020000
[0000.737] I> CO:(35) safe offset:0x53000000
[0000.741] I> CO:(37) safe offset:0x70030000
[0000.745] > MB1_PLATFORM_CONFIG: Rail ID 8 not found in pmic rail config table.
[0000.752] I> MB1 done
\00ÿýÿàmain enter
SPE VERSION #: R01.00.07 Created: Mar 21 2018 @ 15:14:19
HW Function test
Start Scheduler.
in late init
ÿâ
I> Welcome to MB2(TBoot-BPMP)
I> mb2 Safe end :0x52700000 mb2 safe start :0x52032044
I> co:0 offset:0x52700000
I> DMA Heap @ [0x52700000 - 0x53000000]
I> Default Heap @ [0xd486400 - 0xd488400]
I> qspi flash-0 params source = boot args
I> bit @ 0xd480000
I> Found 20 partitions in 00030000 device
I> co:8 offset:0x70030000
I> GR Blob not found or corrupted. Skipping GR Dump for MB1 Stage
I> Binary@ device:3/0 block-20480 (partition size: 0x100000)
I> header load address is : 0x5202fdf0
I> header of binary bpmp-fw read from storage device 3(0)
I> oem authentication of bpmp-fw header done
I> component list is filled with contents from header
I> parsing oem signed section of bpmp-fw header done
I> updated handle with bpmp-fw info. from oem comp table
I> bpmp-fw binary read from storage
I> Binary@ device:3/0 block-22528 (partition size: 0x100000)
I> header of binary bpmp-fw-dtb read from storage device 3(0)
I> oem authentication of bpmp-fw-dtb header done
I> parsing oem signed section of bpmp-fw-dtb header done
I> updated handle with bpmp-fw-dtb info. from oem comp table
I> bpmp-fw-dtb binary read from storage
I> BPMP-FW load address = 0x50000000
I> BPMP-FW DTB load address = 0x503e43a0
I> Loading SCE-FW ...
I> Binary@ device:3/0 block-24576 (partition size: 0x80000)
I> header of binary sce read from storage device 3(0)
I> oem authentication of sce header done
I> parsing oem signed section of sce header done
I> updated handle with sce info. from oem comp table
I> sce binary read from storage
I> Loading RCE-FW ...
I> Binary@ device:3/0 block-25600 (partition size: 0x80000)
I> header of binary rce read from storage device 3(0)
I> oem authentication of rce header done
I> parsing oem signed section of rce header done
I> updated handle with rce info. from oem comp table
I> rce binary read from storage
I> Unpowergating APE
I> Unpowergate done
I> Loading APE-FW ...
I> Binary@ device:3/0 block-26624 (partition size: 0x200000)
I> header of binary ape read from storage device 3(0)
I> oem authentication of ape header done
I> parsing oem signed section of ape header done
I> updated handle with ape info. from oem comp table
I> ape binary read from storage
I> Copy BTCM section
I> Binary@ device:3/0 block-14336 (partition size: 0x80000)
I> header of binary cpubl read from storage device 3(0)
I> oem authentication of cpubl header done
I> parsing oem signed section of cpubl header done
I> updated handle with cpubl info. from oem comp table
I> cpubl binary read from storage
I> co:4 offset:0x70040000
I> CPUBL-params @ 0x70040000
I> co:5 offset:0x70050000
I> Relocating BR-BCT
I> co:6 offset:0x70060000
I> BRBCT @ 0x40066c00
I> BR-BCT relocated to 0x70060000
I> CPU-BL loaded at : 0x96000000
I> Loading TOS ...
I> Binary@ device:3/0 block-15360 (partition size: 0x280000)
I> header of binary tos read from storage device 3(0)
I> oem authentication of tos header done
I> parsing oem signed section of tos header done
I> updated handle with tos info. from oem comp table
I> tos binary read from storage
I> TOS params:@0x52d02410
I> TLK boot-params @ 0x52d02410
I> TLK params prepared
I> Loading EKS ...
I> Binary@ device:3/0 block-30720 (partition size: 0x40000)
I> header of binary eks read from storage device 3(0)
I> oem authentication of eks header done
I> parsing oem signed section of eks header done
I> updated handle with eks info. from oem comp table
I> eks binary read from storage
I> EKS (length: 0x5000) @ 0x52d07800
I> Copied encrypted keys
I> Copying Monitor (length: 0x17170) from 0x52702600 to 0x40000000
I> Erasing Monitor @ 0x52702600
I> tos-params: tzdram_size: 0x1000000
I> tos-params: tzdram_base: 0xebc00000
I> tos-params: uart_port_id: 254
I> Copying TOS (length: 0x13e1d0) from 0x52719770 to 0xabc40000
I> Waypoint2-ACK: 0x52014d64
I> SCR config list empty
I> Unhalting RCE
I> GR Blob not found or corrupted. Skipping GR Dump for MB2 Stage
ÿäNOTICE: BL31: v1.3(release):934cbe7
NOTICE: BL31: Built : 10:49:22, Sep 4 2018
ÿâ
welcome to lk
ÿäÿâbpmp: platform_init
dt initialized
mail initialized
chipid initialized
fuse initialized
sku initialized
speedo initialized
ec initialized
vmon_populate_monitors: found 1 monitors
vmon initialized
vmon_soc_self_check: vmon_vsoc: self-check passed
adc initialized
fmon_populate_monitors: found 73 monitors
vrefro_re_cal: VrefRO: adjusted 0x82=>0x86
fmon_soc_ops_init: re-start disabled FMON_OSCnFUSE_CK
fmon_soc_ops_init: re-start disabled FMON_PMC_CK
fmon initialized
reset initialized
nvhs initialized
warning: pllp_vic do not permit 'allow_fractional_divider' property
warning: pllp_vic do not permit 'allowed-parents' property
warning: mphy_core_pll_fixed do not permit 'allowed-parents' property
warning: ufsdev_ref do not permit 'allowed-parents' property
warning: slvsec do not permit 'allowed-parents' property
warning: pllp_aon do not permit 'allow_fractional_divider' property
warning: pllp_aon do not permit 'allowed-parents' property
warning: mphy_tx_1mhz_ref do not permit 'allowed-parents' property
warning: sdmmc4 do not permit 'allow_fractional_divider' property
warning: eqos_tx do not permit 'allowed-parents' property
386 clocks registered
clk_mrq_init: mrq handler registered
clk initialized
io_dpd initialized
thermal initialized
ti2c_dt_parse: error fetching tlow
ti2c_dt_parse: error fetching thigh
i2c5 controller initialized
initialized i2c mrq handling
i2c initialized
WARNING: at platform/drivers/regulator/regulator-dt.c:126
regulator_parse_dt: regulator-ramp-delay is deprecated. Use regulator-ramp-delay-linear instead.
regulator initialized
avfs_clk_platform initialized
soctherm initialized
aotag initialized
powergate initialized
dvs initialized
pm initialized
pg_late initialized
strap initialized
tag initialized
emc initialized
WARNING: at platform/drivers/vfmon/fmon.c:456
invalid clock 307 rate 0
invalid clock 113 rate 0
fmon_enable: FMON_NVLINK_SYS: s/w DC fault is detected
invalid clock 118 rate 0
warning: i2c2 do not permit parent clk_m
warning: i2c8 do not permit parent clk_m
clk_update_possible_parents: clk_m not in allowed parent table for sdmmc4
warning: sor0_out do not permit parent pll_d
warning: sor0_out do not permit parent pll_dp
clk_update_possible_parents: sor_safe not in allowed parent table for sor0_out
warning: sor1_out do not permit parent pll_d2
warning: sor1_out do not permit parent pll_dp
clk_update_possible_parents: sor_safe not in allowed parent table for sor1_out
warning: sor2_out do not permit parent pll_d3
warning: sor2_out do not permit parent pll_dp
clk_update_possible_parents: sor_safe not in allowed parent table for sor2_out
warning: sor3_out do not permit parent pll_d4
warning: sor3_out do not permit parent pll_dp
clk_update_possible_parents: sor_safe not in allowed parent table for sor3_out
clk_dt initialized
avfs_ccplex_platform initialized
pm_post initialized
tj_max: dt node not found
tj_init initialized
uphy_mrq_init: mrq handler registered
uphy_dt initialized
uphy initialized
mrq initialized
clk_dt_late initialized
carveout 6: size check failed (0x20)
AST0 misconfig for DRAM: slave 0x050000001 master 0x0eb800000 mask 0x3ff000 control 0x80001
AST1 misconfig for DRAM: slave 0x050000001 master 0x0eb800000 mask 0x3ff000 control 0x80001
machine_check initialized
fmon_post initialized
tag is fce7e7e850bd06c123a330c57f701fca
tag_lateinit initialized
avfs_clk_platform_post initialized
dmce initialized
cvc initialized
ÿãCombined UART initialized
Starting OS
ÿâavfs_clk_mach_post initialized
ÿãInitialization done!
ÿâgboost_init initialized
aotag_hsm initialized
regulator_post initialized
rm initialized
sc7_diag initialized
thermal_test initialized
serial_late initialized
clk_post initialized
clk_dt_post initialized
wake initialized
sku_debugfs initialized
speedo_debugfs initialized
adc_debugfs initialized
clk_debugfs initialized
emc_debugfs initialized
ÿáqb:[E]: Partition not found ramdisk
qb:[E]: Error PartitionNotExist (0x30018)
ÿâdvs_debugfs initialized
ÿáqb:[E]: Partition not found kernel-dtb
ÿâfmon_debugfs initialized
vmon_debugfs initialized
pg_debugfs initialized
profile_fs initialized
debugfs_cons initialized
mail_fs initialized
profile initialized
cvc_debugfs initialized
dmce_debugfs initialized
ec_debugfs initialized
soctherm_debug initialized
debugfs_mrq initialized
ÿáÿÿýÿÿþÿâstarting app shell
entering main console loop
] ÿáDRIVE Hypervisor
ÿÿNvGpcDmaLibInitÿÿ
iÿÿ:ÿÿ
vÿÿHÿÿ
cÿÿyÿÿ
_ÿÿpÿÿ
qÿÿeÿÿ
uÿÿrÿÿ
eÿÿvÿÿ
uÿÿiÿÿ
eÿÿsÿÿ
ÿÿoÿÿ
nÿÿrÿÿ
oÿÿ ÿÿ
dÿÿMÿÿ
eÿÿoÿÿ
ÿÿdÿÿ
nÿÿeÿÿ
oÿÿ
ÿÿ
tÿÿ
ÿÿ
present
ivc_queue node not present
ivc_queue node not pÿÿ sÿÿ
rÿÿ tÿÿ
eÿÿ aÿÿ
sÿÿ rÿÿ
eÿÿ tÿÿ
nÿÿ iÿÿ
tÿÿ nÿÿ
ÿÿ gÿÿ
ÿÿ app i2c_server
starting aÿÿ
sÿÿ pÿÿ
tÿÿ pÿÿ
aÿÿ ÿÿ
rÿÿ bÿÿ
tÿÿ pÿÿ
iÿÿ mÿÿ
nÿÿ pÿÿ
gÿÿ _iÿÿ
ÿÿ nÿÿ
aÿÿ cÿÿ
pÿÿ oÿÿ
p ÿÿ mÿÿ
gÿÿ iÿÿ
dÿÿ nÿÿ
bÿÿ gÿÿ
_ÿÿ
ÿÿ
aÿÿ
ÿÿ
gent
ÿÿvirt/servers/servers/apps/thermal/cooling_devs/cdev_balanced_throttle.c: cpufreq-virt_init failed
Registered governor: pid_thermal_govmax20024: No regulator node found in pmc node
ÿÿ
starting app debug_seÿÿstarting app bpmp_ping
starting app thermal
trip_update_worker: Failed to get current temperature for zone 1
starting app bpmp_server
starting app cpÿÿSÿÿufÿÿtÿÿreÿÿaÿÿq_ÿÿrÿÿhvÿÿtÿÿ
ÿÿing TrustZoneÿÿstarting app bpmp_incoming
trip_update_worker: Failed to get current temperature for zone 7
ÿÿ
rver
D-S> ÿÿ Sever...
ÿÿevent logginÿÿRÿÿgÿÿeÿÿ nÿÿsÿÿotÿÿeÿÿ ÿÿrÿÿavÿÿvÿÿaiÿÿeÿÿlaÿÿdÿÿbÿÿ ÿÿleÿÿIÿÿ
ÿÿVÿÿ
ÿÿC id 526
Reserved IVC iÿÿstÿÿdÿÿaÿÿ ÿÿrtÿÿ5ÿÿinÿÿ2ÿÿgÿÿ7ÿÿ apÿÿ
ÿÿpÿÿ
ÿÿ vÿÿRÿÿscÿÿeÿÿ
ÿÿserved IVC id 528
Reserved IVC id 529
Reserved IVC id 530
Resÿÿsÿÿeÿÿtaÿÿrÿÿrtÿÿvÿÿinÿÿeÿÿgÿÿdÿÿ aÿÿ ÿÿppÿÿIÿÿ ÿÿVÿÿbpÿÿCÿÿmpÿÿ ÿÿ_ÿÿiÿÿinÿÿdÿÿcoÿÿ ÿÿmiÿÿ5ÿÿngÿÿ3ÿÿ
ÿÿ1
Reserved IVC id 532
Reserved IVC id 533
Reserved IVC id 534
Reserved IVC id 535
Reserved IVC id 536
Reserved IVC id 537
Reserved IVC id 538
Reserved IVC id 539
ÿäplatform_guest_warm_boot: guest warm reboot
ÿástarting app tz_server
ÿÿaMMFLAGS=1
Starting RM server
Start nvpm server
Setting BOARD_SHUTDOWN_DLL to /proc/boot/libnvshutdown.so if not set already
Done...
ÿÿstarting app se_server
ÿÿpl:[Eÿÿþ 2628418|HV/c4: ÿÿÿÿþGAC : GID 0 unhandled access of size 4 for Read operation on trap address 3270000 with err 0!
ÿÿ]:ÿÿpÿÿÿÿþ 2630931|HV/c4: ÿÿÿÿþGAC : GID 0 unhandled access of size 4 for Read operation on trap address 0 with err 0!
ÿÿ ÿÿlÿÿNÿÿ:ÿÿvÿÿ[ÿÿGÿÿEÿÿuÿÿ]:ÿÿeÿÿ ÿÿsÿÿNvÿÿtÿÿGÿÿFÿÿuÿÿiÿÿeÿÿnÿÿsÿÿdÿÿtÿÿBÿÿFÿÿoÿÿiÿÿoÿÿnÿÿtÿÿdÿÿDÿÿBÿÿeÿÿoÿÿvÿÿoÿÿiÿÿtÿÿcÿÿDÿÿeÿÿpÿÿÿäplatform_guest_warm_boot: guest warm reboot
ÿáÿäplatform_guest_warm_boot: guest warm reboot
ÿáeÿÿIÿÿlÿÿvÿÿnÿÿ:ÿÿiÿÿfÿÿ[ÿÿ\00
ÿÿcÿÿ\00GID 0:ÿÿoÿÿ\00 UnÿÿEÿÿ\00hanÿÿeÿÿ\00dled acÿÿ:ÿÿ\00cesÿÿ]ÿÿ\00s oÿÿIÿÿ\00f sizeÿÿ1ÿÿ\00 4 foÿÿ:ÿÿ\00r read.ÿÿnÿÿ\00
Acceÿÿ5ÿÿ\00ss sÿÿ ÿÿfÿÿ\00izeÿÿ9ÿÿ\00: 0x4
Fault ÿÿNÿÿ\00Iÿÿoÿÿ\00PA: 0ÿÿ ÿÿ\00x32700ÿÿvÿÿ\0000ÿÿ:ÿÿ\00
ESR_EL2ÿÿNÿÿ\00: 0x9382ÿÿGÿÿ\000ÿÿ1ÿÿ\00007
ÿÿoÿÿ\00Fatal VMÿÿuÿÿ\00 ÿÿ5ÿÿ\00Fault: ÿÿ ÿÿ\00Faileÿÿeÿÿ\00d ÿÿ9ÿÿ\00to haÿÿBÿÿ\00ndlÿÿsÿÿ\00e dÿÿ ÿÿ\00ata aÿÿoÿÿ\00borÿÿtÿÿ\00t!
ÿÿNÿÿ\00
VM Stÿÿoÿÿ\00atÿÿFÿÿ\00e:
Vÿÿoÿÿ\00CPU ID: 0xÿÿtÿÿiÿÿ\000
PC:ÿÿ ÿÿ\00 0x21009750ÿÿ ÿÿ\00
ÿÿnÿÿ\00
SPSR_ELÿÿBÿÿ\002: 0x800003cÿÿDÿÿdÿÿ\005
FAR_ELÿÿoÿÿ\002: 0x327ÿÿeÿÿBÿÿ\000000
Sÿÿoÿÿ\00PSR_EL1: 0xÿÿvÿÿ\000
ÿÿoÿÿ\00
GPRÿÿtÿÿ\00s:
x0: ÿÿiÿÿ\000ÿÿoÿÿ\00x000000ÿÿ ÿÿ\000085a46cÿÿcÿÿ\004ÿÿtÿÿ\000 x1:ÿÿDÿÿ\00 0x0ÿÿDÿÿ\000ÿÿeÿÿ\00000ÿÿeÿÿ\0000085e89cÿÿeÿÿ ÿÿ\0038 xÿÿvÿÿ\002: 0x00000ÿÿfÿÿvÿÿ\0000000ÿÿiÿÿ\00000000
ÿÿiÿÿ\00
xÿÿoÿÿ\003: ÿÿcÿÿÿäplatform_guest_warm_boot: guest warm reboot
ÿá\000x00000ÿÿcÿÿ\0000ÿÿuÿÿ\0000327ÿÿeÿÿ\000000 x4: 0xÿÿeÿÿ\000ÿÿnÿÿ\0000000ÿÿ ÿÿ\000085e89e58 x5ÿÿIÿÿdÿÿ\00: 0x00ÿÿfÿÿ\00000000000ÿÿnÿÿ\000ÿÿ
ÿÿ\000000 ÿÿoÿÿ\00
x6: 0x000ÿÿfÿÿ
ÿÿ\00000ÿÿuÿÿ\000000000001 ÿÿoÿÿ\00x7:ÿÿpÿÿnÿÿ\00 0x0000000ÿÿ:ÿÿ\0000000ÿÿlÿÿdÿÿ\000001 x8: ÿÿ1ÿÿ\000x0ÿÿ
ÿÿ:ÿÿ\00000000000ÿÿ5ÿÿ\000000ÿÿ[ÿÿ\000ÿÿ
ÿÿ\001
x9: 0x00ÿÿ9ÿÿ\000000ÿÿEÿÿ\0000ÿÿpÿÿ\0000000004 x10: 0x0ÿÿ]ÿÿ\000ÿÿlÿÿ\0000000000000022 xÿÿ:ÿÿ\0011:ÿÿ:ÿÿ\00 ÿÿ[ÿÿ\000x0000000085a42698
ÿÿEÿÿ\00
x12: 0x000ÿÿ ÿÿ\00000000000ÿÿ]ÿÿ\000000 x13: 0x0ÿÿQÿÿ\000000ÿÿ:ÿÿ\000ÿÿbÿÿ\000000000018ÿÿ ÿÿ\00 x14: 0x0000ÿÿQÿÿ\000ÿÿDÿÿ\0000000000001ÿÿbÿÿ\00
x15: ÿÿaÿÿ\000x00ÿÿDÿÿ\000ÿÿtÿÿ\0000000000000ÿÿaÿÿ\0000 x16: 0x0000000000000ÿÿtÿÿ\0006ÿÿaÿÿ\000 x17: 0x00000000ÿÿaÿÿ\0000000ÿÿDÿÿ\00080
x18: 0x00000ÿÿDÿÿ\000008ÿÿrÿÿ\005e80000 xÿÿ ÿÿ\0019: 0x0000ÿÿrÿÿ\0000ÿÿiÿÿ\000085a46aaÿÿNÿÿ\000 x20:ÿÿiÿÿ\00 0x00ÿÿvÿÿ\00000000ÿÿoÿÿ\0000000000
ÿÿvÿÿ\00x21ÿÿeÿÿ\00: 0x0000ÿÿ ÿÿ\00000085a46c40ÿÿeÿÿ\00 ÿÿnÿÿ\00x22: 0xÿÿBÿÿ\0000000000ÿÿnÿÿ\0000ÿÿIÿÿ\0000000ÿÿoÿÿ\000 x23: 0x000000ÿÿnÿÿ\00008ÿÿIÿÿ\005a46ÿÿoÿÿ\00ac8
x24: 0x0000ÿÿiÿÿ\000ÿÿnÿÿ\00000ÿÿtÿÿ\00ffffffff x25ÿÿtÿÿiÿÿ\00: ÿÿ ÿÿ\000x0000000085a46ÿÿ(ÿÿ\00c3ÿÿtÿÿ\008ÿÿDÿÿ\00 x26: 0x0000ÿÿ)ÿÿ\000000ÿÿ(ÿÿ\0085ÿÿeÿÿ\00a46ac0
x27: 0x0ÿÿ ÿÿ\0000ÿÿ)ÿÿ\000000ÿÿvÿÿ\00085a46ac8 ÿÿfÿÿ\00x28:ÿÿ ÿÿ\00 0ÿÿiÿÿ\00x000000000000ÿÿaÿÿ\0000ÿÿfÿÿ\0002 xÿÿcÿÿ\0029: 0x000000ÿÿiÿÿ\0000ÿÿaÿÿ\0085e7eÿÿeÿÿ\00db0
x30: 0x00ÿÿlÿÿ\0000ÿÿiÿÿ\00000021ÿÿ ÿÿ\00009dd8
Vÿÿeÿÿ\00M ÿÿlÿÿ\00Stackÿÿfÿÿ\00 Trace:
0x21009ÿÿdÿÿ\00dd8ÿÿeÿÿ\00
ÿÿoÿÿ\000x2100bbÿÿ
ÿÿ\002c
ÿÿdÿÿuÿÿ\000x21002fb0
0xÿÿ
ÿÿ\0021003ÿÿ
ÿÿnÿÿ\00514
0x210ÿÿpÿÿ\000155ÿÿ
ÿÿ\000ÿÿdÿÿ\00
0x21000184
Sÿÿpÿÿ\00iÿÿ
ÿÿ\00dÿÿlÿÿ\00ekick Stack Tracÿÿlÿÿ\00eÿÿ
ÿÿ\00:
0x1766ÿÿ:ÿÿ\000
0x18350
ÿÿ:ÿÿ\000xÿÿpÿÿ\00183e8
0x12ÿÿ[ÿÿ\00070
ÿÿ[ÿÿlÿÿEÿÿEÿÿ:ÿÿ]ÿÿ]ÿÿ[ÿÿ:ÿÿ:ÿÿEÿÿ ÿÿ ÿÿ]ÿÿBÿÿ:ÿÿBÿÿUÿÿ ÿÿUÿÿGÿÿQÿÿGÿÿ ÿÿbÿÿ ÿÿdÿÿDÿÿdÿÿaÿÿaÿÿaÿÿtÿÿtÿÿtÿÿaÿÿaÿÿaÿÿDÿÿ_ÿÿ_ÿÿrÿÿdÿÿdÿÿiÿÿrÿÿrÿÿvÿÿiÿÿiÿÿeÿÿvÿÿvÿÿnÿÿeÿÿeÿÿIÿÿnÿÿnÿÿnÿÿ_ÿÿ_ÿÿiÿÿdÿÿdÿÿtÿÿtÿÿtÿÿ(ÿÿ.ÿÿ.ÿÿ)ÿÿcÿÿcÿÿ ÿÿ:ÿÿ:ÿÿfÿÿ9ÿÿ9ÿÿaÿÿ2ÿÿ2ÿÿiÿÿ2ÿÿ2ÿÿlÿÿ ÿÿ ÿÿeÿÿ(ÿÿ(ÿÿdÿÿQÿÿQÿÿ
ÿÿbÿÿbÿÿ
ÿÿDÿÿDÿÿpÿÿaÿÿaÿÿlÿÿtÿÿtÿÿ:ÿÿaÿÿaÿÿ[ÿÿDÿÿDÿÿEÿÿrÿÿrÿÿ]ÿÿiÿÿiÿÿ:ÿÿvÿÿvÿÿ ÿÿeÿÿeÿÿBÿÿnÿÿnÿÿUÿÿIÿÿIÿÿGÿÿnÿÿnÿÿ ÿÿiÿÿiÿÿdÿÿtÿÿtÿÿaÿÿ)ÿÿ)ÿÿtÿÿ
ÿÿ
ÿÿaÿÿ
ÿÿ
ÿÿ_ÿÿpÿÿpÿÿdÿÿlÿÿlÿÿrÿÿ:ÿÿ:ÿÿiÿÿ[ÿÿ[ÿÿvÿÿEÿÿEÿÿeÿÿ]ÿÿ]ÿÿnÿÿ:ÿÿ:ÿÿ_ÿÿ ÿÿ ÿÿdÿÿSÿÿSÿÿtÿÿtÿÿtÿÿ.ÿÿaÿÿaÿÿcÿÿcÿÿcÿÿ:ÿÿkÿÿkÿÿ9ÿÿ ÿÿ ÿÿ2ÿÿtÿÿtÿÿrÿÿrÿÿaÿÿ2ÿÿaÿÿcÿÿ ÿÿcÿÿeÿÿ(ÿÿeÿÿ:ÿÿQÿÿ:ÿÿ
ÿÿbÿÿ
ÿÿ
ÿÿDÿÿ
ÿÿaÿÿpÿÿpÿÿtÿÿlÿÿlÿÿaÿÿ:ÿÿ:ÿÿDÿÿ[ÿÿ[ÿÿrÿÿEÿÿE]ÿÿ]ÿÿiÿÿ:ÿÿ:ÿÿvÿÿ ÿÿ ÿÿeÿÿ<ÿÿ<ÿÿnÿÿ ÿÿ ÿÿIÿÿPÿÿPÿÿnÿÿCÿÿCÿÿiÿÿ ÿÿ ÿÿtÿÿ:ÿÿ:ÿÿ)ÿÿ2ÿÿ2ÿÿ
ÿÿ1ÿÿ
ÿÿ1ÿÿ0ÿÿ0ÿÿpÿÿ0ÿÿ0ÿÿlÿÿ3ÿÿ3ÿÿ:ÿÿ5ÿÿ5ÿÿ[ÿÿbÿÿbÿÿEÿÿ0ÿÿ0ÿÿ]ÿÿ ÿÿ ÿÿ:ÿÿ>ÿÿ>ÿÿ ÿÿ
ÿÿ
ÿÿSÿÿ
ÿÿ
ÿÿtÿÿpÿÿpÿÿaÿÿlÿÿlÿÿcÿÿ:ÿÿpÿÿ:ÿÿkÿÿ[ÿÿlÿÿ[ÿÿ ÿÿEÿÿEÿÿtÿÿ:ÿÿ]ÿÿ]ÿÿrÿÿ[ÿÿ:ÿÿ:ÿÿaÿÿEÿÿ ÿÿ ÿÿcÿÿ<ÿÿ]ÿÿ<ÿÿeÿÿ ÿÿ ÿÿ:ÿÿPÿÿ:ÿÿPÿÿ
ÿÿCÿÿ ÿÿCÿÿ
ÿÿ ÿÿNÿÿ ÿÿpÿÿ:ÿÿ:ÿÿvÿÿlÿÿ2ÿÿ2ÿÿGÿÿ:ÿÿ1ÿÿ1ÿÿuÿÿ[ÿÿ0ÿÿ0ÿÿEÿÿeÿÿ0ÿÿ0ÿÿ]ÿÿ1ÿÿ1ÿÿ:ÿÿ5ÿÿsÿÿ5ÿÿ ÿÿ4ÿÿtÿÿ4ÿÿ<ÿÿcÿÿcÿÿFÿÿ ÿÿ ÿÿ ÿÿiÿÿPÿÿ>ÿÿ>ÿÿCÿÿnÿÿ
ÿÿ
ÿÿ ÿÿdÿÿ
ÿÿ
ÿÿ:ÿÿpÿÿ2ÿÿpÿÿlÿÿBÿÿlÿÿ1ÿÿ:ÿÿoÿÿ:ÿÿ0ÿÿ[ÿÿoÿÿ[ÿÿ0ÿÿEÿÿtÿÿEÿÿ3ÿÿ]ÿÿDÿÿ]ÿÿ5ÿÿ:ÿÿeÿÿ:ÿÿbÿÿ ÿÿvÿÿ ÿÿ0ÿÿ<ÿÿ<ÿÿ ÿÿ ÿÿ ÿÿiÿÿPÿÿ>ÿÿcÿÿPÿÿCÿÿ
ÿÿCÿÿeÿÿ ÿÿ
ÿÿ ÿÿIÿÿ:ÿÿpÿÿ:ÿÿnÿÿ2ÿÿlÿÿ2ÿÿfÿÿ:ÿÿ1ÿÿ1ÿÿ0ÿÿ[ÿÿ0ÿÿoÿÿEÿÿ0ÿÿ0ÿÿ0ÿÿ:ÿÿ]ÿÿ0ÿÿ1ÿÿ:ÿÿ1ÿÿ1ÿÿ8ÿÿ ÿÿ5ÿÿ8ÿÿ0ÿÿ<ÿÿ9ÿÿ0ÿÿ ÿÿ ÿÿ ÿÿ ÿÿ>ÿÿPÿÿNÿÿ>ÿÿ
ÿÿCÿÿ
ÿÿ
ÿÿ ÿÿ
ÿÿoÿÿ:ÿÿ ÿÿ2ÿÿBÿÿ1ÿÿoÿÿ00ÿÿoÿÿ1ÿÿtÿÿ5ÿÿ ÿÿ4cÿÿDÿÿ ÿÿeÿÿ>ÿÿvÿÿ
ÿÿiÿÿ
ÿÿcÿÿpÿÿeÿÿlÿÿ ÿÿ:[ÿÿfÿÿE]ÿÿoÿÿ:ÿÿuÿÿ ÿÿnÿÿ<ÿÿdÿÿ ÿÿ
ÿÿPÿÿ
ÿÿCÿÿpÿÿ :ÿÿlÿÿ21ÿÿ:ÿÿ0ÿÿ[ÿÿ0ÿÿEÿÿ0ÿÿ]ÿÿ1ÿÿ:ÿÿ8ÿÿ ÿÿ0 ÿÿQÿÿ>ÿÿbÿÿ
ÿÿDÿÿ
ÿÿataDrivenInit() failed
pl:[E]: BUG data_driven_dt.c:922 (QbDataDrivenInit)
pl:[E]: Stack trace:
pÿÿpl:[E]: NvGuestFindBootDeviceInfo:159 No Boot Device found
pl:[E]: QbDataDrivenInit() failed
pl:[E]: < PC ÿÿl:[E]: < PC :210035b0 >
pl:[E]: < PC :2100154c >
pl:[E]: < PC :21000180 >
ÿÿ:210035b0 >
ÿãHSM ERROR 244, CRITICAL_ERR_NVL_CAR
\00
[/code]0
ÿÿnÿÿ[code]
\00ÿâ
\00ÿýÿàmain enter
HW Function test
Start Scheduler.
in late init
ÿâ
I> bit @ 0xd480000
I> Unpowergate done
I> Loading TOS ...
I> Loading EKS ...
I> Unhalting RCE
ÿâ
welcome to lk
dt initialized
mail initialized
chipid initialized
fuse initialized
sku initialized
speedo initialized
ec initialized
vmon initialized
adc initialized
fmon initialized
reset initialized
nvhs initialized
clk initialized
io_dpd initialized
thermal initialized
i2c initialized
aotag initialized
dvs initialized
pm initialized
pg_late initialized
strap initialized
tag initialized
emc initialized
clk_dt initialized
pm_post initialized
tj_init initialized
uphy_dt initialized
uphy initialized
mrq initialized
dmce initialized
cvc initialized
Starting OS
rm initialized
wake initialized
mail_fs initialized
profile initialized
ÿÿNvGpcDmaLibInitÿÿ
iÿÿ:ÿÿ
vÿÿHÿÿ
cÿÿyÿÿ
_ÿÿpÿÿ
qÿÿeÿÿ
uÿÿrÿÿ
eÿÿvÿÿ
uÿÿiÿÿ
eÿÿsÿÿ
ÿÿoÿÿ
nÿÿrÿÿ
oÿÿ ÿÿ
dÿÿMÿÿ
eÿÿoÿÿ
ÿÿdÿÿ
nÿÿeÿÿ
oÿÿ
ÿÿ
tÿÿ
ÿÿ
present
rÿÿ tÿÿ
eÿÿ aÿÿ
sÿÿ rÿÿ
eÿÿ tÿÿ
nÿÿ iÿÿ
tÿÿ nÿÿ
ÿÿ gÿÿ
ÿÿ app i2c_server
starting aÿÿ
sÿÿ pÿÿ
tÿÿ pÿÿ
aÿÿ ÿÿ
rÿÿ bÿÿ
tÿÿ pÿÿ
iÿÿ mÿÿ
nÿÿ pÿÿ
gÿÿ _iÿÿ
ÿÿ nÿÿ
aÿÿ cÿÿ
pÿÿ oÿÿ
p ÿÿ mÿÿ
gÿÿ iÿÿ
dÿÿ nÿÿ
bÿÿ gÿÿ
_ÿÿ
ÿÿ
aÿÿ
ÿÿ
gent
ÿÿ
ÿÿ
rver
D-S> ÿÿ Sever...
ÿÿVÿÿ
ÿÿC id 526
ÿÿpÿÿ
ÿÿ vÿÿRÿÿscÿÿeÿÿ
ÿÿserved IVC id 528
Reserved IVC id 529
Reserved IVC id 530
ÿÿ1
Reserved IVC id 532
Reserved IVC id 533
Reserved IVC id 534
Reserved IVC id 535
Reserved IVC id 536
Reserved IVC id 537
Reserved IVC id 538
Reserved IVC id 539
ÿÿaMMFLAGS=1
Starting RM server
Start nvpm server
Done...
ÿÿNÿÿ\00
ÿÿnÿÿ\00
ÿÿoÿÿ\00
GPRÿÿtÿÿ\00s:
ÿÿiÿÿ\00
ÿÿ\000000 ÿÿoÿÿ\00
x6: 0x000ÿÿfÿÿ
ÿÿ\001
ÿÿEÿÿ\00
ÿÿoÿÿ\000x2100bbÿÿ
ÿÿ\002c
0xÿÿ
ÿÿ\0021003ÿÿ
ÿÿnÿÿ\00514
0x210ÿÿpÿÿ\000155ÿÿ
ÿÿ\000ÿÿdÿÿ\00
0x21000184
Sÿÿpÿÿ\00iÿÿ
ÿÿ\00:
0x1766ÿÿ:ÿÿ\000
0x18350
0x12ÿÿ[ÿÿ\00070
ÿÿbÿÿbÿÿ
ÿÿ
ÿÿaÿÿ
ÿÿ
ÿÿbÿÿ
ÿÿ
ÿÿDÿÿ
ÿÿ1ÿÿ
ÿÿ
ÿÿSÿÿ
ÿÿ
ÿÿCÿÿ ÿÿCÿÿ
ÿÿ
ÿÿ ÿÿdÿÿ
ÿÿ
ÿÿCÿÿeÿÿ ÿÿ
ÿÿCÿÿ
ÿÿ
ÿÿ ÿÿ
ÿÿiÿÿ
ÿÿPÿÿ
ÿÿDÿÿ
ÿÿ:210035b0 >
\00
[/code]0
SPSR_ELÿÿBÿÿ[code]
\00ÿâ
\00ÿýÿàmain enter
HW Function test
Start Scheduler.
in late init
ÿâ
I> bit @ 0xd480000
I> Unpowergate done
I> Loading TOS ...
I> Loading EKS ...
I> Unhalting RCE
ÿâ
welcome to lk
dt initialized
mail initialized
chipid initialized
fuse initialized
sku initialized
speedo initialized
ec initialized
vmon initialized
adc initialized
fmon initialized
reset initialized
nvhs initialized
clk initialized
io_dpd initialized
thermal initialized
i2c initialized
aotag initialized
dvs initialized
pm initialized
pg_late initialized
strap initialized
tag initialized
emc initialized
clk_dt initialized
pm_post initialized
tj_init initialized
uphy_dt initialized
uphy initialized
mrq initialized
dmce initialized
cvc initialized
Starting OS
rm initialized
wake initialized
mail_fs initialized
profile initialized
ÿÿNvGpcDmaLibInitÿÿ
iÿÿ:ÿÿ
vÿÿHÿÿ
cÿÿyÿÿ
_ÿÿpÿÿ
qÿÿeÿÿ
uÿÿrÿÿ
eÿÿvÿÿ
uÿÿiÿÿ
eÿÿsÿÿ
ÿÿoÿÿ
nÿÿrÿÿ
oÿÿ ÿÿ
dÿÿMÿÿ
eÿÿoÿÿ
ÿÿdÿÿ
nÿÿeÿÿ
oÿÿ
ÿÿ
tÿÿ
ÿÿ
present
rÿÿ tÿÿ
eÿÿ aÿÿ
sÿÿ rÿÿ
eÿÿ tÿÿ
nÿÿ iÿÿ
tÿÿ nÿÿ
ÿÿ gÿÿ
ÿÿ app i2c_server
starting aÿÿ
sÿÿ pÿÿ
tÿÿ pÿÿ
aÿÿ ÿÿ
rÿÿ bÿÿ
tÿÿ pÿÿ
iÿÿ mÿÿ
nÿÿ pÿÿ
gÿÿ _iÿÿ
ÿÿ nÿÿ
aÿÿ cÿÿ
pÿÿ oÿÿ
p ÿÿ mÿÿ
gÿÿ iÿÿ
dÿÿ nÿÿ
bÿÿ gÿÿ
_ÿÿ
ÿÿ
aÿÿ
ÿÿ
gent
ÿÿ
ÿÿ
rver
D-S> ÿÿ Sever...
ÿÿVÿÿ
ÿÿC id 526
ÿÿpÿÿ
ÿÿ vÿÿRÿÿscÿÿeÿÿ
ÿÿserved IVC id 528
Reserved IVC id 529
Reserved IVC id 530
ÿÿ1
Reserved IVC id 532
Reserved IVC id 533
Reserved IVC id 534
Reserved IVC id 535
Reserved IVC id 536
Reserved IVC id 537
Reserved IVC id 538
Reserved IVC id 539
ÿÿaMMFLAGS=1
Starting RM server
Start nvpm server
Done...
ÿÿNÿÿ\00
ÿÿnÿÿ\00
ÿÿoÿÿ\00
GPRÿÿtÿÿ\00s:
ÿÿiÿÿ\00
ÿÿ\000000 ÿÿoÿÿ\00
x6: 0x000ÿÿfÿÿ
ÿÿ\001
ÿÿEÿÿ\00
ÿÿoÿÿ\000x2100bbÿÿ
ÿÿ\002c
0xÿÿ
ÿÿ\0021003ÿÿ
ÿÿnÿÿ\00514
0x210ÿÿpÿÿ\000155ÿÿ
ÿÿ\000ÿÿdÿÿ\00
0x21000184
Sÿÿpÿÿ\00iÿÿ
ÿÿ\00:
0x1766ÿÿ:ÿÿ\000
0x18350
0x12ÿÿ[ÿÿ\00070
ÿÿbÿÿbÿÿ
ÿÿ
ÿÿaÿÿ
ÿÿ
ÿÿbÿÿ
ÿÿ
ÿÿDÿÿ
ÿÿ1ÿÿ
ÿÿ
ÿÿSÿÿ
ÿÿ
ÿÿCÿÿ ÿÿCÿÿ
ÿÿ
ÿÿ ÿÿdÿÿ
ÿÿ
ÿÿCÿÿeÿÿ ÿÿ
ÿÿCÿÿ
ÿÿ
ÿÿ ÿÿ
ÿÿiÿÿ
ÿÿPÿÿ
ÿÿDÿÿ
ÿÿ:210035b0 >
\00
[/code]02: 0x800003cÿÿDÿÿdÿÿ[code]
\00ÿâ
\00ÿýÿàmain enter
HW Function test
Start Scheduler.
in late init
ÿâ
I> bit @ 0xd480000
I> Unpowergate done
I> Loading TOS ...
I> Loading EKS ...
I> Unhalting RCE
ÿâ
welcome to lk
dt initialized
mail initialized
chipid initialized
fuse initialized
sku initialized
speedo initialized
ec initialized
vmon initialized
adc initialized
fmon initialized
reset initialized
nvhs initialized
clk initialized
io_dpd initialized
thermal initialized
i2c initialized
aotag initialized
dvs initialized
pm initialized
pg_late initialized
strap initialized
tag initialized
emc initialized
clk_dt initialized
pm_post initialized
tj_init initialized
uphy_dt initialized
uphy initialized
mrq initialized
dmce initialized
cvc initialized
Starting OS
rm initialized
wake initialized
mail_fs initialized
profile initialized
ÿÿNvGpcDmaLibInitÿÿ
iÿÿ:ÿÿ
vÿÿHÿÿ
cÿÿyÿÿ
_ÿÿpÿÿ
qÿÿeÿÿ
uÿÿrÿÿ
eÿÿvÿÿ
uÿÿiÿÿ
eÿÿsÿÿ
ÿÿoÿÿ
nÿÿrÿÿ
oÿÿ ÿÿ
dÿÿMÿÿ
eÿÿoÿÿ
ÿÿdÿÿ
nÿÿeÿÿ
oÿÿ
ÿÿ
tÿÿ
ÿÿ
present
rÿÿ tÿÿ
eÿÿ aÿÿ
sÿÿ rÿÿ
eÿÿ tÿÿ
nÿÿ iÿÿ
tÿÿ nÿÿ
ÿÿ gÿÿ
ÿÿ app i2c_server
starting aÿÿ
sÿÿ pÿÿ
tÿÿ pÿÿ
aÿÿ ÿÿ
rÿÿ bÿÿ
tÿÿ pÿÿ
iÿÿ mÿÿ
nÿÿ pÿÿ
gÿÿ _iÿÿ
ÿÿ nÿÿ
aÿÿ cÿÿ
pÿÿ oÿÿ
p ÿÿ mÿÿ
gÿÿ iÿÿ
dÿÿ nÿÿ
bÿÿ gÿÿ
_ÿÿ
ÿÿ
aÿÿ
ÿÿ
gent
ÿÿ
ÿÿ
rver
D-S> ÿÿ Sever...
ÿÿVÿÿ
ÿÿC id 526
ÿÿpÿÿ
ÿÿ vÿÿRÿÿscÿÿeÿÿ
ÿÿserved IVC id 528
Reserved IVC id 529
Reserved IVC id 530
ÿÿ1
Reserved IVC id 532
Reserved IVC id 533
Reserved IVC id 534
Reserved IVC id 535
Reserved IVC id 536
Reserved IVC id 537
Reserved IVC id 538
Reserved IVC id 539
ÿÿaMMFLAGS=1
Starting RM server
Start nvpm server
Done...
ÿÿNÿÿ\00
ÿÿnÿÿ\00
ÿÿoÿÿ\00
GPRÿÿtÿÿ\00s:
ÿÿiÿÿ\00
ÿÿ\000000 ÿÿoÿÿ\00
x6: 0x000ÿÿfÿÿ
ÿÿ\001
ÿÿEÿÿ\00
ÿÿoÿÿ\000x2100bbÿÿ
ÿÿ\002c
0xÿÿ
ÿÿ\0021003ÿÿ
ÿÿnÿÿ\00514
0x210ÿÿpÿÿ\000155ÿÿ
ÿÿ\000ÿÿdÿÿ\00
0x21000184
Sÿÿpÿÿ\00iÿÿ
ÿÿ\00:
0x1766ÿÿ:ÿÿ\000
0x18350
0x12ÿÿ[ÿÿ\00070
ÿÿbÿÿbÿÿ
ÿÿ
ÿÿaÿÿ
ÿÿ
ÿÿbÿÿ
ÿÿ
ÿÿDÿÿ
ÿÿ1ÿÿ
ÿÿ
ÿÿSÿÿ
ÿÿ
ÿÿCÿÿ ÿÿCÿÿ
ÿÿ
ÿÿ ÿÿdÿÿ
ÿÿ
ÿÿCÿÿeÿÿ ÿÿ
ÿÿCÿÿ
ÿÿ
ÿÿ ÿÿ
ÿÿiÿÿ
ÿÿPÿÿ
ÿÿDÿÿ
ÿÿ:210035b0 >
\00
[/code]05
FAR_ELÿÿoÿÿ[code]
\00ÿâ
\00ÿýÿàmain enter
HW Function test
Start Scheduler.
in late init
ÿâ
I> bit @ 0xd480000
I> Unpowergate done
I> Loading TOS ...
I> Loading EKS ...
I> Unhalting RCE
ÿâ
welcome to lk
dt initialized
mail initialized
chipid initialized
fuse initialized
sku initialized
speedo initialized
ec initialized
vmon initialized
adc initialized
fmon initialized
reset initialized
nvhs initialized
clk initialized
io_dpd initialized
thermal initialized
i2c initialized
aotag initialized
dvs initialized
pm initialized
pg_late initialized
strap initialized
tag initialized
emc initialized
clk_dt initialized
pm_post initialized
tj_init initialized
uphy_dt initialized
uphy initialized
mrq initialized
dmce initialized
cvc initialized
Starting OS
rm initialized
wake initialized
mail_fs initialized
profile initialized
ÿÿNvGpcDmaLibInitÿÿ
iÿÿ:ÿÿ
vÿÿHÿÿ
cÿÿyÿÿ
_ÿÿpÿÿ
qÿÿeÿÿ
uÿÿrÿÿ
eÿÿvÿÿ
uÿÿiÿÿ
eÿÿsÿÿ
ÿÿoÿÿ
nÿÿrÿÿ
oÿÿ ÿÿ
dÿÿMÿÿ
eÿÿoÿÿ
ÿÿdÿÿ
nÿÿeÿÿ
oÿÿ
ÿÿ
tÿÿ
ÿÿ
present
rÿÿ tÿÿ
eÿÿ aÿÿ
sÿÿ rÿÿ
eÿÿ tÿÿ
nÿÿ iÿÿ
tÿÿ nÿÿ
ÿÿ gÿÿ
ÿÿ app i2c_server
starting aÿÿ
sÿÿ pÿÿ
tÿÿ pÿÿ
aÿÿ ÿÿ
rÿÿ bÿÿ
tÿÿ pÿÿ
iÿÿ mÿÿ
nÿÿ pÿÿ
gÿÿ _iÿÿ
ÿÿ nÿÿ
aÿÿ cÿÿ
pÿÿ oÿÿ
p ÿÿ mÿÿ
gÿÿ iÿÿ
dÿÿ nÿÿ
bÿÿ gÿÿ
_ÿÿ
ÿÿ
aÿÿ
ÿÿ
gent
ÿÿ
ÿÿ
rver
D-S> ÿÿ Sever...
ÿÿVÿÿ
ÿÿC id 526
ÿÿpÿÿ
ÿÿ vÿÿRÿÿscÿÿeÿÿ
ÿÿserved IVC id 528
Reserved IVC id 529
Reserved IVC id 530
ÿÿ1
Reserved IVC id 532
Reserved IVC id 533
Reserved IVC id 534
Reserved IVC id 535
Reserved IVC id 536
Reserved IVC id 537
Reserved IVC id 538
Reserved IVC id 539
ÿÿaMMFLAGS=1
Starting RM server
Start nvpm server
Done...
ÿÿNÿÿ\00
ÿÿnÿÿ\00
ÿÿoÿÿ\00
GPRÿÿtÿÿ\00s:
ÿÿiÿÿ\00
ÿÿ\000000 ÿÿoÿÿ\00
x6: 0x000ÿÿfÿÿ
ÿÿ\001
ÿÿEÿÿ\00
ÿÿoÿÿ\000x2100bbÿÿ
ÿÿ\002c
0xÿÿ
ÿÿ\0021003ÿÿ
ÿÿnÿÿ\00514
0x210ÿÿpÿÿ\000155ÿÿ
ÿÿ\000ÿÿdÿÿ\00
0x21000184
Sÿÿpÿÿ\00iÿÿ
ÿÿ\00:
0x1766ÿÿ:ÿÿ\000
0x18350
0x12ÿÿ[ÿÿ\00070
ÿÿbÿÿbÿÿ
ÿÿ
ÿÿaÿÿ
ÿÿ
ÿÿbÿÿ
ÿÿ
ÿÿDÿÿ
ÿÿ1ÿÿ
ÿÿ
ÿÿSÿÿ
ÿÿ
ÿÿCÿÿ ÿÿCÿÿ
ÿÿ
ÿÿ ÿÿdÿÿ
ÿÿ
ÿÿCÿÿeÿÿ ÿÿ
ÿÿCÿÿ
ÿÿ
ÿÿ ÿÿ
ÿÿiÿÿ
ÿÿPÿÿ
ÿÿDÿÿ
ÿÿ:210035b0 >
\00
[/code]02: 0x327ÿÿeÿÿBÿÿ[code]
\00ÿâ
\00ÿýÿàmain enter
HW Function test
Start Scheduler.
in late init
ÿâ
I> bit @ 0xd480000
I> Unpowergate done
I> Loading TOS ...
I> Loading EKS ...
I> Unhalting RCE
ÿâ
welcome to lk
dt initialized
mail initialized
chipid initialized
fuse initialized
sku initialized
speedo initialized
ec initialized
vmon initialized
adc initialized
fmon initialized
reset initialized
nvhs initialized
clk initialized
io_dpd initialized
thermal initialized
i2c initialized
aotag initialized
dvs initialized
pm initialized
pg_late initialized
strap initialized
tag initialized
emc initialized
clk_dt initialized
pm_post initialized
tj_init initialized
uphy_dt initialized
uphy initialized
mrq initialized
dmce initialized
cvc initialized
Starting OS
rm initialized
wake initialized
mail_fs initialized
profile initialized
ÿÿNvGpcDmaLibInitÿÿ
iÿÿ:ÿÿ
vÿÿHÿÿ
cÿÿyÿÿ
_ÿÿpÿÿ
qÿÿeÿÿ
uÿÿrÿÿ
eÿÿvÿÿ
uÿÿiÿÿ
eÿÿsÿÿ
ÿÿoÿÿ
nÿÿrÿÿ
oÿÿ ÿÿ
dÿÿMÿÿ
eÿÿoÿÿ
ÿÿdÿÿ
nÿÿeÿÿ
oÿÿ
ÿÿ
tÿÿ
ÿÿ
present
rÿÿ tÿÿ
eÿÿ aÿÿ
sÿÿ rÿÿ
eÿÿ tÿÿ
nÿÿ iÿÿ
tÿÿ nÿÿ
ÿÿ gÿÿ
ÿÿ app i2c_server
starting aÿÿ
sÿÿ pÿÿ
tÿÿ pÿÿ
aÿÿ ÿÿ
rÿÿ bÿÿ
tÿÿ pÿÿ
iÿÿ mÿÿ
nÿÿ pÿÿ
gÿÿ _iÿÿ
ÿÿ nÿÿ
aÿÿ cÿÿ
pÿÿ oÿÿ
p ÿÿ mÿÿ
gÿÿ iÿÿ
dÿÿ nÿÿ
bÿÿ gÿÿ
_ÿÿ
ÿÿ
aÿÿ
ÿÿ
gent
ÿÿ
ÿÿ
rver
D-S> ÿÿ Sever...
ÿÿVÿÿ
ÿÿC id 526
ÿÿpÿÿ
ÿÿ vÿÿRÿÿscÿÿeÿÿ
ÿÿserved IVC id 528
Reserved IVC id 529
Reserved IVC id 530
ÿÿ1
Reserved IVC id 532
Reserved IVC id 533
Reserved IVC id 534
Reserved IVC id 535
Reserved IVC id 536
Reserved IVC id 537
Reserved IVC id 538
Reserved IVC id 539
ÿÿaMMFLAGS=1
Starting RM server
Start nvpm server
Done...
ÿÿNÿÿ\00
ÿÿnÿÿ\00
ÿÿoÿÿ\00
GPRÿÿtÿÿ\00s:
ÿÿiÿÿ\00
ÿÿ\000000 ÿÿoÿÿ\00
x6: 0x000ÿÿfÿÿ
ÿÿ\001
ÿÿEÿÿ\00
ÿÿoÿÿ\000x2100bbÿÿ
ÿÿ\002c
0xÿÿ
ÿÿ\0021003ÿÿ
ÿÿnÿÿ\00514
0x210ÿÿpÿÿ\000155ÿÿ
ÿÿ\000ÿÿdÿÿ\00
0x21000184
Sÿÿpÿÿ\00iÿÿ
ÿÿ\00:
0x1766ÿÿ:ÿÿ\000
0x18350
0x12ÿÿ[ÿÿ\00070
ÿÿbÿÿbÿÿ
ÿÿ
ÿÿaÿÿ
ÿÿ
ÿÿbÿÿ
ÿÿ
ÿÿDÿÿ
ÿÿ1ÿÿ
ÿÿ
ÿÿSÿÿ
ÿÿ
ÿÿCÿÿ ÿÿCÿÿ
ÿÿ
ÿÿ ÿÿdÿÿ
ÿÿ
ÿÿCÿÿeÿÿ ÿÿ
ÿÿCÿÿ
ÿÿ
ÿÿ ÿÿ
ÿÿiÿÿ
ÿÿPÿÿ
ÿÿDÿÿ
ÿÿ:210035b0 >
\00
[/code]00000
Sÿÿoÿÿ[code]
\00ÿâ
\00ÿýÿàmain enter
HW Function test
Start Scheduler.
in late init
ÿâ
I> bit @ 0xd480000
I> Unpowergate done
I> Loading TOS ...
I> Loading EKS ...
I> Unhalting RCE
ÿâ
welcome to lk
dt initialized
mail initialized
chipid initialized
fuse initialized
sku initialized
speedo initialized
ec initialized
vmon initialized
adc initialized
fmon initialized
reset initialized
nvhs initialized
clk initialized
io_dpd initialized
thermal initialized
i2c initialized
aotag initialized
dvs initialized
pm initialized
pg_late initialized
strap initialized
tag initialized
emc initialized
clk_dt initialized
pm_post initialized
tj_init initialized
uphy_dt initialized
uphy initialized
mrq initialized
dmce initialized
cvc initialized
Starting OS
rm initialized
wake initialized
mail_fs initialized
profile initialized
ÿÿNvGpcDmaLibInitÿÿ
iÿÿ:ÿÿ
vÿÿHÿÿ
cÿÿyÿÿ
_ÿÿpÿÿ
qÿÿeÿÿ
uÿÿrÿÿ
eÿÿvÿÿ
uÿÿiÿÿ
eÿÿsÿÿ
ÿÿoÿÿ
nÿÿrÿÿ
oÿÿ ÿÿ
dÿÿMÿÿ
eÿÿoÿÿ
ÿÿdÿÿ
nÿÿeÿÿ
oÿÿ
ÿÿ
tÿÿ
ÿÿ
present
rÿÿ tÿÿ
eÿÿ aÿÿ
sÿÿ rÿÿ
eÿÿ tÿÿ
nÿÿ iÿÿ
tÿÿ nÿÿ
ÿÿ gÿÿ
ÿÿ app i2c_server
starting aÿÿ
sÿÿ pÿÿ
tÿÿ pÿÿ
aÿÿ ÿÿ
rÿÿ bÿÿ
tÿÿ pÿÿ
iÿÿ mÿÿ
nÿÿ pÿÿ
gÿÿ _iÿÿ
ÿÿ nÿÿ
aÿÿ cÿÿ
pÿÿ oÿÿ
p ÿÿ mÿÿ
gÿÿ iÿÿ
dÿÿ nÿÿ
bÿÿ gÿÿ
_ÿÿ
ÿÿ
aÿÿ
ÿÿ
gent
ÿÿ
ÿÿ
rver
D-S> ÿÿ Sever...
ÿÿVÿÿ
ÿÿC id 526
ÿÿpÿÿ
ÿÿ vÿÿRÿÿscÿÿeÿÿ
ÿÿserved IVC id 528
Reserved IVC id 529
Reserved IVC id 530
ÿÿ1
Reserved IVC id 532
Reserved IVC id 533
Reserved IVC id 534
Reserved IVC id 535
Reserved IVC id 536
Reserved IVC id 537
Reserved IVC id 538
Reserved IVC id 539
ÿÿaMMFLAGS=1
Starting RM server
Start nvpm server
Done...
ÿÿNÿÿ\00
ÿÿnÿÿ\00
ÿÿoÿÿ\00
GPRÿÿtÿÿ\00s:
ÿÿiÿÿ\00
ÿÿ\000000 ÿÿoÿÿ\00
x6: 0x000ÿÿfÿÿ
ÿÿ\001
ÿÿEÿÿ\00
ÿÿoÿÿ\000x2100bbÿÿ
ÿÿ\002c
0xÿÿ
ÿÿ\0021003ÿÿ
ÿÿnÿÿ\00514
0x210ÿÿpÿÿ\000155ÿÿ
ÿÿ\000ÿÿdÿÿ\00
0x21000184
Sÿÿpÿÿ\00iÿÿ
ÿÿ\00:
0x1766ÿÿ:ÿÿ\000
0x18350
0x12ÿÿ[ÿÿ\00070
ÿÿbÿÿbÿÿ
ÿÿ
ÿÿaÿÿ
ÿÿ
ÿÿbÿÿ
ÿÿ
ÿÿDÿÿ
ÿÿ1ÿÿ
ÿÿ
ÿÿSÿÿ
ÿÿ
ÿÿCÿÿ ÿÿCÿÿ
ÿÿ
ÿÿ ÿÿdÿÿ
ÿÿ
ÿÿCÿÿeÿÿ ÿÿ
ÿÿCÿÿ
ÿÿ
ÿÿ ÿÿ
ÿÿiÿÿ
ÿÿPÿÿ
ÿÿDÿÿ
ÿÿ:210035b0 >
\00
[/code]0PSR_EL1: 0xÿÿvÿÿ[code]
\00ÿâ
\00ÿýÿàmain enter
HW Function test
Start Scheduler.
in late init
ÿâ
I> bit @ 0xd480000
I> Unpowergate done
I> Loading TOS ...
I> Loading EKS ...
I> Unhalting RCE
ÿâ
welcome to lk
dt initialized
mail initialized
chipid initialized
fuse initialized
sku initialized
speedo initialized
ec initialized
vmon initialized
adc initialized
fmon initialized
reset initialized
nvhs initialized
clk initialized
io_dpd initialized
thermal initialized
i2c initialized
aotag initialized
dvs initialized
pm initialized
pg_late initialized
strap initialized
tag initialized
emc initialized
clk_dt initialized
pm_post initialized
tj_init initialized
uphy_dt initialized
uphy initialized
mrq initialized
dmce initialized
cvc initialized
Starting OS
rm initialized
wake initialized
mail_fs initialized
profile initialized
ÿÿNvGpcDmaLibInitÿÿ
iÿÿ:ÿÿ
vÿÿHÿÿ
cÿÿyÿÿ
_ÿÿpÿÿ
qÿÿeÿÿ
uÿÿrÿÿ
eÿÿvÿÿ
uÿÿiÿÿ
eÿÿsÿÿ
ÿÿoÿÿ
nÿÿrÿÿ
oÿÿ ÿÿ
dÿÿMÿÿ
eÿÿoÿÿ
ÿÿdÿÿ
nÿÿeÿÿ
oÿÿ
ÿÿ
tÿÿ
ÿÿ
present
rÿÿ tÿÿ
eÿÿ aÿÿ
sÿÿ rÿÿ
eÿÿ tÿÿ
nÿÿ iÿÿ
tÿÿ nÿÿ
ÿÿ gÿÿ
ÿÿ app i2c_server
starting aÿÿ
sÿÿ pÿÿ
tÿÿ pÿÿ
aÿÿ ÿÿ
rÿÿ bÿÿ
tÿÿ pÿÿ
iÿÿ mÿÿ
nÿÿ pÿÿ
gÿÿ _iÿÿ
ÿÿ nÿÿ
aÿÿ cÿÿ
pÿÿ oÿÿ
p ÿÿ mÿÿ
gÿÿ iÿÿ
dÿÿ nÿÿ
bÿÿ gÿÿ
_ÿÿ
ÿÿ
aÿÿ
ÿÿ
gent
ÿÿ
ÿÿ
rver
D-S> ÿÿ Sever...
ÿÿVÿÿ
ÿÿC id 526
ÿÿpÿÿ
ÿÿ vÿÿRÿÿscÿÿeÿÿ
ÿÿserved IVC id 528
Reserved IVC id 529
Reserved IVC id 530
ÿÿ1
Reserved IVC id 532
Reserved IVC id 533
Reserved IVC id 534
Reserved IVC id 535
Reserved IVC id 536
Reserved IVC id 537
Reserved IVC id 538
Reserved IVC id 539
ÿÿaMMFLAGS=1
Starting RM server
Start nvpm server
Done...
ÿÿNÿÿ\00
ÿÿnÿÿ\00
ÿÿoÿÿ\00
GPRÿÿtÿÿ\00s:
ÿÿiÿÿ\00
ÿÿ\000000 ÿÿoÿÿ\00
x6: 0x000ÿÿfÿÿ
ÿÿ\001
ÿÿEÿÿ\00
ÿÿoÿÿ\000x2100bbÿÿ
ÿÿ\002c
0xÿÿ
ÿÿ\0021003ÿÿ
ÿÿnÿÿ\00514
0x210ÿÿpÿÿ\000155ÿÿ
ÿÿ\000ÿÿdÿÿ\00
0x21000184
Sÿÿpÿÿ\00iÿÿ
ÿÿ\00:
0x1766ÿÿ:ÿÿ\000
0x18350
0x12ÿÿ[ÿÿ\00070
ÿÿbÿÿbÿÿ
ÿÿ
ÿÿaÿÿ
ÿÿ
ÿÿbÿÿ
ÿÿ
ÿÿDÿÿ
ÿÿ1ÿÿ
ÿÿ
ÿÿSÿÿ
ÿÿ
ÿÿCÿÿ ÿÿCÿÿ
ÿÿ
ÿÿ ÿÿdÿÿ
ÿÿ
ÿÿCÿÿeÿÿ ÿÿ
ÿÿCÿÿ
ÿÿ
ÿÿ ÿÿ
ÿÿiÿÿ
ÿÿPÿÿ
ÿÿDÿÿ
ÿÿ:210035b0 >
\00
[/code]00
ÿÿoÿÿ[code]
\00ÿâ
\00ÿýÿàmain enter
HW Function test
Start Scheduler.
in late init
ÿâ
I> bit @ 0xd480000
I> Unpowergate done
I> Loading TOS ...
I> Loading EKS ...
I> Unhalting RCE
ÿâ
welcome to lk
dt initialized
mail initialized
chipid initialized
fuse initialized
sku initialized
speedo initialized
ec initialized
vmon initialized
adc initialized
fmon initialized
reset initialized
nvhs initialized
clk initialized
io_dpd initialized
thermal initialized
i2c initialized
aotag initialized
dvs initialized
pm initialized
pg_late initialized
strap initialized
tag initialized
emc initialized
clk_dt initialized
pm_post initialized
tj_init initialized
uphy_dt initialized
uphy initialized
mrq initialized
dmce initialized
cvc initialized
Starting OS
rm initialized
wake initialized
mail_fs initialized
profile initialized
ÿÿNvGpcDmaLibInitÿÿ
iÿÿ:ÿÿ
vÿÿHÿÿ
cÿÿyÿÿ
_ÿÿpÿÿ
qÿÿeÿÿ
uÿÿrÿÿ
eÿÿvÿÿ
uÿÿiÿÿ
eÿÿsÿÿ
ÿÿoÿÿ
nÿÿrÿÿ
oÿÿ ÿÿ
dÿÿMÿÿ
eÿÿoÿÿ
ÿÿdÿÿ
nÿÿeÿÿ
oÿÿ
ÿÿ
tÿÿ
ÿÿ
present
rÿÿ tÿÿ
eÿÿ aÿÿ
sÿÿ rÿÿ
eÿÿ tÿÿ
nÿÿ iÿÿ
tÿÿ nÿÿ
ÿÿ gÿÿ
ÿÿ app i2c_server
starting aÿÿ
sÿÿ pÿÿ
tÿÿ pÿÿ
aÿÿ ÿÿ
rÿÿ bÿÿ
tÿÿ pÿÿ
iÿÿ mÿÿ
nÿÿ pÿÿ
gÿÿ _iÿÿ
ÿÿ nÿÿ
aÿÿ cÿÿ
pÿÿ oÿÿ
p ÿÿ mÿÿ
gÿÿ iÿÿ
dÿÿ nÿÿ
bÿÿ gÿÿ
_ÿÿ
ÿÿ
aÿÿ
ÿÿ
gent
ÿÿ
ÿÿ
rver
D-S> ÿÿ Sever...
ÿÿVÿÿ
ÿÿC id 526
ÿÿpÿÿ
ÿÿ vÿÿRÿÿscÿÿeÿÿ
ÿÿserved IVC id 528
Reserved IVC id 529
Reserved IVC id 530
ÿÿ1
Reserved IVC id 532
Reserved IVC id 533
Reserved IVC id 534
Reserved IVC id 535
Reserved IVC id 536
Reserved IVC id 537
Reserved IVC id 538
Reserved IVC id 539
ÿÿaMMFLAGS=1
Starting RM server
Start nvpm server
Done...
ÿÿNÿÿ\00
ÿÿnÿÿ\00
ÿÿoÿÿ\00
GPRÿÿtÿÿ\00s:
ÿÿiÿÿ\00
ÿÿ\000000 ÿÿoÿÿ\00
x6: 0x000ÿÿfÿÿ
ÿÿ\001
ÿÿEÿÿ\00
ÿÿoÿÿ\000x2100bbÿÿ
ÿÿ\002c
0xÿÿ
ÿÿ\0021003ÿÿ
ÿÿnÿÿ\00514
0x210ÿÿpÿÿ\000155ÿÿ
ÿÿ\000ÿÿdÿÿ\00
0x21000184
Sÿÿpÿÿ\00iÿÿ
ÿÿ\00:
0x1766ÿÿ:ÿÿ\000
0x18350
0x12ÿÿ[ÿÿ\00070
ÿÿbÿÿbÿÿ
ÿÿ
ÿÿaÿÿ
ÿÿ
ÿÿbÿÿ
ÿÿ
ÿÿDÿÿ
ÿÿ1ÿÿ
ÿÿ
ÿÿSÿÿ
ÿÿ
ÿÿCÿÿ ÿÿCÿÿ
ÿÿ
ÿÿ ÿÿdÿÿ
ÿÿ
ÿÿCÿÿeÿÿ ÿÿ
ÿÿCÿÿ
ÿÿ
ÿÿ ÿÿ
ÿÿiÿÿ
ÿÿPÿÿ
ÿÿDÿÿ
ÿÿ:210035b0 >
\00
[/code]0
GPRÿÿtÿÿ[code]
\00ÿâ
\00ÿýÿàmain enter
HW Function test
Start Scheduler.
in late init
ÿâ
I> bit @ 0xd480000
I> Unpowergate done
I> Loading TOS ...
I> Loading EKS ...
I> Unhalting RCE
ÿâ
welcome to lk
dt initialized
mail initialized
chipid initialized
fuse initialized
sku initialized
speedo initialized
ec initialized
vmon initialized
adc initialized
fmon initialized
reset initialized
nvhs initialized
clk initialized
io_dpd initialized
thermal initialized
i2c initialized
aotag initialized
dvs initialized
pm initialized
pg_late initialized
strap initialized
tag initialized
emc initialized
clk_dt initialized
pm_post initialized
tj_init initialized
uphy_dt initialized
uphy initialized
mrq initialized
dmce initialized
cvc initialized
Starting OS
rm initialized
wake initialized
mail_fs initialized
profile initialized
ÿÿNvGpcDmaLibInitÿÿ
iÿÿ:ÿÿ
vÿÿHÿÿ
cÿÿyÿÿ
_ÿÿpÿÿ
qÿÿeÿÿ
uÿÿrÿÿ
eÿÿvÿÿ
uÿÿiÿÿ
eÿÿsÿÿ
ÿÿoÿÿ
nÿÿrÿÿ
oÿÿ ÿÿ
dÿÿMÿÿ
eÿÿoÿÿ
ÿÿdÿÿ
nÿÿeÿÿ
oÿÿ
ÿÿ
tÿÿ
ÿÿ
present
rÿÿ tÿÿ
eÿÿ aÿÿ
sÿÿ rÿÿ
eÿÿ tÿÿ
nÿÿ iÿÿ
tÿÿ nÿÿ
ÿÿ gÿÿ
ÿÿ app i2c_server
starting aÿÿ
sÿÿ pÿÿ
tÿÿ pÿÿ
aÿÿ ÿÿ
rÿÿ bÿÿ
tÿÿ pÿÿ
iÿÿ mÿÿ
nÿÿ pÿÿ
gÿÿ _iÿÿ
ÿÿ nÿÿ
aÿÿ cÿÿ
pÿÿ oÿÿ
p ÿÿ mÿÿ
gÿÿ iÿÿ
dÿÿ nÿÿ
bÿÿ gÿÿ
_ÿÿ
ÿÿ
aÿÿ
ÿÿ
gent
ÿÿ
ÿÿ
rver
D-S> ÿÿ Sever...
ÿÿVÿÿ
ÿÿC id 526
ÿÿpÿÿ
ÿÿ vÿÿRÿÿscÿÿeÿÿ
ÿÿserved IVC id 528
Reserved IVC id 529
Reserved IVC id 530
ÿÿ1
Reserved IVC id 532
Reserved IVC id 533
Reserved IVC id 534
Reserved IVC id 535
Reserved IVC id 536
Reserved IVC id 537
Reserved IVC id 538
Reserved IVC id 539
ÿÿaMMFLAGS=1
Starting RM server
Start nvpm server
Done...
ÿÿNÿÿ\00
ÿÿnÿÿ\00
ÿÿoÿÿ\00
GPRÿÿtÿÿ\00s:
ÿÿiÿÿ\00
ÿÿ\000000 ÿÿoÿÿ\00
x6: 0x000ÿÿfÿÿ
ÿÿ\001
ÿÿEÿÿ\00
ÿÿoÿÿ\000x2100bbÿÿ
ÿÿ\002c
0xÿÿ
ÿÿ\0021003ÿÿ
ÿÿnÿÿ\00514
0x210ÿÿpÿÿ\000155ÿÿ
ÿÿ\000ÿÿdÿÿ\00
0x21000184
Sÿÿpÿÿ\00iÿÿ
ÿÿ\00:
0x1766ÿÿ:ÿÿ\000
0x18350
0x12ÿÿ[ÿÿ\00070
ÿÿbÿÿbÿÿ
ÿÿ
ÿÿaÿÿ
ÿÿ
ÿÿbÿÿ
ÿÿ
ÿÿDÿÿ
ÿÿ1ÿÿ
ÿÿ
ÿÿSÿÿ
ÿÿ
ÿÿCÿÿ ÿÿCÿÿ
ÿÿ
ÿÿ ÿÿdÿÿ
ÿÿ
ÿÿCÿÿeÿÿ ÿÿ
ÿÿCÿÿ
ÿÿ
ÿÿ ÿÿ
ÿÿiÿÿ
ÿÿPÿÿ
ÿÿDÿÿ
ÿÿ:210035b0 >
\00
[/code]0s:
x0: ÿÿiÿÿ[code]
\00ÿâ
\00ÿýÿàmain enter
HW Function test
Start Scheduler.
in late init
ÿâ
I> bit @ 0xd480000
I> Unpowergate done
I> Loading TOS ...
I> Loading EKS ...
I> Unhalting RCE
ÿâ
welcome to lk
dt initialized
mail initialized
chipid initialized
fuse initialized
sku initialized
speedo initialized
ec initialized
vmon initialized
adc initialized
fmon initialized
reset initialized
nvhs initialized
clk initialized
io_dpd initialized
thermal initialized
i2c initialized
aotag initialized
dvs initialized
pm initialized
pg_late initialized
strap initialized
tag initialized
emc initialized
clk_dt initialized
pm_post initialized
tj_init initialized
uphy_dt initialized
uphy initialized
mrq initialized
dmce initialized
cvc initialized
Starting OS
rm initialized
wake initialized
mail_fs initialized
profile initialized
ÿÿNvGpcDmaLibInitÿÿ
iÿÿ:ÿÿ
vÿÿHÿÿ
cÿÿyÿÿ
_ÿÿpÿÿ
qÿÿeÿÿ
uÿÿrÿÿ
eÿÿvÿÿ
uÿÿiÿÿ
eÿÿsÿÿ
ÿÿoÿÿ
nÿÿrÿÿ
oÿÿ ÿÿ
dÿÿMÿÿ
eÿÿoÿÿ
ÿÿdÿÿ
nÿÿeÿÿ
oÿÿ
ÿÿ
tÿÿ
ÿÿ
present
rÿÿ tÿÿ
eÿÿ aÿÿ
sÿÿ rÿÿ
eÿÿ tÿÿ
nÿÿ iÿÿ
tÿÿ nÿÿ
ÿÿ gÿÿ
ÿÿ app i2c_server
starting aÿÿ
sÿÿ pÿÿ
tÿÿ pÿÿ
aÿÿ ÿÿ
rÿÿ bÿÿ
tÿÿ pÿÿ
iÿÿ mÿÿ
nÿÿ pÿÿ
gÿÿ _iÿÿ
ÿÿ nÿÿ
aÿÿ cÿÿ
pÿÿ oÿÿ
p ÿÿ mÿÿ
gÿÿ iÿÿ
dÿÿ nÿÿ
bÿÿ gÿÿ
_ÿÿ
ÿÿ
aÿÿ
ÿÿ
gent
ÿÿ
ÿÿ
rver
D-S> ÿÿ Sever...
ÿÿVÿÿ
ÿÿC id 526
ÿÿpÿÿ
ÿÿ vÿÿRÿÿscÿÿeÿÿ
ÿÿserved IVC id 528
Reserved IVC id 529
Reserved IVC id 530
ÿÿ1
Reserved IVC id 532
Reserved IVC id 533
Reserved IVC id 534
Reserved IVC id 535
Reserved IVC id 536
Reserved IVC id 537
Reserved IVC id 538
Reserved IVC id 539
ÿÿaMMFLAGS=1
Starting RM server
Start nvpm server
Done...
ÿÿNÿÿ\00
ÿÿnÿÿ\00
ÿÿoÿÿ\00
GPRÿÿtÿÿ\00s:
ÿÿiÿÿ\00
ÿÿ\000000 ÿÿoÿÿ\00
x6: 0x000ÿÿfÿÿ
ÿÿ\001
ÿÿEÿÿ\00
ÿÿoÿÿ\000x2100bbÿÿ
ÿÿ\002c
0xÿÿ
ÿÿ\0021003ÿÿ
ÿÿnÿÿ\00514
0x210ÿÿpÿÿ\000155ÿÿ
ÿÿ\000ÿÿdÿÿ\00
0x21000184
Sÿÿpÿÿ\00iÿÿ
ÿÿ\00:
0x1766ÿÿ:ÿÿ\000
0x18350
0x12ÿÿ[ÿÿ\00070
ÿÿbÿÿbÿÿ
ÿÿ
ÿÿaÿÿ
ÿÿ
ÿÿbÿÿ
ÿÿ
ÿÿDÿÿ
ÿÿ1ÿÿ
ÿÿ
ÿÿSÿÿ
ÿÿ
ÿÿCÿÿ ÿÿCÿÿ
ÿÿ
ÿÿ ÿÿdÿÿ
ÿÿ
ÿÿCÿÿeÿÿ ÿÿ
ÿÿCÿÿ
ÿÿ
ÿÿ ÿÿ
ÿÿiÿÿ
ÿÿPÿÿ
ÿÿDÿÿ
ÿÿ:210035b0 >
\00
[/code]00ÿÿoÿÿ[code]
\00ÿâ
\00ÿýÿàmain enter
HW Function test
Start Scheduler.
in late init
ÿâ
I> bit @ 0xd480000
I> Unpowergate done
I> Loading TOS ...
I> Loading EKS ...
I> Unhalting RCE
ÿâ
welcome to lk
dt initialized
mail initialized
chipid initialized
fuse initialized
sku initialized
speedo initialized
ec initialized
vmon initialized
adc initialized
fmon initialized
reset initialized
nvhs initialized
clk initialized
io_dpd initialized
thermal initialized
i2c initialized
aotag initialized
dvs initialized
pm initialized
pg_late initialized
strap initialized
tag initialized
emc initialized
clk_dt initialized
pm_post initialized
tj_init initialized
uphy_dt initialized
uphy initialized
mrq initialized
dmce initialized
cvc initialized
Starting OS
rm initialized
wake initialized
mail_fs initialized
profile initialized
ÿÿNvGpcDmaLibInitÿÿ
iÿÿ:ÿÿ
vÿÿHÿÿ
cÿÿyÿÿ
_ÿÿpÿÿ
qÿÿeÿÿ
uÿÿrÿÿ
eÿÿvÿÿ
uÿÿiÿÿ
eÿÿsÿÿ
ÿÿoÿÿ
nÿÿrÿÿ
oÿÿ ÿÿ
dÿÿMÿÿ
eÿÿoÿÿ
ÿÿdÿÿ
nÿÿeÿÿ
oÿÿ
ÿÿ
tÿÿ
ÿÿ
present
rÿÿ tÿÿ
eÿÿ aÿÿ
sÿÿ rÿÿ
eÿÿ tÿÿ
nÿÿ iÿÿ
tÿÿ nÿÿ
ÿÿ gÿÿ
ÿÿ app i2c_server
starting aÿÿ
sÿÿ pÿÿ
tÿÿ pÿÿ
aÿÿ ÿÿ
rÿÿ bÿÿ
tÿÿ pÿÿ
iÿÿ mÿÿ
nÿÿ pÿÿ
gÿÿ _iÿÿ
ÿÿ nÿÿ
aÿÿ cÿÿ
pÿÿ oÿÿ
p ÿÿ mÿÿ
gÿÿ iÿÿ
dÿÿ nÿÿ
bÿÿ gÿÿ
_ÿÿ
ÿÿ
aÿÿ
ÿÿ
gent
ÿÿ
ÿÿ
rver
D-S> ÿÿ Sever...
ÿÿVÿÿ
ÿÿC id 526
ÿÿpÿÿ
ÿÿ vÿÿRÿÿscÿÿeÿÿ
ÿÿserved IVC id 528
Reserved IVC id 529
Reserved IVC id 530
ÿÿ1
Reserved IVC id 532
Reserved IVC id 533
Reserved IVC id 534
Reserved IVC id 535
Reserved IVC id 536
Reserved IVC id 537
Reserved IVC id 538
Reserved IVC id 539
ÿÿaMMFLAGS=1
Starting RM server
Start nvpm server
Done...
ÿÿNÿÿ\00
ÿÿnÿÿ\00
ÿÿoÿÿ\00
GPRÿÿtÿÿ\00s:
ÿÿiÿÿ\00
ÿÿ\000000 ÿÿoÿÿ\00
x6: 0x000ÿÿfÿÿ
ÿÿ\001
ÿÿEÿÿ\00
ÿÿoÿÿ\000x2100bbÿÿ
ÿÿ\002c
0xÿÿ
ÿÿ\0021003ÿÿ
ÿÿnÿÿ\00514
0x210ÿÿpÿÿ\000155ÿÿ
ÿÿ\000ÿÿdÿÿ\00
0x21000184
Sÿÿpÿÿ\00iÿÿ
ÿÿ\00:
0x1766ÿÿ:ÿÿ\000
0x18350
0x12ÿÿ[ÿÿ\00070
ÿÿbÿÿbÿÿ
ÿÿ
ÿÿaÿÿ
ÿÿ
ÿÿbÿÿ
ÿÿ
ÿÿDÿÿ
ÿÿ1ÿÿ
ÿÿ
ÿÿSÿÿ
ÿÿ
ÿÿCÿÿ ÿÿCÿÿ
ÿÿ
ÿÿ ÿÿdÿÿ
ÿÿ
ÿÿCÿÿeÿÿ ÿÿ
ÿÿCÿÿ
ÿÿ
ÿÿ ÿÿ
ÿÿiÿÿ
ÿÿPÿÿ
ÿÿDÿÿ
ÿÿ:210035b0 >
\00
[/code]0x000000ÿÿ ÿÿ[code]
\00ÿâ
\00ÿýÿàmain enter
HW Function test
Start Scheduler.
in late init
ÿâ
I> bit @ 0xd480000
I> Unpowergate done
I> Loading TOS ...
I> Loading EKS ...
I> Unhalting RCE
ÿâ
welcome to lk
dt initialized
mail initialized
chipid initialized
fuse initialized
sku initialized
speedo initialized
ec initialized
vmon initialized
adc initialized
fmon initialized
reset initialized
nvhs initialized
clk initialized
io_dpd initialized
thermal initialized
i2c initialized
aotag initialized
dvs initialized
pm initialized
pg_late initialized
strap initialized
tag initialized
emc initialized
clk_dt initialized
pm_post initialized
tj_init initialized
uphy_dt initialized
uphy initialized
mrq initialized
dmce initialized
cvc initialized
Starting OS
rm initialized
wake initialized
mail_fs initialized
profile initialized
ÿÿNvGpcDmaLibInitÿÿ
iÿÿ:ÿÿ
vÿÿHÿÿ
cÿÿyÿÿ
_ÿÿpÿÿ
qÿÿeÿÿ
uÿÿrÿÿ
eÿÿvÿÿ
uÿÿiÿÿ
eÿÿsÿÿ
ÿÿoÿÿ
nÿÿrÿÿ
oÿÿ ÿÿ
dÿÿMÿÿ
eÿÿoÿÿ
ÿÿdÿÿ
nÿÿeÿÿ
oÿÿ
ÿÿ
tÿÿ
ÿÿ
present
rÿÿ tÿÿ
eÿÿ aÿÿ
sÿÿ rÿÿ
eÿÿ tÿÿ
nÿÿ iÿÿ
tÿÿ nÿÿ
ÿÿ gÿÿ
ÿÿ app i2c_server
starting aÿÿ
sÿÿ pÿÿ
tÿÿ pÿÿ
aÿÿ ÿÿ
rÿÿ bÿÿ
tÿÿ pÿÿ
iÿÿ mÿÿ
nÿÿ pÿÿ
gÿÿ _iÿÿ
ÿÿ nÿÿ
aÿÿ cÿÿ
pÿÿ oÿÿ
p ÿÿ mÿÿ
gÿÿ iÿÿ
dÿÿ nÿÿ
bÿÿ gÿÿ
_ÿÿ
ÿÿ
aÿÿ
ÿÿ
gent
ÿÿ
ÿÿ
rver
D-S> ÿÿ Sever...
ÿÿVÿÿ
ÿÿC id 526
ÿÿpÿÿ
ÿÿ vÿÿRÿÿscÿÿeÿÿ
ÿÿserved IVC id 528
Reserved IVC id 529
Reserved IVC id 530
ÿÿ1
Reserved IVC id 532
Reserved IVC id 533
Reserved IVC id 534
Reserved IVC id 535
Reserved IVC id 536
Reserved IVC id 537
Reserved IVC id 538
Reserved IVC id 539
ÿÿaMMFLAGS=1
Starting RM server
Start nvpm server
Done...
ÿÿNÿÿ\00
ÿÿnÿÿ\00
ÿÿoÿÿ\00
GPRÿÿtÿÿ\00s:
ÿÿiÿÿ\00
ÿÿ\000000 ÿÿoÿÿ\00
x6: 0x000ÿÿfÿÿ
ÿÿ\001
ÿÿEÿÿ\00
ÿÿoÿÿ\000x2100bbÿÿ
ÿÿ\002c
0xÿÿ
ÿÿ\0021003ÿÿ
ÿÿnÿÿ\00514
0x210ÿÿpÿÿ\000155ÿÿ
ÿÿ\000ÿÿdÿÿ\00
0x21000184
Sÿÿpÿÿ\00iÿÿ
ÿÿ\00:
0x1766ÿÿ:ÿÿ\000
0x18350
0x12ÿÿ[ÿÿ\00070
ÿÿbÿÿbÿÿ
ÿÿ
ÿÿaÿÿ
ÿÿ
ÿÿbÿÿ
ÿÿ
ÿÿDÿÿ
ÿÿ1ÿÿ
ÿÿ
ÿÿSÿÿ
ÿÿ
ÿÿCÿÿ ÿÿCÿÿ
ÿÿ
ÿÿ ÿÿdÿÿ
ÿÿ
ÿÿCÿÿeÿÿ ÿÿ
ÿÿCÿÿ
ÿÿ
ÿÿ ÿÿ
ÿÿiÿÿ
ÿÿPÿÿ
ÿÿDÿÿ
ÿÿ:210035b0 >
\00
[/code]00085a46cÿÿcÿÿ[code]
\00ÿâ
\00ÿýÿàmain enter
HW Function test
Start Scheduler.
in late init
ÿâ
I> bit @ 0xd480000
I> Unpowergate done
I> Loading TOS ...
I> Loading EKS ...
I> Unhalting RCE
ÿâ
welcome to lk
dt initialized
mail initialized
chipid initialized
fuse initialized
sku initialized
speedo initialized
ec initialized
vmon initialized
adc initialized
fmon initialized
reset initialized
nvhs initialized
clk initialized
io_dpd initialized
thermal initialized
i2c initialized
aotag initialized
dvs initialized
pm initialized
pg_late initialized
strap initialized
tag initialized
emc initialized
clk_dt initialized
pm_post initialized
tj_init initialized
uphy_dt initialized
uphy initialized
mrq initialized
dmce initialized
cvc initialized
Starting OS
rm initialized
wake initialized
mail_fs initialized
profile initialized
ÿÿNvGpcDmaLibInitÿÿ
iÿÿ:ÿÿ
vÿÿHÿÿ
cÿÿyÿÿ
_ÿÿpÿÿ
qÿÿeÿÿ
uÿÿrÿÿ
eÿÿvÿÿ
uÿÿiÿÿ
eÿÿsÿÿ
ÿÿoÿÿ
nÿÿrÿÿ
oÿÿ ÿÿ
dÿÿMÿÿ
eÿÿoÿÿ
ÿÿdÿÿ
nÿÿeÿÿ
oÿÿ
ÿÿ
tÿÿ
ÿÿ
present
rÿÿ tÿÿ
eÿÿ aÿÿ
sÿÿ rÿÿ
eÿÿ tÿÿ
nÿÿ iÿÿ
tÿÿ nÿÿ
ÿÿ gÿÿ
ÿÿ app i2c_server
starting aÿÿ
sÿÿ pÿÿ
tÿÿ pÿÿ
aÿÿ ÿÿ
rÿÿ bÿÿ
tÿÿ pÿÿ
iÿÿ mÿÿ
nÿÿ pÿÿ
gÿÿ _iÿÿ
ÿÿ nÿÿ
aÿÿ cÿÿ
pÿÿ oÿÿ
p ÿÿ mÿÿ
gÿÿ iÿÿ
dÿÿ nÿÿ
bÿÿ gÿÿ
_ÿÿ
ÿÿ
aÿÿ
ÿÿ
gent
ÿÿ
ÿÿ
rver
D-S> ÿÿ Sever...
ÿÿVÿÿ
ÿÿC id 526
ÿÿpÿÿ
ÿÿ vÿÿRÿÿscÿÿeÿÿ
ÿÿserved IVC id 528
Reserved IVC id 529
Reserved IVC id 530
ÿÿ1
Reserved IVC id 532
Reserved IVC id 533
Reserved IVC id 534
Reserved IVC id 535
Reserved IVC id 536
Reserved IVC id 537
Reserved IVC id 538
Reserved IVC id 539
ÿÿaMMFLAGS=1
Starting RM server
Start nvpm server
Done...
ÿÿNÿÿ\00
ÿÿnÿÿ\00
ÿÿoÿÿ\00
GPRÿÿtÿÿ\00s:
ÿÿiÿÿ\00
ÿÿ\000000 ÿÿoÿÿ\00
x6: 0x000ÿÿfÿÿ
ÿÿ\001
ÿÿEÿÿ\00
ÿÿoÿÿ\000x2100bbÿÿ
ÿÿ\002c
0xÿÿ
ÿÿ\0021003ÿÿ
ÿÿnÿÿ\00514
0x210ÿÿpÿÿ\000155ÿÿ
ÿÿ\000ÿÿdÿÿ\00
0x21000184
Sÿÿpÿÿ\00iÿÿ
ÿÿ\00:
0x1766ÿÿ:ÿÿ\000
0x18350
0x12ÿÿ[ÿÿ\00070
ÿÿbÿÿbÿÿ
ÿÿ
ÿÿaÿÿ
ÿÿ
ÿÿbÿÿ
ÿÿ
ÿÿDÿÿ
ÿÿ1ÿÿ
ÿÿ
ÿÿSÿÿ
ÿÿ
ÿÿCÿÿ ÿÿCÿÿ
ÿÿ
ÿÿ ÿÿdÿÿ
ÿÿ
ÿÿCÿÿeÿÿ ÿÿ
ÿÿCÿÿ
ÿÿ
ÿÿ ÿÿ
ÿÿiÿÿ
ÿÿPÿÿ
ÿÿDÿÿ
ÿÿ:210035b0 >
\00
[/code]04ÿÿtÿÿ[code]
\00ÿâ
\00ÿýÿàmain enter
HW Function test
Start Scheduler.
in late init
ÿâ
I> bit @ 0xd480000
I> Unpowergate done
I> Loading TOS ...
I> Loading EKS ...
I> Unhalting RCE
ÿâ
welcome to lk
dt initialized
mail initialized
chipid initialized
fuse initialized
sku initialized
speedo initialized
ec initialized
vmon initialized
adc initialized
fmon initialized
reset initialized
nvhs initialized
clk initialized
io_dpd initialized
thermal initialized
i2c initialized
aotag initialized
dvs initialized
pm initialized
pg_late initialized
strap initialized
tag initialized
emc initialized
clk_dt initialized
pm_post initialized
tj_init initialized
uphy_dt initialized
uphy initialized
mrq initialized
dmce initialized
cvc initialized
Starting OS
rm initialized
wake initialized
mail_fs initialized
profile initialized
ÿÿNvGpcDmaLibInitÿÿ
iÿÿ:ÿÿ
vÿÿHÿÿ
cÿÿyÿÿ
_ÿÿpÿÿ
qÿÿeÿÿ
uÿÿrÿÿ
eÿÿvÿÿ
uÿÿiÿÿ
eÿÿsÿÿ
ÿÿoÿÿ
nÿÿrÿÿ
oÿÿ ÿÿ
dÿÿMÿÿ
eÿÿoÿÿ
ÿÿdÿÿ
nÿÿeÿÿ
oÿÿ
ÿÿ
tÿÿ
ÿÿ
present
rÿÿ tÿÿ
eÿÿ aÿÿ
sÿÿ rÿÿ
eÿÿ tÿÿ
nÿÿ iÿÿ
tÿÿ nÿÿ
ÿÿ gÿÿ
ÿÿ app i2c_server
starting aÿÿ
sÿÿ pÿÿ
tÿÿ pÿÿ
aÿÿ ÿÿ
rÿÿ bÿÿ
tÿÿ pÿÿ
iÿÿ mÿÿ
nÿÿ pÿÿ
gÿÿ _iÿÿ
ÿÿ nÿÿ
aÿÿ cÿÿ
pÿÿ oÿÿ
p ÿÿ mÿÿ
gÿÿ iÿÿ
dÿÿ nÿÿ
bÿÿ gÿÿ
_ÿÿ
ÿÿ
aÿÿ
ÿÿ
gent
ÿÿ
ÿÿ
rver
D-S> ÿÿ Sever...
ÿÿVÿÿ
ÿÿC id 526
ÿÿpÿÿ
ÿÿ vÿÿRÿÿscÿÿeÿÿ
ÿÿserved IVC id 528
Reserved IVC id 529
Reserved IVC id 530
ÿÿ1
Reserved IVC id 532
Reserved IVC id 533
Reserved IVC id 534
Reserved IVC id 535
Reserved IVC id 536
Reserved IVC id 537
Reserved IVC id 538
Reserved IVC id 539
ÿÿaMMFLAGS=1
Starting RM server
Start nvpm server
Done...
ÿÿNÿÿ\00
ÿÿnÿÿ\00
ÿÿoÿÿ\00
GPRÿÿtÿÿ\00s:
ÿÿiÿÿ\00
ÿÿ\000000 ÿÿoÿÿ\00
x6: 0x000ÿÿfÿÿ
ÿÿ\001
ÿÿEÿÿ\00
ÿÿoÿÿ\000x2100bbÿÿ
ÿÿ\002c
0xÿÿ
ÿÿ\0021003ÿÿ
ÿÿnÿÿ\00514
0x210ÿÿpÿÿ\000155ÿÿ
ÿÿ\000ÿÿdÿÿ\00
0x21000184
Sÿÿpÿÿ\00iÿÿ
ÿÿ\00:
0x1766ÿÿ:ÿÿ\000
0x18350
0x12ÿÿ[ÿÿ\00070
ÿÿbÿÿbÿÿ
ÿÿ
ÿÿaÿÿ
ÿÿ
ÿÿbÿÿ
ÿÿ
ÿÿDÿÿ
ÿÿ1ÿÿ
ÿÿ
ÿÿSÿÿ
ÿÿ
ÿÿCÿÿ ÿÿCÿÿ
ÿÿ
ÿÿ ÿÿdÿÿ
ÿÿ
ÿÿCÿÿeÿÿ ÿÿ
ÿÿCÿÿ
ÿÿ
ÿÿ ÿÿ
ÿÿiÿÿ
ÿÿPÿÿ
ÿÿDÿÿ
ÿÿ:210035b0 >
\00
[/code]00 x1:ÿÿDÿÿ[code]
\00ÿâ
\00ÿýÿàmain enter
HW Function test
Start Scheduler.
in late init
ÿâ
I> bit @ 0xd480000
I> Unpowergate done
I> Loading TOS ...
I> Loading EKS ...
I> Unhalting RCE
ÿâ
welcome to lk
dt initialized
mail initialized
chipid initialized
fuse initialized
sku initialized
speedo initialized
ec initialized
vmon initialized
adc initialized
fmon initialized
reset initialized
nvhs initialized
clk initialized
io_dpd initialized
thermal initialized
i2c initialized
aotag initialized
dvs initialized
pm initialized
pg_late initialized
strap initialized
tag initialized
emc initialized
clk_dt initialized
pm_post initialized
tj_init initialized
uphy_dt initialized
uphy initialized
mrq initialized
dmce initialized
cvc initialized
Starting OS
rm initialized
wake initialized
mail_fs initialized
profile initialized
ÿÿNvGpcDmaLibInitÿÿ
iÿÿ:ÿÿ
vÿÿHÿÿ
cÿÿyÿÿ
_ÿÿpÿÿ
qÿÿeÿÿ
uÿÿrÿÿ
eÿÿvÿÿ
uÿÿiÿÿ
eÿÿsÿÿ
ÿÿoÿÿ
nÿÿrÿÿ
oÿÿ ÿÿ
dÿÿMÿÿ
eÿÿoÿÿ
ÿÿdÿÿ
nÿÿeÿÿ
oÿÿ
ÿÿ
tÿÿ
ÿÿ
present
rÿÿ tÿÿ
eÿÿ aÿÿ
sÿÿ rÿÿ
eÿÿ tÿÿ
nÿÿ iÿÿ
tÿÿ nÿÿ
ÿÿ gÿÿ
ÿÿ app i2c_server
starting aÿÿ
sÿÿ pÿÿ
tÿÿ pÿÿ
aÿÿ ÿÿ
rÿÿ bÿÿ
tÿÿ pÿÿ
iÿÿ mÿÿ
nÿÿ pÿÿ
gÿÿ _iÿÿ
ÿÿ nÿÿ
aÿÿ cÿÿ
pÿÿ oÿÿ
p ÿÿ mÿÿ
gÿÿ iÿÿ
dÿÿ nÿÿ
bÿÿ gÿÿ
_ÿÿ
ÿÿ
aÿÿ
ÿÿ
gent
ÿÿ
ÿÿ
rver
D-S> ÿÿ Sever...
ÿÿVÿÿ
ÿÿC id 526
ÿÿpÿÿ
ÿÿ vÿÿRÿÿscÿÿeÿÿ
ÿÿserved IVC id 528
Reserved IVC id 529
Reserved IVC id 530
ÿÿ1
Reserved IVC id 532
Reserved IVC id 533
Reserved IVC id 534
Reserved IVC id 535
Reserved IVC id 536
Reserved IVC id 537
Reserved IVC id 538
Reserved IVC id 539
ÿÿaMMFLAGS=1
Starting RM server
Start nvpm server
Done...
ÿÿNÿÿ\00
ÿÿnÿÿ\00
ÿÿoÿÿ\00
GPRÿÿtÿÿ\00s:
ÿÿiÿÿ\00
ÿÿ\000000 ÿÿoÿÿ\00
x6: 0x000ÿÿfÿÿ
ÿÿ\001
ÿÿEÿÿ\00
ÿÿoÿÿ\000x2100bbÿÿ
ÿÿ\002c
0xÿÿ
ÿÿ\0021003ÿÿ
ÿÿnÿÿ\00514
0x210ÿÿpÿÿ\000155ÿÿ
ÿÿ\000ÿÿdÿÿ\00
0x21000184
Sÿÿpÿÿ\00iÿÿ
ÿÿ\00:
0x1766ÿÿ:ÿÿ\000
0x18350
0x12ÿÿ[ÿÿ\00070
ÿÿbÿÿbÿÿ
ÿÿ
ÿÿaÿÿ
ÿÿ
ÿÿbÿÿ
ÿÿ
ÿÿDÿÿ
ÿÿ1ÿÿ
ÿÿ
ÿÿSÿÿ
ÿÿ
ÿÿCÿÿ ÿÿCÿÿ
ÿÿ
ÿÿ ÿÿdÿÿ
ÿÿ
ÿÿCÿÿeÿÿ ÿÿ
ÿÿCÿÿ
ÿÿ
ÿÿ ÿÿ
ÿÿiÿÿ
ÿÿPÿÿ
ÿÿDÿÿ
ÿÿ:210035b0 >
\00
[/code]0 0x0ÿÿDÿÿ[code]
\00ÿâ
\00ÿýÿàmain enter
HW Function test
Start Scheduler.
in late init
ÿâ
I> bit @ 0xd480000
I> Unpowergate done
I> Loading TOS ...
I> Loading EKS ...
I> Unhalting RCE
ÿâ
welcome to lk
dt initialized
mail initialized
chipid initialized
fuse initialized
sku initialized
speedo initialized
ec initialized
vmon initialized
adc initialized
fmon initialized
reset initialized
nvhs initialized
clk initialized
io_dpd initialized
thermal initialized
i2c initialized
aotag initialized
dvs initialized
pm initialized
pg_late initialized
strap initialized
tag initialized
emc initialized
clk_dt initialized
pm_post initialized
tj_init initialized
uphy_dt initialized
uphy initialized
mrq initialized
dmce initialized
cvc initialized
Starting OS
rm initialized
wake initialized
mail_fs initialized
profile initialized
ÿÿNvGpcDmaLibInitÿÿ
iÿÿ:ÿÿ
vÿÿHÿÿ
cÿÿyÿÿ
_ÿÿpÿÿ
qÿÿeÿÿ
uÿÿrÿÿ
eÿÿvÿÿ
uÿÿiÿÿ
eÿÿsÿÿ
ÿÿoÿÿ
nÿÿrÿÿ
oÿÿ ÿÿ
dÿÿMÿÿ
eÿÿoÿÿ
ÿÿdÿÿ
nÿÿeÿÿ
oÿÿ
ÿÿ
tÿÿ
ÿÿ
present
rÿÿ tÿÿ
eÿÿ aÿÿ
sÿÿ rÿÿ
eÿÿ tÿÿ
nÿÿ iÿÿ
tÿÿ nÿÿ
ÿÿ gÿÿ
ÿÿ app i2c_server
starting aÿÿ
sÿÿ pÿÿ
tÿÿ pÿÿ
aÿÿ ÿÿ
rÿÿ bÿÿ
tÿÿ pÿÿ
iÿÿ mÿÿ
nÿÿ pÿÿ
gÿÿ _iÿÿ
ÿÿ nÿÿ
aÿÿ cÿÿ
pÿÿ oÿÿ
p ÿÿ mÿÿ
gÿÿ iÿÿ
dÿÿ nÿÿ
bÿÿ gÿÿ
_ÿÿ
ÿÿ
aÿÿ
ÿÿ
gent
ÿÿ
ÿÿ
rver
D-S> ÿÿ Sever...
ÿÿVÿÿ
ÿÿC id 526
ÿÿpÿÿ
ÿÿ vÿÿRÿÿscÿÿeÿÿ
ÿÿserved IVC id 528
Reserved IVC id 529
Reserved IVC id 530
ÿÿ1
Reserved IVC id 532
Reserved IVC id 533
Reserved IVC id 534
Reserved IVC id 535
Reserved IVC id 536
Reserved IVC id 537
Reserved IVC id 538
Reserved IVC id 539
ÿÿaMMFLAGS=1
Starting RM server
Start nvpm server
Done...
ÿÿNÿÿ\00
ÿÿnÿÿ\00
ÿÿoÿÿ\00
GPRÿÿtÿÿ\00s:
ÿÿiÿÿ\00
ÿÿ\000000 ÿÿoÿÿ\00
x6: 0x000ÿÿfÿÿ
ÿÿ\001
ÿÿEÿÿ\00
ÿÿoÿÿ\000x2100bbÿÿ
ÿÿ\002c
0xÿÿ
ÿÿ\0021003ÿÿ
ÿÿnÿÿ\00514
0x210ÿÿpÿÿ\000155ÿÿ
ÿÿ\000ÿÿdÿÿ\00
0x21000184
Sÿÿpÿÿ\00iÿÿ
ÿÿ\00:
0x1766ÿÿ:ÿÿ\000
0x18350
0x12ÿÿ[ÿÿ\00070
ÿÿbÿÿbÿÿ
ÿÿ
ÿÿaÿÿ
ÿÿ
ÿÿbÿÿ
ÿÿ
ÿÿDÿÿ
ÿÿ1ÿÿ
ÿÿ
ÿÿSÿÿ
ÿÿ
ÿÿCÿÿ ÿÿCÿÿ
ÿÿ
ÿÿ ÿÿdÿÿ
ÿÿ
ÿÿCÿÿeÿÿ ÿÿ
ÿÿCÿÿ
ÿÿ
ÿÿ ÿÿ
ÿÿiÿÿ
ÿÿPÿÿ
ÿÿDÿÿ
ÿÿ:210035b0 >
\00
[/code]00ÿÿeÿÿ[code]
\00ÿâ
\00ÿýÿàmain enter
HW Function test
Start Scheduler.
in late init
ÿâ
I> bit @ 0xd480000
I> Unpowergate done
I> Loading TOS ...
I> Loading EKS ...
I> Unhalting RCE
ÿâ
welcome to lk
dt initialized
mail initialized
chipid initialized
fuse initialized
sku initialized
speedo initialized
ec initialized
vmon initialized
adc initialized
fmon initialized
reset initialized
nvhs initialized
clk initialized
io_dpd initialized
thermal initialized
i2c initialized
aotag initialized
dvs initialized
pm initialized
pg_late initialized
strap initialized
tag initialized
emc initialized
clk_dt initialized
pm_post initialized
tj_init initialized
uphy_dt initialized
uphy initialized
mrq initialized
dmce initialized
cvc initialized
Starting OS
rm initialized
wake initialized
mail_fs initialized
profile initialized
ÿÿNvGpcDmaLibInitÿÿ
iÿÿ:ÿÿ
vÿÿHÿÿ
cÿÿyÿÿ
_ÿÿpÿÿ
qÿÿeÿÿ
uÿÿrÿÿ
eÿÿvÿÿ
uÿÿiÿÿ
eÿÿsÿÿ
ÿÿoÿÿ
nÿÿrÿÿ
oÿÿ ÿÿ
dÿÿMÿÿ
eÿÿoÿÿ
ÿÿdÿÿ
nÿÿeÿÿ
oÿÿ
ÿÿ
tÿÿ
ÿÿ
present
rÿÿ tÿÿ
eÿÿ aÿÿ
sÿÿ rÿÿ
eÿÿ tÿÿ
nÿÿ iÿÿ
tÿÿ nÿÿ
ÿÿ gÿÿ
ÿÿ app i2c_server
starting aÿÿ
sÿÿ pÿÿ
tÿÿ pÿÿ
aÿÿ ÿÿ
rÿÿ bÿÿ
tÿÿ pÿÿ
iÿÿ mÿÿ
nÿÿ pÿÿ
gÿÿ _iÿÿ
ÿÿ nÿÿ
aÿÿ cÿÿ
pÿÿ oÿÿ
p ÿÿ mÿÿ
gÿÿ iÿÿ
dÿÿ nÿÿ
bÿÿ gÿÿ
_ÿÿ
ÿÿ
aÿÿ
ÿÿ
gent
ÿÿ
ÿÿ
rver
D-S> ÿÿ Sever...
ÿÿVÿÿ
ÿÿC id 526
ÿÿpÿÿ
ÿÿ vÿÿRÿÿscÿÿeÿÿ
ÿÿserved IVC id 528
Reserved IVC id 529
Reserved IVC id 530
ÿÿ1
Reserved IVC id 532
Reserved IVC id 533
Reserved IVC id 534
Reserved IVC id 535
Reserved IVC id 536
Reserved IVC id 537
Reserved IVC id 538
Reserved IVC id 539
ÿÿaMMFLAGS=1
Starting RM server
Start nvpm server
Done...
ÿÿNÿÿ\00
ÿÿnÿÿ\00
ÿÿoÿÿ\00
GPRÿÿtÿÿ\00s:
ÿÿiÿÿ\00
ÿÿ\000000 ÿÿoÿÿ\00
x6: 0x000ÿÿfÿÿ
ÿÿ\001
ÿÿEÿÿ\00
ÿÿoÿÿ\000x2100bbÿÿ
ÿÿ\002c
0xÿÿ
ÿÿ\0021003ÿÿ
ÿÿnÿÿ\00514
0x210ÿÿpÿÿ\000155ÿÿ
ÿÿ\000ÿÿdÿÿ\00
0x21000184
Sÿÿpÿÿ\00iÿÿ
ÿÿ\00:
0x1766ÿÿ:ÿÿ\000
0x18350
0x12ÿÿ[ÿÿ\00070
ÿÿbÿÿbÿÿ
ÿÿ
ÿÿaÿÿ
ÿÿ
ÿÿbÿÿ
ÿÿ
ÿÿDÿÿ
ÿÿ1ÿÿ
ÿÿ
ÿÿSÿÿ
ÿÿ
ÿÿCÿÿ ÿÿCÿÿ
ÿÿ
ÿÿ ÿÿdÿÿ
ÿÿ
ÿÿCÿÿeÿÿ ÿÿ
ÿÿCÿÿ
ÿÿ
ÿÿ ÿÿ
ÿÿiÿÿ
ÿÿPÿÿ
ÿÿDÿÿ
ÿÿ:210035b0 >
\00
[/code]0000ÿÿeÿÿ[code]
\00ÿâ
\00ÿýÿàmain enter
HW Function test
Start Scheduler.
in late init
ÿâ
I> bit @ 0xd480000
I> Unpowergate done
I> Loading TOS ...
I> Loading EKS ...
I> Unhalting RCE
ÿâ
welcome to lk
dt initialized
mail initialized
chipid initialized
fuse initialized
sku initialized
speedo initialized
ec initialized
vmon initialized
adc initialized
fmon initialized
reset initialized
nvhs initialized
clk initialized
io_dpd initialized
thermal initialized
i2c initialized
aotag initialized
dvs initialized
pm initialized
pg_late initialized
strap initialized
tag initialized
emc initialized
clk_dt initialized
pm_post initialized
tj_init initialized
uphy_dt initialized
uphy initialized
mrq initialized
dmce initialized
cvc initialized
Starting OS
rm initialized
wake initialized
mail_fs initialized
profile initialized
ÿÿNvGpcDmaLibInitÿÿ
iÿÿ:ÿÿ
vÿÿHÿÿ
cÿÿyÿÿ
_ÿÿpÿÿ
qÿÿeÿÿ
uÿÿrÿÿ
eÿÿvÿÿ
uÿÿiÿÿ
eÿÿsÿÿ
ÿÿoÿÿ
nÿÿrÿÿ
oÿÿ ÿÿ
dÿÿMÿÿ
eÿÿoÿÿ
ÿÿdÿÿ
nÿÿeÿÿ
oÿÿ
ÿÿ
tÿÿ
ÿÿ
present
rÿÿ tÿÿ
eÿÿ aÿÿ
sÿÿ rÿÿ
eÿÿ tÿÿ
nÿÿ iÿÿ
tÿÿ nÿÿ
ÿÿ gÿÿ
ÿÿ app i2c_server
starting aÿÿ
sÿÿ pÿÿ
tÿÿ pÿÿ
aÿÿ ÿÿ
rÿÿ bÿÿ
tÿÿ pÿÿ
iÿÿ mÿÿ
nÿÿ pÿÿ
gÿÿ _iÿÿ
ÿÿ nÿÿ
aÿÿ cÿÿ
pÿÿ oÿÿ
p ÿÿ mÿÿ
gÿÿ iÿÿ
dÿÿ nÿÿ
bÿÿ gÿÿ
_ÿÿ
ÿÿ
aÿÿ
ÿÿ
gent
ÿÿ
ÿÿ
rver
D-S> ÿÿ Sever...
ÿÿVÿÿ
ÿÿC id 526
ÿÿpÿÿ
ÿÿ vÿÿRÿÿscÿÿeÿÿ
ÿÿserved IVC id 528
Reserved IVC id 529
Reserved IVC id 530
ÿÿ1
Reserved IVC id 532
Reserved IVC id 533
Reserved IVC id 534
Reserved IVC id 535
Reserved IVC id 536
Reserved IVC id 537
Reserved IVC id 538
Reserved IVC id 539
ÿÿaMMFLAGS=1
Starting RM server
Start nvpm server
Done...
ÿÿNÿÿ\00
ÿÿnÿÿ\00
ÿÿoÿÿ\00
GPRÿÿtÿÿ\00s:
ÿÿiÿÿ\00
ÿÿ\000000 ÿÿoÿÿ\00
x6: 0x000ÿÿfÿÿ
ÿÿ\001
ÿÿEÿÿ\00
ÿÿoÿÿ\000x2100bbÿÿ
ÿÿ\002c
0xÿÿ
ÿÿ\0021003ÿÿ
ÿÿnÿÿ\00514
0x210ÿÿpÿÿ\000155ÿÿ
ÿÿ\000ÿÿdÿÿ\00
0x21000184
Sÿÿpÿÿ\00iÿÿ
ÿÿ\00:
0x1766ÿÿ:ÿÿ\000
0x18350
0x12ÿÿ[ÿÿ\00070
ÿÿbÿÿbÿÿ
ÿÿ
ÿÿaÿÿ
ÿÿ
ÿÿbÿÿ
ÿÿ
ÿÿDÿÿ
ÿÿ1ÿÿ
ÿÿ
ÿÿSÿÿ
ÿÿ
ÿÿCÿÿ ÿÿCÿÿ
ÿÿ
ÿÿ ÿÿdÿÿ
ÿÿ
ÿÿCÿÿeÿÿ ÿÿ
ÿÿCÿÿ
ÿÿ
ÿÿ ÿÿ
ÿÿiÿÿ
ÿÿPÿÿ
ÿÿDÿÿ
ÿÿ:210035b0 >
\00
[/code]000085e89cÿÿeÿÿ ÿÿ[code]
\00ÿâ
\00ÿýÿàmain enter
HW Function test
Start Scheduler.
in late init
ÿâ
I> bit @ 0xd480000
I> Unpowergate done
I> Loading TOS ...
I> Loading EKS ...
I> Unhalting RCE
ÿâ
welcome to lk
dt initialized
mail initialized
chipid initialized
fuse initialized
sku initialized
speedo initialized
ec initialized
vmon initialized
adc initialized
fmon initialized
reset initialized
nvhs initialized
clk initialized
io_dpd initialized
thermal initialized
i2c initialized
aotag initialized
dvs initialized
pm initialized
pg_late initialized
strap initialized
tag initialized
emc initialized
clk_dt initialized
pm_post initialized
tj_init initialized
uphy_dt initialized
uphy initialized
mrq initialized
dmce initialized
cvc initialized
Starting OS
rm initialized
wake initialized
mail_fs initialized
profile initialized
ÿÿNvGpcDmaLibInitÿÿ
iÿÿ:ÿÿ
vÿÿHÿÿ
cÿÿyÿÿ
_ÿÿpÿÿ
qÿÿeÿÿ
uÿÿrÿÿ
eÿÿvÿÿ
uÿÿiÿÿ
eÿÿsÿÿ
ÿÿoÿÿ
nÿÿrÿÿ
oÿÿ ÿÿ
dÿÿMÿÿ
eÿÿoÿÿ
ÿÿdÿÿ
nÿÿeÿÿ
oÿÿ
ÿÿ
tÿÿ
ÿÿ
present
rÿÿ tÿÿ
eÿÿ aÿÿ
sÿÿ rÿÿ
eÿÿ tÿÿ
nÿÿ iÿÿ
tÿÿ nÿÿ
ÿÿ gÿÿ
ÿÿ app i2c_server
starting aÿÿ
sÿÿ pÿÿ
tÿÿ pÿÿ
aÿÿ ÿÿ
rÿÿ bÿÿ
tÿÿ pÿÿ
iÿÿ mÿÿ
nÿÿ pÿÿ
gÿÿ _iÿÿ
ÿÿ nÿÿ
aÿÿ cÿÿ
pÿÿ oÿÿ
p ÿÿ mÿÿ
gÿÿ iÿÿ
dÿÿ nÿÿ
bÿÿ gÿÿ
_ÿÿ
ÿÿ
aÿÿ
ÿÿ
gent
ÿÿ
ÿÿ
rver
D-S> ÿÿ Sever...
ÿÿVÿÿ
ÿÿC id 526
ÿÿpÿÿ
ÿÿ vÿÿRÿÿscÿÿeÿÿ
ÿÿserved IVC id 528
Reserved IVC id 529
Reserved IVC id 530
ÿÿ1
Reserved IVC id 532
Reserved IVC id 533
Reserved IVC id 534
Reserved IVC id 535
Reserved IVC id 536
Reserved IVC id 537
Reserved IVC id 538
Reserved IVC id 539
ÿÿaMMFLAGS=1
Starting RM server
Start nvpm server
Done...
ÿÿNÿÿ\00
ÿÿnÿÿ\00
ÿÿoÿÿ\00
GPRÿÿtÿÿ\00s:
ÿÿiÿÿ\00
ÿÿ\000000 ÿÿoÿÿ\00
x6: 0x000ÿÿfÿÿ
ÿÿ\001
ÿÿEÿÿ\00
ÿÿoÿÿ\000x2100bbÿÿ
ÿÿ\002c
0xÿÿ
ÿÿ\0021003ÿÿ
ÿÿnÿÿ\00514
0x210ÿÿpÿÿ\000155ÿÿ
ÿÿ\000ÿÿdÿÿ\00
0x21000184
Sÿÿpÿÿ\00iÿÿ
ÿÿ\00:
0x1766ÿÿ:ÿÿ\000
0x18350
0x12ÿÿ[ÿÿ\00070
ÿÿbÿÿbÿÿ
ÿÿ
ÿÿaÿÿ
ÿÿ
ÿÿbÿÿ
ÿÿ
ÿÿDÿÿ
ÿÿ1ÿÿ
ÿÿ
ÿÿSÿÿ
ÿÿ
ÿÿCÿÿ ÿÿCÿÿ
ÿÿ
ÿÿ ÿÿdÿÿ
ÿÿ
ÿÿCÿÿeÿÿ ÿÿ
ÿÿCÿÿ
ÿÿ
ÿÿ ÿÿ
ÿÿiÿÿ
ÿÿPÿÿ
ÿÿDÿÿ
ÿÿ:210035b0 >
\00
[/code]038 xÿÿvÿÿ[code]
\00ÿâ
\00ÿýÿàmain enter
HW Function test
Start Scheduler.
in late init
ÿâ
I> bit @ 0xd480000
I> Unpowergate done
I> Loading TOS ...
I> Loading EKS ...
I> Unhalting RCE
ÿâ
welcome to lk
dt initialized
mail initialized
chipid initialized
fuse initialized
sku initialized
speedo initialized
ec initialized
vmon initialized
adc initialized
fmon initialized
reset initialized
nvhs initialized
clk initialized
io_dpd initialized
thermal initialized
i2c initialized
aotag initialized
dvs initialized
pm initialized
pg_late initialized
strap initialized
tag initialized
emc initialized
clk_dt initialized
pm_post initialized
tj_init initialized
uphy_dt initialized
uphy initialized
mrq initialized
dmce initialized
cvc initialized
Starting OS
rm initialized
wake initialized
mail_fs initialized
profile initialized
ÿÿNvGpcDmaLibInitÿÿ
iÿÿ:ÿÿ
vÿÿHÿÿ
cÿÿyÿÿ
_ÿÿpÿÿ
qÿÿeÿÿ
uÿÿrÿÿ
eÿÿvÿÿ
uÿÿiÿÿ
eÿÿsÿÿ
ÿÿoÿÿ
nÿÿrÿÿ
oÿÿ ÿÿ
dÿÿMÿÿ
eÿÿoÿÿ
ÿÿdÿÿ
nÿÿeÿÿ
oÿÿ
ÿÿ
tÿÿ
ÿÿ
present
rÿÿ tÿÿ
eÿÿ aÿÿ
sÿÿ rÿÿ
eÿÿ tÿÿ
nÿÿ iÿÿ
tÿÿ nÿÿ
ÿÿ gÿÿ
ÿÿ app i2c_server
starting aÿÿ
sÿÿ pÿÿ
tÿÿ pÿÿ
aÿÿ ÿÿ
rÿÿ bÿÿ
tÿÿ pÿÿ
iÿÿ mÿÿ
nÿÿ pÿÿ
gÿÿ _iÿÿ
ÿÿ nÿÿ
aÿÿ cÿÿ
pÿÿ oÿÿ
p ÿÿ mÿÿ
gÿÿ iÿÿ
dÿÿ nÿÿ
bÿÿ gÿÿ
_ÿÿ
ÿÿ
aÿÿ
ÿÿ
gent
ÿÿ
ÿÿ
rver
D-S> ÿÿ Sever...
ÿÿVÿÿ
ÿÿC id 526
ÿÿpÿÿ
ÿÿ vÿÿRÿÿscÿÿeÿÿ
ÿÿserved IVC id 528
Reserved IVC id 529
Reserved IVC id 530
ÿÿ1
Reserved IVC id 532
Reserved IVC id 533
Reserved IVC id 534
Reserved IVC id 535
Reserved IVC id 536
Reserved IVC id 537
Reserved IVC id 538
Reserved IVC id 539
ÿÿaMMFLAGS=1
Starting RM server
Start nvpm server
Done...
ÿÿNÿÿ\00
ÿÿnÿÿ\00
ÿÿoÿÿ\00
GPRÿÿtÿÿ\00s:
ÿÿiÿÿ\00
ÿÿ\000000 ÿÿoÿÿ\00
x6: 0x000ÿÿfÿÿ
ÿÿ\001
ÿÿEÿÿ\00
ÿÿoÿÿ\000x2100bbÿÿ
ÿÿ\002c
0xÿÿ
ÿÿ\0021003ÿÿ
ÿÿnÿÿ\00514
0x210ÿÿpÿÿ\000155ÿÿ
ÿÿ\000ÿÿdÿÿ\00
0x21000184
Sÿÿpÿÿ\00iÿÿ
ÿÿ\00:
0x1766ÿÿ:ÿÿ\000
0x18350
0x12ÿÿ[ÿÿ\00070
ÿÿbÿÿbÿÿ
ÿÿ
ÿÿaÿÿ
ÿÿ
ÿÿbÿÿ
ÿÿ
ÿÿDÿÿ
ÿÿ1ÿÿ
ÿÿ
ÿÿSÿÿ
ÿÿ
ÿÿCÿÿ ÿÿCÿÿ
ÿÿ
ÿÿ ÿÿdÿÿ
ÿÿ
ÿÿCÿÿeÿÿ ÿÿ
ÿÿCÿÿ
ÿÿ
ÿÿ ÿÿ
ÿÿiÿÿ
ÿÿPÿÿ
ÿÿDÿÿ
ÿÿ:210035b0 >
\00
[/code]02: 0x00000ÿÿfÿÿvÿÿ[code]
\00ÿâ
[0000.024] I> MISCREG_HIDREV_0: 0x21917
[0000.028] I> MB1 (prd-version: 00.22.180704-t194-39702425-7fcf5198)
[0000.034] I> Boot-mode: L0 coldboot
[0000.037] I> chip revision : A02
[0000.040] I> Bootrom patch version : 3 (correctly patched)
[0000.045] I> ATE fuse revision : 0x200
[0000.049] I> Ram repair fuse : 0x0
[0000.052] I> rst_source : 0x0
[0000.054] I> rst_level : 0x0
[0000.057] E> Last boot error: 0x00000000
[0000.061] I> Soft fuse initialized
[0000.064] I> Boot WARS Applied
[0000.067] I> Boot-device: QSPI
[0000.070] I> qspi flash params source = brbct
[0000.074] I> Qspi using bpmp-dma
[0000.077] I> Qspi clock source : pllp
[0000.080] I> QSPI Flash: Spansion 64MB
[0000.084] I> QSPI Flash Size = 64 MB
[0000.089] I> QSPI Flash: Set 512B page size
[0000.093] I> Qspi initialized successfully
[0000.097] I> Loading MB1-BCT to SysRAM
[0000.100] I> Boot-device: QSPI
[0000.103] I> Binary@ device:3/0 block-1536 (partition size: 0x20000)
[0000.109] I> qspi flash params source = brbct
[0000.114] I> Binary mb1bct loaded successfully at 0x40000000
[0000.120] I> MB1-BCT relocated to 0xd48bc00 from 0x40000000
[0000.125] I> Loading MEM-BCT to SysRAM
[0000.128] I> Binary@ device:3/0 block-2048 (partition size: 0x40000)
[0000.134] I> qspi flash params source = mb1bct
[0000.138] I> Qspi using bpmp-dma
[0000.141] I> Qspi clock source : pllp
[0000.145] I> Qspi reinitialized
[0000.149] I> Binary membct loaded successfully at 0x40000000
[0000.155] I> SDRAM params relocated to 0xd493400 from 0x40000000
[0000.160] I> SDRAM pack relocated to 0xd495c00 from 0x40000000
[0000.166] E> No fuse-bypass data
[0000.171] I> temperature = 31500
[0000.174] W> Skipping boost for clk:aon_cpu_nic
[0000.178] W> Skipping boost for clk:aon_can0
[0000.182] W> Skipping boost for clk:aon_can1
[0000.186] E> MB1_PLATFORM_CONFIG: prod table is empty in MB1 BCT.
[0000.192] I> Boot-device: QSPI
[0000.195] I> Boot-device: QSPI
[0000.198] I> qspi flash params source = mb1bct
[0000.202] I> Binary@ device:3/0 block-2560 (partition size: 0x40000)
[0000.208] I> qspi flash params source = mb1bct
[0000.214] I> Binary spe-fw loaded successfully at 0x40000000
[0000.221] I> ECC region[0]: Start:0x0, End:0x0
[0000.226] I> ECC region[1]: Start:0x0, End:0x0
[0000.230] I> ECC region[2]: Start:0x0, End:0x0
[0000.234] I> ECC region[3]: Start:0x0, End:0x0
[0000.238] I> ECC region[4]: Start:0x0, End:0x0
[0000.242] I> ECC region[5]: Start:0x0, End:0x0
[0000.246] I> Non-ECC region[0]: Start:0x80000000, End:0x100000000
[0000.252] I> Non-ECC region[1]: Start:0x0, End:0x0
[0000.256] I> Non-ECC region[2]: Start:0x0, End:0x0
[0000.261] I> Non-ECC region[3]: Start:0x0, End:0x0
[0000.265] I> Non-ECC region[4]: Start:0x0, End:0x0
[0000.269] I> Non-ECC region[5]: Start:0x0, End:0x0
[0000.274] I> Added Block:1 Start:0x80000000 End:0x100000000
[0000.280] I> allocated(CO:32) base:0xf8000000 size:0x8000000 align: 0x8000000
[0000.287] I> allocated(CO:33) base:0xf0000000 size:0x8000000 align: 0x100000
[0000.294] I> allocated(CO:38) base:0x80000000 size:0x8000000 align: 0x200000
[0000.301] I> allocated(CO:39) base:0x88000000 size:0x8000000 align: 0x8000000
[0000.307] I> allocated(CO:36) base:0x95a00000 size:0x4000000 align: 0x200000
[0000.314] I> allocated(CO:24) base:0xee000000 size:0x2000000 align: 0x2000000
[0000.321] I> allocated(CO:28) base:0xecc00000 size:0x1400000 align: 0x200000
[0000.327] I> allocated(CO:34) base:0xebc00000 size:0x1000000 align: 0x0
[0000.334] I> allocated(CO:35) base:0x90000000 size:0x1000000 align: 0x1000000
[0000.340] I> allocated(CO:7) base:0xeb000000 size:0x800000 align: 0x800000
[0000.347] I> allocated(CO:10) base:0xea800000 size:0x800000 align: 0x800000
[0000.353] I> allocated(CO:37) base:0xea000000 size:0x800000 align: 0x800000
[0000.360] I> allocated(CO:19) base:0xe9a00000 size:0x600000 align: 0x200000
[0000.366] I> allocated(CO:6) base:0xeb800000 size:0x400000 align: 0x200000
[0000.373] I> allocated(CO:27) base:0xe9600000 size:0x400000 align: 0x200000
[0000.380] I> allocated(CO:29) base:0xe9200000 size:0x400000 align: 0x200000
[0000.386] I> allocated(CO:1) base:0xe9100000 size:0x100000 align: 0x100000
[0000.393] I> allocated(CO:2) base:0xe9000000 size:0x100000 align: 0x100000
[0000.399] I> allocated(CO:3) base:0xe8f00000 size:0x100000 align: 0x100000
[0000.406] I> allocated(CO:4) base:0xe8e00000 size:0x100000 align: 0x100000
[0000.412] I> allocated(CO:5) base:0xe8d00000 size:0x100000 align: 0x100000
[0000.419] I> allocated(CO:8) base:0xe8c00000 size:0x100000 align: 0x100000
[0000.425] I> allocated(CO:9) base:0xe8b00000 size:0x100000 align: 0x100000
[0000.431] I> allocated(CO:12) base:0xe8a00000 size:0x100000 align: 0x100000
[0000.438] I> allocated(CO:17) base:0xe8900000 size:0x100000 align: 0x100000
[0000.445] I> allocated(CO:21) base:0xe88f0000 size:0x10000 align: 0x0
[0000.451] > MB1_PLATFORM_CONFIG: Rail ID 9 not found in pmic rail config table.
[0000.458] E> FAILED: Thermal config
[0000.465] > MB1_PLATFORM_CONFIG: Rail ID 7 not found in pmic rail config table.
[0000.472] E> FAILED: MEMIO rail config
[0000.475] I> MSS code-drop: NvBootSdramInit
[0000.492] I> scrub mode: full dram
[0000.495] E> Error: ECID of check failed!!
[0000.499] E> MB1 BCT does not have SCR table
[0000.503] I> Binary@ device:3/0 block-4608 (partition size: 0x40000)
[0000.509] I> qspi flash params source = mb1bct
[0000.523] I> RSA PSS signature check: OK
[0000.527] I> Binary preboot loaded successfully at 0x40000040
[0000.534] I> Restrict GSC#31 access to DPMU only
[0000.538] I> WP-0 triggered
[0000.540] I> WP-0 ACK received :)
[0000.544] I> CPU reset vector: 0x40000000
[0000.547] I> MTS carveout BOM: 0xff000000
[0000.551] I> MC_MTS_CARVEOUT_SIZE_MB_0: 0x10
[0000.555] I> Loading MCE
[0000.557] I> Binary@ device:3/0 block-5120 (partition size: 0x80000)
[0000.563] I> qspi flash params source = mb1bct
[0000.578] I> RSA PSS signature check: OK
[0000.585] I> Binary MCE loaded successfully at 0xbf080000
[0000.594] I> Loading MTS
[0000.596] I> Binary@ device:3/0 block-6144 (partition size: 0x400000)
[0000.602] I> qspi flash params source = mb1bct
[0000.661] I> Binary MTS loaded successfully at 0xbfa00000
[0000.678] I> WP-1 triggered
[0000.683] I> WP-1 ACK received :)
[0000.686] I> MTS carveout BOM: 0xf8000000
[0000.690] I> WP1.5 triggered
[0000.693] I> WP1.5 ACK received :)
[0000.696] E> MB1_PLATFORM_CONFIG: Bootrom mmio i2c table is empty in MB1 BCT.
[0000.703] I> Loading MB2
[0000.705] I> Binary@ device:3/0 block-3072 (partition size: 0x40000)
[0000.711] I> qspi flash params source = mb1bct
[0000.718] I> Binary mb2 loaded successfully at 0x52000000
[0000.723] I> co:0 offset:0x70000000
[0000.726] I> MB2-params @ 0x70000000
[0000.730] I> co:4 offset:0x70010000
[0000.733] I> co:1 offset:0x70020000
[0000.737] I> CO:(35) safe offset:0x53000000
[0000.741] I> CO:(37) safe offset:0x70030000
[0000.745] > MB1_PLATFORM_CONFIG: Rail ID 8 not found in pmic rail config table.
[0000.752] I> MB1 done
\00ÿýÿàmain enter
SPE VERSION #: R01.00.07 Created: Mar 21 2018 @ 15:14:19
HW Function test
Start Scheduler.
in late init
ÿâ
I> Welcome to MB2(TBoot-BPMP)
I> mb2 Safe end :0x52700000 mb2 safe start :0x52032044
I> co:0 offset:0x52700000
I> DMA Heap @ [0x52700000 - 0x53000000]
I> Default Heap @ [0xd486400 - 0xd488400]
I> qspi flash-0 params source = boot args
I> bit @ 0xd480000
I> Found 20 partitions in 00030000 device
I> co:8 offset:0x70030000
I> GR Blob not found or corrupted. Skipping GR Dump for MB1 Stage
I> Binary@ device:3/0 block-20480 (partition size: 0x100000)
I> header load address is : 0x5202fdf0
I> header of binary bpmp-fw read from storage device 3(0)
I> oem authentication of bpmp-fw header done
I> component list is filled with contents from header
I> parsing oem signed section of bpmp-fw header done
I> updated handle with bpmp-fw info. from oem comp table
I> bpmp-fw binary read from storage
I> Binary@ device:3/0 block-22528 (partition size: 0x100000)
I> header of binary bpmp-fw-dtb read from storage device 3(0)
I> oem authentication of bpmp-fw-dtb header done
I> parsing oem signed section of bpmp-fw-dtb header done
I> updated handle with bpmp-fw-dtb info. from oem comp table
I> bpmp-fw-dtb binary read from storage
I> BPMP-FW load address = 0x50000000
I> BPMP-FW DTB load address = 0x503e43a0
I> Loading SCE-FW ...
I> Binary@ device:3/0 block-24576 (partition size: 0x80000)
I> header of binary sce read from storage device 3(0)
I> oem authentication of sce header done
I> parsing oem signed section of sce header done
I> updated handle with sce info. from oem comp table
I> sce binary read from storage
I> Loading RCE-FW ...
I> Binary@ device:3/0 block-25600 (partition size: 0x80000)
I> header of binary rce read from storage device 3(0)
I> oem authentication of rce header done
I> parsing oem signed section of rce header done
I> updated handle with rce info. from oem comp table
I> rce binary read from storage
I> Unpowergating APE
I> Unpowergate done
I> Loading APE-FW ...
I> Binary@ device:3/0 block-26624 (partition size: 0x200000)
I> header of binary ape read from storage device 3(0)
I> oem authentication of ape header done
I> parsing oem signed section of ape header done
I> updated handle with ape info. from oem comp table
I> ape binary read from storage
I> Copy BTCM section
I> Binary@ device:3/0 block-14336 (partition size: 0x80000)
I> header of binary cpubl read from storage device 3(0)
I> oem authentication of cpubl header done
I> parsing oem signed section of cpubl header done
I> updated handle with cpubl info. from oem comp table
I> cpubl binary read from storage
I> co:4 offset:0x70040000
I> CPUBL-params @ 0x70040000
I> co:5 offset:0x70050000
I> Relocating BR-BCT
I> co:6 offset:0x70060000
I> BRBCT @ 0x40066c00
I> BR-BCT relocated to 0x70060000
I> CPU-BL loaded at : 0x96000000
I> Loading TOS ...
I> Binary@ device:3/0 block-15360 (partition size: 0x280000)
I> header of binary tos read from storage device 3(0)
I> oem authentication of tos header done
I> parsing oem signed section of tos header done
I> updated handle with tos info. from oem comp table
I> tos binary read from storage
I> TOS params:@0x52d02410
I> TLK boot-params @ 0x52d02410
I> TLK params prepared
I> Loading EKS ...
I> Binary@ device:3/0 block-30720 (partition size: 0x40000)
I> header of binary eks read from storage device 3(0)
I> oem authentication of eks header done
I> parsing oem signed section of eks header done
I> updated handle with eks info. from oem comp table
I> eks binary read from storage
I> EKS (length: 0x5000) @ 0x52d07800
I> Copied encrypted keys
I> Copying Monitor (length: 0x17170) from 0x52702600 to 0x40000000
I> Erasing Monitor @ 0x52702600
I> tos-params: tzdram_size: 0x1000000
I> tos-params: tzdram_base: 0xebc00000
I> tos-params: uart_port_id: 254
I> Copying TOS (length: 0x13e1d0) from 0x52719770 to 0xabc40000
I> Waypoint2-ACK: 0x52014d64
I> SCR config list empty
I> Unhalting RCE
I> GR Blob not found or corrupted. Skipping GR Dump for MB2 Stage
ÿäNOTICE: BL31: v1.3(release):934cbe7
NOTICE: BL31: Built : 10:49:22, Sep 4 2018
ÿâ
welcome to lk
ÿäÿâbpmp: platform_init
dt initialized
mail initialized
chipid initialized
fuse initialized
sku initialized
speedo initialized
ec initialized
vmon_populate_monitors: found 1 monitors
vmon initialized
vmon_soc_self_check: vmon_vsoc: self-check passed
adc initialized
fmon_populate_monitors: found 73 monitors
vrefro_re_cal: VrefRO: adjusted 0x82=>0x86
fmon_soc_ops_init: re-start disabled FMON_OSCnFUSE_CK
fmon_soc_ops_init: re-start disabled FMON_PMC_CK
fmon initialized
reset initialized
nvhs initialized
warning: pllp_vic do not permit 'allow_fractional_divider' property
warning: pllp_vic do not permit 'allowed-parents' property
warning: mphy_core_pll_fixed do not permit 'allowed-parents' property
warning: ufsdev_ref do not permit 'allowed-parents' property
warning: slvsec do not permit 'allowed-parents' property
warning: pllp_aon do not permit 'allow_fractional_divider' property
warning: pllp_aon do not permit 'allowed-parents' property
warning: mphy_tx_1mhz_ref do not permit 'allowed-parents' property
warning: sdmmc4 do not permit 'allow_fractional_divider' property
warning: eqos_tx do not permit 'allowed-parents' property
386 clocks registered
clk_mrq_init: mrq handler registered
clk initialized
io_dpd initialized
thermal initialized
ti2c_dt_parse: error fetching tlow
ti2c_dt_parse: error fetching thigh
i2c5 controller initialized
initialized i2c mrq handling
i2c initialized
WARNING: at platform/drivers/regulator/regulator-dt.c:126
regulator_parse_dt: regulator-ramp-delay is deprecated. Use regulator-ramp-delay-linear instead.
regulator initialized
avfs_clk_platform initialized
soctherm initialized
aotag initialized
powergate initialized
dvs initialized
pm initialized
pg_late initialized
strap initialized
tag initialized
emc initialized
WARNING: at platform/drivers/vfmon/fmon.c:456
invalid clock 307 rate 0
invalid clock 113 rate 0
fmon_enable: FMON_NVLINK_SYS: s/w DC fault is detected
invalid clock 118 rate 0
warning: i2c2 do not permit parent clk_m
warning: i2c8 do not permit parent clk_m
clk_update_possible_parents: clk_m not in allowed parent table for sdmmc4
warning: sor0_out do not permit parent pll_d
warning: sor0_out do not permit parent pll_dp
clk_update_possible_parents: sor_safe not in allowed parent table for sor0_out
warning: sor1_out do not permit parent pll_d2
warning: sor1_out do not permit parent pll_dp
clk_update_possible_parents: sor_safe not in allowed parent table for sor1_out
warning: sor2_out do not permit parent pll_d3
warning: sor2_out do not permit parent pll_dp
clk_update_possible_parents: sor_safe not in allowed parent table for sor2_out
warning: sor3_out do not permit parent pll_d4
warning: sor3_out do not permit parent pll_dp
clk_update_possible_parents: sor_safe not in allowed parent table for sor3_out
clk_dt initialized
avfs_ccplex_platform initialized
pm_post initialized
tj_max: dt node not found
tj_init initialized
uphy_mrq_init: mrq handler registered
uphy_dt initialized
uphy initialized
mrq initialized
clk_dt_late initialized
carveout 6: size check failed (0x20)
AST0 misconfig for DRAM: slave 0x050000001 master 0x0eb800000 mask 0x3ff000 control 0x80001
AST1 misconfig for DRAM: slave 0x050000001 master 0x0eb800000 mask 0x3ff000 control 0x80001
machine_check initialized
fmon_post initialized
tag is fce7e7e850bd06c123a330c57f701fca
tag_lateinit initialized
avfs_clk_platform_post initialized
dmce initialized
cvc initialized
ÿãCombined UART initialized
Starting OS
ÿâavfs_clk_mach_post initialized
ÿãInitialization done!
ÿâgboost_init initialized
aotag_hsm initialized
regulator_post initialized
rm initialized
sc7_diag initialized
thermal_test initialized
serial_late initialized
clk_post initialized
clk_dt_post initialized
wake initialized
sku_debugfs initialized
speedo_debugfs initialized
adc_debugfs initialized
clk_debugfs initialized
emc_debugfs initialized
ÿáqb:[E]: Partition not found ramdisk
qb:[E]: Error PartitionNotExist (0x30018)
ÿâdvs_debugfs initialized
ÿáqb:[E]: Partition not found kernel-dtb
ÿâfmon_debugfs initialized
vmon_debugfs initialized
pg_debugfs initialized
profile_fs initialized
debugfs_cons initialized
mail_fs initialized
profile initialized
cvc_debugfs initialized
dmce_debugfs initialized
ec_debugfs initialized
soctherm_debug initialized
debugfs_mrq initialized
ÿáÿÿýÿÿþÿâstarting app shell
entering main console loop
] ÿáDRIVE Hypervisor
ÿÿNvGpcDmaLibInitÿÿ
iÿÿ:ÿÿ
vÿÿHÿÿ
cÿÿyÿÿ
_ÿÿpÿÿ
qÿÿeÿÿ
uÿÿrÿÿ
eÿÿvÿÿ
uÿÿiÿÿ
eÿÿsÿÿ
ÿÿoÿÿ
nÿÿrÿÿ
oÿÿ ÿÿ
dÿÿMÿÿ
eÿÿoÿÿ
ÿÿdÿÿ
nÿÿeÿÿ
oÿÿ
ÿÿ
tÿÿ
ÿÿ
present
ivc_queue node not present
ivc_queue node not pÿÿ sÿÿ
rÿÿ tÿÿ
eÿÿ aÿÿ
sÿÿ rÿÿ
eÿÿ tÿÿ
nÿÿ iÿÿ
tÿÿ nÿÿ
ÿÿ gÿÿ
ÿÿ app i2c_server
starting aÿÿ
sÿÿ pÿÿ
tÿÿ pÿÿ
aÿÿ ÿÿ
rÿÿ bÿÿ
tÿÿ pÿÿ
iÿÿ mÿÿ
nÿÿ pÿÿ
gÿÿ _iÿÿ
ÿÿ nÿÿ
aÿÿ cÿÿ
pÿÿ oÿÿ
p ÿÿ mÿÿ
gÿÿ iÿÿ
dÿÿ nÿÿ
bÿÿ gÿÿ
_ÿÿ
ÿÿ
aÿÿ
ÿÿ
gent
ÿÿvirt/servers/servers/apps/thermal/cooling_devs/cdev_balanced_throttle.c: cpufreq-virt_init failed
Registered governor: pid_thermal_govmax20024: No regulator node found in pmc node
ÿÿ
starting app debug_seÿÿstarting app bpmp_ping
starting app thermal
trip_update_worker: Failed to get current temperature for zone 1
starting app bpmp_server
starting app cpÿÿSÿÿufÿÿtÿÿreÿÿaÿÿq_ÿÿrÿÿhvÿÿtÿÿ
ÿÿing TrustZoneÿÿstarting app bpmp_incoming
trip_update_worker: Failed to get current temperature for zone 7
ÿÿ
rver
D-S> ÿÿ Sever...
ÿÿevent logginÿÿRÿÿgÿÿeÿÿ nÿÿsÿÿotÿÿeÿÿ ÿÿrÿÿavÿÿvÿÿaiÿÿeÿÿlaÿÿdÿÿbÿÿ ÿÿleÿÿIÿÿ
ÿÿVÿÿ
ÿÿC id 526
Reserved IVC iÿÿstÿÿdÿÿaÿÿ ÿÿrtÿÿ5ÿÿinÿÿ2ÿÿgÿÿ7ÿÿ apÿÿ
ÿÿpÿÿ
ÿÿ vÿÿRÿÿscÿÿeÿÿ
ÿÿserved IVC id 528
Reserved IVC id 529
Reserved IVC id 530
Resÿÿsÿÿeÿÿtaÿÿrÿÿrtÿÿvÿÿinÿÿeÿÿgÿÿdÿÿ aÿÿ ÿÿppÿÿIÿÿ ÿÿVÿÿbpÿÿCÿÿmpÿÿ ÿÿ_ÿÿiÿÿinÿÿdÿÿcoÿÿ ÿÿmiÿÿ5ÿÿngÿÿ3ÿÿ
ÿÿ1
Reserved IVC id 532
Reserved IVC id 533
Reserved IVC id 534
Reserved IVC id 535
Reserved IVC id 536
Reserved IVC id 537
Reserved IVC id 538
Reserved IVC id 539
ÿäplatform_guest_warm_boot: guest warm reboot
ÿástarting app tz_server
ÿÿaMMFLAGS=1
Starting RM server
Start nvpm server
Setting BOARD_SHUTDOWN_DLL to /proc/boot/libnvshutdown.so if not set already
Done...
ÿÿstarting app se_server
ÿÿpl:[Eÿÿþ 2628418|HV/c4: ÿÿÿÿþGAC : GID 0 unhandled access of size 4 for Read operation on trap address 3270000 with err 0!
ÿÿ]:ÿÿpÿÿÿÿþ 2630931|HV/c4: ÿÿÿÿþGAC : GID 0 unhandled access of size 4 for Read operation on trap address 0 with err 0!
ÿÿ ÿÿlÿÿNÿÿ:ÿÿvÿÿ[ÿÿGÿÿEÿÿuÿÿ]:ÿÿeÿÿ ÿÿsÿÿNvÿÿtÿÿGÿÿFÿÿuÿÿiÿÿeÿÿnÿÿsÿÿdÿÿtÿÿBÿÿFÿÿoÿÿiÿÿoÿÿnÿÿtÿÿdÿÿDÿÿBÿÿeÿÿoÿÿvÿÿoÿÿiÿÿtÿÿcÿÿDÿÿeÿÿpÿÿÿäplatform_guest_warm_boot: guest warm reboot
ÿáÿäplatform_guest_warm_boot: guest warm reboot
ÿáeÿÿIÿÿlÿÿvÿÿnÿÿ:ÿÿiÿÿfÿÿ[ÿÿ\00
ÿÿcÿÿ\00GID 0:ÿÿoÿÿ\00 UnÿÿEÿÿ\00hanÿÿeÿÿ\00dled acÿÿ:ÿÿ\00cesÿÿ]ÿÿ\00s oÿÿIÿÿ\00f sizeÿÿ1ÿÿ\00 4 foÿÿ:ÿÿ\00r read.ÿÿnÿÿ\00
Acceÿÿ5ÿÿ\00ss sÿÿ ÿÿfÿÿ\00izeÿÿ9ÿÿ\00: 0x4
Fault ÿÿNÿÿ\00Iÿÿoÿÿ\00PA: 0ÿÿ ÿÿ\00x32700ÿÿvÿÿ\0000ÿÿ:ÿÿ\00
ESR_EL2ÿÿNÿÿ\00: 0x9382ÿÿGÿÿ\000ÿÿ1ÿÿ\00007
ÿÿoÿÿ\00Fatal VMÿÿuÿÿ\00 ÿÿ5ÿÿ\00Fault: ÿÿ ÿÿ\00Faileÿÿeÿÿ\00d ÿÿ9ÿÿ\00to haÿÿBÿÿ\00ndlÿÿsÿÿ\00e dÿÿ ÿÿ\00ata aÿÿoÿÿ\00borÿÿtÿÿ\00t!
ÿÿNÿÿ\00
VM Stÿÿoÿÿ\00atÿÿFÿÿ\00e:
Vÿÿoÿÿ\00CPU ID: 0xÿÿtÿÿiÿÿ\000
PC:ÿÿ ÿÿ\00 0x21009750ÿÿ ÿÿ\00
ÿÿnÿÿ\00
SPSR_ELÿÿBÿÿ\002: 0x800003cÿÿDÿÿdÿÿ\005
FAR_ELÿÿoÿÿ\002: 0x327ÿÿeÿÿBÿÿ\000000
Sÿÿoÿÿ\00PSR_EL1: 0xÿÿvÿÿ\000
ÿÿoÿÿ\00
GPRÿÿtÿÿ\00s:
x0: ÿÿiÿÿ\000ÿÿoÿÿ\00x000000ÿÿ ÿÿ\000085a46cÿÿcÿÿ\004ÿÿtÿÿ\000 x1:ÿÿDÿÿ\00 0x0ÿÿDÿÿ\000ÿÿeÿÿ\00000ÿÿeÿÿ\0000085e89cÿÿeÿÿ ÿÿ\0038 xÿÿvÿÿ\002: 0x00000ÿÿfÿÿvÿÿ\0000000ÿÿiÿÿ\00000000
ÿÿiÿÿ\00
xÿÿoÿÿ\003: ÿÿcÿÿÿäplatform_guest_warm_boot: guest warm reboot
ÿá\000x00000ÿÿcÿÿ\0000ÿÿuÿÿ\0000327ÿÿeÿÿ\000000 x4: 0xÿÿeÿÿ\000ÿÿnÿÿ\0000000ÿÿ ÿÿ\000085e89e58 x5ÿÿIÿÿdÿÿ\00: 0x00ÿÿfÿÿ\00000000000ÿÿnÿÿ\000ÿÿ
ÿÿ\000000 ÿÿoÿÿ\00
x6: 0x000ÿÿfÿÿ
ÿÿ\00000ÿÿuÿÿ\000000000001 ÿÿoÿÿ\00x7:ÿÿpÿÿnÿÿ\00 0x0000000ÿÿ:ÿÿ\0000000ÿÿlÿÿdÿÿ\000001 x8: ÿÿ1ÿÿ\000x0ÿÿ
ÿÿ:ÿÿ\00000000000ÿÿ5ÿÿ\000000ÿÿ[ÿÿ\000ÿÿ
ÿÿ\001
x9: 0x00ÿÿ9ÿÿ\000000ÿÿEÿÿ\0000ÿÿpÿÿ\0000000004 x10: 0x0ÿÿ]ÿÿ\000ÿÿlÿÿ\0000000000000022 xÿÿ:ÿÿ\0011:ÿÿ:ÿÿ\00 ÿÿ[ÿÿ\000x0000000085a42698
ÿÿEÿÿ\00
x12: 0x000ÿÿ ÿÿ\00000000000ÿÿ]ÿÿ\000000 x13: 0x0ÿÿQÿÿ\000000ÿÿ:ÿÿ\000ÿÿbÿÿ\000000000018ÿÿ ÿÿ\00 x14: 0x0000ÿÿQÿÿ\000ÿÿDÿÿ\0000000000001ÿÿbÿÿ\00
x15: ÿÿaÿÿ\000x00ÿÿDÿÿ\000ÿÿtÿÿ\0000000000000ÿÿaÿÿ\0000 x16: 0x0000000000000ÿÿtÿÿ\0006ÿÿaÿÿ\000 x17: 0x00000000ÿÿaÿÿ\0000000ÿÿDÿÿ\00080
x18: 0x00000ÿÿDÿÿ\000008ÿÿrÿÿ\005e80000 xÿÿ ÿÿ\0019: 0x0000ÿÿrÿÿ\0000ÿÿiÿÿ\000085a46aaÿÿNÿÿ\000 x20:ÿÿiÿÿ\00 0x00ÿÿvÿÿ\00000000ÿÿoÿÿ\0000000000
ÿÿvÿÿ\00x21ÿÿeÿÿ\00: 0x0000ÿÿ ÿÿ\00000085a46c40ÿÿeÿÿ\00 ÿÿnÿÿ\00x22: 0xÿÿBÿÿ\0000000000ÿÿnÿÿ\0000ÿÿIÿÿ\0000000ÿÿoÿÿ\000 x23: 0x000000ÿÿnÿÿ\00008ÿÿIÿÿ\005a46ÿÿoÿÿ\00ac8
x24: 0x0000ÿÿiÿÿ\000ÿÿnÿÿ\00000ÿÿtÿÿ\00ffffffff x25ÿÿtÿÿiÿÿ\00: ÿÿ ÿÿ\000x0000000085a46ÿÿ(ÿÿ\00c3ÿÿtÿÿ\008ÿÿDÿÿ\00 x26: 0x0000ÿÿ)ÿÿ\000000ÿÿ(ÿÿ\0085ÿÿeÿÿ\00a46ac0
x27: 0x0ÿÿ ÿÿ\0000ÿÿ)ÿÿ\000000ÿÿvÿÿ\00085a46ac8 ÿÿfÿÿ\00x28:ÿÿ ÿÿ\00 0ÿÿiÿÿ\00x000000000000ÿÿaÿÿ\0000ÿÿfÿÿ\0002 xÿÿcÿÿ\0029: 0x000000ÿÿiÿÿ\0000ÿÿaÿÿ\0085e7eÿÿeÿÿ\00db0
x30: 0x00ÿÿlÿÿ\0000ÿÿiÿÿ\00000021ÿÿ ÿÿ\00009dd8
Vÿÿeÿÿ\00M ÿÿlÿÿ\00Stackÿÿfÿÿ\00 Trace:
0x21009ÿÿdÿÿ\00dd8ÿÿeÿÿ\00
ÿÿoÿÿ\000x2100bbÿÿ
ÿÿ\002c
ÿÿdÿÿuÿÿ\000x21002fb0
0xÿÿ
ÿÿ\0021003ÿÿ
ÿÿnÿÿ\00514
0x210ÿÿpÿÿ\000155ÿÿ
ÿÿ\000ÿÿdÿÿ\00
0x21000184
Sÿÿpÿÿ\00iÿÿ
ÿÿ\00dÿÿlÿÿ\00ekick Stack Tracÿÿlÿÿ\00eÿÿ
ÿÿ\00:
0x1766ÿÿ:ÿÿ\000
0x18350
ÿÿ:ÿÿ\000xÿÿpÿÿ\00183e8
0x12ÿÿ[ÿÿ\00070
ÿÿ[ÿÿlÿÿEÿÿEÿÿ:ÿÿ]ÿÿ]ÿÿ[ÿÿ:ÿÿ:ÿÿEÿÿ ÿÿ ÿÿ]ÿÿBÿÿ:ÿÿBÿÿUÿÿ ÿÿUÿÿGÿÿQÿÿGÿÿ ÿÿbÿÿ ÿÿdÿÿDÿÿdÿÿaÿÿaÿÿaÿÿtÿÿtÿÿtÿÿaÿÿaÿÿaÿÿDÿÿ_ÿÿ_ÿÿrÿÿdÿÿdÿÿiÿÿrÿÿrÿÿvÿÿiÿÿiÿÿeÿÿvÿÿvÿÿnÿÿeÿÿeÿÿIÿÿnÿÿnÿÿnÿÿ_ÿÿ_ÿÿiÿÿdÿÿdÿÿtÿÿtÿÿtÿÿ(ÿÿ.ÿÿ.ÿÿ)ÿÿcÿÿcÿÿ ÿÿ:ÿÿ:ÿÿfÿÿ9ÿÿ9ÿÿaÿÿ2ÿÿ2ÿÿiÿÿ2ÿÿ2ÿÿlÿÿ ÿÿ ÿÿeÿÿ(ÿÿ(ÿÿdÿÿQÿÿQÿÿ
ÿÿbÿÿbÿÿ
ÿÿDÿÿDÿÿpÿÿaÿÿaÿÿlÿÿtÿÿtÿÿ:ÿÿaÿÿaÿÿ[ÿÿDÿÿDÿÿEÿÿrÿÿrÿÿ]ÿÿiÿÿiÿÿ:ÿÿvÿÿvÿÿ ÿÿeÿÿeÿÿBÿÿnÿÿnÿÿUÿÿIÿÿIÿÿGÿÿnÿÿnÿÿ ÿÿiÿÿiÿÿdÿÿtÿÿtÿÿaÿÿ)ÿÿ)ÿÿtÿÿ
ÿÿ
ÿÿaÿÿ
ÿÿ
ÿÿ_ÿÿpÿÿpÿÿdÿÿlÿÿlÿÿrÿÿ:ÿÿ:ÿÿiÿÿ[ÿÿ[ÿÿvÿÿEÿÿEÿÿeÿÿ]ÿÿ]ÿÿnÿÿ:ÿÿ:ÿÿ_ÿÿ ÿÿ ÿÿdÿÿSÿÿSÿÿtÿÿtÿÿtÿÿ.ÿÿaÿÿaÿÿcÿÿcÿÿcÿÿ:ÿÿkÿÿkÿÿ9ÿÿ ÿÿ ÿÿ2ÿÿtÿÿtÿÿrÿÿrÿÿaÿÿ2ÿÿaÿÿcÿÿ ÿÿcÿÿeÿÿ(ÿÿeÿÿ:ÿÿQÿÿ:ÿÿ
ÿÿbÿÿ
ÿÿ
ÿÿDÿÿ
ÿÿaÿÿpÿÿpÿÿtÿÿlÿÿlÿÿaÿÿ:ÿÿ:ÿÿDÿÿ[ÿÿ[ÿÿrÿÿEÿÿE]ÿÿ]ÿÿiÿÿ:ÿÿ:ÿÿvÿÿ ÿÿ ÿÿeÿÿ<ÿÿ<ÿÿnÿÿ ÿÿ ÿÿIÿÿPÿÿPÿÿnÿÿCÿÿCÿÿiÿÿ ÿÿ ÿÿtÿÿ:ÿÿ:ÿÿ)ÿÿ2ÿÿ2ÿÿ
ÿÿ1ÿÿ
ÿÿ1ÿÿ0ÿÿ0ÿÿpÿÿ0ÿÿ0ÿÿlÿÿ3ÿÿ3ÿÿ:ÿÿ5ÿÿ5ÿÿ[ÿÿbÿÿbÿÿEÿÿ0ÿÿ0ÿÿ]ÿÿ ÿÿ ÿÿ:ÿÿ>ÿÿ>ÿÿ ÿÿ
ÿÿ
ÿÿSÿÿ
ÿÿ
ÿÿtÿÿpÿÿpÿÿaÿÿlÿÿlÿÿcÿÿ:ÿÿpÿÿ:ÿÿkÿÿ[ÿÿlÿÿ[ÿÿ ÿÿEÿÿEÿÿtÿÿ:ÿÿ]ÿÿ]ÿÿrÿÿ[ÿÿ:ÿÿ:ÿÿaÿÿEÿÿ ÿÿ ÿÿcÿÿ<ÿÿ]ÿÿ<ÿÿeÿÿ ÿÿ ÿÿ:ÿÿPÿÿ:ÿÿPÿÿ
ÿÿCÿÿ ÿÿCÿÿ
ÿÿ ÿÿNÿÿ ÿÿpÿÿ:ÿÿ:ÿÿvÿÿlÿÿ2ÿÿ2ÿÿGÿÿ:ÿÿ1ÿÿ1ÿÿuÿÿ[ÿÿ0ÿÿ0ÿÿEÿÿeÿÿ0ÿÿ0ÿÿ]ÿÿ1ÿÿ1ÿÿ:ÿÿ5ÿÿsÿÿ5ÿÿ ÿÿ4ÿÿtÿÿ4ÿÿ<ÿÿcÿÿcÿÿFÿÿ ÿÿ ÿÿ ÿÿiÿÿPÿÿ>ÿÿ>ÿÿCÿÿnÿÿ
ÿÿ
ÿÿ ÿÿdÿÿ
ÿÿ
ÿÿ:ÿÿpÿÿ2ÿÿpÿÿlÿÿBÿÿlÿÿ1ÿÿ:ÿÿoÿÿ:ÿÿ0ÿÿ[ÿÿoÿÿ[ÿÿ0ÿÿEÿÿtÿÿEÿÿ3ÿÿ]ÿÿDÿÿ]ÿÿ5ÿÿ:ÿÿeÿÿ:ÿÿbÿÿ ÿÿvÿÿ ÿÿ0ÿÿ<ÿÿ<ÿÿ ÿÿ ÿÿ ÿÿiÿÿPÿÿ>ÿÿcÿÿPÿÿCÿÿ
ÿÿCÿÿeÿÿ ÿÿ
ÿÿ ÿÿIÿÿ:ÿÿpÿÿ:ÿÿnÿÿ2ÿÿlÿÿ2ÿÿfÿÿ:ÿÿ1ÿÿ1ÿÿ0ÿÿ[ÿÿ0ÿÿoÿÿEÿÿ0ÿÿ0ÿÿ0ÿÿ:ÿÿ]ÿÿ0ÿÿ1ÿÿ:ÿÿ1ÿÿ1ÿÿ8ÿÿ ÿÿ5ÿÿ8ÿÿ0ÿÿ<ÿÿ9ÿÿ0ÿÿ ÿÿ ÿÿ ÿÿ ÿÿ>ÿÿPÿÿNÿÿ>ÿÿ
ÿÿCÿÿ
ÿÿ
ÿÿ ÿÿ
ÿÿoÿÿ:ÿÿ ÿÿ2ÿÿBÿÿ1ÿÿoÿÿ00ÿÿoÿÿ1ÿÿtÿÿ5ÿÿ ÿÿ4cÿÿDÿÿ ÿÿeÿÿ>ÿÿvÿÿ
ÿÿiÿÿ
ÿÿcÿÿpÿÿeÿÿlÿÿ ÿÿ:[ÿÿfÿÿE]ÿÿoÿÿ:ÿÿuÿÿ ÿÿnÿÿ<ÿÿdÿÿ ÿÿ
ÿÿPÿÿ
ÿÿCÿÿpÿÿ :ÿÿlÿÿ21ÿÿ:ÿÿ0ÿÿ[ÿÿ0ÿÿEÿÿ0ÿÿ]ÿÿ1ÿÿ:ÿÿ8ÿÿ ÿÿ0 ÿÿQÿÿ>ÿÿbÿÿ
ÿÿDÿÿ
ÿÿataDrivenInit() failed
pl:[E]: BUG data_driven_dt.c:922 (QbDataDrivenInit)
pl:[E]: Stack trace:
pÿÿpl:[E]: NvGuestFindBootDeviceInfo:159 No Boot Device found
pl:[E]: QbDataDrivenInit() failed
pl:[E]: < PC ÿÿl:[E]: < PC :210035b0 >
pl:[E]: < PC :2100154c >
pl:[E]: < PC :21000180 >
ÿÿ:210035b0 >
ÿãHSM ERROR 244, CRITICAL_ERR_NVL_CAR
\00
[/code]000000ÿÿiÿÿ[code]
\00ÿâ
\00ÿýÿàmain enter
HW Function test
Start Scheduler.
in late init
ÿâ
I> bit @ 0xd480000
I> Unpowergate done
I> Loading TOS ...
I> Loading EKS ...
I> Unhalting RCE
ÿâ
welcome to lk
dt initialized
mail initialized
chipid initialized
fuse initialized
sku initialized
speedo initialized
ec initialized
vmon initialized
adc initialized
fmon initialized
reset initialized
nvhs initialized
clk initialized
io_dpd initialized
thermal initialized
i2c initialized
aotag initialized
dvs initialized
pm initialized
pg_late initialized
strap initialized
tag initialized
emc initialized
clk_dt initialized
pm_post initialized
tj_init initialized
uphy_dt initialized
uphy initialized
mrq initialized
dmce initialized
cvc initialized
Starting OS
rm initialized
wake initialized
mail_fs initialized
profile initialized
ÿÿNvGpcDmaLibInitÿÿ
iÿÿ:ÿÿ
vÿÿHÿÿ
cÿÿyÿÿ
_ÿÿpÿÿ
qÿÿeÿÿ
uÿÿrÿÿ
eÿÿvÿÿ
uÿÿiÿÿ
eÿÿsÿÿ
ÿÿoÿÿ
nÿÿrÿÿ
oÿÿ ÿÿ
dÿÿMÿÿ
eÿÿoÿÿ
ÿÿdÿÿ
nÿÿeÿÿ
oÿÿ
ÿÿ
tÿÿ
ÿÿ
present
rÿÿ tÿÿ
eÿÿ aÿÿ
sÿÿ rÿÿ
eÿÿ tÿÿ
nÿÿ iÿÿ
tÿÿ nÿÿ
ÿÿ gÿÿ
ÿÿ app i2c_server
starting aÿÿ
sÿÿ pÿÿ
tÿÿ pÿÿ
aÿÿ ÿÿ
rÿÿ bÿÿ
tÿÿ pÿÿ
iÿÿ mÿÿ
nÿÿ pÿÿ
gÿÿ _iÿÿ
ÿÿ nÿÿ
aÿÿ cÿÿ
pÿÿ oÿÿ
p ÿÿ mÿÿ
gÿÿ iÿÿ
dÿÿ nÿÿ
bÿÿ gÿÿ
_ÿÿ
ÿÿ
aÿÿ
ÿÿ
gent
ÿÿ
ÿÿ
rver
D-S> ÿÿ Sever...
ÿÿVÿÿ
ÿÿC id 526
ÿÿpÿÿ
ÿÿ vÿÿRÿÿscÿÿeÿÿ
ÿÿserved IVC id 528
Reserved IVC id 529
Reserved IVC id 530
ÿÿ1
Reserved IVC id 532
Reserved IVC id 533
Reserved IVC id 534
Reserved IVC id 535
Reserved IVC id 536
Reserved IVC id 537
Reserved IVC id 538
Reserved IVC id 539
ÿÿaMMFLAGS=1
Starting RM server
Start nvpm server
Done...
ÿÿNÿÿ\00
ÿÿnÿÿ\00
ÿÿoÿÿ\00
GPRÿÿtÿÿ\00s:
ÿÿiÿÿ\00
ÿÿ\000000 ÿÿoÿÿ\00
x6: 0x000ÿÿfÿÿ
ÿÿ\001
ÿÿEÿÿ\00
ÿÿoÿÿ\000x2100bbÿÿ
ÿÿ\002c
0xÿÿ
ÿÿ\0021003ÿÿ
ÿÿnÿÿ\00514
0x210ÿÿpÿÿ\000155ÿÿ
ÿÿ\000ÿÿdÿÿ\00
0x21000184
Sÿÿpÿÿ\00iÿÿ
ÿÿ\00:
0x1766ÿÿ:ÿÿ\000
0x18350
0x12ÿÿ[ÿÿ\00070
ÿÿbÿÿbÿÿ
ÿÿ
ÿÿaÿÿ
ÿÿ
ÿÿbÿÿ
ÿÿ
ÿÿDÿÿ
ÿÿ1ÿÿ
ÿÿ
ÿÿSÿÿ
ÿÿ
ÿÿCÿÿ ÿÿCÿÿ
ÿÿ
ÿÿ ÿÿdÿÿ
ÿÿ
ÿÿCÿÿeÿÿ ÿÿ
ÿÿCÿÿ
ÿÿ
ÿÿ ÿÿ
ÿÿiÿÿ
ÿÿPÿÿ
ÿÿDÿÿ
ÿÿ:210035b0 >
\00
[/code]0000000
ÿÿiÿÿ[code]
\00ÿâ
\00ÿýÿàmain enter
HW Function test
Start Scheduler.
in late init
ÿâ
I> bit @ 0xd480000
I> Unpowergate done
I> Loading TOS ...
I> Loading EKS ...
I> Unhalting RCE
ÿâ
welcome to lk
dt initialized
mail initialized
chipid initialized
fuse initialized
sku initialized
speedo initialized
ec initialized
vmon initialized
adc initialized
fmon initialized
reset initialized
nvhs initialized
clk initialized
io_dpd initialized
thermal initialized
i2c initialized
aotag initialized
dvs initialized
pm initialized
pg_late initialized
strap initialized
tag initialized
emc initialized
clk_dt initialized
pm_post initialized
tj_init initialized
uphy_dt initialized
uphy initialized
mrq initialized
dmce initialized
cvc initialized
Starting OS
rm initialized
wake initialized
mail_fs initialized
profile initialized
ÿÿNvGpcDmaLibInitÿÿ
iÿÿ:ÿÿ
vÿÿHÿÿ
cÿÿyÿÿ
_ÿÿpÿÿ
qÿÿeÿÿ
uÿÿrÿÿ
eÿÿvÿÿ
uÿÿiÿÿ
eÿÿsÿÿ
ÿÿoÿÿ
nÿÿrÿÿ
oÿÿ ÿÿ
dÿÿMÿÿ
eÿÿoÿÿ
ÿÿdÿÿ
nÿÿeÿÿ
oÿÿ
ÿÿ
tÿÿ
ÿÿ
present
rÿÿ tÿÿ
eÿÿ aÿÿ
sÿÿ rÿÿ
eÿÿ tÿÿ
nÿÿ iÿÿ
tÿÿ nÿÿ
ÿÿ gÿÿ
ÿÿ app i2c_server
starting aÿÿ
sÿÿ pÿÿ
tÿÿ pÿÿ
aÿÿ ÿÿ
rÿÿ bÿÿ
tÿÿ pÿÿ
iÿÿ mÿÿ
nÿÿ pÿÿ
gÿÿ _iÿÿ
ÿÿ nÿÿ
aÿÿ cÿÿ
pÿÿ oÿÿ
p ÿÿ mÿÿ
gÿÿ iÿÿ
dÿÿ nÿÿ
bÿÿ gÿÿ
_ÿÿ
ÿÿ
aÿÿ
ÿÿ
gent
ÿÿ
ÿÿ
rver
D-S> ÿÿ Sever...
ÿÿVÿÿ
ÿÿC id 526
ÿÿpÿÿ
ÿÿ vÿÿRÿÿscÿÿeÿÿ
ÿÿserved IVC id 528
Reserved IVC id 529
Reserved IVC id 530
ÿÿ1
Reserved IVC id 532
Reserved IVC id 533
Reserved IVC id 534
Reserved IVC id 535
Reserved IVC id 536
Reserved IVC id 537
Reserved IVC id 538
Reserved IVC id 539
ÿÿaMMFLAGS=1
Starting RM server
Start nvpm server
Done...
ÿÿNÿÿ\00
ÿÿnÿÿ\00
ÿÿoÿÿ\00
GPRÿÿtÿÿ\00s:
ÿÿiÿÿ\00
ÿÿ\000000 ÿÿoÿÿ\00
x6: 0x000ÿÿfÿÿ
ÿÿ\001
ÿÿEÿÿ\00
ÿÿoÿÿ\000x2100bbÿÿ
ÿÿ\002c
0xÿÿ
ÿÿ\0021003ÿÿ
ÿÿnÿÿ\00514
0x210ÿÿpÿÿ\000155ÿÿ
ÿÿ\000ÿÿdÿÿ\00
0x21000184
Sÿÿpÿÿ\00iÿÿ
ÿÿ\00:
0x1766ÿÿ:ÿÿ\000
0x18350
0x12ÿÿ[ÿÿ\00070
ÿÿbÿÿbÿÿ
ÿÿ
ÿÿaÿÿ
ÿÿ
ÿÿbÿÿ
ÿÿ
ÿÿDÿÿ
ÿÿ1ÿÿ
ÿÿ
ÿÿSÿÿ
ÿÿ
ÿÿCÿÿ ÿÿCÿÿ
ÿÿ
ÿÿ ÿÿdÿÿ
ÿÿ
ÿÿCÿÿeÿÿ ÿÿ
ÿÿCÿÿ
ÿÿ
ÿÿ ÿÿ
ÿÿiÿÿ
ÿÿPÿÿ
ÿÿDÿÿ
ÿÿ:210035b0 >
\00
[/code]0
xÿÿoÿÿ[code]
\00ÿâ
\00ÿýÿàmain enter
HW Function test
Start Scheduler.
in late init
ÿâ
I> bit @ 0xd480000
I> Unpowergate done
I> Loading TOS ...
I> Loading EKS ...
I> Unhalting RCE
ÿâ
welcome to lk
dt initialized
mail initialized
chipid initialized
fuse initialized
sku initialized
speedo initialized
ec initialized
vmon initialized
adc initialized
fmon initialized
reset initialized
nvhs initialized
clk initialized
io_dpd initialized
thermal initialized
i2c initialized
aotag initialized
dvs initialized
pm initialized
pg_late initialized
strap initialized
tag initialized
emc initialized
clk_dt initialized
pm_post initialized
tj_init initialized
uphy_dt initialized
uphy initialized
mrq initialized
dmce initialized
cvc initialized
Starting OS
rm initialized
wake initialized
mail_fs initialized
profile initialized
ÿÿNvGpcDmaLibInitÿÿ
iÿÿ:ÿÿ
vÿÿHÿÿ
cÿÿyÿÿ
_ÿÿpÿÿ
qÿÿeÿÿ
uÿÿrÿÿ
eÿÿvÿÿ
uÿÿiÿÿ
eÿÿsÿÿ
ÿÿoÿÿ
nÿÿrÿÿ
oÿÿ ÿÿ
dÿÿMÿÿ
eÿÿoÿÿ
ÿÿdÿÿ
nÿÿeÿÿ
oÿÿ
ÿÿ
tÿÿ
ÿÿ
present
rÿÿ tÿÿ
eÿÿ aÿÿ
sÿÿ rÿÿ
eÿÿ tÿÿ
nÿÿ iÿÿ
tÿÿ nÿÿ
ÿÿ gÿÿ
ÿÿ app i2c_server
starting aÿÿ
sÿÿ pÿÿ
tÿÿ pÿÿ
aÿÿ ÿÿ
rÿÿ bÿÿ
tÿÿ pÿÿ
iÿÿ mÿÿ
nÿÿ pÿÿ
gÿÿ _iÿÿ
ÿÿ nÿÿ
aÿÿ cÿÿ
pÿÿ oÿÿ
p ÿÿ mÿÿ
gÿÿ iÿÿ
dÿÿ nÿÿ
bÿÿ gÿÿ
_ÿÿ
ÿÿ
aÿÿ
ÿÿ
gent
ÿÿ
ÿÿ
rver
D-S> ÿÿ Sever...
ÿÿVÿÿ
ÿÿC id 526
ÿÿpÿÿ
ÿÿ vÿÿRÿÿscÿÿeÿÿ
ÿÿserved IVC id 528
Reserved IVC id 529
Reserved IVC id 530
ÿÿ1
Reserved IVC id 532
Reserved IVC id 533
Reserved IVC id 534
Reserved IVC id 535
Reserved IVC id 536
Reserved IVC id 537
Reserved IVC id 538
Reserved IVC id 539
ÿÿaMMFLAGS=1
Starting RM server
Start nvpm server
Done...
ÿÿNÿÿ\00
ÿÿnÿÿ\00
ÿÿoÿÿ\00
GPRÿÿtÿÿ\00s:
ÿÿiÿÿ\00
ÿÿ\000000 ÿÿoÿÿ\00
x6: 0x000ÿÿfÿÿ
ÿÿ\001
ÿÿEÿÿ\00
ÿÿoÿÿ\000x2100bbÿÿ
ÿÿ\002c
0xÿÿ
ÿÿ\0021003ÿÿ
ÿÿnÿÿ\00514
0x210ÿÿpÿÿ\000155ÿÿ
ÿÿ\000ÿÿdÿÿ\00
0x21000184
Sÿÿpÿÿ\00iÿÿ
ÿÿ\00:
0x1766ÿÿ:ÿÿ\000
0x18350
0x12ÿÿ[ÿÿ\00070
ÿÿbÿÿbÿÿ
ÿÿ
ÿÿaÿÿ
ÿÿ
ÿÿbÿÿ
ÿÿ
ÿÿDÿÿ
ÿÿ1ÿÿ
ÿÿ
ÿÿSÿÿ
ÿÿ
ÿÿCÿÿ ÿÿCÿÿ
ÿÿ
ÿÿ ÿÿdÿÿ
ÿÿ
ÿÿCÿÿeÿÿ ÿÿ
ÿÿCÿÿ
ÿÿ
ÿÿ ÿÿ
ÿÿiÿÿ
ÿÿPÿÿ
ÿÿDÿÿ
ÿÿ:210035b0 >
\00
[/code]03: ÿÿcÿÿÿäplatform_guest_warm_boot: guest warm reboot
ÿá[code]
\00ÿâ
\00ÿýÿàmain enter
HW Function test
Start Scheduler.
in late init
ÿâ
I> bit @ 0xd480000
I> Unpowergate done
I> Loading TOS ...
I> Loading EKS ...
I> Unhalting RCE
ÿâ
welcome to lk
dt initialized
mail initialized
chipid initialized
fuse initialized
sku initialized
speedo initialized
ec initialized
vmon initialized
adc initialized
fmon initialized
reset initialized
nvhs initialized
clk initialized
io_dpd initialized
thermal initialized
i2c initialized
aotag initialized
dvs initialized
pm initialized
pg_late initialized
strap initialized
tag initialized
emc initialized
clk_dt initialized
pm_post initialized
tj_init initialized
uphy_dt initialized
uphy initialized
mrq initialized
dmce initialized
cvc initialized
Starting OS
rm initialized
wake initialized
mail_fs initialized
profile initialized
ÿÿNvGpcDmaLibInitÿÿ
iÿÿ:ÿÿ
vÿÿHÿÿ
cÿÿyÿÿ
_ÿÿpÿÿ
qÿÿeÿÿ
uÿÿrÿÿ
eÿÿvÿÿ
uÿÿiÿÿ
eÿÿsÿÿ
ÿÿoÿÿ
nÿÿrÿÿ
oÿÿ ÿÿ
dÿÿMÿÿ
eÿÿoÿÿ
ÿÿdÿÿ
nÿÿeÿÿ
oÿÿ
ÿÿ
tÿÿ
ÿÿ
present
rÿÿ tÿÿ
eÿÿ aÿÿ
sÿÿ rÿÿ
eÿÿ tÿÿ
nÿÿ iÿÿ
tÿÿ nÿÿ
ÿÿ gÿÿ
ÿÿ app i2c_server
starting aÿÿ
sÿÿ pÿÿ
tÿÿ pÿÿ
aÿÿ ÿÿ
rÿÿ bÿÿ
tÿÿ pÿÿ
iÿÿ mÿÿ
nÿÿ pÿÿ
gÿÿ _iÿÿ
ÿÿ nÿÿ
aÿÿ cÿÿ
pÿÿ oÿÿ
p ÿÿ mÿÿ
gÿÿ iÿÿ
dÿÿ nÿÿ
bÿÿ gÿÿ
_ÿÿ
ÿÿ
aÿÿ
ÿÿ
gent
ÿÿ
ÿÿ
rver
D-S> ÿÿ Sever...
ÿÿVÿÿ
ÿÿC id 526
ÿÿpÿÿ
ÿÿ vÿÿRÿÿscÿÿeÿÿ
ÿÿserved IVC id 528
Reserved IVC id 529
Reserved IVC id 530
ÿÿ1
Reserved IVC id 532
Reserved IVC id 533
Reserved IVC id 534
Reserved IVC id 535
Reserved IVC id 536
Reserved IVC id 537
Reserved IVC id 538
Reserved IVC id 539
ÿÿaMMFLAGS=1
Starting RM server
Start nvpm server
Done...
ÿÿNÿÿ\00
ÿÿnÿÿ\00
ÿÿoÿÿ\00
GPRÿÿtÿÿ\00s:
ÿÿiÿÿ\00
ÿÿ\000000 ÿÿoÿÿ\00
x6: 0x000ÿÿfÿÿ
ÿÿ\001
ÿÿEÿÿ\00
ÿÿoÿÿ\000x2100bbÿÿ
ÿÿ\002c
0xÿÿ
ÿÿ\0021003ÿÿ
ÿÿnÿÿ\00514
0x210ÿÿpÿÿ\000155ÿÿ
ÿÿ\000ÿÿdÿÿ\00
0x21000184
Sÿÿpÿÿ\00iÿÿ
ÿÿ\00:
0x1766ÿÿ:ÿÿ\000
0x18350
0x12ÿÿ[ÿÿ\00070
ÿÿbÿÿbÿÿ
ÿÿ
ÿÿaÿÿ
ÿÿ
ÿÿbÿÿ
ÿÿ
ÿÿDÿÿ
ÿÿ1ÿÿ
ÿÿ
ÿÿSÿÿ
ÿÿ
ÿÿCÿÿ ÿÿCÿÿ
ÿÿ
ÿÿ ÿÿdÿÿ
ÿÿ
ÿÿCÿÿeÿÿ ÿÿ
ÿÿCÿÿ
ÿÿ
ÿÿ ÿÿ
ÿÿiÿÿ
ÿÿPÿÿ
ÿÿDÿÿ
ÿÿ:210035b0 >
\00
[/code]00x00000ÿÿcÿÿ[code]
\00ÿâ
\00ÿýÿàmain enter
HW Function test
Start Scheduler.
in late init
ÿâ
I> bit @ 0xd480000
I> Unpowergate done
I> Loading TOS ...
I> Loading EKS ...
I> Unhalting RCE
ÿâ
welcome to lk
dt initialized
mail initialized
chipid initialized
fuse initialized
sku initialized
speedo initialized
ec initialized
vmon initialized
adc initialized
fmon initialized
reset initialized
nvhs initialized
clk initialized
io_dpd initialized
thermal initialized
i2c initialized
aotag initialized
dvs initialized
pm initialized
pg_late initialized
strap initialized
tag initialized
emc initialized
clk_dt initialized
pm_post initialized
tj_init initialized
uphy_dt initialized
uphy initialized
mrq initialized
dmce initialized
cvc initialized
Starting OS
rm initialized
wake initialized
mail_fs initialized
profile initialized
ÿÿNvGpcDmaLibInitÿÿ
iÿÿ:ÿÿ
vÿÿHÿÿ
cÿÿyÿÿ
_ÿÿpÿÿ
qÿÿeÿÿ
uÿÿrÿÿ
eÿÿvÿÿ
uÿÿiÿÿ
eÿÿsÿÿ
ÿÿoÿÿ
nÿÿrÿÿ
oÿÿ ÿÿ
dÿÿMÿÿ
eÿÿoÿÿ
ÿÿdÿÿ
nÿÿeÿÿ
oÿÿ
ÿÿ
tÿÿ
ÿÿ
present
rÿÿ tÿÿ
eÿÿ aÿÿ
sÿÿ rÿÿ
eÿÿ tÿÿ
nÿÿ iÿÿ
tÿÿ nÿÿ
ÿÿ gÿÿ
ÿÿ app i2c_server
starting aÿÿ
sÿÿ pÿÿ
tÿÿ pÿÿ
aÿÿ ÿÿ
rÿÿ bÿÿ
tÿÿ pÿÿ
iÿÿ mÿÿ
nÿÿ pÿÿ
gÿÿ _iÿÿ
ÿÿ nÿÿ
aÿÿ cÿÿ
pÿÿ oÿÿ
p ÿÿ mÿÿ
gÿÿ iÿÿ
dÿÿ nÿÿ
bÿÿ gÿÿ
_ÿÿ
ÿÿ
aÿÿ
ÿÿ
gent
ÿÿ
ÿÿ
rver
D-S> ÿÿ Sever...
ÿÿVÿÿ
ÿÿC id 526
ÿÿpÿÿ
ÿÿ vÿÿRÿÿscÿÿeÿÿ
ÿÿserved IVC id 528
Reserved IVC id 529
Reserved IVC id 530
ÿÿ1
Reserved IVC id 532
Reserved IVC id 533
Reserved IVC id 534
Reserved IVC id 535
Reserved IVC id 536
Reserved IVC id 537
Reserved IVC id 538
Reserved IVC id 539
ÿÿaMMFLAGS=1
Starting RM server
Start nvpm server
Done...
ÿÿNÿÿ\00
ÿÿnÿÿ\00
ÿÿoÿÿ\00
GPRÿÿtÿÿ\00s:
ÿÿiÿÿ\00
ÿÿ\000000 ÿÿoÿÿ\00
x6: 0x000ÿÿfÿÿ
ÿÿ\001
ÿÿEÿÿ\00
ÿÿoÿÿ\000x2100bbÿÿ
ÿÿ\002c
0xÿÿ
ÿÿ\0021003ÿÿ
ÿÿnÿÿ\00514
0x210ÿÿpÿÿ\000155ÿÿ
ÿÿ\000ÿÿdÿÿ\00
0x21000184
Sÿÿpÿÿ\00iÿÿ
ÿÿ\00:
0x1766ÿÿ:ÿÿ\000
0x18350
0x12ÿÿ[ÿÿ\00070
ÿÿbÿÿbÿÿ
ÿÿ
ÿÿaÿÿ
ÿÿ
ÿÿbÿÿ
ÿÿ
ÿÿDÿÿ
ÿÿ1ÿÿ
ÿÿ
ÿÿSÿÿ
ÿÿ
ÿÿCÿÿ ÿÿCÿÿ
ÿÿ
ÿÿ ÿÿdÿÿ
ÿÿ
ÿÿCÿÿeÿÿ ÿÿ
ÿÿCÿÿ
ÿÿ
ÿÿ ÿÿ
ÿÿiÿÿ
ÿÿPÿÿ
ÿÿDÿÿ
ÿÿ:210035b0 >
\00
[/code]000ÿÿuÿÿ[code]
\00ÿâ
\00ÿýÿàmain enter
HW Function test
Start Scheduler.
in late init
ÿâ
I> bit @ 0xd480000
I> Unpowergate done
I> Loading TOS ...
I> Loading EKS ...
I> Unhalting RCE
ÿâ
welcome to lk
dt initialized
mail initialized
chipid initialized
fuse initialized
sku initialized
speedo initialized
ec initialized
vmon initialized
adc initialized
fmon initialized
reset initialized
nvhs initialized
clk initialized
io_dpd initialized
thermal initialized
i2c initialized
aotag initialized
dvs initialized
pm initialized
pg_late initialized
strap initialized
tag initialized
emc initialized
clk_dt initialized
pm_post initialized
tj_init initialized
uphy_dt initialized
uphy initialized
mrq initialized
dmce initialized
cvc initialized
Starting OS
rm initialized
wake initialized
mail_fs initialized
profile initialized
ÿÿNvGpcDmaLibInitÿÿ
iÿÿ:ÿÿ
vÿÿHÿÿ
cÿÿyÿÿ
_ÿÿpÿÿ
qÿÿeÿÿ
uÿÿrÿÿ
eÿÿvÿÿ
uÿÿiÿÿ
eÿÿsÿÿ
ÿÿoÿÿ
nÿÿrÿÿ
oÿÿ ÿÿ
dÿÿMÿÿ
eÿÿoÿÿ
ÿÿdÿÿ
nÿÿeÿÿ
oÿÿ
ÿÿ
tÿÿ
ÿÿ
present
rÿÿ tÿÿ
eÿÿ aÿÿ
sÿÿ rÿÿ
eÿÿ tÿÿ
nÿÿ iÿÿ
tÿÿ nÿÿ
ÿÿ gÿÿ
ÿÿ app i2c_server
starting aÿÿ
sÿÿ pÿÿ
tÿÿ pÿÿ
aÿÿ ÿÿ
rÿÿ bÿÿ
tÿÿ pÿÿ
iÿÿ mÿÿ
nÿÿ pÿÿ
gÿÿ _iÿÿ
ÿÿ nÿÿ
aÿÿ cÿÿ
pÿÿ oÿÿ
p ÿÿ mÿÿ
gÿÿ iÿÿ
dÿÿ nÿÿ
bÿÿ gÿÿ
_ÿÿ
ÿÿ
aÿÿ
ÿÿ
gent
ÿÿ
ÿÿ
rver
D-S> ÿÿ Sever...
ÿÿVÿÿ
ÿÿC id 526
ÿÿpÿÿ
ÿÿ vÿÿRÿÿscÿÿeÿÿ
ÿÿserved IVC id 528
Reserved IVC id 529
Reserved IVC id 530
ÿÿ1
Reserved IVC id 532
Reserved IVC id 533
Reserved IVC id 534
Reserved IVC id 535
Reserved IVC id 536
Reserved IVC id 537
Reserved IVC id 538
Reserved IVC id 539
ÿÿaMMFLAGS=1
Starting RM server
Start nvpm server
Done...
ÿÿNÿÿ\00
ÿÿnÿÿ\00
ÿÿoÿÿ\00
GPRÿÿtÿÿ\00s:
ÿÿiÿÿ\00
ÿÿ\000000 ÿÿoÿÿ\00
x6: 0x000ÿÿfÿÿ
ÿÿ\001
ÿÿEÿÿ\00
ÿÿoÿÿ\000x2100bbÿÿ
ÿÿ\002c
0xÿÿ
ÿÿ\0021003ÿÿ
ÿÿnÿÿ\00514
0x210ÿÿpÿÿ\000155ÿÿ
ÿÿ\000ÿÿdÿÿ\00
0x21000184
Sÿÿpÿÿ\00iÿÿ
ÿÿ\00:
0x1766ÿÿ:ÿÿ\000
0x18350
0x12ÿÿ[ÿÿ\00070
ÿÿbÿÿbÿÿ
ÿÿ
ÿÿaÿÿ
ÿÿ
ÿÿbÿÿ
ÿÿ
ÿÿDÿÿ
ÿÿ1ÿÿ
ÿÿ
ÿÿSÿÿ
ÿÿ
ÿÿCÿÿ ÿÿCÿÿ
ÿÿ
ÿÿ ÿÿdÿÿ
ÿÿ
ÿÿCÿÿeÿÿ ÿÿ
ÿÿCÿÿ
ÿÿ
ÿÿ ÿÿ
ÿÿiÿÿ
ÿÿPÿÿ
ÿÿDÿÿ
ÿÿ:210035b0 >
\00
[/code]000327ÿÿeÿÿ[code]
\00ÿâ
\00ÿýÿàmain enter
HW Function test
Start Scheduler.
in late init
ÿâ
I> bit @ 0xd480000
I> Unpowergate done
I> Loading TOS ...
I> Loading EKS ...
I> Unhalting RCE
ÿâ
welcome to lk
dt initialized
mail initialized
chipid initialized
fuse initialized
sku initialized
speedo initialized
ec initialized
vmon initialized
adc initialized
fmon initialized
reset initialized
nvhs initialized
clk initialized
io_dpd initialized
thermal initialized
i2c initialized
aotag initialized
dvs initialized
pm initialized
pg_late initialized
strap initialized
tag initialized
emc initialized
clk_dt initialized
pm_post initialized
tj_init initialized
uphy_dt initialized
uphy initialized
mrq initialized
dmce initialized
cvc initialized
Starting OS
rm initialized
wake initialized
mail_fs initialized
profile initialized
ÿÿNvGpcDmaLibInitÿÿ
iÿÿ:ÿÿ
vÿÿHÿÿ
cÿÿyÿÿ
_ÿÿpÿÿ
qÿÿeÿÿ
uÿÿrÿÿ
eÿÿvÿÿ
uÿÿiÿÿ
eÿÿsÿÿ
ÿÿoÿÿ
nÿÿrÿÿ
oÿÿ ÿÿ
dÿÿMÿÿ
eÿÿoÿÿ
ÿÿdÿÿ
nÿÿeÿÿ
oÿÿ
ÿÿ
tÿÿ
ÿÿ
present
rÿÿ tÿÿ
eÿÿ aÿÿ
sÿÿ rÿÿ
eÿÿ tÿÿ
nÿÿ iÿÿ
tÿÿ nÿÿ
ÿÿ gÿÿ
ÿÿ app i2c_server
starting aÿÿ
sÿÿ pÿÿ
tÿÿ pÿÿ
aÿÿ ÿÿ
rÿÿ bÿÿ
tÿÿ pÿÿ
iÿÿ mÿÿ
nÿÿ pÿÿ
gÿÿ _iÿÿ
ÿÿ nÿÿ
aÿÿ cÿÿ
pÿÿ oÿÿ
p ÿÿ mÿÿ
gÿÿ iÿÿ
dÿÿ nÿÿ
bÿÿ gÿÿ
_ÿÿ
ÿÿ
aÿÿ
ÿÿ
gent
ÿÿ
ÿÿ
rver
D-S> ÿÿ Sever...
ÿÿVÿÿ
ÿÿC id 526
ÿÿpÿÿ
ÿÿ vÿÿRÿÿscÿÿeÿÿ
ÿÿserved IVC id 528
Reserved IVC id 529
Reserved IVC id 530
ÿÿ1
Reserved IVC id 532
Reserved IVC id 533
Reserved IVC id 534
Reserved IVC id 535
Reserved IVC id 536
Reserved IVC id 537
Reserved IVC id 538
Reserved IVC id 539
ÿÿaMMFLAGS=1
Starting RM server
Start nvpm server
Done...
ÿÿNÿÿ\00
ÿÿnÿÿ\00
ÿÿoÿÿ\00
GPRÿÿtÿÿ\00s:
ÿÿiÿÿ\00
ÿÿ\000000 ÿÿoÿÿ\00
x6: 0x000ÿÿfÿÿ
ÿÿ\001
ÿÿEÿÿ\00
ÿÿoÿÿ\000x2100bbÿÿ
ÿÿ\002c
0xÿÿ
ÿÿ\0021003ÿÿ
ÿÿnÿÿ\00514
0x210ÿÿpÿÿ\000155ÿÿ
ÿÿ\000ÿÿdÿÿ\00
0x21000184
Sÿÿpÿÿ\00iÿÿ
ÿÿ\00:
0x1766ÿÿ:ÿÿ\000
0x18350
0x12ÿÿ[ÿÿ\00070
ÿÿbÿÿbÿÿ
ÿÿ
ÿÿaÿÿ
ÿÿ
ÿÿbÿÿ
ÿÿ
ÿÿDÿÿ
ÿÿ1ÿÿ
ÿÿ
ÿÿSÿÿ
ÿÿ
ÿÿCÿÿ ÿÿCÿÿ
ÿÿ
ÿÿ ÿÿdÿÿ
ÿÿ
ÿÿCÿÿeÿÿ ÿÿ
ÿÿCÿÿ
ÿÿ
ÿÿ ÿÿ
ÿÿiÿÿ
ÿÿPÿÿ
ÿÿDÿÿ
ÿÿ:210035b0 >
\00
[/code]00000 x4: 0xÿÿeÿÿ[code]
\00ÿâ
\00ÿýÿàmain enter
HW Function test
Start Scheduler.
in late init
ÿâ
I> bit @ 0xd480000
I> Unpowergate done
I> Loading TOS ...
I> Loading EKS ...
I> Unhalting RCE
ÿâ
welcome to lk
dt initialized
mail initialized
chipid initialized
fuse initialized
sku initialized
speedo initialized
ec initialized
vmon initialized
adc initialized
fmon initialized
reset initialized
nvhs initialized
clk initialized
io_dpd initialized
thermal initialized
i2c initialized
aotag initialized
dvs initialized
pm initialized
pg_late initialized
strap initialized
tag initialized
emc initialized
clk_dt initialized
pm_post initialized
tj_init initialized
uphy_dt initialized
uphy initialized
mrq initialized
dmce initialized
cvc initialized
Starting OS
rm initialized
wake initialized
mail_fs initialized
profile initialized
ÿÿNvGpcDmaLibInitÿÿ
iÿÿ:ÿÿ
vÿÿHÿÿ
cÿÿyÿÿ
_ÿÿpÿÿ
qÿÿeÿÿ
uÿÿrÿÿ
eÿÿvÿÿ
uÿÿiÿÿ
eÿÿsÿÿ
ÿÿoÿÿ
nÿÿrÿÿ
oÿÿ ÿÿ
dÿÿMÿÿ
eÿÿoÿÿ
ÿÿdÿÿ
nÿÿeÿÿ
oÿÿ
ÿÿ
tÿÿ
ÿÿ
present
rÿÿ tÿÿ
eÿÿ aÿÿ
sÿÿ rÿÿ
eÿÿ tÿÿ
nÿÿ iÿÿ
tÿÿ nÿÿ
ÿÿ gÿÿ
ÿÿ app i2c_server
starting aÿÿ
sÿÿ pÿÿ
tÿÿ pÿÿ
aÿÿ ÿÿ
rÿÿ bÿÿ
tÿÿ pÿÿ
iÿÿ mÿÿ
nÿÿ pÿÿ
gÿÿ _iÿÿ
ÿÿ nÿÿ
aÿÿ cÿÿ
pÿÿ oÿÿ
p ÿÿ mÿÿ
gÿÿ iÿÿ
dÿÿ nÿÿ
bÿÿ gÿÿ
_ÿÿ
ÿÿ
aÿÿ
ÿÿ
gent
ÿÿ
ÿÿ
rver
D-S> ÿÿ Sever...
ÿÿVÿÿ
ÿÿC id 526
ÿÿpÿÿ
ÿÿ vÿÿRÿÿscÿÿeÿÿ
ÿÿserved IVC id 528
Reserved IVC id 529
Reserved IVC id 530
ÿÿ1
Reserved IVC id 532
Reserved IVC id 533
Reserved IVC id 534
Reserved IVC id 535
Reserved IVC id 536
Reserved IVC id 537
Reserved IVC id 538
Reserved IVC id 539
ÿÿaMMFLAGS=1
Starting RM server
Start nvpm server
Done...
ÿÿNÿÿ\00
ÿÿnÿÿ\00
ÿÿoÿÿ\00
GPRÿÿtÿÿ\00s:
ÿÿiÿÿ\00
ÿÿ\000000 ÿÿoÿÿ\00
x6: 0x000ÿÿfÿÿ
ÿÿ\001
ÿÿEÿÿ\00
ÿÿoÿÿ\000x2100bbÿÿ
ÿÿ\002c
0xÿÿ
ÿÿ\0021003ÿÿ
ÿÿnÿÿ\00514
0x210ÿÿpÿÿ\000155ÿÿ
ÿÿ\000ÿÿdÿÿ\00
0x21000184
Sÿÿpÿÿ\00iÿÿ
ÿÿ\00:
0x1766ÿÿ:ÿÿ\000
0x18350
0x12ÿÿ[ÿÿ\00070
ÿÿbÿÿbÿÿ
ÿÿ
ÿÿaÿÿ
ÿÿ
ÿÿbÿÿ
ÿÿ
ÿÿDÿÿ
ÿÿ1ÿÿ
ÿÿ
ÿÿSÿÿ
ÿÿ
ÿÿCÿÿ ÿÿCÿÿ
ÿÿ
ÿÿ ÿÿdÿÿ
ÿÿ
ÿÿCÿÿeÿÿ ÿÿ
ÿÿCÿÿ
ÿÿ
ÿÿ ÿÿ
ÿÿiÿÿ
ÿÿPÿÿ
ÿÿDÿÿ
ÿÿ:210035b0 >
\00
[/code]00ÿÿnÿÿ[code]
\00ÿâ
\00ÿýÿàmain enter
HW Function test
Start Scheduler.
in late init
ÿâ
I> bit @ 0xd480000
I> Unpowergate done
I> Loading TOS ...
I> Loading EKS ...
I> Unhalting RCE
ÿâ
welcome to lk
dt initialized
mail initialized
chipid initialized
fuse initialized
sku initialized
speedo initialized
ec initialized
vmon initialized
adc initialized
fmon initialized
reset initialized
nvhs initialized
clk initialized
io_dpd initialized
thermal initialized
i2c initialized
aotag initialized
dvs initialized
pm initialized
pg_late initialized
strap initialized
tag initialized
emc initialized
clk_dt initialized
pm_post initialized
tj_init initialized
uphy_dt initialized
uphy initialized
mrq initialized
dmce initialized
cvc initialized
Starting OS
rm initialized
wake initialized
mail_fs initialized
profile initialized
ÿÿNvGpcDmaLibInitÿÿ
iÿÿ:ÿÿ
vÿÿHÿÿ
cÿÿyÿÿ
_ÿÿpÿÿ
qÿÿeÿÿ
uÿÿrÿÿ
eÿÿvÿÿ
uÿÿiÿÿ
eÿÿsÿÿ
ÿÿoÿÿ
nÿÿrÿÿ
oÿÿ ÿÿ
dÿÿMÿÿ
eÿÿoÿÿ
ÿÿdÿÿ
nÿÿeÿÿ
oÿÿ
ÿÿ
tÿÿ
ÿÿ
present
rÿÿ tÿÿ
eÿÿ aÿÿ
sÿÿ rÿÿ
eÿÿ tÿÿ
nÿÿ iÿÿ
tÿÿ nÿÿ
ÿÿ gÿÿ
ÿÿ app i2c_server
starting aÿÿ
sÿÿ pÿÿ
tÿÿ pÿÿ
aÿÿ ÿÿ
rÿÿ bÿÿ
tÿÿ pÿÿ
iÿÿ mÿÿ
nÿÿ pÿÿ
gÿÿ _iÿÿ
ÿÿ nÿÿ
aÿÿ cÿÿ
pÿÿ oÿÿ
p ÿÿ mÿÿ
gÿÿ iÿÿ
dÿÿ nÿÿ
bÿÿ gÿÿ
_ÿÿ
ÿÿ
aÿÿ
ÿÿ
gent
ÿÿ
ÿÿ
rver
D-S> ÿÿ Sever...
ÿÿVÿÿ
ÿÿC id 526
ÿÿpÿÿ
ÿÿ vÿÿRÿÿscÿÿeÿÿ
ÿÿserved IVC id 528
Reserved IVC id 529
Reserved IVC id 530
ÿÿ1
Reserved IVC id 532
Reserved IVC id 533
Reserved IVC id 534
Reserved IVC id 535
Reserved IVC id 536
Reserved IVC id 537
Reserved IVC id 538
Reserved IVC id 539
ÿÿaMMFLAGS=1
Starting RM server
Start nvpm server
Done...
ÿÿNÿÿ\00
ÿÿnÿÿ\00
ÿÿoÿÿ\00
GPRÿÿtÿÿ\00s:
ÿÿiÿÿ\00
ÿÿ\000000 ÿÿoÿÿ\00
x6: 0x000ÿÿfÿÿ
ÿÿ\001
ÿÿEÿÿ\00
ÿÿoÿÿ\000x2100bbÿÿ
ÿÿ\002c
0xÿÿ
ÿÿ\0021003ÿÿ
ÿÿnÿÿ\00514
0x210ÿÿpÿÿ\000155ÿÿ
ÿÿ\000ÿÿdÿÿ\00
0x21000184
Sÿÿpÿÿ\00iÿÿ
ÿÿ\00:
0x1766ÿÿ:ÿÿ\000
0x18350
0x12ÿÿ[ÿÿ\00070
ÿÿbÿÿbÿÿ
ÿÿ
ÿÿaÿÿ
ÿÿ
ÿÿbÿÿ
ÿÿ
ÿÿDÿÿ
ÿÿ1ÿÿ
ÿÿ
ÿÿSÿÿ
ÿÿ
ÿÿCÿÿ ÿÿCÿÿ
ÿÿ
ÿÿ ÿÿdÿÿ
ÿÿ
ÿÿCÿÿeÿÿ ÿÿ
ÿÿCÿÿ
ÿÿ
ÿÿ ÿÿ
ÿÿiÿÿ
ÿÿPÿÿ
ÿÿDÿÿ
ÿÿ:210035b0 >
\00
[/code]000000ÿÿ ÿÿ[code]
\00ÿâ
\00ÿýÿàmain enter
HW Function test
Start Scheduler.
in late init
ÿâ
I> bit @ 0xd480000
I> Unpowergate done
I> Loading TOS ...
I> Loading EKS ...
I> Unhalting RCE
ÿâ
welcome to lk
dt initialized
mail initialized
chipid initialized
fuse initialized
sku initialized
speedo initialized
ec initialized
vmon initialized
adc initialized
fmon initialized
reset initialized
nvhs initialized
clk initialized
io_dpd initialized
thermal initialized
i2c initialized
aotag initialized
dvs initialized
pm initialized
pg_late initialized
strap initialized
tag initialized
emc initialized
clk_dt initialized
pm_post initialized
tj_init initialized
uphy_dt initialized
uphy initialized
mrq initialized
dmce initialized
cvc initialized
Starting OS
rm initialized
wake initialized
mail_fs initialized
profile initialized
ÿÿNvGpcDmaLibInitÿÿ
iÿÿ:ÿÿ
vÿÿHÿÿ
cÿÿyÿÿ
_ÿÿpÿÿ
qÿÿeÿÿ
uÿÿrÿÿ
eÿÿvÿÿ
uÿÿiÿÿ
eÿÿsÿÿ
ÿÿoÿÿ
nÿÿrÿÿ
oÿÿ ÿÿ
dÿÿMÿÿ
eÿÿoÿÿ
ÿÿdÿÿ
nÿÿeÿÿ
oÿÿ
ÿÿ
tÿÿ
ÿÿ
present
rÿÿ tÿÿ
eÿÿ aÿÿ
sÿÿ rÿÿ
eÿÿ tÿÿ
nÿÿ iÿÿ
tÿÿ nÿÿ
ÿÿ gÿÿ
ÿÿ app i2c_server
starting aÿÿ
sÿÿ pÿÿ
tÿÿ pÿÿ
aÿÿ ÿÿ
rÿÿ bÿÿ
tÿÿ pÿÿ
iÿÿ mÿÿ
nÿÿ pÿÿ
gÿÿ _iÿÿ
ÿÿ nÿÿ
aÿÿ cÿÿ
pÿÿ oÿÿ
p ÿÿ mÿÿ
gÿÿ iÿÿ
dÿÿ nÿÿ
bÿÿ gÿÿ
_ÿÿ
ÿÿ
aÿÿ
ÿÿ
gent
ÿÿ
ÿÿ
rver
D-S> ÿÿ Sever...
ÿÿVÿÿ
ÿÿC id 526
ÿÿpÿÿ
ÿÿ vÿÿRÿÿscÿÿeÿÿ
ÿÿserved IVC id 528
Reserved IVC id 529
Reserved IVC id 530
ÿÿ1
Reserved IVC id 532
Reserved IVC id 533
Reserved IVC id 534
Reserved IVC id 535
Reserved IVC id 536
Reserved IVC id 537
Reserved IVC id 538
Reserved IVC id 539
ÿÿaMMFLAGS=1
Starting RM server
Start nvpm server
Done...
ÿÿNÿÿ\00
ÿÿnÿÿ\00
ÿÿoÿÿ\00
GPRÿÿtÿÿ\00s:
ÿÿiÿÿ\00
ÿÿ\000000 ÿÿoÿÿ\00
x6: 0x000ÿÿfÿÿ
ÿÿ\001
ÿÿEÿÿ\00
ÿÿoÿÿ\000x2100bbÿÿ
ÿÿ\002c
0xÿÿ
ÿÿ\0021003ÿÿ
ÿÿnÿÿ\00514
0x210ÿÿpÿÿ\000155ÿÿ
ÿÿ\000ÿÿdÿÿ\00
0x21000184
Sÿÿpÿÿ\00iÿÿ
ÿÿ\00:
0x1766ÿÿ:ÿÿ\000
0x18350
0x12ÿÿ[ÿÿ\00070
ÿÿbÿÿbÿÿ
ÿÿ
ÿÿaÿÿ
ÿÿ
ÿÿbÿÿ
ÿÿ
ÿÿDÿÿ
ÿÿ1ÿÿ
ÿÿ
ÿÿSÿÿ
ÿÿ
ÿÿCÿÿ ÿÿCÿÿ
ÿÿ
ÿÿ ÿÿdÿÿ
ÿÿ
ÿÿCÿÿeÿÿ ÿÿ
ÿÿCÿÿ
ÿÿ
ÿÿ ÿÿ
ÿÿiÿÿ
ÿÿPÿÿ
ÿÿDÿÿ
ÿÿ:210035b0 >
\00
[/code]00085e89e58 x5ÿÿIÿÿdÿÿ[code]
\00ÿâ
\00ÿýÿàmain enter
HW Function test
Start Scheduler.
in late init
ÿâ
I> bit @ 0xd480000
I> Unpowergate done
I> Loading TOS ...
I> Loading EKS ...
I> Unhalting RCE
ÿâ
welcome to lk
dt initialized
mail initialized
chipid initialized
fuse initialized
sku initialized
speedo initialized
ec initialized
vmon initialized
adc initialized
fmon initialized
reset initialized
nvhs initialized
clk initialized
io_dpd initialized
thermal initialized
i2c initialized
aotag initialized
dvs initialized
pm initialized
pg_late initialized
strap initialized
tag initialized
emc initialized
clk_dt initialized
pm_post initialized
tj_init initialized
uphy_dt initialized
uphy initialized
mrq initialized
dmce initialized
cvc initialized
Starting OS
rm initialized
wake initialized
mail_fs initialized
profile initialized
ÿÿNvGpcDmaLibInitÿÿ
iÿÿ:ÿÿ
vÿÿHÿÿ
cÿÿyÿÿ
_ÿÿpÿÿ
qÿÿeÿÿ
uÿÿrÿÿ
eÿÿvÿÿ
uÿÿiÿÿ
eÿÿsÿÿ
ÿÿoÿÿ
nÿÿrÿÿ
oÿÿ ÿÿ
dÿÿMÿÿ
eÿÿoÿÿ
ÿÿdÿÿ
nÿÿeÿÿ
oÿÿ
ÿÿ
tÿÿ
ÿÿ
present
rÿÿ tÿÿ
eÿÿ aÿÿ
sÿÿ rÿÿ
eÿÿ tÿÿ
nÿÿ iÿÿ
tÿÿ nÿÿ
ÿÿ gÿÿ
ÿÿ app i2c_server
starting aÿÿ
sÿÿ pÿÿ
tÿÿ pÿÿ
aÿÿ ÿÿ
rÿÿ bÿÿ
tÿÿ pÿÿ
iÿÿ mÿÿ
nÿÿ pÿÿ
gÿÿ _iÿÿ
ÿÿ nÿÿ
aÿÿ cÿÿ
pÿÿ oÿÿ
p ÿÿ mÿÿ
gÿÿ iÿÿ
dÿÿ nÿÿ
bÿÿ gÿÿ
_ÿÿ
ÿÿ
aÿÿ
ÿÿ
gent
ÿÿ
ÿÿ
rver
D-S> ÿÿ Sever...
ÿÿVÿÿ
ÿÿC id 526
ÿÿpÿÿ
ÿÿ vÿÿRÿÿscÿÿeÿÿ
ÿÿserved IVC id 528
Reserved IVC id 529
Reserved IVC id 530
ÿÿ1
Reserved IVC id 532
Reserved IVC id 533
Reserved IVC id 534
Reserved IVC id 535
Reserved IVC id 536
Reserved IVC id 537
Reserved IVC id 538
Reserved IVC id 539
ÿÿaMMFLAGS=1
Starting RM server
Start nvpm server
Done...
ÿÿNÿÿ\00
ÿÿnÿÿ\00
ÿÿoÿÿ\00
GPRÿÿtÿÿ\00s:
ÿÿiÿÿ\00
ÿÿ\000000 ÿÿoÿÿ\00
x6: 0x000ÿÿfÿÿ
ÿÿ\001
ÿÿEÿÿ\00
ÿÿoÿÿ\000x2100bbÿÿ
ÿÿ\002c
0xÿÿ
ÿÿ\0021003ÿÿ
ÿÿnÿÿ\00514
0x210ÿÿpÿÿ\000155ÿÿ
ÿÿ\000ÿÿdÿÿ\00
0x21000184
Sÿÿpÿÿ\00iÿÿ
ÿÿ\00:
0x1766ÿÿ:ÿÿ\000
0x18350
0x12ÿÿ[ÿÿ\00070
ÿÿbÿÿbÿÿ
ÿÿ
ÿÿaÿÿ
ÿÿ
ÿÿbÿÿ
ÿÿ
ÿÿDÿÿ
ÿÿ1ÿÿ
ÿÿ
ÿÿSÿÿ
ÿÿ
ÿÿCÿÿ ÿÿCÿÿ
ÿÿ
ÿÿ ÿÿdÿÿ
ÿÿ
ÿÿCÿÿeÿÿ ÿÿ
ÿÿCÿÿ
ÿÿ
ÿÿ ÿÿ
ÿÿiÿÿ
ÿÿPÿÿ
ÿÿDÿÿ
ÿÿ:210035b0 >
\00
[/code]0: 0x00ÿÿfÿÿ[code]
\00ÿâ
\00ÿýÿàmain enter
HW Function test
Start Scheduler.
in late init
ÿâ
I> bit @ 0xd480000
I> Unpowergate done
I> Loading TOS ...
I> Loading EKS ...
I> Unhalting RCE
ÿâ
welcome to lk
dt initialized
mail initialized
chipid initialized
fuse initialized
sku initialized
speedo initialized
ec initialized
vmon initialized
adc initialized
fmon initialized
reset initialized
nvhs initialized
clk initialized
io_dpd initialized
thermal initialized
i2c initialized
aotag initialized
dvs initialized
pm initialized
pg_late initialized
strap initialized
tag initialized
emc initialized
clk_dt initialized
pm_post initialized
tj_init initialized
uphy_dt initialized
uphy initialized
mrq initialized
dmce initialized
cvc initialized
Starting OS
rm initialized
wake initialized
mail_fs initialized
profile initialized
ÿÿNvGpcDmaLibInitÿÿ
iÿÿ:ÿÿ
vÿÿHÿÿ
cÿÿyÿÿ
_ÿÿpÿÿ
qÿÿeÿÿ
uÿÿrÿÿ
eÿÿvÿÿ
uÿÿiÿÿ
eÿÿsÿÿ
ÿÿoÿÿ
nÿÿrÿÿ
oÿÿ ÿÿ
dÿÿMÿÿ
eÿÿoÿÿ
ÿÿdÿÿ
nÿÿeÿÿ
oÿÿ
ÿÿ
tÿÿ
ÿÿ
present
rÿÿ tÿÿ
eÿÿ aÿÿ
sÿÿ rÿÿ
eÿÿ tÿÿ
nÿÿ iÿÿ
tÿÿ nÿÿ
ÿÿ gÿÿ
ÿÿ app i2c_server
starting aÿÿ
sÿÿ pÿÿ
tÿÿ pÿÿ
aÿÿ ÿÿ
rÿÿ bÿÿ
tÿÿ pÿÿ
iÿÿ mÿÿ
nÿÿ pÿÿ
gÿÿ _iÿÿ
ÿÿ nÿÿ
aÿÿ cÿÿ
pÿÿ oÿÿ
p ÿÿ mÿÿ
gÿÿ iÿÿ
dÿÿ nÿÿ
bÿÿ gÿÿ
_ÿÿ
ÿÿ
aÿÿ
ÿÿ
gent
ÿÿ
ÿÿ
rver
D-S> ÿÿ Sever...
ÿÿVÿÿ
ÿÿC id 526
ÿÿpÿÿ
ÿÿ vÿÿRÿÿscÿÿeÿÿ
ÿÿserved IVC id 528
Reserved IVC id 529
Reserved IVC id 530
ÿÿ1
Reserved IVC id 532
Reserved IVC id 533
Reserved IVC id 534
Reserved IVC id 535
Reserved IVC id 536
Reserved IVC id 537
Reserved IVC id 538
Reserved IVC id 539
ÿÿaMMFLAGS=1
Starting RM server
Start nvpm server
Done...
ÿÿNÿÿ\00
ÿÿnÿÿ\00
ÿÿoÿÿ\00
GPRÿÿtÿÿ\00s:
ÿÿiÿÿ\00
ÿÿ\000000 ÿÿoÿÿ\00
x6: 0x000ÿÿfÿÿ
ÿÿ\001
ÿÿEÿÿ\00
ÿÿoÿÿ\000x2100bbÿÿ
ÿÿ\002c
0xÿÿ
ÿÿ\0021003ÿÿ
ÿÿnÿÿ\00514
0x210ÿÿpÿÿ\000155ÿÿ
ÿÿ\000ÿÿdÿÿ\00
0x21000184
Sÿÿpÿÿ\00iÿÿ
ÿÿ\00:
0x1766ÿÿ:ÿÿ\000
0x18350
0x12ÿÿ[ÿÿ\00070
ÿÿbÿÿbÿÿ
ÿÿ
ÿÿaÿÿ
ÿÿ
ÿÿbÿÿ
ÿÿ
ÿÿDÿÿ
ÿÿ1ÿÿ
ÿÿ
ÿÿSÿÿ
ÿÿ
ÿÿCÿÿ ÿÿCÿÿ
ÿÿ
ÿÿ ÿÿdÿÿ
ÿÿ
ÿÿCÿÿeÿÿ ÿÿ
ÿÿCÿÿ
ÿÿ
ÿÿ ÿÿ
ÿÿiÿÿ
ÿÿPÿÿ
ÿÿDÿÿ
ÿÿ:210035b0 >
\00
[/code]0000000000ÿÿnÿÿ[code]
\00ÿâ
\00ÿýÿàmain enter
HW Function test
Start Scheduler.
in late init
ÿâ
I> bit @ 0xd480000
I> Unpowergate done
I> Loading TOS ...
I> Loading EKS ...
I> Unhalting RCE
ÿâ
welcome to lk
dt initialized
mail initialized
chipid initialized
fuse initialized
sku initialized
speedo initialized
ec initialized
vmon initialized
adc initialized
fmon initialized
reset initialized
nvhs initialized
clk initialized
io_dpd initialized
thermal initialized
i2c initialized
aotag initialized
dvs initialized
pm initialized
pg_late initialized
strap initialized
tag initialized
emc initialized
clk_dt initialized
pm_post initialized
tj_init initialized
uphy_dt initialized
uphy initialized
mrq initialized
dmce initialized
cvc initialized
Starting OS
rm initialized
wake initialized
mail_fs initialized
profile initialized
ÿÿNvGpcDmaLibInitÿÿ
iÿÿ:ÿÿ
vÿÿHÿÿ
cÿÿyÿÿ
_ÿÿpÿÿ
qÿÿeÿÿ
uÿÿrÿÿ
eÿÿvÿÿ
uÿÿiÿÿ
eÿÿsÿÿ
ÿÿoÿÿ
nÿÿrÿÿ
oÿÿ ÿÿ
dÿÿMÿÿ
eÿÿoÿÿ
ÿÿdÿÿ
nÿÿeÿÿ
oÿÿ
ÿÿ
tÿÿ
ÿÿ
present
rÿÿ tÿÿ
eÿÿ aÿÿ
sÿÿ rÿÿ
eÿÿ tÿÿ
nÿÿ iÿÿ
tÿÿ nÿÿ
ÿÿ gÿÿ
ÿÿ app i2c_server
starting aÿÿ
sÿÿ pÿÿ
tÿÿ pÿÿ
aÿÿ ÿÿ
rÿÿ bÿÿ
tÿÿ pÿÿ
iÿÿ mÿÿ
nÿÿ pÿÿ
gÿÿ _iÿÿ
ÿÿ nÿÿ
aÿÿ cÿÿ
pÿÿ oÿÿ
p ÿÿ mÿÿ
gÿÿ iÿÿ
dÿÿ nÿÿ
bÿÿ gÿÿ
_ÿÿ
ÿÿ
aÿÿ
ÿÿ
gent
ÿÿ
ÿÿ
rver
D-S> ÿÿ Sever...
ÿÿVÿÿ
ÿÿC id 526
ÿÿpÿÿ
ÿÿ vÿÿRÿÿscÿÿeÿÿ
ÿÿserved IVC id 528
Reserved IVC id 529
Reserved IVC id 530
ÿÿ1
Reserved IVC id 532
Reserved IVC id 533
Reserved IVC id 534
Reserved IVC id 535
Reserved IVC id 536
Reserved IVC id 537
Reserved IVC id 538
Reserved IVC id 539
ÿÿaMMFLAGS=1
Starting RM server
Start nvpm server
Done...
ÿÿNÿÿ\00
ÿÿnÿÿ\00
ÿÿoÿÿ\00
GPRÿÿtÿÿ\00s:
ÿÿiÿÿ\00
ÿÿ\000000 ÿÿoÿÿ\00
x6: 0x000ÿÿfÿÿ
ÿÿ\001
ÿÿEÿÿ\00
ÿÿoÿÿ\000x2100bbÿÿ
ÿÿ\002c
0xÿÿ
ÿÿ\0021003ÿÿ
ÿÿnÿÿ\00514
0x210ÿÿpÿÿ\000155ÿÿ
ÿÿ\000ÿÿdÿÿ\00
0x21000184
Sÿÿpÿÿ\00iÿÿ
ÿÿ\00:
0x1766ÿÿ:ÿÿ\000
0x18350
0x12ÿÿ[ÿÿ\00070
ÿÿbÿÿbÿÿ
ÿÿ
ÿÿaÿÿ
ÿÿ
ÿÿbÿÿ
ÿÿ
ÿÿDÿÿ
ÿÿ1ÿÿ
ÿÿ
ÿÿSÿÿ
ÿÿ
ÿÿCÿÿ ÿÿCÿÿ
ÿÿ
ÿÿ ÿÿdÿÿ
ÿÿ
ÿÿCÿÿeÿÿ ÿÿ
ÿÿCÿÿ
ÿÿ
ÿÿ ÿÿ
ÿÿiÿÿ
ÿÿPÿÿ
ÿÿDÿÿ
ÿÿ:210035b0 >
\00
[/code]00ÿÿ
ÿÿ[code]
\00ÿâ
\00ÿýÿàmain enter
HW Function test
Start Scheduler.
in late init
ÿâ
I> bit @ 0xd480000
I> Unpowergate done
I> Loading TOS ...
I> Loading EKS ...
I> Unhalting RCE
ÿâ
welcome to lk
dt initialized
mail initialized
chipid initialized
fuse initialized
sku initialized
speedo initialized
ec initialized
vmon initialized
adc initialized
fmon initialized
reset initialized
nvhs initialized
clk initialized
io_dpd initialized
thermal initialized
i2c initialized
aotag initialized
dvs initialized
pm initialized
pg_late initialized
strap initialized
tag initialized
emc initialized
clk_dt initialized
pm_post initialized
tj_init initialized
uphy_dt initialized
uphy initialized
mrq initialized
dmce initialized
cvc initialized
Starting OS
rm initialized
wake initialized
mail_fs initialized
profile initialized
ÿÿNvGpcDmaLibInitÿÿ
iÿÿ:ÿÿ
vÿÿHÿÿ
cÿÿyÿÿ
_ÿÿpÿÿ
qÿÿeÿÿ
uÿÿrÿÿ
eÿÿvÿÿ
uÿÿiÿÿ
eÿÿsÿÿ
ÿÿoÿÿ
nÿÿrÿÿ
oÿÿ ÿÿ
dÿÿMÿÿ
eÿÿoÿÿ
ÿÿdÿÿ
nÿÿeÿÿ
oÿÿ
ÿÿ
tÿÿ
ÿÿ
present
rÿÿ tÿÿ
eÿÿ aÿÿ
sÿÿ rÿÿ
eÿÿ tÿÿ
nÿÿ iÿÿ
tÿÿ nÿÿ
ÿÿ gÿÿ
ÿÿ app i2c_server
starting aÿÿ
sÿÿ pÿÿ
tÿÿ pÿÿ
aÿÿ ÿÿ
rÿÿ bÿÿ
tÿÿ pÿÿ
iÿÿ mÿÿ
nÿÿ pÿÿ
gÿÿ _iÿÿ
ÿÿ nÿÿ
aÿÿ cÿÿ
pÿÿ oÿÿ
p ÿÿ mÿÿ
gÿÿ iÿÿ
dÿÿ nÿÿ
bÿÿ gÿÿ
_ÿÿ
ÿÿ
aÿÿ
ÿÿ
gent
ÿÿ
ÿÿ
rver
D-S> ÿÿ Sever...
ÿÿVÿÿ
ÿÿC id 526
ÿÿpÿÿ
ÿÿ vÿÿRÿÿscÿÿeÿÿ
ÿÿserved IVC id 528
Reserved IVC id 529
Reserved IVC id 530
ÿÿ1
Reserved IVC id 532
Reserved IVC id 533
Reserved IVC id 534
Reserved IVC id 535
Reserved IVC id 536
Reserved IVC id 537
Reserved IVC id 538
Reserved IVC id 539
ÿÿaMMFLAGS=1
Starting RM server
Start nvpm server
Done...
ÿÿNÿÿ\00
ÿÿnÿÿ\00
ÿÿoÿÿ\00
GPRÿÿtÿÿ\00s:
ÿÿiÿÿ\00
ÿÿ\000000 ÿÿoÿÿ\00
x6: 0x000ÿÿfÿÿ
ÿÿ\001
ÿÿEÿÿ\00
ÿÿoÿÿ\000x2100bbÿÿ
ÿÿ\002c
0xÿÿ
ÿÿ\0021003ÿÿ
ÿÿnÿÿ\00514
0x210ÿÿpÿÿ\000155ÿÿ
ÿÿ\000ÿÿdÿÿ\00
0x21000184
Sÿÿpÿÿ\00iÿÿ
ÿÿ\00:
0x1766ÿÿ:ÿÿ\000
0x18350
0x12ÿÿ[ÿÿ\00070
ÿÿbÿÿbÿÿ
ÿÿ
ÿÿaÿÿ
ÿÿ
ÿÿbÿÿ
ÿÿ
ÿÿDÿÿ
ÿÿ1ÿÿ
ÿÿ
ÿÿSÿÿ
ÿÿ
ÿÿCÿÿ ÿÿCÿÿ
ÿÿ
ÿÿ ÿÿdÿÿ
ÿÿ
ÿÿCÿÿeÿÿ ÿÿ
ÿÿCÿÿ
ÿÿ
ÿÿ ÿÿ
ÿÿiÿÿ
ÿÿPÿÿ
ÿÿDÿÿ
ÿÿ:210035b0 >
\00
[/code]00000 ÿÿoÿÿ[code]
\00ÿâ
\00ÿýÿàmain enter
HW Function test
Start Scheduler.
in late init
ÿâ
I> bit @ 0xd480000
I> Unpowergate done
I> Loading TOS ...
I> Loading EKS ...
I> Unhalting RCE
ÿâ
welcome to lk
dt initialized
mail initialized
chipid initialized
fuse initialized
sku initialized
speedo initialized
ec initialized
vmon initialized
adc initialized
fmon initialized
reset initialized
nvhs initialized
clk initialized
io_dpd initialized
thermal initialized
i2c initialized
aotag initialized
dvs initialized
pm initialized
pg_late initialized
strap initialized
tag initialized
emc initialized
clk_dt initialized
pm_post initialized
tj_init initialized
uphy_dt initialized
uphy initialized
mrq initialized
dmce initialized
cvc initialized
Starting OS
rm initialized
wake initialized
mail_fs initialized
profile initialized
ÿÿNvGpcDmaLibInitÿÿ
iÿÿ:ÿÿ
vÿÿHÿÿ
cÿÿyÿÿ
_ÿÿpÿÿ
qÿÿeÿÿ
uÿÿrÿÿ
eÿÿvÿÿ
uÿÿiÿÿ
eÿÿsÿÿ
ÿÿoÿÿ
nÿÿrÿÿ
oÿÿ ÿÿ
dÿÿMÿÿ
eÿÿoÿÿ
ÿÿdÿÿ
nÿÿeÿÿ
oÿÿ
ÿÿ
tÿÿ
ÿÿ
present
rÿÿ tÿÿ
eÿÿ aÿÿ
sÿÿ rÿÿ
eÿÿ tÿÿ
nÿÿ iÿÿ
tÿÿ nÿÿ
ÿÿ gÿÿ
ÿÿ app i2c_server
starting aÿÿ
sÿÿ pÿÿ
tÿÿ pÿÿ
aÿÿ ÿÿ
rÿÿ bÿÿ
tÿÿ pÿÿ
iÿÿ mÿÿ
nÿÿ pÿÿ
gÿÿ _iÿÿ
ÿÿ nÿÿ
aÿÿ cÿÿ
pÿÿ oÿÿ
p ÿÿ mÿÿ
gÿÿ iÿÿ
dÿÿ nÿÿ
bÿÿ gÿÿ
_ÿÿ
ÿÿ
aÿÿ
ÿÿ
gent
ÿÿ
ÿÿ
rver
D-S> ÿÿ Sever...
ÿÿVÿÿ
ÿÿC id 526
ÿÿpÿÿ
ÿÿ vÿÿRÿÿscÿÿeÿÿ
ÿÿserved IVC id 528
Reserved IVC id 529
Reserved IVC id 530
ÿÿ1
Reserved IVC id 532
Reserved IVC id 533
Reserved IVC id 534
Reserved IVC id 535
Reserved IVC id 536
Reserved IVC id 537
Reserved IVC id 538
Reserved IVC id 539
ÿÿaMMFLAGS=1
Starting RM server
Start nvpm server
Done...
ÿÿNÿÿ\00
ÿÿnÿÿ\00
ÿÿoÿÿ\00
GPRÿÿtÿÿ\00s:
ÿÿiÿÿ\00
ÿÿ\000000 ÿÿoÿÿ\00
x6: 0x000ÿÿfÿÿ
ÿÿ\001
ÿÿEÿÿ\00
ÿÿoÿÿ\000x2100bbÿÿ
ÿÿ\002c
0xÿÿ
ÿÿ\0021003ÿÿ
ÿÿnÿÿ\00514
0x210ÿÿpÿÿ\000155ÿÿ
ÿÿ\000ÿÿdÿÿ\00
0x21000184
Sÿÿpÿÿ\00iÿÿ
ÿÿ\00:
0x1766ÿÿ:ÿÿ\000
0x18350
0x12ÿÿ[ÿÿ\00070
ÿÿbÿÿbÿÿ
ÿÿ
ÿÿaÿÿ
ÿÿ
ÿÿbÿÿ
ÿÿ
ÿÿDÿÿ
ÿÿ1ÿÿ
ÿÿ
ÿÿSÿÿ
ÿÿ
ÿÿCÿÿ ÿÿCÿÿ
ÿÿ
ÿÿ ÿÿdÿÿ
ÿÿ
ÿÿCÿÿeÿÿ ÿÿ
ÿÿCÿÿ
ÿÿ
ÿÿ ÿÿ
ÿÿiÿÿ
ÿÿPÿÿ
ÿÿDÿÿ
ÿÿ:210035b0 >
\00
[/code]0
x6: 0x000ÿÿfÿÿ
ÿÿ[code]
\00ÿâ
\00ÿýÿàmain enter
HW Function test
Start Scheduler.
in late init
ÿâ
I> bit @ 0xd480000
I> Unpowergate done
I> Loading TOS ...
I> Loading EKS ...
I> Unhalting RCE
ÿâ
welcome to lk
dt initialized
mail initialized
chipid initialized
fuse initialized
sku initialized
speedo initialized
ec initialized
vmon initialized
adc initialized
fmon initialized
reset initialized
nvhs initialized
clk initialized
io_dpd initialized
thermal initialized
i2c initialized
aotag initialized
dvs initialized
pm initialized
pg_late initialized
strap initialized
tag initialized
emc initialized
clk_dt initialized
pm_post initialized
tj_init initialized
uphy_dt initialized
uphy initialized
mrq initialized
dmce initialized
cvc initialized
Starting OS
rm initialized
wake initialized
mail_fs initialized
profile initialized
ÿÿNvGpcDmaLibInitÿÿ
iÿÿ:ÿÿ
vÿÿHÿÿ
cÿÿyÿÿ
_ÿÿpÿÿ
qÿÿeÿÿ
uÿÿrÿÿ
eÿÿvÿÿ
uÿÿiÿÿ
eÿÿsÿÿ
ÿÿoÿÿ
nÿÿrÿÿ
oÿÿ ÿÿ
dÿÿMÿÿ
eÿÿoÿÿ
ÿÿdÿÿ
nÿÿeÿÿ
oÿÿ
ÿÿ
tÿÿ
ÿÿ
present
rÿÿ tÿÿ
eÿÿ aÿÿ
sÿÿ rÿÿ
eÿÿ tÿÿ
nÿÿ iÿÿ
tÿÿ nÿÿ
ÿÿ gÿÿ
ÿÿ app i2c_server
starting aÿÿ
sÿÿ pÿÿ
tÿÿ pÿÿ
aÿÿ ÿÿ
rÿÿ bÿÿ
tÿÿ pÿÿ
iÿÿ mÿÿ
nÿÿ pÿÿ
gÿÿ _iÿÿ
ÿÿ nÿÿ
aÿÿ cÿÿ
pÿÿ oÿÿ
p ÿÿ mÿÿ
gÿÿ iÿÿ
dÿÿ nÿÿ
bÿÿ gÿÿ
_ÿÿ
ÿÿ
aÿÿ
ÿÿ
gent
ÿÿ
ÿÿ
rver
D-S> ÿÿ Sever...
ÿÿVÿÿ
ÿÿC id 526
ÿÿpÿÿ
ÿÿ vÿÿRÿÿscÿÿeÿÿ
ÿÿserved IVC id 528
Reserved IVC id 529
Reserved IVC id 530
ÿÿ1
Reserved IVC id 532
Reserved IVC id 533
Reserved IVC id 534
Reserved IVC id 535
Reserved IVC id 536
Reserved IVC id 537
Reserved IVC id 538
Reserved IVC id 539
ÿÿaMMFLAGS=1
Starting RM server
Start nvpm server
Done...
ÿÿNÿÿ\00
ÿÿnÿÿ\00
ÿÿoÿÿ\00
GPRÿÿtÿÿ\00s:
ÿÿiÿÿ\00
ÿÿ\000000 ÿÿoÿÿ\00
x6: 0x000ÿÿfÿÿ
ÿÿ\001
ÿÿEÿÿ\00
ÿÿoÿÿ\000x2100bbÿÿ
ÿÿ\002c
0xÿÿ
ÿÿ\0021003ÿÿ
ÿÿnÿÿ\00514
0x210ÿÿpÿÿ\000155ÿÿ
ÿÿ\000ÿÿdÿÿ\00
0x21000184
Sÿÿpÿÿ\00iÿÿ
ÿÿ\00:
0x1766ÿÿ:ÿÿ\000
0x18350
0x12ÿÿ[ÿÿ\00070
ÿÿbÿÿbÿÿ
ÿÿ
ÿÿaÿÿ
ÿÿ
ÿÿbÿÿ
ÿÿ
ÿÿDÿÿ
ÿÿ1ÿÿ
ÿÿ
ÿÿSÿÿ
ÿÿ
ÿÿCÿÿ ÿÿCÿÿ
ÿÿ
ÿÿ ÿÿdÿÿ
ÿÿ
ÿÿCÿÿeÿÿ ÿÿ
ÿÿCÿÿ
ÿÿ
ÿÿ ÿÿ
ÿÿiÿÿ
ÿÿPÿÿ
ÿÿDÿÿ
ÿÿ:210035b0 >
\00
[/code]0000ÿÿuÿÿ[code]
\00ÿâ
\00ÿýÿàmain enter
HW Function test
Start Scheduler.
in late init
ÿâ
I> bit @ 0xd480000
I> Unpowergate done
I> Loading TOS ...
I> Loading EKS ...
I> Unhalting RCE
ÿâ
welcome to lk
dt initialized
mail initialized
chipid initialized
fuse initialized
sku initialized
speedo initialized
ec initialized
vmon initialized
adc initialized
fmon initialized
reset initialized
nvhs initialized
clk initialized
io_dpd initialized
thermal initialized
i2c initialized
aotag initialized
dvs initialized
pm initialized
pg_late initialized
strap initialized
tag initialized
emc initialized
clk_dt initialized
pm_post initialized
tj_init initialized
uphy_dt initialized
uphy initialized
mrq initialized
dmce initialized
cvc initialized
Starting OS
rm initialized
wake initialized
mail_fs initialized
profile initialized
ÿÿNvGpcDmaLibInitÿÿ
iÿÿ:ÿÿ
vÿÿHÿÿ
cÿÿyÿÿ
_ÿÿpÿÿ
qÿÿeÿÿ
uÿÿrÿÿ
eÿÿvÿÿ
uÿÿiÿÿ
eÿÿsÿÿ
ÿÿoÿÿ
nÿÿrÿÿ
oÿÿ ÿÿ
dÿÿMÿÿ
eÿÿoÿÿ
ÿÿdÿÿ
nÿÿeÿÿ
oÿÿ
ÿÿ
tÿÿ
ÿÿ
present
rÿÿ tÿÿ
eÿÿ aÿÿ
sÿÿ rÿÿ
eÿÿ tÿÿ
nÿÿ iÿÿ
tÿÿ nÿÿ
ÿÿ gÿÿ
ÿÿ app i2c_server
starting aÿÿ
sÿÿ pÿÿ
tÿÿ pÿÿ
aÿÿ ÿÿ
rÿÿ bÿÿ
tÿÿ pÿÿ
iÿÿ mÿÿ
nÿÿ pÿÿ
gÿÿ _iÿÿ
ÿÿ nÿÿ
aÿÿ cÿÿ
pÿÿ oÿÿ
p ÿÿ mÿÿ
gÿÿ iÿÿ
dÿÿ nÿÿ
bÿÿ gÿÿ
_ÿÿ
ÿÿ
aÿÿ
ÿÿ
gent
ÿÿ
ÿÿ
rver
D-S> ÿÿ Sever...
ÿÿVÿÿ
ÿÿC id 526
ÿÿpÿÿ
ÿÿ vÿÿRÿÿscÿÿeÿÿ
ÿÿserved IVC id 528
Reserved IVC id 529
Reserved IVC id 530
ÿÿ1
Reserved IVC id 532
Reserved IVC id 533
Reserved IVC id 534
Reserved IVC id 535
Reserved IVC id 536
Reserved IVC id 537
Reserved IVC id 538
Reserved IVC id 539
ÿÿaMMFLAGS=1
Starting RM server
Start nvpm server
Done...
ÿÿNÿÿ\00
ÿÿnÿÿ\00
ÿÿoÿÿ\00
GPRÿÿtÿÿ\00s:
ÿÿiÿÿ\00
ÿÿ\000000 ÿÿoÿÿ\00
x6: 0x000ÿÿfÿÿ
ÿÿ\001
ÿÿEÿÿ\00
ÿÿoÿÿ\000x2100bbÿÿ
ÿÿ\002c
0xÿÿ
ÿÿ\0021003ÿÿ
ÿÿnÿÿ\00514
0x210ÿÿpÿÿ\000155ÿÿ
ÿÿ\000ÿÿdÿÿ\00
0x21000184
Sÿÿpÿÿ\00iÿÿ
ÿÿ\00:
0x1766ÿÿ:ÿÿ\000
0x18350
0x12ÿÿ[ÿÿ\00070
ÿÿbÿÿbÿÿ
ÿÿ
ÿÿaÿÿ
ÿÿ
ÿÿbÿÿ
ÿÿ
ÿÿDÿÿ
ÿÿ1ÿÿ
ÿÿ
ÿÿSÿÿ
ÿÿ
ÿÿCÿÿ ÿÿCÿÿ
ÿÿ
ÿÿ ÿÿdÿÿ
ÿÿ
ÿÿCÿÿeÿÿ ÿÿ
ÿÿCÿÿ
ÿÿ
ÿÿ ÿÿ
ÿÿiÿÿ
ÿÿPÿÿ
ÿÿDÿÿ
ÿÿ:210035b0 >
\00
[/code]00000000001 ÿÿoÿÿ[code]
\00ÿâ
\00ÿýÿàmain enter
HW Function test
Start Scheduler.
in late init
ÿâ
I> bit @ 0xd480000
I> Unpowergate done
I> Loading TOS ...
I> Loading EKS ...
I> Unhalting RCE
ÿâ
welcome to lk
dt initialized
mail initialized
chipid initialized
fuse initialized
sku initialized
speedo initialized
ec initialized
vmon initialized
adc initialized
fmon initialized
reset initialized
nvhs initialized
clk initialized
io_dpd initialized
thermal initialized
i2c initialized
aotag initialized
dvs initialized
pm initialized
pg_late initialized
strap initialized
tag initialized
emc initialized
clk_dt initialized
pm_post initialized
tj_init initialized
uphy_dt initialized
uphy initialized
mrq initialized
dmce initialized
cvc initialized
Starting OS
rm initialized
wake initialized
mail_fs initialized
profile initialized
ÿÿNvGpcDmaLibInitÿÿ
iÿÿ:ÿÿ
vÿÿHÿÿ
cÿÿyÿÿ
_ÿÿpÿÿ
qÿÿeÿÿ
uÿÿrÿÿ
eÿÿvÿÿ
uÿÿiÿÿ
eÿÿsÿÿ
ÿÿoÿÿ
nÿÿrÿÿ
oÿÿ ÿÿ
dÿÿMÿÿ
eÿÿoÿÿ
ÿÿdÿÿ
nÿÿeÿÿ
oÿÿ
ÿÿ
tÿÿ
ÿÿ
present
rÿÿ tÿÿ
eÿÿ aÿÿ
sÿÿ rÿÿ
eÿÿ tÿÿ
nÿÿ iÿÿ
tÿÿ nÿÿ
ÿÿ gÿÿ
ÿÿ app i2c_server
starting aÿÿ
sÿÿ pÿÿ
tÿÿ pÿÿ
aÿÿ ÿÿ
rÿÿ bÿÿ
tÿÿ pÿÿ
iÿÿ mÿÿ
nÿÿ pÿÿ
gÿÿ _iÿÿ
ÿÿ nÿÿ
aÿÿ cÿÿ
pÿÿ oÿÿ
p ÿÿ mÿÿ
gÿÿ iÿÿ
dÿÿ nÿÿ
bÿÿ gÿÿ
_ÿÿ
ÿÿ
aÿÿ
ÿÿ
gent
ÿÿ
ÿÿ
rver
D-S> ÿÿ Sever...
ÿÿVÿÿ
ÿÿC id 526
ÿÿpÿÿ
ÿÿ vÿÿRÿÿscÿÿeÿÿ
ÿÿserved IVC id 528
Reserved IVC id 529
Reserved IVC id 530
ÿÿ1
Reserved IVC id 532
Reserved IVC id 533
Reserved IVC id 534
Reserved IVC id 535
Reserved IVC id 536
Reserved IVC id 537
Reserved IVC id 538
Reserved IVC id 539
ÿÿaMMFLAGS=1
Starting RM server
Start nvpm server
Done...
ÿÿNÿÿ\00
ÿÿnÿÿ\00
ÿÿoÿÿ\00
GPRÿÿtÿÿ\00s:
ÿÿiÿÿ\00
ÿÿ\000000 ÿÿoÿÿ\00
x6: 0x000ÿÿfÿÿ
ÿÿ\001
ÿÿEÿÿ\00
ÿÿoÿÿ\000x2100bbÿÿ
ÿÿ\002c
0xÿÿ
ÿÿ\0021003ÿÿ
ÿÿnÿÿ\00514
0x210ÿÿpÿÿ\000155ÿÿ
ÿÿ\000ÿÿdÿÿ\00
0x21000184
Sÿÿpÿÿ\00iÿÿ
ÿÿ\00:
0x1766ÿÿ:ÿÿ\000
0x18350
0x12ÿÿ[ÿÿ\00070
ÿÿbÿÿbÿÿ
ÿÿ
ÿÿaÿÿ
ÿÿ
ÿÿbÿÿ
ÿÿ
ÿÿDÿÿ
ÿÿ1ÿÿ
ÿÿ
ÿÿSÿÿ
ÿÿ
ÿÿCÿÿ ÿÿCÿÿ
ÿÿ
ÿÿ ÿÿdÿÿ
ÿÿ
ÿÿCÿÿeÿÿ ÿÿ
ÿÿCÿÿ
ÿÿ
ÿÿ ÿÿ
ÿÿiÿÿ
ÿÿPÿÿ
ÿÿDÿÿ
ÿÿ:210035b0 >
\00
[/code]0x7:ÿÿpÿÿnÿÿ[code]
\00ÿâ
\00ÿýÿàmain enter
HW Function test
Start Scheduler.
in late init
ÿâ
I> bit @ 0xd480000
I> Unpowergate done
I> Loading TOS ...
I> Loading EKS ...
