I am trying to create a MANO hand USD file that I can import and use in Isaac Lab.
The reference URDF file I am using is from https://github.com/zdchan/GraspXL/blob/main/rsc/mano_double/rhand_mano_low_mass.urdf
I have modified the file by changing all links with zero mass to a mass of 0.001 and setting zero inertia to .
The joints of this urdf can be moved in isaacsim using physic interpreter
Also the joints of this same urdf file can be controlled in isaacgym.
However, when I use the USD converted from the same URDF, I am unable to move the joints using write_joint_state_to_sim to set their positions.
Any help would be greatly appreciated!
Thanks a lot!
