CameraMaster: master init failed with status = 10 with 4 lidars + PTP Time Grand Master
DRIVE OS Version: 6.0.10, Ubuntu
Setup: DRIVE AGX Orin, 6 cameras (GMSL, IMX728_RGGB), 4 lidars (Hesai AT128), PTP Time Grand Master (TGM, Orin Sync ./ptp4l -f automotive_slave.cfg -i mgbe2_0 -p /dev/ptp -m ). Camera rigs worked fine before.
Issue Description: Since connecting the lidars + TGM, camera init fails with:
CameraMaster: master init failed with status = 10 / sipl status 10 unexpected event
All 6 deserializers/sensors are detected correctly via I2C. Right after that, no frames/events ever arrive (ImageQueue timeout / Event notification queue timeout), then master init aborts with status 10 after ~3–4 s. All sensors run in external trigger mode (isTriggerMode: 1).
Error Messages:
[12-08-2026 01:07:58] Try allocate texture cache! filterMode: 1 readMode: 1 accessMode: 3 fromImage: 1
[12-08-2026 01:07:58] Cache count is: 186
[12-08-2026 01:07:58] GenericImage: generic image cuda
[12-08-2026 01:07:58] GenericImage: generic image cpu
[12-08-2026 01:07:58] ImageStreamer(NvMedia → CUDA)
[12-08-2026 01:07:58] Cache count is: 187
[12-08-2026 01:07:58] Cache count is: 188
[12-08-2026 01:07:58] Cache count is: 189
[12-08-2026 01:07:58] Cache count is: 190
[12-08-2026 01:07:58] Cache count is: 191
[12-08-2026 01:07:58] Cache count is: 192
[12-08-2026 01:07:58] CameraClient: using NITO found at /usr/share/camera/IMX728_RGGB.nito
[12-08-2026 01:07:58] Adding variable IMX728_RGGB:csi-ef:1:SerialNumber
[12-08-2026 01:07:58] Added variable IMX728_RGGB:csi-ef:1:SerialNumber
[12-08-2026 01:07:58] Adding variable IMX728_RGGB:csi-ef:1:HardwareVersion
[12-08-2026 01:07:58] Added variable IMX728_RGGB:csi-ef:1:HardwareVersion
[12-08-2026 01:07:58] Adding variable IMX728_RGGB:csi-ef:1:OemPartNumber
[12-08-2026 01:07:58] Added variable IMX728_RGGB:csi-ef:1:OemPartNumber
[12-08-2026 01:07:58] Adding variable IMX728_RGGB:csi-ef:1:TemperatureHistogram
[12-08-2026 01:07:58] Added variable IMX728_RGGB:csi-ef:1:TemperatureHistogram
onInitialize: creating camera.gmsl with params: camera-name=IMX728_RGGB,interface=csi-ef,CPHY-mode=1,link=2,format=h265,enable-ultrafast-mode=1,bitrate=4000000,output-format=processed,isp0-res=1920X1080,warn-per-frame=0,output-timestamp=host,fifo-size=4
[12-08-2026 01:07:58] SensorFactory::createSensor() → camera.gmsl, camera-name=IMX728_RGGB,interface=csi-ef,CPHY-mode=1,link=2,format=h265,enable-ultrafast-mode=1,bitrate=4000000,output-format=processed,isp0-res=1920X1080,warn-per-frame=0,output-timestamp=host,fifo-size=4
[12-08-2026 01:07:58] Found driver: camera.gmsl
[12-08-2026 01:07:58] CameraBase: pool size set to 16
[12-08-2026 01:07:58] devBlock: 1 Slave = 0 Interface = csi-ef Camera_name = IMX728_RGGB Link = 2 GroupInit = 0 RecCfg = 1
[12-08-2026 01:07:58] Camera Match Name: IMX728_RGGB Description: Sony IMX728 RGGB module - MIPI-IMX728, MAX96717 linkIndex: 4294967295 serInfo.Name: MAX96717F
[12-08-2026 01:07:58] Authentication is disabled for camera IMX728_RGGB
[12-08-2026 01:07:58] Not an EEPROM supported camera IMX728_RGGB
[12-08-2026 01:07:58] Client, Setting up information for camera ID 4
[12-08-2026 01:07:58] Client, successfully found info for camera ID 4 bound to id 4
[12-08-2026 01:07:58] Cache count is: 193
[12-08-2026 01:07:58] Cache count is: 194
[12-08-2026 01:07:58] Cache count is: 195
[12-08-2026 01:07:58] Cache count is: 196
[12-08-2026 01:07:58] Cache count is: 197
[12-08-2026 01:07:58] Cache count is: 198
[12-08-2026 01:07:58] Cache count is: 199
[12-08-2026 01:07:58] Cache count is: 200
[12-08-2026 01:07:58] Cache count is: 201
[12-08-2026 01:07:58] Cache count is: 202
[12-08-2026 01:07:58] Cache count is: 203
[12-08-2026 01:07:58] Cache count is: 204
[12-08-2026 01:07:58] Cache count is: 205
[12-08-2026 01:07:58] Cache count is: 206
[12-08-2026 01:07:58] Cache count is: 207
[12-08-2026 01:07:58] Cache count is: 208
[12-08-2026 01:07:58] Cache count is: 209
[12-08-2026 01:07:58] Cache count is: 210
[12-08-2026 01:07:58] Cache count is: 211
[12-08-2026 01:07:58] Cache count is: 212
[12-08-2026 01:07:58] Cache count is: 213
[12-08-2026 01:07:58] Cache count is: 214
[12-08-2026 01:07:58] Cache count is: 215
[12-08-2026 01:07:58] Cache count is: 216
[12-08-2026 01:07:58] Cache count is: 217
[12-08-2026 01:07:58] Cache count is: 218
[12-08-2026 01:07:58] Cache count is: 219
[12-08-2026 01:07:58] Cache count is: 220
[12-08-2026 01:07:58] Cache count is: 221
[12-08-2026 01:07:58] Cache count is: 222
[12-08-2026 01:07:58] Cache count is: 223
[12-08-2026 01:07:58] Cache count is: 224
[12-08-2026 01:07:58] Cache count is: 225
[12-08-2026 01:07:58] Cache count is: 226
[12-08-2026 01:07:58] Cache count is: 227
[12-08-2026 01:07:58] Cache count is: 228
[12-08-2026 01:07:58] Cache count is: 229
[12-08-2026 01:07:58] Cache count is: 230
[12-08-2026 01:07:58] Cache count is: 231
[12-08-2026 01:07:58] Cache count is: 232
[12-08-2026 01:07:58] Cache count is: 233
[12-08-2026 01:07:58] Cache count is: 234
[12-08-2026 01:07:58] Cache count is: 235
[12-08-2026 01:07:58] Cache count is: 236
[12-08-2026 01:07:58] Cache count is: 237
[12-08-2026 01:07:58] Cache count is: 238
[12-08-2026 01:07:58] Cache count is: 239
[12-08-2026 01:07:58] Cache count is: 240
[12-08-2026 01:07:58] Adding variable IMX728_RGGB:csi-ef:2:SerialNumber
[12-08-2026 01:07:58] Added variable IMX728_RGGB:csi-ef:2:SerialNumber
[12-08-2026 01:07:58] Adding variable IMX728_RGGB:csi-ef:2:HardwareVersion
[12-08-2026 01:07:58] Added variable IMX728_RGGB:csi-ef:2:HardwareVersion
[12-08-2026 01:07:58] Adding variable IMX728_RGGB:csi-ef:2:OemPartNumber
[12-08-2026 01:07:58] Added variable IMX728_RGGB:csi-ef:2:OemPartNumber
[12-08-2026 01:07:58] Adding variable IMX728_RGGB:csi-ef:2:TemperatureHistogram
[12-08-2026 01:07:58] Added variable IMX728_RGGB:csi-ef:2:TemperatureHistogram
onInitialize: creating camera.gmsl with params: camera-name=IMX728_RGGB,interface=csi-ef,CPHY-mode=1,link=3,format=h265,enable-ultrafast-mode=1,bitrate=4000000,output-format=processed,isp0-res=1920X1080,warn-per-frame=0,output-timestamp=host,fifo-size=4
[12-08-2026 01:07:58] SensorFactory::createSensor() → camera.gmsl, camera-name=IMX728_RGGB,interface=csi-ef,CPHY-mode=1,link=3,format=h265,enable-ultrafast-mode=1,bitrate=4000000,output-format=processed,isp0-res=1920X1080,warn-per-frame=0,output-timestamp=host,fifo-size=4
[12-08-2026 01:07:58] devBlock: 1 Slave = 0 Interface = csi-ef Camera_name = IMX728_RGGB Link = 3 GroupInit = 0 RecCfg = 1
[12-08-2026 01:07:58] Client, Setting up information for camera ID 5
[12-08-2026 01:07:58] Client, successfully found info for camera ID 5 bound to id 5
[12-08-2026 01:07:58] Cache count is: 241
[12-08-2026 01:07:58] Cache count is: 242
[12-08-2026 01:07:58] Cache count is: 243
[12-08-2026 01:07:58] Cache count is: 244
[12-08-2026 01:07:58] Cache count is: 245
[12-08-2026 01:07:58] Cache count is: 246
[12-08-2026 01:07:58] Cache count is: 247
[12-08-2026 01:07:58] Cache count is: 248
[12-08-2026 01:07:58] Cache count is: 249
[12-08-2026 01:07:58] Cache count is: 250
[12-08-2026 01:07:58] Cache count is: 251
[12-08-2026 01:07:58] Cache count is: 252
[12-08-2026 01:07:58] Cache count is: 253
[12-08-2026 01:07:58] Cache count is: 254
[12-08-2026 01:07:58] Cache count is: 255
[12-08-2026 01:07:58] Cache count is: 256
[12-08-2026 01:07:58] Cache count is: 257
[12-08-2026 01:07:58] Cache count is: 258
[12-08-2026 01:07:58] Cache count is: 259
[12-08-2026 01:07:58] Cache count is: 260
[12-08-2026 01:07:58] Cache count is: 261
[12-08-2026 01:07:58] Cache count is: 262
[12-08-2026 01:07:58] Cache count is: 263
[12-08-2026 01:07:58] Cache count is: 264
[12-08-2026 01:07:58] Cache count is: 265
[12-08-2026 01:07:58] Cache count is: 266
[12-08-2026 01:07:58] Cache count is: 267
[12-08-2026 01:07:58] Cache count is: 268
[12-08-2026 01:07:58] Cache count is: 269
[12-08-2026 01:07:58] Cache count is: 270
[12-08-2026 01:07:58] Cache count is: 271
[12-08-2026 01:07:58] Cache count is: 272
[12-08-2026 01:07:58] Cache count is: 273
[12-08-2026 01:07:58] Cache count is: 274
[12-08-2026 01:07:58] Cache count is: 275
[12-08-2026 01:07:58] Cache count is: 276
[12-08-2026 01:07:58] Cache count is: 277
[12-08-2026 01:07:58] Cache count is: 278
[12-08-2026 01:07:58] Cache count is: 279
[12-08-2026 01:07:58] Cache count is: 280
[12-08-2026 01:07:58] Cache count is: 281
[12-08-2026 01:07:58] Cache count is: 282
[12-08-2026 01:07:58] Cache count is: 283
[12-08-2026 01:07:58] Cache count is: 284
[12-08-2026 01:07:58] Cache count is: 285
[12-08-2026 01:07:58] Cache count is: 286
[12-08-2026 01:07:58] Cache count is: 287
[12-08-2026 01:07:58] Cache count is: 288
[12-08-2026 01:07:58] Adding variable IMX728_RGGB:csi-ef:3:SerialNumber
[12-08-2026 01:07:58] Added variable IMX728_RGGB:csi-ef:3:SerialNumber
[12-08-2026 01:07:58] Adding variable IMX728_RGGB:csi-ef:3:HardwareVersion
[12-08-2026 01:07:58] Added variable IMX728_RGGB:csi-ef:3:HardwareVersion
[12-08-2026 01:07:58] Adding variable IMX728_RGGB:csi-ef:3:OemPartNumber
[12-08-2026 01:07:58] Added variable IMX728_RGGB:csi-ef:3:OemPartNumber
[12-08-2026 01:07:58] Adding variable IMX728_RGGB:csi-ef:3:TemperatureHistogram
[12-08-2026 01:07:58] Added variable IMX728_RGGB:csi-ef:3:TemperatureHistogram
[12-08-2026 01:07:58] SIPLMaster::SIPLMaster: Setting up master camera
[12-08-2026 01:07:58] Platform:
[12-08-2026 01:07:58] Platform Config:
[12-08-2026 01:07:58] Description:
[12-08-2026 01:07:58] Number of device blocks: 2
[12-08-2026 01:07:58] Device Block : 0
[12-08-2026 01:07:58] csiPort: 0
[12-08-2026 01:07:58] i2cDevice: 0
[12-08-2026 01:07:58] cphyRate_0: 2000000
[12-08-2026 01:07:58] cphyRate_1: 2000000
[12-08-2026 01:07:58] Deserializer Name: MAX96712_camRecCfg_V1
[12-08-2026 01:07:58] Deserializer Description: Maxim 96712 Aggregator
[12-08-2026 01:07:58] Deserializer i2cAddress: 41
[12-08-2026 01:07:58] Passive Mode: 0
[12-08-2026 01:07:58] Phy Mode: 1
[12-08-2026 01:07:58] Number of camera modules: 2
[12-08-2026 01:07:58] CameraModule index: 1
[12-08-2026 01:07:58] Name :IMX728_RGGB
[12-08-2026 01:07:58] Description: Sony IMX728 RGGB module - MIPI-IMX728, MAX96717
[12-08-2026 01:07:58] Serializer name: MAX96717F
[12-08-2026 01:07:58] Serializer description: Maxim 96717F Serializer
[12-08-2026 01:07:58] Serializer i2cAdress: 66
[12-08-2026 01:07:58] EEPROM name: M24C64
[12-08-2026 01:07:58] EEPROM i2cAddress: 84
[12-08-2026 01:07:58] EEPROM description: M24C64 64-Kbit serial I2C EEPROM
[12-08-2026 01:07:58] Sensor ID: 0
[12-08-2026 01:07:58] Sensor name: IMX728
[12-08-2026 01:07:58] Sensor description: Sony IMX728 Sensor
[12-08-2026 01:07:58] Sensor isTPGEnabled: 0
[12-08-2026 01:07:58] Sensor i2cAddress: 26
[12-08-2026 01:07:58] Sensor isTriggerMode: 1
[12-08-2026 01:07:58] cfa: 33
[12-08-2026 01:07:58] embeddedTopLines: 1
[12-08-2026 01:07:58] embeddedBottomLines: 20
[12-08-2026 01:07:58] inputFormat: 8
[12-08-2026 01:07:58] height: 2160
[12-08-2026 01:07:58] width: 3840
[12-08-2026 01:07:58] fps: 30.000000
[12-08-2026 01:07:58] Embedded Data: 0
[12-08-2026 01:07:58] CameraModule index: 0
[12-08-2026 01:07:58] Sensor ID: 1
[12-08-2026 01:07:58] Device Block : 1
[12-08-2026 01:07:58] csiPort: 8
[12-08-2026 01:07:58] i2cDevice: 2
[12-08-2026 01:07:58] Number of camera modules: 4
[12-08-2026 01:07:58] Sensor ID: 2
[12-08-2026 01:07:58] Sensor ID: 3
[12-08-2026 01:07:58] CameraModule index: 2
[12-08-2026 01:07:58] Sensor ID: 4
[12-08-2026 01:07:58] CameraModule index: 3
[12-08-2026 01:07:58] Sensor ID: 5
[12-08-2026 01:07:58] CameraMaster available outputs: 1
[12-08-2026 01:07:58] CameraClient: setting pipeline config for camera ID 0
[12-08-2026 01:07:58] CameraClient, SIPLNotifier created
[12-08-2026 01:07:58] CameraClient: setting pipeline config for camera ID 1
[12-08-2026 01:07:58] CameraClient: setting pipeline config for camera ID 2
[12-08-2026 01:07:58] CameraClient: setting pipeline config for camera ID 3
[12-08-2026 01:07:58] CameraClient: setting pipeline config for camera ID 4
[12-08-2026 01:07:58] CameraClient: setting pipeline config for camera ID 5
[12-08-2026 01:07:58] CameraMaster: master initiation
[12-08-2026 01:07:58] CameraMaster: Bootstrap NvSIPL and ClientPipelines complete
[12-08-2026 01:07:58] Initialize DriveWorks VisualizationSDK v5.20.24
[12-08-2026 01:07:58] Initialize DriveWorksGL SDK v5.20.24
[12-08-2026 01:07:58] egl::Display: found 1 EGL devices
[12-08-2026 01:07:58] egl::Display: use drm device: /dev/dri/card0
onInitialize: Total cameras 6
onInitialize: getting image props 0
onInitialize: initilizing stream: 0
onInitialize: getting image props 1
onInitialize: initilizing stream: 1
onInitialize: getting image props 2
onInitialize: initilizing stream: 2
onInitialize: getting image props 3
onInitialize: initilizing stream: 3
onInitialize: getting image props 4
onInitialize: initilizing stream: 4
onInitialize: getting image props 5
onInitialize: initilizing stream: 5
Main: Starting master.
[12-08-2026 01:07:59] CameraClient: startImpl: thread id: 4697
[12-08-2026 01:07:59] CameraClient: initializeAndStartCameras: thread id: 4697
MAX96712: Revision 5 detected
MAX96712 Link 0: PHY optimization was enabled
MAX96712 Link 1: PHY optimization was enabled
MAX96712 Link 2: PHY optimization was enabled
MAX96712 Link 3: PHY optimization was enabled
MAX96717: Revision 4 detected!
Sensor IMX728 Rev 51 RGGB detected!
[12-08-2026 01:07:59] SIPLClient: ImageQueue timeout
[12-08-2026 01:07:59] SIPLNotifier: Event notification queue timeout
[12-08-2026 01:07:59] eventQueuePollCustomInterface: Custom interface is not available. This is expected if bootstrap is not complete
[12-08-2026 01:08:00] SIPLNotifier: Event notification queue timeout
[12-08-2026 01:08:00] SIPLClient: ImageQueue timeout
[12-08-2026 01:08:01] SIPLNotifier: Event notification queue timeout
[12-08-2026 01:08:01] SIPLClient: ImageQueue timeout
[12-08-2026 01:08:02] SIPLNotifier: Event notification queue timeout
[12-08-2026 01:08:02] SIPLClient: ImageQueue timeout
[12-08-2026 01:08:02] CameraMaster: master init failed with status = 10
[12-08-2026 01:08:02] Driveworks exception thrown: DW_UNEXPECTED_EVENT: CameraMaster::resume failed with sipl status 10
terminate called after throwing an instance of ‘std::runtime_error’
what(): [2026-08-12 01:08:02] DW Error DW_UNEXPECTED_EVENT executing DW function:
dwSensor_start(m_camera[i])
at /usr/local/driveworks/samples/src/sensors/camera/camera/main.cpp:911
Rig File
“rig”: {
“sensors”: [
“name”: “camera:front:left:60fov”,
“nominalSensor2Rig_FLU”: {
“roll-pitch-yaw”: [
0.0,
-0.0,
0.0
“t”: [
0.0,
0.0,
0.0
“parameter”: “camera-name=IMX728_RGGB,interface=csi-a,CPHY-mode=1,link=1,format=h265,enable-ultrafast-mode=1,bitrate=4000000,output-format=processed,isp0-res=1920X1080,warn-per-frame=0,output-timestamp=host,fifo-size=4”,
“properties”: {
“Model”: “ftheta”,
“bw-poly”: “0.0 0.000545421498827636 -1.6216719633103e-10 -4.64720492990289e-12 2.85224527762934e-16”,
“cx”: “960”,
“cy”: “540”,
“height”: “1080”,
“width”: “1920”
“protocol”: “camera.gmsl”
“name”: “camera:front:right:60fov”,
“roll-pitch-yaw”: [
0.0,
-0.0,
0.0
“t”: [
0.0,
0.0,
0.0
“parameter”: “camera-name=IMX728_RGGB,interface=csi-a,CPHY-mode=1,link=0,format=h265,enable-ultrafast-mode=1,bitrate=4000000,output-format=processed,isp0-res=1920X1080,warn-per-frame=0,output-timestamp=host,fifo-size=4”,
“properties”: {
“Model”: “ftheta”,
“cx”: “960”,
“cy”: “540”,
“height”: “1080”,
“width”: “1920”
“name”: “camera:front:left:120fov”,
“roll-pitch-yaw”: [
0.0,
-0.0,
0.0
“t”: [
0.0,
0.0,
0.0
“parameter”: “camera-name=IMX728_RGGB,interface=csi-ef,CPHY-mode=1,link=0,format=h265,enable-ultrafast-mode=1,bitrate=4000000,output-format=processed,isp0-res=1920X1080,warn-per-frame=0,output-timestamp=host,fifo-size=4”,
“properties”: {
“Model”: “ftheta”,
“cx”: “960”,
“cy”: “540”,
“height”: “1080”,
“width”: “1920”
“name”: “camera:front:right:120fov”,
“roll-pitch-yaw”: [
0.0,
-0.0,
0.0
“t”: [
0.0,
0.0,
0.0
“parameter”: “camera-name=IMX728_RGGB,interface=csi-ef,CPHY-mode=1,link=1,format=h265,enable-ultrafast-mode=1,bitrate=4000000,output-format=processed,isp0-res=1920X1080,warn-per-frame=0,output-timestamp=host,fifo-size=4”,
“properties”: {
“Model”: “ftheta”,
“cx”: “960”,
“cy”: “540”,
“height”: “1080”,
“width”: “1920”
“name”: “camera:rear:left:120fov”,
“roll-pitch-yaw”: [
0.0,
-0.0,
0.0
“t”: [
0.0,
0.0,
0.0
“parameter”: “camera-name=IMX728_RGGB,interface=csi-ef,CPHY-mode=1,link=2,format=h265,enable-ultrafast-mode=1,bitrate=4000000,output-format=processed,isp0-res=1920X1080,warn-per-frame=0,output-timestamp=host,fifo-size=4”,
“properties”: {
“Model”: “ftheta”,
“cx”: “960”,
“cy”: “540”,
“height”: “1080”,
“width”: “1920”
“name”: “camera:rear:right:120fov”,
“roll-pitch-yaw”: [
0.0,
-0.0,
0.0
“t”: [
0.0,
0.0,
0.0
“parameter”: “camera-name=IMX728_RGGB,interface=csi-ef,CPHY-mode=1,link=3,format=h265,enable-ultrafast-mode=1,bitrate=4000000,output-format=processed,isp0-res=1920X1080,warn-per-frame=0,output-timestamp=host,fifo-size=4”,
“properties”: {
“Model”: “ftheta”,
“cx”: “960”,
“cy”: “540”,
“height”: “1080”,
“width”: “1920”
“vehicle”: {
“valid”: false,
“value”: {
“aeroHeight”: 1.5,
“aerodynamicDragCoeff”: 0.699999988079071,
“axlebaseFront”: 1.5820000171661377,
“axlebaseRear”: 1.5750000476837158,
“brakeActuatorTimeConstant”: 0.5,
“bumperFront”: 0.9120000004768372,
“bumperRear”: 1.1089999675750732,
“centerOfMassHeight”: 0.550000011920929,
“centerOfMassToFrontAxle”: 1.2860000133514404,
“centerOfMassToRearAxle”: 1.5640000104904175,
“driveByWireTimeConstant”: 0.25999999046325684,
“driveByWireTimeDelay”: 0.10999999940395355,
“effectiveMass”: 0,
“frontCorneringStiffness”: 30654,
“frontSteeringOffset”: 0,
“frontalArea”: 1,
“height”: 1.4730000495910645,
“inertia3D”: [
750,
3200,
3500
“length”: 4.872000217437744,
“mass”: 1779.4000244140625,
“maxEnginePower”: 134000,
“maxSteeringWheelAngle”: 8.290313720703125,
“rearCorneringStiffness”: 36407,
“rollingResistanceCoeff”: 0.014999999664723873,
“steeringWheelToSteeringMap”: [
0,
0.06764844059944153,
-0.00002211817081843037,
0.0001220461999764666,
6.98658084274939e-7,
0.0000010106930403708247
“throttleActuatorTimeConstant”: 1,
“torqueLUT”: {
“brakePedalInput”: “0.000, 0.07, 0.14, 0.21, 0.29, 0.36, 0.43, 0.50, 0.57, 0.64, 0.71, 0.79, 0.86, 0.93, 1.000”,
“brakeTorqueOutput”: “0.000, 236.05, 470.44, 708.48, 944.52, 1180.57, 1416.95, 1653.000, 1889.05, 2125.43, 2361.48, 2597.52, 2833.57, 3069.95, 3306.000”,
“throttlePedalInput”: “0.000, 0.07, 0.14, 0.21, 0.29, 0.36, 0.43, 0.50, 0.57, 0.64, 0.71, 0.79, 0.86, 0.93, 1.000”,
“throttleSpeedInput”: “0.000, 2.000, 4.000, 6.000, 8.000, 10.000, 12.000, 14.000, 16.000, 18.000, 20.000, 22.000, 24.000, 26.000, 28.000”,
“throttleTorqueOutput”: [
“0.000, 0.000, 0.000, 0.000, 0.000, 0.000, 0.000, 0.000, 0.000, 0.000, 0.000, 0.000, 0.000, 0.000, 0.000”,
“103.15, 103.15, 103.15, 103.15, 103.15, 103.15, 103.15, 103.15, 103.15, 103.15, 103.15, 103.15, 103.15, 103.15, 103.15”,
“205.96, 205.96, 205.96, 205.96, 205.96, 205.96, 205.96, 205.96, 205.96, 205.96, 205.96, 205.96, 205.96, 205.96, 205.96”,
“359.03, 359.03, 359.03, 359.03, 359.03, 359.03, 359.03, 359.03, 359.03, 359.03, 359.03, 359.03, 359.03, 359.03, 359.03”,
“874.77, 874.77, 874.77, 874.77, 874.77, 874.77, 874.77, 874.77, 874.77, 874.77, 874.77, 874.77, 874.77, 874.77, 874.77”,
“1412.32, 1412.32, 1412.32, 1412.32, 1412.32, 1412.32, 1412.32, 1412.32, 1412.32, 1412.32, 1412.32, 1412.32, 1412.32, 1412.32, 1412.32”,
“1775.32, 1775.32, 1775.32, 1775.32, 1775.32, 1775.32, 1775.32, 1775.32, 1775.32, 1775.32, 1775.32, 1775.32, 1775.32, 1775.32, 1775.32”,
“2000.79, 2000.79, 2000.79, 2000.79, 2000.79, 2000.79, 2000.79, 2000.79, 2000.79, 2000.79, 2000.79, 2000.79, 2000.79, 2000.79, 2000.79”,
“2103.61, 2103.61, 2103.61, 2103.61, 2103.61, 2103.61, 2103.61, 2103.61, 2103.61, 2103.61, 2103.61, 2103.61, 2103.61, 2103.61, 2103.61”,
“2167.41, 2167.41, 2167.41, 2167.41, 2167.41, 2167.41, 2167.41, 2167.41, 2167.41, 2167.41, 2167.41, 2167.41, 2167.41, 2167.41, 2167.41”,
“2224.94, 2224.94, 2224.94, 2224.94, 2224.94, 2224.94, 2224.94, 2224.94, 2224.94, 2224.94, 2224.94, 2224.94, 2224.94, 2224.94, 2224.94”,
“2282.79, 2282.79, 2282.79, 2282.79, 2282.79, 2282.79, 2282.79, 2282.79, 2282.79, 2282.79, 2282.79, 2282.79, 2282.79, 2282.79, 2282.79”,
“2344.62, 2344.62, 2344.62, 2344.62, 2344.62, 2344.62, 2344.62, 2344.62, 2344.62, 2344.62, 2344.62, 2344.62, 2344.62, 2344.62, 2344.62”,
“2407.76, 2407.76, 2407.76, 2407.76, 2407.76, 2407.76, 2407.76, 2407.76, 2407.76, 2407.76, 2407.76, 2407.76, 2407.76, 2407.76, 2407.76”,
“2470.57, 2470.57, 2470.57, 2470.57, 2470.57, 2470.57, 2470.57, 2470.57, 2470.57, 2470.57, 2470.57, 2470.57, 2470.57, 2470.57, 2470.57”
“wheelRadius”: [
0.33059999346733093,
0.33059999346733093
“wheelbase”: 2.8499999046325684,
“width”: 1.8519999980926514,
“widthWithMirrors”: 2.121000051498413
“vehicleio”:
“version”: 7
Custom nvpps info, based on own diagnose:
== NVPPS_GETVERSION ==
driver version : 0.2
api version : 0.4
== NVPPS_GETPARAMS ==
evt_mode = 0x02 → TIMER (interner SW-Timer)
tsc_mode = 0x00 → NSEC (Nanosekunden)
== NVPPS_GETEVENT Polling (Ctrl-C zum Beenden, Stats am Ende) ==
[ 0] evt_nb=3731 tsc=3825771317440 ptp=1788257972056840539 secondary_ptp=0
evt_mode=TIMER (interner SW-Timer) tsc_mode=NSEC (Nanosekunden) tsc_res_ns=32 irq_latency=0 ns
== NVPPS_GETTIMESTAMP ==
kernel_ts 2026-09-01 10:18:42.045513632 UTC (raw sec=1788257922 nsec=45513632)
hw_ptp_ts 2026-09-01 10:19:32.397007111 UTC (raw sec=1788257972 nsec=397007111)
kernel<->hw_ptp delta: 50351493479 ns
[ 1] evt_nb=3732 tsc=3826795309440 ptp=1788257973080827047 secondary_ptp=0
delta_tsc=1023992000 ns delta_ptp=1023986508 ns tsc<->ptp drift=-5492 ns since last event
kernel_ts 2026-09-01 10:18:43.045721120 UTC (raw sec=1788257923 nsec=45721120)
hw_ptp_ts 2026-09-01 10:19:33.397205331 UTC (raw sec=1788257973 nsec=397205331)
kernel<->hw_ptp delta: 50351484211 ns
[ 2] evt_nb=3733 tsc=3827819304640 ptp=1788257974104815267 secondary_ptp=0
delta_tsc=1023995200 ns delta_ptp=1023988220 ns tsc<->ptp drift=-6980 ns since last event
kernel_ts 2026-09-01 10:18:44.045860512 UTC (raw sec=1788257924 nsec=45860512)
hw_ptp_ts 2026-09-01 10:19:34.397345191 UTC (raw sec=1788257974 nsec=397345191)
kernel<->hw_ptp delta: 50351484679 ns
[ 3] evt_nb=3734 tsc=3828843304736 ptp=1788257975128816815 secondary_ptp=0
delta_tsc=1024000096 ns delta_ptp=1024001548 ns tsc<->ptp drift=1452 ns since last event
kernel_ts 2026-09-01 10:18:45.046004416 UTC (raw sec=1788257925 nsec=46004416)
hw_ptp_ts 2026-09-01 10:19:35.397474859 UTC (raw sec=1788257975 nsec=397474859)
kernel<->hw_ptp delta: 50351470443 ns
[ 4] evt_nb=3735 tsc=3829867311360 ptp=1788257976152800351 secondary_ptp=0
delta_tsc=1024006624 ns delta_ptp=1023983536 ns tsc<->ptp drift=-23088 ns since last event
kernel_ts 2026-09-01 10:18:46.046143680 UTC (raw sec=1788257926 nsec=46143680)
hw_ptp_ts 2026-09-01 10:19:36.397600891 UTC (raw sec=1788257976 nsec=397600891)
kernel<->hw_ptp delta: 50351457211 ns
[ 5] evt_nb=3736 tsc=3830891305664 ptp=1788257977176804847 secondary_ptp=0
delta_tsc=1023994304 ns delta_ptp=1024004496 ns tsc<->ptp drift=10192 ns since last event
kernel_ts 2026-09-01 10:18:47.046274720 UTC (raw sec=1788257927 nsec=46274720)
hw_ptp_ts 2026-09-01 10:19:37.397745651 UTC (raw sec=1788257977 nsec=397745651)
kernel<->hw_ptp delta: 50351470931 ns
[ 6] evt_nb=3737 tsc=3831915307168 ptp=1788257978200818719 secondary_ptp=0
delta_tsc=1024001504 ns delta_ptp=1024013872 ns tsc<->ptp drift=12368 ns since last event
kernel_ts 2026-09-01 10:18:48.046411328 UTC (raw sec=1788257928 nsec=46411328)
hw_ptp_ts 2026-09-01 10:19:38.397893115 UTC (raw sec=1788257978 nsec=397893115)
kernel<->hw_ptp delta: 50351481787 ns
[ 7] evt_nb=3738 tsc=3832939305440 ptp=1788257979224819987 secondary_ptp=0
delta_tsc=1023998272 ns delta_ptp=1024001268 ns tsc<->ptp drift=2996 ns since last event
kernel_ts 2026-09-01 10:18:49.046549280 UTC (raw sec=1788257929 nsec=46549280)
hw_ptp_ts 2026-09-01 10:19:39.398031503 UTC (raw sec=1788257979 nsec=398031503)
kernel<->hw_ptp delta: 50351482223 ns
[ 8] evt_nb=3739 tsc=3833963311488 ptp=1788257980248822647 secondary_ptp=0
delta_tsc=1024006048 ns delta_ptp=1024002660 ns tsc<->ptp drift=-3388 ns since last event
kernel_ts 2026-09-01 10:18:50.046685600 UTC (raw sec=1788257930 nsec=46685600)
hw_ptp_ts 2026-09-01 10:19:40.398164303 UTC (raw sec=1788257980 nsec=398164303)
kernel<->hw_ptp delta: 50351478703 ns
[ 9] evt_nb=3740 tsc=3834987308352 ptp=1788257981272815391 secondary_ptp=0
delta_tsc=1023996864 ns delta_ptp=1023992744 ns tsc<->ptp drift=-4120 ns since last event
kernel_ts 2026-09-01 10:18:51.046826656 UTC (raw sec=1788257931 nsec=46826656)
hw_ptp_ts 2026-09-01 10:19:41.398300955 UTC (raw sec=1788257981 nsec=398300955)
kernel<->hw_ptp delta: 50351474299 ns
[ 10] evt_nb=3741 tsc=3836011305728 ptp=1788257982296810999 secondary_ptp=0
delta_tsc=1023997376 ns delta_ptp=1023995608 ns tsc<->ptp drift=-1768 ns since last event
kernel_ts 2026-09-01 10:18:52.046964864 UTC (raw sec=1788257932 nsec=46964864)
hw_ptp_ts 2026-09-01 10:19:42.398437863 UTC (raw sec=1788257982 nsec=398437863)
kernel<->hw_ptp delta: 50351472999 ns
[ 11] evt_nb=3742 tsc=3837035309120 ptp=1788257983320814995 secondary_ptp=0
delta_tsc=1024003392 ns delta_ptp=1024003996 ns tsc<->ptp drift=604 ns since last event
kernel_ts 2026-09-01 10:18:53.047092544 UTC (raw sec=1788257933 nsec=47092544)
hw_ptp_ts 2026-09-01 10:19:43.398566303 UTC (raw sec=1788257983 nsec=398566303)
kernel<->hw_ptp delta: 50351473759 ns
[ 12] evt_nb=3743 tsc=3838059306272 ptp=1788257984344813215 secondary_ptp=0
delta_tsc=1023997152 ns delta_ptp=1023998220 ns tsc<->ptp drift=1068 ns since last event
kernel_ts 2026-09-01 10:18:54.047236352 UTC (raw sec=1788257934 nsec=47236352)
hw_ptp_ts 2026-09-01 10:19:44.398711311 UTC (raw sec=1788257984 nsec=398711311)
kernel<->hw_ptp delta: 50351474959 ns
[ 13] evt_nb=3744 tsc=3839083315424 ptp=1788257985368822807 secondary_ptp=0
delta_tsc=1024009152 ns delta_ptp=1024009592 ns tsc<->ptp drift=440 ns since last event
kernel_ts 2026-09-01 10:18:55.047374944 UTC (raw sec=1788257935 nsec=47374944)
hw_ptp_ts 2026-09-01 10:19:45.398849891 UTC (raw sec=1788257985 nsec=398849891)
kernel<->hw_ptp delta: 50351474947 ns
[ 14] evt_nb=3745 tsc=3840107312448 ptp=1788257986392819611 secondary_ptp=0
delta_tsc=1023997024 ns delta_ptp=1023996804 ns tsc<->ptp drift=-220 ns since last event
kernel_ts 2026-09-01 10:18:56.047508160 UTC (raw sec=1788257936 nsec=47508160)
hw_ptp_ts 2026-09-01 10:19:46.398983703 UTC (raw sec=1788257986 nsec=398983703)
kernel<->hw_ptp delta: 50351475543 ns
[ 15] evt_nb=3745 tsc=3840107312448 ptp=1788257986392819611 secondary_ptp=0
kernel_ts 2026-09-01 10:18:57.047642272 UTC (raw sec=1788257937 nsec=47642272)
hw_ptp_ts 2026-09-01 10:19:47.399118967 UTC (raw sec=1788257987 nsec=399118967)
kernel<->hw_ptp delta: 50351476695 ns
[ 16] evt_nb=3746 tsc=3841131316512 ptp=1788257987416823663 secondary_ptp=0
delta_tsc=1024004064 ns delta_ptp=1024004052 ns tsc<->ptp drift=-12 ns since last event
kernel_ts 2026-09-01 10:18:58.047790816 UTC (raw sec=1788257938 nsec=47790816)
hw_ptp_ts 2026-09-01 10:19:48.399279231 UTC (raw sec=1788257988 nsec=399279231)
kernel<->hw_ptp delta: 50351488415 ns
[ 17] evt_nb=3747 tsc=3842155318720 ptp=1788257988440838971 secondary_ptp=0
delta_tsc=1024002208 ns delta_ptp=1024015308 ns tsc<->ptp drift=13100 ns since last event
kernel_ts 2026-09-01 10:18:59.047927392 UTC (raw sec=1788257939 nsec=47927392)
hw_ptp_ts 2026-09-01 10:19:49.399408059 UTC (raw sec=1788257989 nsec=399408059)
kernel<->hw_ptp delta: 50351480667 ns
[ 18] evt_nb=3748 tsc=3843179311680 ptp=1788257989464820515 secondary_ptp=0
delta_tsc=1023992960 ns delta_ptp=1023981544 ns tsc<->ptp drift=-11416 ns since last event
kernel_ts 2026-09-01 10:19:00.048062752 UTC (raw sec=1788257940 nsec=48062752)
hw_ptp_ts 2026-09-01 10:19:50.399520427 UTC (raw sec=1788257990 nsec=399520427)
kernel<->hw_ptp delta: 50351457675 ns
[ 19] evt_nb=3749 tsc=3844203315616 ptp=1788257990488802131 secondary_ptp=0
delta_tsc=1024003936 ns delta_ptp=1023981616 ns tsc<->ptp drift=-22320 ns since last event
kernel_ts 2026-09-01 10:19:01.048192416 UTC (raw sec=1788257941 nsec=48192416)
hw_ptp_ts 2026-09-01 10:19:51.399657351 UTC (raw sec=1788257991 nsec=399657351)
kernel<->hw_ptp delta: 50351464935 ns
Dear @marius.westendorf ,
What is the used camera module?
Just with 6 cameras is the application working? If so, Can you check increasing number of lidars from 1 to 4 to see when it gets triggered.
What does your application do?
We’re using Sony IMX728 GMSL2 cameras. The application in question is the recorder tool. Currently, even with no lidars and no Time Grand Master attached, neither the recorder tool nor the sample camera application works — I disconnected the TGM as well to test that, and the issue persisted. At this point, reflashing the system looks like my only viable option, unless you have another suggestion.
Sample_camera is not working with single camera as well? Is it listed in DRIVE AGX Orin Ecosystem Vendors | NVIDIA Developer ?
Does nvsipl_camera works well? Did sony confirm if DOS 6.0.10 is supported for the module?
If it worked earlier, you may check reflashing the target.
We can close this thread. We were able to identify the fault ourselves. During a vehicle modification, a quad cable was plugged into Interface B. This does not have the same I2C bus speed as Ports A, C and D.
