Getting this error shown below, when trying to use any other port than csi-a interface. Saying it fails to allocate image pool. Why is that happening? This is a software for translating gmsl nvidia into ROS, it is crosscompiled.
nvidia@tegra-ubuntu:~/kia_samples/joystick_drive_ws$ roslaunch nvidia_gmsl_driver_ros nvidia_gmsl_driver_ros.launch verbose:=true
... logging to /home/nvidia/.ros/log/b0abbcba-2239-11ed-bd8e-00044bd343cc/roslaunch-tegra-ubuntu-11713.log
Checking log directory for disk usage. This may take a while.
Press Ctrl-C to interrupt
WARNING: disk usage in log directory [/home/nvidia/.ros/log] is over 1GB.
It's recommended that you use the 'rosclean' command.
started roslaunch server http://tegra-ubuntu:39577/
SUMMARY
PARAMETERS
* /nvidia_gmsl_driver_ros/calib_dir_path: /home/nvidia/kia_...
* /nvidia_gmsl_driver_ros/config_path: /home/nvidia/kia_...
* /nvidia_gmsl_driver_ros/encoder: h264
* /nvidia_gmsl_driver_ros/framerate: 30
* /nvidia_gmsl_driver_ros/h264_bitrate: 2000000
* /rosdistro: melodic
* /rosversion: 1.14.13
NODES
nvidia_gmsl_driver_ros (nvidia_gmsl_driver_ros/nvidia_gmsl_driver_ros_node)
auto-starting new master
process[master]: started with pid [11731]
ROS_MASTER_URI=http://localhost:11311
setting /run_id to b0abbcba-2239-11ed-bd8e-00044bd343cc
process[rosout-1]: started with pid [11750]
started core service [/rosout]
process[nvidia_gmsl_driver_ros-2]: started with pid [11757]
[ INFO] [1661186671.759016972]: encoder: h264
[ INFO] [1661186671.763023880]: config_path: /home/nvidia/kia_samples/ros_catkin_ws/install_isolated/share/nvidia_gmsl_driver_ros/launch/../config/ports.yaml
[ INFO] [1661186671.765168296]: [22-08-2022 18:44:31]
[ INFO] [1661186671.765326538]: Platform: Detected DDPX - Tegra B
[ INFO] [1661186671.765616623]: [22-08-2022 18:44:31]
[ INFO] [1661186671.765751281]: TimeSource: monotonic epoch time offset is 1661180167264997
[ WARN] [1661186671.765908019]: [22-08-2022 18:44:31]
[ WARN] [1661186671.765993524]: TimeSource: Could not detect valid PTP time source at nvpps. Fallback to eth0
[ERROR] [1661186671.766164407]: [22-08-2022 18:44:31]
[ERROR] [1661186671.766245880]: TimeSource Eth: Lost PTP time synchronizaton. Synchronized time will not be available from this timesource.
[ WARN] [1661186671.766361530]: [22-08-2022 18:44:31]
[ WARN] [1661186671.766495548]: TimeSource: Could not detect valid PTP time source at 'eth0'. Fallback to CLOCK_MONOTONIC.
[ INFO] [1661186672.490061657]: [22-08-2022 18:44:32]
[ INFO] [1661186672.490244987]: Platform: number of GPU devices detected 1
[ INFO] [1661186672.490563520]: [22-08-2022 18:44:32]
[ INFO] [1661186672.490669858]: Platform: currently selected GPU device integrated ID 0
[ INFO] [1661186672.493843377]: [22-08-2022 18:44:32]
[ INFO] [1661186672.494007219]: Context::getDataPathFromSelfLocation DATA_ROOT found at: /usr/local/driveworks-3.5/data
[ INFO] [1661186672.494839264]: [22-08-2022 18:44:32]
[ INFO] [1661186672.494931521]: SDK: No resources(.pak) mounted, some modules will not function properly
[ INFO] [1661186672.495070723]: [22-08-2022 18:44:32]
[ INFO] [1661186672.495137316]: SDK: Create NvMediaDevice
[ INFO] [1661186672.495287814]: [22-08-2022 18:44:32]
[ INFO] [1661186672.495380360]: SDK: Create NvMedia2D
[ INFO] [1661186672.507719328]: [22-08-2022 18:44:32]
[ INFO] [1661186672.507839905]: egl::Display: found 1 EGL devices
[ INFO] [1661186672.508808880]: [22-08-2022 18:44:32]
[ INFO] [1661186672.508930674]: egl::Display: use drm device: /dev/dri/card0
[ INFO] [1661186672.712888241]: [22-08-2022 18:44:32]
[ INFO] [1661186672.713159157]: TimeSource: monotonic epoch time offset is 1661180167264998
[ WARN] [1661186672.713387544]: [22-08-2022 18:44:32]
[ WARN] [1661186672.713513722]: TimeSource: Could not detect valid PTP time source at nvpps. Fallback to eth0
[ERROR] [1661186672.713669116]: [22-08-2022 18:44:32]
[ERROR] [1661186672.713764894]: TimeSource Eth: Lost PTP time synchronizaton. Synchronized time will not be available from this timesource.
[ WARN] [1661186672.713890207]: [22-08-2022 18:44:32]
[ WARN] [1661186672.713991425]: TimeSource: Could not detect valid PTP time source at 'eth0'. Fallback to CLOCK_MONOTONIC.
[ INFO] [1661186672.714969072]: [22-08-2022 18:44:32]
[ INFO] [1661186672.715186035]: Initialize DriveWorks SDK v3.5.75
[ INFO] [1661186672.715334005]: [22-08-2022 18:44:32]
[ INFO] [1661186672.715481079]: Release build with GNU 7.3.1 from heads/buildbrain-branch-0-gc61a9a35bd0 against Drive PDK v5.2.0.0
[DEBUG] [1661186672.716184930]: Link 1 : SF3324
[ INFO] [1661186672.720890664]: [22-08-2022 18:44:32]
[ INFO] [1661186672.720990601]: SensorFactory::createSensor() -> camera.gmsl, output-format=processed,camera-name=SF3324,interface=csi-b,link=1
[ INFO] [1661186672.721496753]: [22-08-2022 18:44:32]
[ INFO] [1661186672.721618227]: CameraBase: pool size set to 8
[ INFO] [1661186672.721809109]: [22-08-2022 18:44:32]
[ INFO] [1661186672.721952056]: SensorFactory::createSensor() -> camera.gmsl.master,
[ INFO] [1661186672.753794450]: [22-08-2022 18:44:32]
[ INFO] [1661186672.753927284]: CameraMaster::parseDevBlock Getting device info list.
[ INFO] [1661186672.754216984]: [22-08-2022 18:44:32]
[ INFO] [1661186672.754312186]: devBlock: 1 Slave = 0 Interface = csi-b Camera_name = SF3324 Link = 1
[ INFO] [1661186672.754843138]: [22-08-2022 18:44:32]
[ INFO] [1661186672.754936515]: Camera Match Name: SF3324 Description: Sekonix SF3324 module - 120-deg FOV, DVP AR0231-RCCB, MAX96705 linkIndex: 4294967295 serInfo.Name: MAX96705
[ INFO] [1661186672.755189351]: [22-08-2022 18:44:32]
[ INFO] [1661186672.755282824]: Client, Setting up information for camera ID 0
[ INFO] [1661186672.755385514]: [22-08-2022 18:44:32]
[ INFO] [1661186672.755461611]: Client, successfully found info for camera ID 0 bound to id 0
[ INFO] [1661186672.896304701]: [22-08-2022 18:44:32]
[ INFO] [1661186672.896442463]: CameraClient: no NITO found at /opt/nvidia/nvmedia/nit/SF3324.nito
[ INFO] [1661186672.897192971]: [22-08-2022 18:44:32]
[ INFO] [1661186672.897458511]: CameraClient: using NITO found at /opt/nvidia/nvmedia/nit/sf3324.nito
[ INFO] [1661186672.907044797]: camera calibration URL: file:///home/nvidia/kia_samples/ros_catkin_ws/install_isolated/share/nvidia_gmsl_driver_ros/launch/../calib/interfaceb_link1.yaml
[DEBUG] [1661186672.910069034]: CameraH264 on interface : b, link : 1 initialized successfully!
[ INFO] [1661186672.914647727]: H264 Bitrate: 2000000
[ INFO] [1661186672.917164980]: [22-08-2022 18:44:32]
[ INFO] [1661186672.917257590]: CameraClient: camera params: format=h264,bitrate=2000000,framerate=30,type=user
[ WARN] [1661186672.917450008]: [22-08-2022 18:44:32]
[ WARN] [1661186672.917534394]: EncoderNvMedia: Setting encode on instance 0
[DEBUG] [1661186672.927680177]: INITIALIZED SERIALIZER
[DEBUG] [1661186672.927819475]: Link 0 : SF3324
[ INFO] [1661186672.932569914]: [22-08-2022 18:44:32]
[ INFO] [1661186672.932699772]: SensorFactory::createSensor() -> camera.gmsl, output-format=processed,camera-name=SF3324,interface=csi-b,link=0
[ INFO] [1661186672.932904639]: [22-08-2022 18:44:32]
[ INFO] [1661186672.932955455]: CameraBase: pool size set to 8
[ INFO] [1661186672.933150306]: [22-08-2022 18:44:32]
[ INFO] [1661186672.933199971]: devBlock: 1 Slave = 0 Interface = csi-b Camera_name = SF3324 Link = 0
[ INFO] [1661186672.933312357]: [22-08-2022 18:44:32]
[ INFO] [1661186672.933454247]: Camera Match Name: SF3324 Description: Sekonix SF3324 module - 120-deg FOV, DVP AR0231-RCCB, MAX96705 linkIndex: 4294967295 serInfo.Name: MAX96705
[ INFO] [1661186672.933567817]: [22-08-2022 18:44:32]
[ INFO] [1661186672.933648522]: Client, Setting up information for camera ID 1
[ INFO] [1661186672.933727595]: [22-08-2022 18:44:32]
[ INFO] [1661186672.933802508]: Client, successfully found info for camera ID 1 bound to id 1
[ INFO] [1661186673.079152802]: [22-08-2022 18:44:33]
[ INFO] [1661186673.079349253]: CameraClient: no NITO found at /opt/nvidia/nvmedia/nit/SF3324.nito
[ INFO] [1661186673.079510727]: [22-08-2022 18:44:33]
[ INFO] [1661186673.079574696]: CameraClient: using NITO found at /opt/nvidia/nvmedia/nit/sf3324.nito
[ INFO] [1661186673.088634863]: camera calibration URL: file:///home/nvidia/kia_samples/ros_catkin_ws/install_isolated/share/nvidia_gmsl_driver_ros/launch/../calib/interfaceb_link0.yaml
[DEBUG] [1661186673.091027891]: CameraH264 on interface : b, link : 0 initialized successfully!
[ INFO] [1661186673.095119408]: H264 Bitrate: 2000000
[ INFO] [1661186673.097697398]: [22-08-2022 18:44:33]
[ INFO] [1661186673.097795127]: CameraClient: camera params: format=h264,bitrate=2000000,framerate=30,type=user
[ WARN] [1661186673.097918809]: [22-08-2022 18:44:33]
[ WARN] [1661186673.097973690]: EncoderNvMedia: Setting encode on instance 0
[DEBUG] [1661186673.107108706]: INITIALIZED SERIALIZER
[DEBUG] [1661186673.107245188]: Link 3 : SF3325
[ INFO] [1661186673.112437970]: [22-08-2022 18:44:33]
[ INFO] [1661186673.112595604]: SensorFactory::createSensor() -> camera.gmsl, output-format=processed,camera-name=SF3325,interface=csi-b,link=3
[ INFO] [1661186673.112791511]: [22-08-2022 18:44:33]
[ INFO] [1661186673.112864888]: CameraBase: pool size set to 8
[ INFO] [1661186673.112951545]: [22-08-2022 18:44:33]
[ INFO] [1661186673.113077371]: devBlock: 1 Slave = 0 Interface = csi-b Camera_name = SF3325 Link = 3
[ INFO] [1661186673.113210589]: [22-08-2022 18:44:33]
[ INFO] [1661186673.113293790]: Camera Match Name: SF3325 Description: Sekonix SF3325 module - 60-deg FOV, DVP AR0231-RCCB, MAX96705 linkIndex: 4294967295 serInfo.Name: MAX96705
[ INFO] [1661186673.113416384]: [22-08-2022 18:44:33]
[ INFO] [1661186673.113475713]: Client, Setting up information for camera ID 2
[ INFO] [1661186673.113530146]: [22-08-2022 18:44:33]
[ INFO] [1661186673.113571331]: Client, successfully found info for camera ID 2 bound to id 2
[ INFO] [1661186673.263213656]: [22-08-2022 18:44:33]
[ INFO] [1661186673.263338970]: CameraClient: no NITO found at /opt/nvidia/nvmedia/nit/SF3325.nito
[ INFO] [1661186673.263465532]: [22-08-2022 18:44:33]
[ INFO] [1661186673.263536221]: CameraClient: using NITO found at /opt/nvidia/nvmedia/nit/sf3325.nito
[ INFO] [1661186673.274011705]: camera calibration URL: file:///home/nvidia/kia_samples/ros_catkin_ws/install_isolated/share/nvidia_gmsl_driver_ros/launch/../calib/interfaceb_link3.yaml
[DEBUG] [1661186673.276344156]: CameraH264 on interface : b, link : 3 initialized successfully!
[ INFO] [1661186673.280581019]: H264 Bitrate: 2000000
[ INFO] [1661186673.283148225]: [22-08-2022 18:44:33]
[ INFO] [1661186673.283241891]: CameraClient: camera params: format=h264,bitrate=2000000,framerate=30,type=user
[ WARN] [1661186673.283349828]: [22-08-2022 18:44:33]
[ WARN] [1661186673.283411973]: EncoderNvMedia: Setting encode on instance 0
[DEBUG] [1661186673.292467884]: INITIALIZED SERIALIZER
[DEBUG] [1661186673.292617038]: Link 2 : SF3324
[ INFO] [1661186673.297524599]: [22-08-2022 18:44:33]
[ INFO] [1661186673.297675034]: SensorFactory::createSensor() -> camera.gmsl, camera-name=SF3324,output-format=processed,interface=csi-b,link=2
[ INFO] [1661186673.297867324]: [22-08-2022 18:44:33]
[ INFO] [1661186673.297922141]: CameraBase: pool size set to 8
[ INFO] [1661186673.298039903]: [22-08-2022 18:44:33]
[ INFO] [1661186673.298103360]: devBlock: 1 Slave = 0 Interface = csi-b Camera_name = SF3324 Link = 2
[ INFO] [1661186673.298209954]: [22-08-2022 18:44:33]
[ INFO] [1661186673.298263810]: Camera Match Name: SF3324 Description: Sekonix SF3324 module - 120-deg FOV, DVP AR0231-RCCB, MAX96705 linkIndex: 4294967295 serInfo.Name: MAX96705
[ INFO] [1661186673.298354756]: [22-08-2022 18:44:33]
[ INFO] [1661186673.298405860]: Client, Setting up information for camera ID 3
[ INFO] [1661186673.298483014]: [22-08-2022 18:44:33]
[ INFO] [1661186673.298531238]: Client, successfully found info for camera ID 3 bound to id 3
[ INFO] [1661186673.451200073]: [22-08-2022 18:44:33]
[ INFO] [1661186673.451330443]: CameraClient: no NITO found at /opt/nvidia/nvmedia/nit/SF3324.nito
[ INFO] [1661186673.451463053]: [22-08-2022 18:44:33]
[ INFO] [1661186673.451512878]: CameraClient: using NITO found at /opt/nvidia/nvmedia/nit/sf3324.nito
[ INFO] [1661186673.461512899]: camera calibration URL: file:///home/nvidia/kia_samples/ros_catkin_ws/install_isolated/share/nvidia_gmsl_driver_ros/launch/../calib/interfaceb_link2.yaml
[DEBUG] [1661186673.463918150]: CameraH264 on interface : b, link : 2 initialized successfully!
[ INFO] [1661186673.468493195]: H264 Bitrate: 2000000
[ INFO] [1661186673.472988430]: [22-08-2022 18:44:33]
[ INFO] [1661186673.473160144]: CameraClient: camera params: format=h264,bitrate=2000000,framerate=30,type=user
[ WARN] [1661186673.473288082]: [22-08-2022 18:44:33]
[ WARN] [1661186673.473337747]: EncoderNvMedia: Setting encode on instance 0
[DEBUG] [1661186673.500340581]: INITIALIZED SERIALIZER
[ INFO] [1661186673.500594121]: [22-08-2022 18:44:33]
[ INFO] [1661186673.500681386]: CameraGSMLMaster: starting...
[ INFO] [1661186673.500836429]: [22-08-2022 18:44:33]
[ INFO] [1661186673.500906702]: SIPLMaster::SIPLMaster: Setting up master camera
[ INFO] [1661186673.510413147]: [22-08-2022 18:44:33]
[ INFO] [1661186673.510550909]: Platform:
[ INFO] [1661186673.510659071]: [22-08-2022 18:44:33]
[ INFO] [1661186673.510744992]: Platform Config:
[ INFO] [1661186673.510825185]: [22-08-2022 18:44:33]
[ INFO] [1661186673.510888130]: Description:
[ INFO] [1661186673.510973444]: [22-08-2022 18:44:33]
[ INFO] [1661186673.511037029]: Number of device blocks: 1
[ INFO] [1661186673.511092549]: [22-08-2022 18:44:33]
[ INFO] [1661186673.511150918]: Device Block : 0
[ INFO] [1661186673.511229799]: [22-08-2022 18:44:33]
[ INFO] [1661186673.511313577]: csiPort: 1
[ INFO] [1661186673.511426826]: [22-08-2022 18:44:33]
[ INFO] [1661186673.511476075]: i2cDevice: 0
[ INFO] [1661186673.511547308]: [22-08-2022 18:44:33]
[ INFO] [1661186673.511599533]: Deserializer Name: MAX96712
[ INFO] [1661186673.511654510]: [22-08-2022 18:44:33]
[ INFO] [1661186673.511727983]: Deserializer Description: Maxim 96712 Aggregator
[ INFO] [1661186673.511794224]: [22-08-2022 18:44:33]
[ INFO] [1661186673.511862353]: Deserializer i2cAddress: 41
[ INFO] [1661186673.511934866]: [22-08-2022 18:44:33]
[ INFO] [1661186673.512002835]: Simulator Mode: 0
[ INFO] [1661186673.512065652]: [22-08-2022 18:44:33]
[ INFO] [1661186673.512129333]: Slave Mode: 0
[ INFO] [1661186673.512206006]: [22-08-2022 18:44:33]
[ INFO] [1661186673.512279095]: Phy Mode: 0
[ INFO] [1661186673.512354424]: [22-08-2022 18:44:33]
[ INFO] [1661186673.512418329]: Number of camera modules: 4
[ INFO] [1661186673.512487738]: [22-08-2022 18:44:33]
[ INFO] [1661186673.512527867]: CameraModule index: 1
[ INFO] [1661186673.512608828]: [22-08-2022 18:44:33]
[ INFO] [1661186673.512674141]: Name :SF3324
[ INFO] [1661186673.512734398]: [22-08-2022 18:44:33]
[ INFO] [1661186673.512826303]: Description: Sekonix SF3324 module - 120-deg FOV, DVP AR0231-RCCB, MAX96705
[ INFO] [1661186673.512902400]: [22-08-2022 18:44:33]
[ INFO] [1661186673.512958081]: Serializer name: MAX96705
[ INFO] [1661186673.513082051]: [22-08-2022 18:44:33]
[ INFO] [1661186673.513147428]: Serializer description: Maxim 96705 Serializer
[ INFO] [1661186673.513223333]: [22-08-2022 18:44:33]
[ INFO] [1661186673.513283686]: Serializer i2cAdress: 64
[ INFO] [1661186673.513339015]: [22-08-2022 18:44:33]
[ INFO] [1661186673.513400456]: Sensor ID: 0
[ INFO] [1661186673.513473673]: [22-08-2022 18:44:33]
[ INFO] [1661186673.513540234]: Sensor name: AR0231
[ INFO] [1661186673.513621323]: [22-08-2022 18:44:33]
[ INFO] [1661186673.513664236]: Sensor description: OnSemi AR0231 Sensor
[ INFO] [1661186673.513756109]: [22-08-2022 18:44:33]
[ INFO] [1661186673.513820686]: Sensor i2cAddress: 16
[ INFO] [1661186673.513911663]: [22-08-2022 18:44:33]
[ INFO] [1661186673.514072978]: Sensor isTPGEnabled: 0
[ INFO] [1661186673.514168275]: [22-08-2022 18:44:33]
[ INFO] [1661186673.514213460]: Sensor isTriggerMode: 1
[ INFO] [1661186673.514311381]: [22-08-2022 18:44:33]
[ INFO] [1661186673.514354838]: cfa: 39
[ INFO] [1661186673.514419031]: [22-08-2022 18:44:33]
[ INFO] [1661186673.514474008]: embeddedTopLines: 24
[ INFO] [1661186673.514572569]: [22-08-2022 18:44:33]
[ INFO] [1661186673.514622938]: embeddedBottomLines: 4
[ INFO] [1661186673.514679739]: [22-08-2022 18:44:33]
[ INFO] [1661186673.514720699]: inputFormat: 8
[ INFO] [1661186673.514788028]: [22-08-2022 18:44:33]
[ INFO] [1661186673.514830237]: height: 1208
[ INFO] [1661186673.514891038]: [22-08-2022 18:44:33]
[ INFO] [1661186673.514931263]: width: 1920
[ INFO] [1661186673.515020064]: [22-08-2022 18:44:33]
[ INFO] [1661186673.515120321]: fps: 30.0000000
[ INFO] [1661186673.515195170]: [22-08-2022 18:44:33]
[ INFO] [1661186673.515236323]: Embedded Data: 0
[ INFO] [1661186673.515294596]: [22-08-2022 18:44:33]
[ INFO] [1661186673.515382437]: CameraModule index: 0
[ INFO] [1661186673.515451558]: [22-08-2022 18:44:33]
[ INFO] [1661186673.515525671]: Name :SF3324
[ INFO] [1661186673.515599753]: [22-08-2022 18:44:33]
[ INFO] [1661186673.515675018]: Description: Sekonix SF3324 module - 120-deg FOV, DVP AR0231-RCCB, MAX96705
[ INFO] [1661186673.515735115]: [22-08-2022 18:44:33]
[ INFO] [1661186673.515839116]: Serializer name: MAX96705
[ INFO] [1661186673.516008047]: [22-08-2022 18:44:33]
[ INFO] [1661186673.516102992]: Serializer description: Maxim 96705 Serializer
[ INFO] [1661186673.516272019]: [22-08-2022 18:44:33]
[ INFO] [1661186673.516328403]: Serializer i2cAdress: 64
[ INFO] [1661186673.516423317]: [22-08-2022 18:44:33]
[ INFO] [1661186673.516498614]: Sensor ID: 1
[ INFO] [1661186673.516608536]: [22-08-2022 18:44:33]
[ INFO] [1661186673.516674361]: Sensor name: AR0231
[ INFO] [1661186673.516792570]: [22-08-2022 18:44:33]
[ INFO] [1661186673.516860699]: Sensor description: OnSemi AR0231 Sensor
[ INFO] [1661186673.516992957]: [22-08-2022 18:44:33]
[ INFO] [1661186673.517113023]: Sensor i2cAddress: 16
[ INFO] [1661186673.517265537]: [22-08-2022 18:44:33]
[ INFO] [1661186673.517332258]: Sensor isTPGEnabled: 0
[ INFO] [1661186673.517405379]: [22-08-2022 18:44:33]
[ INFO] [1661186673.517476132]: Sensor isTriggerMode: 1
[ INFO] [1661186673.517551398]: [22-08-2022 18:44:33]
[ INFO] [1661186673.517593094]: cfa: 39
[ INFO] [1661186673.517674087]: [22-08-2022 18:44:33]
[ INFO] [1661186673.517719720]: embeddedTopLines: 24
[ INFO] [1661186673.517817482]: [22-08-2022 18:44:33]
[ INFO] [1661186673.517866954]: embeddedBottomLines: 4
[ INFO] [1661186673.517941099]: [22-08-2022 18:44:33]
[ INFO] [1661186673.518003020]: inputFormat: 8
[ INFO] [1661186673.518057965]: [22-08-2022 18:44:33]
[ INFO] [1661186673.518132878]: height: 1208
[ INFO] [1661186673.518204399]: [22-08-2022 18:44:33]
[ INFO] [1661186673.518257104]: width: 1920
[ INFO] [1661186673.518314705]: [22-08-2022 18:44:33]
[ INFO] [1661186673.518368306]: fps: 30.0000000
[ INFO] [1661186673.518421939]: [22-08-2022 18:44:33]
[ INFO] [1661186673.518474867]: Embedded Data: 0
[ INFO] [1661186673.518542164]: [22-08-2022 18:44:33]
[ INFO] [1661186673.518589429]: CameraModule index: 3
[ INFO] [1661186673.518767960]: [22-08-2022 18:44:33]
[ INFO] [1661186673.518839161]: Name :SF3325
[ INFO] [1661186673.518936634]: [22-08-2022 18:44:33]
[ INFO] [1661186673.519026556]: Description: Sekonix SF3325 module - 60-deg FOV, DVP AR0231-RCCB, MAX96705
[ INFO] [1661186673.519109341]: [22-08-2022 18:44:33]
[ INFO] [1661186673.519164030]: Serializer name: MAX96705
[ INFO] [1661186673.519277503]: [22-08-2022 18:44:33]
[ INFO] [1661186673.519356897]: Serializer description: Maxim 96705 Serializer
[ INFO] [1661186673.519450690]: [22-08-2022 18:44:33]
[ INFO] [1661186673.519507203]: Serializer i2cAdress: 64
[ INFO] [1661186673.519598180]: [22-08-2022 18:44:33]
[ INFO] [1661186673.519657541]: Sensor ID: 2
[ INFO] [1661186673.519742982]: [22-08-2022 18:44:33]
[ INFO] [1661186673.519812359]: Sensor name: AR0231
[ INFO] [1661186673.519888808]: [22-08-2022 18:44:33]
[ INFO] [1661186673.519954409]: Sensor description: OnSemi AR0231 Sensor
[ INFO] [1661186673.520032651]: [22-08-2022 18:44:33]
[ INFO] [1661186673.520095084]: Sensor i2cAddress: 16
[ INFO] [1661186673.520203085]: [22-08-2022 18:44:33]
[ INFO] [1661186673.520305455]: Sensor isTPGEnabled: 0
[ INFO] [1661186673.520418512]: [22-08-2022 18:44:33]
[ INFO] [1661186673.520553970]: Sensor isTriggerMode: 1
[ INFO] [1661186673.520642676]: [22-08-2022 18:44:33]
[ INFO] [1661186673.520709109]: cfa: 39
[ INFO] [1661186673.520825782]: [22-08-2022 18:44:33]
[ INFO] [1661186673.520882295]: embeddedTopLines: 24
[ INFO] [1661186673.520963608]: [22-08-2022 18:44:33]
[ INFO] [1661186673.521067034]: embeddedBottomLines: 4
[ INFO] [1661186673.521159899]: [22-08-2022 18:44:33]
[ INFO] [1661186673.521214108]: inputFormat: 8
[ INFO] [1661186673.521296669]: [22-08-2022 18:44:33]
[ INFO] [1661186673.521383455]: height: 1208
[ INFO] [1661186673.521477216]: [22-08-2022 18:44:33]
[ INFO] [1661186673.521530081]: width: 1920
[ INFO] [1661186673.521617410]: [22-08-2022 18:44:33]
[ INFO] [1661186673.521719908]: fps: 30.0000000
[ INFO] [1661186673.521780869]: [22-08-2022 18:44:33]
[ INFO] [1661186673.521831909]: Embedded Data: 0
[ INFO] [1661186673.521933031]: [22-08-2022 18:44:33]
[ INFO] [1661186673.521991176]: CameraModule index: 2
[ INFO] [1661186673.522088585]: [22-08-2022 18:44:33]
[ INFO] [1661186673.522146602]: Name :SF3324
[ INFO] [1661186673.522227563]: [22-08-2022 18:44:33]
[ INFO] [1661186673.522291340]: Description: Sekonix SF3324 module - 120-deg FOV, DVP AR0231-RCCB, MAX96705
[ INFO] [1661186673.522379374]: [22-08-2022 18:44:33]
[ INFO] [1661186673.522469615]: Serializer name: MAX96705
[ INFO] [1661186673.522541072]: [22-08-2022 18:44:33]
[ INFO] [1661186673.522611857]: Serializer description: Maxim 96705 Serializer
[ INFO] [1661186673.522692210]: [22-08-2022 18:44:33]
[ INFO] [1661186673.522805076]: Serializer i2cAdress: 64
[ INFO] [1661186673.522911445]: [22-08-2022 18:44:33]
[ INFO] [1661186673.522978102]: Sensor ID: 3
[ INFO] [1661186673.523090968]: [22-08-2022 18:44:33]
[ INFO] [1661186673.523167737]: Sensor name: AR0231
[ INFO] [1661186673.523272571]: [22-08-2022 18:44:33]
[ INFO] [1661186673.523350460]: Sensor description: OnSemi AR0231 Sensor
[ INFO] [1661186673.523450045]: [22-08-2022 18:44:33]
[ INFO] [1661186673.523512062]: Sensor i2cAddress: 16
[ INFO] [1661186673.523619552]: [22-08-2022 18:44:33]
[ INFO] [1661186673.523713281]: Sensor isTPGEnabled: 0
[ INFO] [1661186673.523824931]: [22-08-2022 18:44:33]
[ INFO] [1661186673.523890340]: Sensor isTriggerMode: 1
[ INFO] [1661186673.523988166]: [22-08-2022 18:44:33]
[ INFO] [1661186673.524072231]: cfa: 39
[ INFO] [1661186673.524154184]: [22-08-2022 18:44:33]
[ INFO] [1661186673.524214313]: embeddedTopLines: 24
[ INFO] [1661186673.524277578]: [22-08-2022 18:44:33]
[ INFO] [1661186673.524351627]: embeddedBottomLines: 4
[ INFO] [1661186673.524434060]: [22-08-2022 18:44:33]
[ INFO] [1661186673.524501645]: inputFormat: 8
[ INFO] [1661186673.524612655]: [22-08-2022 18:44:33]
[ INFO] [1661186673.524678704]: height: 1208
[ INFO] [1661186673.524761329]: [22-08-2022 18:44:33]
[ INFO] [1661186673.524822162]: width: 1920
[ INFO] [1661186673.524899507]: [22-08-2022 18:44:33]
[ INFO] [1661186673.524984532]: fps: 30.0000000
[ INFO] [1661186673.525180663]: [22-08-2022 18:44:33]
[ INFO] [1661186673.525253656]: Embedded Data: 0
[ INFO] [1661186673.525406555]: [22-08-2022 18:44:33]
[ INFO] [1661186673.525510428]: CameraMaster::setOutputDescription Setting output consumer descriptors for sensor: OutputType: 1
[ INFO] [1661186673.525602750]: [22-08-2022 18:44:33]
[ INFO] [1661186673.525667519]: CameraMaster::setOutputDescription Setting output consumer descriptors for sensor: OutputType: 1
[ INFO] [1661186673.525771392]: [22-08-2022 18:44:33]
[ INFO] [1661186673.525835169]: CameraMaster::setOutputDescription Setting output consumer descriptors for sensor: OutputType: 1
[ INFO] [1661186673.525920034]: [22-08-2022 18:44:33]
[ INFO] [1661186673.525987811]: CameraMaster::setOutputDescription Setting output consumer descriptors for sensor: OutputType: 1
[ INFO] [1661186673.526158598]: [22-08-2022 18:44:33]
[ INFO] [1661186673.526249255]: Client, setting pipeline config for camera ID 0
[ INFO] [1661186673.526391529]: [22-08-2022 18:44:33]
[ INFO] [1661186673.526456458]: Client, setting pipeline config for camera ID 1
[ INFO] [1661186673.526571404]: [22-08-2022 18:44:33]
[ INFO] [1661186673.526635757]: Client, setting pipeline config for camera ID 2
[ INFO] [1661186673.526727758]: [22-08-2022 18:44:33]
[ INFO] [1661186673.526792527]: Client, setting pipeline config for camera ID 3
[ INFO] [1661186673.526881105]: [22-08-2022 18:44:33]
[ INFO] [1661186673.526948050]: CameraMaster: master initiation
cdiRootDevOpen: can't open /dev/isc-mgr.0.b - No such file or directory
DevBlkCDIRootDeviceCreate: Unable to open root device
DEVBLK_WORKER_0: CNvMDeviceBlock.cpp: 218: Init: DevBlkCDIRootDeviceCreate failed!
DEVBLK_WORKER_0: CNvMDeviceBlockMgr.hpp: 147: ThreadFunc: Device block init failed(7f)
nvidia_gmsl_dri: CNvMDeviceBlockMgr.cpp: 129: WorkersDoAction: Device block action:1 failed for block:0
nvidia_gmsl_dri: CNvMDeviceBlockMgr.cpp: 163: Init: Failed to initialize device blocks
nvidia_gmsl_dri: CNvMCamera.cpp: 436: Init: DeviceBlock manager init failed
[ERROR] [1661186673.825642644]: [22-08-2022 18:44:33]
[ERROR] [1661186673.825779830]: CameraMaster: master init failed127
nvidia_gmsl_dri: CNvMCamera.cpp: 568: GetImageAttributes: Incorrect pipeline state:1 for pipeline:0
[ INFO] [1661186673.825977145]: [22-08-2022 18:44:33]
[ INFO] [1661186673.826046522]: CameraMaster: GetImageAttributes failed6
[ INFO] [1661186673.826158108]: [22-08-2022 18:44:33]
[ INFO] [1661186673.826224957]: CameraClient: GetImageAttributes failed6
[ INFO] [1661186673.826298814]: [22-08-2022 18:44:33]
[ INFO] [1661186673.826367647]: CameraClient: Failed to allocate images groups!6
[ERROR] [1661186673.826722084]: [22-08-2022 18:44:33]
[ERROR] [1661186673.826800133]: Driveworks exception thrown: DW_FAILURE: CameraClient: Failed to allocate images pool!
[ERROR] [1661186673.826870022]:
[FATAL] [1661186673.827195403]: [2022-08-22 18:44:33] DW Error DW_FAILURE executing DW function:
dwSensor_start(sensorHandle_)
at /home/gkiss/ros_catkin_ws/src/nvidia_gmsl_driver_ros/src/cameras/CameraBase.cpp:50
nvidia_gmsl_dri: CNvMCamera.cpp: 1088: Deinit: Incorrect pipeline state:1 for pipeline:0
nvidia_gmsl_dri: CNvMCamera.cpp: 48: ~CNvMCamera: CNvMCamera object fails to deinit
nvmedia: ERROR: MAX96712: Bad parameter: Null ptr
nvidia_gmsl_dri: CNvMMax96712.cpp: 244: Deinit: CDI_CONFIG_MAX96712_DISABLE_REPLICATION failed! with NvMedia error: 1
nvidia_gmsl_dri: CNvMDeviceBlock.cpp: 353: Deinit: Deserializer Deinit failed================================================================================REQUIRED process [nvidia_gmsl_driver_ros-2] has died!
process has died [pid 11757, exit code 1, cmd /home/nvidia/kia_samples/ros_catkin_ws/install_isolated/lib/nvidia_gmsl_driver_ros/nvidia_gmsl_driver_ros_node --verbose __name:=nvidia_gmsl_driver_ros __log:=/home/nvidia/.ros/log/b0abbcba-2239-11ed-bd8e-00044bd343cc/nvidia_gmsl_driver_ros-2.log].
log file: /home/nvidia/.ros/log/b0abbcba-2239-11ed-bd8e-00044bd343cc/nvidia_gmsl_driver_ros-2*.log
Initiating shutdown!
[nvidia_gmsl_driver_ros-2] killing on exit
[rosout-1] killing on exit
[master] killing on exit
shutting down processing monitor...
... shutting down processing monitor complete
done
Software Version
DRIVE OS Linux 5.2.6
DRIVE OS Linux 5.2.6 and DriveWorks 4.0
DRIVE OS Linux 5.2.0
other DRIVE OS version
other
Target Operating System
Linux
QNX
other
Hardware Platform
other
SDK Manager Version
1.8.1.10392
other
Host Machine Version
native Ubuntu 18.04
other
