bjxiao
#1
When I tried to install, it prompt
XCode Version 3.2 or higher is required for this installation.
But actually I am using Xcode4.5, I also set Xcode path using
sudo xcode-select -switch /Applications/Xcode.app/Contents/Developer
I need a help. Thank you in advance.
tull
#2
- do you have gcc installed? If not, do you have the Xcode command line
tool installed?
2.run the following
% sudo xcode-select -switch /Applications/Xcode.app/ Contents/Developer
% /usr/bin/xcode-select -print-path
#make sure that it prints /Applications/Xcode.app/ Contents/Developer
then install again.
Also make sure 'remote login’s are enabled.
regards,
dave
