Can we run the Entron camera (Entron F008A120RM0AES) on 24 bit
Software Version
DRIVE OS Linux 5.2.6
DRIVE OS Linux 5.2.6 and DriveWorks 4.0
DRIVE OS Linux 5.2.0
other DRIVE OS version
other
Target Operating System
Linux
QNX
other
Hardware Platform
other
SDK Manager Version
1.7.1.8928
other
Host Machine Version
native Ubuntu 18.04
other
My question is can we run the Entron camera (Entron F008A120RM0AES) on 24 bit?
Thank you.
Hi @user158496
I assume it runs on 24 bits. Do you see any problem?
No it is on 12 bits.
Do we need to do some setting to run on 24 bits?
Could you share your command to run the camera?
sudo ./sample_camera --rig=/path/to/ar0820_entron_camera
cd /usr/local/driveworks/bin
sudo ./sample_camera --rig=/usr/local/driveworks/data/samples/sensors/camera/camera/rig_ar0820.json
The sensor’s output is 12bits. You may try contacting Entron and see if they have a driver to support 24bits. Thanks.
