Please provide the following info (check/uncheck the boxes after creating this topic): Software Version
DRIVE OS Linux 5.2.6
DRIVE OS Linux 5.2.6 and DriveWorks 4.0
DRIVE OS Linux 5.2.0
other DRIVE OS version
other
Hello
I am using ./sample_camera_gmsl --camera-type=ar0820-rccb-bae-f008a120bm0a --write-file =… to record test video data.
It looks nvmedia found the camera type but driver is missing
nvmedia: ERROR: ImgGetDevice: Can’t find driver for ref_max96712_9295_ar0820f008a120bm0a
camera is entron f008a120bm0a
Please let me know what file need to add and where to put, thanks!
Dear @tingguang.wang1,
in DRIVE SW 10.0, the image capture in DW(DRIVEAV) is based on Nvmedia IPP framework.
In DRIVE OS 5.2.6 + DW 4.0 release, IPP is deprecated and replaced with NVSIPL framework. Note that, the DriveAV supported sensors in DRIVE SW 10.0 are SF3325 and SF3324 and DRIVE IX supports AR0144ATSM-GEVK
Entron camera is not supported with Driveworks. Please use supported sensors for using driveworks. Enabling unsupported camera for DW is out of forum support scope.
As clarified earlier DRIVE SW 10.0 uses IPP based framework to capture images in DRIVE AV. We later deprecated IPP and moved to SIPL framework.
Note that they are no releases targetted for DRIVE AGX Xavier platform and hence we request to use the supported cameras only.
