I cannot connect to the local server.
I wan to use the NVIDIA assets so I really need to connect the local server.
I have uninstalled the nucleus and reinstall but the same things happened.
And I also found that Search Service, Auth is stopped and I can not find the reasons.
Thanks for the post. Here are a couple of tips. First of all, you do not need to install localhost Nucleus to gain access to Nvidia Assets. Every single asset available through your localhost is also preloaded into USD Composer through the Nvidia Assets library. Secondly, if you wish to connect to your localhost, simply type in “localhost”.
My honest advice is for you to not try to get Nucleus working and just access any assets you need through the Nvidia Assets library browser in USD Composer.
