DRIVE OS Version: 7.0.3
Issue Description: No link detected on mgbe0_0
I am trying to connect mgbe0_0 directly to a NAS for streaming and logging high bandwidth data using the direct 10G connection. However, no matter what combination of cables, adapters, SFP adapter, media converters, etc… I try, no link is ever established and I am confident in ruling out anything exterior to the dev kit at this point.
$sudo ethtool mgbe0_0
Settings for mgbe0_0:
Supported ports: \[ TP MII \]
Supported link modes: Not reported
Supported pause frame use: Symmetric Receive-only
Supports auto-negotiation: Yes
Supported FEC modes: Not reported
Advertised link modes: Not reported
Advertised pause frame use: No
Advertised auto-negotiation: Yes
Advertised FEC modes: Not reported
Speed: 10000Mb/s
Duplex: Full
Auto-negotiation: on
Port: MII
PHYAD: 1
Transceiver: external
Supports Wake-on: d
Wake-on: d
Current message level: 0x00000000 (0)
Link detected: no
If I plug in the exact same cables/media convertes/etc into one of the other 10G ports that go through the marvell or realtek switches, things work as expected. The issue is only with mgbe0_0 that is supposed to be on Connector J4 Port 3 according to the SDK docs. The link lights on the various media converters / PCIe network card on the other end of the cable also never show a link established, which correlates to what the Thor is reporting via ethtool.
If I connect J4-3 to an Nvidia 10G media converter, it also never shows a link established on the T1 side when I pull up its serial console.
Link Status: BASE-T1 BASE-T
DOWN 10G
When I connect it to J1-4 (which goes through a Realtek switch) it does report a link.
10Gs 10G
Questions:
- Can you confirm mgbe0_0 is supposed to be on connector J4-3?
- Is there a known issue with mgbe0_0 and driveos 7.0.3?
- Are there any working examples or anecdotes that use mgbe0_0 for anything?
Thank you for your assistance.
edit: MIxed up the TS2/TS3 layouts that moved the mgbe0 port from J4-4 to J4-3. I have the SKU 12 dev kit (DC powered version).
