How to directly connect two orins via 10G-BASE-T1(mebe0_0) with H-MTD lines?
Software Version
DRIVE OS 6.0.5
DRIVE OS 6.0.4 (rev. 1)
DRIVE OS 6.0.4 SDK
[√] other DRIVE OS 6.0.3
Target Operating System
[√] Linux
QNX
other
Hardware Platform
[√] DRIVE AGX Orin Developer Kit (not sure its number)
other
SDK Manager Version
1.9.0.10816
[√] other
Host Machine Version
[√] native Ubuntu Linux 20.04 Host installed with DRIVE OS Docker Containers
other
We have two driver orin kits orinA & orinB.
We want to connect orinA & orinB via 10G-BASE-T1(mebe0_0) with the H-MTD lines(28Gbps from Rosenberger), the purpose is to transmit a large amount of data.
The connectors are as follows:
1
The config and test step:
  1. orinA: sudo ifconfig mgbe0_0 192.168.10.28
  2. orinB: sudo ifconfig mgbe0_0 192.168.10.29
  3. orinA: ping 192.168.10.29
    we will get the failed report:
    From 192.168.10.28 icmp_seq=3 Destination Host Unreachable
Are there any other configurations that need to be set?
Dear @xiaolei.qin,
We are checking internally on connection details and update you.
There are two Ethernet ports on J2. @xiaolei.qin, did you connect the same port 1 with your cable?
Dual HMTD Connector J2
Port Connected to
1 Tegra MGBE0 Ethernet Controller
2 LAN7431 (PCIe Ethernet Controller)
orinA: ping 192.168.9.29
It should be ‘ping 192.168.10.29’.
Thanks for your replay.
Yes, I did “ping 192.168.10.29”, sorry for typing mistake(mebe0_0 should be mgbe0_0).
The cable’s connectors at both sides are the same(like the picture), so my connection:
orinA J2-Port1 — orinB J2-Port1 Tegra MGBE0
orinA J2-Port2 — orinB J2-Port2 LAN7431
I think the connection was correct, right?
Maybe I should config the role of mgbe0_0(eg: orinA: Primary, orinB:Secondary), but I didn’t know how to set it.
I think you should check the phy and link status first, such as ‘ethtool’. And also check any kernel log once you plug-in/out the cable.
Dear @xiaolei.qin,
Could you check below steps if it works.
Connect HMTD cable between 88Q4364 and validate the loopback
  • Make sure the FW is udpated to 7.1.8.
 cd /usr/lib/firmware/marvell_ethernet/88Q4364/
   ./flash_4364 --GetCurrentVersion mgbe0_0
   ./flash_4364 --Install mgbe0_0 Arc-7.1.8.fw.image-ARC_9KB_nvidia_Main_MSMode-GPIO_ID58_VER2031.nvm.bin
Flashing time is around 12 to 15 minutes
  • Reboot device and Test Steps to verify this REQ
    Step1> Connect both 88Q4384 port back to back on MGBE0 instance with HMTD cable.
    Step2> execute master on one Orin.
  • Use set_mode_4364 <master(1)/slave(0)> to set mode.
# set master mode on first orin
  ./set_mode_4364 mgbe0_0 1
# set slave on another Orin.
   ./set_mode_4364 mgbe0_0 0
# Assign static IP on both Orin boards.
   ifconfig mgbe0_0 192.168.1.1 up #Master Orin
   ifconfig mgbe0_0 192.168.1.2 up #Slave Orin
I used the ethtool checked Tegra MGBE0(mgbe0_0) & LAN7431(enP7p1s0).
Whether the cable is plugged in or not, the ethtool message is the same (link detected: yes), and the kernel has no message.
ethtool info:
nvidia@xa-155-9:~$ ethtool mgbe0_0
Settings for mgbe0_0:
  •    Supported ports: [ TP MII ]*
  •    Supported link modes:   Not reported*
  •    Supported pause frame use: Symmetric Receive-only*
  •    Supports auto-negotiation: Yes*
  •    Supported FEC modes: Not reported*
  •    Advertised link modes:  Not reported*
  •    Advertised pause frame use: No*
  •    Advertised auto-negotiation: Yes*
  •    Advertised FEC modes: Not reported*
  •    Speed: 10000Mb/s*
  •    Duplex: Full*
  •    Port: MII*
  •    PHYAD: 0*
  •    Transceiver: internal*
  •    Auto-negotiation: on*
Cannot get wake-on-lan settings: Operation not permitted
  •    Link detected: yes*
nvidia@xa-155-9:~$ ethtool enP7p1s0
Settings for enP7p1s0:
  •    Supported link modes:   1000baseT/Full*
  •    Advertised link modes:  1000baseT/Full*
  •    Advertised pause frame use: Symmetric Receive-only*
  •    Speed: 1000Mb/s*
  •    Duplex: Full*
  •    Port: MII*
  •    PHYAD: 3*
  •    Current message level: 0x00000137 (311)*
  •                           drv probe link ifdown ifup tx_queued*
Thanks for reply, I think this is the root cause.
But I still have some other questions:
1.Can I update the FW to 7.1.8 on DERIVER OS 6.0.3?
2.Where can I get the bin file: mgbe0_0 Arc-7.1.8.fw.image-ARC_9KB_nvidia_Main_MSMode-GPIO_ID58_VER2031.nvm.bin.
Now my FW version is 7.1.4.0.
3.I also want the LAN7431( enP7p1s0) working in this way, how to config it like mgbe0_0?
I got the FW 7.1.8 from DRIVE OS 6.0.5.
I did tests but still ping failed:
Test 1:
orinA: DRIVE OS 6.0.3, MGBE0 FW 7.1.8, set_mode_4364 mgbe0_0 1, IP: 192.168.10.10
orinB: DRIVE OS 6.0.3, MGBE0 FW 7.1.8, set_mode_4364 mgbe0_0 0, IP: 192.168.10.30
orinA: ping 192.168.10.30 , Unreachable
orinA||orinB: ifconfig mgbe0_0 , Rx packets 0
Test 2:
orinB: DRIVE OS 6.0.5, MGBE0 FW 7.1.8, set_mode_4364 mgbe0_0 0, IP: 192.168.10.30
orinB: ping 192.168.10.10 , Unreachable
There may be other configurations that need to be set.
or
Is there a hardware configuration strap option ?
Update the last status:
Finally, it works, I changed another cable then mgbe0 ping OK.
Dear @xiaolei.qin,
Glad to hear the issue is fixed. So, the steps in How to directly connect two orins via 10G-BASE-T1(mebe0_0) with H-MTD lines? - #6 by SivaRamaKrishnaNV are enough to fix the issue?
Hello @SivaRamaKrishnaNV,
I think the - #6 by SivaRamaKrishnaNV are enough to fix the issue.
Only one additional point: when we reboot the orin the commands "./set_mode_4364 mgbe0_0 1; ifconfig mgbe0_0 down/up " need to be set on master again.
I have one related issues:
1.How to config the master/slave role for enP7p1s0 " |LAN7431 (PCIe Ethernet Controller)|"?
Dear @xiaolei.qin,
Could you please file new topic for different issues?
I created the new topic:
How to set mode(master/slave) of network(enP7p1s0) 1G-BASE-T1?
We can close this topic.
