Units do not connect to any BaseT link on mgbe1_0
Software Version
DRIVE OS 6.0.6
DRIVE OS 6.0.5
DRIVE OS 6.0.4 (rev. 1)
DRIVE OS 6.0.4 SDK
other
Target Operating System
Linux
QNX
other
Hardware Platform
other
SDK Manager Version
1.9.3.10904
other
Host Machine Version
other
We have two Drive AGX Orin that failed.
The issue is: Units do not connect to any BaseT link on mgbe1_0. They might connect once on a cold boot. But on subsequent boots they will fail to link.
Serial numbers:
1425122009082
1425022019007
Dear @dli3,
Do you notice the same after re-flashing target?
Do you issue with other interfaces as well when connected via RJ45/Matenet/Quad(dual HMTD) ports?
Could you share below details when failed to connect
  1. Connection pictures
  2. ifconfig log
  3. Boot log
  4. dmesg log
The info you asked has been provided in an earlier ticket here: AQR113C PHY firmware update corrupted
ifconfig.rtf (5.5 KB)
@bmargosian2 Hi Brian, can you answer above question please?
I am the original creator of the AQR corrupt topic and yes I can confirm that we saw the linking issue before a firmware update was attempted.
Adding another confirmed fail, SN 1425022019126
As far as I know, you have previously reported the issue for three units, and their corresponding serial numbers are as follows:
1425122009082
1425022019007
1425022019126
Could you please refer to How to Identify System Part Number (P/N) and provide the part numbers (P/Ns) and serial numbers (S/Ns) pairs for all the affected units?
