Software Version
DRIVE OS 6.0.10.0
DRIVE OS 6.0.8.1
DRIVE OS 6.0.6
DRIVE OS 6.0.5
DRIVE OS 6.0.4 (rev. 1)
DRIVE OS 6.0.4 SDK
other
Target Operating System
Linux
QNX
other
Hardware Platform
other
SDK Manager Version
2.1.0
other
Host Machine Version
other
Issue Description
By using the in-box 1G NIC adapter, I am unable to connect/ping to DRIVE AGX Orin Developer Kit’s 10GbE, ½ H-MTD double, mgbe0_0, port. (I am successfully using the RJ-45/1000BASE-T and RJ-45/10GBASE-T ports without the adapter.)
Looking with ‘ethtool’ or with ‘ip addr’ I can see that mgbe0_0 shows Link Detected even when there are no cables connected to any of the ethernet ports.
- Should the in-box 1GbE NIC adapter work when connected to this 10GbE port, or do I need the 10GbE NIC adapter?
- Why is the link detected even when there is no cable is connected? Is this expected behavior? If not, how to correct the situation? (I assume this should be fixed before trying the 10G NIC adapter as well.)
Error String
< Please provide just the error messages here >
Logs
Provide logs in text box instead of image
Please paste the complete application log here. If there are multiple logs, please use multiple text box
