Low speed on mgbe1_0, 10GbE, 10GBASE-T port when running iperf
Software Version
DRIVE OS 6.0.10.0
DRIVE OS 6.0.8.1
DRIVE OS 6.0.6
DRIVE OS 6.0.5
DRIVE OS 6.0.4 (rev. 1)
DRIVE OS 6.0.4 SDK
other
Target Operating System
Linux
QNX
other
Hardware Platform
other
SDK Manager Version
2.1.0
other
Host Machine Version
other
Issue Description
I have two DRIVE AGX Orin developer kits. I connect them together with a couple of feet long CAT6 550MHz cable from RJ-45/10GBASE-T of one developer kit to RJ-45/10GBASE-T of another developer kit.
Host computer is connected to both developer kits to their micro-USB debug ports, and I am connected from host to both developer kits via minicom.
I have set IP addresses for both developer kits’ mgbe1_0 ports and can ping between the developer kits.
On one developer kits I set “iperf -s” to act as listening “server”.
One another developer kits I set “iperf -c [IP_ADDRESS_OF ABOVE_DEVKIT]”.
By running multiple tests, I get the bandwidth result of between 6.07…6.17Gps, which is well below the expected (closer to) 10Gbps rate.
I have also tried with other similar ethernet cables resulting to the same results.
Error String
< Please provide just the error messages here >
Logs
Provide logs in text box instead of image
Please paste the complete application log here. If there are multiple logs, please use multiple text box
Dear @sheinisuo ,
Are you using DRIVE AGX Orin devkit or any other platform? Could you share DRIVE OS release details?
Yes, this is with DRIVE AGX Orin devkit.
Right out the box, booted to Ubuntu 20.04.4 LTS.
Should this already have a version of DRIVE OS pre-installed? If so, how to check the version?
Does increasing MTU value of interface helps to increasing BW?
Any update on previous suggestion?
Please share the version details using cat /etc/nvidia/version-ubuntu-rootfs.txt.
Dear @sheinisuo ,
Could you confirm if increasing MTU helped to increase speed?
Dear @sheinisuo ,
Could you please provide any update for this issue?
