Unable to configure dual MTD connector for using 10g base-t1 or 1g base-t1
Software Version
DRIVE OS 6.0.10.0
DRIVE OS 6.0.8.1
DRIVE OS 6.0.6
DRIVE OS 6.0.5
DRIVE OS 6.0.4 (rev. 1)
DRIVE OS 6.0.4 SDK
other
Target Operating System
Linux
QNX
other
Hardware Platform
other
SDK Manager Version
2.1.0
other
Host Machine Version
other
Hello.
I’m trying to use the dual HMTD connector J2 which supports 10Gbase-T1 port (mgbe0_0) and LAN7431 (enp7p1s0)
on a Drive AGX Orin devkit.
I can’t get it to work, but I’m not sure what’s wrong. I found the instructions for updating the firmware: Marvel 88Q4364 PHY Firmware Update | NVIDIA Docs and upgraded it based on the document provided to latest version.
I’m trying to convert the connection to RJ45, and connect it to my host computer, just to check it works. I’m using the media converter that came with the devkit. I’ve assigned IP addresses on both the devkit and host computer, but I’m unable to ping in either direction.
Can you confirm can we use only the 1g interface using the convertor since it supports that mode, if so how do we configure it?
Dear @saurabh.sinalkar ,
It’s not working means, you are getting any IP on the interface?
Could you share the connection pictures and used commands in the setup.
Is your requirement to connect host and target using LAN and make ping to work?
I am able to connect it with 1G Base-T1i.e. LAN7431 (enp7p1s0) connector. But unable to connect with the 2nd port i.e.10Gbase-T1 port (mgbe0_0). Can you confirm how to configure it?
Are you using DRIVE AGX Orin 10GbE HMTD to RJ45 Adapter ?
No, I am using the 1GBE HMTD to RJ45 adapter.
It works only for 1GBe interface.
