DRIVE Orin network configuration for radar over QUAD HMDT ports
Software Version
DRIVE OS 6.0.10.0
DRIVE OS 6.0.8.1
DRIVE OS 6.0.6
DRIVE OS 6.0.5
DRIVE OS 6.0.4 (rev. 1)
DRIVE OS 6.0.4 SDK
other
Target Operating System
Linux
QNX
other
Hardware Platform
other
SDK Manager Version
2.1.0
other
Host Machine Version
other
Issue Description
Hello NVIDIA Team,
we currently have six radars successfully connected to its Matenet ports on the mgbe2_0 interface. We can see over tcpdump the expected multicasts of the radars.
We want to use two additional radars that we connected to two of the QUAD HMDT ports (e.g. Port 5 and 9 from Switch-2) on interface mgbe3_0. However, we do not receive any data from them.
When we connect a media converter to the port we can receive multicast messages sent to the same destination and port from it. We can also receive data sent from the radar over the same media converter.
Our current assumption is that the ports are configured to 1G-BASE-T1, while the radars only support 100M-BASE-T1.
Is there any way to downgrade the Mode/Speed of a specific port or an entire switch from 1G-BASE-T1 to 100M-BASE-T1? Or, do you perhaps have any other recommendations?
Let me check if it is feasible and get back to you.
we need to modify the Aurix FW for the HMTD 100M swith/phy configuration, which is not supported for devzone release and forum. Do you have any media converter which can convert to 100 Mbps? If so, could you give a try if it helps the case.
