Cannot load URDF model for MuSHR car in Isaac Gym. Are .dae/.obj files supported?
I am trying to import a URDF created for a (MuSHR)[https://mushr.io/] vehicle, but I get these errors:
[Error] [carb.gym.plugin] Failed to resolve collision mesh 'package://mushr_description/meshes/base/tx2/mushr_base_tx2_collision.dae'
[Error] [carb.gym.plugin] Failed to resolve visual mesh 'package://mushr_description/meshes/base/tx2/mushr_base_tx2.dae'
[Error] [carb.gym.plugin] Failed to resolve collision mesh 'package://mushr_description/meshes/base/mushr_wheel_collision.obj'
[Error] [carb.gym.plugin] Failed to resolve visual mesh 'package://mushr_description/meshes/base/mushr_wheel.obj'
[Error] [carb.gym.plugin] Failed to resolve collision mesh 'package://mushr_description/meshes/sensors/mushr_ydlidar_collision.obj'
[Error] [carb.gym.plugin] Failed to resolve visual mesh 'package://mushr_description/meshes/sensors/mushr_ydlidar.obj'
[Error] [carb.gym.plugin] Failed to resolve visual mesh 'package://realsense2_description/meshes/d435.dae'
I have tried generating the URDF files using both DAE and OBJ meshes, but I get the same errors regardless. I can load both of these URDF files in RVIZ, but not on Isaac Gym. Am I missing something?
I am attaching both of these URDF files below. My original meshes and Xacro files come from this repo: mushr/mushr_description at master · prl-mushr/mushr · GitHub. I am using the mushr_tx2.urdf.xacro file to generate my URDF files.
mushr.urdf (8.9 KB)
mushr_obj.urdf (8.9 KB)
Hi
Only .dae and .obj files are supported.
If you don’t do the same as the sample, it shouldn’t work.
# Copyright (c) 2018-2021, NVIDIA Corporation
# All rights reserved.
# Redistribution and use in source and binary forms, with or without
# modification, are permitted provided that the following conditions are met:
# 1. Redistributions of source code must retain the above copyright notice, this
#    list of conditions and the following disclaimer.
# 2. Redistributions in binary form must reproduce the above copyright notice,
#    this list of conditions and the following disclaimer in the documentation
#    and/or other materials provided with the distribution.
# 3. Neither the name of the copyright holder nor the names of its
#    contributors may be used to endorse or promote products derived from
#    this software without specific prior written permission.
# THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
# AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
# IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE
# DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT HOLDER OR CONTRIBUTORS BE LIABLE
# FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL
# DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR
# SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER
# CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY,
# OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE
# OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
import numpy as np
import os
import torch
from isaacgym import gymutil, gymtorch, gymapi
from isaacgym.torch_utils import *
from tasks.base.vec_task import VecTask
class FrankaCabinet(VecTask):
    def __init__(self, cfg, sim_device, graphics_device_id, headless):
        self.cfg = cfg
        self.max_episode_length = self.cfg["env"]["episodeLength"]
        self.action_scale = self.cfg["env"]["actionScale"]
        self.start_position_noise = self.cfg["env"]["startPositionNoise"]
        self.start_rotation_noise = self.cfg["env"]["startRotationNoise"]
        self.num_props = self.cfg["env"]["numProps"]
        self.aggregate_mode = self.cfg["env"]["aggregateMode"]
        self.dof_vel_scale = self.cfg["env"]["dofVelocityScale"]
        self.dist_reward_scale = self.cfg["env"]["distRewardScale"]
        self.rot_reward_scale = self.cfg["env"]["rotRewardScale"]
        self.around_handle_reward_scale = self.cfg["env"]["aroundHandleRewardScale"]
        self.open_reward_scale = self.cfg["env"]["openRewardScale"]
        self.finger_dist_reward_scale = self.cfg["env"]["fingerDistRewardScale"]
        self.action_penalty_scale = self.cfg["env"]["actionPenaltyScale"]
        self.debug_viz = self.cfg["env"]["enableDebugVis"]
        self.up_axis = "z"
        self.up_axis_idx = 2
        self.distX_offset = 0.04
        self.dt = 1/60.
        # prop dimensions
        self.prop_width = 0.08
        self.prop_height = 0.08
        self.prop_length = 0.08
        self.prop_spacing = 0.09
        num_obs = 23
        num_acts = 9
        self.cfg["env"]["numObservations"] = 23
        self.cfg["env"]["numActions"] = 9
        super().__init__(config=self.cfg, sim_device=sim_device,
                         graphics_device_id=graphics_device_id, headless=headless)
        # get gym GPU state tensors
        actor_root_state_tensor = self.gym.acquire_actor_root_state_tensor(
            self.sim)
        dof_state_tensor = self.gym.acquire_dof_state_tensor(self.sim)
        rigid_body_tensor = self.gym.acquire_rigid_body_state_tensor(self.sim)
        self.gym.refresh_actor_root_state_tensor(self.sim)
        self.gym.refresh_dof_state_tensor(self.sim)
        self.gym.refresh_rigid_body_state_tensor(self.sim)
        # create some wrapper tensors for different slices
        self.franka_default_dof_pos = to_torch(
            [1.157, -1.066, -0.155, -2.239, -1.841, 1.003, 0.469, 0.035, 0.035], device=self.device)
        self.dof_state = gymtorch.wrap_tensor(dof_state_tensor)
        self.franka_dof_state = self.dof_state.view(
            self.num_envs, -1, 2)[:, :self.num_franka_dofs]
        self.franka_dof_pos = self.franka_dof_state[..., 0]
        self.franka_dof_vel = self.franka_dof_state[..., 1]
        self.cabinet_dof_state = self.dof_state.view(
            self.num_envs, -1, 2)[:, self.num_franka_dofs:]
        self.cabinet_dof_pos = self.cabinet_dof_state[..., 0]
        self.cabinet_dof_vel = self.cabinet_dof_state[..., 1]
        self.rigid_body_states = gymtorch.wrap_tensor(
            rigid_body_tensor).view(self.num_envs, -1, 13)
        self.num_bodies = self.rigid_body_states.shape[1]
        self.root_state_tensor = gymtorch.wrap_tensor(
            actor_root_state_tensor).view(self.num_envs, -1, 13)
        if self.num_props > 0:
            self.prop_states = self.root_state_tensor[:, 2:]
        self.num_dofs = self.gym.get_sim_dof_count(self.sim) // self.num_envs
        self.franka_dof_targets = torch.zeros(
            (self.num_envs, self.num_dofs), dtype=torch.float, device=self.device)
        self.global_indices = torch.arange(
            self.num_envs * (2 + self.num_props), dtype=torch.int32, device=self.device).view(self.num_envs, -1)
        self.reset_idx(torch.arange(self.num_envs, device=self.device))
    def create_sim(self):
        self.sim_params.up_axis = gymapi.UP_AXIS_Z
        self.sim_params.gravity.x = 0
        self.sim_params.gravity.y = 0
        self.sim_params.gravity.z = -9.81
        self.sim = super().create_sim(
            self.device_id, self.graphics_device_id, self.physics_engine, self.sim_params)
        self._create_ground_plane()
        self._create_envs(
            self.num_envs, self.cfg["env"]['envSpacing'], int(np.sqrt(self.num_envs)))
    def _create_ground_plane(self):
        plane_params = gymapi.PlaneParams()
        plane_params.normal = gymapi.Vec3(0.0, 0.0, 1.0)
        self.gym.add_ground(self.sim, plane_params)
    def _create_envs(self, num_envs, spacing, num_per_row):
        lower = gymapi.Vec3(-spacing, -spacing, 0.0)
        upper = gymapi.Vec3(spacing, spacing, spacing)
        asset_root = os.path.join(os.path.dirname(
            os.path.abspath(__file__)), "../../assets")
        franka_asset_file = "urdf/franka_description/robots/franka_panda.urdf"
        cabinet_asset_file = "urdf/sektion_cabinet_model/urdf/sektion_cabinet_2.urdf"
        if "asset" in self.cfg["env"]:
            asset_root = os.path.join(os.path.dirname(os.path.abspath(
                __file__)), self.cfg["env"]["asset"].get("assetRoot", asset_root))
            franka_asset_file = self.cfg["env"]["asset"].get(
                "assetFileNameFranka", franka_asset_file)
            cabinet_asset_file = self.cfg["env"]["asset"].get(
                "assetFileNameCabinet", cabinet_asset_file)
        # load franka asset
        asset_options = gymapi.AssetOptions()
        asset_options.flip_visual_attachments = True
        asset_options.fix_base_link = True
        asset_options.collapse_fixed_joints = True
        asset_options.disable_gravity = True
        asset_options.thickness = 0.001
        asset_options.default_dof_drive_mode = gymapi.DOF_MODE_POS
        asset_options.use_mesh_materials = True
        franka_asset = self.gym.load_asset(
            self.sim, asset_root, franka_asset_file, asset_options)
        # load cabinet asset
        asset_options.flip_visual_attachments = False
        asset_options.disable_gravity = False
        asset_options.default_dof_drive_mode = gymapi.DOF_MODE_NONE
        asset_options.armature = 0.005
        cabinet_asset = self.gym.load_asset(
            self.sim, asset_root, cabinet_asset_file, asset_options)
        franka_dof_stiffness = to_torch(
            [400, 400, 400, 400, 400, 400, 400, 1.0e6, 1.0e6], dtype=torch.float, device=self.device)
        franka_dof_damping = to_torch(
            [80, 80, 80, 80, 80, 80, 80, 1.0e2, 1.0e2], dtype=torch.float, device=self.device)
        self.num_franka_bodies = self.gym.get_asset_rigid_body_count(
            franka_asset)
        self.num_franka_dofs = self.gym.get_asset_dof_count(franka_asset)
        self.num_cabinet_bodies = self.gym.get_asset_rigid_body_count(
            cabinet_asset)
        self.num_cabinet_dofs = self.gym.get_asset_dof_count(cabinet_asset)
        print("num franka bodies: ", self.num_franka_bodies)
        print("num franka dofs: ", self.num_franka_dofs)
        print("num cabinet bodies: ", self.num_cabinet_bodies)
        print("num cabinet dofs: ", self.num_cabinet_dofs)
        # set franka dof properties
        franka_dof_props = self.gym.get_asset_dof_properties(franka_asset)
        self.franka_dof_lower_limits = []
        self.franka_dof_upper_limits = []
        for i in range(self.num_franka_dofs):
            franka_dof_props['driveMode'][i] = gymapi.DOF_MODE_POS
            if self.physics_engine == gymapi.SIM_PHYSX:
                franka_dof_props['stiffness'][i] = franka_dof_stiffness[i]
                franka_dof_props['damping'][i] = franka_dof_damping[i]
            else:
                franka_dof_props['stiffness'][i] = 7000.0
                franka_dof_props['damping'][i] = 50.0
            self.franka_dof_lower_limits.append(franka_dof_props['lower'][i])
            self.franka_dof_upper_limits.append(franka_dof_props['upper'][i])
        self.franka_dof_lower_limits = to_torch(
            self.franka_dof_lower_limits, device=self.device)
        self.franka_dof_upper_limits = to_torch(
            self.franka_dof_upper_limits, device=self.device)
        self.franka_dof_speed_scales = torch.ones_like(
            self.franka_dof_lower_limits)
        self.franka_dof_speed_scales[[7, 8]] = 0.1
        franka_dof_props['effort'][7] = 200
        franka_dof_props['effort'][8] = 200
        # set cabinet dof properties
        cabinet_dof_props = self.gym.get_asset_dof_properties(cabinet_asset)
        for i in range(self.num_cabinet_dofs):
            cabinet_dof_props['damping'][i] = 10.0
        # create prop assets
        box_opts = gymapi.AssetOptions()
        box_opts.density = 400
        prop_asset = self.gym.create_box(
            self.sim, self.prop_width, self.prop_height, self.prop_width, box_opts)
        franka_start_pose = gymapi.Transform()
        franka_start_pose.p = gymapi.Vec3(1.0, 0.0, 0.0)
        franka_start_pose.r = gymapi.Quat(0.0, 0.0, 1.0, 0.0)
        cabinet_start_pose = gymapi.Transform()
        cabinet_start_pose.p = gymapi.Vec3(
            *get_axis_params(0.4, self.up_axis_idx))
        # compute aggregate size
        num_franka_bodies = self.gym.get_asset_rigid_body_count(franka_asset)
        num_franka_shapes = self.gym.get_asset_rigid_shape_count(franka_asset)
        num_cabinet_bodies = self.gym.get_asset_rigid_body_count(cabinet_asset)
        num_cabinet_shapes = self.gym.get_asset_rigid_shape_count(
            cabinet_asset)
        num_prop_bodies = self.gym.get_asset_rigid_body_count(prop_asset)
        num_prop_shapes = self.gym.get_asset_rigid_shape_count(prop_asset)
        max_agg_bodies = num_franka_bodies + \
            num_cabinet_bodies + self.num_props * num_prop_bodies
        max_agg_shapes = num_franka_shapes + \
            num_cabinet_shapes + self.num_props * num_prop_shapes
        self.frankas = []
        self.cabinets = []
        self.default_prop_states = []
        self.prop_start = []
        self.envs = []
        for i in range(self.num_envs):
            # create env instance
            env_ptr = self.gym.create_env(
                self.sim, lower, upper, num_per_row
            if self.aggregate_mode >= 3:
                self.gym.begin_aggregate(
                    env_ptr, max_agg_bodies, max_agg_shapes, True)
            franka_actor = self.gym.create_actor(
                env_ptr, franka_asset, franka_start_pose, "franka", i, 1, 0)
            self.gym.set_actor_dof_properties(
                env_ptr, franka_actor, franka_dof_props)
            if self.aggregate_mode == 2:
            cabinet_pose = cabinet_start_pose
            cabinet_pose.p.x += self.start_position_noise * \
                (np.random.rand() - 0.5)
            dz = 0.5 * np.random.rand()
            dy = np.random.rand() - 0.5
            cabinet_pose.p.y += self.start_position_noise * dy
            cabinet_pose.p.z += self.start_position_noise * dz
            cabinet_actor = self.gym.create_actor(
                env_ptr, cabinet_asset, cabinet_pose, "cabinet", i, 2, 0)
                env_ptr, cabinet_actor, cabinet_dof_props)
            if self.aggregate_mode == 1:
                self.prop_start.append(self.gym.get_sim_actor_count(self.sim))
                drawer_handle = self.gym.find_actor_rigid_body_handle(
                    env_ptr, cabinet_actor, "drawer_top")
                drawer_pose = self.gym.get_rigid_transform(
                    env_ptr, drawer_handle)
                props_per_row = int(np.ceil(np.sqrt(self.num_props)))
                xmin = -0.5 * self.prop_spacing * (props_per_row - 1)
                yzmin = -0.5 * self.prop_spacing * (props_per_row - 1)
                prop_count = 0
                for j in range(props_per_row):
                    prop_up = yzmin + j * self.prop_spacing
                    for k in range(props_per_row):
                        if prop_count >= self.num_props:
                            break
                        propx = xmin + k * self.prop_spacing
                        prop_state_pose = gymapi.Transform()
                        prop_state_pose.p.x = drawer_pose.p.x + propx
                        propz, propy = 0, prop_up
                        prop_state_pose.p.y = drawer_pose.p.y + propy
                        prop_state_pose.p.z = drawer_pose.p.z + propz
                        prop_state_pose.r = gymapi.Quat(0, 0, 0, 1)
                        prop_handle = self.gym.create_actor(
                            env_ptr, prop_asset, prop_state_pose, "prop{}".format(prop_count), i, 0, 0)
                        prop_count += 1
                        prop_idx = j * props_per_row + k
                        self.default_prop_states.append([prop_state_pose.p.x, prop_state_pose.p.y, prop_state_pose.p.z,
                                                         prop_state_pose.r.x, prop_state_pose.r.y, prop_state_pose.r.z, prop_state_pose.r.w,
                                                         0, 0, 0, 0, 0, 0])
            if self.aggregate_mode > 0:
                self.gym.end_aggregate(env_ptr)
            self.envs.append(env_ptr)
            self.frankas.append(franka_actor)
            self.cabinets.append(cabinet_actor)
        self.hand_handle = self.gym.find_actor_rigid_body_handle(
            env_ptr, franka_actor, "panda_link7")
        self.drawer_handle = self.gym.find_actor_rigid_body_handle(
        self.lfinger_handle = self.gym.find_actor_rigid_body_handle(
            env_ptr, franka_actor, "panda_leftfinger")
        self.rfinger_handle = self.gym.find_actor_rigid_body_handle(
            env_ptr, franka_actor, "panda_rightfinger")
        self.default_prop_states = to_torch(
            self.default_prop_states, device=self.device, dtype=torch.float).view(self.num_envs, self.num_props, 13)
        self.init_data()
    def init_data(self):
        hand = self.gym.find_actor_rigid_body_handle(
            self.envs[0], self.frankas[0], "panda_link7")
        lfinger = self.gym.find_actor_rigid_body_handle(
            self.envs[0], self.frankas[0], "panda_leftfinger")
        rfinger = self.gym.find_actor_rigid_body_handle(
            self.envs[0], self.frankas[0], "panda_rightfinger")
        hand_pose = self.gym.get_rigid_transform(self.envs[0], hand)
        lfinger_pose = self.gym.get_rigid_transform(self.envs[0], lfinger)
        rfinger_pose = self.gym.get_rigid_transform(self.envs[0], rfinger)
        finger_pose = gymapi.Transform()
        finger_pose.p = (lfinger_pose.p + rfinger_pose.p) * 0.5
        finger_pose.r = lfinger_pose.r
        hand_pose_inv = hand_pose.inverse()
        grasp_pose_axis = 1
        franka_local_grasp_pose = hand_pose_inv * finger_pose
        franka_local_grasp_pose.p += gymapi.Vec3(
            *get_axis_params(0.04, grasp_pose_axis))
        self.franka_local_grasp_pos = to_torch([franka_local_grasp_pose.p.x, franka_local_grasp_pose.p.y,
                                                franka_local_grasp_pose.p.z], device=self.device).repeat((self.num_envs, 1))
        self.franka_local_grasp_rot = to_torch([franka_local_grasp_pose.r.x, franka_local_grasp_pose.r.y,
                                                franka_local_grasp_pose.r.z, franka_local_grasp_pose.r.w], device=self.device).repeat((self.num_envs, 1))
        drawer_local_grasp_pose = gymapi.Transform()
        drawer_local_grasp_pose.p = gymapi.Vec3(
            *get_axis_params(0.01, grasp_pose_axis, 0.3))
        drawer_local_grasp_pose.r = gymapi.Quat(0, 0, 0, 1)
        self.drawer_local_grasp_pos = to_torch([drawer_local_grasp_pose.p.x, drawer_local_grasp_pose.p.y,
                                                drawer_local_grasp_pose.p.z], device=self.device).repeat((self.num_envs, 1))
        self.drawer_local_grasp_rot = to_torch([drawer_local_grasp_pose.r.x, drawer_local_grasp_pose.r.y,
                                                drawer_local_grasp_pose.r.z, drawer_local_grasp_pose.r.w], device=self.device).repeat((self.num_envs, 1))
        self.gripper_forward_axis = to_torch(
            [0, 0, 1], device=self.device).repeat((self.num_envs, 1))
        self.drawer_inward_axis = to_torch(
            [-1, 0, 0], device=self.device).repeat((self.num_envs, 1))
        self.gripper_up_axis = to_torch(
            [0, 1, 0], device=self.device).repeat((self.num_envs, 1))
        self.drawer_up_axis = to_torch(
        self.franka_grasp_pos = torch.zeros_like(self.franka_local_grasp_pos)
        self.franka_grasp_rot = torch.zeros_like(self.franka_local_grasp_rot)
        self.franka_grasp_rot[..., -1] = 1  # xyzw
        self.drawer_grasp_pos = torch.zeros_like(self.drawer_local_grasp_pos)
        self.drawer_grasp_rot = torch.zeros_like(self.drawer_local_grasp_rot)
        self.drawer_grasp_rot[..., -1] = 1
        self.franka_lfinger_pos = torch.zeros_like(self.franka_local_grasp_pos)
        self.franka_rfinger_pos = torch.zeros_like(self.franka_local_grasp_pos)
        self.franka_lfinger_rot = torch.zeros_like(self.franka_local_grasp_rot)
        self.franka_rfinger_rot = torch.zeros_like(self.franka_local_grasp_rot)
    def compute_reward(self, actions):
        self.rew_buf[:], self.reset_buf[:] = compute_franka_reward(
            self.reset_buf, self.progress_buf, self.actions, self.cabinet_dof_pos,
            self.franka_grasp_pos, self.drawer_grasp_pos, self.franka_grasp_rot, self.drawer_grasp_rot,
            self.franka_lfinger_pos, self.franka_rfinger_pos,
            self.gripper_forward_axis, self.drawer_inward_axis, self.gripper_up_axis, self.drawer_up_axis,
            self.num_envs, self.dist_reward_scale, self.rot_reward_scale, self.around_handle_reward_scale, self.open_reward_scale,
            self.finger_dist_reward_scale, self.action_penalty_scale, self.distX_offset, self.max_episode_length
        # print("rew: ", self.rew_buf[0])
        # print("res: ", self.reset_buf[0])
    def compute_observations(self):
        hand_pos = self.rigid_body_states[:, self.hand_handle][:, 0:3]
        hand_rot = self.rigid_body_states[:, self.hand_handle][:, 3:7]
        drawer_pos = self.rigid_body_states[:, self.drawer_handle][:, 0:3]
        drawer_rot = self.rigid_body_states[:, self.drawer_handle][:, 3:7]
        self.franka_grasp_rot[:], self.franka_grasp_pos[:], self.drawer_grasp_rot[:], self.drawer_grasp_pos[:] = \
            compute_grasp_transforms(hand_rot, hand_pos, self.franka_local_grasp_rot, self.franka_local_grasp_pos,
                                     drawer_rot, drawer_pos, self.drawer_local_grasp_rot, self.drawer_local_grasp_pos
        self.franka_lfinger_pos = self.rigid_body_states[:,
                                                         self.lfinger_handle][:, 0:3]
        self.franka_rfinger_pos = self.rigid_body_states[:,
                                                         self.rfinger_handle][:, 0:3]
        self.franka_lfinger_rot = self.rigid_body_states[:,
                                                         self.lfinger_handle][:, 3:7]
        self.franka_rfinger_rot = self.rigid_body_states[:,
                                                         self.rfinger_handle][:, 3:7]
        dof_pos_scaled = (2.0 * (self.franka_dof_pos - self.franka_dof_lower_limits)
                          / (self.franka_dof_upper_limits - self.franka_dof_lower_limits) - 1.0)
        to_target = self.drawer_grasp_pos - self.franka_grasp_pos
        self.obs_buf = torch.cat((dof_pos_scaled, self.franka_dof_vel * self.dof_vel_scale, to_target,
                                  self.cabinet_dof_pos[:, 3].unsqueeze(-1), self.cabinet_dof_vel[:, 3].unsqueeze(-1)), dim=-1)
        return self.obs_buf
    def reset_idx(self, env_ids):
        env_ids_int32 = env_ids.to(dtype=torch.int32)
        # reset franka
        pos = tensor_clamp(
            self.franka_default_dof_pos.unsqueeze(
                0) + 0.25 * (torch.rand((len(env_ids), self.num_franka_dofs), device=self.device) - 0.5),
            self.franka_dof_lower_limits, self.franka_dof_upper_limits)
        self.franka_dof_pos[env_ids, :] = pos
        self.franka_dof_vel[env_ids, :] = torch.zeros_like(
            self.franka_dof_vel[env_ids])
        self.franka_dof_targets[env_ids, :self.num_franka_dofs] = pos
        # reset cabinet
        self.cabinet_dof_state[env_ids, :] = torch.zeros_like(
            self.cabinet_dof_state[env_ids])
        # reset props
            prop_indices = self.global_indices[env_ids, 2:].flatten()
            self.prop_states[env_ids] = self.default_prop_states[env_ids]
            self.gym.set_actor_root_state_tensor_indexed(self.sim,
                                                         gymtorch.unwrap_tensor(
                                                             self.root_state_tensor),
                                                         gymtorch.unwrap_tensor(prop_indices), len(prop_indices))
        multi_env_ids_int32 = self.global_indices[env_ids, :2].flatten()
        self.gym.set_dof_position_target_tensor_indexed(self.sim,
                                                            self.franka_dof_targets),
                                                        gymtorch.unwrap_tensor(multi_env_ids_int32), len(multi_env_ids_int32))
        self.gym.set_dof_state_tensor_indexed(self.sim,
                                                  self.dof_state),
        self.progress_buf[env_ids] = 0
        self.reset_buf[env_ids] = 0
    def pre_physics_step(self, actions):
        self.actions = actions.clone().to(self.device)
        targets = self.franka_dof_targets[:, :self.num_franka_dofs] + \
            self.franka_dof_speed_scales * self.dt * self.actions * self.action_scale
        self.franka_dof_targets[:, :self.num_franka_dofs] = tensor_clamp(
            targets, self.franka_dof_lower_limits, self.franka_dof_upper_limits)
        env_ids_int32 = torch.arange(
            self.num_envs, dtype=torch.int32, device=self.device)
        self.gym.set_dof_position_target_tensor(self.sim,
                                                gymtorch.unwrap_tensor(self.franka_dof_targets))
    def post_physics_step(self):
        self.progress_buf += 1
        env_ids = self.reset_buf.nonzero(as_tuple=False).squeeze(-1)
        if len(env_ids) > 0:
            self.reset_idx(env_ids)
        self.compute_observations()
        self.compute_reward(self.actions)
        # debug viz
        if self.viewer and self.debug_viz:
            self.gym.clear_lines(self.viewer)
                px = (self.franka_grasp_pos[i] + quat_apply(self.franka_grasp_rot[i], to_torch(
                    [1, 0, 0], device=self.device) * 0.2)).cpu().numpy()
                py = (self.franka_grasp_pos[i] + quat_apply(self.franka_grasp_rot[i], to_torch(
                    [0, 1, 0], device=self.device) * 0.2)).cpu().numpy()
                pz = (self.franka_grasp_pos[i] + quat_apply(self.franka_grasp_rot[i], to_torch(
                    [0, 0, 1], device=self.device) * 0.2)).cpu().numpy()
                p0 = self.franka_grasp_pos[i].cpu().numpy()
                self.gym.add_lines(self.viewer, self.envs[i], 1, [
                                   p0[0], p0[1], p0[2], px[0], px[1], px[2]], [0.85, 0.1, 0.1])
                                   p0[0], p0[1], p0[2], py[0], py[1], py[2]], [0.1, 0.85, 0.1])
                                   p0[0], p0[1], p0[2], pz[0], pz[1], pz[2]], [0.1, 0.1, 0.85])
                px = (self.drawer_grasp_pos[i] + quat_apply(self.drawer_grasp_rot[i], to_torch(
                py = (self.drawer_grasp_pos[i] + quat_apply(self.drawer_grasp_rot[i], to_torch(
                pz = (self.drawer_grasp_pos[i] + quat_apply(self.drawer_grasp_rot[i], to_torch(
                p0 = self.drawer_grasp_pos[i].cpu().numpy()
                                   p0[0], p0[1], p0[2], px[0], px[1], px[2]], [1, 0, 0])
                                   p0[0], p0[1], p0[2], py[0], py[1], py[2]], [0, 1, 0])
                                   p0[0], p0[1], p0[2], pz[0], pz[1], pz[2]], [0, 0, 1])
                px = (self.franka_lfinger_pos[i] + quat_apply(self.franka_lfinger_rot[i], to_torch(
                py = (self.franka_lfinger_pos[i] + quat_apply(self.franka_lfinger_rot[i], to_torch(
                pz = (self.franka_lfinger_pos[i] + quat_apply(self.franka_lfinger_rot[i], to_torch(
                p0 = self.franka_lfinger_pos[i].cpu().numpy()
                px = (self.franka_rfinger_pos[i] + quat_apply(self.franka_rfinger_rot[i], to_torch(
                py = (self.franka_rfinger_pos[i] + quat_apply(self.franka_rfinger_rot[i], to_torch(
                pz = (self.franka_rfinger_pos[i] + quat_apply(self.franka_rfinger_rot[i], to_torch(
                p0 = self.franka_rfinger_pos[i].cpu().numpy()
###=========================jit functions=========================###
@torch.jit.script
def compute_franka_reward(
    reset_buf, progress_buf, actions, cabinet_dof_pos,
    franka_grasp_pos, drawer_grasp_pos, franka_grasp_rot, drawer_grasp_rot,
    franka_lfinger_pos, franka_rfinger_pos,
    gripper_forward_axis, drawer_inward_axis, gripper_up_axis, drawer_up_axis,
    num_envs, dist_reward_scale, rot_reward_scale, around_handle_reward_scale, open_reward_scale,
    finger_dist_reward_scale, action_penalty_scale, distX_offset, max_episode_length
    # type: (Tensor, Tensor, Tensor, Tensor, Tensor, Tensor, Tensor, Tensor, Tensor, Tensor, Tensor, Tensor, Tensor, Tensor, int, float, float, float, float, float, float, float, float) -> Tuple[Tensor, Tensor]
    # distance from hand to the drawer
    d = torch.norm(franka_grasp_pos - drawer_grasp_pos, p=2, dim=-1)
    dist_reward = 1.0 / (1.0 + d ** 2)
    dist_reward *= dist_reward
    dist_reward = torch.where(d <= 0.02, dist_reward * 2, dist_reward)
    axis1 = tf_vector(franka_grasp_rot, gripper_forward_axis)
    axis2 = tf_vector(drawer_grasp_rot, drawer_inward_axis)
    axis3 = tf_vector(franka_grasp_rot, gripper_up_axis)
    axis4 = tf_vector(drawer_grasp_rot, drawer_up_axis)
    dot1 = torch.bmm(axis1.view(num_envs, 1, 3), axis2.view(
        num_envs, 3, 1)).squeeze(-1).squeeze(-1)  # alignment of forward axis for gripper
    dot2 = torch.bmm(axis3.view(num_envs, 1, 3), axis4.view(
        num_envs, 3, 1)).squeeze(-1).squeeze(-1)  # alignment of up axis for gripper
    # reward for matching the orientation of the hand to the drawer (fingers wrapped)
    rot_reward = 0.5 * (torch.sign(dot1) * dot1 ** 2 +
                        torch.sign(dot2) * dot2 ** 2)
    # bonus if left finger is above the drawer handle and right below
    around_handle_reward = torch.zeros_like(rot_reward)
    around_handle_reward = torch.where(franka_lfinger_pos[:, 2] > drawer_grasp_pos[:, 2],
                                       torch.where(franka_rfinger_pos[:, 2] < drawer_grasp_pos[:, 2],
                                                   around_handle_reward + 0.5, around_handle_reward), around_handle_reward)
    # reward for distance of each finger from the drawer
    finger_dist_reward = torch.zeros_like(rot_reward)
    lfinger_dist = torch.abs(franka_lfinger_pos[:, 2] - drawer_grasp_pos[:, 2])
    rfinger_dist = torch.abs(franka_rfinger_pos[:, 2] - drawer_grasp_pos[:, 2])
    finger_dist_reward = torch.where(franka_lfinger_pos[:, 2] > drawer_grasp_pos[:, 2],
                                                 (0.04 - lfinger_dist) + (0.04 - rfinger_dist), finger_dist_reward), finger_dist_reward)
    # regularization on the actions (summed for each environment)
    action_penalty = torch.sum(actions ** 2, dim=-1)
    # how far the cabinet has been opened out
    # drawer_top_joint
    open_reward = cabinet_dof_pos[:, 3] * \
        around_handle_reward + cabinet_dof_pos[:, 3]
    rewards = dist_reward_scale * dist_reward + rot_reward_scale * rot_reward \
        + around_handle_reward_scale * around_handle_reward + open_reward_scale * open_reward \
        + finger_dist_reward_scale * finger_dist_reward - \
        action_penalty_scale * action_penalty
    # bonus for opening drawer properly
    rewards = torch.where(cabinet_dof_pos[:, 3] > 0.01, rewards + 0.5, rewards)
        cabinet_dof_pos[:, 3] > 0.2, rewards + around_handle_reward, rewards)
        cabinet_dof_pos[:, 3] > 0.39, rewards + (2.0 * around_handle_reward), rewards)
    # prevent bad style in opening drawer
    rewards = torch.where(franka_lfinger_pos[:, 0] < drawer_grasp_pos[:, 0] - distX_offset,
                          torch.ones_like(rewards) * -1, rewards)
    rewards = torch.where(franka_rfinger_pos[:, 0] < drawer_grasp_pos[:, 0] - distX_offset,
    # reset if drawer is open or max length reached
    reset_buf = torch.where(
        cabinet_dof_pos[:, 3] > 0.39, torch.ones_like(reset_buf), reset_buf)
        progress_buf >= max_episode_length - 1, torch.ones_like(reset_buf), reset_buf)
    return rewards, reset_buf
@torch.jit.script
def compute_grasp_transforms(hand_rot, hand_pos, franka_local_grasp_rot, franka_local_grasp_pos,
                             drawer_rot, drawer_pos, drawer_local_grasp_rot, drawer_local_grasp_pos
    # type: (Tensor, Tensor, Tensor, Tensor, Tensor, Tensor, Tensor, Tensor) -> Tuple[Tensor, Tensor, Tensor, Tensor]
    global_franka_rot, global_franka_pos = tf_combine(
        hand_rot, hand_pos, franka_local_grasp_rot, franka_local_grasp_pos)
    global_drawer_rot, global_drawer_pos = tf_combine(
        drawer_rot, drawer_pos, drawer_local_grasp_rot, drawer_local_grasp_pos)
    return global_franka_rot, global_franka_pos, global_drawer_rot, global_drawer_pos
Hi @mateo.guaman1998 ,
Both .dae and .obj should be supported. The errors you are seeing seem to be due to missing mesh files that the importer isn’t able to locate. Make sure the paths of the mesh files are valid from the root directory specified when you call load_asset(). I didn’t find them in your attached files.
