I am trying to run yolov8 and zed_mono_rect_depth to both detect objects and measure depth. When I try to include depth, I keep having to reset parameters in the config files that appear to be outdated. I was unable to update the parameter for object_detection.model. The program claims:
[component_container_mt-2] [WARN] [1763679385.686818939] [zed_node]: The value of the parameter ‘object_detection.model’ is not valid: ‘’. Stopping the node
In every config file that includes a model, the value is model: ‘MULTI_CLASS_BOX_MEDIUM’
This is the current value in the config file called by the launch file, but it is still claiming it is an empty string. It will not let me force a value to it when I run the command. How can I include depth when running the yolo model?
Welcome to the Isaac ROS forum, and thanks for your post!
Are you planning to use YOLOv8 or the ZED node for object detection? It looks like the zed_node is trying to run its own object detection model, which may conflict with YOLOv8. To avoid this, please disable the ZED object detection by setting object_detection.enable:=false in the ZED parameters (or pass --ros-args -p object_detection.enable:=false when launching). Then, launch the ZED node with depth enabled and run YOLOv8 using the rectified color image as input.
I attempted to set object_detection.enable to false by hard coding it as well as passing an argument to it, but it always keeps it at true regardless of what I do. It appears to be a bug that I cannot work around. This is the command I am running:
