In the install process, I can’t got the FLEXlm hostid.
The problem as follows:
Do you wish to generate license keys? (y/n) y
All PGI software is license-managed. This program will walk you through the
steps required to download and install your license keys. An active Internet
connection is required. If you don’t have an Internet connection, please see
the PGI Installation Guide that came with your software for alternatives on
generating and installing license keys.
You will need to know the following information.
- Does this computer access the Internet directly or through some sort of
proxy connection? - If a proxy is used, you’ll need the address (URL) of the proxy server.
- Does the proxy require authentication? If so, you’ll need to know the
username and password. - To login to the PGI website to generate license keys, you need either a
PGI web account (username and password) or a PIN code from the PGI order
confirmation email message from PGI Sales.
If this computer is behind a firewall at your site, please make sure it can
access the Internet.
1 Generate a license key for this computer
2 Configure and start a license server on this computer
3 All of the above
4 I’m not sure (quit now and re-run this script later,)
What do you want to do? 1
How does this computer access the Internet?
1 Direct Internet connection
2 Manual proxy configuration
3 Automatic proxy configuration
Answer? 1
Please enter your PGI account credentials.
PGI username: qweszxcrtygb@sjtu.edu.cn
PGI password (input will not be displayed):
ERROR: Curl failed with error = 0
The PGI license tool can be re-started by running the script located at
/opt/pgi/linux86/11.7/bin/pgi_license_tool.
Do you want the files in the install directory to be read-only? (y/n) y
Installation complete.
If you purchased a software subscription, please note that the ST support
services to you are limited to the terms described in the file
/opt/pgi/SUBSCRIPTION_SERVICE.
A copy of this file can also be found on the PGI website, at
http://www.pgroup.com/support/SUBSCRIPTION_SERVICE.
Please check the FAQ at FAQ | PGI for a current
listing of customer support concerns, including installation, use of PGI
software, and other questions or problems.
This product uses the STLport Standard Template Library for ANSI C++. The
STLport license can be found at STLport: License Agreement.
And then I type:
ifconfig
I got: HWaddr 00:19:B9:22:42:CB
But in the file of “license.info”, the FLEXnet hostid: 000000000000
I have used the “0019B92242CB” to generate a trial license, but it didn’t work, when type
pgf77 -V x.f
[root@localhost bin]# pgf77 -V x.f
pgf77 11.7-0 32-bit target on x86 Linux -tp core2
Copyright 1989-2000, The Portland Group, Inc. All Rights Reserved.
Copyright 2000-2011, STMicroelectronics, Inc. All Rights Reserved.
pgi-f77-lin32: LICENSE MANAGER PROBLEM: Failed to checkout license
