Casting Shadows on Gaussian Splats in Isaac Sim via Shadow Compositing — Need Feedback & Help
Context
I’m building a synthetic data generation pipeline combining Gaussian Splats with CAD models in Isaac Sim to reduce the sim-to-real gap. Since Gaussian Splats don’t natively receive shadows in the RTX renderer, I developed a shadow compositing approach.
My Pipeline
  1. RGB render — shadows disabled → base image
  2. White render — shadows enabled → shadow mask
  3. Multiply blend in OpenCV → final composite
Problem — Proxy Mesh & Custom Lights
I use a proxy mesh as the shadow caster for the Gaussian Splat.
  • Works correctly with the default dome light
  • Does not work with custom lights (Distant, Sphere, Rect), the proxy mesh renders black and leaks into the composite
Questions
  1. Is there a way to make the proxy mesh invisible to the camera but still cast shadows from custom lights?
  2. Is the black mesh issue a material problem with custom light types?
  3. Are there better approaches for a clean shadow-only pass?
Any suggestions are appreciated. Thanks!
Component Specification
CPU Intel Core i9-11900K
RAM 64 GB
GPU NVIDIA RTX A5000 Mobile (16 GB VRAM)
Isaac Sim Version 5.1.0
OS Windows
