CGF - Sample Sensor node Examples are available?
Software Version
[X] DRIVE OS 6.0.8.1
DRIVE OS 6.0.6
DRIVE OS 6.0.5
DRIVE OS 6.0.4 (rev. 1)
DRIVE OS 6.0.4 SDK
other
Target Operating System
[X] Linux
QNX
other
Hardware Platform
[X] DRIVE AGX Orin Developer Kit (940-63710-0010-300)
other
SDK Manager Version
1.9.3.10904
other
Host Machine Version
[X] native Ubuntu Linux 20.04 Host installed with DRIVE OS Docker Containers
other
Is there any example available to implement Sensor nodes in CGF 5.14?
We use custom sensor plugins to interface custom CAN based sensors, But I don’t see any specific guideline specific to sensor node implementation.
Please refer to the previous discussion:
Hi @VickNV,
I had read this discussion before raising new Request.
I am not sure in the proposed discussion is applicable to CGF 5.14 v?
If yes are you suggesting that “sample sensor node example” is not available nor any tutorial? In this case how one can use custom sensors with CGF?
Friendly Gentle reminder @VickNV @SivaRamaKrishnaNV
Dear @sushant.bahadure,
Yes. we don’t have any sample or tutorial demonstrating Adding sensors node.
So you could use custom CAN based sensor in DW and wants to check with CGF framework? If so, let me check with core team on how to help on this request and get back to you.
@SivaRamaKrishnaNV thank you for clarification, if I understand correctly.
I should create custom CAN based sensor with custom sensor plugin as process node?
Dear @sushant.bahadure ,
a sensor node is almost the same as a (process) node, it just implements the additional interface of ISensorNode . All the sensor nodes included in CGF framework have followed this pattern and tested. Implementing just process node may work as well.
