Hello! I want to change one pin to input pull none configuration.
On Linux for Jetson docs it says that I have to run some Python script from Jetson or something - is it possible to do it simply via the main .dts file (tegra186-p3636-0001-p3509-0000-a01.dts)?
I tried adding this to the end of my main .dts file, but it doesn’t work
pinmux@2430000 {
pinmux_default: common {
ts_int_active: ts-int-active {
nvidia,pins = "gpio_cam2_pn1";
nvidia,pull = <TEGRA_PIN_PULL_NONE>;
nvidia,tristate = <TEGRA_PIN_DISABLE>;
nvidia,enable-input = <TEGRA_PIN_ENABLE>;
status = "okay";
I don’t want to generate Excel stuff or anything - I want the simplest way to redefine one single pin.
