Cmake error: couldn't find tileiras_executable
DRIVE OS Version: 7.0.3
Issue Description: CMake configuring of samples fails, see log:
********** boot blob image CHAIN C ended **********
root@7.0.3.0-0010-linux-nsr:/drive/drive-foundation# cd ..
root@7.0.3.0-0010-linux-nsr:/drive# cd cuda-samples/
root@7.0.3.0-0010-linux-nsr:/drive/cuda-samples# cd b
bash: cd: b: No such file or directory
root@7.0.3.0-0010-linux-nsr:/drive/cuda-samples# cd build/
root@7.0.3.0-0010-linux-nsr:/drive/cuda-samples/build# ls
root@7.0.3.0-0010-linux-nsr:/drive/cuda-samples/build# cmake .. -DBUILD_TEGRA=True \
-DCMAKE_CUDA_COMPILER=/usr/local/cuda/bin/nvcc \
-DCMAKE_TOOLCHAIN_FILE=../cmake/toolchains/toolchain-aarch64-linux.cmake \
-DTARGET_FS=/drive/temp \
-DCMAKE_LIBRARY_PATH=/drive/temp/usr/local/cuda-12.8/thor/lib64/ \
-DCMAKE_INCLUDE_PATH=/drive/temp/usr/local/cuda-12.8/thor/include/
-- The C compiler identification is GNU 13.3.0
-- The CXX compiler identification is GNU 13.3.0
-- The CUDA compiler identification is NVIDIA 12.8.93
-- Detecting C compiler ABI info
-- Detecting C compiler ABI info - done
-- Check for working C compiler: /usr/bin/aarch64-linux-gnu-gcc - skipped
-- Detecting C compile features
-- Detecting C compile features - done
-- Detecting CXX compiler ABI info
-- Detecting CXX compiler ABI info - done
-- Check for working CXX compiler: /usr/bin/aarch64-linux-gnu-g++ - skipped
-- Detecting CXX compile features
-- Detecting CXX compile features - done
-- Detecting CUDA compiler ABI info
-- Detecting CUDA compiler ABI info - done
-- Check for working CUDA compiler: /usr/local/cuda/bin/nvcc - skipped
-- Detecting CUDA compile features
-- Detecting CUDA compile features - done
-- Found CUDAToolkit: /usr/local/cuda/targets/aarch64-linux/include (found version “12.8.93”)
-- Performing Test CMAKE_HAVE_LIBC_PTHREAD
-- Performing Test CMAKE_HAVE_LIBC_PTHREAD - Success
-- Found Threads: TRUE
CMake Warning at /usr/share/cmake-3.28/Modules/FindCUDAToolkit.cmake:1161 (message):
Could not find librt library, needed by CUDA::cudart_static
Call Stack (most recent call first):
CMakeLists.txt:5 (find_package)
-- CUDA Samples installation configured:
-- Architecture: aarch64
-- OS: linux
-- Build Type: release
-- Install Prefix: /drive/cuda-samples/build/bin
-- Install Directory: /drive/cuda-samples/build/bin/aarch64/linux/release
-- Found OpenMP_CXX: -fopenmp (found version “4.5”)
-- Found OpenMP: TRUE (found version “4.5”) found components: CXX
-- Found OpenMP_C: -fopenmp (found version “4.5”)
-- Could NOT find OpenGL (missing: OPENGL_opengl_LIBRARY OPENGL_glx_LIBRARY OPENGL_INCLUDE_DIR)
-- Could NOT find GLUT (missing: GLUT_glut_LIBRARY GLUT_INCLUDE_DIR)
-- OpenGL not found - will not build sample ‘simpleCUDA2GL’
-- Will not build sample simpleIPC - not supported on aarch64
-- Could NOT find MPI_C (missing: MPI_mpi_LIBRARY MPI_C_HEADER_DIR MPI_C_WORKS)
-- Could NOT find MPI_CXX (missing: MPI_mpi_cxx_LIBRARY MPI_mpi_LIBRARY MPI_CXX_HEADER_DIR MPI_CXX_WORKS)
-- Could NOT find MPI (missing: MPI_C_FOUND MPI_CXX_FOUND)
-- MPI not found - will not build sample ‘simpleMPI’
-- Will not build sample simpleP2P - not supported on aarch64
-- OpenGL not found - will not build sample ‘simpleTexture3D’
-- Will not build sample systemWideAtomics - not supported on aarch64
-- Will not build sample vectorAddMMAP - not supported on aarch64
-- Will not build sample topologyQuery - not supported on aarch64
-- Could NOT find EGL (missing: EGL_LIBRARY EGL_INCLUDE_DIR)
-- EGL not found - will not build sample ‘EGLStream_CUDA_CrossGPU’
-- EGL not found - will not build sample ‘EGLStream_CUDA_Interop’
-- OpenGL not found - will not build sample ‘FunctionPointers’
-- OpenGL not found - will not build sample ‘boxFilter’
-- OpenGL not found - will not build sample ‘imageDenoising’
-- OpenGL not found - will not build sample ‘particles’
-- Will not build sample streamOrderedAllocationIPC - not supported on aarch64
-- Will not build sample streamPriorities - not supported on aarch64
-- OpenGL not found - will not build sample ‘bindlessTexture’
-- Could NOT find FreeImage (missing: FreeImage_LIBRARY FreeImage_INCLUDE_DIR)
-- FreeImage not found - will not build sample ‘FilterBorderControlNPP’
-- FreeImage not found - will not build sample ‘boxFilterNPP’
-- FreeImage not found - will not build sample ‘cannyEdgeDetectorNPP’
-- CPM: Adding package CCCL@3.3.3 (v3.3.3)
-- Finding CCCL components: Thrust;CUB;libcudacxx
-- Found CUB: /drive/cuda-samples/build/_deps/cccl-src/lib/cmake/cub/cub-config.cmake (found suitable version “3.3.3.0”, minimum required is “3.3.3.0”)
-- libcudacxx: - Assuming CUDA host compiler is the same as CXX compiler.
-- libcudacxx: Set libcudacxx_MISMATCHED_HOST_COMPILER=TRUE to disable this.
-- Found libcudacxx: /drive/cuda-samples/build/_deps/cccl-src/lib/cmake/libcudacxx/libcudacxx-config.cmake (found suitable exact version “3.3.3.0”)
-- Found Thrust: /drive/cuda-samples/build/_deps/cccl-src/lib/cmake/thrust/thrust-config.cmake (found suitable exact version “3.3.3.0”)
-- Found CCCL: /drive/cuda-samples/build/_deps/cccl-src/lib/cmake/cccl/cccl-config.cmake (found version “3.3.3.0”)
-- Found libcudacxx: /drive/cuda-samples/build/_deps/cccl-src/lib/cmake/libcudacxx/libcudacxx-config.cmake (found version “3.3.3.0”)
-- Found CUB: /drive/cuda-samples/build/_deps/cccl-src/lib/cmake/cub/cub-config.cmake (found version “3.3.3.0”)
-- Found Thrust: /drive/cuda-samples/build/_deps/cccl-src/lib/cmake/thrust/thrust-config.cmake (found version “3.3.3.0”)
-- Could NOT find NVSCI (missing: NVSCIBUF_LIBRARY NVSCISYNC_LIBRARY NVSCIBUF_INCLUDE_DIR NVSCISYNC_INCLUDE_DIR)
-- NvSCI not found - will not build sample ‘cudaNvSci’
-- FreeImage not found - will not build sample ‘freeImageInteropNPP’
-- FreeImage not found - will not build sample ‘histEqualizationNPP’
-- CPM: Adding package dlpack@1.3 (v1.3)
-- Populating dlpack
-- Configuring done (0.0s)
-- Generating done (0.0s)
-- Build files have been written to: /drive/cuda-samples/build/_deps/dlpack-subbuild
[ 11%] Creating directories for ‘dlpack-populate’
[ 22%] Performing download step (git clone) for ‘dlpack-populate’
Cloning into ‘dlpack-src’
HEAD is now at 84d107b Update exchange API to be capsule following new convention (#180)
[ 33%] Performing update step for ‘dlpack-populate’
[ 44%] No patch step for ‘dlpack-populate’
[ 55%] No configure step for ‘dlpack-populate’
[ 66%] No build step for ‘dlpack-populate’
[ 77%] No install step for ‘dlpack-populate’
[ 88%] No test step for ‘dlpack-populate’
[100%] Completed ‘dlpack-populate’
[100%] Built target dlpack-populate
-- OpenGL not found - will not build sample ‘oceanFFT’
-- OpenGL not found - will not build sample ‘randomFog’
-- OpenGL not found - will not build sample ‘Mandelbrot’
-- OpenGL not found - will not build sample ‘SobelFilter’
-- OpenGL not found - will not build sample ‘bicubicTexture’
-- OpenGL not found - will not build sample ‘bilateralFilter’
-- OpenGL not found - will not build sample ‘fluidsGL’
-- OpenGL not found - will not build sample ‘marchingCubes’
-- OpenGL not found - will not build sample ‘nbody’
-- OpenGL not found - will not build sample ‘postProcessGL’
-- OpenGL not found - will not build sample ‘recursiveGaussian’
-- Sample ‘simpleD3D11’ is Windows-only - skipping
-- Sample ‘simpleD3D11Texture’ is Windows-only - skipping
-- Sample ‘simpleD3D12’ is Windows-only - skipping
-- OpenGL not found - will not build sample ‘simpleGL’
-- Could NOT find Vulkan (missing: Vulkan_LIBRARY Vulkan_INCLUDE_DIR) (found version “”)
-- Looking for GLFW/glfw3.h
-- Looking for GLFW/glfw3.h - not found
-- Vulkan not found - will not build sample ‘simpleVulkan’
-- Vulkan not found - will not build sample ‘simpleVulkanMMAP’
-- OpenGL not found - will not build sample ‘smokeParticles’
-- OpenGL not found - will not build sample ‘volumeFiltering’
-- OpenGL not found - will not build sample ‘volumeRender’
-- Vulkan not found - will not build sample ‘vulkanImageCUDA’
-- Using CUDA_HOME: /usr/local/cuda
-- Using CUDA_LIB: /usr/local/cuda/targets/aarch64-linux/lib/stubs/libcuda.so
-- Using LIBNVVM_HOME: LIBNVVM_HOME-NOTFOUND
-- Using libnvvm header: NVVM_H-NOTFOUND
-- Using libnvvm header path:
-- Using libnvvm library: NVVM_LIB-NOTFOUND
-- Using rpath:
-- Skipping the build of the cuda-c-linking sample.
-- NvSCI not found - will not build sample ‘cudaNvSciNvMedia’
-- NvSCI not found - will not build sample ‘cudaNvSciBufMultiplanar’
-- CUDLA not found - will not build sample ‘cuDLAErrorReporting’
-- CUDLA not found - will not build sample ‘cuDLAHybridMode’
-- CUDLA not found - will not build sample ‘cuDLALayerwiseStatsHybrid’
-- CUDLA not found - will not build sample ‘cuDLALayerwiseStatsStandalone’
-- CUDLA not found - will not build sample ‘cuDLAStandaloneMode’
-- Could NOT find X11 (missing: X11_X11_INCLUDE_PATH X11_X11_LIB)
-- OpenGL not found - will not build sample ‘EGLSync_CUDAEvent_Interop’
-- OpenGL not found - will not build sample ‘fluidsGLES’
-- OpenGL not found - will not build sample ‘nbody_opengles’
-- OpenGL not found - will not build sample ‘simpleGLES’
-- OpenGL not found - will not build sample ‘simpleGLES_EGLOutput’
CMake Error at cpp/9_CUDA_Tile/tileMatmulAutotuner/CMakeLists.txt:10 (find_program):
Could not find TILEIRAS_EXECUTABLE using the following names: tileiras
-- Configuring incomplete, errors occurred!
Dear @kevin.kolesiak ,
Could you please try pulling the CUDA 12.8 sample and check. Noticed CUDA tile sample is not part of CUDA 12.8 (cuda-samples/Samples at v12.8 · NVIDIA/cuda-samples · GitHub)
Could you please provide any update for this topic?
my projects at work shifted priorities, when I have some free time I will give an update regarding the mods solution.
Ok. We have released DOS 7.2.5 with CUDA 13.x.
Consider upgrading to latest release .
