We have build autoware.ai on Drive PX2 with Drivework 1.2.4. However, the package autoware_driveworks_gmsl_interface, autoware_driveworks_interface has got complie errors. We cannot find dwImageFormatConverterHandle_t either on the Drive PX2 or the host machine. How can we find it and build driveworks wth autoware?
nvidia@tegra-ubuntu:~/autoware.ai$ AUTOWARE_COMPILE_WITH_CUDA=1 colcon build --symlink-install --packages-select autoware_driveworks_gmsl_interface autoware_driveworks_interface --cmake-args -DCMAKE_BUILD_TYPE=Release --cmake-clean-cache
Starting >>> autoware_driveworks_gmsl_interface
Starting >>> autoware_driveworks_interface
--- stderr: autoware_driveworks_interface
9.2
aarch64
/usr/local/driveworks/lib/libdriveworks.so
TRUE
/usr/local/cuda-9.2
Finished <<< autoware_driveworks_interface [20.1s]
--- stderr: autoware_driveworks_gmsl_interface
CMake Warning (dev) at CMakeLists.txt:68 (target_link_libraries):
Policy CMP0023 is not set: Plain and keyword target_link_libraries
signatures cannot be mixed. Run "cmake --help-policy CMP0023" for policy
details. Use the cmake_policy command to set the policy and suppress this
warning.
The plain signature for target_link_libraries has already been used with
the target "autoware_driveworks_gmsl_interface_node". All uses of
target_link_libraries with a target should be either all-keyword or
all-plain.
The uses of the plain signature are here:
* /usr/share/cmake-3.5/Modules/FindCUDA.cmake:1704 (target_link_libraries)
This warning is for project developers. Use -Wno-dev to suppress it.
In file included from /home/nvidia/autoware.ai/src/drivers/awf_drivers/autoware_driveworks_gmsl_interface/include/SekonixGmslCamera.hpp:71:0,
from /home/nvidia/autoware.ai/src/drivers/awf_drivers/autoware_driveworks_gmsl_interface/src/gmsl_camera_multiple/SekonixGmslCamera.cpp:37:
/home/nvidia/autoware.ai/src/drivers/awf_drivers/autoware_driveworks_gmsl_interface/include/DriveWorksApi.hpp:95:3: error: ‘dwImageFormatConverterHandle_t’ does not name a type
dwImageFormatConverterHandle_t yuv2rgba;
/home/nvidia/autoware.ai/src/drivers/awf_drivers/autoware_driveworks_gmsl_interface/include/DriveWorksApi.hpp:142:44: error: ‘dwImageFormatConverterHandle_t’ has not been declared
uint32_t sibling, dwImageFormatConverterHandle_t yuv2rgba,
from /home/nvidia/autoware.ai/src/drivers/awf_drivers/autoware_driveworks_gmsl_interface/src/gmsl_camera_multiple/gmsl_nodelets.cpp:43:
from /home/nvidia/autoware.ai/src/drivers/awf_drivers/autoware_driveworks_gmsl_interface/src/gmsl_camera_multiple/gmsl_node.cpp:40:
make[2]: *** [CMakeFiles/nodelet_autoware_driveworks_gmsl_interface.dir/src/gmsl_camera_multiple/SekonixGmslCamera.cpp.o] Error 1
make[2]: *** Waiting for unfinished jobs....
In file included from /home/nvidia/autoware.ai/src/drivers/awf_drivers/autoware_driveworks_gmsl_interface/src/gmsl_camera_multiple/DriveWorksApi.cpp:39:0:
make[2]: *** [CMakeFiles/autoware_driveworks_gmsl_interface_node.dir/src/gmsl_camera_multiple/gmsl_node.cpp.o] Error 1
/home/nvidia/autoware.ai/src/drivers/awf_drivers/autoware_driveworks_gmsl_interface/src/gmsl_camera_multiple/DriveWorksApi.cpp: In member function ‘void DriveWorks::DriveWorksApi::initSdk(dwContextObject**)’:
/home/nvidia/autoware.ai/src/drivers/awf_drivers/autoware_driveworks_gmsl_interface/src/gmsl_camera_multiple/DriveWorksApi.cpp:77:25: error: ‘DW_VERSION’ was not declared in this scope
dwInitialize(context, DW_VERSION, &sdkParams);
/home/nvidia/autoware.ai/src/drivers/awf_drivers/autoware_driveworks_gmsl_interface/src/gmsl_camera_multiple/DriveWorksApi.cpp: In member function ‘void DriveWorks::DriveWorksApi::initSensors(std::vector<DriveWorks::Camera>*, uint32_t*, dwSALHandle_t, DriveWorks::DeviceArguments&)’:
/home/nvidia/autoware.ai/src/drivers/awf_drivers/autoware_driveworks_gmsl_interface/src/gmsl_camera_multiple/DriveWorksApi.cpp:158:43: error: ‘DW_CAMERA_PROCESSED_IMAGE’ was not declared in this scope
DW_CAMERA_PROCESSED_IMAGE,
/home/nvidia/autoware.ai/src/drivers/awf_drivers/autoware_driveworks_gmsl_interface/src/gmsl_camera_multiple/DriveWorksApi.cpp: In member function ‘void DriveWorks::DriveWorksApi::initFrameImage(DriveWorks::Camera*)’:
/home/nvidia/autoware.ai/src/drivers/awf_drivers/autoware_driveworks_gmsl_interface/src/gmsl_camera_multiple/DriveWorksApi.cpp:250:63: error: ‘DW_CAMERA_PROCESSED_IMAGE’ was not declared in this scope
dwSensorCamera_getImageProperties(&cameraImageProperties, DW_CAMERA_PROCESSED_IMAGE,camera->sensor);
/home/nvidia/autoware.ai/src/drivers/awf_drivers/autoware_driveworks_gmsl_interface/src/gmsl_camera_multiple/DriveWorksApi.cpp:252:28: error: ‘dwImageProperties {aka struct dwImageProperties}’ has no member named ‘pxlFormat’
displayImageProperties.pxlFormat = DW_IMAGE_RGBA;
/home/nvidia/autoware.ai/src/drivers/awf_drivers/autoware_driveworks_gmsl_interface/src/gmsl_camera_multiple/DriveWorksApi.cpp:252:48: error: ‘DW_IMAGE_RGBA’ was not declared in this scope
/home/nvidia/autoware.ai/src/drivers/awf_drivers/autoware_driveworks_gmsl_interface/src/gmsl_camera_multiple/DriveWorksApi.cpp:253:28: error: ‘dwImageProperties {aka struct dwImageProperties}’ has no member named ‘planeCount’
displayImageProperties.planeCount = 1;
/home/nvidia/autoware.ai/src/drivers/awf_drivers/autoware_driveworks_gmsl_interface/src/gmsl_camera_multiple/DriveWorksApi.cpp:256:57: error: ‘struct DriveWorks::Camera’ has no member named ‘yuv2rgba’
result = dwImageFormatConverter_initialize(&camera->yuv2rgba, cameraImageProperties.type, sdk);
/home/nvidia/autoware.ai/src/drivers/awf_drivers/autoware_driveworks_gmsl_interface/src/gmsl_camera_multiple/DriveWorksApi.cpp:256:98: error: ‘dwImageFormatConverter_initialize’ was not declared in this scope
/home/nvidia/autoware.ai/src/drivers/awf_drivers/autoware_driveworks_gmsl_interface/src/gmsl_camera_multiple/DriveWorksApi.cpp:269:75: error: ‘dwImageNvMedia_create’ was not declared in this scope
result = dwImageNvMedia_create(&rgba, &displayImageProperties, sdk);
/home/nvidia/autoware.ai/src/drivers/awf_drivers/autoware_driveworks_gmsl_interface/src/gmsl_camera_multiple/DriveWorksApi.cpp: In member function ‘void DriveWorks::DriveWorksApi::threadCameraPipeline(DriveWorks::Camera*, uint32_t, dwContextHandle_t)’:
/home/nvidia/autoware.ai/src/drivers/awf_drivers/autoware_driveworks_gmsl_interface/src/gmsl_camera_multiple/DriveWorksApi.cpp:393:43: error: ‘struct DriveWorks::Camera’ has no member named ‘yuv2rgba’
cameraSensor->yuv2rgba,
/home/nvidia/autoware.ai/src/drivers/awf_drivers/autoware_driveworks_gmsl_interface/src/gmsl_camera_multiple/DriveWorksApi.cpp: At global scope:
/home/nvidia/autoware.ai/src/drivers/awf_drivers/autoware_driveworks_gmsl_interface/src/gmsl_camera_multiple/DriveWorksApi.cpp:462:42: error: ‘dwImageFormatConverterHandle_t’ has not been declared
/home/nvidia/autoware.ai/src/drivers/awf_drivers/autoware_driveworks_gmsl_interface/src/gmsl_camera_multiple/DriveWorksApi.cpp: In member function ‘dwStatus DriveWorks::DriveWorksApi::captureCamera(dwImageNvMedia*, dwSensorHandle_t, uint32_t, uint32_t, int, uint8_t*, NvMediaIJPE*)’:
/home/nvidia/autoware.ai/src/drivers/awf_drivers/autoware_driveworks_gmsl_interface/src/gmsl_camera_multiple/DriveWorksApi.cpp:475:57: error: ‘DW_CAMERA_PROCESSED_IMAGE’ was not declared in this scope
result = dwSensorCamera_getImageNvMedia(&frameNVMyuv, DW_CAMERA_PROCESSED_IMAGE, frameHandle);
/home/nvidia/autoware.ai/src/drivers/awf_drivers/autoware_driveworks_gmsl_interface/src/gmsl_camera_multiple/DriveWorksApi.cpp:481:89: error: invalid conversion from ‘int’ to ‘dwContextHandle_t {aka dwContextObject*}’ [-fpermissive]
result = dwImageFormatConverter_copyConvertNvMedia(frameNVMrgba, frameNVMyuv, yuv2rgba);
In file included from /usr/local/driveworks/include/dw/image/FormatConverter.h:94:0,
from /home/nvidia/autoware.ai/src/drivers/awf_drivers/autoware_driveworks_gmsl_interface/include/DriveWorksApi.hpp:74,
/usr/local/driveworks/include/dw/image/FormatConverter_vibrante.h:79:10: note: initializing argument 3 of ‘dwStatus dwImageFormatConverter_copyConvertNvMedia(dwImageNvMedia*, const dwImageNvMedia*, dwContextHandle_t)’
dwStatus dwImageFormatConverter_copyConvertNvMedia(dwImageNvMedia* output,
/home/nvidia/autoware.ai/src/drivers/awf_drivers/autoware_driveworks_gmsl_interface/src/gmsl_camera_multiple/DriveWorksApi.cpp: In member function ‘void DriveWorks::DriveWorksApi::releaseCameras(DriveWorks::Camera*)’:
/home/nvidia/autoware.ai/src/drivers/awf_drivers/autoware_driveworks_gmsl_interface/src/gmsl_camera_multiple/DriveWorksApi.cpp:525:51: error: ‘struct DriveWorks::Camera’ has no member named ‘yuv2rgba’
dwImageFormatConverter_release(&cameraSensor->yuv2rgba);
/home/nvidia/autoware.ai/src/drivers/awf_drivers/autoware_driveworks_gmsl_interface/src/gmsl_camera_multiple/DriveWorksApi.cpp:525:59: error: ‘dwImageFormatConverter_release’ was not declared in this scope
/home/nvidia/autoware.ai/src/drivers/awf_drivers/autoware_driveworks_gmsl_interface/src/gmsl_camera_multiple/DriveWorksApi.cpp:532:51: error: ‘dwImageNvMedia_destroy’ was not declared in this scope
dwStatus result = dwImageNvMedia_destroy(&frame);
make[2]: *** [CMakeFiles/nodelet_autoware_driveworks_gmsl_interface.dir/src/gmsl_camera_multiple/gmsl_nodelets.cpp.o] Error 1
make[2]: *** [CMakeFiles/autoware_driveworks_gmsl_interface_node.dir/src/gmsl_camera_multiple/SekonixGmslCamera.cpp.o] Error 1
make[2]: *** [CMakeFiles/nodelet_autoware_driveworks_gmsl_interface.dir/src/gmsl_camera_multiple/DriveWorksApi.cpp.o] Error 1
make[1]: *** [CMakeFiles/nodelet_autoware_driveworks_gmsl_interface.dir/all] Error 2
make[1]: *** Waiting for unfinished jobs....
make[2]: *** [CMakeFiles/autoware_driveworks_gmsl_interface_node.dir/src/gmsl_camera_multiple/DriveWorksApi.cpp.o] Error 1
make[1]: *** [CMakeFiles/autoware_driveworks_gmsl_interface_node.dir/all] Error 2
make: *** [all] Error 2
Failed <<< autoware_driveworks_gmsl_interface [22.5s, exited with code 2]
Summary: 1 package finished [24.8s]
1 package failed: autoware_driveworks_gmsl_interface
2 packages had stderr output: autoware_driveworks_gmsl_interface autoware_driveworks_interface
