[b]Hello there ,
i have this 7" TFT RGB Display : http://shop.udoo.org/other/accessories/video-kit-7-touch-for-quaddual.html?___from_store=other&popup=no
Which interface is : parallel 18-bit rgb
is it possible to connect it to the board ?
[/b]
[b]Hello there ,
[/b]
Can’t really tell what the display is from the page, but I believe HDMI and maybe eDP might be your only options. Maybe it would work with some kind of converter?
This is the Datasheet : http://udoo.org/download/files/datasheets/datasheet7.pdf
http://blog.reasonablycorrect.com/raw-dpi-raspberry-pi/
this a good read on a similar panel and hookup to raspberry pi. not sure how much this translates to jumper J21 , i think only 9 GPIO pins there, or the display port but you might get some ideas from reading it.
