Converting RAW image to Sparse image errors flashing Jestson Nano dev board via SDKManager
I’m having trouble flashing my Jetson Nano development board using the SDKManager. I see the following errors in my terminal window (see below). After the errors, The process eventually hangs
“Writing partition APP with system.img”
Any help is greatly appreciated
Thanks,
Robert.
19:27:39 INFO : Flash Jetson Nano : ./tegraflash.py --chip 0x21 --applet "/home/rjh-principle/nvidia/nvidia_sdk/JetPack_4.2.1_Linux_GA_P3448/Linux_for_Tegra/bootloader/nvtboot_recovery.bin" --skipuid --cmd "dump eeprom boardinfo cvm.bin"
19:27:39 INFO : Flash Jetson Nano : Welcome to Tegra Flash
19:27:39 INFO : Flash Jetson Nano : version 1.0.0
19:27:39 INFO : Flash Jetson Nano : Type ? or help for help and q or quit to exit
19:27:39 INFO : Flash Jetson Nano : Use ! to execute system commands
19:27:39 INFO : Flash Jetson Nano : [ 0.0170 ] Generating RCM messages
19:27:39 INFO : Flash Jetson Nano : [ 0.0247 ] tegrarcm --listrcm rcm_list.xml --chip 0x21 0 --download rcm /home/rjh-principle/nvidia/nvidia_sdk/JetPack_4.2.1_Linux_GA_P3448/Linux_for_Tegra/bootloader/nvtboot_recovery.bin 0 0
19:27:39 INFO : Flash Jetson Nano : [ 0.0262 ] RCM 0 is saved as rcm_0.rcm
19:27:39 INFO : Flash Jetson Nano : [ 0.0488 ] RCM 1 is saved as rcm_1.rcm
19:27:39 INFO : Flash Jetson Nano : [ 0.0488 ] List of rcm files are saved in rcm_list.xml
19:27:39 INFO : Flash Jetson Nano : [ 0.0488 ] Signing RCM messages
19:27:39 INFO : Flash Jetson Nano : [ 0.0627 ] tegrasign --key None --list rcm_list.xml --pubkeyhash pub_key.key
19:27:39 INFO : Flash Jetson Nano : [ 0.0641 ] Assuming zero filled SBK key
19:27:39 INFO : Flash Jetson Nano : [ 0.0832 ]
19:27:39 INFO : Flash Jetson Nano : [ 0.0832 ] Copying signature to RCM mesages
19:27:39 INFO : Flash Jetson Nano : [ 0.0844 ] tegrarcm --chip 0x21 0 --updatesig rcm_list_signed.xml
19:27:39 INFO : Flash Jetson Nano : [ 0.1032 ]
19:27:39 INFO : Flash Jetson Nano : [ 0.1033 ] Boot Rom communication
19:27:39 INFO : Flash Jetson Nano : [ 0.1047 ] tegrarcm --chip 0x21 0 --rcm rcm_list_signed.xml --skipuid
19:27:39 INFO : Flash Jetson Nano : [ 0.1077 ] RCM version 0X210001
19:27:40 INFO : Flash Jetson Nano : [ 0.1694 ] Boot Rom communication completed
19:27:40 INFO : Flash Jetson Nano : [ 1.2512 ]
19:27:40 INFO : Flash Jetson Nano : [ 1.2513 ] dump EEPROM info
19:27:40 INFO : Flash Jetson Nano : [ 1.2534 ] tegrarcm --oem platformdetails eeprom /home/rjh-principle/nvidia/nvidia_sdk/JetPack_4.2.1_Linux_GA_P3448/Linux_for_Tegra/bootloader/cvm.bin
19:27:40 INFO : Flash Jetson Nano : [ 1.2557 ] Applet version 00.01.0000
19:27:41 INFO : Flash Jetson Nano : [ 1.4427 ] Saved platform info in /home/rjh-principle/nvidia/nvidia_sdk/JetPack_4.2.1_Linux_GA_P3448/Linux_for_Tegra/bootloader/cvm.bin
19:27:41 INFO : Flash Jetson Nano : [ 1.7149 ]
19:27:41 ERROR : Flash Jetson Nano : Board ID(3448) version(200)
19:27:41 INFO : Flash Jetson Nano : creating dummy /home/rjh-principle/nvidia/nvidia_sdk/JetPack_4.2.1_Linux_GA_P3448/Linux_for_Tegra/bootloader/badpage.bin
19:27:41 ERROR : Flash Jetson Nano : 1+0 records in
19:27:41 INFO : Flash Jetson Nano : 1+0 records out
19:27:41 ERROR : Flash Jetson Nano : 4096 bytes (4.1 kB, 4.0 KiB) copied, 0.000236583 s, 17.3 MB/s
19:27:41 INFO : Flash Jetson Nano : copying bctfile(/home/rjh-principle/nvidia/nvidia_sdk/JetPack_4.2.1_Linux_GA_P3448/Linux_for_Tegra/bootloader/t210ref/BCT/P3448_A00_4GB_Micron_4GB_lpddr4_204Mhz_P987.cfg)... done.
19:27:41 INFO : Flash Jetson Nano : copying bootloader(/home/rjh-principle/nvidia/nvidia_sdk/JetPack_4.2.1_Linux_GA_P3448/Linux_for_Tegra/bootloader/t210ref/cboot.bin)... done.
19:27:41 INFO : Flash Jetson Nano : copying initrd(/home/rjh-principle/nvidia/nvidia_sdk/JetPack_4.2.1_Linux_GA_P3448/Linux_for_Tegra/bootloader/l4t_initrd.img)... done.
19:27:41 INFO : Flash Jetson Nano : populating kernel to rootfs... done.
19:27:41 INFO : Flash Jetson Nano : populating initrd to rootfs... done.
19:27:41 INFO : Flash Jetson Nano : populating /home/rjh-principle/nvidia/nvidia_sdk/JetPack_4.2.1_Linux_GA_P3448/Linux_for_Tegra/kernel/dtb/tegra210-p3448-0000-p3449-0000-a02.dtb to rootfs... done.
19:27:42 INFO : Flash Jetson Nano : Making Boot image... done.
19:27:42 INFO : Flash Jetson Nano : Existing sosfile(/home/rjh-principle/nvidia/nvidia_sdk/JetPack_4.2.1_Linux_GA_P3448/Linux_for_Tegra/bootloader/nvtboot_recovery.bin) reused.
19:27:42 INFO : Flash Jetson Nano : copying tegraboot(/home/rjh-principle/nvidia/nvidia_sdk/JetPack_4.2.1_Linux_GA_P3448/Linux_for_Tegra/bootloader/t210ref/nvtboot.bin)... done.
19:27:42 INFO : Flash Jetson Nano : copying cpu_bootloader(/home/rjh-principle/nvidia/nvidia_sdk/JetPack_4.2.1_Linux_GA_P3448/Linux_for_Tegra/bootloader/t210ref/cboot.bin)... done.
19:27:42 INFO : Flash Jetson Nano : copying bpffile(/home/rjh-principle/nvidia/nvidia_sdk/JetPack_4.2.1_Linux_GA_P3448/Linux_for_Tegra/bootloader/t210ref/sc7entry-firmware.bin)... done.
19:27:42 INFO : Flash Jetson Nano : Existing badpagefile(/home/rjh-principle/nvidia/nvidia_sdk/JetPack_4.2.1_Linux_GA_P3448/Linux_for_Tegra/bootloader/badpage.bin) reused.
19:27:42 INFO : Flash Jetson Nano : copying wb0boot(/home/rjh-principle/nvidia/nvidia_sdk/JetPack_4.2.1_Linux_GA_P3448/Linux_for_Tegra/bootloader/t210ref/warmboot.bin)... done.
19:27:42 INFO : Flash Jetson Nano : Existing tosfile(/home/rjh-principle/nvidia/nvidia_sdk/JetPack_4.2.1_Linux_GA_P3448/Linux_for_Tegra/bootloader/tos-mon-only.img) reused.
19:27:42 INFO : Flash Jetson Nano : Existing eksfile(/home/rjh-principle/nvidia/nvidia_sdk/JetPack_4.2.1_Linux_GA_P3448/Linux_for_Tegra/bootloader/eks.img) reused.
19:27:42 INFO : Flash Jetson Nano : copying dtbfile(/home/rjh-principle/nvidia/nvidia_sdk/JetPack_4.2.1_Linux_GA_P3448/Linux_for_Tegra/kernel/dtb/tegra210-p3448-0000-p3449-0000-a02.dtb)... done.
19:27:44 INFO : Flash Jetson Nano : Copying nv_boot_control.conf to rootfs
19:27:44 INFO : Flash Jetson Nano : Making system.img...
19:29:45 INFO : Flash Jetson Nano : populating rootfs from /home/rjh-principle/nvidia/nvidia_sdk/JetPack_4.2.1_Linux_GA_P3448/Linux_for_Tegra/rootfs ...
19:32:20 INFO : Flash Jetson Nano : done.
19:32:30 INFO : Flash Jetson Nano : Sync'ing system.img ... done.
19:32:30 INFO : Flash Jetson Nano : Converting RAW image to Sparse image...
19:32:30 ERROR : Flash Jetson Nano :
19:32:30 INFO : Flash Jetson Nano : ---- Raw to Sparse Image Converter v1.0 ----------------------------
19:32:30 ERROR : Flash Jetson Nano : 0: RAW: 5242880( 5 blks) ==> 28:5242892
19:32:30 ERROR : Flash Jetson Nano : 1: SKP: 32505856( 31 blks) ==> 5242920:12
19:32:30 ERROR : Flash Jetson Nano : 2: RAW: 1048576( 1 blks) ==> 5242932:1048588
19:32:30 ERROR : Flash Jetson Nano : 3: SKP: 95420416( 91 blks) ==> 6291520:12
19:32:30 ERROR : Flash Jetson Nano : 4: RAW: 1048576( 1 blks) ==> 6291532:1048588
19:32:30 ERROR : Flash Jetson Nano : 5: SKP: 3145728( 3 blks) ==> 7340120:12
19:32:30 ERROR : Flash Jetson Nano : 6: RAW: 2097152( 2 blks) ==> 7340132:2097164
19:32:30 ERROR : Flash Jetson Nano : 7: SKP: 2097152( 2 blks) ==> 9437296:12
19:32:30 ERROR : Flash Jetson Nano : 8: RAW: 23068672( 22 blks) ==> 9437308:23068684
19:32:30 ERROR : Flash Jetson Nano : 9: SKP: 1048576( 1 blks) ==> 32505992:12
19:32:31 ERROR : Flash Jetson Nano : 10: RAW: 40894464( 39 blks) ==> 32506004:40894476
19:32:31 ERROR : Flash Jetson Nano : 11: SKP: 2097152( 2 blks) ==> 73400480:12
19:32:31 ERROR : Flash Jetson Nano : 12: RAW: 1048576( 1 blks) ==> 73400492:1048588
19:32:31 ERROR : Flash Jetson Nano : 13: SKP: 15728640( 15 blks) ==> 74449080:12
19:32:31 ERROR : Flash Jetson Nano : 14: RAW: 65011712( 62 blks) ==> 74449092:65011724
19:32:31 ERROR : Flash Jetson Nano : 15: SKP: 2097152( 2 blks) ==> 139460816:12
19:32:32 ERROR : Flash Jetson Nano : 16: RAW: 40894464( 39 blks) ==> 139460828:40894476
19:32:32 ERROR : Flash Jetson Nano : 17: SKP: 1048576( 1 blks) ==> 180355304:12
19:32:32 ERROR : Flash Jetson Nano : 18: RAW: 3145728( 3 blks) ==> 180355316:3145740
19:32:32 ERROR : Flash Jetson Nano : 19: SKP: 1048576( 1 blks) ==> 183501056:12
19:32:32 ERROR : Flash Jetson Nano : 20: RAW: 20971520( 20 blks) ==> 183501068:20971532
19:32:32 ERROR : Flash Jetson Nano : 21: SKP: 1048576( 1 blks) ==> 204472600:12
19:32:32 ERROR : Flash Jetson Nano : 22: RAW: 35651584( 34 blks) ==> 204472612:35651596
19:32:32 ERROR : Flash Jetson Nano : 23: SKP: 5242880( 5 blks) ==> 240124208:12
19:32:32 ERROR : Flash Jetson Nano : 24: RAW: 1048576( 1 blks) ==> 240124220:1048588
19:32:32 ERROR : Flash Jetson Nano : 25: SKP: 3145728( 3 blks) ==> 241172808:12
19:32:32 ERROR : Flash Jetson Nano : 26: RAW: 3145728( 3 blks) ==> 241172820:3145740
19:32:32 ERROR : Flash Jetson Nano : 27: SKP: 1048576( 1 blks) ==> 244318560:12
19:32:34 ERROR : Flash Jetson Nano : 28: RAW: 105906176( 101 blks) ==> 244318572:105906188
19:32:34 ERROR : Flash Jetson Nano : 29: SKP: 3145728( 3 blks) ==> 350224760:12
19:32:35 ERROR : Flash Jetson Nano : 30: RAW: 116391936( 111 blks) ==> 350224772:116391948
19:32:35 ERROR : Flash Jetson Nano : 31: SKP: 1048576( 1 blks) ==> 466616720:12
19:32:35 ERROR : Flash Jetson Nano : 32: RAW: 34603008( 33 blks) ==> 466616732:34603020
19:32:35 ERROR : Flash Jetson Nano : 33: SKP: 7340032( 7 blks) ==> 501219752:12
19:32:36 ERROR : Flash Jetson Nano : 34: RAW: 65011712( 62 blks) ==> 501219764:65011724
19:32:36 ERROR : Flash Jetson Nano : 35: SKP: 2097152( 2 blks) ==> 566231488:12
19:32:37 ERROR : Flash Jetson Nano : 36: RAW: 39845888( 38 blks) ==> 566231500:39845900
19:32:37 ERROR : Flash Jetson Nano : 37: SKP: 2097152( 2 blks) ==> 606077400:12
19:32:37 ERROR : Flash Jetson Nano : 38: RAW: 32505856( 31 blks) ==> 606077412:32505868
19:32:37 ERROR : Flash Jetson Nano : 39: SKP: 1048576( 1 blks) ==> 638583280:12
19:32:39 ERROR : Flash Jetson Nano : 40: RAW: 80740352( 77 blks) ==> 638583292:80740364
19:32:39 ERROR : Flash Jetson Nano : 41: SKP: 3145728( 3 blks) ==> 719323656:12
19:32:40 ERROR : Flash Jetson Nano : 42: RAW: 34603008( 33 blks) ==> 719323668:34603020
19:32:40 ERROR : Flash Jetson Nano : 43: SKP: 3145728( 3 blks) ==> 753926688:12
19:32:42 ERROR : Flash Jetson Nano : 44: RAW: 36700160( 35 blks) ==> 753926700:36700172
19:32:42 ERROR : Flash Jetson Nano : 45: SKP: 1048576( 1 blks) ==> 790626872:12
19:32:43 ERROR : Flash Jetson Nano : 46: RAW: 20971520( 20 blks) ==> 790626884:20971532
19:32:44 ERROR : Flash Jetson Nano : 47: SKP: 4194304( 4 blks) ==> 811598416:12
19:32:49 ERROR : Flash Jetson Nano : 48: RAW: 74448896( 71 blks) ==> 811598428:74448908
19:32:49 ERROR : Flash Jetson Nano : 49: SKP: 1048576( 1 blks) ==> 886047336:12
19:32:49 ERROR : Flash Jetson Nano : 50: RAW: 37748736( 36 blks) ==> 886047348:37748748
19:32:49 ERROR : Flash Jetson Nano : 51: SKP: 1048576( 1 blks) ==> 923796096:12
19:32:49 ERROR : Flash Jetson Nano : 52: RAW: 32505856( 31 blks) ==> 923796108:32505868
19:32:49 ERROR : Flash Jetson Nano : 53: SKP: 4194304( 4 blks) ==> 956301976:12
19:32:49 ERROR : Flash Jetson Nano : 54: RAW: 51380224( 49 blks) ==> 956301988:51380236
19:32:49 ERROR : Flash Jetson Nano : 55: SKP: 3145728( 3 blks) ==> 1007682224:12
19:32:49 ERROR : Flash Jetson Nano : 56: RAW: 6291456( 6 blks) ==> 1007682236:6291468
19:32:49 ERROR : Flash Jetson Nano : 57: SKP: 6291456( 6 blks) ==> 1013973704:12
19:32:49 ERROR : Flash Jetson Nano : 58: RAW: 65011712( 62 blks) ==> 1013973716:65011724
19:32:49 ERROR : Flash Jetson Nano : 59: SKP: 2097152( 2 blks) ==> 1078985440:12
19:32:50 ERROR : Flash Jetson Nano : 60: RAW: 161480704( 154 blks) ==> 1078985452:161480716
19:32:50 ERROR : Flash Jetson Nano : 61: SKP: 6291456( 6 blks) ==> 1240466168:12
19:32:50 ERROR : Flash Jetson Nano : 62: RAW: 24117248( 23 blks) ==> 1240466180:24117260
19:32:50 ERROR : Flash Jetson Nano : 63: SKP: 1048576( 1 blks) ==> 1264583440:12
19:32:50 ERROR : Flash Jetson Nano : 64: RAW: 15728640( 15 blks) ==> 1264583452:15728652
19:32:50 ERROR : Flash Jetson Nano : 65: SKP: 1048576( 1 blks) ==> 1280312104:12
19:32:50 ERROR : Flash Jetson Nano : 66: RAW: 15728640( 15 blks) ==> 1280312116:15728652
19:32:50 ERROR : Flash Jetson Nano : 67: SKP: 1048576( 1 blks) ==> 1296040768:12
19:32:50 ERROR : Flash Jetson Nano : 68: RAW: 8388608( 8 blks) ==> 1296040780:8388620
19:32:50 ERROR : Flash Jetson Nano : 69: SKP: 620756992( 592 blks) ==> 1304429400:12
19:32:51 ERROR : Flash Jetson Nano : 70: RAW: 11534336( 11 blks) ==> 1304429412:11534348
19:32:51 ERROR : Flash Jetson Nano : 71: SKP: 22020096( 21 blks) ==> 1315963760:12
19:32:52 ERROR : Flash Jetson Nano : 72: RAW: 13631488( 13 blks) ==> 1315963772:13631500
19:32:52 ERROR : Flash Jetson Nano : 73: SKP: 87031808( 83 blks) ==> 1329595272:12
19:33:30 ERROR : Flash Jetson Nano : 74: RAW: 910163968( 868 blks) ==> 1329595284:910163980
19:33:30 ERROR : Flash Jetson Nano : 75: SKP: 163577856( 156 blks) ==> 2239759264:12
19:33:30 ERROR : Flash Jetson Nano : 76: RAW: 1048576( 1 blks) ==> 2239759276:1048588
19:33:30 ERROR : Flash Jetson Nano : 77: SKP: 267386880( 255 blks) ==> 2240807864:12
19:33:30 ERROR : Flash Jetson Nano : 78: RAW: 1048576( 1 blks) ==> 2240807876:1048588
19:33:31 ERROR : Flash Jetson Nano : 79: SKP: 670040064( 639 blks) ==> 2241856464:12
19:33:31 ERROR : Flash Jetson Nano : 80: RAW: 6291456( 6 blks) ==> 2241856476:6291468
19:33:31 ERROR : Flash Jetson Nano : 81: SKP: 27262976( 26 blks) ==> 2248147944:12
19:33:32 ERROR : Flash Jetson Nano : 82: RAW: 13631488( 13 blks) ==> 2248147956:13631500
19:33:32 ERROR : Flash Jetson Nano : 83: SKP: 87031808( 83 blks) ==> 2261779456:12
19:34:04 ERROR : Flash Jetson Nano : 84: RAW: 838860800( 800 blks) ==> 2261779468:838860812
19:34:04 ERROR : Flash Jetson Nano : 85: SKP: 33554432( 32 blks) ==> 3100640280:12
19:34:04 ERROR : Flash Jetson Nano : 86: RAW: 9437184( 9 blks) ==> 3100640292:9437196
19:34:05 ERROR : Flash Jetson Nano : 87: SKP: 1131413504( 1079 blks) ==> 3110077488:12
19:34:05 ERROR : Flash Jetson Nano : 88: RAW: 5242880( 5 blks) ==> 3110077500:5242892
19:34:05 ERROR : Flash Jetson Nano : 89: SKP: 28311552( 27 blks) ==> 3115320392:12
19:34:05 ERROR : Flash Jetson Nano : 90: RAW: 13631488( 13 blks) ==> 3115320404:13631500
19:34:05 ERROR : Flash Jetson Nano : 91: SKP: 87031808( 83 blks) ==> 3128951904:12
19:34:05 ERROR : Flash Jetson Nano : 92: RAW: 1048576( 1 blks) ==> 3128951916:1048588
19:34:05 ERROR : Flash Jetson Nano : 93: SKP: 3145728( 3 blks) ==> 3130000504:12
19:34:21 ERROR : Flash Jetson Nano : 94: RAW: 273678336( 261 blks) ==> 3130000516:273678348
19:34:23 ERROR : Flash Jetson Nano : 95: SKP: 1735393280( 1655 blks) ==> 3403678864:12
19:34:23 ERROR : Flash Jetson Nano : 96: RAW: 6291456( 6 blks) ==> 3403678876:6291468
19:34:23 ERROR : Flash Jetson Nano : 97: SKP: 27262976( 26 blks) ==> 3409970344:12
19:34:24 ERROR : Flash Jetson Nano : 98: RAW: 13631488( 13 blks) ==> 3409970356:13631500
19:34:24 ERROR : Flash Jetson Nano : 99: SKP: 87031808( 83 blks) ==> 3423601856:12
19:34:35 ERROR : Flash Jetson Nano : 100: RAW: 152043520( 145 blks) ==> 3423601868:152043532
19:34:37 ERROR : Flash Jetson Nano : 101: SKP: 2097152( 2 blks) ==> 3575645400:12
19:34:53 ERROR : Flash Jetson Nano : 102: RAW: 521142272( 497 blks) ==> 3575645412:521142284
19:34:53 ERROR : Flash Jetson Nano : 103: SKP: 1337982976( 1276 blks) ==> 4096787696:12
19:34:53 ERROR : Flash Jetson Nano : 104: RAW: 8388608( 8 blks) ==> 4096787708:8388620
19:34:53 ERROR : Flash Jetson Nano : 105: SKP: 25165824( 24 blks) ==> 4105176328:12
19:34:54 ERROR : Flash Jetson Nano : 106: RAW: 15728640( 15 blks) ==> 4105176340:15728652
19:34:54 ERROR : Flash Jetson Nano : 107: SKP: 84934656( 81 blks) ==> 4120904992:12
19:34:54 ERROR : Flash Jetson Nano : 108: RAW: 1048576( 1 blks) ==> 4120905004:1048588
19:34:54 ERROR : Flash Jetson Nano : 109: SKP: 3145728( 3 blks) ==> 4121953592:12
19:34:56 ERROR : Flash Jetson Nano : 110: RAW: 158334976( 151 blks) ==> 4121953604:158334988
19:34:58 ERROR : Flash Jetson Nano : 111: SKP: 1850736640( 1765 blks) ==> 4280288592:12
19:34:59 ERROR : Flash Jetson Nano : 112: RAW: 6291456( 6 blks) ==> 4280288604:6291468
19:34:59 ERROR : Flash Jetson Nano : 113: SKP: 27262976( 26 blks) ==> 4286580072:12
19:35:01 ERROR : Flash Jetson Nano : 114: RAW: 23068672( 22 blks) ==> 4286580084:23068684
19:35:02 ERROR : Flash Jetson Nano : 115: SKP: 77594624( 74 blks) ==> 4309648768:12
19:35:04 ERROR : Flash Jetson Nano : 116: RAW: 51380224( 49 blks) ==> 4309648780:51380236
19:35:04 ERROR : Flash Jetson Nano : 117: SKP: 1961885696( 1871 blks) ==> 4361029016:12
19:35:04 ERROR : Flash Jetson Nano : -- Total:
19:35:04 ERROR : Flash Jetson Nano : ---------------------------------------------------
19:35:04 ERROR : Flash Jetson Nano : 118 CHUNK 15032385536( 14336 blks) ==> 4361029028(4159 blks)
19:35:04 INFO : Flash Jetson Nano : done.
19:35:04 INFO : Flash Jetson Nano : system.img built successfully.
19:35:06 INFO : Flash Jetson Nano : Existing tbcfile(/home/rjh-principle/nvidia/nvidia_sdk/JetPack_4.2.1_Linux_GA_P3448/Linux_for_Tegra/bootloader/nvtboot_cpu.bin) reused.
19:35:06 INFO : Flash Jetson Nano : copying tbcdtbfile(/home/rjh-principle/nvidia/nvidia_sdk/JetPack_4.2.1_Linux_GA_P3448/Linux_for_Tegra/kernel/dtb/tegra210-p3448-0000-p3449-0000-a02.dtb)... done.
19:35:06 INFO : Flash Jetson Nano : copying cfgfile(/home/rjh-principle/nvidia/nvidia_sdk/JetPack_4.2.1_Linux_GA_P3448/Linux_for_Tegra/bootloader/t210ref/cfg/flash_l4t_t210_spi_sd_p3448.xml) to flash.xml... done.
19:35:06 INFO : Flash Jetson Nano : copying flasher(/home/rjh-principle/nvidia/nvidia_sdk/JetPack_4.2.1_Linux_GA_P3448/Linux_for_Tegra/bootloader/t210ref/cboot.bin)... done.
19:35:06 INFO : Flash Jetson Nano : Existing flashapp(/home/rjh-principle/nvidia/nvidia_sdk/JetPack_4.2.1_Linux_GA_P3448/Linux_for_Tegra/bootloader/tegraflash.py) reused.
19:35:06 INFO : Flash Jetson Nano : ./tegraflash.py --bl cboot.bin --bct P3448_A00_4GB_Micron_4GB_lpddr4_204Mhz_P987.cfg --odmdata 0x94000 --bldtb tegra210-p3448-0000-p3449-0000-a02.dtb --applet nvtboot_recovery.bin --cmd "flash; reboot" --cfg flash.xml --chip 0x21 --bins "EBT cboot.bin; DTB tegra210-p3448-0000-p3449-0000-a02.dtb"
19:35:06 INFO : Flash Jetson Nano : saving flash command in /home/rjh-principle/nvidia/nvidia_sdk/JetPack_4.2.1_Linux_GA_P3448/Linux_for_Tegra/bootloader/flashcmd.txt
19:35:06 INFO : Flash Jetson Nano : saving Windows flash command to /home/rjh-principle/nvidia/nvidia_sdk/JetPack_4.2.1_Linux_GA_P3448/Linux_for_Tegra/bootloader/flash_win.bat
19:35:06 INFO : Flash Jetson Nano : *** Flashing target device started. ***
19:35:08 INFO : Flash Jetson Nano : Welcome to Tegra Flash
19:35:08 INFO : Flash Jetson Nano : version 1.0.0
19:35:08 INFO : Flash Jetson Nano : Type ? or help for help and q or quit to exit
19:35:08 INFO : Flash Jetson Nano : Use ! to execute system commands
19:35:08 INFO : Flash Jetson Nano : [ 0.0695 ] tegrasign --key None --getmode mode.txt
19:35:08 INFO : Flash Jetson Nano : [ 0.0706 ] Assuming zero filled SBK key
19:35:08 INFO : Flash Jetson Nano : [ 0.1225 ]
19:35:08 INFO : Flash Jetson Nano : [ 0.1226 ] Generating RCM messages
19:35:08 INFO : Flash Jetson Nano : [ 0.1440 ] tegrarcm --listrcm rcm_list.xml --chip 0x21 0 --download rcm nvtboot_recovery.bin 0 0
19:35:08 INFO : Flash Jetson Nano : [ 0.1453 ] RCM 0 is saved as rcm_0.rcm
19:35:08 INFO : Flash Jetson Nano : [ 0.1580 ] RCM 1 is saved as rcm_1.rcm
19:35:08 INFO : Flash Jetson Nano : [ 0.1584 ] List of rcm files are saved in rcm_list.xml
19:35:08 INFO : Flash Jetson Nano : [ 0.1671 ]
19:35:08 INFO : Flash Jetson Nano : [ 0.1671 ] Signing RCM messages
19:35:08 INFO : Flash Jetson Nano : [ 0.1681 ] tegrasign --key None --list rcm_list.xml --pubkeyhash pub_key.key
19:35:08 INFO : Flash Jetson Nano : [ 0.1701 ] Assuming zero filled SBK key
19:35:08 INFO : Flash Jetson Nano : [ 0.1900 ]
19:35:08 INFO : Flash Jetson Nano : [ 0.1900 ] Copying signature to RCM mesages
19:35:08 INFO : Flash Jetson Nano : [ 0.1911 ] tegrarcm --chip 0x21 0 --updatesig rcm_list_signed.xml
19:35:08 INFO : Flash Jetson Nano : [ 0.2032 ]
19:35:08 INFO : Flash Jetson Nano : [ 0.2032 ] Parsing partition layout
19:35:08 INFO : Flash Jetson Nano : [ 0.2200 ] tegraparser --pt flash.xml.tmp
19:35:08 INFO : Flash Jetson Nano : [ 0.2277 ]
19:35:08 INFO : Flash Jetson Nano : [ 0.2277 ] Creating list of images to be signed
19:35:08 INFO : Flash Jetson Nano : [ 0.2389 ] tegrahost --chip 0x21 0 --partitionlayout flash.xml.bin --list images_list.xml
19:35:08 INFO : Flash Jetson Nano : [ 0.2789 ]
19:35:08 INFO : Flash Jetson Nano : [ 0.2790 ] Generating signatures
19:35:08 INFO : Flash Jetson Nano : [ 0.2799 ] tegrasign --key None --list images_list.xml --pubkeyhash pub_key.key
19:35:08 INFO : Flash Jetson Nano : [ 0.2836 ] Assuming zero filled SBK key
19:35:08 INFO : Flash Jetson Nano : [ 0.3990 ]
19:35:08 INFO : Flash Jetson Nano : [ 0.3990 ] Generating br-bct
19:35:08 INFO : Flash Jetson Nano : [ 0.4378 ] tegrabct --bct P3448_A00_4GB_Micron_4GB_lpddr4_204Mhz_P987.cfg --chip 0x21 0
19:35:08 INFO : Flash Jetson Nano : [ 0.4390 ] Copying Sdram info from 0 to 1 set
19:35:08 INFO : Flash Jetson Nano : [ 0.4663 ] Copying Sdram info from 1 to 2 set
19:35:08 INFO : Flash Jetson Nano : [ 0.4666 ] Copying Sdram info from 2 to 3 set
19:35:08 INFO : Flash Jetson Nano : [ 0.4752 ]
19:35:08 INFO : Flash Jetson Nano : [ 0.4752 ] Updating boot device parameters
19:35:08 INFO : Flash Jetson Nano : [ 0.4762 ] tegrabct --bct P3448_A00_4GB_Micron_4GB_lpddr4_204Mhz_P987.bct --chip 0x21 0 --updatedevparam flash.xml.bin
19:35:08 INFO : Flash Jetson Nano : [ 0.4801 ] Warning: No sdram params
19:35:08 INFO : Flash Jetson Nano : [ 0.4937 ]
19:35:08 INFO : Flash Jetson Nano : [ 0.4937 ] Updating bl info
19:35:08 INFO : Flash Jetson Nano : [ 0.4950 ] tegrabct --bct P3448_A00_4GB_Micron_4GB_lpddr4_204Mhz_P987.bct --chip 0x21 0 --updateblinfo flash.xml.bin --updatesig images_list_signed.xml
19:35:08 INFO : Flash Jetson Nano : [ 0.5113 ]
19:35:08 INFO : Flash Jetson Nano : [ 0.5113 ] Updating secondary storage information into bct
19:35:08 INFO : Flash Jetson Nano : [ 0.5126 ] tegraparser --pt flash.xml.bin --chip 0x21 0 --updatecustinfo P3448_A00_4GB_Micron_4GB_lpddr4_204Mhz_P987.bct
19:35:08 INFO : Flash Jetson Nano : [ 0.5303 ]
19:35:08 INFO : Flash Jetson Nano : [ 0.5304 ] Updating Odmdata
19:35:08 INFO : Flash Jetson Nano : [ 0.5314 ] tegrabct --bct P3448_A00_4GB_Micron_4GB_lpddr4_204Mhz_P987.bct --chip 0x21 0 --updatefields Odmdata =0x94000
19:35:08 INFO : Flash Jetson Nano : [ 0.5324 ] Warning: No sdram params
19:35:08 INFO : Flash Jetson Nano : [ 0.5466 ]
19:35:08 INFO : Flash Jetson Nano : [ 0.5466 ] Get Signed section of bct
19:35:08 INFO : Flash Jetson Nano : [ 0.5479 ] tegrabct --bct P3448_A00_4GB_Micron_4GB_lpddr4_204Mhz_P987.bct --chip 0x21 0 --listbct bct_list.xml
19:35:08 INFO : Flash Jetson Nano : [ 0.5591 ]
19:35:08 INFO : Flash Jetson Nano : [ 0.5592 ] Signing BCT
19:35:08 INFO : Flash Jetson Nano : [ 0.5641 ] tegrasign --key None --list bct_list.xml --pubkeyhash pub_key.key
19:35:08 INFO : Flash Jetson Nano : [ 0.5680 ] Assuming zero filled SBK key
19:35:08 INFO : Flash Jetson Nano : [ 0.5752 ]
19:35:08 INFO : Flash Jetson Nano : [ 0.5752 ] Updating BCT with signature
19:35:08 INFO : Flash Jetson Nano : [ 0.5762 ] tegrabct --bct P3448_A00_4GB_Micron_4GB_lpddr4_204Mhz_P987.bct --chip 0x21 0 --updatesig bct_list_signed.xml
19:35:08 INFO : Flash Jetson Nano : [ 0.5936 ]
19:35:08 INFO : Flash Jetson Nano : [ 0.5936 ] Copying signatures
19:35:08 INFO : Flash Jetson Nano : [ 0.5947 ] tegrahost --chip 0x21 0 --partitionlayout flash.xml.bin --updatesig images_list_signed.xml
19:35:08 INFO : Flash Jetson Nano : [ 0.6233 ]
19:35:08 INFO : Flash Jetson Nano : [ 0.6234 ] Updating BFS information on BCT
19:35:08 INFO : Flash Jetson Nano : [ 0.6246 ] tegrabct --bct P3448_A00_4GB_Micron_4GB_lpddr4_204Mhz_P987.bct --chip 0x21 0 --updatebfsinfo flash.xml.bin
19:35:08 INFO : Flash Jetson Nano : [ 0.6332 ]
19:35:08 INFO : Flash Jetson Nano : [ 0.6332 ] Boot Rom communication
19:35:08 INFO : Flash Jetson Nano : [ 0.6343 ] tegrarcm --chip 0x21 0 --rcm rcm_list_signed.xml
19:35:08 INFO : Flash Jetson Nano : [ 0.6371 ] BootRom is not running
19:35:08 INFO : Flash Jetson Nano : [ 0.7187 ]
19:35:08 INFO : Flash Jetson Nano : [ 0.7187 ] Sending BCTs
19:35:08 INFO : Flash Jetson Nano : [ 0.7233 ] tegrarcm --download bct P3448_A00_4GB_Micron_4GB_lpddr4_204Mhz_P987.bct
19:35:08 INFO : Flash Jetson Nano : [ 0.7244 ] Applet version 00.01.0000
19:35:08 INFO : Flash Jetson Nano : [ 0.8948 ] Sending bct
19:35:08 INFO : Flash Jetson Nano : [ 0.8949 ] [...] 100%
19:35:08 INFO : Flash Jetson Nano : [ 1.2637 ]
19:35:08 INFO : Flash Jetson Nano : [ 1.2658 ] tegrahost --chip 0x21 --align cboot.bin
19:35:08 INFO : Flash Jetson Nano : [ 1.2764 ]
19:35:08 INFO : Flash Jetson Nano : [ 1.2776 ] tegrahost --magicid EBT --appendsigheader cboot.bin cboot.bin_blheader
19:35:08 INFO : Flash Jetson Nano : [ 1.2974 ]
19:35:08 INFO : Flash Jetson Nano : [ 1.2988 ] tegrasign --key None --list cboot.bin_list.xml
19:35:08 INFO : Flash Jetson Nano : [ 1.2998 ] Assuming zero filled SBK key
19:35:09 INFO : Flash Jetson Nano : [ 1.3349 ]
19:35:09 INFO : Flash Jetson Nano : [ 1.3364 ] tegrahost --updatesigheader cboot.bin_blheader.encrypt cboot.bin_blheader.hash zerosbk
19:35:09 INFO : Flash Jetson Nano : [ 1.3541 ]
19:35:09 INFO : Flash Jetson Nano : [ 1.3564 ] tegrahost --chip 0x21 --align tegra210-p3448-0000-p3449-0000-a02.dtb
19:35:09 INFO : Flash Jetson Nano : [ 1.3711 ]
19:35:09 INFO : Flash Jetson Nano : [ 1.3722 ] tegrahost --magicid DTB --appendsigheader tegra210-p3448-0000-p3449-0000-a02.dtb tegra210-p3448-0000-p3449-0000-a02.dtb_blheader
19:35:09 INFO : Flash Jetson Nano : [ 1.3844 ]
19:35:09 INFO : Flash Jetson Nano : [ 1.3857 ] tegrasign --key None --list tegra210-p3448-0000-p3449-0000-a02.dtb_list.xml
19:35:09 INFO : Flash Jetson Nano : [ 1.3878 ] Assuming zero filled SBK key
19:35:09 INFO : Flash Jetson Nano : [ 1.4150 ]
19:35:09 INFO : Flash Jetson Nano : [ 1.4165 ] tegrahost --updatesigheader tegra210-p3448-0000-p3449-0000-a02.dtb_blheader.encrypt tegra210-p3448-0000-p3449-0000-a02.dtb_blheader.hash zerosbk
19:35:09 INFO : Flash Jetson Nano : [ 1.4282 ]
19:35:09 INFO : Flash Jetson Nano : [ 1.4287 ] Sending bootloader and pre-requisite binaries
19:35:09 INFO : Flash Jetson Nano : [ 1.4356 ] tegrarcm --download ebt cboot.bin.encrypt 0 0 --download rp1 tegra210-p3448-0000-p3449-0000-a02.dtb.encrypt 0
19:35:09 INFO : Flash Jetson Nano : [ 1.4367 ] Applet version 00.01.0000
19:35:09 INFO : Flash Jetson Nano : [ 1.6047 ] Sending ebt
19:35:09 INFO : Flash Jetson Nano : [ 1.6051 ] [...] 100%
19:35:09 INFO : Flash Jetson Nano : [ 1.9730 ] Sending rp1
19:35:09 INFO : Flash Jetson Nano : [ 2.0363 ] [...] 100%
19:35:10 INFO : Flash Jetson Nano : [ 2.3104 ]
19:35:10 INFO : Flash Jetson Nano : [ 2.3125 ] tegrarcm --boot recovery
19:35:10 INFO : Flash Jetson Nano : [ 2.3149 ] Applet version 00.01.0000
19:35:12 INFO : Flash Jetson Nano : [ 2.6406 ]
19:35:12 INFO : Flash Jetson Nano : [ 2.6406 ] Retrieving storage infomation
19:35:12 INFO : Flash Jetson Nano : [ 2.6436 ] tegrarcm --oem platformdetails storage storage_info.bin
19:35:12 INFO : Flash Jetson Nano : [ 2.6473 ] Applet is not running on device. Continue with Bootloader
19:35:12 INFO : Flash Jetson Nano : [ 3.4670 ]
19:35:12 INFO : Flash Jetson Nano : [ 3.5025 ] tegradevflash --oem platformdetails storage storage_info.bin
19:35:12 INFO : Flash Jetson Nano : [ 3.5039 ] Cboot version 00.01.0000
19:35:12 INFO : Flash Jetson Nano : [ 3.6827 ] Saved platform info in storage_info.bin
19:35:12 INFO : Flash Jetson Nano : [ 3.8768 ]
19:35:12 INFO : Flash Jetson Nano : [ 3.8768 ] Flashing the device
19:35:12 INFO : Flash Jetson Nano : [ 3.8797 ] tegradevflash --pt flash.xml.bin --storageinfo storage_info.bin --create
19:35:12 INFO : Flash Jetson Nano : [ 3.8820 ] Cboot version 00.01.0000
19:35:12 INFO : Flash Jetson Nano : [ 4.0655 ] Writing partition GPT with gpt.bin
19:35:12 INFO : Flash Jetson Nano : [ 4.0660 ] [...] 100%
19:35:31 INFO : Flash Jetson Nano : [ 4.1722 ] Writing partition NVC with nvtboot.bin.encrypt
19:35:33 INFO : Flash Jetson Nano : [ 24.8326 ] [...] 100%
19:35:42 INFO : Flash Jetson Nano : [ 24.9909 ] Writing partition PT with flash.xml.bin
19:35:42 INFO : Flash Jetson Nano : [ 35.5895 ] [...] 100%
19:35:43 INFO : Flash Jetson Nano : [ 35.7000 ] Writing partition NVC_R with nvtboot.bin.encrypt
19:35:43 INFO : Flash Jetson Nano : [ 36.0417 ] [...] 100%
19:35:53 INFO : Flash Jetson Nano : [ 36.2078 ] Writing partition VER with qspi_bootblob_ver.txt
19:35:53 INFO : Flash Jetson Nano : [ 46.8069 ] [...] 100%
19:35:54 INFO : Flash Jetson Nano : [ 46.9438 ] Writing partition APP with system.img
19:37:56 INFO : Flash Jetson Nano : [ 47.2833 ] [ ] 000% [ 47.2833 ] [ ] 000% [ 47.2833 ] [ ] 000% [ 47.2833 ] [ ] 000% [ 47.2833 ] [ ] 000%
terminal.txt (28 KB)
May I know did you do anything to the system image?
Are you using your own system image? or you just do nothing but flash a fresh board?
The topic title is a little bit misleading
Thanks for the quick response… sorry for the misleading topic, I must have pasted some text into the field and didn’t notice.
Back to your question, I’ve done nothing to the image. I first flashed the SD with an image using my computer, to go through the training course and everything went great. I’m now trying to flash the OS and SDK components using the SDKManager, but I’m unable to get the OS flash to complete successfully.
Are the conversion errors in the log of any concern, or can they be ignored?
Thanks again,
Robert
one additional comment… if I re-flash the image to the SD card using my computer, insert the card in the device and power up, it always comes up in recovery mode. Is this to be expected?
->For sdkmanager,
Could you share your error message of flash error?
->For the sdcard
How do you tell the board is always in recovery mode? through lsusb command?
Please disregard. Problems were all related to running SDK Manager from a VBox VM. After setting up laptop as a dual boot system, everything is working for me now.
Thanks for following up. Very much appreciated.
Robert
