I currently fail to burn the OS and SDK using SDK Manager (I have tried at least 3 times), and even after re-burning the OS using “balenaEtcher”, I cannot boot now (no screen at all).
Explain the way of using SDK Manager and error message, hope to help me fix it, thank you.
- Install “ubuntu-18.04.4-desktop-amd64.iso” using Oracle VM VirtualBox
- Install the SDK Manager in “ubuntu-18.04.4-desktop-amd64”.
- Use balenaEtcher to burn “nv-jetson-nano-sd-card-imager-r32.4.2.zip” to SK card
- Power off jetson nano
- Confirm that the microSD Card has been inserted
6.jumper across the Force Recovery Mode pins (P3449-0000 B01 carrier board)
7.Enable use of the Power Jack [J25] by placing jumper across Power Select Header [J48] pins.
8.Connect the power adapter to the Power Jack [J25]
9.Rempve the jumper from the Force Recovery Mode pins (I didn’t perform this step when I first brushed the OS, I don’t know if it has any effect)
- Currently using USB to connect to the computer, the computer can still detect the device (Jetson Nano)
The following is the error message:
- 10:56:28 INFO : Flash Jetson Nano : # L4T BSP Information:
- 10:56:28 INFO : Flash Jetson Nano : # R32 , REVISION: 3.1
- 10:56:28 INFO : Flash Jetson Nano : ###############################################################################
- 10:56:28 INFO : Flash Jetson Nano : # Target Board Information:
- 10:56:28 INFO : Flash Jetson Nano : # Name: jetson-nano-qspi-sd, Board Family: t210ref, SoC: Tegra 210,
- 10:56:28 INFO : Flash Jetson Nano : # OpMode: production, Boot Authentication: ,
- 10:56:28 INFO : Flash Jetson Nano : ./tegraflash.py --chip 0x21 --applet “/home/leon/nvidia/nvidia_sdk/JetPack_4.3_Linux_JETSON_NANO_DEVKIT/Linux_for_Tegra/bootloader/nvtboot_recovery.bin” --skipuid --cmd “dump eeprom boardinfo cvm.bin”
- 10:56:29 INFO : Flash Jetson Nano : Welcome to Tegra Flash
- 10:56:29 INFO : Flash Jetson Nano : version 1.0.0
- 10:56:29 INFO : Flash Jetson Nano : Type ? or help for help and q or quit to exit
- 10:56:29 INFO : Flash Jetson Nano : Use ! to execute system commands
- 10:56:29 INFO : Flash Jetson Nano : [ 0.1087 ] Generating RCM messages
- 10:56:29 INFO : Flash Jetson Nano : [ 0.1114 ] tegrarcm --listrcm rcm_list.xml --chip 0x21 0 --download rcm /home/leon/nvidia/nvidia_sdk/JetPack_4.3_Linux_JETSON_NANO_DEVKIT/Linux_for_Tegra/bootloader/nvtboot_recovery.bin 0 0
- 10:56:29 INFO : Flash Jetson Nano : [ 0.1153 ] RCM 0 is saved as rcm_0.rcm
- 10:56:29 INFO : Flash Jetson Nano : [ 0.1506 ] RCM 1 is saved as rcm_1.rcm
- 10:56:29 INFO : Flash Jetson Nano : [ 0.1506 ] List of rcm files are saved in rcm_list.xml
- 10:56:29 INFO : Flash Jetson Nano : [ 0.1506 ] Signing RCM messages
- 10:56:29 INFO : Flash Jetson Nano : [ 0.1573 ] tegrasign --key None --list rcm_list.xml --pubkeyhash pub_key.key
- 10:56:29 INFO : Flash Jetson Nano : [ 0.1585 ] Assuming zero filled SBK key
- 10:56:29 INFO : Flash Jetson Nano : [ 0.1790 ]
- 10:56:29 INFO : Flash Jetson Nano : [ 0.1791 ] Copying signature to RCM mesages
- 10:56:29 INFO : Flash Jetson Nano : [ 0.1815 ] tegrarcm --chip 0x21 0 --updatesig rcm_list_signed.xml
- 10:56:29 INFO : Flash Jetson Nano : [ 0.1999 ]
- 10:56:29 INFO : Flash Jetson Nano : [ 0.1999 ] Boot Rom communication
- 10:56:29 INFO : Flash Jetson Nano : [ 0.2011 ] tegrarcm --chip 0x21 0 --rcm rcm_list_signed.xml --skipuid
- 10:56:29 INFO : Flash Jetson Nano : [ 0.2052 ] RCM version 0X210001
- 10:56:30 INFO : Flash Jetson Nano : [ 0.2699 ] Boot Rom communication completed
- 10:56:30 INFO : Flash Jetson Nano : [ 1.3511 ]
- 10:56:30 INFO : Flash Jetson Nano : [ 1.3512 ] dump EEPROM info
- 10:56:30 INFO : Flash Jetson Nano : [ 1.3525 ] tegrarcm --oem platformdetails eeprom /home/leon/nvidia/nvidia_sdk/JetPack_4.3_Linux_JETSON_NANO_DEVKIT/Linux_for_Tegra/bootloader/cvm.bin
- 10:56:30 INFO : Flash Jetson Nano : [ 1.3593 ] Applet version 00.01.0000
- 10:56:30 INFO : Flash Jetson Nano : [ 1.5437 ] Saved platform info in /home/leon/nvidia/nvidia_sdk/JetPack_4.3_Linux_JETSON_NANO_DEVKIT/Linux_for_Tegra/bootloader/cvm.bin
- 10:56:30 INFO : Flash Jetson Nano : [ 1.8161 ]
- 10:56:30 ERROR : Flash Jetson Nano : Board ID(3448) version(400)
- 10:56:31 INFO : Flash Jetson Nano : copying bctfile(/home/leon/nvidia/nvidia_sdk/JetPack_4.3_Linux_JETSON_NANO_DEVKIT/Linux_for_Tegra/bootloader/t210ref/BCT/P3448_A00_4GB_Micron_4GB_lpddr4_204Mhz_P987.cfg)… done.
- 10:56:31 INFO : Flash Jetson Nano : copying bootloader(/home/leon/nvidia/nvidia_sdk/JetPack_4.3_Linux_JETSON_NANO_DEVKIT/Linux_for_Tegra/bootloader/t210ref/cboot.bin)… done.
- 10:56:31 INFO : Flash Jetson Nano : copying initrd(/home/leon/nvidia/nvidia_sdk/JetPack_4.3_Linux_JETSON_NANO_DEVKIT/Linux_for_Tegra/bootloader/l4t_initrd.img)… done.
- 10:56:31 INFO : Flash Jetson Nano : populating kernel to rootfs… done.
- 10:56:31 INFO : Flash Jetson Nano : populating initrd to rootfs… done.
- 10:56:32 INFO : Flash Jetson Nano : populating /home/leon/nvidia/nvidia_sdk/JetPack_4.3_Linux_JETSON_NANO_DEVKIT/Linux_for_Tegra/kernel/dtb/tegra210-p3448-0000-p3449-0000-b00.dtb to rootfs… done.
- 10:56:32 INFO : Flash Jetson Nano : Making Boot image… done.
- 10:56:32 INFO : Flash Jetson Nano : Existing sosfile(/home/leon/nvidia/nvidia_sdk/JetPack_4.3_Linux_JETSON_NANO_DEVKIT/Linux_for_Tegra/bootloader/nvtboot_recovery.bin) reused.
- 10:56:32 INFO : Flash Jetson Nano : copying tegraboot(/home/leon/nvidia/nvidia_sdk/JetPack_4.3_Linux_JETSON_NANO_DEVKIT/Linux_for_Tegra/bootloader/t210ref/nvtboot.bin)… done.
- 10:56:32 INFO : Flash Jetson Nano : copying cpu_bootloader(/home/leon/nvidia/nvidia_sdk/JetPack_4.3_Linux_JETSON_NANO_DEVKIT/Linux_for_Tegra/bootloader/t210ref/cboot.bin)… done.
- 10:56:32 INFO : Flash Jetson Nano : copying bpffile(/home/leon/nvidia/nvidia_sdk/JetPack_4.3_Linux_JETSON_NANO_DEVKIT/Linux_for_Tegra/bootloader/t210ref/sc7entry-firmware.bin)… done.
- 10:56:32 INFO : Flash Jetson Nano : Existing badpagefile(/home/leon/nvidia/nvidia_sdk/JetPack_4.3_Linux_JETSON_NANO_DEVKIT/Linux_for_Tegra/bootloader/badpage.bin) reused.
- 10:56:32 INFO : Flash Jetson Nano : copying wb0boot(/home/leon/nvidia/nvidia_sdk/JetPack_4.3_Linux_JETSON_NANO_DEVKIT/Linux_for_Tegra/bootloader/t210ref/warmboot.bin)… done.
- 10:56:32 INFO : Flash Jetson Nano : Existing tosfile(/home/leon/nvidia/nvidia_sdk/JetPack_4.3_Linux_JETSON_NANO_DEVKIT/Linux_for_Tegra/bootloader/tos-mon-only.img) reused.
- 10:56:32 INFO : Flash Jetson Nano : Existing eksfile(/home/leon/nvidia/nvidia_sdk/JetPack_4.3_Linux_JETSON_NANO_DEVKIT/Linux_for_Tegra/bootloader/eks.img) reused.
- 10:56:32 INFO : Flash Jetson Nano : copying dtbfile(/home/leon/nvidia/nvidia_sdk/JetPack_4.3_Linux_JETSON_NANO_DEVKIT/Linux_for_Tegra/kernel/dtb/tegra210-p3448-0000-p3449-0000-b00.dtb)… done.
- 10:56:33 INFO : Flash Jetson Nano : Copying nv_boot_control.conf to rootfs
- 10:56:33 INFO : Flash Jetson Nano : Making system.img…
- 10:58:34 INFO : Flash Jetson Nano : populating rootfs from /home/leon/nvidia/nvidia_sdk/JetPack_4.3_Linux_JETSON_NANO_DEVKIT/Linux_for_Tegra/rootfs …
- 10:59:51 INFO : Flash Jetson Nano : done.
- 10:59:59 INFO : Flash Jetson Nano : Sync’ing system.img … done.
- 11:00:00 INFO : Flash Jetson Nano : Converting RAW image to Sparse image…
- 11:00:00 ERROR : Flash Jetson Nano :
- 11:00:00 INFO : Flash Jetson Nano : ---- Raw to Sparse Image Converter v1.0
- 11:00:00 ERROR : Flash Jetson Nano : ----------------------------
- 11:00:00 ERROR : Flash Jetson Nano : 0: RAW: 9437184( 9 blks) ==> 28:9437196
- 11:00:00 ERROR : Flash Jetson Nano : 1: SKP: 28311552( 27 blks) ==> 9437224:12
- 11:00:01 ERROR : Flash Jetson Nano : 2: RAW: 16777216( 16 blks) ==> 9437236:16777228
- 11:00:01 ERROR : Flash Jetson Nano : 3: SKP: 79691776( 76 blks) ==> 26214464:12
- 11:00:01 ERROR : Flash Jetson Nano : 4: RAW: 1048576( 1 blks) ==> 26214476:1048588
- 11:00:01 ERROR : Flash Jetson Nano : 5: SKP: 3145728( 3 blks) ==> 27263064:12
- 11:00:02 ERROR : Flash Jetson Nano : 6: RAW: 27262976( 26 blks) ==> 27263076:27262988
- 11:00:02 ERROR : Flash Jetson Nano : 7: SKP: 1048576( 1 blks) ==> 54526064:12
- 11:00:02 ERROR : Flash Jetson Nano : 8: RAW: 44040192( 42 blks) ==> 54526076:44040204
- 11:00:02 ERROR : Flash Jetson Nano : 9: SKP: 15728640( 15 blks) ==> 98566280:12
- 11:00:04 ERROR : Flash Jetson Nano : 10: RAW: 177209344( 169 blks) ==> 98566292:177209356
- 11:00:04 ERROR : Flash Jetson Nano : 11: SKP: 3145728( 3 blks) ==> 275775648:12
- 11:00:06 ERROR : Flash Jetson Nano : 12: RAW: 205520896( 196 blks) ==> 275775660:205520908
- 11:00:06 ERROR : Flash Jetson Nano : 13: SKP: 1048576( 1 blks) ==> 481296568:12
- 11:00:07 ERROR : Flash Jetson Nano : 14: RAW: 58720256( 56 blks) ==> 481296580:58720268
- 11:00:07 ERROR : Flash Jetson Nano : 15: SKP: 3145728( 3 blks) ==> 540016848:12
- 11:00:07 ERROR : Flash Jetson Nano : 16: RAW: 7340032( 7 blks) ==> 540016860:7340044
- 11:00:07 ERROR : Flash Jetson Nano : 17: SKP: 1048576( 1 blks) ==> 547356904:12
- 11:00:08 ERROR : Flash Jetson Nano : 18: RAW: 256901120( 245 blks) ==> 547356916:256901132
- 11:00:08 ERROR : Flash Jetson Nano : 19: SKP: 3145728( 3 blks) ==> 804258048:12
- 11:00:08 ERROR : Flash Jetson Nano : 20: RAW: 118489088( 113 blks) ==> 804258060:118489100
- 11:00:08 ERROR : Flash Jetson Nano : 21: SKP: 3145728( 3 blks) ==> 922747160:12
- 11:00:08 ERROR : Flash Jetson Nano : 22: RAW: 66060288( 63 blks) ==> 922747172:66060300
- 11:00:08 ERROR : Flash Jetson Nano : 23: SKP: 1048576( 1 blks) ==> 988807472:12
- 11:00:08 ERROR : Flash Jetson Nano : 24: RAW: 55574528( 53 blks) ==> 988807484:55574540
- 11:00:08 ERROR : Flash Jetson Nano : 25: SKP: 3145728( 3 blks) ==> 1044382024:12
- 11:00:09 ERROR : Flash Jetson Nano : 26: RAW: 17825792( 17 blks) ==> 1044382036:17825804
- 11:00:09 ERROR : Flash Jetson Nano : 27: SKP: 3145728( 3 blks) ==> 1062207840:12
- 11:00:09 ERROR : Flash Jetson Nano : 28: RAW: 10485760( 10 blks) ==> 1062207852:10485772
- 11:00:09 ERROR : Flash Jetson Nano : 29: SKP: 2097152( 2 blks) ==> 1072693624:12
- 11:00:09 ERROR : Flash Jetson Nano : 30: RAW: 72351744( 69 blks) ==> 1072693636:72351756
- 11:00:09 ERROR : Flash Jetson Nano : 31: SKP: 3145728( 3 blks) ==> 1145045392:12
- 11:00:09 ERROR : Flash Jetson Nano : 32: RAW: 63963136( 61 blks) ==> 1145045404:63963148
- 11:00:09 ERROR : Flash Jetson Nano : 33: SKP: 3145728( 3 blks) ==> 1209008552:12
- 11:00:09 ERROR : Flash Jetson Nano : 34: RAW: 22020096( 21 blks) ==> 1209008564:22020108
- 11:00:09 ERROR : Flash Jetson Nano : 35: SKP: 3145728( 3 blks) ==> 1231028672:12
- 11:00:09 ERROR : Flash Jetson Nano : 36: RAW: 55574528( 53 blks) ==> 1231028684:55574540
- 11:00:09 ERROR : Flash Jetson Nano : 37: SKP: 3145728( 3 blks) ==> 1286603224:12
- 11:00:09 ERROR : Flash Jetson Nano : 38: RAW: 29360128( 28 blks) ==> 1286603236:29360140
- 11:00:09 ERROR : Flash Jetson Nano : 39: SKP: 1048576( 1 blks) ==> 1315963376:12
- 11:00:09 ERROR : Flash Jetson Nano : 40: RAW: 110100480( 105 blks) ==> 1315963388:110100492
- 11:00:10 ERROR : Flash Jetson Nano : 41: SKP: 2097152( 2 blks) ==> 1426063880:12
- 11:00:10 ERROR : Flash Jetson Nano : 42: RAW: 165675008( 158 blks) ==> 1426063892:165675020
- 11:00:10 ERROR : Flash Jetson Nano : 43: SKP: 2097152( 2 blks) ==> 1591738912:12
- 11:00:10 ERROR : Flash Jetson Nano : 44: RAW: 32505856( 31 blks) ==> 1591738924:32505868
- 11:00:10 ERROR : Flash Jetson Nano : 45: SKP: 1048576( 1 blks) ==> 1624244792:12
- 11:00:10 ERROR : Flash Jetson Nano : 46: RAW: 13631488( 13 blks) ==> 1624244804:13631500
- 11:00:11 ERROR : Flash Jetson Nano : 47: SKP: 338690048( 323 blks) ==> 1637876304:12
- 11:00:12 ERROR : Flash Jetson Nano : 48: RAW: 10485760( 10 blks) ==> 1637876316:10485772
- 11:00:12 ERROR : Flash Jetson Nano : 49: SKP: 23068672( 22 blks) ==> 1648362088:12
- 11:00:13 ERROR : Flash Jetson Nano : 50: RAW: 15728640( 15 blks) ==> 1648362100:15728652
- 11:00:13 ERROR : Flash Jetson Nano : 51: SKP: 84934656( 81 blks) ==> 1664090752:12
- 11:00:23 ERROR : Flash Jetson Nano : 52: RAW: 355467264( 339 blks) ==> 1664090764:355467276
- 11:00:24 ERROR : Flash Jetson Nano : 53: SKP: 718274560( 685 blks) ==> 2019558040:12
- 11:00:24 ERROR : Flash Jetson Nano : 54: RAW: 1048576( 1 blks) ==> 2019558052:1048588
- 11:00:24 ERROR : Flash Jetson Nano : 55: SKP: 267386880( 255 blks) ==> 2020606640:12
- 11:00:24 ERROR : Flash Jetson Nano : 56: RAW: 1048576( 1 blks) ==> 2020606652:1048588
- 11:00:26 ERROR : Flash Jetson Nano : 57: SKP: 670040064( 639 blks) ==> 2021655240:12
- 11:00:26 ERROR : Flash Jetson Nano : 58: RAW: 7340032( 7 blks) ==> 2021655252:7340044
- 11:00:26 ERROR : Flash Jetson Nano : 59: SKP: 26214400( 25 blks) ==> 2028995296:12
- 11:00:26 ERROR : Flash Jetson Nano : 60: RAW: 13631488( 13 blks) ==> 2028995308:13631500
- 11:00:27 ERROR : Flash Jetson Nano : 61: SKP: 87031808( 83 blks) ==> 2042626808:12
- 11:00:34 ERROR : Flash Jetson Nano : 62: RAW: 421527552( 402 blks) ==> 2042626820:421527564
- 11:00:36 ERROR : Flash Jetson Nano : 63: SKP: 1591738368( 1518 blks) ==> 2464154384:12
- 11:00:36 ERROR : Flash Jetson Nano : 64: RAW: 4194304( 4 blks) ==> 2464154396:4194316
- 11:00:36 ERROR : Flash Jetson Nano : 65: SKP: 29360128( 28 blks) ==> 2468348712:12
- 11:00:37 ERROR : Flash Jetson Nano : 66: RAW: 11534336( 11 blks) ==> 2468348724:11534348
- 11:00:37 ERROR : Flash Jetson Nano : 67: SKP: 89128960( 85 blks) ==> 2479883072:12
- 11:00:37 ERROR : Flash Jetson Nano : 68: RAW: 1048576( 1 blks) ==> 2479883084:1048588
- 11:00:37 ERROR : Flash Jetson Nano : 69: SKP: 3145728( 3 blks) ==> 2480931672:12
- 11:00:38 ERROR : Flash Jetson Nano : 70: RAW: 159383552( 152 blks) ==> 2480931684:159383564
- 11:00:41 ERROR : Flash Jetson Nano : 71: SKP: 1849688064( 1764 blks) ==> 2640315248:12
- 11:00:41 ERROR : Flash Jetson Nano : 72: RAW: 5242880( 5 blks) ==> 2640315260:5242892
- 11:00:41 ERROR : Flash Jetson Nano : 73: SKP: 28311552( 27 blks) ==> 2645558152:12
- 11:00:42 ERROR : Flash Jetson Nano : 74: RAW: 5242880( 5 blks) ==> 2645558164:5242892
- 11:00:42 ERROR : Flash Jetson Nano : 75: SKP: 95420416( 91 blks) ==> 2650801056:12
- 11:00:45 ERROR : Flash Jetson Nano : 76: RAW: 203423744( 194 blks) ==> 2650801068:203423756
- 11:00:45 ERROR : Flash Jetson Nano : 77: SKP: 2097152( 2 blks) ==> 2854224824:12
- 11:00:50 ERROR : Flash Jetson Nano : 78: RAW: 270532608( 258 blks) ==> 2854224836:270532620
- 11:00:50 ERROR : Flash Jetson Nano : 79: SKP: 27262976( 26 blks) ==> 3124757456:12
- 11:00:50 ERROR : Flash Jetson Nano : 80: RAW: 33554432( 32 blks) ==> 3124757468:33554444
- 11:00:52 ERROR : Flash Jetson Nano : 81: SKP: 1476395008( 1408 blks) ==> 3158311912:12
- 11:00:52 ERROR : Flash Jetson Nano : 82: RAW: 6291456( 6 blks) ==> 3158311924:6291468
- 11:00:52 ERROR : Flash Jetson Nano : 83: SKP: 27262976( 26 blks) ==> 3164603392:12
- 11:00:53 ERROR : Flash Jetson Nano : 84: RAW: 13631488( 13 blks) ==> 3164603404:13631500
- 11:00:53 ERROR : Flash Jetson Nano : 85: SKP: 87031808( 83 blks) ==> 3178234904:12
- 11:00:53 ERROR : Flash Jetson Nano : 86: RAW: 1048576( 1 blks) ==> 3178234916:1048588
- 11:00:53 ERROR : Flash Jetson Nano : 87: SKP: 3145728( 3 blks) ==> 3179283504:12
- 11:01:04 ERROR : Flash Jetson Nano : 88: RAW: 516947968( 493 blks) ==> 3179283516:516947980
- 11:01:05 ERROR : Flash Jetson Nano : 89: SKP: 1492123648( 1423 blks) ==> 3696231496:12
- 11:01:05 ERROR : Flash Jetson Nano : 90: RAW: 7340032( 7 blks) ==> 3696231508:7340044
- 11:01:05 ERROR : Flash Jetson Nano : 91: SKP: 26214400( 25 blks) ==> 3703571552:12
- 11:01:05 ERROR : Flash Jetson Nano : 92: RAW: 17825792( 17 blks) ==> 3703571564:17825804
- 11:01:06 ERROR : Flash Jetson Nano : 93: SKP: 82837504( 79 blks) ==> 3721397368:12
- 11:01:21 ERROR : Flash Jetson Nano : 94: RAW: 794820608( 758 blks) ==> 3721397380:794820620
- 11:01:22 ERROR : Flash Jetson Nano : 95: SKP: 1218445312( 1162 blks) ==> 4516218000:12
- 11:01:22 ERROR : Flash Jetson Nano : – Total:
- 11:01:22 ERROR : Flash Jetson Nano : ---------------------------------------------------
- 11:01:22 ERROR : Flash Jetson Nano : 96 CHUNK 15032385536( 14336 blks) ==> 4516218012(4307 blks)
- 11:01:22 INFO : Flash Jetson Nano : done.
- 11:01:22 INFO : Flash Jetson Nano : system.img built successfully.
- 11:01:22 INFO : Flash Jetson Nano : Existing tbcfile(/home/leon/nvidia/nvidia_sdk/JetPack_4.3_Linux_JETSON_NANO_DEVKIT/Linux_for_Tegra/bootloader/nvtboot_cpu.bin) reused.
- 11:01:22 INFO : Flash Jetson Nano : copying tbcdtbfile(/home/leon/nvidia/nvidia_sdk/JetPack_4.3_Linux_JETSON_NANO_DEVKIT/Linux_for_Tegra/kernel/dtb/tegra210-p3448-0000-p3449-0000-b00.dtb)… done.
- 11:01:23 INFO : Flash Jetson Nano : copying cfgfile(/home/leon/nvidia/nvidia_sdk/JetPack_4.3_Linux_JETSON_NANO_DEVKIT/Linux_for_Tegra/bootloader/t210ref/cfg/flash_l4t_t210_spi_sd_p3448.xml) to flash.xml… done.
- 11:01:23 INFO : Flash Jetson Nano : copying flasher(/home/leon/nvidia/nvidia_sdk/JetPack_4.3_Linux_JETSON_NANO_DEVKIT/Linux_for_Tegra/bootloader/t210ref/cboot.bin)… done.
- 11:01:23 INFO : Flash Jetson Nano : Existing flashapp(/home/leon/nvidia/nvidia_sdk/JetPack_4.3_Linux_JETSON_NANO_DEVKIT/Linux_for_Tegra/bootloader/tegraflash.py) reused.
- 11:01:23 INFO : Flash Jetson Nano : ./tegraflash.py --bl cboot.bin --bct P3448_A00_4GB_Micron_4GB_lpddr4_204Mhz_P987.cfg --odmdata 0x94000 --bldtb tegra210-p3448-0000-p3449-0000-b00.dtb --applet nvtboot_recovery.bin --cmd “flash; reboot” --cfg flash.xml --chip 0x21 --bins “EBT cboot.bin; DTB tegra210-p3448-0000-p3449-0000-b00.dtb”
- 11:01:23 INFO : Flash Jetson Nano : saving flash command in /home/leon/nvidia/nvidia_sdk/JetPack_4.3_Linux_JETSON_NANO_DEVKIT/Linux_for_Tegra/bootloader/flashcmd.txt
- 11:01:23 INFO : Flash Jetson Nano : saving Windows flash command to /home/leon/nvidia/nvidia_sdk/JetPack_4.3_Linux_JETSON_NANO_DEVKIT/Linux_for_Tegra/bootloader/flash_win.bat
- 11:01:23 INFO : Flash Jetson Nano : *** Flashing target device started. ***
- 11:01:26 INFO : Flash Jetson Nano : Welcome to Tegra Flash
- 11:01:26 INFO : Flash Jetson Nano : version 1.0.0
- 11:01:26 INFO : Flash Jetson Nano : Type ? or help for help and q or quit to exit
- 11:01:26 INFO : Flash Jetson Nano : Use ! to execute system commands
- 11:01:26 INFO : Flash Jetson Nano : [ 0.0427 ] tegrasign --key None --getmode mode.txt
- 11:01:26 INFO : Flash Jetson Nano : [ 0.0437 ] Assuming zero filled SBK key
- 11:01:26 INFO : Flash Jetson Nano : [ 0.1604 ]
- 11:01:26 INFO : Flash Jetson Nano : [ 0.1605 ] Generating RCM messages
- 11:01:26 INFO : Flash Jetson Nano : [ 0.1652 ] tegrarcm --listrcm rcm_list.xml --chip 0x21 0 --download rcm nvtboot_recovery.bin 0 0
- 11:01:26 INFO : Flash Jetson Nano : [ 0.1669 ] RCM 0 is saved as rcm_0.rcm
- 11:01:26 INFO : Flash Jetson Nano : [ 0.1873 ] RCM 1 is saved as rcm_1.rcm
- 11:01:26 INFO : Flash Jetson Nano : [ 0.1876 ] List of rcm files are saved in rcm_list.xml
- 11:01:26 INFO : Flash Jetson Nano : [ 0.1990 ]
- 11:01:26 INFO : Flash Jetson Nano : [ 0.1992 ] Signing RCM messages
- 11:01:26 INFO : Flash Jetson Nano : [ 0.2033 ] tegrasign --key None --list rcm_list.xml --pubkeyhash pub_key.key
- 11:01:26 INFO : Flash Jetson Nano : [ 0.2071 ] Assuming zero filled SBK key
- 11:01:26 INFO : Flash Jetson Nano : [ 0.2389 ]
- 11:01:26 INFO : Flash Jetson Nano : [ 0.2390 ] Copying signature to RCM mesages
- 11:01:26 INFO : Flash Jetson Nano : [ 0.2400 ] tegrarcm --chip 0x21 0 --updatesig rcm_list_signed.xml
- 11:01:26 INFO : Flash Jetson Nano : [ 0.2680 ]
- 11:01:26 INFO : Flash Jetson Nano : [ 0.2680 ] Parsing partition layout
- 11:01:26 INFO : Flash Jetson Nano : [ 0.2930 ] tegraparser --pt flash.xml.tmp
- 11:01:26 INFO : Flash Jetson Nano : [ 0.3075 ]
- 11:01:26 INFO : Flash Jetson Nano : [ 0.3075 ] Creating list of images to be signed
- 11:01:26 INFO : Flash Jetson Nano : [ 0.3200 ] tegrahost --chip 0x21 0 --partitionlayout flash.xml.bin --list images_list.xml
- 11:01:26 INFO : Flash Jetson Nano : [ 0.3941 ]
- 11:01:26 INFO : Flash Jetson Nano : [ 0.3942 ] Generating signatures
- 11:01:26 INFO : Flash Jetson Nano : [ 0.3993 ] tegrasign --key None --list images_list.xml --pubkeyhash pub_key.key
- 11:01:26 INFO : Flash Jetson Nano : [ 0.4007 ] Assuming zero filled SBK key
- 11:01:26 INFO : Flash Jetson Nano : [ 0.4965 ]
- 11:01:26 INFO : Flash Jetson Nano : [ 0.4966 ] Generating br-bct
- 11:01:26 INFO : Flash Jetson Nano : [ 0.4994 ] tegrabct --bct P3448_A00_4GB_Micron_4GB_lpddr4_204Mhz_P987.cfg --chip 0x21 0
- 11:01:26 INFO : Flash Jetson Nano : [ 0.5009 ] Copying Sdram info from 0 to 1 set
- 11:01:26 INFO : Flash Jetson Nano : [ 0.5095 ] Copying Sdram info from 1 to 2 set
- 11:01:26 INFO : Flash Jetson Nano : [ 0.5097 ] Copying Sdram info from 2 to 3 set
- 11:01:26 INFO : Flash Jetson Nano : [ 0.5195 ]
- 11:01:26 INFO : Flash Jetson Nano : [ 0.5195 ] Updating boot device parameters
- 11:01:26 INFO : Flash Jetson Nano : [ 0.5208 ] tegrabct --bct P3448_A00_4GB_Micron_4GB_lpddr4_204Mhz_P987.bct --chip 0x21 0 --updatedevparam flash.xml.bin
- 11:01:26 INFO : Flash Jetson Nano : [ 0.5248 ] Warning: No sdram params
- 11:01:26 INFO : Flash Jetson Nano : [ 0.5340 ]
- 11:01:26 INFO : Flash Jetson Nano : [ 0.5340 ] Updating bl info
- 11:01:26 INFO : Flash Jetson Nano : [ 0.5351 ] tegrabct --bct P3448_A00_4GB_Micron_4GB_lpddr4_204Mhz_P987.bct --chip 0x21 0 --updateblinfo flash.xml.bin --updatesig images_list_signed.xml
- 11:01:26 INFO : Flash Jetson Nano : [ 0.5472 ]
- 11:01:26 INFO : Flash Jetson Nano : [ 0.5472 ] Updating secondary storage information into bct
- 11:01:26 INFO : Flash Jetson Nano : [ 0.5492 ] tegraparser --pt flash.xml.bin --chip 0x21 0 --updatecustinfo P3448_A00_4GB_Micron_4GB_lpddr4_204Mhz_P987.bct
- 11:01:26 INFO : Flash Jetson Nano : [ 0.5767 ]
- 11:01:26 INFO : Flash Jetson Nano : [ 0.5767 ] Updating Odmdata
- 11:01:26 INFO : Flash Jetson Nano : [ 0.5777 ] tegrabct --bct P3448_A00_4GB_Micron_4GB_lpddr4_204Mhz_P987.bct --chip 0x21 0 --updatefields Odmdata =0x94000
- 11:01:26 INFO : Flash Jetson Nano : [ 0.5790 ] Warning: No sdram params
- 11:01:26 INFO : Flash Jetson Nano : [ 0.5923 ]
- 11:01:26 INFO : Flash Jetson Nano : [ 0.5923 ] Get Signed section of bct
- 11:01:26 INFO : Flash Jetson Nano : [ 0.5933 ] tegrabct --bct P3448_A00_4GB_Micron_4GB_lpddr4_204Mhz_P987.bct --chip 0x21 0 --listbct bct_list.xml
- 11:01:26 INFO : Flash Jetson Nano : [ 0.6104 ]
- 11:01:26 INFO : Flash Jetson Nano : [ 0.6104 ] Signing BCT
- 11:01:26 INFO : Flash Jetson Nano : [ 0.6139 ] tegrasign --key None --list bct_list.xml --pubkeyhash pub_key.key
- 11:01:26 INFO : Flash Jetson Nano : [ 0.6207 ] Assuming zero filled SBK key
- 11:01:26 INFO : Flash Jetson Nano : [ 0.6351 ]
- 11:01:26 INFO : Flash Jetson Nano : [ 0.6352 ] Updating BCT with signature
- 11:01:26 INFO : Flash Jetson Nano : [ 0.6363 ] tegrabct --bct P3448_A00_4GB_Micron_4GB_lpddr4_204Mhz_P987.bct --chip 0x21 0 --updatesig bct_list_signed.xml
- 11:01:26 INFO : Flash Jetson Nano : [ 0.6455 ]
- 11:01:26 INFO : Flash Jetson Nano : [ 0.6455 ] Copying signatures
- 11:01:26 INFO : Flash Jetson Nano : [ 0.6535 ] tegrahost --chip 0x21 0 --partitionlayout flash.xml.bin --updatesig images_list_signed.xml
- 11:01:26 INFO : Flash Jetson Nano : [ 0.6788 ]
- 11:01:26 INFO : Flash Jetson Nano : [ 0.6788 ] Updating BFS information on BCT
- 11:01:26 INFO : Flash Jetson Nano : [ 0.6799 ] tegrabct --bct P3448_A00_4GB_Micron_4GB_lpddr4_204Mhz_P987.bct --chip 0x21 0 --updatebfsinfo flash.xml.bin
- 11:01:26 INFO : Flash Jetson Nano : [ 0.6998 ]
- 11:01:26 INFO : Flash Jetson Nano : [ 0.6998 ] Boot Rom communication
- 11:01:26 INFO : Flash Jetson Nano : [ 0.7042 ] tegrarcm --chip 0x21 0 --rcm rcm_list_signed.xml
- 11:01:26 INFO : Flash Jetson Nano : [ 0.7056 ] BootRom is not running
- 11:01:26 INFO : Flash Jetson Nano : [ 0.7605 ]
- 11:01:26 INFO : Flash Jetson Nano : [ 0.7605 ] Sending BCTs
- 11:01:26 INFO : Flash Jetson Nano : [ 0.7615 ] tegrarcm --download bct P3448_A00_4GB_Micron_4GB_lpddr4_204Mhz_P987.bct
- 11:01:26 INFO : Flash Jetson Nano : [ 0.7627 ] Applet version 00.01.0000
- 11:01:26 INFO : Flash Jetson Nano : [ 0.9358 ] Sending bct
- 11:01:26 INFO : Flash Jetson Nano : [ 0.9360 ] […] 100%
- 11:01:27 INFO : Flash Jetson Nano : [ 1.3059 ]
- 11:01:27 INFO : Flash Jetson Nano : [ 1.3070 ] tegrahost --chip 0x21 --align cboot.bin
- 11:01:27 INFO : Flash Jetson Nano : [ 1.3183 ]
- 11:01:27 INFO : Flash Jetson Nano : [ 1.3193 ] tegrahost --magicid EBT --appendsigheader cboot.bin cboot.bin_blheader
- 11:01:27 INFO : Flash Jetson Nano : [ 1.3398 ]
- 11:01:27 INFO : Flash Jetson Nano : [ 1.3411 ] tegrasign --key None --list cboot.bin_list.xml
- 11:01:27 INFO : Flash Jetson Nano : [ 1.3420 ] Assuming zero filled SBK key
- 11:01:27 INFO : Flash Jetson Nano : [ 1.3875 ]
- 11:01:27 INFO : Flash Jetson Nano : [ 1.3890 ] tegrahost --updatesigheader cboot.bin_blheader.encrypt cboot.bin_blheader.hash zerosbk
- 11:01:27 INFO : Flash Jetson Nano : [ 1.4068 ]
- 11:01:27 INFO : Flash Jetson Nano : [ 1.4106 ] tegrahost --chip 0x21 --align tegra210-p3448-0000-p3449-0000-b00.dtb
- 11:01:27 INFO : Flash Jetson Nano : [ 1.4275 ]
- 11:01:27 INFO : Flash Jetson Nano : [ 1.4285 ] tegrahost --magicid DTB --appendsigheader tegra210-p3448-0000-p3449-0000-b00.dtb tegra210-p3448-0000-p3449-0000-b00.dtb_blheader
- 11:01:27 INFO : Flash Jetson Nano : [ 1.4477 ]
- 11:01:27 INFO : Flash Jetson Nano : [ 1.4575 ] tegrasign --key None --list tegra210-p3448-0000-p3449-0000-b00.dtb_list.xml
- 11:01:27 INFO : Flash Jetson Nano : [ 1.4606 ] Assuming zero filled SBK key
- 11:01:27 INFO : Flash Jetson Nano : [ 1.4840 ]
- 11:01:27 INFO : Flash Jetson Nano : [ 1.4901 ] tegrahost --updatesigheader tegra210-p3448-0000-p3449-0000-b00.dtb_blheader.encrypt tegra210-p3448-0000-p3449-0000-b00.dtb_blheader.hash zerosbk
- 11:01:27 INFO : Flash Jetson Nano : [ 1.5089 ]
- 11:01:27 INFO : Flash Jetson Nano : [ 1.5118 ] Sending bootloader and pre-requisite binaries
- 11:01:27 INFO : Flash Jetson Nano : [ 1.5130 ] tegrarcm --download ebt cboot.bin.encrypt 0 0 --download rp1 tegra210-p3448-0000-p3449-0000-b00.dtb.encrypt 0
- 11:01:27 INFO : Flash Jetson Nano : [ 1.5161 ] Applet version 00.01.0000
- 11:01:27 INFO : Flash Jetson Nano : [ 1.7150 ] Sending ebt
- 11:01:27 INFO : Flash Jetson Nano : [ 1.7154 ] […] 100%
- 11:01:28 INFO : Flash Jetson Nano : [ 2.0799 ] Sending rp1
- 11:01:28 INFO : Flash Jetson Nano : [ 2.1500 ] […] 100%
- 11:01:28 INFO : Flash Jetson Nano : [ 2.4378 ]
- 11:01:28 INFO : Flash Jetson Nano : [ 2.4392 ] tegrarcm --boot recovery
- 11:01:28 INFO : Flash Jetson Nano : [ 2.4415 ] Applet version 00.01.0000
- 11:01:29 INFO : Flash Jetson Nano : [ 2.7558 ]
- 11:01:29 INFO : Flash Jetson Nano : [ 2.7558 ] Retrieving storage infomation
- 11:01:29 INFO : Flash Jetson Nano : [ 2.7569 ] tegrarcm --oem platformdetails storage storage_info.bin
- 11:01:29 INFO : Flash Jetson Nano : [ 2.7579 ] Applet is not running on device. Continue with Bootloader
- 11:01:29 INFO : Flash Jetson Nano : [ 3.7735 ]
- 11:01:29 INFO : Flash Jetson Nano : [ 3.7937 ] tegradevflash --oem platformdetails storage storage_info.bin
- 11:01:29 INFO : Flash Jetson Nano : [ 3.7950 ] Cboot version 00.01.0000
- 11:01:30 INFO : Flash Jetson Nano : [ 3.9946 ] Saved platform info in storage_info.bin
- 11:01:30 INFO : Flash Jetson Nano : [ 4.1778 ]
- 11:01:30 INFO : Flash Jetson Nano : [ 4.1779 ] Flashing the device
- 11:01:30 INFO : Flash Jetson Nano : [ 4.1796 ] tegradevflash --pt flash.xml.bin --storageinfo storage_info.bin --create
- 11:01:30 INFO : Flash Jetson Nano : [ 4.1806 ] Cboot version 00.01.0000
- 11:01:30 INFO : Flash Jetson Nano : [ 4.3534 ] Writing partition GPT with gpt.bin
- 11:01:30 INFO : Flash Jetson Nano : [ 4.3537 ] […] 100%
- 11:01:48 INFO : Flash Jetson Nano : [ 4.4589 ] Writing partition NVC with nvtboot.bin.encrypt
- 11:01:48 INFO : Flash Jetson Nano : [ 22.6822 ] […] 100%
- 11:01:58 INFO : Flash Jetson Nano : [ 22.8442 ] Writing partition PT with flash.xml.bin
- 11:01:58 INFO : Flash Jetson Nano : [ 32.9362 ] […] 100%
- 11:01:59 INFO : Flash Jetson Nano : [ 33.0399 ] Writing partition NVC_R with nvtboot.bin.encrypt
- 11:01:59 INFO : Flash Jetson Nano : [ 33.3762 ] […] 100%
- 11:02:09 INFO : Flash Jetson Nano : [ 33.5320 ] Writing partition VER_b with qspi_bootblob_ver.txt
- 11:02:09 INFO : Flash Jetson Nano : [ 43.6370 ] […] 100%
- 11:02:09 INFO : Flash Jetson Nano : [ 43.7522 ] Writing partition VER with qspi_bootblob_ver.txt
- 11:02:10 INFO : Flash Jetson Nano : [ 44.0932 ] […] 100%
- 11:02:10 INFO : Flash Jetson Nano : [ 44.1948 ] Writing partition APP with system.img
- 11:04:27 INFO : Flash Jetson Nano : [ 44.5364 ] 000% [ 44.5364 ] 000% [ 44.5364 ] 000% [ 44.5364 ] 000% [ 44.5364 ] 000% [ 44.5364 ] 000% [ 44.5364 ] 000% [ 44.5364 ] 000% [ 44.5364 ] 000% [ 44.5364 ] 000% [ 44.5364 ] 000% [ 44.5364 ] 000% [ 44.5364 ] 000% [ 44.5364 ] 000% [ 44.5364 ] 000% [ 44.5364 ] 000% [ 44.5364 ] 000% [ 44.5364 ] 000% [ 44.5364 ] 000% [ 44.5364 ] 000% [ 44.5364 ] 000% [ 44.5364 ] 000% [ 44.5364 ] 000% [ 44.5364 ] 000% [ 44.5364 ] 000% [ 44.5364 ] 000% [ 44.5364 ] 000% [ 44.5364 ] 000% [ 44.5364 ] 000% [ 44.5364 ] 000% [ 44.5364 ] 000% [ 44.5364 ] 000% [ 44.5364 ] 000% [ 44.5364 ] 000% [ 44.5364 ] 000% [ 44.5364 ] 000% [ 44.5364 ] 000% [ 44.5364 ] 000% [ 44.5364 ] 000% [ 44.5364 ] 000% [ 44.5364 ] 000% [ 44.5364 ] 000%
- 11:23:26 ERROR : Flash Jetson Nano : Install ‘Flash Jetson Nano’ failure, NV_L4T_FLASH_NANO_DEVKIT_WITH_OS_IMAGE_COMP install timeout, user cancelled installation.
- 11:23:26 INFO : Device Mode Host Setup in Target SDK : Install ‘Device Mode Host Setup in Target SDK’ Skipped
- 11:23:26 INFO : DateTime Target Setup : Install ‘DateTime Target Setup’ Skipped
- 11:23:26 INFO : CUDA Toolkit for L4T : Install ‘CUDA Toolkit for L4T’ Skipped
- 11:23:26 INFO : cuDNN on Target : Install ‘cuDNN on Target’ Skipped
- 11:23:26 INFO : TensorRT on Target : Install ‘TensorRT on Target’ Skipped
- 11:23:26 INFO : OpenCV on Target : Install ‘OpenCV on Target’ Skipped
- 11:23:26 INFO : VisionWorks on Target : Install ‘VisionWorks on Target’ Skipped
- 11:23:26 INFO : VPI : Install ‘VPI’ Skipped
- 11:23:26 INFO : NVIDIA Container Runtime with Docker integration (Beta) : Install ‘NVIDIA Container Runtime with Docker integration (Beta)’ Skipped
- 11:23:26 INFO : Multimedia API : Install ‘Multimedia API’ Skipped
- 11:23:26 INFO : DeepStream : Install ‘DeepStream’ Skipped
- 11:23:26 DEBUG : running command < ps aux | grep NV_L4T_FLASH_NANO_DEVKIT_WITH_OS_IMAGE_COMP | grep -v grep | awk ‘{print $2}’ | xargs kill -9 >
- 11:23:26 INFO : Flash Jetson Nano : Killed
- 11:23:26 ERROR : Flash Jetson Nano : command terminated with error
- 11:23:26 INFO : bash: syntax error near unexpected token `&&’
- 11:23:27 INFO : All done!
