Creating the custom driver SIPL: CDI_CONFIG_MAX96712_CHECK_CSIPLL_LOCK Error
Please provide the following info (check/uncheck the boxes after clicking “+ Create Topic”):
Software Version
DRIVE OS Linux 5.2.0
other DRIVE OS version
other
Target Operating System
Linux
QNX
other
Hardware Platform
other
SDK Manager Version
1.5.0.7774
other
Host Machine Version
native Ubuntu 18.04
other
Dear Nvidia experts,
Continude with last topic, Create customized camera driver AR0231 + Max9295 with SIPL, I created adriver for Ar0231+ Max9295. We have previous version driver for this camera module in OS 5.1. I ported all configuration step by step from this old driver to SIPL. But when I run sample, although it can detect MAX96712/MAX9295/AR0231, it still occurs error blow, I carefully checked all step but can not resolve. Can you please advise me about this error:
./nvsipl_camera -c CUSTOM_DPHY_x2 -m “0x0010 0x0000 0x0000 0x0000” -s
MAX96712: Revision 2 detected
MAX96712 Rev 2: Link 1: Tx amplitude 0x28, 0x68, 0xb3, 0x72, 0xd2
MAX96712 Rev 2 manual adaptation on the link 1 (31)
MAX9295: Revision 8 detected!
Sensor AR0231 RCCB Rev7 detected!
Module_id 22 Severity 6 : NvMediaICPCreateEx 76
Module_id 22 Severity 6 : T19x VI version 0x000019
[Init:132] CNvSIPLMaster Init() end
nvsipl_camera: Opened NITO file for module “CUSTOM”
Warning : CheckCSIPLLLock 2582: CSIPLL Unlocked 0x0
nvmedia: ERROR: CheckCSIPLLLock: CSI PLL unlock 0x0
nvmedia: ERROR: MAX9295: CDI_CONFIG_MAX96712_CHECK_CSIPLL_LOCK failed
DEVBLK_WORKER_0: CNvMMax96712.cpp: 400: Start: CDI_CONFIG_MAX96712_CHECK_CSIPLL_LOCK failed! with NvMedia error: 7
Enter ‘les’ followed by sensor ID to enable LED
Enter ‘lds’ followed by sensor ID to disable LED
Enter ‘q’ to quit the application
Output
Sensor1_Out1 Frame rate (fps): 0
Sensor1_Out2 Frame rate (fps): 0
Output
Thanks in advance,
Hung.
Hi @v.HungNV99 ,
These messages are from the following source file. CSIPLL_LOCK error happens if no valid video streams are coming into the deserializer.
~/nvidia/nvidia_sdk/DRIVE_OS_5.2.0_SDK_Linux_OS_DDPX/DRIVEOS/drive-t186ref-linux/samples/nvmedia/nvsipl/devblk/devices/MAX96712DeserializerDriver/cdi_max96712.c
Hi @VickNV ,
I fixed CSIPLL_LOCK error, but it can not capture image with flag: NOTIF_WARN_ICP_CAPTURE_TIMEOUT. Can you explain something about this issue? I searched in forums/documentation but have not enough information.
Thank you for letting us know.
Please help to create another topic for NOTIF_WARN_ICP_CAPTURE_TIMEOUT question for other developers having the same issue in the furture to easily find it.
Sorry for any inconvenience.
