Software Version
DRIVE OS Linux 5.2.6
DRIVE OS Linux 5.2.6 and DriveWorks 4.0
DRIVE OS Linux 5.2.0
other DRIVE OS version 6.0.9
other
Target Operating System
Linux
QNX
other
Hardware Platform
other production kit
SDK Manager Version
1.9.1.10844
other
Host Machine Version
native Ubuntu 18.04
other, Ubuntu 20.04
I am setting up a cross-compilation environment to deploy code on the nvidia drive orin. Do I miss certain packages? My Dockerfile looks like this:
ENV DEBIAN_FRONTEND=noninteractive
# Copy the dependency files into the container
COPY deps/*.deb /tmp/
WORKDIR /tmp
ENV NV_WORKSPACE=/drive
RUN apt-get update && apt-get install -y \
gcc-aarch64-linux-gnu g++-aarch64-linux-gnu \
wget dpkg-dev
# Install CUDA, cuDNN, TensorRT, and DriveOS SDK
ADD deps/camera_tools_sdk6090_0.0.8.13_gravis/camera_api.tar.gz /tmp
RUN dpkg -i cuda-repo-cross-aarch64-ubuntu2004-11-4-local_11.4.28-1_all.deb
RUN dpkg -i cuda-repo-ubuntu2004-11-4-local_11.4.28-535.104.12-1_amd64.deb
RUN dpkg -i cudnn-local-repo-cross-aarch64-ubuntu2004-8.9.2.19_1.0-1_all.deb
RUN dpkg -i cudnn-local-repo-ubuntu2004-8.9.2.19_1.0-1_amd64.deb
RUN dpkg -i nv-driveos-repo-sdk-linux-6.0.9.0-35041135_6.0.9.0_amd64.deb
RUN dpkg -i nv-tensorrt-repo-ubuntu2004-cuda11.4-trt8.6.12.4-d6l-cross-ga-20231014_1-1_amd64.deb
RUN dpkg -i nv-tensorrt-repo-ubuntu2004-cuda11.4-trt8.6.12.4-x86-host-ga-20231014_1-1_amd64.deb
# Copy keyrings to the system keyrings directory
RUN cp /var/cuda-repo-ubuntu2004-11-4-local/*.gpg /usr/share/keyrings/ && \
cp /var/cuda-repo-cross-aarch64-ubuntu2004-11-4-local/*.gpg /usr/share/keyrings/ && \
cp /var/cudnn-local-repo-ubuntu2004-8.9.2.19/*.gpg /usr/share/keyrings/ && \
cp /var/cudnn-local-repo-cross-aarch64-ubuntu2004-8.9.2.19/*.gpg /usr/share/keyrings/ && \
cp /var/nv-tensorrt-repo-ubuntu2004-cuda11.4-trt8.6.12.4-d6l-cross-ga-20231014/*.gpg /usr/share/keyrings/ && \
cp /var/nv-tensorrt-repo-ubuntu2004-cuda11.4-trt8.6.12.4-x86-host-ga-20231014/*.gpg /usr/share/keyrings/
RUN apt-get update && \
apt-get install -y --no-install-recommends \
cuda-toolkit-11-4 \
libcudnn8 \
tensorrt \
gcc-aarch64-linux-gnu \
libc6-dev-arm64-cross \
linux-libc-dev-arm64-cross \
libstdc++-10-dev-arm64-cross \
&& apt-get clean
RUN mkdir -p $NV_WORKSPACE
RUN apt-get install -y nv-driveos-build-sdk-linux-6.0.9.0-35041135
