CUDA Installer failed
Hello. NVIDIA Cuda installer gives me the error in the screenshot. Can somebody help me troubleshoot ?
Graphics drivers are 537.58 (Studio).
Thus far, I have tried uninstalling the main graphics drivers and clean re-installing both Game-Ready or Studio without any success. Also tried install with and without PhysX component and with/without GeForece Experience resulting in the same error.
Typically I run my computer with only the drivers, no PhysX and no Geforce Experience so this would be the ideal end-result (CUDA + drivers).
Graphics card is a Geforce RTX 3060 (Gigabyte VISION OC v2) 12 GB VRAM.
Machine is: HP Z4 G4 with Xeon W-2145, 32 GB DDR4 ECC.
Operating system: Windows 10
Reason for wanting to install CUDA is that I am trying to learn to use Stable Diffusion and LORA training or fine-tuning with my own dataset photos and learned that CUDA is a pre-requsite. I never used CUDA before and never had any version of it installed on my PC.
When initially trying to install CUDA I was presented with warning message: " No supported version of Visual Studio was found. Some components of the CUDA Toolkit will not work properly", after which I closed the CUDA installer and succesfully installed Visual Studio.
If further information is required let me know.
Thank you.
EDIT: I have read a related forum post ( WIndows 10 CUDA installation failure solved - #17 by bnrr2000 ) but it is dating from 2018 and the solution presented there is disabling Visual Studio Integration. I am unsure if I should follow that solution given the purpose above. Isn’t Visual Studio Integration required for running Stable Diffusion training ?
Untitled-2
have u found a fix yet
Pretty late here but i has the idea! I observe same situation with you and also see the post you mention.
Just do as my step
  1. Intall CUDA
  2. Encounter Error, scroll and check for what has the FAILED status (others are NOT INSTALLED)
  3. In my case, it’s Nsight System and Nsight computing. So remember it.
  4. Prepare for install again, but this time Install Custom.
  5. Deselect which FAILED you encouter at step 2. Select the lasts.
  6. Install Sucessfully!
