hitimo
October 2, 2018, 10:26am
1
I need to install cuDNN 7.1.5 on a Jetson TX2. I downloaded JetPack-L4T-3.3-linux-x64_b39.run
which should include cuDNN v 7.1.5:
https://docs.nvidia.com/jetpack-l4t/index.html#jetpack/3.3/release_notes.htm
However, on the JetPack 3.3 Components Manager I can only select “Install 7.0” for cuDNN.
Hi hitimo,
After install JetPack-3.3 finished, you can check cuDNN version is 7.1.5.14
check cuDNN version:
dpkg -l | grep cudnn
hitimo
October 4, 2018, 10:33am
3
Hi carolyuu,
Thanks a lot - I figured it out. So I guess it only shows the version major in the JetPack 3.3. Components Manager.
How can I upgrade my cuDNN to 7.5 version.
Now my tx2 has a 9.0 cuda and a 7.1.5.14 cuDNN.
I try to make Opencv’s dnn moudle with cuda support, but cmake tall me that the cuDNN is required at least “7.5”.
Hi chenchunlei,
Please using sdkmanager to flash JetPack-4.3 image and install sdk components.
This version JetPack support cuDNN 7.6 and CUDA 10.0.
