I have an issue where I need to Deactivate a prim in my stage:
Where can I find the code that is called by the Deactivate option in the context menu? I need to implement this code in my extension.
Some backround into why I need this:
I have a main usd stage where I enable my extension. My extension then load a “template” which is just a template of a specific environment. I then create an Omnigraph with scatter a node in my code and run rundomization with an async loop and rep.orchestrator.
Then, once the simulation ren X frames, I load a new template and edit the input to my scatter nodes and start the async loop again. and so forth.
The issues:
- I cannot delete an “old template”. This is a bug with Omnigraph. Even though I changed the Input to scatter2dnode:input:SurfacePrim to the floor plane of the new template, I still cannot delete the previous input surface prim (which is inside the older template). If I do delete that plane then EVERYTHING brakes in my stage. If I click a prim in the stage I get a flooding or errors.
To handle this I simply set the visability of the older template to false.
- The issue with my solution to issue 1 is, That if I have two templates in my stage (regardless of visability) I get a flooding of the error:
[Error] [omni.syntheticdata.plugin] OgnSdStageSemanticInstanceMapping missing filteredLabelMap semLabelMap in the history.
Why? because the “floor” plate in each template has many many grass instances that was created with the paint tool. each instance has a semantic label “grass”.
It turns out there is a limit on how many semantic instances you can have in a single stage.
So now we come to the third and final issue.
- Cannot delete the PaintTool prim of the older template:
There for, I need to deactivate it.
Thank you,
Danielle
