I got the free university developer license, and run it. But when I finished the code compiling and run the the executable file, there are a problem. I doubt if the installation still has problem, so I listed main points.
The problem shows
DEPLOYMENT RESTRICTED
The PGI compiler license used to create this executable is for development
purposes only and does not include deployment rights. Please contact PGI
Sales at sales@pgroup.com for information on lifting this restriction.
and the outputs of
% ps ax | grep lmgrd
% lmutil lmhostid
% lmutil lmhostid -hostname
% lmutil lmhostid -internet
% ping meta
% /sbin/ifconfig
[webber@localhost ~]$ ps ax | grep lmgrd
5624 ? S 0:00 /opt/pgi/linux86-64/16.1/bin/lmgrd -c :/opt/pgi/license.dat
5625 ? Ssl 0:00 pgroupd -T localhost.localdomain 11.11 3 -c :/opt/pgi/license.dat --lmgrd_start 56e67232
8370 pts/0 S+ 0:00 grep --color=auto lmgrd
[webber@localhost exa]$ lmutil lmhostid
lmutil - Copyright (c) 1989-2013 Flexera Software LLC. All Rights Reserved.
The FlexNet host ID of this machine is “b8aeedb75dd4”
[webber@localhost exa]$ lmutil lmhostid -hostname
The FlexNet host ID of this machine is “HOSTNAME=localhost.localdomain”
[webber@localhost exa]$ lmutil lmhostid -internet
The FlexNet host ID of this machine is “INTERNET=127.0.0.1”
[webber@localhost exa]$ ping localhost.localdomain
PING localhost (127.0.0.1) 56(84) bytes of data.
64 bytes from localhost (127.0.0.1): icmp_seq=1 ttl=64 time=0.037 ms
64 bytes from localhost (127.0.0.1): icmp_seq=2 ttl=64 time=0.029 ms
^C
— localhost ping statistics —
2 packets transmitted, 2 received, 0% packet loss, time 1000ms
rtt min/avg/max/mdev = 0.029/0.033/0.037/0.004 ms
[webber@localhost exa]$ /sbin/ifconfig
enp3s0f0: flags=4099<UP,BROADCAST,MULTICAST> mtu 1500
ether b8:ae:ed:b7:5d:d4 txqueuelen 1000 (Ethernet)
RX packets 0 bytes 0 (0.0 B)
RX errors 0 dropped 0 overruns 0 frame 0
TX packets 0 bytes 0 (0.0 B)
TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0
lo: flags=73<UP,LOOPBACK,RUNNING> mtu 65536
inet 127.0.0.1 netmask 255.0.0.0
inet6 ::1 prefixlen 128 scopeid 0x10
loop txqueuelen 0 (Local Loopback)
RX packets 875 bytes 76665 (74.8 KiB)
TX packets 875 bytes 76665 (74.8 KiB)
best,
Jackie
