I followed the NVIDIA manual to install the BSP using a USB stick and installed it on the NVMe. I confirmed that Ubuntu 24.04 boots up correctly in jetson thor.
However, since I use my monitor in portrait orientation, I changed the display orientation settings. After doing this, the screen stopped working and became unresponsive. When I rebooted, the monitor no longer turned on. I also tried reinstalling using the USB, but it didn’t fix the issue.
Is there a way to resolve this problem? Or is there a factory reset method available?
If you want it more formal or technical, let me know!
You might have to hit a key (e.g., space key) during boot to get it to show up at the Grub menu, not sure. If that doesn’t work, then you probably need to flash it with a host PC. Check for the latest release of L4T (which is what actually gets flashed) compatible with Thor here: https://developer.nvidia.com/linux-tegra
Question for @kayccc or anyone else from NVIDIA: I was thinking there was a newer L4T release then R38.2, but it doesn’t show up on this URL. Is that correct? I ask because probably command line flash will be used with the NVMe in the m.2 slot.
I have already tried the methods mentioned in the provided link several times.
Even after modifying the SoC Display hand-Off Mode and rebooting, the issue remains the same (the monitor does not respond).
One difference I noticed when following the provided link was that in the Jetson BSP Installation menu, there was an additional item listed below “Flash Jetson AGX Thor Developer Kit on NVMe 0.2.0-r38.0”:
“Flash Jetson AGX Thor Developer Kit on USB 0.2.0-r38.0”.
