I am trying to remove drive software 10 and install drive os 5.2, Is there any special instructions that I need to follow?
Please provide the following info (check/uncheck the boxes after clicking “+ Create Topic”): Software Version
DRIVE OS Linux 5.2.0
other DRIVE OS version
other
I have succesfully flashed the drive OS, but after that I am not able to connect via the USB.
I tried activating the terminal emulation ,
•Install Foundation package
•Install these packages on the host system:
Dear @aswb,
Are you able to login to target directly?
Did you press ENTER after sudo minicom –D /dev/ttyUSB2. Please file new topic as it is not related to current topic thread.
hi,
i meet the same problem when connecting to the Drive AGX platform.
and press ENTER after sudo minicom –D /dev/ttyUSB2, the host shows “Device /dev/ttyUSB2 is locked”
One small query,
When I installed the drive software 10, the display was working fine and the desktop version was accessible from the dev kit.
But with drive OS 5.2, Is the desktop accessible, Or is that not included?
