Driveworks and ROS cross compilation: Not able to install libboost-all-dev
Software Version
DRIVE OS 6.0.6
Target Operating System
Linux
Hardware Platform
SDK Manager Version
1.9.3.10904
Host Machine Version
I am trying to setup ROS and Driveworks cross-compilation on the Host PC. I did the following steps:
	export SYSROOT=~/nvidia/nvidia_sdk/DRIVE_OS_6.0.6_SDK_Linux_DRIVE_AGX_ORIN_DEVKITS/DRIVEOS/drive-linux/filesystem/targetfs
	cd $SYSROOT
	sudo apt-get install qemu-user-static
	sudo cp /usr/bin/qemu-aarch64-static usr/bin/
	sudo cp -ib /etc/resolv.conf etc
	sudo mount -o bind /dev dev
	sudo mount -o bind /proc proc
	sudo mount -o bind /sys sys
	sudo LC_ALL=C chroot .
	apt-get update
 	apt-get install libboost-all-dev libtinyxml-dev libtinyxml2-dev liblz4-dev libbz2-dev libapr1 libaprutil1 libconsole-bridge-dev libpoco-dev libgpgme-dev python3-defusedxml python3-rospkg python3-catkin-pkg python3-netifaces liblog4cxx-dev
	exit
when I was installing libboost-all-dev, it showed me unmet dependencies error. I also tried to use aptitude to install libboost-all-dev, none of the options let me install the library.
On this folder (~/nvidia/nvidia_sdk/DRIVE_OS_6.0.6_SDK_Linux_DRIVE_AGX_ORIN_DEVKITS/DRIVEOS/drive-linux/filesystem/targetfs/usr/lib/aarch64-linux-gnu) i could only find the following 2 files:
libboost_iostreams.so.1.71.0
libboost_thread.so.1.71.0
When i was trying to run the cross-compilation for ros, I saw this error Could NOT find Boost (missing: thread system) (found version "1.71.0")
Do you have any idea on this? Thank you!
Dear @baoxin.chen,
We don’t officially support ROS on DRIVE AGX Orin. Could you check if the discussion in Cross Compile ROS and openCV for Drive AGX Orin helps?
