hello, i have been trying to build the isaac ros container and i keep getting this error:
MPC version 1.2.1, isl version isl-0.24-GMP
179.5
179.5 GGC heuristics: --param ggc-min-expand=100 --param ggc-min-heapsize=131072
179.5 GNU GIMPLE (Ubuntu 11.4.0-1ubuntu1~22.04) version 11.4.0 (aarch64-linux-gnu)
179.5 compiled by GNU C version 11.4.0, GMP version 6.2.1, MPFR version 4.1.0, MPC version 1.2.1, isl version isl-0.24-GMP
179.5
179.5 COLLECT_GCC_OPTIONS='-c' '-fno-openmp' '-fno-openacc' '-fPIC' '-fcf-protection=none' '-g' '-mlittle-endian' '-mabi=lp64' '-O2' '-g' '-O2' '-ffile-prefix-map=/opt/ros/humble/src/moveit_task_constructor/core=.' '-ffat-lto-objects' '-fstack-protector-strong' '-v' '-shared-libgcc' '-mlittle-endian' '-mabi=lp64' '-fltrans' '-o' '/tmp/ccFKsKHa.ltrans0.ltrans.o' '-shared-libgcc'
179.5 as -v --gdwarf-5 -EL -mabi=lp64 -mabi=lp64 -o /tmp/ccFKsKHa.ltrans0.ltrans.o /tmp/ccfYWX5u.s
179.5 GNU assembler version 2.38 (aarch64-linux-gnu) using BFD version (GNU Binutils for Ubuntu) 2.38
179.5 MAKEFLAGS=w -j12 --
179.5 COMPILER_PATH=/usr/lib/gcc/aarch64-linux-gnu/11/:/usr/lib/gcc/aarch64-linux-gnu/11/:/usr/lib/gcc/aarch64-linux-gnu/:/usr/lib/gcc/aarch64-linux-gnu/11/:/usr/lib/gcc/aarch64-linux-gnu/:/usr/lib/gcc/aarch64-linux-gnu/11/:/usr/lib/gcc/aarch64-linux-gnu/11/:/usr/lib/gcc/aarch64-linux-gnu/:/usr/lib/gcc/aarch64-linux-gnu/11/:/usr/lib/gcc/aarch64-linux-gnu/
179.5 LIBRARY_PATH=/usr/lib/gcc/aarch64-linux-gnu/11/../../../../lib/aarch64-linux-gnu/:/usr/lib/gcc/aarch64-linux-gnu/11/../../../../lib/../lib/:/lib/../lib/aarch64-linux-gnu/:/lib/../lib/../lib/:/usr/lib/../lib/aarch64-linux-gnu/:/usr/lib/../lib/../lib/:/usr/lib/gcc/aarch64-linux-gnu/11/../../../aarch64-linux-gnu/:/usr/lib/gcc/aarch64-linux-gnu/11/../../../../lib/:/lib/aarch64-linux-gnu/:/lib/../lib/:/usr/lib/aarch64-linux-gnu/:/usr/lib/../lib/:/usr/lib/gcc/aarch64-linux-gnu/11/:/usr/lib/gcc/aarch64-linux-gnu/11/../../../aarch64-linux-gnu/:/usr/lib/gcc/aarch64-linux-gnu/11/../../../../lib/:/lib/aarch64-linux-gnu/:/lib/../lib/:/usr/lib/aarch64-linux-gnu/:/usr/lib/../lib/:/usr/lib/gcc/aarch64-linux-gnu/11/:/usr/lib/gcc/aarch64-linux-gnu/11/../../../aarch64-linux-gnu/:/usr/lib/gcc/aarch64-linux-gnu/11/../../../../lib/:/lib/aarch64-linux-gnu/:/lib/../lib/:/usr/lib/aarch64-linux-gnu/:/usr/lib/../lib/:/usr/local/cuda/lib64/stubs/:/usr/lib/gcc/aarch64-linux-gnu/11/../../../:/lib/:/usr/lib/:/usr/lib/gcc/aarch64-linux-gnu/11/../../../:/lib/:/usr/lib/
179.5 COLLECT_GCC_OPTIONS='-c' '-fno-openmp' '-fno-openacc' '-fPIC' '-fcf-protection=none' '-g' '-mlittle-endian' '-mabi=lp64' '-O2' '-g' '-O2' '-ffile-prefix-map=/opt/ros/humble/src/moveit_task_constructor/core=.' '-ffat-lto-objects' '-fstack-protector-strong' '-v' '-shared-libgcc' '-mlittle-endian' '-mabi=lp64' '-fltrans' '-o' '/tmp/ccFKsKHa.ltrans0.ltrans.o' '-shared-libgcc' '-dumpdir' './cmTC_12939.ltrans0.ltrans.'
179.5 COLLECT_GCC_OPTIONS='-g' '-O2' '-ffile-prefix-map=/opt/ros/humble/src/moveit_task_constructor/core=.' '-flto=auto' '-flto=auto' '-ffat-lto-objects' '-fstack-protector-strong' '-Wformat=1' '-D' 'NDEBUG' '-Wdate-time' '-D' '_FORTIFY_SOURCE=2' '-v' '-o' 'cmTC_12939' '-shared-libgcc' '-mlittle-endian' '-mabi=lp64' '-dumpdir' 'cmTC_12939.'
179.5 gmake[3]: Leaving directory '/opt/ros/humble/src/moveit_task_constructor/core/.obj-aarch64-linux-gnu/CMakeFiles/CMakeTmp'
179.5 gmake[2]: Leaving directory '/opt/ros/humble/src/moveit_task_constructor/core/.obj-aarch64-linux-gnu/CMakeFiles/CMakeTmp'
179.5
179.5
179.5
179.5 Parsed CXX implicit include dir info from above output: rv=done
179.5 found start of include info
179.5 found start of implicit include info
179.5 add: [/usr/include/c++/11]
179.5 add: [/usr/include/aarch64-linux-gnu/c++/11]
179.5 add: [/usr/include/c++/11/backward]
179.5 add: [/usr/lib/gcc/aarch64-linux-gnu/11/include]
179.5 add: [/usr/local/include]
179.5 add: [/usr/include/aarch64-linux-gnu]
179.5 add: [/usr/include]
179.5 end of search list found
179.5 collapse include dir [/usr/include/c++/11] ==> [/usr/include/c++/11]
179.5 collapse include dir [/usr/include/aarch64-linux-gnu/c++/11] ==> [/usr/include/aarch64-linux-gnu/c++/11]
179.5 collapse include dir [/usr/include/c++/11/backward] ==> [/usr/include/c++/11/backward]
179.5 collapse include dir [/usr/lib/gcc/aarch64-linux-gnu/11/include] ==> [/usr/lib/gcc/aarch64-linux-gnu/11/include]
179.5 collapse include dir [/usr/local/include] ==> [/usr/local/include]
179.5 collapse include dir [/usr/include/aarch64-linux-gnu] ==> [/usr/include/aarch64-linux-gnu]
179.5 collapse include dir [/usr/include] ==> [/usr/include]
179.5 implicit include dirs: [/usr/include/c++/11;/usr/include/aarch64-linux-gnu/c++/11;/usr/include/c++/11/backward;/usr/lib/gcc/aarch64-linux-gnu/11/include;/usr/local/include;/usr/include/aarch64-linux-gnu;/usr/include]
179.5
179.5
179.5 Parsed CXX implicit link information from above output:
179.5 link line regex: [^( *|.*[/\])(ld|CMAKE_LINK_STARTFILE-NOTFOUND|([^/\]+-)?ld|collect2)[^/\]*( |$)]
179.5 ignore line: [Change Dir: /opt/ros/humble/src/moveit_task_constructor/core/.obj-aarch64-linux-gnu/CMakeFiles/CMakeTmp]
179.5 ignore line: []
179.5 ignore line: [Run Build Command(s):/usr/bin/gmake -f Makefile cmTC_12939/fast && gmake[2]: Entering directory '/opt/ros/humble/src/moveit_task_constructor/core/.obj-aarch64-linux-gnu/CMakeFiles/CMakeTmp']
179.5 ignore line: [/usr/bin/gmake -f CMakeFiles/cmTC_12939.dir/build.make CMakeFiles/cmTC_12939.dir/build]
179.5 ignore line: [gmake[3]: Entering directory '/opt/ros/humble/src/moveit_task_constructor/core/.obj-aarch64-linux-gnu/CMakeFiles/CMakeTmp']
179.5 ignore line: [Building CXX object CMakeFiles/cmTC_12939.dir/CMakeCXXCompilerABI.cpp.o]
179.5 ignore line: [/usr/bin/c++ -g -O2 -ffile-prefix-map=/opt/ros/humble/src/moveit_task_constructor/core=. -flto=auto -ffat-lto-objects -flto=auto -ffat-lto-objects -fstack-protector-strong -Wformat -DNDEBUG -Wdate-time -D_FORTIFY_SOURCE=2 -v -o CMakeFiles/cmTC_12939.dir/CMakeCXXCompilerABI.cpp.o -c /usr/share/cmake-3.22/Modules/CMakeCXXCompilerABI.cpp]
179.5 ignore line: [Using built-in specs.]
179.5 ignore line: [COLLECT_GCC=/usr/bin/c++]
179.5 ignore line: [Target: aarch64-linux-gnu]
179.5 ignore line: [Configured with: ../src/configure -v --with-pkgversion='Ubuntu 11.4.0-1ubuntu1~22.04' --with-bugurl=file:///usr/share/doc/gcc-11/README.Bugs --enable-languages=c ada c++ go d fortran objc obj-c++ m2 --prefix=/usr --with-gcc-major-version-only --program-suffix=-11 --program-prefix=aarch64-linux-gnu- --enable-shared --enable-linker-build-id --libexecdir=/usr/lib --without-included-gettext --enable-threads=posix --libdir=/usr/lib --enable-nls --enable-bootstrap --enable-clocale=gnu --enable-libstdcxx-debug --enable-libstdcxx-time=yes --with-default-libstdcxx-abi=new --enable-gnu-unique-object --disable-libquadmath --disable-libquadmath-support --enable-plugin --enable-default-pie --with-system-zlib --enable-libphobos-checking=release --with-target-system-zlib=auto --enable-objc-gc=auto --enable-multiarch --enable-fix-cortex-a53-843419 --disable-werror --enable-checking=release --build=aarch64-linux-gnu --host=aarch64-linux-gnu --target=aarch64-linux-gnu --with-build-config=bootstrap-lto-lean --enable-link-serialization=2]
179.5 ignore line: [Thread model: posix]
179.5 ignore line: [Supported LTO compression algorithms: zlib zstd]
179.5 ignore line: [gcc version 11.4.0 (Ubuntu 11.4.0-1ubuntu1~22.04) ]
179.5 ignore line: [COLLECT_GCC_OPTIONS='-g' '-O2' '-ffile-prefix-map=/opt/ros/humble/src/moveit_task_constructor/core=.' '-flto=auto' '-flto=auto' '-ffat-lto-objects' '-fstack-protector-strong' '-Wformat=1' '-D' 'NDEBUG' '-Wdate-time' '-D' '_FORTIFY_SOURCE=2' '-v' '-o' 'CMakeFiles/cmTC_12939.dir/CMakeCXXCompilerABI.cpp.o' '-c' '-shared-libgcc' '-mlittle-endian' '-mabi=lp64' '-dumpdir' 'CMakeFiles/cmTC_12939.dir/']
179.5 ignore line: [ /usr/lib/gcc/aarch64-linux-gnu/11/cc1plus -quiet -v -imultiarch aarch64-linux-gnu -D_GNU_SOURCE -D NDEBUG -D _FORTIFY_SOURCE=2 /usr/share/cmake-3.22/Modules/CMakeCXXCompilerABI.cpp -quiet -dumpdir CMakeFiles/cmTC_12939.dir/ -dumpbase CMakeCXXCompilerABI.cpp.cpp -dumpbase-ext .cpp -mlittle-endian -mabi=lp64 -g -O2 -Wformat=1 -Wdate-time -version -ffile-prefix-map=/opt/ros/humble/src/moveit_task_constructor/core=. -flto=auto -flto=auto -ffat-lto-objects -fstack-protector-strong -fasynchronous-unwind-tables -fstack-protector-strong -Wformat -Wformat-security -fstack-clash-protection -o /tmp/ccoiVVrV.s]
179.5 ignore line: [GNU C++17 (Ubuntu 11.4.0-1ubuntu1~22.04) version 11.4.0 (aarch64-linux-gnu)]
179.5 ignore line: [ compiled by GNU C version 11.4.0 GMP version 6.2.1 MPFR version 4.1.0 MPC version 1.2.1 isl version isl-0.24-GMP]
179.5 ignore line: [GGC heuristics: --param ggc-min-expand=100 --param ggc-min-heapsize=131072]
179.5 ignore line: [ignoring duplicate directory "/usr/include/aarch64-linux-gnu/c++/11"]
179.5 ignore line: [ignoring nonexistent directory "/usr/local/include/aarch64-linux-gnu"]
179.5 ignore line: [ignoring nonexistent directory "/usr/lib/gcc/aarch64-linux-gnu/11/include-fixed"]
179.5 ignore line: [ignoring nonexistent directory "/usr/lib/gcc/aarch64-linux-gnu/11/../../../../aarch64-linux-gnu/include"]
179.5 ignore line: [#include "..." search starts here:]
179.5 ignore line: [#include <...> search starts here:]
179.5 ignore line: [ /usr/include/c++/11]
179.5 ignore line: [ /usr/include/aarch64-linux-gnu/c++/11]
179.5 ignore line: [ /usr/include/c++/11/backward]
179.5 ignore line: [ /usr/lib/gcc/aarch64-linux-gnu/11/include]
179.5 ignore line: [ /usr/local/include]
179.5 ignore line: [ /usr/include/aarch64-linux-gnu]
179.5 ignore line: [ /usr/include]
179.5 ignore line: [End of search list.]
179.5 ignore line: [Compiler executable checksum: 3e6e780af1232722b47e0979fda82402]
179.5 ignore line: [ as -v --gdwarf-5 -EL -mabi=lp64 -o CMakeFiles/cmTC_12939.dir/CMakeCXXCompilerABI.cpp.o /tmp/ccoiVVrV.s]
179.5 ignore line: [GNU assembler version 2.38 (aarch64-linux-gnu) using BFD version (GNU Binutils for Ubuntu) 2.38]
179.5 ignore line: [COMPILER_PATH=/usr/lib/gcc/aarch64-linux-gnu/11/:/usr/lib/gcc/aarch64-linux-gnu/11/:/usr/lib/gcc/aarch64-linux-gnu/:/usr/lib/gcc/aarch64-linux-gnu/11/:/usr/lib/gcc/aarch64-linux-gnu/]
179.5 ignore line: [LIBRARY_PATH=/usr/lib/gcc/aarch64-linux-gnu/11/:/usr/lib/gcc/aarch64-linux-gnu/11/../../../aarch64-linux-gnu/:/usr/lib/gcc/aarch64-linux-gnu/11/../../../../lib/:/lib/aarch64-linux-gnu/:/lib/../lib/:/usr/lib/aarch64-linux-gnu/:/usr/lib/../lib/:/usr/local/cuda/lib64/stubs/:/usr/lib/gcc/aarch64-linux-gnu/11/../../../:/lib/:/usr/lib/]
179.5 ignore line: [COLLECT_GCC_OPTIONS='-g' '-O2' '-ffile-prefix-map=/opt/ros/humble/src/moveit_task_constructor/core=.' '-flto=auto' '-flto=auto' '-ffat-lto-objects' '-fstack-protector-strong' '-Wformat=1' '-D' 'NDEBUG' '-Wdate-time' '-D' '_FORTIFY_SOURCE=2' '-v' '-o' 'CMakeFiles/cmTC_12939.dir/CMakeCXXCompilerABI.cpp.o' '-c' '-shared-libgcc' '-mlittle-endian' '-mabi=lp64' '-dumpdir' 'CMakeFiles/cmTC_12939.dir/CMakeCXXCompilerABI.cpp.']
179.5 ignore line: [Linking CXX executable cmTC_12939]
179.5 ignore line: [/usr/bin/cmake -E cmake_link_script CMakeFiles/cmTC_12939.dir/link.txt --verbose=1]
179.5 ignore line: [/usr/bin/c++ -g -O2 -ffile-prefix-map=/opt/ros/humble/src/moveit_task_constructor/core=. -flto=auto -ffat-lto-objects -flto=auto -ffat-lto-objects -fstack-protector-strong -Wformat -DNDEBUG -Wdate-time -D_FORTIFY_SOURCE=2 -v CMakeFiles/cmTC_12939.dir/CMakeCXXCompilerABI.cpp.o -o cmTC_12939 ]
179.5 ignore line: [COLLECT_LTO_WRAPPER=/usr/lib/gcc/aarch64-linux-gnu/11/lto-wrapper]
179.5 ignore line: [COLLECT_GCC_OPTIONS='-g' '-O2' '-ffile-prefix-map=/opt/ros/humble/src/moveit_task_constructor/core=.' '-flto=auto' '-flto=auto' '-ffat-lto-objects' '-fstack-protector-strong' '-Wformat=1' '-D' 'NDEBUG' '-Wdate-time' '-D' '_FORTIFY_SOURCE=2' '-v' '-o' 'cmTC_12939' '-shared-libgcc' '-mlittle-endian' '-mabi=lp64' '-dumpdir' 'cmTC_12939.']
179.5 link line: [ /usr/lib/gcc/aarch64-linux-gnu/11/collect2 -plugin /usr/lib/gcc/aarch64-linux-gnu/11/liblto_plugin.so -plugin-opt=/usr/lib/gcc/aarch64-linux-gnu/11/lto-wrapper -plugin-opt=-fresolution=/tmp/ccNUWNAj.res -plugin-opt=-pass-through=-lgcc_s -plugin-opt=-pass-through=-lgcc -plugin-opt=-pass-through=-lc -plugin-opt=-pass-through=-lgcc_s -plugin-opt=-pass-through=-lgcc -flto=auto -flto=auto --build-id --eh-frame-hdr --hash-style=gnu --as-needed -dynamic-linker /lib/ld-linux-aarch64.so.1 -X -EL -maarch64linux --fix-cortex-a53-843419 -pie -z now -z relro -o cmTC_12939 /usr/lib/gcc/aarch64-linux-gnu/11/../../../aarch64-linux-gnu/Scrt1.o /usr/lib/gcc/aarch64-linux-gnu/11/../../../aarch64-linux-gnu/crti.o /usr/lib/gcc/aarch64-linux-gnu/11/crtbeginS.o -L/usr/lib/gcc/aarch64-linux-gnu/11 -L/usr/lib/gcc/aarch64-linux-gnu/11/../../../aarch64-linux-gnu -L/usr/lib/gcc/aarch64-linux-gnu/11/../../../../lib -L/lib/aarch64-linux-gnu -L/lib/../lib -L/usr/lib/aarch64-linux-gnu -L/usr/lib/../lib -L/usr/local/cuda/lib64/stubs -L/usr/lib/gcc/aarch64-linux-gnu/11/../../.. CMakeFiles/cmTC_12939.dir/CMakeCXXCompilerABI.cpp.o -lstdc++ -lm -lgcc_s -lgcc -lc -lgcc_s -lgcc /usr/lib/gcc/aarch64-linux-gnu/11/crtendS.o /usr/lib/gcc/aarch64-linux-gnu/11/../../../aarch64-linux-gnu/crtn.o]
179.5 arg [/usr/lib/gcc/aarch64-linux-gnu/11/collect2] ==> ignore
179.5 arg [-plugin] ==> ignore
179.5 arg [/usr/lib/gcc/aarch64-linux-gnu/11/liblto_plugin.so] ==> ignore
179.5 arg [-plugin-opt=/usr/lib/gcc/aarch64-linux-gnu/11/lto-wrapper] ==> ignore
179.5 arg [-plugin-opt=-fresolution=/tmp/ccNUWNAj.res] ==> ignore
179.5 arg [-plugin-opt=-pass-through=-lgcc_s] ==> ignore
179.5 arg [-plugin-opt=-pass-through=-lgcc] ==> ignore
179.5 arg [-plugin-opt=-pass-through=-lc] ==> ignore
179.5 arg [-flto=auto] ==> ignore
179.5 arg [--build-id] ==> ignore
179.5 arg [--eh-frame-hdr] ==> ignore
179.5 arg [--hash-style=gnu] ==> ignore
179.5 arg [--as-needed] ==> ignore
179.5 arg [-dynamic-linker] ==> ignore
179.5 arg [/lib/ld-linux-aarch64.so.1] ==> ignore
179.5 arg [-X] ==> ignore
179.5 arg [-EL] ==> ignore
179.5 arg [-maarch64linux] ==> ignore
179.5 arg [--fix-cortex-a53-843419] ==> ignore
179.5 arg [-pie] ==> ignore
179.5 arg [-znow] ==> ignore
179.5 arg [-zrelro] ==> ignore
179.5 arg [-o] ==> ignore
179.5 arg [cmTC_12939] ==> ignore
179.5 arg [/usr/lib/gcc/aarch64-linux-gnu/11/../../../aarch64-linux-gnu/Scrt1.o] ==> obj [/usr/lib/gcc/aarch64-linux-gnu/11/../../../aarch64-linux-gnu/Scrt1.o]
179.5 arg [/usr/lib/gcc/aarch64-linux-gnu/11/../../../aarch64-linux-gnu/crti.o] ==> obj [/usr/lib/gcc/aarch64-linux-gnu/11/../../../aarch64-linux-gnu/crti.o]
179.5 arg [/usr/lib/gcc/aarch64-linux-gnu/11/crtbeginS.o] ==> obj [/usr/lib/gcc/aarch64-linux-gnu/11/crtbeginS.o]
179.5 arg [-L/usr/lib/gcc/aarch64-linux-gnu/11] ==> dir [/usr/lib/gcc/aarch64-linux-gnu/11]
179.5 arg [-L/usr/lib/gcc/aarch64-linux-gnu/11/../../../aarch64-linux-gnu] ==> dir [/usr/lib/gcc/aarch64-linux-gnu/11/../../../aarch64-linux-gnu]
179.5 arg [-L/usr/lib/gcc/aarch64-linux-gnu/11/../../../../lib] ==> dir [/usr/lib/gcc/aarch64-linux-gnu/11/../../../../lib]
179.5 arg [-L/lib/aarch64-linux-gnu] ==> dir [/lib/aarch64-linux-gnu]
179.5 arg [-L/lib/../lib] ==> dir [/lib/../lib]
179.5 arg [-L/usr/lib/aarch64-linux-gnu] ==> dir [/usr/lib/aarch64-linux-gnu]
179.5 arg [-L/usr/lib/../lib] ==> dir [/usr/lib/../lib]
179.5 arg [-L/usr/local/cuda/lib64/stubs] ==> dir [/usr/local/cuda/lib64/stubs]
179.5 arg [-L/usr/lib/gcc/aarch64-linux-gnu/11/../../..] ==> dir [/usr/lib/gcc/aarch64-linux-gnu/11/../../..]
179.5 arg [CMakeFiles/cmTC_12939.dir/CMakeCXXCompilerABI.cpp.o] ==> ignore
179.5 arg [-lstdc++] ==> lib [stdc++]
179.5 arg [-lm] ==> lib [m]
179.5 arg [-lgcc_s] ==> lib [gcc_s]
179.5 arg [-lgcc] ==> lib [gcc]
179.5 arg [-lc] ==> lib [c]
179.5 arg [/usr/lib/gcc/aarch64-linux-gnu/11/crtendS.o] ==> obj [/usr/lib/gcc/aarch64-linux-gnu/11/crtendS.o]
179.5 arg [/usr/lib/gcc/aarch64-linux-gnu/11/../../../aarch64-linux-gnu/crtn.o] ==> obj [/usr/lib/gcc/aarch64-linux-gnu/11/../../../aarch64-linux-gnu/crtn.o]
179.5 collapse obj [/usr/lib/gcc/aarch64-linux-gnu/11/../../../aarch64-linux-gnu/Scrt1.o] ==> [/usr/lib/aarch64-linux-gnu/Scrt1.o]
179.5 collapse obj [/usr/lib/gcc/aarch64-linux-gnu/11/../../../aarch64-linux-gnu/crti.o] ==> [/usr/lib/aarch64-linux-gnu/crti.o]
179.5 collapse obj [/usr/lib/gcc/aarch64-linux-gnu/11/../../../aarch64-linux-gnu/crtn.o] ==> [/usr/lib/aarch64-linux-gnu/crtn.o]
179.5 collapse library dir [/usr/lib/gcc/aarch64-linux-gnu/11] ==> [/usr/lib/gcc/aarch64-linux-gnu/11]
179.5 collapse library dir [/usr/lib/gcc/aarch64-linux-gnu/11/../../../aarch64-linux-gnu] ==> [/usr/lib/aarch64-linux-gnu]
179.5 collapse library dir [/usr/lib/gcc/aarch64-linux-gnu/11/../../../../lib] ==> [/usr/lib]
179.5 collapse library dir [/lib/aarch64-linux-gnu] ==> [/lib/aarch64-linux-gnu]
179.5 collapse library dir [/lib/../lib] ==> [/lib]
179.5 collapse library dir [/usr/lib/aarch64-linux-gnu] ==> [/usr/lib/aarch64-linux-gnu]
179.5 collapse library dir [/usr/lib/../lib] ==> [/usr/lib]
179.5 collapse library dir [/usr/local/cuda/lib64/stubs] ==> [/usr/local/cuda/lib64/stubs]
179.5 collapse library dir [/usr/lib/gcc/aarch64-linux-gnu/11/../../..] ==> [/usr/lib]
179.5 implicit libs: [stdc++;m;gcc_s;gcc;c;gcc_s;gcc]
179.5 implicit objs: [/usr/lib/aarch64-linux-gnu/Scrt1.o;/usr/lib/aarch64-linux-gnu/crti.o;/usr/lib/gcc/aarch64-linux-gnu/11/crtbeginS.o;/usr/lib/gcc/aarch64-linux-gnu/11/crtendS.o;/usr/lib/aarch64-linux-gnu/crtn.o]
179.5 implicit dirs: [/usr/lib/gcc/aarch64-linux-gnu/11;/usr/lib/aarch64-linux-gnu;/usr/lib;/lib/aarch64-linux-gnu;/lib;/usr/local/cuda/lib64/stubs]
179.5 implicit fwks: []
179.5
179.5
179.5 Determining if the include file pthread.h exists passed with the following output:
179.5 Change Dir: /opt/ros/humble/src/moveit_task_constructor/core/.obj-aarch64-linux-gnu/CMakeFiles/CMakeTmp
179.5
179.5 Run Build Command(s):/usr/bin/gmake -f Makefile cmTC_a83cf/fast && gmake[2]: Entering directory '/opt/ros/humble/src/moveit_task_constructor/core/.obj-aarch64-linux-gnu/CMakeFiles/CMakeTmp'
179.5 /usr/bin/gmake -f CMakeFiles/cmTC_a83cf.dir/build.make CMakeFiles/cmTC_a83cf.dir/build
179.5 gmake[3]: Entering directory '/opt/ros/humble/src/moveit_task_constructor/core/.obj-aarch64-linux-gnu/CMakeFiles/CMakeTmp'
179.5 Building C object CMakeFiles/cmTC_a83cf.dir/CheckIncludeFile.c.o
179.5 /usr/bin/cc -g -O2 -ffile-prefix-map=/opt/ros/humble/src/moveit_task_constructor/core=. -flto=auto -ffat-lto-objects -flto=auto -ffat-lto-objects -fstack-protector-strong -Wformat -Werror=format-security -Wdate-time -D_FORTIFY_SOURCE=2 -o CMakeFiles/cmTC_a83cf.dir/CheckIncludeFile.c.o -c /opt/ros/humble/src/moveit_task_constructor/core/.obj-aarch64-linux-gnu/CMakeFiles/CMakeTmp/CheckIncludeFile.c
179.5 Linking C executable cmTC_a83cf
179.5 /usr/bin/cmake -E cmake_link_script CMakeFiles/cmTC_a83cf.dir/link.txt --verbose=1
179.5 /usr/bin/cc -g -O2 -ffile-prefix-map=/opt/ros/humble/src/moveit_task_constructor/core=. -flto=auto -ffat-lto-objects -flto=auto -ffat-lto-objects -fstack-protector-strong -Wformat -Werror=format-security -Wdate-time -D_FORTIFY_SOURCE=2 -Wl,--no-as-needed /opt/ros/humble/lib/libbackward.so /usr/lib/aarch64-linux-gnu/libdw.so -Wl,--as-needed CMakeFiles/cmTC_a83cf.dir/CheckIncludeFile.c.o -o cmTC_a83cf
179.5
179.5
179.5
179.5 Performing C SOURCE FILE Test CMAKE_HAVE_LIBC_PTHREAD succeeded with the following output:
179.5
179.5 Run Build Command(s):/usr/bin/gmake -f Makefile cmTC_38eef/fast && gmake[2]: Entering directory '/opt/ros/humble/src/moveit_task_constructor/core/.obj-aarch64-linux-gnu/CMakeFiles/CMakeTmp'
179.5 /usr/bin/gmake -f CMakeFiles/cmTC_38eef.dir/build.make CMakeFiles/cmTC_38eef.dir/build
179.5 Building C object CMakeFiles/cmTC_38eef.dir/src.c.o
179.5 /usr/bin/cc -DCMAKE_HAVE_LIBC_PTHREAD -g -O2 -ffile-prefix-map=/opt/ros/humble/src/moveit_task_constructor/core=. -flto=auto -ffat-lto-objects -flto=auto -ffat-lto-objects -fstack-protector-strong -Wformat -Werror=format-security -Wdate-time -D_FORTIFY_SOURCE=2 -o CMakeFiles/cmTC_38eef.dir/src.c.o -c /opt/ros/humble/src/moveit_task_constructor/core/.obj-aarch64-linux-gnu/CMakeFiles/CMakeTmp/src.c
179.5 Linking C executable cmTC_38eef
179.5 /usr/bin/cmake -E cmake_link_script CMakeFiles/cmTC_38eef.dir/link.txt --verbose=1
179.5 /usr/bin/cc -g -O2 -ffile-prefix-map=/opt/ros/humble/src/moveit_task_constructor/core=. -flto=auto -ffat-lto-objects -flto=auto -ffat-lto-objects -fstack-protector-strong -Wformat -Werror=format-security -Wdate-time -D_FORTIFY_SOURCE=2 -Wl,--no-as-needed /opt/ros/humble/lib/libbackward.so /usr/lib/aarch64-linux-gnu/libdw.so -Wl,--as-needed CMakeFiles/cmTC_38eef.dir/src.c.o -o cmTC_38eef
179.5
179.5
179.5 Source file was:
179.5 #include <pthread.h>
179.5
179.5 static void* test_func(void* data)
179.5 {
179.5 return data;
179.5 }
179.5
179.5 int main(void)
179.5 {
179.5 pthread_t thread;
179.5 pthread_create(&thread, NULL, test_func, NULL);
179.5 pthread_detach(thread);
179.5 pthread_cancel(thread);
179.5 pthread_join(thread, NULL);
179.5 pthread_atfork(NULL, NULL, NULL);
179.5 pthread_exit(NULL);
179.5
179.5 return 0;
179.5 }
179.5
179.5 dh_auto_configure: error: cd .obj-aarch64-linux-gnu && cmake -DCMAKE_INSTALL_PREFIX=/usr -DCMAKE_BUILD_TYPE=None -DCMAKE_INSTALL_SYSCONFDIR=/etc -DCMAKE_INSTALL_LOCALSTATEDIR=/var -DCMAKE_EXPORT_NO_PACKAGE_REGISTRY=ON -DCMAKE_FIND_USE_PACKAGE_REGISTRY=OFF -DCMAKE_FIND_PACKAGE_NO_PACKAGE_REGISTRY=ON "-GUnix Makefiles" -DCMAKE_VERBOSE_MAKEFILE=ON -DCMAKE_INSTALL_LIBDIR=lib/aarch64-linux-gnu -DCMAKE_INSTALL_PREFIX=/opt/ros/humble -DAMENT_PREFIX_PATH=/opt/ros/humble -DCMAKE_PREFIX_PATH=/opt/ros/humble -DBUILD_TESTING=OFF .. returned exit code 1
179.5 make[1]: *** [debian/rules:33: override_dh_auto_configure] Error 2
179.5 make[1]: Leaving directory '/opt/ros/humble/src/moveit_task_constructor/core'
179.6 make: *** [debian/rules:27: binary] Error 2
1 warning found (use --debug to expand):
- LegacyKeyValueFormat: "ENV key=value" should be used instead of legacy "ENV key value" format (line 17)
Dockerfile.ros2_humble:241
240 | # installed from source above.
241 | >>> RUN --mount=type=cache,target=/var/cache/apt \
242 | >>> mkdir -p ${ROS_ROOT}/src && cd ${ROS_ROOT}/src \
243 | >>> && git clone https://github.com/ros-planning/moveit_task_constructor.git -b humble \
244 | >>> && cd moveit_task_constructor && source ${ROS_ROOT}/setup.bash \
245 | >>> && cd msgs && bloom-generate rosdebian && fakeroot debian/rules binary \
246 | >>> && cd ../ && apt-get install -y ./*.deb && rm ./*.deb \
247 | >>> && cd rviz_marker_tools && bloom-generate rosdebian && fakeroot debian/rules binary \
248 | >>> && cd ../ && apt-get install -y ./*.deb && rm ./*.deb \
249 | >>> && cd core && bloom-generate rosdebian && fakeroot debian/rules binary DEB_BUILD_OPTIONS=nocheck \
250 | >>> && cd ../ && apt-get install -y ./*.deb && rm ./*.deb \
251 | >>> && cd capabilities && bloom-generate rosdebian && fakeroot debian/rules binary DEB_BUILD_OPTIONS=nocheck \
252 | >>> && cd ../ && apt-get install -y ./*.deb && rm ./*.deb \
253 | >>> && cd visualization && bloom-generate rosdebian && fakeroot debian/rules binary DEB_BUILD_OPTIONS=nocheck \
254 | >>> && cd ../ && apt-get install -y ./*.deb && rm ./*.deb \
255 | >>> && cd demo && bloom-generate rosdebian && fakeroot debian/rules binary DEB_BUILD_OPTIONS=nocheck \
256 | >>> && cd ../ && apt-get install -y ./*.deb && rm ./*.deb
257 |
ERROR: failed to solve: process "/bin/bash -c mkdir -p ${ROS_ROOT}/src && cd ${ROS_ROOT}/src && git clone https://github.com/ros-planning/moveit_task_constructor.git -b humble && cd moveit_task_constructor && source ${ROS_ROOT}/setup.bash && cd msgs && bloom-generate rosdebian && fakeroot debian/rules binary && cd ../ && apt-get install -y ./*.deb && rm ./*.deb && cd rviz_marker_tools && bloom-generate rosdebian && fakeroot debian/rules binary && cd ../ && apt-get install -y ./*.deb && rm ./*.deb && cd core && bloom-generate rosdebian && fakeroot debian/rules binary DEB_BUILD_OPTIONS=nocheck && cd ../ && apt-get install -y ./*.deb && rm ./*.deb && cd capabilities && bloom-generate rosdebian && fakeroot debian/rules binary DEB_BUILD_OPTIONS=nocheck && cd ../ && apt-get install -y ./*.deb && rm ./*.deb && cd visualization && bloom-generate rosdebian && fakeroot debian/rules binary DEB_BUILD_OPTIONS=nocheck && cd ../ && apt-get install -y ./*.deb && rm ./*.deb && cd demo && bloom-generate rosdebian && fakeroot debian/rules binary DEB_BUILD_OPTIONS=nocheck && cd ../ && apt-get install -y ./*.deb && rm ./*.deb" did not complete successfully: exit code: 2
~/workspaces/isaac_ros-dev/src/isaac_ros_common
I am using JetPack 6.0
